    4. DWD Warnung als Telegramm
      PrinzEisenherz1 last edited by
      [EDIT] Hab das Script nochmal etwas überarbeitet - 16.01.17 11:50
      So hier mal kurz ne idee bezüglich der unterschiedlichen Aufhebungen der Wetterwarnungen
      /* Script zum Übertragen der DWD-Wetterwarnungen an Telegram */
          var idSeverity = "dwd.0.warning.description";
          var idSeverity1 = "dwd.0.warning1.description";
          var idSeverity2 = "dwd.0.warning2.description";
      /*  States und Variablen anlegen zur Sicherung der DWD-headlines  */
          createState("javascript.0.DWD.headline1");
          createState("javascript.0.DWD.headline2");
          createState("javascript.0.DWD.headline3");
          var idBackHeadline1 = "javascript.0.DWD.headline1";
          var idBackHeadline2 = "javascript.0.DWD.headline2";
          var idBackHeadline3 = "javascript.0.DWD.headline3";
      function check(){
      var Severity = getState(idSeverity).val;
      if (Severity !== "") {
          var Begin = getState("dwd.0.warning.begin").val;
          var End = getState("dwd.0.warning.end").val;
          var text = getState("dwd.0.warning.text").val;
          var Headline = getState("dwd.0.warning.headline").val;
          var Description = getState("dwd.0.warning.description").val;
          var DWD_telegramm = Headline + "\ngültig vom " + Begin + " bis " + End + "\n" + Description ;
          setTimeout(function() {
              sendTo ("telegram.0", DWD_telegramm);
          }, 1 * 1000);
      /* headline für Warning sichern */
          setState(idBackHeadline1,Headline);
      function check1(){
      var Severity1 = getState(idSeverity1).val;
      if (Severity1 !== "") {
          var Begin = getState("dwd.0.warning1.begin").val;
          var End = getState("dwd.0.warning1.end").val;
          var text = getState("dwd.0.warning1.text").val;
          var Headline = getState("dwd.0.warning1.headline").val;
          var Description = getState("dwd.0.warning1.description").val;
          }, 1 * 1000);
      /* headline für Warning1 sichern */
          setState(idBackHeadline2,Headline);
      function check2(){
      var Severity2 = getState(idSeverity2).val;
      if (Severity2 !== "") {
          var Begin = getState("dwd.0.warning2.begin").val;
          var End = getState("dwd.0.warning2.end").val;
          var text = getState("dwd.0.warning2.text").val;
          var Headline = getState("dwd.0.warning2.headline").val;
          var Description = getState("dwd.0.warning2.description").val;
          }, 1 * 1000);
      /* headline für Warning2 sichern */
          setState(idBackHeadline3,Headline);
      on(idSeverity, function (obj){
          if (obj.newState.val !== obj.oldState.val) {
              if (obj.newState.val !== "") {
                  check();
              }else {
                  sendTo ("telegram.0", "Alle Wetterwarnungen des DWD wurden aufgehoben") ;
      on(idSeverity1, function (obj){
                  check1();
              } else
                  var Headlineclear1 = getState(idBackHeadline2).val;
                  sendTo ("telegram.0", "Die Wetterwarnung " +"'"+ Headlineclear1 + "'" + " des DWD wurde aufgehoben") ;
      on(idSeverity2, function (obj){
                  check2();
              } else
                  var Headlineclear2 = getState(idBackHeadline3).val;
                  sendTo ("telegram.0", "Die Wetterwarnung " +"'"+ Headlineclear2 + "'" + " des DWD wurde aufgehoben") ;
      /* Auslösen bei Scriptstart - Wenn nicht benötigt einfach löschen oder auskommentieren */
      check();
      check1();
      check2();
      Jetzt wird bei mehr als einer Warnung immer zusätzlich beim aufheben der Warnung immer die headline der Warnung mit angegeben.
      z.B.
      Wetterwarnung 'Amtliche WARNUNG vor GLÄTTE' des Deutschen Wetterdienstes wurde aufgehoben
      Johnny
      [EDIT] Aktuelle Version mit Sprachausgabe hier http://forum.iobroker.net/viewtopic.php … =40#p52017
      • N
        Nordlicht last edited by
        @PrinzEisenherz1: `
        Hi Johnny,
        es kann sein, dass ich auch einem Irrtum erliege, aber wäre es nicht auch sinnvoll nicht "nur" auf die Änderung der <u>severity</u> zu reagieren sondern auf die <u>description</u>.
        Warum?
        Mir ist jetzt mehrfach aufgefallen, dass sich z.B. dwd.0.warning.description ändert (zeitliche Verlängerung der Meldung o.ä.) und die <u>severity</u> trotzdem gleich bleibt (z.B. 1). Auf diese Änderung wird nicht reagiert. Ich muss hier aber auch dazu sagen, dass ich die Meldung nicht via Telegramm versende sondern über den Home24 Mediaplayer sprechen lasse. Hinsichtlich der Funktion als solches wird dies jedoch keinen Einfluss haben.
        Ansonsten…. ein ganz klasse Skript das ich sehr gerne im Einsatz habe!
        Thomas
          Hi Thomas, das hätte ich zuerst aber dann war das Problem das severity sich geändert hat aber description noch nicht befüllt war und ich Nachrichten ohne Beschreibung erhalten habe. Deswegen trigger ich die Beschreibung. Mal schauen ob ich es anders umbiegen kann. Das Script reagiert aber auf Änderung der Beschreibung.
          Trotzdem freut es mich das es dir gefällt und auf Verbesserungsvorschläge oder wünsche hab ich immer n Ohr offen.
          Gruß Johnny
          • N
            @PrinzEisenherz1: `
            Hi Johnny,
            alles klar, weiß ich Bescheid. Ich bin da eher das Greenhorn und der Anwender, (leider) weniger der Programmierer 😉 .
            Ich habe jetzt mal Dein Skript von hier http://forum.iobroker.net/viewtopic.php?p=47187#p47187 übernommen, auf 4 Warnungen ausgebaut und "umgestrickt" für die Sprachausgabe für den Mediaplayer.
            Mal sehen ob das richtig tut…. :oops:
            Thomas
            • N
              @PrinzEisenherz1: `
              Na so ganz hat das noch nicht geklappt.
