    4. Test Adapter Govee v0.0.x
      A Former User @nbuenger last edited by
      @nbuenger
      der Adapter startet, ich kann die Geräte ein-aus schalten, allerdings holt der Adapter keine Werte ab "error 400"
      2021-06-29 07:19:27.233  - info: govee.0 (49232) Command send: {"device":"9B:18:78:9C:E7:08:13:CD","model":"H6104","cmd":{"name":"turn","value":"on"}}
      2021-06-29 07:19:37.502  - error: govee.0 (49232) Error: Request failed with status code 400
      2021-06-29 07:19:37.509  - error: govee.0 (49232) Error: Request failed with status code 400
      2021-06-29 07:19:37.983  - info: govee.0 (49232) Command send: {"device":"9B:18:78:9C:E7:08:13:CD","model":"H6104","cmd":{"name":"brightness","value":100}}
      2021-06-29 07:19:49.298  - error: govee.0 (49232) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-06-29 07:19:49.298  - error: govee.0 (49232) unhandled promise rejection: Cannot read property 'val' of null
      2021-06-29 07:19:49.299  - error: govee.0 (49232) TypeError: Cannot read property 'val' of null
          at Govee.onStateChange (/opt/iobroker/node_modules/iobroker.govee/main.js:240:35)
      2021-06-29 07:19:49.300  - error: govee.0 (49232) Cannot read property 'val' of null
      2021-06-29 07:19:49.303  - info: govee.0 (49232) terminating
      2021-06-29 07:19:49.304  - warn: govee.0 (49232) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2021-06-29 07:19:50.410  - error: host.VMC123-iobroker instance system.adapter.govee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2021-06-29 07:19:50.411  - info: host.VMC123-iobroker Restart adapter system.adapter.govee.0 because enabled
      2021-06-29 07:20:20.501  - info: host.VMC123-iobroker instance system.adapter.govee.0 started with pid 30166
      2021-06-29 07:20:22.427  - info: govee.0 (30166) starting. Version 0.0.4 in /opt/iobroker/node_modules/iobroker.govee, node: v14.17.1, js-controller: 3.3.14
      2021-06-29 07:20:22.453  - warn: govee.0 (30166) Expert log disabled
      2021-06-29 07:20:22.455  - info: govee.0 (30166) Govee API Key: verratichnicht
      2021-06-29 07:20:22.950  - info: govee.0 (30166) Govee Startup Routine finished
      2021-06-29 07:20:23.061  - info: govee.0 (30166) check user admin pw iobroker: false,system.user.admin
      2021-06-29 07:20:23.066  - info: govee.0 (30166) check group user admin group admin: false
      2021-06-29 07:20:23.360  - error: govee.0 (30166) Error: Request failed with status code 400
      2021-06-29 07:20:23.380  - error: govee.0 (30166) Error: Request failed with status code 400
      2021-06-29 07:20:38.099  - error: govee.0 (30166) Error: Request failed with status code 400
      2021-06-29 07:20:38.156  - error: govee.0 (30166) Error: Request failed with status code 400
      2021-06-29 07:20:49.478  - info: host.VMC123-iobroker stopInstance system.adapter.govee.0 (force=false, process=true)
      2021-06-29 07:20:49.479  - info: host.VMC123-iobroker stopInstance system.adapter.govee.0 send kill signal
      2021-06-29 07:20:49.481  - info: govee.0 (30166) Got terminate signal TERMINATE_YOURSELF
      2021-06-29 07:20:49.482  - info: govee.0 (30166) terminating
      2021-06-29 07:20:49.482  - info: govee.0 (30166) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-06-29 07:20:50.520  - info: host.VMC123-iobroker instance system.adapter.govee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-06-29 07:20:53.012  - info: host.VMC123-iobroker instance system.adapter.govee.0 started with pid 30484
      2021-06-29 07:20:53.776  - info: govee.0 (30484) starting. Version 0.0.4 in /opt/iobroker/node_modules/iobroker.govee, node: v14.17.1, js-controller: 3.3.14
      2021-06-29 07:20:53.826  - info: govee.0 (30484) Expert log enabled
      2021-06-29 07:20:53.827  - info: govee.0 (30484) Refresh interval set to: 15 seceonds
      2021-06-29 07:20:53.827  - info: govee.0 (30484) Govee API Key: auchhiernicht
      2021-06-29 07:20:54.454  - info: govee.0 (30484) Request send: get device list
      2021-06-29 07:20:54.455  - info: govee.0 (30484) Server Response: 200 (OK)
      2021-06-29 07:20:54.456  - info: govee.0 (30484) Found (2) Devices
      2021-06-29 07:20:54.457  - info: govee.0 (30484) Select Device: 9B:18:78:9C:E7:08:13:CD
      2021-06-29 07:20:54.458  - info: govee.0 (30484) Device: 9B:18:78:9C:E7:08:13:CD is controllable
      2021-06-29 07:20:54.460  - info: govee.0 (30484) Device: 9B:18:78:9C:E7:08:13:CD created
      2021-06-29 07:20:54.461  - info: govee.0 (30484) object "model" for: 9B:18:78:9C:E7:08:13:CD created
