    4. Test Adapter PSA v0.0.x Peugeot Opel Citroen
      tombox @sigi234 last edited by
      @sigi234 @holgerwolf Login is gefixt für Sonderzeichen. Vehicles müssten jetzt auch geholt werden außer bei den älteren account da schaue ich noch
        sigi234 Forum Testing Most Active @tombox last edited by sigi234
        @tombox sagte in Test Adapter PSA v0.0.x Peugot Opel Citroen:
        psa.0
        2021-06-23 09:44:52.511	error	Get vehicles failed
        psa.0
        2021-06-23 09:44:52.511	error	{"uuid":"xxxxxxxxxxxxxx","code":40410,"message":"No vehicule found"}
        psa.0
        2021-06-23 09:44:52.511	error	Get Vehicles failed
        psa.0
        2021-06-23 09:44:52.510	error	Error: Request failed with status code 404
        psa.0
        2021-06-23 09:44:52.089	warn	State "psa.0.info.connection" has no existing object, this might lead to an error in future versions
        psa.0
        2021-06-23 09:44:52.084	info	Login successful
        psa.0
        2021-06-23 09:44:52.083	debug	{"scope":"openid profile","expires_in":3599,"token_type":"Bearer","refresh_token":"xxxxxxxxxxx-xxxxxxxx-5ea8a30a1ed7","id_token":"xxxxxx","access_token":"xxxxxxxxxxx"}
        psa.0
        2021-06-23 09:44:51.694	info	starting. Version 0.0.1 in C:/Program Files/iobroker/Home/node_modules/iobroker.psa, node: v12.22.1, js-controller: 3.3.14
        psa.0
        2021-06-23 09:44:51.485	debug	statesDB connected
        psa.0
        2021-06-23 09:44:51.484	debug	States connected to redis: 127.0.0.1:9010
        psa.0
        2021-06-23 09:44:51.463	debug	States create User PubSub Client
        psa.0
        2021-06-23 09:44:51.462	debug	States create System PubSub Client
        psa.0
        2021-06-23 09:44:51.456	debug	Redis States: Use Redis connection: 127.0.0.1:9010
        psa.0
        2021-06-23 09:44:51.455	debug	objectDB connected
        psa.0
        2021-06-23 09:44:51.451	debug	Objects connected to redis: 127.0.0.1:9011
        psa.0
        2021-06-23 09:44:51.432	debug	Objects client initialize lua scripts
        psa.0
        2021-06-23 09:44:51.432	debug	Objects create User PubSub Client
        psa.0
        2021-06-23 09:44:51.431	debug	Objects create System PubSub Client
        psa.0
        2021-06-23 09:44:51.431	debug	Objects client ready ... initialize now
        psa.0
        2021-06-23 09:44:51.401	debug	Redis Objects: Use Redis connection: 127.0.0.1:9011
        psa.0
        2021-06-23 09:44:47.728	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        psa.0
        2021-06-23 09:44:47.728	warn	Clear yet terminated interval 484
        psa.0
        2021-06-23 09:44:47.727	warn	Clear yet terminated interval undefined
        psa.0
        2021-06-23 09:44:47.728	info	terminating
        psa.0
        2021-06-23 09:44:47.726	info	Got terminate signal TERMINATE_YOURSELF
          holgerwolf @sigi234 last edited by holgerwolf
          Nächster Fehler:
          psa.0
          	2021-06-23 10:06:20.129	error	Get device status failed
          psa.0
          	2021-06-23 10:06:20.129	error	{"httpCode":"401","httpMessage":"Unauthorized","moreInformation":"Token is invalid"}
          psa.0