              Es werden zwar die Wettermeldungen angesagt, aber es passiert, dass 2 Meldungen "übereinanderlaufen" und somit 1 davon nicht angesagt wird. Kann es sein, dass ich den Timeout der dort mit 1000 gesetzt ist eventuell (deutlich) erhöhen muss, damit jede Ansage genug Zeit hat?
              Ich frage das jetzt als Unwissender was die Programmiererei anbelangt, ich erwähnte es schon.
              Kannst ja mal einen Blick auf das erweiterte Skript werfen ob das so passt…. und eben die Sache mit dem Timeout.
              var request = require ('request');
              ! /* Script zum Übertragen der DWD-Wetterwarnungen an Home24 Mediaplayer */
              var idSeverity0 = "dwd.0.warning.description";
              var idSeverity3 = "dwd.0.warning3.description";
              var idSeverity4 = "dwd.0.warning4.description";
              ! /* States und Variablen anlegen zur Sicherung der DWD-headlines */
              createState("javascript.1.DWD.headline0");
              createState("javascript.1.DWD.headline1");
              createState("javascript.1.DWD.headline2");
              createState("javascript.1.DWD.headline3");
              createState("javascript.1.DWD.headline4");
              var idBackHeadline0 = "javascript.1.DWD.headline0";
              var idBackHeadline1 = "javascript.1.DWD.headline1";
              var idBackHeadline2 = "javascript.1.DWD.headline2";
              var idBackHeadline3 = "javascript.1.DWD.headline3";
              var idBackHeadline4 = "javascript.1.DWD.headline4";
              function check0(){
              var Severity0 = getState(idSeverity0).val;
              if (Severity0 !== "") {
              var Begin0 = getState("dwd.0.warning.begin").val;
              var End0 = getState("dwd.0.warning.end").val;
              var text0 = getState("dwd.0.warning.text").val;
              var Headline0 = getState("dwd.0.warning.headline").val;
              var Description0 = getState("dwd.0.warning.description").val;
              var DWD_meldung_0 = Headline0 + ". gültig vom, " + Begin0 + " bis, " + End0 + ". " + Description0 ;
              var Url = "http://192.168.178.58:50000/track=4fachgong.mp3|tts=" + DWD_meldung_0 ;
              request(Url);
              }, 1 * 1000);
              setState(idBackHeadline0,Headline0);
              ! function check1(){
              var Begin1 = getState("dwd.0.warning1.begin").val;
              var End1 = getState("dwd.0.warning1.end").val;
              var text1 = getState("dwd.0.warning1.text").val;
              var Headline1 = getState("dwd.0.warning1.headline").val;
              var Description1 = getState("dwd.0.warning1.description").val;
              var DWD_meldung_1 = Headline1 + ". gültig vom, " + Begin1 + " bis, " + End1 + ". " + Description1 ;
              ! var Url = "http://192.168.178.58:50000/track=4fachgong.mp3|tts=" + DWD_meldung_1 ;
              request(Url);
              }, 1 * 1000);
              setState(idBackHeadline1,Headline1);
              ! function check2(){
              var Begin2 = getState("dwd.0.warning2.begin").val;
              var End2 = getState("dwd.0.warning2.end").val;
              var text2 = getState("dwd.0.warning2.text").val;
              var Headline2 = getState("dwd.0.warning2.headline").val;
              var Description2 = getState("dwd.0.warning2.description").val;
              var DWD_meldung_2 = Headline2 + ". gültig vom, " + Begin2 + " bis, " + End2 + ". " + Description2 ;
              ! var Url = "http://192.168.178.58:50000/track=4fachgong.mp3|tts=" + DWD_meldung_2 ;
              request(Url);
              }, 1 * 1000);
              setState(idBackHeadline2,Headline2);
              ! function check3(){
              var Severity3 = getState(idSeverity3).val;
              if (Severity3 !== "") {
              var Begin3 = getState("dwd.0.warning3.begin").val;
              var End3 = getState("dwd.0.warning3.end").val;
              var text3 = getState("dwd.0.warning3.text").val;
              var Headline3 = getState("dwd.0.warning3.headline").val;
              var Description3 = getState("dwd.0.warning3.description").val;
              var DWD_meldung_3 = Headline3 + ". gültig vom, " + Begin3 + " bis, " + End3 + ". " + Description3 ;
              ! var Url = "http://192.168.178.58:50000/track=4fachgong.mp3|tts=" + DWD_meldung_3 ;
              request(Url);
              }, 1 * 1000);
              setState(idBackHeadline3,Headline3);
              ! function check4(){
              var Severity4 = getState(idSeverity4).val;
              if (Severity4 !== "") {
              var Begin4 = getState("dwd.0.warning4.begin").val;
              var End4 = getState("dwd.0.warning4.end").val;
              var text4 = getState("dwd.0.warning4.text").val;
              var Headline4 = getState("dwd.0.warning4.headline").val;
              var Description4 = getState("dwd.0.warning4.description").val;
              var DWD_meldung_4 = Headline4 + ". gültig vom, " + Begin4 + " bis, " + End4 + ". " + Description4 ;
              request(Url);
              }, 1 * 1000);
              setState(idBackHeadline4,Headline4);
              ! on(idSeverity0, function (obj){
              check0();
              } else {
              ! var Url = "http://192.168.178.58:50000/track=4fachgong.mp3|tts=Alle Wetterwarnungen des DWD wurden aufgehoben." ;
              request(Url);
              ! on(idSeverity1, function (obj){
              check1();
              } else
              var Headlineclear0 = getState(idBackHeadline1).val;
              var Url = "http://192.168.178.58:50000/track=4fachgong.mp3|tts=Die Wetterwarnung " + ":" + Headlineclear0 + " des DWD wurde aufgehoben." ;
              request(Url);
              ! on(idSeverity2, function (obj){
              check2();
              } else
              var Url = "http://192.168.178.58:50000/track=4fachgong.mp3|tts=Die Wetterwarnung " + ":" + Headlineclear1 + " des DWD wurde aufgehoben." ;
              request(Url);
              ! on(idSeverity3, function (obj){
              check3();
              } else
              var Url = "http://192.168.178.58:50000/track=4fachgong.mp3|tts=Die Wetterwarnung " + ":" + Headlineclear2 + " des DWD wurde aufgehoben." ;
              request(Url);
              ! on(idSeverity4, function (obj){
              check4();
              } else
              var Headlineclear3 = getState(idBackHeadline4).val;
              var Url = "http://192.168.178.58:50000/track=4fachgong.mp3|tts=Die Wetterwarnung " + ":" + Headlineclear3 + " des DWD wurde aufgehoben." ;
              request(Url);
              ! /* Auslösen bei Scriptstart - Wenn nicht benötigt einfach löschen oder auskommentieren
              check0();
              check1();
              check2();
              check3();
              check4();*/
              Danke und Gruß
              Thomas
                Hi Thomas, ich schau mir später das mal an.
