    4. Test Adapter Material Design Widgets v0.5.x
    • O
      Oli @Scrounger last edited by
      @scrounger
      hier das gewünschte log
      log neu
      • Scrounger
        Scrounger Developer @Oli last edited by
        @oli
        Hast du das Dialog Widget angewählt bevor du das console log gezogen hast?
        Erstell Mal das Dialog Widget komplett neu.
        • O
          Oli @Scrounger last edited by Oli
          @scrounger
          Ja habe ich, heute schaffe ich es nicht mehr, liefer es morgen nach
          • Scrounger
            @oli
            OK da steht leider nix brauchbares drin. Dann bitte Dialog Widget komplett neu erstellen.
            • O
              @scrounger
              guten Morgen, habe den Fehler gefunden. Ich habe bei der Rahmenfarbe ein Binding hinterlegt, sobald ich das herausnehme funktioniert das Widget wieder
              Hier mal ein Export des Widgets.
              [{"tpl":"tplVis-materialdesign-Vuetify-Dialog-View","data":{"g_fixed":true,"g_visibility":true,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":true,"g_css_border":true,"g_gestures":false,"g_signals":true,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","showDialogMethod":"button","fullscreenResolutionLower":"360","vibrateOnMobilDevices":"50","buttonStyle":"raised","iconPosition":"left","closingClickOutside":"true","showTitle":"true","buttonPosition":"flex-end","buttonSize":"medium","signals-cond-0":">","signals-val-0":"0","signals-icon-0":"/icons-mfd-png/measure_battery_0.png","signals-icon-size-0":"40","signals-blink-0":false,"signals-horz-0":"7","signals-vert-0":"10","signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":"0","signals-icon-1":"/icons-mfd-png/measure_battery_100.png","signals-icon-size-1":"40","signals-blink-1":false,"signals-horz-1":"7","signals-vert-1":"10","signals-hide-edit-1":false,"signals-cond-2":">","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"contains_view":"Startseite_System_Batteriestatus_Dialog","dialogMaxWidth":"85%","viewHeight":"90%","backgroundColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.background","showDivider":true,"dividerColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.divider","titleFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.dialog.title","titleFont":"#mdwTheme:vis-materialdesign.0.fonts.dialog.title","title":"Batteriestatus","titleColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.header_text","buttonFullWidth":true,"buttonText":"Schließen","buttonFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.dialog.button","buttonFont":"#mdwTheme:vis-materialdesign.0.fonts.dialog.button","buttonFontColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.close_button_text","pressColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.close_button_press","viewDistanceToBorder":"0","signals-oid-2":"","signals-oid-1":"0_userdata.0.Energieverbrauch.Batterie.AkkuAlarm","signals-oid-0":"0_userdata.0.Energieverbrauch.Batterie.AkkuAlarm","class":"","headerBackgroundColor":"linear-gradient(to bottom, #202020, grey, #202020)","textFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.button.default.text","textFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.button.default.text","mdwButtonPrimaryColor":"#mdwTheme:vis-materialdesign.0.colors.button.default.primary","mdwButtonSecondaryColor":"#mdwTheme:vis-materialdesign.0.colors.button.default.secondary","fullscreenCloseIcon":"{mode:vis-materialdesign.0.colors.darkTheme;light:vis-materialdesign.0.colors.light.dialog.close_button_icon;dark:vis-materialdesign.0.colors.dark.dialog.close_button_icon; mode === \"true\" ? dark : light}","imageColor":"#mdwTheme:vis-materialdesign.0.colors.button.icon.icon_off","footerBackgroundColor":"linear-gradient(to bottom, #202020, grey, #202020)","overlayColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.overlay","fullscreenCloseIconColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.close_button_icon","fullscreenCloseIconPressColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.close_button_fullscreen_press","debug":true},"style":{"left":"calc(66% - 35px)","top":"45px","height":"50px","width":"50px","z-index":"1","background":"#2e2e2e","box-shadow":"2px 2px 3px rgba(20, 20, 20, 50)","border-radius":"5px","border-color":"{wert:0_userdata.0.Energieverbrauch.Batterie.AkkuAlarm; wert==0 ? \"green\" :: \"red\"}","border-style":"solid","border-width":"2px"},"widgetSet":"materialdesign"}]
              Stephan Schleich 1 Reply Last reply Reply Quote 0
              • Stephan Schleich
                Stephan Schleich @Oli last edited by
                @Scrounger Welcher Punkte wäre das in deinem Adapter wenn ich die Beschreibung in weiß ändern möchte? Ist nun ja direkt in deinem Adapter zu setzten wenn ich mich nicht irre
                • Scrounger
                  Scrounger Developer @Stephan Schleich last edited by
                  @stephan-schleich
                  Du kannst es nach wie vor per vis Editor konfigurieren.