      2021-06-29 07:20:54.463  - info: govee.0 (30484) Device: 9B:18:78:9C:E7:08:13:CD supports cmd "powerState"
      2021-06-29 07:20:54.463  - info: govee.0 (30484) object "powerState" for: 9B:18:78:9C:E7:08:13:CD created
      2021-06-29 07:20:54.464  - info: govee.0 (30484) Device: 9B:18:78:9C:E7:08:13:CD supports cmd "brightness"
      2021-06-29 07:20:54.464  - info: govee.0 (30484) object "brightness" for: 9B:18:78:9C:E7:08:13:CD created
      2021-06-29 07:20:54.465  - info: govee.0 (30484) Device: 9B:18:78:9C:E7:08:13:CD supports cmd "color"
      2021-06-29 07:20:54.465  - info: govee.0 (30484) object "color" for: 9B:18:78:9C:E7:08:13:CD created
      2021-06-29 07:20:54.466  - info: govee.0 (30484) object "color.rgb" for: 9B:18:78:9C:E7:08:13:CD created
      2021-06-29 07:20:54.466  - info: govee.0 (30484) object "color.red" for: 9B:18:78:9C:E7:08:13:CD created
      2021-06-29 07:20:54.467  - info: govee.0 (30484) object "color.green" for: 9B:18:78:9C:E7:08:13:CD created
      2021-06-29 07:20:54.467  - info: govee.0 (30484) object "color.blue" for: 9B:18:78:9C:E7:08:13:CD created
      2021-06-29 07:20:54.468  - info: govee.0 (30484) object "color.hsv" for: 9B:18:78:9C:E7:08:13:CD created
      2021-06-29 07:20:54.468  - info: govee.0 (30484) object "color.hue" for: 9B:18:78:9C:E7:08:13:CD created
      2021-06-29 07:20:54.469  - info: govee.0 (30484) object "color.saturation" for: 9B:18:78:9C:E7:08:13:CD created
      2021-06-29 07:20:54.469  - info: govee.0 (30484) object "color.value" for: 9B:18:78:9C:E7:08:13:CD created
      2021-06-29 07:20:54.470  - info: govee.0 (30484) object "color.hex" for: 9B:18:78:9C:E7:08:13:CD created
      2021-06-29 07:20:54.470  - info: govee.0 (30484) Device: 9B:18:78:9C:E7:08:13:CD supports cmd "colorTem"
      2021-06-29 07:20:54.471  - info: govee.0 (30484) object "colorTem" for: 9B:18:78:9C:E7:08:13:CD created
      2021-06-29 07:20:54.471  - info: govee.0 (30484) object "colorTemMod" for: 9B:18:78:9C:E7:08:13:CD created
      2021-06-29 07:20:54.472  - info: govee.0 (30484) Device "9B:18:78:9C:E7:08:13:CD" was created.
      2021-06-29 07:20:54.473  - info: govee.0 (30484) Select Device: 99:63:78:9C:E7:0D:1D:74
      2021-06-29 07:20:54.473  - info: govee.0 (30484) Device: 99:63:78:9C:E7:0D:1D:74 is controllable
      2021-06-29 07:20:54.473  - info: govee.0 (30484) Device: 99:63:78:9C:E7:0D:1D:74 created
      2021-06-29 07:20:54.474  - info: govee.0 (30484) object "model" for: 99:63:78:9C:E7:0D:1D:74 created
      2021-06-29 07:20:54.474  - info: govee.0 (30484) Device: 99:63:78:9C:E7:0D:1D:74 supports cmd "powerState"
      2021-06-29 07:20:54.475  - info: govee.0 (30484) object "powerState" for: 99:63:78:9C:E7:0D:1D:74 created
      2021-06-29 07:20:54.475  - info: govee.0 (30484) Device: 99:63:78:9C:E7:0D:1D:74 supports cmd "brightness"
      2021-06-29 07:20:54.476  - info: govee.0 (30484) object "brightness" for: 99:63:78:9C:E7:0D:1D:74 created
      2021-06-29 07:20:54.476  - info: govee.0 (30484) Device: 99:63:78:9C:E7:0D:1D:74 supports cmd "color"
      2021-06-29 07:20:54.476  - info: govee.0 (30484) object "color" for: 99:63:78:9C:E7:0D:1D:74 created
      2021-06-29 07:20:54.477  - info: govee.0 (30484) object "color.rgb" for: 99:63:78:9C:E7:0D:1D:74 created
      2021-06-29 07:20:54.477  - info: govee.0 (30484) object "color.red" for: 99:63:78:9C:E7:0D:1D:74 created
      2021-06-29 07:20:54.478  - info: govee.0 (30484) object "color.green" for: 99:63:78:9C:E7:0D:1D:74 created
      2021-06-29 07:20:54.479  - info: govee.0 (30484) object "color.blue" for: 99:63:78:9C:E7:0D:1D:74 created
      2021-06-29 07:20:54.479  - info: govee.0 (30484) object "color.hsv" for: 99:63:78:9C:E7:0D:1D:74 created
      2021-06-29 07:20:54.480  - info: govee.0 (30484) object "color.hue" for: 99:63:78:9C:E7:0D:1D:74 created
      2021-06-29 07:20:54.480  - info: govee.0 (30484) object "color.saturation" for: 99:63:78:9C:E7:0D:1D:74 created
      2021-06-29 07:20:54.482  - info: govee.0 (30484) object "color.value" for: 99:63:78:9C:E7:0D:1D:74 created
      2021-06-29 07:20:54.482  - info: govee.0 (30484) object "color.hex" for: 99:63:78:9C:E7:0D:1D:74 created
      2021-06-29 07:20:54.482  - info: govee.0 (30484) Device: 99:63:78:9C:E7:0D:1D:74 supports cmd "colorTem"
      2021-06-29 07:20:54.483  - info: govee.0 (30484) object "colorTem" for: 99:63:78:9C:E7:0D:1D:74 created
      2021-06-29 07:20:54.484  - info: govee.0 (30484) object "colorTemMod" for: 99:63:78:9C:E7:0D:1D:74 created
      2021-06-29 07:20:54.484  - info: govee.0 (30484) Device "99:63:78:9C:E7:0D:1D:74" was created.