                Hab bloß im Moment was zu tun
                Gruß Johnny
                  Gelöscht da fehlerhaftes Script.
                  • N
                    Ich habe nun dieses Skript am laufen und es funktioniert einwandfrei
                    function check0(){
                    request(Url);
                    }, 1 * 1000);
                    request(Url);
                    }, 1 * 1000);
                    request(Url);
                    }, 1 * 1000);
                    request(Url);
                    }, 1 * 1000);
                    request(Url);
                    }, 1 * 1000);
                    check0();
                    } else {
                    request(Url);
                    check1();
                    } else
                    request(Url);
                    check2();
                    } else
                    request(Url);
                    check3();
                    } else
                    request(Url);
                    check4();
                    } else
                    request(Url);
                    check0();
                    check1();
                    check2();
                    check3();
                    check4();*/
                    Das ist schon mal perfekt, solange es klappt werde ich hieran nichts mehr verändern…. sonst gehen ggf. Probleme wieder los 8-)
                    Thomas
                    • wendy2702
                      wendy2702 last edited by
                      @Nordlicht:
                      Thomas `
                      Das macht aber nur die Ansage und keine Nachricht per Telegram, oder?
                      • N
                        @wendy2702:
                        Das macht aber nur die Ansage und keine Nachricht per Telegram, oder? `
                        Ja richtig…. mit Telegram bin ich noch nicht soweit um es einzusetzen.
                        Aber da dürfte es ja nur eines "Umbaus" speziell dieser Funktion bedürfen....
                        • wendy2702
                          @Nordlicht:
                          @wendy2702:
                          Aber da dürfte es ja nur eines "Umbaus" speziell dieser Funktion bedürfen.... `
                          OK.
                          Danke.
                          Werde mal versuchen das an meine Bedürfnisse und Installation anzupassen.
                            Hi zusammen, ich stelle nachher eins rein das home24, Telegram und pushover macht
                              Gelöscht, da Script fehlerhaft
                                Achja, Nordlicht warte mit m anpassen auf 4 warnings.
                                Ich baue es gerade für Dich auf 4 um
                                  Gelöscht, da Script fehlerhaft.
                                  [EDIT] Aktuelle Version (die funktioniert) mit Sprachausgabe hier http://forum.iobroker.net/viewtopic.php … =40#p52017
                                  • N
                                    @PrinzEisenherz1:
                                    Ich baue es gerade für Dich auf 4 um `
                                    Danke perfekt…. nur keine unnötige Hektik.
                                    Bislang läuft das ja alles gut.
                                    • grisuv
                                      grisuv last edited by
                                      Leider funktioniert der script mit 4 Warnungen leider nicht. Javascript wird laut log neu gestartet.
                                      mit drei läuft alles perfekt.
                                      In der Zeile "if(idSprachausgabe === true){" kommt ein ausrufezeichen "zu viele fehler. 82% scanned"
                                      @PrinzEisenherz1:
                                      So, und hier ne Variante für 4 Warnungen.
                                      Hab die noch etwas Nutzerfreundlicher gestaltet bzgl Einstellungen
                                      ! /* Script zum Übertragen der DWD-Wetterwarnungen an Telegram */ /* Stand: 11012017 PrinzEisenherz1 */ var request = require('request'); /* Abfragen eingestellten Nachrichten-Dienst */ /* aus=0 ; alle=1 ; Pushover=2 ; Telegram=3 */ var pushdienst = 3; // Auswahl Nachrichtendienst ! /* Pfadangaben */ var instanz = 'javascript.0.'; // Instanz des javascript-Adapters var pfad = 'DWD'; // Pfad in im Javascript-Adapter ! /* Konfiguration Sprachausgabe */ var idSprachausgabe = true; // Wenn zusätzlich eine Sprachausgabe erfolgen soll dann auf true, ohne Sprachausgabe false var idMediaplayer = "192.168.000.000:50000"; // Eingabe IP-Adresse incl. Port für Home24-Mediaplayer ! /* Datenpunkte DWD-Adapter */ var idDescription0 = "dwd.0.warning.description"; var idDescription1 = "dwd.0.warning1.description"; var idDescription2 = "dwd.0.warning2.description"; var idDescription3 = "dwd.0.warning3.description"; var idHeadline0 = "dwd.0.warning.headline"; var idHeadline1 = "dwd.0.warning1.headline"; var idHeadline2 = "dwd.0.warning2.headline"; var idHeadline3 = "dwd.0.warning3.headline"; var idBegin0 = "dwd.0.warning.begin"; var idBegin1 = "dwd.0.warning1.begin"; var idBegin2 = "dwd.0.warning2.begin"; var idBegin3 = "dwd.0.warning3.begin"; var idEnd0 = "dwd.0.warning.end"; var idEnd1 = "dwd.0.warning1.end"; var idEnd2 = "dwd.0.warning2.end"; var idEnd3 = "dwd.0.warning3.end"; ! /* ######################### createStates ###################################### /* Sicherung der DWD-Warnmeldungen */ createState(instanz + pfad + ".BackupMessage0"); createState(instanz + pfad + ".BackupMessage1"); createState(instanz + pfad + ".BackupMessage2"); createState(instanz + pfad + ".BackupMessage4"); /* Sicherung der DWD-headlines und Gültig-Bis */ createState(instanz + pfad + ".headline0"); createState(instanz + pfad + ".headline1"); createState(instanz + pfad + ".headline2"); createState(instanz + pfad + ".headline3"); createState(instanz + pfad + ".gueltig0"); createState(instanz + pfad + ".gueltig1"); createState(instanz + pfad + ".gueltig2"); ! createState(instanz + pfad + ".gueltig3"); ! /* Sicherung der DWD-Warnmeldungen */ var idBackupMessage0 = instanz + pfad + ".BackupMessage0"; var idBackupMessage1 = instanz + pfad + ".BackupMessage1"; var idBackupMessage2 = instanz + pfad + ".BackupMessage2"; ! var idBackupMessage2 = instanz + pfad + ".BackupMessage3"; ! /* Sicherung der DWD-headlines und Gültig-Bis */ var idBackHeadline0 = instanz + pfad + ".headline0"; var idBackHeadline1 = instanz + pfad + ".headline1"; var idBackHeadline2 = instanz + pfad + ".headline2"; var idBackHeadline3 = instanz + pfad + ".headline3"; var idBackGueltig0 = instanz + pfad + ".gueltig0"; var idBackGueltig1 = instanz + pfad + ".gueltig1"; var idBackGueltig2 = instanz + pfad + ".gueltig2"; ! var idBackGueltig3 = instanz + pfad + ".gueltig3"; ! /* Meldungen Text und Sprache */ var Meldung = ''; var Meldung0 = ''; var Meldung1 = ''; var Meldung2 = ''; ! var Meldung3 = ''; var MeldungSprache = ''; var Meldung0Sprache = ''; var Meldung1Sprache = ''; var Meldung2Sprache = ''; ! var Meldung3Sprache = ''; ! /* Konfiguration Timer */ var timer = null; ! function nachricht(){ /* Einlesen Backup */ var BackupMessage0 = getState(idBackupMessage0).val; var BackupMessage1 = getState(idBackupMessage1).val; var BackupMessage2 = getState(idBackupMessage2).val; /* Einlesen Warnung0 */ var Description0 = getState(idDescription0).val; var Headline0 = getState(idHeadline0).val; var Begin0 = getState(idBegin0).val; var End0 = getState(idEnd0).val; /* Einlesen Warnung1 */ var Description1 = getState(idDescription1).val; var Headline1 = getState(idHeadline1).val; var Begin1 = getState(idBegin1).val; var End1 = getState(idEnd1).val; /* Einlesen Warnung2 */ var Description2 = getState(idDescription2).val; var Headline2 = getState(idHeadline2).val; var Begin2 = getState(idBegin2).val; var End2 = getState(idEnd2).val; /* Variable für Vergleich */ var Pruefung0 = Description0 + End0; var Pruefung1 = Description1 + End1; var Pruefung2 = Description2 + End2; ! /* Bereich Auswerten neue Wetterwarnung für Warnung3 */ if((Description3 !== "") && (Pruefung3 !== BackupMessage3) && (Pruefung3 !== BackupMessage2) && (Pruefung3 !== BackupMessage1) && (Pruefung3 !== BackupMessage0)) { Meldung3 = Headline3 + "\ngültig vom " + Begin3 + " Uhr bis " + End3 + " Uhr\n" + Description3; var replaceDescription3 = entferneDatenpunkt(Description3); Meldung3Sprache = Headline3 + " gültig vom " + Begin3 + " Uhr, bis " + End3 + " Uhr. " + replaceDescription3; if ((pushdienst === 3) || (pushdienst === 1) ) { sendTo ("telegram.0", Meldung3); } if ((pushdienst === 2) || (pushdienst === 1) ) { sendTo("pushover.0", Meldung3); } setState(idBackupMessage3,Pruefung3); setState(idBackHeadline3,Headline3); setState(idBackGueltig3,End3); } else if((Description3 === "") && (Description2 !== "") && (Description1 !== "") && (Description0 !== "") && (BackupMessage3 !== Pruefung2) && (BackupMessage3 !== Pruefung1) && (BackupMessage3 !== Pruefung0)) { var Headlineclear3 = getState(idBackHeadline3).val; var Gueltigclear3 = getState(idBackGueltig3).val; if ((pushdienst === 3) || (pushdienst === 1) ) { setTimeout(function() { sendTo ("telegram.0", "Die Wetterwarnung " +"'"+ Headlineclear3 + " gültig bis " + Gueltigclear3 + "'" + " des DWD wurde aufgehoben"); }, 1 * 1000); } if ((pushdienst === 2) || (pushdienst === 1) ) { setTimeout(function() { sendTo("pushover.0", "Die Wetterwarnung " +"'"+ Headlineclear3 + " gültig bis " + Gueltigclear3 + "'" + " des DWD wurde aufgehoben"); }, 1 * 1000); } setState(idBackupMessage3,''); } /* Bereich Auswerten neue Wetterwarnung für Warnung2 */ if((Description2 !== "") && (Pruefung2 !== BackupMessage3) && (Pruefung2 !== BackupMessage2) && (Pruefung2 !== BackupMessage1) && (Pruefung2 !== BackupMessage0)) { Meldung2 = Headline2 + "\ngültig vom " + Begin2 + " Uhr bis " + End2 + " Uhr\n" + Description2; var replaceDescription2 = entferneDatenpunkt(Description2); Meldung2Sprache = Headline2 + " gültig vom " + Begin2 + " Uhr, bis " + End2 + " Uhr. " + replaceDescription2; if ((pushdienst === 3) || (pushdienst === 1) ) { setTimeout(function() { sendTo ("telegram.0", Meldung2); }, 1 * 1000); } if ((pushdienst === 2) || (pushdienst === 1) ) { setTimeout(function() { sendTo("pushover.0", Meldung2); }, 1 * 1000); } setState(idBackupMessage2,Pruefung2); setState(idBackHeadline2,Headline2); setState(idBackGueltig2,End2); } else if((Description3 === "") && (Description2 === "") && (Description1 !== "") && (Description0 !== "") && (BackupMessage2 !== Pruefung3) && (BackupMessage2 !== Pruefung1) && (BackupMessage2 !== Pruefung0)) { var Headlineclear2 = getState(idBackHeadline2).val; var Gueltigclear2 = getState(idBackGueltig2).val; if ((pushdienst === 3) || (pushdienst === 1) ) { setTimeout(function() { sendTo ("telegram.0", "Die Wetterwarnung " +"'"+ Headlineclear2 + " gültig bis " + Gueltigclear2 + "'" + " des DWD wurde aufgehoben"); }, 1 * 1000); } if ((pushdienst === 2) || (pushdienst === 1) ) { setTimeout(function() { sendTo("pushover.0", "Die Wetterwarnung " +"'"+ Headlineclear2 + " gültig bis " + Gueltigclear2 + "'" + " des DWD wurde aufgehoben"); }, 1 * 1000); } setState(idBackupMessage2,''); } /* Bereich Auswerten neue Wetterwarnung für Warnung1 */ if((Description1 !