    4. Test Adapter PSA v0.0.x Peugeot Opel Citroen
      mane444 @tombox last edited by
      @tombox Das System stürzt wieder nach einer gewissen Zeit ab. Ich hab folgendes bemerkt. Da kommen Warnmeldungen und die verdoppeln sich nach jedem Zyklus.
      psa.0
      2021-06-27 21:35:37.174	warn	Clear yet terminated interval 118106
      psa.0
      2021-06-27 21:35:26.420	warn	Clear yet terminated interval 117788
      psa.0
      2021-06-27 21:35:26.345	warn	Clear yet terminated interval 115138
      psa.0
      2021-06-27 21:35:25.730	warn	Clear yet terminated interval 114820
      psa.0
      2021-06-27 21:35:25.647	warn	Clear yet terminated interval 112097
      psa.0
      2021-06-27 21:35:25.108	warn	Clear yet terminated interval 109109
      psa.0
      2021-06-27 21:35:24.622	warn	Clear yet terminated interval 108791
      psa.0
      2021-06-27 21:35:24.530	warn	Clear yet terminated interval 108473
      psa.0
      2021-06-27 21:35:24.483	warn	Clear yet terminated interval 107257
      psa.0
      2021-06-27 21:35:24.291	warn	Clear yet terminated interval 106346
      psa.0
      2021-06-27 21:35:24.162	warn	Clear yet terminated interval 90914
      psa.0
      2021-06-27 21:35:17.424	warn	Clear yet terminated interval 89087
      psa.0
      2021-06-27 21:35:17.141	warn	Clear yet terminated interval 88769
      psa.0
      2021-06-27 21:35:17.066	warn	Clear yet terminated interval 87853
      psa.0
      2021-06-27 21:35:16.896	warn	Clear yet terminated interval 83101
      psa.0
      2021-06-27 21:35:12.777	warn	Clear yet terminated interval 76868
      psa.0
      2021-06-27 21:30:26.502	warn	Clear yet terminated interval 66656
      psa.0
      2021-06-27 21:30:22.509	warn	Clear yet terminated interval 65998
      psa.0
      2021-06-27 21:30:22.356	warn	Clear yet terminated interval 63233
      psa.0
      2021-06-27 21:30:21.753	warn	Clear yet terminated interval 51482
      psa.0
      2021-06-27 21:30:17.661	warn	Clear yet terminated interval 50031
      psa.0
      2021-06-27 21:30:17.491	warn	Clear yet terminated interval 49404
      psa.0
      2021-06-27 21:30:17.325	warn	Clear yet terminated interval 44666
      psa.0
      2021-06-27 21:30:13.129	warn	Clear yet terminated interval 38440
      psa.0
      2021-06-27 21:25:21.732	warn	Clear yet terminated interval 31612
      psa.0
      2021-06-27 21:25:17.616	warn	Clear yet terminated interval 29438
      psa.0
      2021-06-27 21:25:17.059	warn	Clear yet terminated interval 24897
      psa.0
      2021-06-27 21:25:12.892	warn	Clear yet terminated interval 18781
      psa.0
      2021-06-27 21:20:17.319	warn	Clear yet terminated interval 14132
      psa.0
      2021-06-27 21:20:12.772	warn	Clear yet terminated interval 8241
      psa.0
      2021-06-27 21:15:13.068	warn	Clear yet terminated interval 2076
      psa.0
      2021-06-27 21:10:07.730	warn	Clear yet terminated interval undefined
        tombox @mane444 last edited by
        @mane444 Ich habe nochmal was umgeschoben probiere es nochmal
          aueland last edited by
          Moin @tombox
          wollte auch ein Feedback geben. Toll, dass du den Adapter aufgesetzt hast!
          Nutze ihn gerade mit einem Peugeot e208 aus 2020.
          Läuft soweit, Login funktioniert, Daten kommen rein. Den Fehler
          hatte ich gestern nach der ersten Installation auch. Jetzt nochmal nach Deiner Änderung neu installiert und die Warnung scheint weg zu sein.
          Witzig ist, dass der Kilometerstand zwischen alter und neue API unterschiedlich zu sein scheint bzw. die neue API den aktuelleren Stand ausliest.
          Den Update-Intervall habe ich jetzt erstmal auf den 5 Minuten gelassen, aber gerade wenn es um das Laden geht, würde ich gerne Häufiger abfragen, gibt es dann Probleme mit der API oder kann man auch in Abständen problemlos abfragen?
          Habe ich das richtig verstanden, Du hast den vor den Adapter so aufzubohren, dass zukünftig auch ein Steuern über iobroker möglich wird? Also vor allem Vorklimatisierung, Ladesteuerung... Das wäre echt Spitze!
          T H 2 Replies Last reply Reply Quote 0
            tombox @aueland last edited by
            @aueland Gut das der Fehler jetzt weg ist.
