    5. [geloest] While Schleife mit mehreren Objekten?
    • oberfragger
      oberfragger @paul53 last edited by
      Ich habe das jetzt wie folgt gemacht
      Bekomme leider direkt bei Scriptstart einen Fehler:
      23:49:18.580	info	javascript.0 (1050) Start javascript script.js.common.Gardena_Zisterne_fuellen
      23:49:18.584	error	javascript.0 (1050) script.js.common.Gardena_Zisterne_fuellen: script.js.common.Gardena_Zisterne_fuellen:15
      23:49:18.585	error	javascript.0 (1050) at script.js.common.Gardena_Zisterne_fuellen:21:3
      Hier ist mein Script:
       <variables>
         <variable id="kOPQJ]S}yV|$_f]Oqd(J">VentilListe</variable>
       </variables>
       <block type="variables_set" id="M3[*C!*iU=a~.;w[O#hN" x="63" y="63">
         <field name="VAR" id="kOPQJ]S}yV|$_f]Oqd(J">VentilListe</field>
           <block type="selector" id="t.l2|UUi=U+YvUD=mzNd">
             <field name="TEXT">channel[state.id=smartgarden.0.*.*.*.activity_value]</field>
           <block type="on_ext" id="$Ag5y!5Z3-hN-EIK^ofg">
             <value name="OID0">
               <shadow type="field_oid" id="#ZXf^+~J~%RUH4`-=[ZT">
               <block type="variables_get" id="M;$PLj#-fEc@gj;LEa`#">
               <block type="debug" id="[;Payw+#!rr-NRRBt*Xs">
                 <value name="TEXT">
                   <shadow type="text" id="./T:zhrosIxNAii:7P1Z">
                     <field name="TEXT">VentilListe geaendert</field>
                   <block type="control" id="v5n(v^D575)2=t)lBQ?y">
                     <field name="OID">smartgarden.0.LOCATION_09fda3bb-2Dddb4-2D468b-2Dab8a-2Dbdb83b0f1c9f.DEVICE_2be886f7-2D6553-2D4308-2D80f8-2D0c504c0d1227.SERVICE_VALVE_2be886f7-2D6553-2D4308-2D80f8-2D0c504c0d1227.activity_value</field>
                       <block type="text" id=",]Ooz3-Ppco9OU;#BA[t">
                         <field name="TEXT">CLOSED</field>
                       <block type="debug" id="_;cw}ugS3aUD4G_{]BC,">
                         <value name="TEXT">
                           <shadow type="text" id="~0#w9@Z[mN|iGkwQ#m7=">
                             <field name="TEXT">Zisternenbefuellung auf "CLOSED"</field>
                           <block type="debug" id="v]O7TgC@o6~Cd#t3bHAf">
                             <value name="TEXT">
                               <shadow type="text" id="]`OS2mAyDBt-akr,a2v-">
                                 <field name="TEXT">SR</field>
                               <block type="text_join" id="M3D$:7-yk2K*v*ji~sZ1">
                                 <value name="ADD0">
                                   <block type="text" id="y-eW4FjnKGL?EbUzIKB5">
                                     <field name="TEXT">SR04 Distance = </field>
                                 <value name="ADD1">
                                   <block type="get_value" id="(6O;5+BRzS1r#u4tKUl)">
                                     <field name="OID">sonoff.0.Zisterne.SR04_Distance</field>
                               <block type="controls_if" id="@aQzk(;^XM7lHL^Vq#lD">
                                   <block type="logic_compare" id="[rdAMw0QCENLXI/O^{oT">
                                     <field name="OP">GT</field>
                                       <block type="get_value" id="jCD(:CCb,WKeL~OZLqn#">
                                       <block type="math_number" id=":J?8[_WhiTRi4FfW#oha">
                                         <field name="NUM">105</field>
                                   <block type="debug" id="sljG:^;`/.l{dH0V!z=c">
                                     <value name="TEXT">
                                       <shadow type="text" id="3#7ozj#K2g2Fx(XKNIof">
                                         <field name="TEXT">Schleife betreten</field>
                                       <block type="control" id="5Qb.wHu|lc;MewZq/nHs">
                                           <block type="text" id="tYK|/!cUyD/`2.04p@]N">
                                             <field name="TEXT">MANUAL_WATERING</field>
                                           <block type="controls_flow_statements" id="}Hjmz^iFduo2^a3i4|aL">
                                             <field name="FLOW">BREAK</field>
               <block type="control" id="s7k@e(S25x|sB_QjP[7A">
                   <block type="text" id="o|V+6RXEQ61dQ;E4L8C*">
      Objekt der Zisternenbefüllung:
      "_id": "smartgarden.0.LOCATION_09fda3bb-2Dddb4-2D468b-2Dab8a-2Dbdb83b0f1c9f.DEVICE_2be886f7-2D6553-2D4308-2D80f8-2D0c504c0d1227.SERVICE_VALVE_2be886f7-2D6553-2D4308-2D80f8-2D0c504c0d1227.activity_value"
      Beispielobjekt eines Ventils:
      "_id": "smartgarden.0.LOCATION_09fda3bb-2Dddb4-2D468b-2Dab8a-2Dbdb83b0f1c9f.DEVICE_e8990271-2D7615-2D4807-2D864b-2D2505dc75699a.SERVICE_VALVE_e8990271-2D7615-2D4807-2D864b-2D2505dc75699a-3A1.activity_value",
      Wo liegt mein Fehler?