          	2021-06-23 10:06:20.129	error	Get 1566c497a565574615331686154456f334f546b314f544d6a497a4133595752684d57466c4d6d49334f474d31597a67335a6a64694f5463314e7a6c6d5a546c684d6d4e6c595459334d3245774d4455354d54686b4e3249794e4756694e7a686c5a6a566a4d325130596d45784f574d3dstatus failed
          psa.0
          	2021-06-23 10:06:20.128	error	Error: Request failed with status code 401
          psa.0
          	2021-06-23 10:06:20.121	error	Get device status failed
          psa.0
          	2021-06-23 10:06:20.121	error	{"httpCode":"401","httpMessage":"Unauthorized","moreInformation":"Token is invalid"}
          psa.0
          	2021-06-23 10:06:20.121	error	Get 1566c497a565574615331686154456f334f546b314f544d6a497a4133595752684d57466c4d6d49334f474d31597a67335a6a64694f5463314e7a6c6d5a546c684d6d4e6c595459334d3245774d4455354d54686b4e3249794e4756694e7a686c5a6a566a4d325130596d45784f574d3dlastPosition failed
          psa.0
          	2021-06-23 10:06:20.120	error	Error: Request failed with status code 401
          psa.0
          	2021-06-23 10:06:20.095	error	Get Details failed
          psa.0
          	2021-06-23 10:06:20.094	error	{"httpCode":"401","httpMessage":"Unauthorized","moreInformation":"Invalid client id or secret."}
          psa.0
          	2021-06-23 10:06:20.094	error	Get 1566c497a565574615331686154456f334f546b314f544d6a497a4133595752684d57466c4d6d49334f474d31597a67335a6a64694f5463314e7a6c6d5a546c684d6d4e6c595459334d3245774d4455354d54686b4e3249794e4756694e7a686c5a6a566a4d325130596d45784f574d3d.details failed
          psa.0
          	2021-06-23 10:06:20.094	error	Error: Request failed with status code 401
          psa.0
          	2021-06-23 10:06:19.938	debug	{"_links":{"self":{"href":"https://api.groupe-psa.com/connectedcar/v4/user"},"vehicles":{"href":"https://api.groupe-psa.com/connectedcar/v4/user/vehicles"}},"_embedded":{"vehicles":[{"id":"YYYY","vin":"XXXX","brand":"Peugeot","pictures":["http://visuel3d.peugeot.com/V3DImage.ashx?client=miseco&format=png&back=0&version=1PP1SYUESFB0A0B0&color=0MM60NSM&trim=0P2A0RFX&OPT1=DE30&OPT2=DLZ0&OPT3=DTC0&view=001","http://visuel3d.peugeot.com/V3DImage.ashx?client=miseco&format=png&back=0&version=1PP1SYUESFB0A0B0&color=0MM60NSM&trim=0P2A0RFX&OPT1=DE30&OPT2=DLZ0&OPT3=DTC0&view=002","http://visuel3d.peugeot.com/V3DImage.ashx?client=miseco&format=png&back=0&version=1PP1SYUESFB0A0B0&color=0MM60NSM&trim=0P2A0RFX&OPT1=DE30&OPT2=DLZ0&OPT3=DTC0&view=003","http://visuel3d.peugeot.com/V3DImage.ashx?client=miseco&format=png&back=0&version=1PP1SYUESFB0A0B0&color=0MM60NSM&trim=0P2A0RFX&OPT1=DE30&OPT2=DLZ0&OPT3=DTC0&view=004","http://visuel3d.peugeot.com/V3DImage.ashx?client=miseco&format=png&back=0&version=1PP1SYUESFB0A0B0&color=0MM60NSM&trim=0P2A0RFX&OPT1=DE30&OPT2=DLZ0&OPT3=DTC0&view=005","http://visuel3d.peugeot.com/V3DImage.ashx?client=miseco&format=png&back=0&version=1PP1SYUESFB0A0B0&color=0MM60NSM&trim=0P2A0RFX&OPT1=DE30&OPT2=DLZ0&OPT3=DTC0&view=006","http://visuel3d.peugeot.com/V3DImage.ashx?client=miseco&format=png&back=0&version=1PP1SYUESFB0A0B0&color=0MM60NSM&trim=0P2A0RFX&OPT1=DE30&OPT2=DLZ0&OPT3=DTC0&view=007","http://visuel3d.peugeot.com/V3DImage.ashx?client=miseco&format=png&back=0&version=1PP1SYUESFB0A0B0&color=0MM60NSM&trim=0P2A0RFX&OPT1=DE30&OPT2=DLZ0&OPT3=DTC0&view=008","http://visuel3d.peugeot.com/V3DImage.ashx?client