      2021-06-29 07:20:54.485  - info: govee.0 (30484) Govee Startup Routine finished
      2021-06-29 07:20:54.630  - info: govee.0 (30484) check user admin pw iobroker: false,system.user.admin
      2021-06-29 07:20:54.635  - info: govee.0 (30484) check group user admin group admin: false
      2021-06-29 07:20:54.804  - error: govee.0 (30484) Error: Request failed with status code 400
      2021-06-29 07:20:54.821  - error: govee.0 (30484) Error: Request failed with status code 400
      2021-06-29 07:21:06.199  - info: host.VMC123-iobroker stopInstance system.adapter.govee.0 (force=false, process=true)
      2021-06-29 07:21:06.202  - info: govee.0 (30484) Got terminate signal TERMINATE_YOURSELF
      2021-06-29 07:21:06.207  - info: host.VMC123-iobroker stopInstance system.adapter.govee.0 send kill signal
      2021-06-29 07:21:06.203  - info: govee.0 (30484) terminating
      2021-06-29 07:21:06.204  - info: govee.0 (30484) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-06-29 07:21:07.061  - info: host.VMC123-iobroker instance system.adapter.govee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-06-29 07:21:09.629  - info: host.VMC123-iobroker instance system.adapter.govee.0 started with pid 30793
      2021-06-29 07:21:10.155  - debug: govee.0 (30793) Redis Objects: Use Redis connection: 127.0.0.1:6379
      2021-06-29 07:21:10.197  - debug: govee.0 (30793) Objects client ready ... initialize now
      2021-06-29 07:21:10.199  - debug: govee.0 (30793) Objects create System PubSub Client
      2021-06-29 07:21:10.200  - debug: govee.0 (30793) Objects create User PubSub Client
      2021-06-29 07:21:10.201  - debug: govee.0 (30793) Objects client initialize lua scripts
      2021-06-29 07:21:10.222  - debug: govee.0 (30793) Objects connected to redis: 127.0.0.1:6379
      2021-06-29 07:21:10.234  - debug: govee.0 (30793) objectDB connected
      2021-06-29 07:21:10.237  - debug: govee.0 (30793) Redis States: Use Redis connection: 127.0.0.1:6379
      2021-06-29 07:21:10.244  - debug: govee.0 (30793) States create System PubSub Client
      2021-06-29 07:21:10.245  - debug: govee.0 (30793) States create User PubSub Client
      2021-06-29 07:21:10.251  - debug: govee.0 (30793) States connected to redis: 127.0.0.1:6379
      2021-06-29 07:21:10.252  - debug: govee.0 (30793) statesDB connected
      2021-06-29 07:21:10.394  - info: govee.0 (30793) starting. Version 0.0.4 in /opt/iobroker/node_modules/iobroker.govee, node: v14.17.1, js-controller: 3.3.14
      2021-06-29 07:21:10.418  - info: govee.0 (30793) Expert log enabled
      2021-06-29 07:21:10.419  - info: govee.0 (30793) Refresh interval set to: 15 seceonds
      2021-06-29 07:21:10.420  - info: govee.0 (30793) Govee API Key: daauchnet
      2021-06-29 07:21:10.909  - info: govee.0 (30793) check user admin pw iobroker: false,system.user.admin
      2021-06-29 07:21:10.913  - info: govee.0 (30793) check group user admin group admin: false
      2021-06-29 07:21:10.925  - info: govee.0 (30793) Request send: get device list
      2021-06-29 07:21:10.925  - info: govee.0 (30793) Server Response: 200 (OK)
      2021-06-29 07:21:10.926  - info: govee.0 (30793) Found (2) Devices
      2021-06-29 07:21:10.926  - info: govee.0 (30793) Select Device: 9B:18:78:9C:E7:08:13:CD
      2021-06-29 07:21:10.927  - info: govee.0 (30793) Device: 9B:18:78:9C:E7:08:13:CD is controllable
      2021-06-29 07:21:10.927  - info: govee.0 (30793) Device: 9B:18:78:9C:E7:08:13:CD created
      2021-06-29 07:21:10.928  - info: govee.0 (30793) object "model" for: 9B:18:78:9C:E7:08:13:CD created
      2021-06-29 07:21:10.929  - info: govee.0 (30793) Device: 9B:18:78:9C:E7:08:13:CD supports cmd "powerState"
      2021-06-29 07:21:10.929  - info: govee.0 (30793) object "powerState" for: 9B:18:78:9C:E7:08:13:CD created
      2021-06-29 07:21:10.929  - info: govee.0 (30793) Device: 9B:18:78:9C:E7:08:13:CD supports cmd "brightness"
      2021-06-29 07:21:10.929  - info: govee.0 (30793) object "brightness" for: 9B:18:78:9C:E7:08:13:CD created
      2021-06-29 07:21:10.930  - info: govee.0 (30793) Device: 9B:18:78:9C:E7:08:13:CD supports cmd "color"
      2021-06-29 07:21:10.930  - info: govee.0 (30793) object "color" for: 9B:18:78:9C:E7:08:13:CD created
      2021-06-29 07:21:10.930  - info: govee.0 (30793) object "color.rgb" for: 9B:18:78:9C:E7:08:13:CD created
      2021-06-29 07:21:10.930  - info: govee.0 (30793) object "color.red" for: 9B:18:78:9C:E7:08:13:CD created
      2021-06-29 07:21:10.930  - info: govee.0 (30793) object "color.green" for: 9B:18:78:9C:E7:08:13:CD created
      2021-06-29 07:21:10.931  - info: govee.0 (30793) object "color.blue" for: 9B:18:78:9C:E7:08:13:CD created
      2021-06-29 07:21:10.931  - info: govee.0 (30793) object "color.hsv" for: 9B:18:78:9C:E7:08:13:CD created
      2021-06-29 07:21:10.931  - info: govee.0 (30793) object "color.hue" for: 9B:18:78:9C:E7:08:13:CD created
      2021-06-29 07:21:10.931  - info: govee.0 (30793) object "color.saturation" for: 9B:18:78:9C:E7:08:13:CD created
      2021-06-29 07:21:10.932  - info: govee.0 (30793) object "color.value" for: 9B:18:78:9C:E7:08:13:CD created
      2021-06-29 07:21:10.932  - info: govee.0 (30793) object "color.hex" for: 9B:18:78:9C:E7:08:13:CD created
      2021-06-29 07:21:10.932  - info: govee.0 (30793) Device: 9B:18:78:9C:E7:08:13:CD supports cmd "colorTem"
      2021-06-29 07:21:10.932  - info: govee.0 (30793) object "colorTem" for: 9B:18:78:9C:E7:08:13:CD created
      2021-06-29 07:21:10.932  - info: govee.0 (30793) object "colorTemMod" for: 9B:18:78:9C:E7:08:13:CD created
      2021-06-29 07:21:10.933  - info: govee.0 (30793) Device "9B:18:78:9C:E7:08:13:CD" was created.
