    4. Neuer Adapter EMS-ESP für Bosch Heizungen
      tp1de @Chaot last edited by
      @chaot Freut mich. Noch Fragen zur km200 Strukturumsetzung?
      • Chaot
        Chaot @tp1de last edited by
        @tp1de
        Noch ein paar Fehlermeldungen wegen falscher Datenart:
        ems-esp.0
        2021-06-18 23:16:57.259	info	State value to set for "ems-esp.0.dhwCircuits.dhw1.wwactivated" has to be type "number" but received type "string"
        ems-esp.0
        2021-06-18 23:16:55.634	info	State value to set for "ems-esp.0.dhwCircuits.dhw1.wwcirc" has to be type "number" but received type "string"
        ems-esp.0
        2021-06-18 23:16:55.418	info	State value to set for "ems-esp.0.dhwCircuits.dhw1.wwcircmode" has to be type "number" but received type "string"
        ems-esp.0
        2021-06-18 23:16:54.818	info	State value to set for "ems-esp.0.dhwCircuits.dhw1.wwchargetype" has to be type "number" but received type "string"
        ems-esp.0
        2021-06-18 23:16:54.484	info	State value to set for "ems-esp.0.dhwCircuits.dhw1.wwcircpump" has to be type "number" but received type "string"
        ems-esp.0
        2021-06-18 23:16:53.809	info	State value to set for "ems-esp.0.dhwCircuits.dhw1.wwcomfort" has to be type "number" but received type "string"
        ems-esp.0
        2021-06-18 23:16:53.471	info	State value to set for "ems-esp.0.dhwCircuits.dhw1.wwtype" has to be type "number" but received type "string"
        ems-esp.0
        2021-06-18 23:16:52.576	info	State value to set for "ems-esp.0.heatSources.hs1.maintenance" has to be type "number" but received type "string"
        ems-esp.0
        2021-06-18 23:16:47.096	info	State value to set for "ems-esp.0.heatSources.hs1.heatingactivated" has to be type "number" but received type "string"
        ems-esp.0
        2021-06-18 23:16:46.727	info	State value to set for "ems-esp.0.heatSources.hs1.ignwork" has to be type "number" but received type "string"
        ems-esp.0
        2021-06-18 23:16:46.428	info	State value to set for "ems-esp.0.heatSources.hs1.fanwork" has to be type "number" but received type "string"
        ems-esp.0
        2021-06-18 23:16:46.188	info	State value to set for "ems-esp.0.heatSources.hs1.heatingpump" has to be type "number" but received type "string"
        ems-esp.0
        2021-06-18 23:16:45.492	info	State value to set for "ems-esp.0.heatSources.hs1.burngas" has to be type "number" but received type "string"
        ems-esp.0
        2021-06-18 23:16:42.452	info	State value to set for "ems-esp.0.heatSources.hs1.tapwateractive" has to be type "number" but received type "string"
        ems-esp.0
        2021-06-18 23:16:42.146	info	State value to set for "ems-esp.0.heatSources.hs1.heatingactive" has to be type "number" but received type "string"
        ems-esp.0
        2021-06-18 23:16:41.263	info	start initializing ems states
        ems-esp.0
        2021-06-18 23:16:40.251	info	starting. Version 0.9.0 in /opt/iobroker/node_modules/iobroker.ems-esp, node: v12.22.1, js-controller: 3.3.12
          @chaot
          Die enum Attribute scheinen falsch übermittelt zu werden vom Ems-esp.
          was gibt ems-esp/api/boiler/burngas zurück?
          Bei mir
          "name": "burngas",
          "fullname": "gas",
          "value": 0,
          "type": "boolean",
          "min": 0,
          "max": 1,
          "enum": [
          0,
          "unit": " ",
          "writeable": false
          Chaot 2 Replies Last reply Reply Quote 0
          • Chaot
            Chaot @tp1de last edited by Chaot
            @tp1de sagte in Neuer Adapter EMS-ESP für Bosch Heizungen:
            /api/boiler/burngas
              "name": "burngas",
              "fullname": "gas",
              "value": "off",
              "type": "boolean",
              "min": 0,
              "max": 1,
              "enum": [
                "off",
                "on"
              "unit": " ",
              "writeable": false
            Ist übrigens eine Gastherme Marke Sieger
            • Chaot
              @tp1de
              Zum Basteln:
              Wenn ich die KM200 Struktur weglasse kommen ein paar mehr:
              ems-esp.0
              2021-06-18 23:45:05.132	info	recordings:false hour
              ems-esp.0
              2021-06-18 23:45:05.132	info	km200:false 90 secs
              ems-esp.0
              2021-06-18 23:45:05.131	info	ems :true 15 secs
              ems-esp.0
              2021-06-18 23:45:05.131	info	start polling intervals now.