                  Oder über die Adapter Einstellungen. Hier gibt's ein Filter Feld, dort den Namen des Widget eingeben oder auswählen und dann werden dir alle Einstellung für dieses Widget angezeigt. Die Beschreibung ist gleich wie im vis Editor.
                    darkiop Most Active last edited by
                    @Scrounger Hast du für vis-materialdesign.0.colors.darkTheme eine globale CSS ID/Class vorgsehen damit man auch über die CSS drauf reagieren kann? Suche mir grad den Wolf 😄
                    • Scrounger
                      Scrounger Developer @darkiop last edited by
                      @darkiop
                      Ne das ist ein Datenpunkt, da geht nix per CSS. Was hast denn vor?
                        darkiop Most Active @Scrounger last edited by darkiop
                        @scrounger
                        Ich nutze eine Mischung aus Uhula's Framework und deinen Widgets.
                        Grundsätzlich ist meine aktuelle Fragestellung:
                        Wie setze ich in Abhängigkeit von dem Theme-DP die Hintergrund-Grafik. Mit einer <body id="dark-mode-on"> / <body id="dark-mode-off"> wäre das simpel.
                        Oder übersehe ich gerade etwas?
                        • Scrounger
                          Scrounger Developer @darkiop last edited by Scrounger
                          @darkiop
                          puhhhh...
                          Wahrscheinlich müsstest du direkt im VIS Editor ein Skript schreiben, dass den Datenpunkt liest und in Abhängigkeit dann jedem Widget eine Klasse zu weist. Für diese beiden Klassen kannst dann css regeln erstellen.
                          Wenn du nur den Hintergrund anpassen willst, würd ich nen html Widget in den Hintergrund legen und dann per binding die hintergrundfarbe in Abhängigkeit des Datenpunktes setzen.
                          Kannst du nicht den Uhula Widgets die Layout datenpunkte des Theme Editors per binding zuweisen?
                          B D 2 Replies Last reply Reply Quote 0
                            BobBruni @Scrounger last edited by
                            Dank der "generate HTML Element" lassen sich super Widgets basteln 👍
                            Gibt es auch eine Möglichkeit aus dem generierten HTML-Code das ursprüngliche Widget wieder herzustellen?
                            • Scrounger
                              Scrounger Developer @BobBruni last edited by
                              @bobbruni sagte in Test Adapter Material Design Widgets v0.5.x:
                              Zeig doch Mal was du so gebastelt hast, würde mich sehr interessieren.
                              Ja manuelle Eingabe der Daten im Editor 😉
                              Warum sollte man das brauchen?
                              • ice987
                                ice987 last edited by ice987
                                @Scrounger
                                Ich möchte z. B. den Batterieladestand und die WiFi Qualität grafisch ausgeben. Gibt‘s ein Widget, bei welchem je nach Wert eine andere/s Grafik/Symbol angezeigt werden kann?
                                Für die Batterie gienge evtl. Progress für WiFi passt jedoch das Symbol nicht so richtig…
                                • Scrounger
                                  Scrounger Developer @ice987 last edited by
                                  @ice987
                                  Ja geht mit dem value Widget. Da kannst du einfach im das Feld fürs Icon eine Bedingung schreiben. Wie das mit den Bedingungen geht ist in der Doku zum value Widget beschrieben.
                                  ice987 1 Reply Last reply Reply Quote 0
                                  • ice987
                                    ice987 @Scrounger last edited by ice987
                                    @scrounger
                                    das value Widget habe ich mir auch angekuckt und noch gedacht, irgendwie könnte das das richtige Widget sein 😎
                                    auf jeden Fall funktioniert das wie gewünscht bis auf einen kleinen Schönheitsfehler: in der Runtime aktualisiert sich die Grafik wie gewünscht, im Editor aktualisiert es die Grafik nicht auf Anhieb. Beim Anklicken dauert es immer eine Weile bis das Widget aktiv wird (Bedienung/Eingabe insgesamt sehr träge):
                                    Hier einen Export:
                                    [{"tpl":"tplVis-materialdesign-value","data":{"oid":"0_userdata.0.test.wert27","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","targetType":"auto","image":"#value == 0 ? \"home\" : (#value > 0 and #value <= 10 ? \"abacus\" : \"account\")","imageColor":"","iconPosition":"left","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"g_changeEffect":false,"effectFontColor":"#mdwTheme:vis-materialdesign.0.colors.value.effect","effectFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.value.effect","effectDuration":"750","overrideText":"","g_layout":false,"textAlign":"start","valueLabelWidth":"4","valuesFontColor":"#mdwTheme:vis-materialdesign.0.colors.value.text","valuesFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.value.text","valuesFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.value.text","prepandTextColor":"#mdwTheme:vis-materialdesign.0.colors.value.prepand","prepandTextFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.value.prepand","prepandTextFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.value.prepand","appendTextColor":"#mdwTheme:vis-materialdesign.0.colors.value.append","appendTextFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.value.append","appendTextFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.value.append","g_formatNumber":false,"g_formatBoolean":false,"iconHeight":"25"},"style":{"left":"173px","top":"665px"},"widgetSet":"materialdesign"}]
                                    Versions:
                                    Adapter version: material design widgets v0.5.9
                                    JS-Controller version: v3.2.16
                                    Node version: v12.22.1
                                    VIS Adapter version: v1.3.9
                                    • Scrounger
                                      @ice987
                                      Das ist aber normal im Editor. Die States werden da nur beim laden aktualisiert und wenn man an den Einstellungen des Widgets etwas ändert.