=miseco&format=png&back=0&version=1PP1SYUESFB0A0B0&color=0MM60NSM&trim=0P2A0RFX&OPT1=DE30&OPT2=DLZ0&OPT3=DTC0&view=009","http://visuel3d.peugeot.com/V3DImage.ashx?client=miseco&format=png&back=0&version=1PP1SYUESFB0A0B0&color=0MM60NSM&trim=0P2A0RFX&OPT1=DE30&OPT2=DLZ0&OPT3=DTC0&view=010","http://visuel3d.peugeot.com/V3DImage.ashx?client=miseco&format=png&back=0&version=1PP1SYUESFB0A0B0&color=0MM60NSM&trim=0P2A0RFX&OPT1=DE30&OPT2=DLZ0&OPT3=DTC0&view=011","http://visuel3d.peugeot.com/V3DImage.ashx?client=miseco&format=png&back=0&version=1PP1SYUESFB0A0B0&color=0MM60NSM&trim=0P2A0RFX&OPT1=DE30&OPT2=DLZ0&OPT3=DTC0&view=012"],"_links":{"alerts":{"href":"https://api.groupe-psa.com/connectedcar/v4/user/vehicles/1566c497a565574615331686154456f334f546b314f544d6a497a4133595752684d57466c4d6d49334f474d31597a67335a6a64694f5463314e7a6c6d5a546c684d6d4e6c595459334d3245774d4455354d54686b4e3249794e4756694e7a686c5a6a566a4d325130596d45784f574d3d/alerts"},"trips":{"href":"https://api.groupe-psa.com/connectedcar/v4/user/vehicles/1566c497a565574615331686154456f334f546b314f544d6a497a4133595752684d57466c4d6d49334f474d31597a67335a6a64694f5463314e7a6c6d5a546c684d6d4e6c595459334d3245774d4455354d54686b4e3249794e4756694e7a686c5a6a566a4d325130596d45784f574d3d/trips"},"self":{"href":"https://api.groupe-psa.com/connectedcar/v4/user/vehicles/1566c497a565574615331686154456f334f546b314f544d6a497a4133595752684d57466c4d6d49334f474d31597a67335a6a64694f5463314e7a6c6d5a546c684d6d4e6c595459334d3245774d4455354d54686b4e3249794e4756694e7a686c5a6a566a4d325130596d45784f574d3d"},"lastPosition":{"href":"https://api.groupe-psa.com/connectedcar/v4/user/vehicles/1566c497a565574615331686154456f334f546b314f544d6a497a4133595752684d57466c4d6d49334f474d31597a67335a6a64694f5463314e7a6c6d5a546c684d6d4e6c595459334d3245774d4455354d54686b4e3249794e4756694e7a686c5a6a566a4d325130596d45784f574d3d/lastPosition"},"telemetry":{"href":"https://api.groupe-psa.com/connectedcar/v4/user/vehicles/1566c497a565574615331686154456f334f546b314f544d6a497a4133595752684d57466c4d6d49334f474d31597a67335a6a64694f5463314e7a6c6d5a546c684d6d4e6c595459334d3245774d4455354d54686b4e3249794e4756694e7a686c5a6a566a4d325130596d45784f574d3d/telemetry"},"maintenance":{"href":"https://api.groupe-psa.com/connectedcar/v4/user/vehicles/1566c497a565574615331686154456f334f546b314f544d6a497a4133595752684d57466c4d6d49334f474d31597a67335a6a64694f5463314e7a6c6d5a546c684d6d4e6c595459334d3245774d4455354d54686b4e3249794e4756694e7a686c5a6a566a4d325130596d45784f574d3d/maintenance"},"status":{"href":"https://api.groupe-psa.com/connectedcar/v4/user/vehicles/1566c497a565574615331686154456f334f546b314f544d6a497a4133595752684d57466c4d6d49334f474d31597a67335a6a64694f5463314e7a6c6d5a546c684d6d4e6c595459334d3245774d4455354d54686b4e3249794e4756694e7a686c5a6a566a4d325130596d45784f574d3d/status"}}}]}}
          psa.0
          	2021-06-23 10:06:19.554	warn	State "psa.0.info.connection" has no existing object, this might lead to an error in future versions
          psa.0
          	2021-06-23 10:06:19.541	info	Login successful
          psa.0
          	2021-06-23 10:06:19.540	debug	{"scope":"openid profile","expires_in":3599,"token_type":"Bearer","refresh_token":"XXXX"}
          Wo hatte ich denn ein Sonderzeichen?
