    4. [Vorstellung] Meine dritte VIS
      Kuddel @maximal1981 last edited by
      @maximal1981 meinst du die Anzeige der laufenden Adapter ?
      Hier mein aktuelles Skript (java):
      // Liest die ioBroker Adapter aus und legt verschiedenen State's an.
      schedule('*/10 * * * * *', function (obj) {
      //on({id:"system.adapter.admin.0.uptime",change:'any'}, function (obj) {
         createState('Adapter.Anzahl', 0, { name: 'Anzahl', desc: 'Anzahl der Adapter', type: 'number', unit: '', min: '0', max: '255', role: '',read: true, write: true });
         createState('Adapter.AdapterNummer', 0, { name: 'Adapter zum schalten', desc: 'Adapter zum schalten', type: 'number', unit: '', min: '0', max: '255', role: '',read: true, write: true });
         //var counterAlt = getState("javascript.0.Adapter.Anzahl").val;
         //Variablen zurücksetzen
         var counter =0;
         var on = 0
         var manuell=0
         var cacheSelector = $('[id=system.adapter.*.alive]');
         cacheSelector.each(function(id, i) {
             //Instanzen ausklammer
             var check1 = id.indexOf('system.adapter.coronavirus-statistics.0.alive');
         	var check2 = id.indexOf('system.adapter.daswetter.0.alive');
         	var check3 = id.indexOf('system.adapter.dwd.0.alive');
         	var check4 = id.indexOf('system.adapter.ical.0.alive');
         	var check5 = id.indexOf('system.adapter.ical.1.alive');
         	var check6 = id.indexOf('system.adapter.ical.2.alive');
         	var check7 = id.indexOf('system.adapter.feiertage.0.alive');
         	var check8 = id.indexOf('system.adapter.kodi.0.alive');
         	var check9 = id.indexOf('system.adapter.snmp.1.alive');
             var check10 = id.indexOf('system.adapter.yamaha.0.alive');
         	var check11 = id.indexOf('system.adapter.vis.0.alive');
             var check = check1 + check2 + check3 + check4 + check5 + check6 + check7 + check8 + check9 + check10 + check11;
             //Abfrage nur ausführen, wenn Instanz nicht ausgeklammert ist
             if(check == -11){
                 var devicename = getObject(id).common.name;
                 //console.log(devicename);
         		var devicenameName=devicename;
         		var instanzname=getObject(id).common.name;
         		var test = devicenameName;
         		var devicename_array = devicenameName.split(' ');
         		devicenameName = devicename_array[0];
         		counter = counter+1;
         		var strStatePath = "system.adapter." + devicenameName + ".alive";
         		//Uptime
         		var uptime = getState("system.adapter." + devicenameName + ".uptime").val;
         		var tage = Math.floor(uptime / (24*3600));
         		var stunden = Math.floor((uptime % (24*3600))/3600);
         		var minuten = Math.floor((uptime % (3600))/60);
         		if (stunden < 10) {stunden = "0"+stunden};
         		if (minuten < 10) {minuten = "0"+minuten};
         		if (tage == 1) {uptime = tage.toString()+" Tag, "+stunden.toString()+" Std, "+minuten.toString()+" Min ";};
         		if (tage != 1) {uptime = tage.toString()+" Tage, "+stunden.toString()+" Std, "+minuten.toString()+" Min ";}
         		//Arbeitsspeicher etc.
