    4. Material Design Widgets: List Widget
      BobBruni @Scrounger last edited by
      @scrounger
      Hier der Export
      [{"tpl":"tplVis-materialdesign-List","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","vibrateOnMobilDevices":"50","listType":"text","listItemDividerStyle":"standard","listLayout":"standard","showScrollbar":"true","listItemDataMethod":"inputPerEditor","countListItems":"1","listItemAlignment":"left","listBackground":"#mdwTheme:vis-materialdesign.0.colors.list.background","listItemBackground":"#mdwTheme:vis-materialdesign.0.colors.list.background_off","listItemBackgroundActive":"#mdwTheme:vis-materialdesign.0.colors.list.background_on","colorSwitchThumb":"#mdwTheme:vis-materialdesign.0.colors.switch.off","colorSwitchTrack":"#mdwTheme:vis-materialdesign.0.colors.switch.track","colorSwitchTrue":"#mdwTheme:vis-materialdesign.0.colors.switch.on","colorSwitchHover":"#mdwTheme:vis-materialdesign.0.colors.switch.off_hover","colorCheckBox":"#mdwTheme:vis-materialdesign.0.colors.checkbox.on","colorListItemHover":"#mdwTheme:vis-materialdesign.0.colors.list.hover","colorListItemSelected":"#mdwTheme:vis-materialdesign.0.colors.list.selected","colorListItemText":"#mdwTheme:vis-materialdesign.0.colors.list.text","colorListItemTextSecondary":"#mdwTheme:vis-materialdesign.0.colors.list.subText","colorListItemTextRight":"#mdwTheme:vis-materialdesign.0.colors.list.text_right","colorListItemTextSecondaryRight":"{mode:vis-materialdesign.0.colors.darkTheme;light:vis-materialdesign.0.colors.light.list.subText_right;dark:vis-materialdesign.0.colors.dark.list.subText_right; mode === \"true\" ? dark : light}","colorListItemHeaders":"#mdwTheme:vis-materialdesign.0.colors.list.header","colorListItemDivider":"#mdwTheme:vis-materialdesign.0.colors.list.divider","headerFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.list.header","listItemFont":"#mdwTheme:vis-materialdesign.0.fonts.list.text","listItemSubFont":"#mdwTheme:vis-materialdesign.0.fonts.list.subText","listItemRightFont":"#mdwTheme:vis-materialdesign.0.fonts.list.text_right","listItemSubRightFont":"#mdwTheme:vis-materialdesign.0.fonts.list.subText_right","listItemTextSize":"#mdwTheme:vis-materialdesign.0.fontSizes.list.text","listItemSubTextSize":"#mdwTheme:vis-materialdesign.0.fontSizes.list.subText","listItemTextRightSize":"#mdwTheme:vis-materialdesign.0.fontSizes.list.text_right","listItemSubTextRightSize":"#mdwTheme:vis-materialdesign.0.fontSizes.list.subText_right","listItemHeaderTextSize":"#mdwTheme:vis-materialdesign.0.fontSizes.list.header","listImageColor0":"#mdwTheme:vis-materialdesign.0.colors.list.icon_off","listImageActiveColor0":"#mdwTheme:vis-materialdesign.0.colors.list.icon_on","listImageColor1":"#mdwTheme:vis-materialdesign.0.colors.list.icon_off","listImageActiveColor1":"#mdwTheme:vis-materialdesign.0.colors.list.icon_on","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"groupHeader0":"TEST","listImage0":"ab-testing","listImage1":"abacus"},"style":{"left":"10px","top":"270px"},"widgetSet":"materialdesign"}]
      • Scrounger
        Scrounger Developer last edited by
        @bobbruni
        Also Header geht, evtl. DARK Themen aktiv?
        Das andere ist ein Bug, wir in der nächsten Version behoben sein
          @scrounger
          Sorry, hab mich nicht präzise genug ausgedrückt.
          Beim Header meinte ich nicht die Farbe, sondern die Schriftgröße, die nicht übernommen wird...
          • Scrounger
            Scrounger Developer @BobBruni last edited by Scrounger
            @bobbruni
            Ok ist auch nen Bug, da wird gar keine Schriftgröße übernommen. Hab ich behoben.
            Zur Info, damit das auch angewendet wird musst du auch was bei Label eintragen.
              PatrickFro last edited by
              Gibt es einen Trick ein Element "einschieben" zu können? Ich habe etwa 70 Einträge und muss an 25. Stelle ein weiteres Gerät einfügen. Alles anzupassen ist so unkomfortabel 😉
                darkiop Most Active last edited by
                @Scrounger
                Ich nutze deine Liste mit Bindings zur Anzeige von Daten. Die OID habe ich dafür nicht befüllt - nur via Bindungs über zweiter Text / Text Rechts. Allerdings macht das auch keinen Unterschied, siehe Beispiel Projekt.