== "") && (Pruefung1 !== BackupMessage3) && (Pruefung1 !== BackupMessage2) && (Pruefung1 !== BackupMessage1) && (Pruefung1 !== BackupMessage0)) { Meldung1 = Headline1 + "\ngültig vom " + Begin1 + " Uhr bis " + End1 + " Uhr\n" + Description1; var replaceDescription1 = entferneDatenpunkt(Description1); Meldung1Sprache = Headline1 + " gültig vom " + Begin1 + " Uhr, bis " + End1 + " Uhr. " + replaceDescription1; if ((pushdienst === 3) || (pushdienst === 1) ) { setTimeout(function() { sendTo ("telegram.0", Meldung1); }, 5 * 1000); } if ((pushdienst === 2) || (pushdienst === 1) ) { setTimeout(function() { sendTo("pushover.0", Meldung1); }, 5 * 1000); } setState(idBackupMessage1,Pruefung1); setState(idBackHeadline1,Headline1); setState(idBackGueltig1,End1); } else if((Description3 === "") && (Description2 === "") && (Description1 === "") && (Description0 !== "") && (BackupMessage1 !== Pruefung3) && (BackupMessage1 !== Pruefung2) && (BackupMessage1 !== Pruefung0)) { var Headlineclear1 = getState(idBackHeadline1).val; var Gueltigclear1 = getState(idBackGueltig1).val; if ((pushdienst === 3) || (pushdienst === 1) ) { setTimeout(function() { sendTo ("telegram.0", "Die Wetterwarnung " +"'"+ Headlineclear1 + " gültig bis " + Gueltigclear1 + "'" + " des DWD wurde aufgehoben"); }, 5 * 1000); } if ((pushdienst === 2) || (pushdienst === 1) ) { setTimeout(function() { sendTo("pushover.0", "Die Wetterwarnung " +"'"+ Headlineclear1 + " gültig bis " + Gueltigclear1 + "'" + " des DWD wurde aufgehoben"); }, 5 * 1000); } setState(idBackupMessage1,''); } /* Bereich Auswerten neue Wetterwarnung für Warnung0 */ if((Description0 !== "") && (Pruefung0 !== BackupMessage3) && (Pruefung0 !== BackupMessage2) && (Pruefung0 !== BackupMessage1) && (Pruefung0 !== BackupMessage0)) { Meldung0 = Headline0 + "\ngültig vom " + Begin0 + " Uhr bis " + End0 + " Uhr\n" + Description0; var replaceDescription0 = entferneDatenpunkt(Description0); Meldung0Sprache = Headline0 + " gültig vom " + Begin0 + " Uhr, bis " + End0 + " Uhr. " + replaceDescription0; if ((pushdienst === 3) || (pushdienst === 1) ) { setTimeout(function() { sendTo ("telegram.0", Meldung0); }, 9 * 1000); } if ((pushdienst === 2) || (pushdienst === 1) ) { setTimeout(function() { sendTo("pushover.0", Meldung0); }, 9 * 1000); } setState(idBackupMessage0,Pruefung0); setState(idBackHeadline0,Headline0); setState(idBackGueltig0,End0); } else if((Description0 === "") && (Description1 === "") && (Description2 === "") && (Description3 === "")) { setState(idBackupMessage0,''); Meldung0Sprache = 'Alle Warnmeldungen des DWD wurden aufgehoben'; if ((pushdienst === 3) || (pushdienst === 1) ) { setTimeout(function() { sendTo ("telegram.0", 'Alle Warnmeldungen des DWD wurden aufgehoben'); }, 9 * 1000); } if ((pushdienst === 2) || (pushdienst === 1) ) { setTimeout(function() { sendTo("pushover.0", 'Alle Warnmeldungen des DWD wurden aufgehoben'); }, 9 * 1000); } } /* Bereich verbinden Einzelnachrichten für Sprachausgabe */ if((Meldung0Sprache !== '') && (Meldung1Sprache !== '') && (Meldung2Sprache !== '') && (Meldung3Sprache !== '')){ MeldungSprache = Meldung0Sprache + " . " + Meldung1Sprache + " . " + Meldung2Sprache + " . " + Meldung3Sprache; } else if((Meldung0Sprache !== '') && (Meldung1Sprache !== '') && (Meldung2Sprache !== '')){ MeldungSprache = Meldung0Sprache + " . " + Meldung1Sprache + " . " + Meldung2Sprache; } else if((Meldung0Sprache !== '') && (Meldung1Sprache !== '') && (Meldung2Sprache === '')) { MeldungSprache = Meldung0Sprache + " . " + Meldung1Sprache; } else if((Meldung0Sprache !== '') && (Meldung1Sprache === '') && (Meldung2Sprache === '')) { MeldungSprache = Meldung0Sprache; } else { MeldungSprache = Meldung0Sprache; } if(idSprachausgabe === true){ var Url = "http://" + idMediaplayer + "/track=4fachgong.mp3|tts=" + MeldungSprache; log('Url :' + Url); request(Url); /* Löschen Inhalt Meldevariablen für Text und Sprache */ setTimeout(function() { Meldung3 = ''; Meldung2 = ''; Meldung1 = ''; Meldung0 = ''; Meldung = ''; Meldung3Sprache = ''; Meldung2Sprache = ''; Meldung1Sprache = ''; Meldung0Sprache = ''; MeldungSprache = ''; }, 13 * 1000); } } /* Auslöser Warnung0 */ on(idDescription0, function (obj){ if(obj.newState.lc > obj.oldState.lc){ if(timer) clearTimeout(timer); timer = setTimeout(nachricht, 5000); } }); /* Auslöser Warnung1 */ on(idDescription1, function (obj){ if(obj.newState.lc > obj.oldState.lc){ if(timer) clearTimeout(timer); timer = setTimeout(nachricht, 5000); } }); /* Auslöser Warnung2 */ on(idDescription2, function (obj){ if(obj.newState.lc !== obj.oldState.lc){ if(timer) clearTimeout(timer); timer = setTimeout(nachricht, 5000); } }); /* Auslöser Warnung3 */ on(idDescription2, function (obj){ if(obj.newState.lc !== obj.oldState.lc){ if(timer) clearTimeout(timer); timer = setTimeout(nachricht, 5000); } }); /* Entfernt "°C" aus Sprachmeldung und ersetzt es durch "Grad" */ function entferneDatenpunkt(beschreibung) { var rueckgabe; rueckgabe = beschreibung; try {rueckgabe = rueckgabe.replace(/\°C/g, "Grad");} catch(e) {} return rueckgabe; } `
                                      • wendy2702
                                        @grisuv:
                                        In der Zeile "if(idSprachausgabe === true){" kommt ein ausrufezeichen "zu viele fehler. 82% scanned" `
                                        Das hatte ich auch.