              ems-esp.0
              2021-06-18 23:45:04.950	info	end of initializing ems states
              ems-esp.0
              2021-06-18 23:45:03.835	info	State value to set for "ems-esp.0.thermostat.hc1.control" has to be type "number" but received type "string"
              ems-esp.0
              2021-06-18 23:45:03.541	info	State value to set for "ems-esp.0.thermostat.hc1.reducemode" has to be type "number" but received type "string"
              ems-esp.0
              2021-06-18 23:45:03.224	info	State value to set for "ems-esp.0.thermostat.hc1.heatingtype" has to be type "number" but received type "string"
              ems-esp.0
              2021-06-18 23:45:01.676	info	State value to set for "ems-esp.0.thermostat.hc1.holidaymode" has to be type "number" but received type "string"
              ems-esp.0
              2021-06-18 23:45:01.373	info	State value to set for "ems-esp.0.thermostat.hc1.summermode" has to be type "number" but received type "string"
              ems-esp.0
              2021-06-18 23:44:59.262	info	State value to set for "ems-esp.0.thermostat.hc1.modetype" has to be type "number" but received type "string"
              ems-esp.0
              2021-06-18 23:44:58.598	info	State value to set for "ems-esp.0.thermostat.hc1.mode" has to be type "number" but received type "string"
              ems-esp.0
              2021-06-18 23:44:57.702	info	State value to set for "ems-esp.0.thermostat.wwcircmode" has to be type "number" but received type "string"
              ems-esp.0
              2021-06-18 23:44:57.408	info	State value to set for "ems-esp.0.thermostat.wwmode" has to be type "number" but received type "string"
              ems-esp.0
              2021-06-18 23:44:57.144	info	State value to set for "ems-esp.0.thermostat.building" has to be type "number" but received type "string"
              ems-esp.0
              2021-06-18 23:44:54.229	info	State value to set for "ems-esp.0.boiler.wwheat" has to be type "number" but received type "string"
              ems-esp.0
              2021-06-18 23:44:54.060	info	State value to set for "ems-esp.0.boiler.wwactive" has to be type "number" but received type "string"
              ems-esp.0
              2021-06-18 23:44:53.764	info	State value to set for "ems-esp.0.boiler.wwtempok" has to be type "number" but received type "string"
              ems-esp.0
              2021-06-18 23:44:53.644	info	State value to set for "ems-esp.0.boiler.wwrecharging" has to be type "number" but received type "string"
              ems-esp.0
              2021-06-18 23:44:53.115	info	State value to set for "ems-esp.0.boiler.wwcharging" has to be type "number" but received type "string"
              ems-esp.0
              2021-06-18 23:44:52.856	info	State value to set for "ems-esp.0.boiler.wwdisinfecting" has to be type "number" but received type "string"
              ems-esp.0
              2021-06-18 23:44:52.444	info	State value to set for "ems-esp.0.boiler.wwonetime" has to be type "number" but received type "string"
              ems-esp.0
              2021-06-18 23:44:52.204	info	State value to set for "ems-esp.0.boiler.wwactivated" has to be type "number" but received type "string"
              ems-esp.0
              2021-06-18 23:44:50.634	info	State value to set for "ems-esp.0.boiler.wwcirc" has to be type "number" but received type "string"
              ems-esp.0
              2021-06-18 23:44:50.363	info	State value to set for "ems-esp.0.boiler.wwcircmode" has to be type "number" but received type "string"
              ems-esp.0
              2021-06-18 23:44:49.698	info	State value to set for "ems-esp.0.boiler.wwchargetype" has to be type "number" but received type "string"
              ems-esp.0
              2021-06-18 23:44:49.365	info	State value to set for "ems-esp.0.boiler.wwcircpump" has to be type "number" but received type "string"
              ems-esp.0
              2021-06-18 23:44:48.811	info	State value to set for "ems-esp.0.boiler.wwcomfort" has to be type "number" but received type "string"