                Bei jedem Update der DPs werden dann die Fehler aus den Screenshot unten geworfen - bei meinem Hauptprojekt sind das ein paar und das ganze summiert sich innerhalb weniger Minuten zu einem Chrome.exe Prozess mit mehreren GB 🙂
                Test String - bei manuellem Update von diesem wirft der Browser den Fehler.
                createState("Test.Test-String", 'test1', {name: "Test-String", type: "string"});
                Beispiel-Projekt zum Nachvollziehen:
                2021-06-21-test6.zip
                Log - mit tausenden von Einträgen nach wenigen Sekunden:
                Hast du eine Idee woran das Liegen könnte?
                • Scrounger
                  Scrounger Developer @darkiop last edited by Scrounger
                  @darkiop
                  Welche Version nutzt du?
                  Sieht mir nach ne Log Meldung aus, die ich eingebaut habe um was zu analysieren und vergessen hab wieder raus zu nehmen
                  Und noch nen Tipp anstatt der ganzen bindings würde ich das value Widget per html einbinden, ist von der Performance her besser
                    darkiop Most Active @Scrounger last edited by darkiop
                    @scrounger sagte in Material Design Widgets: List Widget:
                    bin auf der 0.5.9
                    Danke, das Teste ich mal - das gibt dann eine Fleißarbeit 🙂
                    Edit:
                    Ich habe in meinem Beispiel Projekt aus meinem Post von heute Morgen eine View mit dem Value-Widget + LIste erstellt - dann wird der Fehler nicht mehr geworfen. Das muss also mit Aktualisierung des DPs über Bindungs zusammenhängen. Heißt für mich: Nach der Fleißarbeit sollte mein Problem behoben sein ...
                    Edit #2
                    Denke das wird für die Werte rechts funktionieren, ich stelle da mal ein paar Listen um und beobachte die Anzahl an Meldungen. Ich schreibe allerdings in 'zweiter Text' den last change des DPs, den .lc bekomme ich aber nicht über die OID. Vieleicht wäre das noch eine Idee für eine Erweiterung.
                    • Scrounger
                      @darkiop sagte in Material Design Widgets: List Widget:
                      Edit:
                      Die Log Meldung hab ich bereits gefunden, war ein überbleibsel im code zum debuggen. Wird in der nächsten Version raus sein.
                      Das kommt wahrscheinlich durch die Bindings und nicht durch die log meldung. Technik der Bidnings ist, dass wenn sich ein Wert ändert, wird das ganze Widget neu erzeugt, was letztendlich mehr speicher braucht - vorallem wenn die aktualisierung sehr niedrig ist, z.B. wird der Werte jede sekunde aktualsiert wird auch jede Sekunden das Widget neu erzeugt.
                      Früher gab es deswegen auch mal das Problem mit dem Überlauf.
                      Deshalb hab ich das Value Widget entwickelt, hier wird nur der Wert bei Veränderung aktualisert und nicht das ganze Widget.
                      Edit #2
                      Danach sollte deine Speicherauslastung auch runter gehen. Sollten beim Value Widget funktionen fehlen, schreib nen issue auf github und ich bau es ein.
                        Danke!
                        Perfekt, ich habe die Werte von den meinen größten Liste bereits umgestellt auf das Value Widget - die Anzahl der Meldungen pro Sekunden hat sich dadurch schon deutlich reduziert - die verbleibenden sind dann wohl von den OID .lc - Bindings. Issue erstelle ich dafür. Auch hier, Danke!!
                        Weis nicht ob nur ich den Use-case für den .lc in der Liste sehe - aber könntest du dir vortsellen bei der Liste eine Option "Zeige LastChange-Date der OID im Feld 'Zweiter Text'" einzubauen? Ggf. auch mit einer OID zum aktivieren/deaktivieren?
                        • Scrounger
                          Für das list Widget nicht. Im value Widget Bau ich das ein, dass kann dann ja im list Widget verwendet werden
                            Hi @Scrounger, kannst du mir sagen wo ich die Logmeldung finde? Dann würde ich die Lokal bei mir schonmal entfernen und testen ob damit mein Problem gelöst ist.
                            • Scrounger
                              @darkiop
                              Nimm die Version von github, da ist es bereits draussen.
                                @scrounger Ok, hab gesehen das du commited hast, aber keine Acht auf die Log Meldung gehabt. Ich teste und melde mich.
                                  Die Meldungen sind damit erledigt, schaut dies bzgl. super aus! Danke!