            sigi234 Forum Testing Most Active @holgerwolf last edited by
            @holgerwolf sagte in Test Adapter PSA v0.0.x Peugot Opel Citroen:
            Das war bei mir im Passwort denke ich. 😏
              tombox @holgerwolf last edited by
              @holgerwolf Probier nochmal
              T H 2 Replies Last reply Reply Quote 0
                tombox @tombox last edited by
                @sigi234 Die api geht anscheinend nur für die neuen emodelle
                @holgerwolf Es sieht gut aus erste Daten kommen rein ich versuche noch die fernsteuerung mit reinzumachen
                  holgerwolf @tombox last edited by
                  @tombox Gleicher 401 error wie oben:
                  psa.0
                  	2021-06-23 11:18:05.549	error	{"httpCode":"401","httpMessage":"Unauthorized","moreInformation":"Invalid client id or secret."}
                  Ich habe den Adapter auch mal komplett deinstalliert und neu aufgesetzt. Gleiches Ergebnis.
                  Was nutzt du den eigentlich für den Adapter? Ich zapfe die PSA API ja auch durch ein paar andere Methoden an:
                  Direkt in der Wallbox (OpenWB). Dort muss ich aber zusätzlich zum Login und PW noch die Client ID und Secret angeben. Die habe ich vorher mit dieser Methode erzeugt:
                  https://github.com/flobz/psa_car_controller/blob/master/docs/Install.md
                  Erzeugst du die Client Daten selbst?
                    @holgerwolf Nochmal die aktuelle github version installieren. alle objekte löschen
                    Ja
                      @tombox Jetzt gehts. Hat sich wohl irgendwas überschnitten.
                      Batteriestatus, Position, und Kilometer (in Meilen) werden aktualsiert.
                      Danke und Gruß
                      Holger
                        michihorn @tombox last edited by
                        @tombox Hey super, vielen Dank für den Adapter, Installation klappte sofort er hat auch sofort Daten geliefert, allerdings von meinem letzten Dienstwagen einen 3008 Hybrid, aktuell habe ich einen 508 SW Hybrid. Kann es sein das die Daten noch kommen? In der APP ist nur noch der aktuelles DW drin.
                        Michael
                          tombox @michihorn last edited by
                          @michihorn Schreib mich mal an müsste mich mir genau anschauen ob etwas auffälliges in deinem account ist
                            Ich glaube gerade jetzt hat PSA was an der API geändert. Ist auch schon Thema im OpenWB-Forum:
                            https://openwb.de/forum/viewtopic.php?f=5&t=1206&start=240
                            Es werden jetzt pro Status-Änderungen einzelne Bäume mit Zeitstempel als Objekte angelegt:
                            Zusätzlich gibt es noch einen Fuel-Level (Hybrid oder Verbrenner?)
                              @holgerwolf schaue ich mir gleich an und passe es an das es schöner aussieht
                                @holgerwolf Ich kann die Änderung nicht nachvollziehen bei mir kommen sie noch nach dem alten format
                                  @tombox Bei mir kamen die Änderungen auch erst nach der ersten, neuen Fahrt. Gestern war noch alles ok, bei anderen kam schon die neue Struktur.
                                    @michihorn @sigi234
                                    Das problem ist dass das "neue" fahrzeug nicht die neue API unterstützt.
                                    Ich habe jetzt die alte API hinzugefügt aber die liest nur den km stand aus mehr nicht.