                                      ice987 D3ltoroxp O 3 Replies Last reply Reply Quote 0
                                      • ice987
                                        @scrounger
                                        ah ok, dann ist alles i.O. Ich dachte nur, da das Widget Button Toggle vertikal auch direkt im Editor aktualisiert wird.
                                        das value Widget kann auch so genutzt werden, was die ganze Geschichte sehr interessant macht (zwei DP's als Binding, ohne Object ID) 😳
                                        [{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"<div class='vis-widget materialdesign-widget materialdesign-value materialdesign-value-html-element'\n\tstyle='width: 100%; height: 100%; position: relative; display: flex; align-items: center;'\n\tmdw-debug='false'\n\tmdw-oid='nothing_selected'\n\tmdw-targetType='auto'\n\tmdw-overrideText=' '\n\tmdw-textAlign='start'\n\tmdw-valueLabelWidth='4'\n\tmdw-valuesFontColor='#mdwTheme:vis-materialdesign.0.colors.value.text'\n\tmdw-valuesFontFamily='#mdwTheme:vis-materialdesign.0.fonts.value.text'\n\tmdw-valuesFontSize='#mdwTheme:vis-materialdesign.0.fontSizes.value.text'\n\tmdw-prepandTextColor='#mdwTheme:vis-materialdesign.0.colors.value.prepand'\n\tmdw-prepandTextFontFamily='#mdwTheme:vis-materialdesign.0.fonts.value.prepand'\n\tmdw-prepandTextFontSize='#mdwTheme:vis-materialdesign.0.fontSizes.value.prepand'\n\tmdw-appendTextColor='#mdwTheme:vis-materialdesign.0.colors.value.append'\n\tmdw-appendTextFontFamily='#mdwTheme:vis-materialdesign.0.fonts.value.append'\n\tmdw-appendTextFontSize='#mdwTheme:vis-materialdesign.0.fontSizes.value.append'\n\tmdw-image='{wert1:0_userdata.0.test.test26;wert2:0_userdata.0.test.wert27;wert1 === \\\"true\\\" ? \\\"/vis.0/main/img/icon_nowifi.png\\\" : (wert2 >= -50 ? \\\"/vis.0/main/img/icon_wifi_excellent.png\\\" : (wert2 < -50 && wert2 >= -60 ? \\\"/vis.0/main/img/icon_wifi_good.png\\\" : (wert2 < -60 && wert2 >= -70 ? \\\"/vis.0/main/img/icon_wifi_fair.png\\\" : \\\"/vis.0/main/img/icon_wifi_weak.png\\\")))}'\n\tmdw-iconPosition='left'\n\tmdw-iconHeight='25'\n\tmdw-effectFontColor='#mdwTheme:vis-materialdesign.0.colors.value.effect'\n\tmdw-effectFontSize='#mdwTheme:vis-materialdesign.0.fontSizes.value.effect'\n\tmdw-effectDuration='750'\n></div>"},"style":{"left":"659px","top":"116px"},"widgetSet":"basic"}]
                                          @scrounger sagte in Test Adapter Material Design Widgets v0.5.x:
                                          @darkiop
                                          puhhhh...
                                          Hatte schon befürchtet das man das evtl. per Skript abfangen muss.
                                          Ja, die Idee hatte ich auch, werd ich demnächst noch Testen.
                                          Ich nutze von Uhulas Framework eigentlich nur den Rahmen - also alles was die Seite Responsiv macht - die Inhalte werden größtenteils mit deinen Widgets dargestellt. Und Uhulas Konzept mit mehreren Page Views habe ich auf eine Page View mit einem View in Widget 8 und deiner TopAppBar angepasst.
                                          Eine Idee war noch, das ganze über ein Bindung der BG-Optionen der Seite selbst zu machen (kein Widget selektiert):
                                          Leider sind hier Bindings ohne Funktion.
                                            darkiop Most Active @darkiop last edited by darkiop
                                            @Scrounger
                                            @darkiop sagte in Test Adapter Material Design Widgets v0.5.x:
                                            Ich hab mir jetzt so beholfen wie von dir Vorgeschlagean. Auf meiner page-View liegt ein HTML mit 100% x 100% und das bekommt über ein Binding eine class verpasst:
                                            {x:vis-materialdesign.0.colors.darkTheme;x=='true' ? 'bg-dark-theme' : 'bg-light-theme'}
                                            1.0k
                                            adapter material material design widgets vis visualisation widget
                                            22
                                            110
                                            17759