      2021-06-29 07:21:10.933  - info: govee.0 (30793) Select Device: 99:63:78:9C:E7:0D:1D:74
      2021-06-29 07:21:10.936  - info: govee.0 (30793) Device: 99:63:78:9C:E7:0D:1D:74 is controllable
      2021-06-29 07:21:10.936  - info: govee.0 (30793) Device: 99:63:78:9C:E7:0D:1D:74 created
      2021-06-29 07:21:10.936  - info: govee.0 (30793) object "model" for: 99:63:78:9C:E7:0D:1D:74 created
      2021-06-29 07:21:10.936  - info: govee.0 (30793) Device: 99:63:78:9C:E7:0D:1D:74 supports cmd "powerState"
      2021-06-29 07:21:10.937  - info: govee.0 (30793) object "powerState" for: 99:63:78:9C:E7:0D:1D:74 created
      2021-06-29 07:21:10.937  - info: govee.0 (30793) Device: 99:63:78:9C:E7:0D:1D:74 supports cmd "brightness"
      2021-06-29 07:21:10.937  - info: govee.0 (30793) object "brightness" for: 99:63:78:9C:E7:0D:1D:74 created
      2021-06-29 07:21:10.937  - info: govee.0 (30793) Device: 99:63:78:9C:E7:0D:1D:74 supports cmd "color"
      2021-06-29 07:21:10.937  - info: govee.0 (30793) object "color" for: 99:63:78:9C:E7:0D:1D:74 created
      2021-06-29 07:21:10.938  - info: govee.0 (30793) object "color.rgb" for: 99:63:78:9C:E7:0D:1D:74 created
      2021-06-29 07:21:10.938  - info: govee.0 (30793) object "color.red" for: 99:63:78:9C:E7:0D:1D:74 created
      2021-06-29 07:21:10.938  - info: govee.0 (30793) object "color.green" for: 99:63:78:9C:E7:0D:1D:74 created
      2021-06-29 07:21:10.938  - info: govee.0 (30793) object "color.blue" for: 99:63:78:9C:E7:0D:1D:74 created
      2021-06-29 07:21:10.938  - info: govee.0 (30793) object "color.hsv" for: 99:63:78:9C:E7:0D:1D:74 created
      2021-06-29 07:21:10.939  - info: govee.0 (30793) object "color.hue" for: 99:63:78:9C:E7:0D:1D:74 created
      2021-06-29 07:21:10.939  - info: govee.0 (30793) object "color.saturation" for: 99:63:78:9C:E7:0D:1D:74 created
      2021-06-29 07:21:10.939  - info: govee.0 (30793) object "color.value" for: 99:63:78:9C:E7:0D:1D:74 created
      2021-06-29 07:21:10.939  - info: govee.0 (30793) object "color.hex" for: 99:63:78:9C:E7:0D:1D:74 created
      2021-06-29 07:21:10.939  - info: govee.0 (30793) Device: 99:63:78:9C:E7:0D:1D:74 supports cmd "colorTem"
      2021-06-29 07:21:10.939  - info: govee.0 (30793) object "colorTem" for: 99:63:78:9C:E7:0D:1D:74 created
      2021-06-29 07:21:10.940  - info: govee.0 (30793) object "colorTemMod" for: 99:63:78:9C:E7:0D:1D:74 created
      2021-06-29 07:21:10.940  - info: govee.0 (30793) Device "99:63:78:9C:E7:0D:1D:74" was created.