         		//var total = getState("system.adapter." + devicenameName + ".memHeapTotal").val;
         		//var used = getState("system.adapter." + devicenameName + ".memHeapUsed").val;
         		//var rss = getState("system.adapter." + devicenameName + ".memRss").val;
         		//Connection Status
         		var connect = getState("system.adapter." + devicenameName + ".alive").val;
         		if(connect == false){var con = 0;}
         		else {
         			var con = 1;
         			var strStatePath = devicenameName + ".info.connection";
         			if (isState(strStatePath, true)) {
         				var connectS = getState(devicenameName + ".info.connection").val;
         				if (connectS == false) {
         					con = 2;
         		if(con==1) {on = on + 1}
         		devicename="Adapter.Adapter"+counter.toString()+".KompletterNameAdapter";
         		createState(devicename, 'empty', { name: 'Kompletter Name des Adapters', desc: '', type: 'string', role: '',read: true, write: true });
         		setStateDelayed(devicename, devicenameName, 800);
         		var contentstring = devicenameName;
         		var suchstring = /(ical)/g;
         		var suchergebnis = suchstring.test( contentstring );
         		if (suchergebnis != true) {
         			var devicename_array = devicenameName.split('.');
         		if (devicenameName == "daswetter") {
         			var bild = "/" + devicenameName + ".admin/" + devicenameName + "com.png";
         		} else if (suchergebnis != false) {
         			var icalName = devicename_array[0];
         			var bild = "/" + icalName + ".admin/" + icalName + ".png";
         		} else {
         			var bild = "/" + devicenameName + ".admin/" + devicenameName + ".png";
         		// Icon-Pfad definieren //
         		//Alexa2
         		if (devicenameName == 'alexa2') {var bild = "/" + devicenameName + ".admin/" + "alexa.png";}
         		//FritzDECT
         		if (devicenameName == 'fritzdect') {var bild = "/" + devicenameName + ".admin/" + "fritzdect_logo.png";}
         		//FullyBrowser
         		if (devicenameName == 'fullybrowser') {var bild = "/" + devicenameName + ".admin/" + "fully.png";}
         		//HM-Rega
         		//if (devicenameName == 'hm-rega') {var bild = "/" + devicenameName + ".admin/" + "homematic.png";}
         		if (devicenameName == 'hm-rega') {var bild = "/vis.0/VIS/Meine_Icons/Adapter_Icons/homematic.gif";}
         		//HomeMatic
         		//if (instanzname == 'hm-rpc.0 alive') {var bild = "/" + devicenameName + ".admin/" + "homematic.png";}
         		if (instanzname == 'hm-rpc.0 alive') {var bild = "/vis.0/VIS/Meine_Icons/Adapter_Icons/homematic.gif";}
         		//HomeMatic-IP
         		//if (instanzname == 'hm-rpc.1 alive') {var bild = "/" + devicenameName + ".admin/" + "homematic.png";}
         		if (instanzname == 'hm-rpc.1 alive') {var bild = "/vis.0/VIS/Meine_Icons/Adapter_Icons/homematic_ip.jpg";}
                 //Homepilot
                 if (instanzname == 'homepilot20.0 alive') {var bild = "/vis.0/VIS/Meine_Icons/Adapter_Icons/homepilot.png";}
         		//UPNP
         		if (devicenameName == 'upnp') {var bild = "/" + devicenameName + ".admin/" + "upnp-discovery.png";}
         		//Pushover.1
         		if (instanzname == 'pushover.1 alive') {var bild = "/mihome-vacuum.admin/mihome-vacuum.png";}
         		//Pushover.2
         		if (instanzname == 'pushover.2 alive') {var bild = "/daswetter.admin/daswettercom.png";}
         		//AdapterName anpassen
         		//Corona-Statistics
         		if (instanzname == 'coronavirus-statistics.0 alive') {devicenameName='Corona'; manuell=1}
         		//DasWetter
         		if (instanzname == 'daswetter.0 alive') {devicenameName='DasWetter'; manuell=1}
         		//DWD
         		if (instanzname == 'dwd.0 alive') {devicenameName='DWD'; manuell=1}
         		//Fullybrowser
         		if (instanzname == 'fullybrowser.0 alive') {devicenameName='FullyKiosk'; manuell=1}
         		//HM-REGA
         		if (instanzname == 'hm-rega.0 alive') {devicenameName='HM-Rega'; manuell=1}