      • dslraser
        dslraser Forum Testing Most Active @oberfragger last edited by dslraser
        @oberfragger sagte in While Schleife mit mehreren Objekten?:
        Dieser DP ist read only. Was willst Du steuern ?
        Willst Du die Bewässerung starten ? Das geht anders....
        https://github.com/jpgorganizer/ioBroker.smartgarden#for-service_valve_set
        oberfragger 2 Replies Last reply Reply Quote 0
        • oberfragger
          oberfragger @dslraser last edited by oberfragger
          @dslraser Wow.
          Ich Depp. Stimmt. Ganz vergessen. Das muss man über die Zeit machen.
          Ich habe 1 Gardena-Ventil (so ein Teil mit Batterien) direkt am Wasserhahn. Der befüllt mir die Zisterne, wenn diese zu leer ist (> 105 cm Wasserhöhe). Die Bewässerung zieht das Wasser immer aus der Zisterne und ich brauch nichts manuell umstellen.
          Ich mache morgen mal weiter. Jetzt Bett. Ich melde mich.
          • oberfragger
            oberfragger @Asgothian last edited by
            @asgothian Habs geändert und richtige Liste eingesetzt. Hatte mich bei Import auch gewundert, welche Liste das ist...
            Da das Ventil welches die Zisterne befüllen soll, Teil der Liste geworden ist, bin ich nun in einer Schleife. Der ioBroker mag das garnicht:
            Ich teste morgen mal weiter. Denke der Weg ist der richtige und ich bin nicht weit weg von einer vollautomatischen Bewässerung, inkl. Befüllung der Zisterne wenn leer.
            • oberfragger
              @dslraser und
              @Asgothian
              Ich habe jetzt mal mein Script etwas angepasst. Leider wirds nun nicht mehr getriggert (der Debu´g-Outpunkt kommt nicht und das Ventil zur Befüllung springt nicht an)... AARGH!
              1. Die Werte aller 6 Ventile direkt in die Liste geschrieben. Damit möchte ich vermeiden, dass das Scipt auf das Gardena Smart Water Control reagiert. Dieser schreibt den Wert ja auch unter Activity_Value rein
              2. Vor Eintritt in die Schleife wird auf den Füllstand der Zisterne geachtet
              3. In der Schleife wird nun gezählt, wie oft "CLOSED" vorkommt. Wenn 6 Ventile geschlossen sind, dann soll auch kein Wasser mehr in die Zisterne laufen. Wenn mindestens 1Mal KEIN "CLOSED" steht, dann soll Wasser in die Zisterne geleitet werden.
              Aber warum triggert das nicht, die Liste verändert sich doch, sobald ich die Bewässerung starte...?
              oberfragger 1 Reply Last reply Reply Quote 0
              • oberfragger
                oberfragger @oberfragger last edited by oberfragger
                Ok, Korrektur.
                Habs hinbekommen.
                Jetzt muss ich nur noch rausfinden, wie ich die Bewässerung stoppen kann. Die GardenaAPI mag irgendwie die EIngabe(n) nicht. Das sollte ich auch noch rausbekommen.
                JUHU! Gute Doku ist doch alles!
                Dank an Euch! WIeder was dazugelernt.
                  paul53 @oberfragger last edited by
                  @oberfragger sagte: Habs hinbekommen.
                  Nicht ganz: Der Zähler muss vor der Schleife auf 0 initialisiert werden.
                  • oberfragger
                    oberfragger @paul53 last edited by oberfragger
                    @paul53 Verdammt! Und danke für den Hinweis. Dachte der ist bei Scriptstart immer auf 0.
                    Ich änder das mal lieber sonst läuft die Zisterne über 😉
                      paul53 @oberfragger last edited by paul53
                      @oberfragger sagte: Dachte der ist bei Scriptstart immer auf 0.
                      Nach Skriptstart schon, aber nicht, nachdem die Schleife einmal durchlaufen wurde (nächster Trigger).
                      oberfragger 1 Reply Last reply Reply Quote 1
                      • oberfragger
                        @paul53 said in [geloest] While Schleife mit mehreren Objekten?:
                        Okay. Den Fall hatte ich glatt wieder verdrängt.
                        1439