                                        Habe das Script für mich erstmal soweit korrigiert und an Sayit angepasst das es für mich funktioniert.
                                        Lediglich mit den Ansagen bei mehreren Warnungen scheint es ein Problem zu geben.
                                        ! /* Script zum Übertragen der DWD-Wetterwarnungen an Telegram/Sayit /
                                        Stand: 11012029 Wendy2702 /
                                        ! var request = require('request');
                                        Abfragen eingestellten Nachrichten-Dienst /
                                        aus=0 ; alle=1 ; Pushover=2 ; Telegram=3 /
                                        ! var pushdienst = 3; // Auswahl Nachrichtendienst
                                        Pfadangaben /
                                        ! var instanz = 'javascript.1.'; // Instanz des javascript-Adapters
                                        ! var pfad = 'DWD'; // Pfad in im Javascript-Adapter
                                        Konfiguration Sprachausgabe /
                                        ! var idSprachausgabe = true; // Wenn zusätzlich eine Sprachausgabe erfolgen soll dann auf true, ohne Sprachausgabe false
                                        ! // var idMediaplayer = "192.168.000.000:50000"; // Eingabe IP-Adresse incl. Port für Home24-Mediaplayer
                                        ! var idSayIt = "sayit.1.tts.text";
                                        ! // Einstellung Lautstaerke
                                        ! var lautstaerke = 90;
                                        Datenpunkte DWD-Adapter /
                                        ! var idDescription0 = "dwd.0.warning0.description";
                                        ! var idDescription1 = "dwd.0.warning1.description";
                                        ! var idDescription2 = "dwd.0.warning2.description";
                                        ! var idDescription3 = "dwd.0.warning3.description";
                                        ! var idHeadline0 = "dwd.0.warning0.headline";
                                        ! var idHeadline1 = "dwd.0.warning1.headline";
                                        ! var idHeadline2 = "dwd.0.warning2.headline";
                                        ! var idHeadline3 = "dwd.0.warning3.headline";
                                        ! var idBegin0 = "dwd.0.warning0.begin";
                                        ! var idBegin1 = "dwd.0.warning1.begin";
                                        ! var idBegin2 = "dwd.0.warning2.begin";
                                        ! var idBegin3 = "dwd.0.warning3.begin";
                                        ! var idEnd0 = "dwd.0.warning0.end";
                                        ! var idEnd1 = "dwd.0.warning1.end";
                                        ! var idEnd2 = "dwd.0.warning2.end";
                                        ! var idEnd3 = "dwd.0.warning3.end";
                                        ! /* Sicherung der DWD-Warnmeldungen /
                                        ! createState(instanz + pfad + ".BackupMessage0");
                                        ! createState(instanz + pfad + ".BackupMessage1");
                                        ! createState(instanz + pfad + ".BackupMessage2");
                                        ! createState(instanz + pfad + ".BackupMessage3");
                                        Sicherung der DWD-headlines und Gültig-Bis /
                                        ! createState(instanz + pfad + ".headline0");
                                        ! createState(instanz + pfad + ".headline1");
                                        ! createState(instanz + pfad + ".headline2");
                                        ! createState(instanz + pfad + ".headline3");
                                        ! createState(instanz + pfad + ".gueltig0");
                                        ! createState(instanz + pfad + ".gueltig1");
                                        ! createState(instanz + pfad + ".gueltig2");
                                        ! var idBackupMessage0 = instanz + pfad + ".BackupMessage0";
                                        ! var idBackupMessage1 = instanz + pfad + ".BackupMessage1";
                                        ! var idBackupMessage2 = instanz + pfad + ".BackupMessage2";
                                        ! var idBackupMessage3 = instanz + pfad + ".BackupMessage3";
                                        ! var idBackHeadline0 = instanz + pfad + ".headline0";
                                        ! var idBackHeadline1 = instanz + pfad + ".headline1";
                                        ! var idBackHeadline2 = instanz + pfad + ".headline2";
                                        ! var idBackHeadline3 = instanz + pfad + ".headline3";
                                        ! var idBackGueltig0 = instanz + pfad + ".gueltig0";
                                        ! var idBackGueltig1 = instanz + pfad + ".gueltig1";
                                        ! var idBackGueltig2 = instanz + pfad + ".gueltig2";
                                        Meldungen Text und Sprache /
                                        ! var Meldung = '';
                                        ! var Meldung0 = '';
                                        ! var Meldung1 = '';
                                        ! var Meldung2 = '';
                                        ! var MeldungSprache = '';
                                        ! var Meldung0Sprache = '';
                                        ! var Meldung1Sprache = '';
                                        ! var Meldung2Sprache = '';
                                        Konfiguration Timer /
                                        ! var timer = null;
                                        Einlesen Backup /
                                        ! var BackupMessage0 = getState(idBackupMessage0).val;
                                        ! var BackupMessage1 = getState(idBackupMessage1).val;
                                        ! var BackupMessage2 = getState(idBackupMessage2).val;
                                        ! var BackupMessage3 = getState(idBackupMessage3).val;
                                        Einlesen Warnung0 /
                                        ! var Description0 = getState(idDescription0).val;
                                        ! var Headline0 = getState(idHeadline0).val;
                                        ! var Begin0 = getState(idBegin0).val;
                                        ! var End0 = getState(idEnd0).val;
                                        Einlesen Warnung1 /
                                        ! var Description1 = getState(idDescription1).val;
                                        ! var Headline1 = getState(idHeadline1).val;
                                        ! var Begin1 = getState(idBegin1).val;