         		//HM-RPC.0
         		if (instanzname == 'hm-rpc.0 alive') {devicenameName='HomeMatic'; manuell=1}
         		//HM-RPC.1
         		if (instanzname == 'hm-rpc.1 alive') {devicenameName='HM-IP'; manuell=1}
                 //Homepilot
                 if (instanzname == 'homepilot20.0 alive') {devicenameName='Homepilot'; manuell=1}
         		//Linux-Control
         		if (instanzname == 'linux-control.0 alive') {devicenameName='Linux-Ctr.'; manuell=1}
         		//MiHome-Vacuum -> NoNo
         		if (instanzname == 'mihome-vacuum.0 alive') {devicenameName='Nono'; manuell=1}
                 //MiHome-Vacuum -> Dusty
         		if (instanzname == 'mihome-vacuum.1 alive') {devicenameName='Dusty'; manuell=1}
         		//Pushover
         		if (instanzname == 'pushover.0 alive') {devicenameName='Pushover.0'; manuell=1}
         		if (instanzname == 'pushover.1 alive') {devicenameName='Pushover.1'; manuell=1}
         		if (instanzname == 'pushover.2 alive') {devicenameName='Pushover.2'; manuell=1}
         		//Simple-API
         		if (instanzname == 'simple-api.0 alive') {devicenameName='Simple-API'; manuell=1}
         		//SNMP.0
         		if (instanzname == 'snmp.0 alive') {devicenameName='QNAP-B'; manuell=1}
         		//SNMP.1
         		if (instanzname == 'snmp.1 alive') {devicenameName='QNAP-Archiv'; manuell=1}
                 //SNMP.2
         		if (instanzname == 'snmp.2 alive') {devicenameName='Brother'; manuell=1}
         		//Spotify
         		if (instanzname == 'spotify-premium.0 alive') {devicenameName='Spotify'; manuell=1}
         		//Tankerkoenig
         		if (instanzname == 'tankerkoenig.0 alive') {devicenameName='Tankerk.'; manuell=1}
         		//Tashscheduler
         		if (instanzname == 'trashschedule.0 alive') {devicenameName='Trashsched.'; manuell=1}
         		//TR-064.0
         		if (instanzname == 'tr-064.0 alive') {devicenameName='TR-064.0'; manuell=1}
         		//TR-064.1
         		if (instanzname == 'tr-064.1 alive') {devicenameName='TR-064.1'; manuell=1}
         		//XPEnology
         		if (instanzname == 'synology.1 alive') {devicenameName='XPEnology'; manuell=1}
         		//Instanz-Namen setzen
         		if(manuell!=1) {devicenameName = devicenameName.substring(0, 1).toUpperCase() + devicenameName.substring(1).toLowerCase();}
         		//devicenameName = devicenameName.substring(0, 1).toUpperCase() + devicenameName.substring(1).toLowerCase();
         		devicename="Adapter.Adapter"+counter.toString()+".NameInstanz";
         		createState(devicename, 'empty', { name: 'Name des Geräts', desc: '', type: 'string', role: '',read: true, write: true });
         		//Bild Pfad setzen
         		devicename="Adapter.Adapter"+counter.toString()+".Bild";
         		createState(devicename, 'empty', { name: 'Speicherort Bild', desc: '', type: 'string', role: '',read: true, write: true });
         		setStateDelayed(devicename, bild, 800);
         		//Uptime setzen
         		devicename="Adapter.Adapter"+counter.toString()+".Uptime";
         		createState(devicename, 'empty', { name: 'Uptime', desc: '', type: 'string', role: '',read: true, write: true });
         		setStateDelayed(devicename, uptime, 800);
         		//MemUsed setzen
         		//devicename="Adapter.Adapter"+counter.toString()+".MemUsed";
         		//createState(devicename, 0, { name: 'Link MemUsed', desc: '', type: 'number', role: '',read: true, write: true });
         		//setStateDelayed(devicename, used, 800);
         		//MemToal setzen
         		//devicename="Adapter.Adapter"+counter.toString()+".MemTotal";
         		//createState(devicename, 0, { name: 'Link MemTotal', desc: '', type: 'number', role: '',read: true, write: true });
         		//setStateDelayed(devicename, total, 800);
         		//MemRSS setzen
         		//devicename="Adapter.Adapter"+counter.toString()+".MemRSS";
         		//createState(devicename, 0, { name: 'Link MemRSS', desc: '', type: 'number', role: '',read: true, write: true });