      2021-06-29 07:21:10.940  - info: govee.0 (30793) Govee Startup Routine finished
      2021-06-29 07:21:11.291  - error: govee.0 (30793) Error: Request failed with status code 400
      2021-06-29 07:21:11.433  - error: govee.0 (30793) Error: Request failed with status code 400
      2021-06-29 07:21:25.710  - info: govee.0 (30793) Function: get current device info by API
      2021-06-29 07:21:25.710  - info: govee.0 (30793) Request send: get device list
      2021-06-29 07:21:25.711  - info: govee.0 (30793) Server Response: 200 (OK)
      2021-06-29 07:21:26.043  - error: govee.0 (30793) Error: Request failed with status code 400
      2021-06-29 07:21:26.047  - error: govee.0 (30793) Error: Request failed with status code 400
      2021-06-29 07:21:40.723  - info: govee.0 (30793) Function: get current device info by API
      2021-06-29 07:21:40.724  - info: govee.0 (30793) Request send: get device list
      2021-06-29 07:21:40.725  - info: govee.0 (30793) Server Response: 200 (OK)
      2021-06-29 07:21:41.030  - error: govee.0 (30793) Error: Request failed with status code 400
      2021-06-29 07:21:41.032  - error: govee.0 (30793) Error: Request failed with status code 400
      2021-06-29 07:21:55.725  - info: govee.0 (30793) Function: get current device info by API
      2021-06-29 07:21:55.726  - info: govee.0 (30793) Request send: get device list
      2021-06-29 07:21:55.726  - info: govee.0 (30793) Server Response: 200 (OK)
      2021-06-29 07:21:56.030  - error: govee.0 (30793) Error: Request failed with status code 400
      2021-06-29 07:21:56.041  - error: govee.0 (30793) Error: Request failed with status code 400
      2021-06-29 07:22:10.729  - info: govee.0 (30793) Function: get current device info by API
      2021-06-29 07:22:10.729  - info: govee.0 (30793) Request send: get device list
      2021-06-29 07:22:10.730  - info: govee.0 (30793) Server Response: 200 (OK)
      2021-06-29 07:22:11.038  - error: govee.0 (30793) Error: Request failed with status code 400
      2021-06-29 07:22:11.040  - error: govee.0 (30793) Error: Request failed with status code 400
      2021-06-29 07:22:25.736  - info: govee.0 (30793) Function: get current device info by API
      2021-06-29 07:22:25.736  - info: govee.0 (30793) Request send: get device list
      2021-06-29 07:22:25.737  - info: govee.0 (30793) Server Response: 200 (OK)
      2021-06-29 07:22:26.028  - error: govee.0 (30793) Error: Request failed with status code 400
      2021-06-29 07:22:26.030  - error: govee.0 (30793) Error: Request failed with status code 400
      2021-06-29 07:22:40.728  - info: govee.0 (30793) Function: get current device info by API
      2021-06-29 07:22:40.729  - info: govee.0 (30793) Request send: get device list
      2021-06-29 07:22:40.729  - info: govee.0 (30793) Server Response: 200 (OK)
      2021-06-29 07:22:41.030  - error: govee.0 (30793) Error: Request failed with status code 400
      2021-06-29 07:22:41.047  - error: govee.0 (30793) Error: Request failed with status code 400
      2021-06-29 07:22:55.731  - info: govee.0 (30793) Function: get current device info by API
      2021-06-29 07:22:55.732  - info: govee.0 (30793) Request send: get device list
      2021-06-29 07:22:55.732  - info: govee.0 (30793) Server Response: 200 (OK)
      2021-06-29 07:22:56.035  - error: govee.0 (30793) Error: Request failed with status code 400
      2021-06-29 07:22:56.047  - error: govee.0 (30793) Error: Request failed with status code 400
      2021-06-29 07:23:10.825  - info: govee.0 (30793) Function: get current device info by API
      2021-06-29 07:23:10.826  - info: govee.0 (30793) Request send: get device list
      2021-06-29 07:23:10.826  - info: govee.0 (30793) Server Response: 200 (OK)
      2021-06-29 07:23:11.246  - error: govee.0 (30793) Error: Request failed with status code 400
      2021-06-29 07:23:11.398  - error: govee.0 (30793) Error: Request failed with status code 400
      2021-06-29 07:23:25.731  - info: govee.0 (30793) Function: get current device info by API
      2021-06-29 07:23:25.732  - info: govee.0 (30793) Request send: get device list
      2021-06-29 07:23:25.733  - info: govee.0 (30793) Server Response: 200 (OK)
      2021-06-29 07:23:26.031  - error: govee.0 (30793) Error: Request failed with status code 400
      2021-06-29 07:23:26.039  - error: govee.0 (30793) Error: Request failed with status code 400
      2021-06-29 07:23:40.722  - info: govee.0 (30793) Function: get current device info by API
      2021-06-29 07:23:40.723  - info: govee.0 (30793) Request send: get device list
      2021-06-29 07:23:40.723  - info: govee.0 (30793) Server Response: 200 (OK)
      2021-06-29 07:23:41.032  - error: govee.0 (30793) Error: Request failed with status code 400
      2021-06-29 07:23:41.046  - error: govee.0 (30793) Error: Request failed with status code 400
      2021-06-29 07:23:55.712  - info: govee.0 (30793) Function: get current device info by API
      2021-06-29 07:23:55.713  - info: govee.0 (30793) Request send: get device list
      2021-06-29 07:23:55.713  - info: govee.0 (30793) Server Response: 200 (OK)
      nbuenger 1 Reply Last reply Reply Quote 0
      • nbuenger
        nbuenger Developer @Guest last edited by
        @ilovegym Moin, Ich danke dir für die Info. Der Fehler 400 ist bisher bei anderen und mir nicht aufgetreten. Ich schaue mir nachher wenn ich von der Arbeit nach Hause komme mal genau an was bei dir im log steht. Den API Key nehme ich an hast du nachträglich aus dem Log gelöscht also im Betrieb wirst du ihn mit Sicherheit eingetragen haben👍 . Funktionieren denn alle anderen Dinge auch wie Helligkeit und Farbe?
        Gruß Nick
        ? M 2 Replies Last reply Reply Quote -1
          @nbuenger
          guten Morgen,
          ja, ist raus. Mir ist das hier aufgefallen, mein user Admin hat kein Passwort iobroker.. 😉
          braucht er das hier?
          Nein, die Helligkeit und Farben funktionieren nicht. Nur an/aus.
          • nbuenger
            nbuenger Developer @Guest last edited by nbuenger
            @ilovegym
            Dir auch einen guten Morgen,
            magst du mir mal ein Screenshot von deiner Objekt Übersicht machen. Denn im log sehe ich das bei dir ein Objekt null zurück gibt. Ich brauche eigentlich auch nur die Values sehen die IDS sind nicht wichtig.
            Wir finden auf jeden Fall dein Problem.
            Und ein Passwort braucht der Benutzer nicht. Habe auch keins.