                                        ! var End1 = getState(idEnd1).val;
                                        Einlesen Warnung2 /
                                        ! var Description2 = getState(idDescription2).val;
                                        ! var Headline2 = getState(idHeadline2).val;
                                        ! var Begin2 = getState(idBegin2).val;
                                        ! var End2 = getState(idEnd2).val;
                                        Einlesen Warnung3 /
                                        ! var Description3 = getState(idDescription3).val;
                                        ! var Headline3 = getState(idHeadline3).val;
                                        ! var Begin3 = getState(idBegin3).val;
                                        ! var End3 = getState(idEnd3).val;
                                        Variable für Vergleich /
                                        ! var Pruefung0 = Description0 + End0;
                                        ! var Pruefung1 = Description1 + End1;
                                        ! var Pruefung2 = Description2 + End2;
                                        ! var Pruefung3 = Description3 + End3;
                                        Bereich Auswerten neue Wetterwarnung für Warnung3 /
                                        ! if((Description3 !== "") && (Pruefung3 !== BackupMessage3) && (Pruefung3 !== BackupMessage2) && (Pruefung3 !== BackupMessage1) && (Pruefung3 !== BackupMessage0)) {
                                        ! Meldung3 = Headline3 + "\ngültig vom " + Begin3 + " Uhr bis " + End3 + " Uhr\n" + Description3;
                                        ! var replaceDescription3 = entferneDatenpunkt(Description3);
                                        ! Meldung3Sprache = Headline3 + " gültig vom " + Begin3 + " Uhr, bis " + End3 + " Uhr. " + replaceDescription3;
                                        ! if ((pushdienst === 3) || (pushdienst === 1) ) {
                                        ! sendTo ("telegram.0", Meldung3);
                                        ! if ((pushdienst === 2) || (pushdienst === 1) ) {
                                        ! sendTo("pushover.0", Meldung3);
                                        ! setState(idBackupMessage3,Pruefung3);
                                        ! setState(idBackHeadline3,Headline3);
                                        ! setState(idBackGueltig3,End3);
                                        ! } else if((Description3 === "") && (Description2 !== "") && (Description1 !== "") && (Description0 !== "") && (BackupMessage3 !== Pruefung2) && (BackupMessage3 !== Pruefung1) && (BackupMessage3 !== Pruefung0)) {
                                        ! var Headlineclear3 = getState(idBackHeadline3).val;
                                        ! var Gueltigclear3 = getState(idBackGueltig3).val;
                                        ! setTimeout(function() {
                                        ! sendTo ("telegram.0", "Die Wetterwarnung " +"'"+ Headlineclear3 + " gültig bis " + Gueltigclear3 + "'" + " des Wetterdienstes wurde aufgehoben");
                                        ! }, 1 * 1000);
                                        ! sendTo("pushover.0", "Die Wetterwarnung " +"'"+ Headlineclear3 + " gültig bis " + Gueltigclear3 + "'" + " des Wetterdienstes wurde aufgehoben");
                                        ! }, 1 * 1000);
                                        ! setState(idBackupMessage3,'');
                                        Bereich Auswerten neue Wetterwarnung für Warnung2 /
                                        ! if((Description2 !== "") && (Pruefung2 !== BackupMessage3) && (Pruefung2 !== BackupMessage2) && (Pruefung2 !== BackupMessage1) && (Pruefung2 !== BackupMessage0)) {
                                        ! Meldung2 = Headline2 + "\ngültig vom " + Begin2 + " Uhr bis " + End2 + " Uhr\n" + Description2;
                                        ! var replaceDescription2 = entferneDatenpunkt(Description2);
                                        ! Meldung2Sprache = Headline2 + " gültig vom " + Begin2 + " Uhr, bis " + End2 + " Uhr. " + replaceDescription2;
                                        ! sendTo ("telegram.0", Meldung2);
                                        ! }, 1 * 1000);
                                        ! sendTo("pushover.0", Meldung2);
                                        ! }, 1 * 1000);
                                        ! setState(idBackupMessage2,Pruefung2);
                                        ! setState(idBackHeadline2,Headline2);
                                        ! setState(idBackGueltig2,End2);
                                        ! } else if((Description3 === "") && (Description2 === "") && (Description1 !== "") && (Description0 !== "") && (BackupMessage2 !== Pruefung3) && (BackupMessage2 !== Pruefung1) && (BackupMessage2 !== Pruefung0)) {
                                        ! var Headlineclear2 = getState(idBackHeadline2).val;
                                        ! var Gueltigclear2 = getState(idBackGueltig2).val;
                                        ! sendTo ("telegram.0", "Die Wetterwarnung " +"'"+ Headlineclear2 + " gültig bis " + Gueltigclear2 + "'" + " des Wetterdienstes wurde aufgehoben");
                                        ! }, 1 * 1000);
                                        ! sendTo("pushover.0", "Die Wetterwarnung " +"'"+ Headlineclear2 + " gültig bis " + Gueltigclear2 + "'" + " des Wetterdienstes wurde aufgehoben");
                                        ! }, 1 * 1000);
                                        ! setState(idBackupMessage2,'');
                                        Bereich Auswerten neue Wetterwarnung für Warnung1 /
                                        ! if((Description1 !== "") && (Pruefung1 !== BackupMessage3) && (Pruefung1 !== BackupMessage2) && (Pruefung1 !== BackupMessage1) && (Pruefung1 !== BackupMessage0)) {
                                        ! Meldung1 = Headline1 + "\ngültig vom " + Begin1 + " Uhr bis " + End1 + " Uhr\n" + Description1;
                                        ! var replaceDescription1 = entferneDatenpunkt(Description1);
                                        ! Meldung1Sprache = Headline1 + " gültig vom " + Begin1 + " Uhr, bis " + End1 + " Uhr. " + replaceDescription1;
                                        ! sendTo ("telegram.0", Meldung1);
                                        ! }, 5 * 1000);
                                        ! sendTo("pushover.0", Meldung1);
                                        ! }, 5 * 1000);
                                        ! setState(idBackupMessage1,Pruefung1);
                                        ! setState(idBackHeadline1,Headline1);
                                        ! setState(idBackGueltig1,End1);
                                        ! } else if((Description3 === "") && (Description2 === "") && (Description1 === "") && (Description0 !== "") && (BackupMessage1 !== Pruefung3) && (BackupMessage1 !== Pruefung2) && (BackupMessage1 !== Pruefung0)) {