            Ich denke di eAPI kann einiges ab und minütlich sollte gehen oder weniger
            Ja wenn ich Zeit habe schon aber der Ablauf ist sehr kompliziert mit der SMS aktivierung
              holgerwolf @aueland last edited by
              @aueland sagte in Test Adapter PSA v0.0.x Peugot Opel Citroen:
              Das wird dir nix bringen, weil PSA leider den SoC beim Laden nicht aktualisiert 😞
                @holgerwolf ok, das ist natürlich blöd, aber in der myPeugeot App - wenn sie denn mal funktioniert, wird es doch auch angezeigt...
                Sonst muss ich mal schauen, ob ich dann nicht was über die Daten der Wallbox basteln kann. Also Ausgangslage via psa und dann hinzurechnen, was die Wallbox als Ladung angibt.
                @tombox said in Test Adapter PSA v0.0.x Peugot Opel Citroen:
                Danke, bin gespannt und stehe für Tests gerne zur Verfügung.
                  Ja, aber du willst ja auch nicht ständig in der App nachschauen, damit dann die API nen neuen Wert hat 😉
                  Welche Wallbox hast du? Bei der OpenWB wird das jetzt schon gemacht. Beim Ladestart SoC abfragen und dann den SoC anhand der Lademenge, Batteriegröße und Effizienz berechen.
                    aueland @holgerwolf last edited by
                    @holgerwolf habe die E3/DC easy Connect. Überschussladen klappt damit mehr oder weniger, aber z.B. nicht das Fzg. nur bis x% aufladen. Wobei ich da eventuell mit einem Script über die Wallboxsteuerung noch was machen könnte, aber das gibt es eben bisher m.W. nicht und ich konnte mich noch nicht damit beschäftigen. Greife im Moment nur lesend via modbus drauf zu. Über RSPC wäre auch eine schreibende Umsetzung möglich und damit das, was ich möchte. Wenn das aber auch von der anderen Seite - dem Peugeot her - ginge, wäre ich nicht böse drum 😉
                      @tombox Hi, Systemabsturz ist weg. Nun werden die Daten gelesen, aber nach einer Stunde kommen Errors und es werden keine Datenpunkte mehr aktualisiert.
                      Hier das Log, ab 9:12 wurden keine Daten mehr aktualisiert. Nach einem Neustart des Adapters läuft das ganze wieder für eine Stunde
                      psa.0
                      2021-06-28 09:22:57.899	error	Get device status failed
                      psa.0
                      2021-06-28 09:22:57.897	error	{"httpCode":"401","httpMessage":"Unauthorized","moreInformation":"Token is not active"}
                      psa.0
                      2021-06-28 09:22:57.896	error	Get VR7BCZKXCME028557.status failed
                      psa.0
                      2021-06-28 09:22:57.894	error	Error: Request failed with status code 401
                      psa.0
                      2021-06-28 09:17:58.017	error	Get device status failed
                      psa.0
                      2021-06-28 09:17:58.015	error	{"httpCode":"401","httpMessage":"Unauthorized","moreInformation":"Token is not active"}
                      psa.0
                      2021-06-28 09:17:58.013	error	Get VR7BCZKXCME028557.status failed
                      psa.0
                      2021-06-28 09:17:58.010	error	Error: Request failed with status code 401
                      psa.0
                      2021-06-28 09:17:57.999	error	Get device status failed
                      psa.0
                      2021-06-28 09:17:57.997	error	{"httpCode":"401","httpMessage":"Unauthorized","moreInformation":"Token is not active"}
                      psa.0
                      2021-06-28 09:17:57.995	error	Get VR7BCZKXCME028557.status failed
                      psa.0
                      2021-06-28 09:17:57.993	error	Error: Request failed with status code 401
                      psa.0
                      2021-06-28 09:17:56.329	error	Refresh token failed
                      psa.0
                      2021-06-28 09:17:56.327	error	{"error":"invalid_client","error_description":"Client authentication failed"}
                      psa.0
                      2021-06-28 09:17:56.326	error	Refreshtoken failed
                      psa.0
                      2021-06-28 09:17:56.311	error	Error: Request failed with status code 401
                      psa.0
                      2021-06-28 08:17:56.930	info	Login successful
                      psa.0
                      2021-06-28 08:17:56.228	info	starting. Version 0.0.5 in /opt/iobroker/node_modules/iobroker.psa, node: v12.22.1, js-controller: 3.3.14
                      host.TestBroker
                      2021-06-28 08:17:51.210	info	instance system.adapter.psa.0 started with pid 8893
                      host.TestBroker
                      2021-06-28 08:17:48.763	info	instance system.adapter.psa.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        @mane444 Eigentlich sollte das erst nach 3h kommen. Ich habe mal auf 1h reduziert und den Fehler abgefangen.