                                      psa.0
                                      2021-06-25 12:55:31.731	error	Get vehicles failed
                                      psa.0
                                      2021-06-25 12:55:31.731	error	No compatible vehicles found. Maybe your vehicle is too old.
                                      psa.0
                                      2021-06-25 12:55:31.730	error	{"uuid":"dfb1e1a3-3558-4cf5-b96c-3594639db06c","code":40410,"message":"No vehicule found"}
                                      psa.0
                                      2021-06-25 12:55:31.730	error	Get Vehicles failed
                                      psa.0
                                      2021-06-25 12:55:31.730	error	Error: Request failed with status code 404
                                      psa.0
                                      2021-06-25 12:55:31.350	warn	receive old api failed
                                      psa.0
                                      2021-06-25 12:55:31.350	warn	TypeError [ERR_HTTP_INVALID_HEADER_VALUE]: Invalid value "undefined" for header "token"
                                      psa.0
                                      2021-06-25 12:55:31.286	info	Login successful
                                      psa.0
                                      2021-06-25 12:55:30.791	info	starting. Version 0.0.3 in C:/Program Files/iobroker/Home/node_modules/iobroker.psa, node: v12.22.1, js-controller: 3.3.14
                                      psa.0
                                      2021-06-25 12:57:28.735	error	Get Vehicles failed
                                      psa.0
                                      2021-06-25 12:57:28.735	error	Error: Request failed with status code 404
                                      psa.0
                                      2021-06-25 12:57:28.349	warn	receive old api failed
                                      psa.0
                                      2021-06-25 12:57:28.348	warn	TypeError [ERR_HTTP_INVALID_HEADER_VALUE]: Invalid value "undefined" for header "token"
                                      psa.0
                                      2021-06-25 12:57:28.344	debug	{"returnCode":"AUTHENTICATION_FAILED"}
                                      psa.0
                                      2021-06-25 12:57:28.260	info	Login successful
                                        @sigi234 probier nochmal via github
                                          mane444 last edited by
                                          Hallo, ich bin begeistert das jemand einen Adapter für diese Anwendung erstellt.
                                          Ich hab gerade meinen neuen C4 E bekommen und hab den Adapter getestet. Leider bekomme ich keine Verbindung. Die APP MY Citroen läuft, nur hab ich hier noch zusätzlich zu Benutzer und Passwort ein PIN. Brauche ich beim Adapter auch noch die PIN ?
                                          psa.0
                                          2021-06-25 15:42:41.289	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          psa.0
                                          2021-06-25 15:42:41.284	info	terminating
                                          psa.0
                                          2021-06-25 15:42:41.281	warn	Clear yet terminated interval undefined
                                          psa.0
                                          2021-06-25 15:42:41.279	warn	Clear yet terminated interval undefined
                                          psa.0
                                          2021-06-25 15:42:41.276	warn	Clear yet terminated interval undefined
                                          psa.0
                                          2021-06-25 15:42:41.271	info	Got terminate signal TERMINATE_YOURSELF
                                          psa.0
                                          2021-06-25 15:42:23.733	warn	No Token received for old api
                                          psa.0
                                          2021-06-25 15:42:23.731	warn	{"returnCode":"NEED_CREATION"}
                                          psa.0
                                          2021-06-25 15:42:23.729	debug	{"returnCode":"NEED_CREATION"}
                                          psa.0
                                          2021-06-25 15:42:23.683	error	Login failed
                                          psa.0
                                          2021-06-25 15:42:23.681	error	{"error":"invalid_client","error_description":"Client authentication failed"}
                                          psa.0
                                          2021-06-25 15:42:23.680	error	Login failed
                                          psa.0
                                          2021-06-25 15:42:23.677	error	Error: Request failed with status code 401
                                          psa.0
                                          2021-06-25 15:42:22.994	info	starting. Version 0.0.4 in /opt/iobroker/node_modules/iobroker.psa, node: v12.22.1, js-controller: 3.3.13
                                            TOP geht! 👍
                                            citroen corsa corsa-e e208 opel peugeot psa
                                            44
                                            334
                                            47377