         		//setStateDelayed(devicename, rss, 800);
         		//Connected setzen
         		devicename="Adapter.Adapter"+counter.toString()+".Connected";
         		createState(devicename, 0, { name: 'Status Adapter', desc: '', type: 'number', role: '',read: true, write: true });
         		setStateDelayed(devicename, con, 800);
         		//Wert zurücksetzen
         		var manuell=0
         //Adaptet Icon Übersicht
         visstatus="javascript.0.VIS-Status.alle_adapter_gestartet";
         if(on == counter){setState(visstatus, true);}
         //if(on == counter -1){setState(visstatus, true);}
         else{setState(visstatus, false);}
         setStateDelayed('Adapter.Anzahl', counter, 800);
         function isState(strStatePath, strict) {
             let mSelector;
             if (strict) {
                 mSelector = $('state[id=' + strStatePath + '$]');
             } else {
                 mSelector = $('state[id=' + strStatePath + ']');
             if (mSelector.length > 0) {
                 return true;
             } else {
                 return false;
      on({id:"javascript.0.Adapter.AdapterNummer", change: 'any'}, function (dpobj) {
         if (getState("javascript.0.Adapter.AdapterNummer").val != 0) {
             const instanz = "javascript." + instance;
             var adapterNummer = getState(instanz + ".Adapter.AdapterNummer").val;
             var adapter = getState(instanz + ".Adapter.Adapter" + adapterNummer + ".KompletterNameAdapter").val; // Name und Instanz des Adapters
             var idAdapter = "system.adapter." + adapter;
             var obj = getObject(idAdapter);
             if (dpobj.state.val == false) {
                 obj.common.enabled = true;  // Adapter einschalten
             } else if (dpobj.state.val == true) {
                 obj.common.enabled = false;  // Adapter ausschalten
             setObject(idAdapter, obj);
             setStateDelayed('javascript.0.Adapter.AdapterNummer', 0, 800);
      maximal1981 D 2 Replies Last reply Reply Quote 0
      • maximal1981
        maximal1981 @Kuddel last edited by
        @kuddel danke schön
          djsirius @Kuddel last edited by djsirius
          Ich habe den Fehler gefunden!
          • Rouwdy
            Rouwdy @Kuddel last edited by
            @kuddel hallo kuddel ich bin absoluter frischling was das programmieren hier angeht und versuche nun so pö a pö schlau zu werden, mein problem ist schon denke fehlendes grundwissen 😞 , wie genau importiere ich wo genau deine objekte / skripte ? einen mail-adapter hab ich so wie auch die von dir vorgeschlagenen adapter
              WeiserWolf @Rouwdy last edited by
              @rouwdy Als erstes installierst du mal den Adapter "Script Engine" und startest danach den ioBroker neu. Anschließend erscheint links in der Übersicht der Bereich Skripte.
              Dort gehst du oben auf die drei Punkte --> Skripts importieren und ziehst die heruntergeladene ZIP-Datei per Drag&Drop in den Uploadbereich. Danach sind schon einmal alle Skripts importiert. Dort liegt dann ein Skript "Objekte_anlegen"
              Das startest du einmal kurz und kannst es danach wieder beenden. Dieses Skript legt sämtliche Datenpunkte im Bereich "Objekte" an (javascript.0 in den einzelnen Unterordner sortiert)
              Evtl ist auch hier ein Neustart des ioBroker bzw. der Script-Engine erforderlich.
              Ist zumindest bei mir öfter mal der Fall wenn ich neue Adapter installiere o.ä.
              Rouwdy 1 Reply Last reply Reply Quote 0
              • Rouwdy
                Rouwdy @WeiserWolf last edited by
                @weiserwolf said in [Vorstellung] Meine dritte VIS:
                Script Engine
                Dank Dir @weiserwolf , werd es ausprobieren.
                • maximal1981
                  maximal1981 last edited by maximal1981
                  ich habe gerade ein komisches Phänomen.
                  Am Abend wird der Rolladen nicht zur korrekten Zeit herunter gefahren. Jedoch sieht laut mir theoretisch alles richtig aus.