                        Einfach nochmal probieren.
                        Humidor M 2 Replies Last reply Reply Quote 0
                          @tombox die Fehlermeldung von @mane444 habe ich nicht bekommen, aber aktuell gibt es gerade diesen Fehler:
                          psa.0	2021-06-28 16:33:49.432	warn	(20643) {"code":"404","message":"404 Not found"}
                          psa.0	2021-06-28 16:33:49.431	warn	(20643) receive old api failed
                          psa.0	2021-06-28 16:33:49.431	warn	(20643) Error: Request failed with status code 404
                          Die neue API-Abfrage läuft ohne Probleme durch seit heute Morgen.
                          • Humidor
                            Humidor @tombox last edited by Humidor
                            @tombox morgen, wie fkt. das mit der "neuen" API ? ist 0.0.6 aktuell?
                            psa.0	2021-06-30 08:04:31.872	error	(394990) Get vehicles failed
                            psa.0	2021-06-30 08:04:31.872	error	(394990) No compatible vehicles found. Maybe your vehicle is too old.
                            psa.0	2021-06-30 08:04:31.871	error	(394990) {"uuid":"1207d474-f6f4-4077-b40b-6f4cd7872349","code":40410,"message":"No vehicule found"}
                            psa.0	2021-06-30 08:04:31.871	error	(394990) Get Vehicles failed
                            psa.0	2021-06-30 08:04:31.871	error	(394990) Error: Request failed with status code 404
                            psa.0	2021-06-30 08:04:31.266	warn	(394990) No Token received for old api
                            psa.0	2021-06-30 08:04:31.265	warn	(394990) {"session":"1cec33b9eeb5a7b64baf4a37acfedca3","returnCode":"NEED_AUTHORIZATION","token":"ffae1e4d78b9ea8b64df43801ef63f3c062923edd725369600f930d4df2fa08e"}
                            psa.0	2021-06-30 08:04:31.265	debug	(394990) {"session":"1cec33b9eeb5a7b64baf4a37acfedca3","returnCode":"NEED_AUTHORIZATION","token":"ffae1e4d78b9ea8b64df43801ef63f3c062923edd725369600f930d4df2fa08e"}
                            psa.0	2021-06-30 08:04:31.023	info	(394990) Login successful
                              tombox @Humidor last edited by
                              @humidor welches Baujahr hast du und in welcher App wird dir dein Fahrzeug angezeigt
                              Humidor 1 Reply Last reply Reply Quote 0
                                @tombox Hi ich hab das heute nochmal mit der neusten Version getestet. Bei läuft das immer genau 1 Stunde dann kommt der Fehler.
                                psa.0
                                2021-06-30 11:39:37.068	error	{"error":"invalid_client","error_description":"Client authentication failed"}
                                psa.0
                                2021-06-30 11:39:37.068	error	Refreshtoken failed
                                psa.0
                                2021-06-30 11:39:37.067	error	Error: Request failed with status code 401
                                psa.0
                                2021-06-30 11:39:36.827	info	Token expired. Try to refresh token
                                psa.0
                                2021-06-30 11:39:36.816	info	Token expired. Try to refresh token
                                psa.0
                                2021-06-30 11:39:36.373	error	Refresh token failed
                                psa.0
                                2021-06-30 11:39:36.373	error	{"error":"invalid_client","error_description":"Client authentication failed"}
                                psa.0
                                2021-06-30 11:39:36.372	error	Refreshtoken failed
                                psa.0
                                2021-06-30 11:39:36.366	error	Error: Request failed with status code 401
                                psa.0
                                2021-06-30 10:39:35.907	info	Login successful
                                psa.0
                                2021-06-30 10:39:35.423	info	starting. Version 0.0.7 in /opt/iobroker/node_modules/iobroker.psa, node: v12.22.1, js-controller: 3.3.14
                                Auto Citroen eC4; HandyApp MYCitroen v.1.29.3
                                Vielleicht hilfts ja bei der Lösung.
                                • Humidor
                                  @tombox BJ 2021, App ? MyPeugeot
                                    @mane444 Danke für den hinweis citroen sollte jetzt gefixt sein
                                      @humidor Ist es auch ein E Auto? Was passiert wenn du dich in der App ausloggst und nochmal einloggst
                                      • Humidor
                                        @tombox nein, ein std. 2008 kein e-2008, dh. nur e gehen? ein Sim hat er mW. es wird ja die Position im App angezeigt.
                                          @humidor die normalen gehen such aber nur Kilometer stand. Aber dein Login geht nicht deswegen mal mit der aktuellen App probieren ob man sich einloggen kann
                                          • Humidor
                                            @tombox Login ist korrekt, mich interessiert nur die Position, dh das fkt nicht?
                                            citroen corsa corsa-e e208 opel peugeot psa
                                            44
                                            334
                                            47467