                                  Alledings muss ich wohl das TopAppBar Widget neu setzen - das hats mit dem Update etwas verrupft. Setzt man es im Editor neu passt alles. Da ich das allerdings über den Editor und nicht über json konfiguriert habe muss der finale Wechsel noch etwas warten.
                                    Guten Morgen, ich hatte letztens eine größere Aktion und musste viele manuell Icons umstellen.
                                    Meinst du es wäre möglich, das automatische Suchen der Icons in deinen Widgets, per Option in den Adapter-Einstellungen zu deaktivieren?
                                    Das würde die Arbeit damit beschleunigen, wenn man
                                    • lokale Items nutzt
                                    • die Namen der Material Design Items über die Webseite herraussucht (Vorte
                                    • die Namen der Icons kennt
                                    Das Vorrausladen ist ne feine sache - allerdings dauert das auch immer 1-2-3 Sekunden und kann in den oben genannten Fällen etwas bremsen 🙂
                                    Wenn ja, kann ich da zu gerne mal ein Issue anlegen.
                                      stephan.ritscher last edited by
                                      ich habe ein Problem mit dem Update von Bindings beim Verwenden eines über JSON-Datenpunkte definierten List Widget.
                                      Erstelle eine View mit 2 Widgets:
                                      1. List-Widget, definiert über Editor mit
                                      • Anzahl Listenelemente = 0
                                      • Beschriftung[0] = {0_userdata.0.a}
                                      • zweiter Text[0] = {0_userdata.0.a.ts}
                                      1. List-Widget definiert über JSON-Datenpunkt mit Wert:
                                        "text":"{0_userdata.0.a}",
                                        "subText":"{0_userdata.0.a.ts}"
                                      Definiere Datenpunkt 0_userdata.0.a und setze einen Wert.
                                      Öffne View in VIS Runtime.
                                      => Beide Widgets zeigen dieselben Werte an.
                                      Ändere Wert Datenpunkt 0_userdata.0.a während View noch in VIS Runtime geöffnet ist (z.B. in anderem Browser-Tab) und wechsle zurück zu View in VIS Runtime.
                                      => Nur Widget 1 (definiert über Editor) zeigt den neuen Wert von 0_userdata.0.a und den neuen Timestamp, Widget 2 (definiert über JSON) zeigt noch den alten Wert von 0_userdata.0.a.
                                      Mache ich etwas falsch, ist das ein Bug, oder gibt es einen Grund, warum das nicht unterstützt wird?
                                      Viele Grüße
                                      Stephan
                                        stephan.ritscher @stephan.ritscher last edited by
                                        ich habe obiges Szenario nochmal mit dem GitHub Pull Request #186 getestet.
                                        Das Problem ist noch reproduzierbar, wenn beide Listen auf demselben View sind und dieselbe Variable(n) referenzieren.
                                        Wenn ich in einer der Listen 0_userdata.0.b statt 0_userdata.0.a referenziere, funktionieren die Updates in beiden Listen.
                                        Ich vermute, dass jedes Binding nur einmal (pro View) registriert wird, aber nur das registrierende Widget dann die Updates bekommt. Da in obigem Beispiel die JSON-Liste erst den Datenpunkt abrufen muss, der die Liste definiert, ist die Liste immer später mit der Registrierung von anderen Bindings dran als das über Editor definierte View und bekommt somit keine Updates.
                                        Viele Grüße
                                        Stephan
                                          meicker last edited by
                                          Guten Abend 🙂
                                          ich hoffe die Frage habe ich nicht irgendwo übersehen ...
                                          Wenn ich meine Visualisierung auf meinem Rechner ansehe sieht alles gut aus. Wenn ich sie auf meinem Handy im Browser im gleichen WLan ansehe ist alles OK, wenn ich sie mir über die ioBroker APP ansehe habe ich keine Schalter, nur die Beschriftungen. Ich nutze materialdesign - den Switch. Ich habe für das widget den Upload schon neu gemacht, hat auch nichts gebracht.
                                          Gerade habe ich festgestellt das es passiert wenn ich mich über iobroker.pro anmelde. Hat jemand eine Idee warum das so ist und was ich dagegen unternehmen muss ?
                                          Viele Grüße,
                                          Marc
                                            mainhunter last edited by
                                            arbeite seit etwa einem Jahr mit ioBroker und bin immer noch fasziniert davon. Seit ca. 5 Monaten nutze ich die Material Design Widgets, wirklich ganz super programmierte Widgets! Nun habe ich Fragen zu den HTML Properties, wo kann ich diese Snippets finden und auch nutzen, würde auch gerne solche Elemente im List Widget verwenden.
                                            Ich hoffe Ihr könnt mir helfen.
                                            vis
                                            31
                                            103
                                            14174