              ems-esp.0
              2021-06-18 23:44:48.470	info	State value to set for "ems-esp.0.boiler.wwtype" has to be type "number" but received type "string"
              ems-esp.0
              ems-esp.0
              ems-esp.0
              ems-esp.0
              ems-esp.0
              ems-esp.0
              ems-esp.0
              2021-06-18 23:44:47.112	info	State value to set for "ems-esp.0.boiler.maintenance" has to be type "number" but received type "string"
              ems-esp.0
              2021-06-18 23:44:41.440	info	State value to set for "ems-esp.0.boiler.heatingactivated" has to be type "number" but received type "string"
              ems-esp.0
              2021-06-18 23:44:41.175	info	State value to set for "ems-esp.0.boiler.ignwork" has to be type "number" but received type "string"
              ems-esp.0
              2021-06-18 23:44:40.871	info	State value to set for "ems-esp.0.boiler.fanwork" has to be type "number" but received type "string"
              ems-esp.0
              2021-06-18 23:44:40.518	info	State value to set for "ems-esp.0.boiler.heatingpump" has to be type "number" but received type "string"
              ems-esp.0
              2021-06-18 23:44:39.913	info	State value to set for "ems-esp.0.boiler.burngas" has to be type "number" but received type "string"
              ems-esp.0
              2021-06-18 23:44:37.131	info	State value to set for "ems-esp.0.boiler.tapwateractive" has to be type "number" but received type "string"
              ems-esp.0
              2021-06-18 23:44:36.858	info	State value to set for "ems-esp.0.boiler.heatingactive" has to be type "number" but received type "string"
              ems-esp.0
              2021-06-18 23:44:35.988	info	start initializing ems states
              ems-esp.0
              2021-06-18 23:44:34.976	info	starting. Version 0.9.0 in /opt/iobroker/node_modules/iobroker.ems-esp, node: v12.22.1, js-controller: 3.3.12
              ems-esp.0
              2021-06-18 23:44:34.895	info	starting. Version 0.9.0 in /opt/iobroker/node_modules/iobroker.ems-esp, node: v12.22.1, js-controller: 3.3.12
              ems-esp.0
                @chaot Ok ich registriere gerade, das die Einstellungen von MQTT Settings für das Bolean Format auch für API genommen werden. Das ist nicht so gut. Wenn Du das in den MQTT settings auf 0/1 setzt, dann sollte es funktionieren.
                Chaot T 2 Replies Last reply Reply Quote 0
                • Chaot
                  @tp1de Jau! Treffer!
                  Klappt einwandfrei - ein weiterer Punkt für die Installationsanleitung 👍
                    tp1de @tp1de last edited by
                    @tp1de Was kommt bei ..../api/thermostat/building zurück?
                    Bei mir:
                    name	"building"
                    fullname	"building"
                    value	2
                    type	"enum"
                    min	1
                    max	3
                    enum
                    0	"light"
                    1	"medium"
                    2	"heavy"
                    writeable	true
                    • Chaot
                        "name": "building",
                        "fullname": "building",
                        "value": 1,
                        "type": "enum",
                        "min": 0,
                        "max": 2,
                        "enum": [
                          "light",
                          "medium",
                          "heavy"
                        "writeable": true
                        @chaot
                        Danke fürs erste Feedback. Das Boolean Format sollte ich im Adapter abfangen können, um unabhängig von den MQTT Settings zu sein. Die enum Formate des http get Befehls sind leicht unterschiedlich. Ich schaue Morgen mal den Adapter-Code nach. Die einzelnen Werte nehme ich zum initialieren der ioBroker States und die Werte werden dann je Device gelesen. Kannst Du mir zum Abschluss für heute noch schicken, was bei .../api/thermostat zurückkommt?