              Michi_Pi @nbuenger last edited by
              Hey @nbuenger, vielen Dank dass du dir Zeit genommen hast, dafür einen Adapter zu entwickeln. Freut mich.
              Ich habe ihn installiert und es hat auf anhieb alles problemlos funktioniert. Gerät wurde sofort gefunden und eingebunden. Ich habe bisher nur das Model H6163, Grund war natürlich die fehlende Anbindung zu ioBroker.
              Nun zur Funktion. Ich habe mal alles durchprobiert und funktioniert auch alles. Allerdings ist mir aufgefallen, dass bei den Werten ColorTem und ColorTemMod, der geänderte Wert nicht gehalten wird.
              Sprich wenn ich z.b. auf 4500 ändere (die Änderung findet auch statt) bleibt das für 1-2 Sekunden und springt dann wieder auf 5500 zurück, jedoch ohne Änderung.
              Auszug aus dem LOG
              govee.0	2021-06-29 09:12:27.774	info	(4154) Server Response: 200 (OK)
              govee.0	2021-06-29 09:12:27.774	info	(4154) Request send: get device info (90:5F:A4:C1:38:38:16:6B)
              govee.0	2021-06-29 09:12:27.415	info	(4154) Server Response: 200 (OK)
              govee.0	2021-06-29 09:12:27.415	info	(4154) Request send: get device list
              govee.0	2021-06-29 09:12:27.415	info	(4154) Function: get current device info by API
              govee.0	2021-06-29 09:11:43.604	info	(4154) Server Response: 200 (OK)
              govee.0	2021-06-29 09:11:43.202	info	(4154) Command send: {"device":"90:5F:A4:C1:38:38:16:6B","model":"H6163","cmd":{"name":"colorTem","value":4500}}
              govee.0	2021-06-29 09:11:27.699	info	(4154) Values for object: 90:5F:A4:C1:38:38:16:6B updated
              • nbuenger
                nbuenger Developer @Michi_Pi last edited by
                @michi_pi Moin, freut mich sehr das du auf dazu gestoßen bist. Und danke für die netten Worte😌
                Freut mich soweit das alles bei dir funktioniert. Das mit dem colorTem hat ein anderer auch gehabt. Bei mir ist das bisher noch nicht aufgetreten. Wie hoch hast du denn den refreshInterval eingestellt. Denn die API braucht etwas Zeit bis die neuen Daten hinterlegt wurden. Daher habe ich ein Minimum von 5 Sekunden festgelegt bevor die neuen Werte von der API abgerufen werden.
                Gruß Nick
                  @nbuenger
                  Da kommt nix von der API zurück..
                  Wenn ich etwas per Hand eintrage, ändert sich nichts.
                  Nur PowerState funktioniert mit true-false.
                    @nbuenger Gern geschehen 😄
                    Hatte zuvor 60 Sekunden bin dann mal auf 10 Sekunden runter gegangen.
                    Ich habe auch die Aktualisierung abgewartet, allerdings bleibt dieser "Pseudowert" (5500) stehen.
                    Die anderen Datenpunkte werden gleich geändert und verändern sich auch nicht mehr.
                    nbuenger 2 Replies Last reply Reply Quote 0
                    • nbuenger
                      @ilovegym okay genau das habe ich mir auch gedacht das bei dir keine Werte hinterlegt werden. Es ist bei der API so das die Geräte einen „retrievable“ Wert haben. Dieser kann True oder False haben. Wenn dieser Wert False zurück gibt dann kann die API keine Werte für dein Gerät bereitstellen. Wenn ich zu Hause bin werde ich ein Objekt anlegen was den „retrievable“ anzeigt. Möglicherweise unterstützt dein Modell diesen Support nicht. Aber das finde. Wir schon raus.
                      • nbuenger
                        nbuenger Developer @Michi_Pi last edited by nbuenger
                        @michi_pi okay dann schaue ich mir mal an wenn ich zu Hause bin wieso dieser Wert resetet wird. Möglicherweise habe ich einen Fehler in der Schleife
                        • nbuenger
                          nbuenger Developer last edited by
                          So ich habe mal ein sehr kleines Tool gebastelt mit den man die Werte aus der API auslesen kann. Ich habe mir jetzt keine mühe für das Design gegeben, sondern nur die Funktion implementiert.
                          Hier könnt ihr euch das Tool ansehen und schauen ob eure Geräte unterstützt werden. Ich werde dieses Tool auch weiter ausbauen damit die Fehlersuche einfacher wird.
                          @ilovegym sag mir mal bitte wenn du das Tool benutzt was bei dir raus kommt besonders der "retrievable" Wert interessiert mich bei dir besonders.
                          Alle weiteren Änderungen kommen die Tage. Schönen Abend euch noch allen.
                          (WICHTIG: Das Tool läuft im Browser ihr müsst also nichts herunterladen und die Website und die Domain sind auch meine eigene ihr braucht da keine sorgen zu haben irgendwelche dubiosen Seiten besuchen zu müssen.)
                          • nbuenger
                            @michi_pi Ich habe möglicherweise das Problem wegen dem ColorTemp gefunden. Ich hoffe ich komme morgen dazu das zu beheben wenn ich es schaffe gibt es morgen für euch ein Update sonst ein paar Tage später😊 .
                              @nbuenger
                              guten Morgen,
                              super, gute Idee!