                                        ! var Headlineclear1 = getState(idBackHeadline1).val;
                                        ! var Gueltigclear1 = getState(idBackGueltig1).val;
                                        ! sendTo ("telegram.0", "Die Wetterwarnung " +"'"+ Headlineclear1 + " gültig bis " + Gueltigclear1 + "'" + " des Wetterdienstes wurde aufgehoben");
                                        ! }, 5 * 1000);
                                        ! sendTo("pushover.0", "Die Wetterwarnung " +"'"+ Headlineclear1 + " gültig bis " + Gueltigclear1 + "'" + " des Wetterdienstes wurde aufgehoben");
                                        ! }, 5 * 1000);
                                        ! setState(idBackupMessage1,'');
                                        Bereich Auswerten neue Wetterwarnung für Warnung0 /
                                        ! if((Description0 !== "") && (Pruefung0 !== BackupMessage3) && (Pruefung0 !== BackupMessage2) && (Pruefung0 !== BackupMessage1) && (Pruefung0 !== BackupMessage0)) {
                                        ! Meldung0 = Headline0 + "\ngültig vom " + Begin0 + " Uhr bis " + End0 + " Uhr\n" + Description0;
                                        ! var replaceDescription0 = entferneDatenpunkt(Description0);
                                        ! Meldung0Sprache = Headline0 + " gültig vom " + Begin0 + " Uhr, bis " + End0 + " Uhr. " + replaceDescription0;
                                        ! sendTo ("telegram.0", Meldung0);
                                        ! }, 9 * 1000);
                                        ! sendTo("pushover.0", Meldung0);
                                        ! }, 9 * 1000);
                                        ! setState(idBackupMessage0,Pruefung0);
                                        ! setState(idBackHeadline0,Headline0);
                                        ! setState(idBackGueltig0,End0);
                                        ! } else if((Description0 === "") && (Description1 === "") && (Description2 === "") && (Description3 === "")) {
                                        ! setState(idBackupMessage0,'');
                                        ! Meldung0Sprache = 'Alle Warnmeldungen des Wetterdienstes wurden aufgehoben';
                                        ! sendTo ("telegram.0", 'Alle Warnmeldungen des Wetterdienstes wurden aufgehoben');
                                        ! }, 9 * 1000);
                                        ! sendTo("pushover.0", 'Alle Warnmeldungen des Wetterdienstes wurden aufgehoben');
                                        ! }, 9 * 1000);
                                        Bereich verbinden Einzelnachrichten für Sprachausgabe /
                                        ! if((Meldung0Sprache !== '') && (Meldung1Sprache !== '') && (Meldung2Sprache !== '') && (Meldung3Sprache !== '')){
                                        ! MeldungSprache = Meldung0Sprache + " . " + Meldung1Sprache + " . " + Meldung2Sprache + " . " + Meldung3Sprache;
                                        ! } else
                                        ! if((Meldung0Sprache !== '') && (Meldung1Sprache !== '') && (Meldung2Sprache !== '')){
                                        ! MeldungSprache = Meldung0Sprache + " . " + Meldung1Sprache + " . " + Meldung2Sprache;
                                        ! } else
                                        ! if((Meldung0Sprache !== '') && (Meldung1Sprache !== '') && (Meldung2Sprache === '')) {
                                        ! MeldungSprache = Meldung0Sprache + " . " + Meldung1Sprache;
                                        ! } else
                                        ! if((Meldung0Sprache !== '') && (Meldung1Sprache === '') && (Meldung2Sprache === '')) {
                                        ! MeldungSprache = Meldung0Sprache;
                                        ! else {
                                        ! if(idSprachausgabe === true){
                                        ! // var Url = "http://" + idMediaplayer + "/track=4fachgong.mp3|tts=" + MeldungSprache;
                                        ! // log('Url :' + Url);
                                        ! // request(Url);
                                        ! if (compareTime('09:00', '22:30', "between", null)) {
                                        ! setState(idSayIt, lautstaerke + ";" + MeldungSprache);
                                        Löschen Inhalt Meldevariablen für Text und Sprache /
                                        ! Meldung3 = '';
                                        ! Meldung2 = '';
                                        ! Meldung1 = '';
                                        ! Meldung0 = '';
                                        ! Meldung = '';
                                        ! Meldung3Sprache = '';
                                        ! Meldung2Sprache = '';
                                        ! Meldung1Sprache = '';
                                        ! Meldung0Sprache = '';
                                        ! MeldungSprache = '';
                                        ! }, 13 * 1000);
                                        Auslöser Warnung0 /
                                        ! on(idDescription0, function (obj){
                                        ! if(obj.newState.lc > obj.oldState.lc){
                                        ! if(timer) clearTimeout(timer);
                                        ! timer = setTimeout(nachricht, 5000);
                                        Auslöser Warnung1 /
                                        ! on(idDescription1, function (obj){
                                        Auslöser Warnung2 /
                                        ! on(idDescription2, function (obj){
                                        ! if(obj.newState.lc !== obj.oldState.lc){
                                        Auslöser Warnung3 /
                                        ! function entferneDatenpunkt(beschreibung) {
                                        ! var rueckgabe;
                                        ! rueckgabe = beschreibung;
                                        ! try {rueckgabe = rueckgabe.replace(/\°C/g, "Grad");}
                                        ! catch(e) {}
                                        ! return rueckgabe;
                                          Hi zusammen,
                                          Ist mir leider auch schon aufgefallen.
                                          Bin gerade an ner neuen Version.
                                          Kürzer und hoffentlich ohne Fehler.
                                          Gruß Johnny
                                          • wendy2702
                                            Kein Stress [emoji41]
                                            67
                                            10362