                        • Chaot
                          @tp1de gerne doch:
                            "id": 76,
                            "errorcode": "(0)",
                            "lastcode": "A0(816) 18.11.2020 22:50",
                            "datetime": "23:58:35 18/06/2021",
                            "intoffset": 0,
                            "minexttemp": -16,
                            "dampedoutdoortemp": 26,
                            "building": 1,
                            "wwmode": 2,
                            "wwcircmode": 2,
                            "hc1": {
                              "seltemp": 22.5,
                              "currtemp": 25,
                              "mode": 1,
                              "modetype": 1,
                              "daytemp": 22.5,
                              "nighttemp": 20,
                              "designtemp": 75,
                              "offsettemp": 0,
                              "holidaytemp": 17,
                              "targetflowtemp": 28,
                              "summertemp": 16,
                              "summermode": 0,
                              "holidaymode": 0,
                              "nofrosttemp": 3,
                              "roominfluence": 3,
                              "minflowtemp": 5,
                              "maxflowtemp": 75,
                              "flowtempoffset": 5,
                              "heatingtype": 1,
                              "reducemode": 2,
                              "control": 2,
                              "program": 0,
                              "pause": 0,
                              "party": 0
                          • Chaot
                            @tp1de Heute kam noch eine Fehlermeldung:
                            ems-esp.0
                            2021-06-19 01:06:45.413	warn	State value to set for "ems-esp.0.boiler.selburnpow" has value "123" greater than max "100"
                              @chaot oh Deine Heizung kann mehr als 100% Modulation .... Was ist Dein Brenner?
                              • Chaot
                                @tp1de Das ist eine Heizung von Sieger.
                                Den Modulationswert habe ich ehrlich gesagt nie beachtet, aber der ist irgendwie seltsam. Aktuell steht 100% im Datenpunkt.
                                Aber selburnpower ist doch ein Setzwert. Der steht auf 100% und sollte doch sich von sich aus nicht verändern. Entweder liest hier der ems-esp Mist aus oder das ist ein anderer Datenpunkt.
                                  @chaot Die min / max Werte kommen über das API und ich setze diese dann in den States. Deshalb die Warnmeldung.
                                  Kannst auch in dem State den Max-Wert erhöhen, damit keine Warnung kommt.
                                  • Chaot
                                    @tp1de Wäre eine Möglichkeit.
                                    Ist aber trotzdem strange wo da 123 herkommen sollten.
                                    Edit: Aktuell stehen wieder 123% drin.Brenner.jpg
                                      tp1de @Chaot last edited by tp1de
                                      @chaot Es gibt aktuell noch einige "Ungereimtheiten" in der EMS-ESP Firmware.
                                      Das liegt auch daran, dass mehr als 60 unterschiedliche Hardware-Systeme unterstützt werden.
                                      Du kannst ja im Github eine Fehlermeldung aufmachen und den JSON-Output aus dem Browser für das Feld als Beispiel hinzufügen.
                                      Ich habe gerade im Github einen Thread geöffnet: https://github.com/emsesp/EMS-ESP32/issues/76.
                                      Der MQTT Parameter für das Boolean Format verändert die Werte für Boolean and Enum von Number zu Text.
                                      Das betrifft scheinbar auch das Setzen der Werte in den http post Kommandos.
                                      D.h. der Adapter funktioniert im Moment nur mit dem Boolean Format 1/0 in den MQTT Settings.
                                      Ich versuche das im Adapter anzupassen, ist aber nicht so trivial. Besser wäre es die FW des ems-esp zu verändern.
                                      tp1de created this issue in emsesp/EMS-ESP32
                                      closed MQTT settings for Boolean Format are changing API V3 Output #76
                                      • Chaot
                                        @tp1de Werde ich heute Nachmittag machen. Ich will zuerst noch testen ob der Datenpunkt wirklich übereinstimmt.
                                        Wenn ich also an der Regelung den Maximalwert auf 50% setze müsste der Punkt mitgehen. Wenn nicht, liest er irgendwas falsches aus dem Protokoll aus.
                                          @chaot sagte in Neuer Adapter EMS-ESP für Bosch Heizungen:
                                          wenn ich also an der Regelung den Maximalwert auf 50% setze
                                          Versuch mal den Wert über den Adapter zu setzen: boiler.burnmaxpower.
                                            manrum1 @tp1de last edited by
                                            @tp1de Hi, habe jetzt eine 2. Instanz installiert. Die erste läuft, bis auf ein paar Ungereimtheiten, problemlos.
                                            api bosch buderus ems-esp heizungssteuerung junkers km200 netfit
                                            60
                                            741
                                            178966