                              Hier der output der API:
                                "device": "9B:18:78:9C:E7:08:13:CD",
                                "model": "H6104",
                                "deviceName": "TV Ambiente Wohnzimmer",
                                "controllable": true,
                                "retrievable": false,
                                "supportCmds": [
                                  "turn",
                                  "brightness",
                                  "color",
                                  "colorTem"
                                "properties": {
                                  "colorTem": {
                                    "range": {
                                      "min": 2000,
                                      "max": 9000
                                "device": "99:63:78:9C:E7:0D:1D:74",
                                "model": "H6104",
                                "deviceName": "TV Ambiente Schlafzimm",
                                "supportCmds": [
                                  "turn",
                                  "brightness",
                                  "color",
                                  "colorTem"
                                "properties": {
                                  "colorTem": {
                                    "range": {
                                      "min": 2000,
                                      "max": 9000
                              • nbuenger
                                @ilovegym Moin. Genau das habe ich mir gedacht. Dein Modell unterstüzt leider nicht das der Status übermittelt wird. Nur die Steuerung geht. Das war aber mein Fehler ich habe nur geprüft ob man die Geräte steuern kann aber nicht ob sie überhaupt senden können😓
                                Ich werde das aber sobald wie möglich fixen und dann die Steuerung für die Geräte dementsprechend anpassen. Du kannst deine Leisten zwar über die API steuern. Aber sie gibt keine Werte zurück.
                                  @nbuenger
                                  ahhh ja, wahrscheinlich weil das die Ambiente-LEDs sind...
                                  retrievable=false
                                  • nbuenger
                                    @ilovegym das ist möglich. Aber ich werde im nächsten Update gucken das die Geräte auch steuerbar sind. Nur die Werte werden halt nicht aktualisiert. Das ist schade das das Modell von der API nicht komplett unterstützt wird. Tut mir leid😞
                                      DocGame @nbuenger last edited by
                                      @nbuenger
                                      Hallo..
                                      zuerst einmal vielen Dank für die Mühe, die du dir gemacht hast.
                                      Ich habe im Moment nur ein Govee-Gerät (H6104). Das sins die Stripes mit Kamera für den Fernseher. Leider will er die scheinbar nicht.
                                      Hier einige Infos:
                                      govee.0	2021-06-30 17:37:32.802	error	(1612) Error: Request failed with status code 400
                                      govee.0	2021-06-30 17:37:32.484	info	(1612) Server Response: 200 (OK)
                                      govee.0	2021-06-30 17:37:32.484	info	(1612) Request send: get device list
                                      govee.0	2021-06-30 17:37:32.483	info	(1612) Function: get current device info by API
                                      govee.0	2021-06-30 17:37:22.683	error	(1612) Error: Request failed with status code 400
                                      govee.0	2021-06-30 17:37:22.351	info	(1612) Server Response: 200 (OK)
                                      govee.0	2021-06-30 17:37:22.351	info	(1612) Request send: get device list
                                      govee.0	2021-06-30 17:37:22.351	info	(1612) Function: get current device info by API
                                      govee.0	2021-06-30 17:37:12.815	error	(1612) Error: Request failed with status code 400
                                      govee.0	2021-06-30 17:37:12.490	warn	(1612) State "govee.0.B6:3C:78:9C:E7:07:46:AB.model" has no existing object, this might lead to an error in future versions
                                      govee.0	2021-06-30 17:37:12.486	info	(1612) Govee Startup Routine finished
                                      govee.0	2021-06-30 17:37:12.486	info	(1612) Device "B6:3C:78:9C:E7:07:46:AB" was created.
                                      govee.0	2021-06-30 17:37:12.486	info	(1612) object "colorTemMod" for: B6:3C:78:9C:E7:07:46:AB created
                                      govee.0	2021-06-30 17:37:12.486	info	(1612) object "colorTem" for: B6:3C:78:9C:E7:07:46:AB created
                                      govee.0	2021-06-30 17:37:12.486	info	(1612) Device: B6:3C:78:9C:E7:07:46:AB supports cmd "colorTem"
                                      govee.0	2021-06-30 17:37:12.486	info	(1612) object "color.hex" for: B6:3C:78:9C:E7:07:46:AB created
                                      govee.0	2021-06-30 17:37:12.485	info	(1612) object "color.value" for: B6:3C:78:9C:E7:07:46:AB created
                                      govee.0	2021-06-30 17:37:12.485	info	(1612) object "color.saturation" for: B6:3C:78:9C:E7:07:46:AB created
                                      govee.0	2021-06-30 17:37:12.485	info	(1612) object "color.hue" for: B6:3C:78:9C:E7:07:46:AB created
                                      govee.0	2021-06-30 17:37:12.485	info	(1612) object "color.hsv" for: B6:3C:78:9C:E7:07:46:AB created
                                      govee.0	2021-06-30 17:37:12.485	info	(1612) object "color.blue" for: B6:3C:78:9C:E7:07:46:AB created
                                      govee.0	2021-06-30 17:37:12.485	info	(1612) object "color.green" for: B6:3C:78:9C:E7:07:46:AB created
                                      govee.0	2021-06-30 17:37:12.485	info	(1612) object "color.red" for: B6:3C:78:9C:E7:07:46:AB created
                                      govee.0	2021-06-30 17:37:12.485	info	(1612) object "color.rgb" for: B6:3C:78:9C:E7:07:46:AB created
                                      govee.0	2021-06-30 17:37:12.485	info	(1612) object "color" for: B6:3C:78:9C:E7:07:46:AB created
                                      govee.0	2021-06-30 17:37:12.485	info	(1612) Device: B6:3C:78:9C:E7:07:46:AB supports cmd "color"
                                      govee.0	2021-06-30 17:37:12.485	info	(1612) object "brightness" for: B6:3C:78:9C:E7:07:46:AB created
                                      govee.0	2021-06-30 17:37:12.484	info	(1612) Device: B6:3C:78:9C:E7:07:46:AB supports cmd "brightness"
                                      govee.0	2021-06-30 17:37:12.484	info	(1612) object "powerState" for: B6:3C:78:9C:E7:07:46:AB created
                                      govee.0	2021-06-30 17:37:12.484	info	(1612) Device: B6:3C:78:9C:E7:07:46:AB supports cmd "powerState"
                                      govee.0	2021-06-30 17:37:12.484	info	(1612) object "model" for: B6:3C:78:9C:E7:07:46:AB created
                                      govee.0	2021-06-30 17:37:12.484	info	(1612) Device: B6:3C:78:9C:E7:07:46:AB created
                                      govee.0	2021-06-30 17:37:12.483	info	(1612) Device: B6:3C:78:9C:E7:07:46:AB is controllable
                                      govee.0	2021-06-30 17:37:12.483	info	(1612) Select Device: B6:3C:78:9C:E7:07:46:AB
                                      govee.0	2021-06-30 17:37:12.483	info	(1612) Found (1) Devices
                                      govee.0	2021-06-30 17:37:12.483	info	(1612) Server Response: 200 (OK)
                                      govee.0	2021-06-30 17:37:12.482	info	(1612) Request send: get device list
                                      govee.0	2021-06-30 17:37:12.100	info	(1612) check group user admin group admin: false
                                      govee.0	2021-06-30 17:37:12.092	info	(1612) check user admin pw iobroker: true,system.user.admin
                                      govee.0	2021-06-30 17:37:12.031	info	(1612) Govee API Key: c12a43e7-687d-460a-8803-e9f98b59f130
                                      govee.0	2021-06-30 17:37:12.030	info	(1612) Refresh interval set to: 10 seceonds
                                      govee.0	2021-06-30 17:37:12.030	info	(1612) Expert log enabled
                                      govee.0	2021-06-30 17:37:12.023	info	(1612) starting. Version 0.0.4 in /opt/iobroker/node_modules/iobroker.govee, node: v14.17.0, js-controller: 3.3.14
                                      Aus deinem Api-Tool:
                                        "device": "B6:3C:78:9C:E7:07:46:AB",
                                        "model": "H6104",
                                        "deviceName": "Ambristripe",
                                        "supportCmds": [
                                          "turn",
                                          "brightness",
                                          "color",
                                          "colorTem"
                                        "properties": {
                                          "colorTem": {
                                            "range": {
                                              "min": 2000,
                                              "max": 9000
                                      Die Objekte unter deinem Adapter:
                                      Mit dem HAM-Adapter:
                                      • nbuenger
                                        nbuenger Developer @DocGame last edited by
                                        @docgame Moin, freut mich das du auch an Board bist. Ja das ist leider ein Problem von dem Modell es unterstützt zwar die Steuerung aber die API gibt für das Modell keine Werte zurück. Das siehst du im API Output unter dem Punkt „retrievable“ = False. Ich werde aber gucken wie ich die im nächsten Update mit einbinden kann. Dann kann man sie zumindest steuern. Wenn dir noch mehr Punkte auffallen gib mir gerne Bescheid. Schönen Abend dir noch.
                                        • nbuenger
                                          nbuenger Developer last edited by nbuenger
                                          Moin, also ich habe nun leider herausgefunden das der colorTem Wert der von der API asugespukt wird manchmal Fehlerhaft ist.
                                          Wenn ich den Wert über die API auf 5600 einstelle wird dieser in der API auch korrekt angezeigt:
                                          Wenn man den Wert allerdings auf unter oder über 5600 stellt wird der colorTemp Farbton in RGB ausgegeben und daher steht in der API dann das hier:
                                          Und da die API den colorTemp Wert nicht mehr ausspuckt setzt sich der Wert bei euch wieder auf Default bei den meisten wird das 5500 sein.
                                          Ich weiß leider nicht was Govee sich da ausgedacht hat denn wenn ich den Temperatur Wert über die App einstelle steht der auch so in der API (hier als Beispiel 4100):
                                          Ich musste durch diesen Fehler seitens der API die Steuerung für die Temperatur erstmal entfernen. Ich frage da aber bei Govee nach ob dies in Zukunft behoben werden kann. Außerdem habe ich einen "Private Mode" eingebaut. Wenn ihr den einstellt werden alle sensiblen Infos wie der API Key oder die Device IDs unkenntlich gemacht. Ihr könnt dann euren Log gefahrlos posten. Auch an dem Problem mit dem Ambilight TV Stripe arbeite ich, es wird wohl so sein das dieser nur ein und aus geschaltet werden kann zumindest vorerst. Ich hoffe euch das Update morgen hochladen zu können wenn ich bis dahin fertig bin. Ich hoffe ich habe eure Fragen erstmal soweit beantwortet und wünsche euch noch einen schönen Freitag.
                                          EDIT: Kleiner nachtrag. Dieses Problem tritt bisher wohl nur bei dem Model H6159 auf denn bei meiner H6188 steht in der API colorTem bei egal welchem Wert.
                                          • nbuenger
                                            Moin Leute, ich habe nun einiges gefixt, Der Fehler wegen dem ColorTem ist ein Problem der Govee API das habe ich ja im vorigen Post erwähnt. Ich habe das Objekt für das Modell H6159 erstmal entfernt. Wenn dieser Fehler seitens Govee behoben wird kommt er natürlich wieder dazu. Der andere Fehler wegen der H6104 den konnte ich nur soweit in der Theorie beheben da ich dieses Modell nicht habe. Allerdings kann ich dazu nur soviel sagen das ich nur den powerState möglich machen konnte. Außerdem gibt es eine neue Einstellung Ihr könnt nun alle sensiblen Informationen im Log unkenntlich machen. Dazu zählen der API Key und die Device IDs. Ich bin auf euer Feedback gespannt und hoffe das nun einige Fehler beseitigt werden konnten. Das Update bekommt ihr hier.
                                            Ich wünsche euch noch einen angenehmen Tag.
                                            312
                                            68134