                  2021-06-19 20:18:00.443  - info: javascript.0 (1506) script.js.smarthome.rolladen.rolladen_tag_nacht: +++ Sonnenuntergang -30: Wonhzimmer Seite auf 0% +++
                  Selbst die Ausgabe/debug des Cron sieht richtig aus.
                  2021-06-19 20:32:02.320  - warn: javascript.0 (1506) script.js.smarthome.rolladen.rolladen_tag_nacht: 31 20 * * *
                  Zeit am Tablet bzw. ioBroker stimmt auch, was man ja auch im Log sehen kann, dass sie nicht mit der Schließzeit übereinstimmt.
                  Jemand eine Idee?
                  lg
                    @maximal1981 kurzer check, ob ich das Problem richtig verstanden habe:
                    Die Rolladen sollen um 20:31 Uhr (30 Min vor dem Sonnenuntergang) heruterfahren.
                    Der entsprechende Log-Eintrag kommt aver schon um 20:18 Uhr.
                    Das sieht für mich so aus, als wenn sich der Cron-Job nicht die richtige Zeit zieht.
                    • maximal1981
                      ich werde es mal weiter beobachten
                        HoTi last edited by HoTi
                        ich bin auch neu hier und wollte mich mal an die VIS machen, da die Anzeige der Daten für meine Frau erstmal das wichtigste ist. Vorher habe ich alles mit FHEM und TabletUI gemacht, aber da fange ich jetzt nicht wieder mit an.
                        Nun scheitere ich allerdings schon am Import und zwar an den ICONS.
                        Ich meine sie liegen richtig:
                        aber angezeigt wird mir nix 😞
                        Was mache ich nun falsch? Nun verbringe ich schon 3 Tage damit, weil ich euch nicht mit so einer Kleinigkeit nerven wollte, aber langsam verzweifle ich.
                        edit
                        Na gut, habe nun rausgefunden das die Wetter ICONS vom Widget kommen, aber die werden trotzdem nicht angezeigt. Bei den Widget Einstellungen von DasWetter schon.
                        Viele Grüße
                        Tim
                          sigi234 Forum Testing Most Active @HoTi last edited by
                          @hoti
                          Welche Vis Version?
                          Welche Icons?
                          Eigene musst du immer mit den Dateimanager hochladen!
                            HoTi @sigi234 last edited by
                            @sigi234
                            Ja habe ich auch gemacht. Ich Depp habe nicht Kapiert das die Wetter ICONS nicht in "Meine_Icons" liegen.
                            Aber die Wetter ICONS werden nicht angezeigt weil er die auf einer mir Unbekannten IP Adresse sucht. Wo verdammt muss ich das nur ändern?
                            • Glasfaser
                              Glasfaser @HoTi last edited by
                              @hoti
                              https://forum.iobroker.net/topic/30497/vorstellung-meine-dritte-vis/322
                                HoTi @Glasfaser last edited by
                                @glasfaser
                                Danke.
                                Habe die IP Adresse raus genommen und schon geht es auch.
                                aber irgendwas mach ich noch falsch. Ich habe ganz viele solche überlagerungen:
                                und sowas, im Editor sieht es so aus:
                                und auf der Webseite dann so:
                                  Kuddel @HoTi last edited by Kuddel
                                  @hoti ich arbeite oft mit Sichtbarkeiten.
                                  Wenn in deiner Umgebung die verwendeten Datenpunkte nicht vorhanden sind, werden immer alle Objekte angezeigt
                                  Da hilft nur eines: Schritt für Schritt anpassen
                                  • maximal1981
                                    @HoTi
                                    wie schon @Kuddel erwähnt hat, es gibt viele Ebenen. Ich habe die Icons Anfangs hin und her geschoben um an die anderen Schichten zu kommen, aber das ist nicht notwendig.
                                    Jedes Widget auf einer Seite ist ein Widget in sich. Das muss man immer beachten, und die Ebenen lassen sich im Widget-Editor sehr gut bearbeiten.
                                    Würde mal empfehlen mit der Hauptseite 0000 anzufangen, ich habe viel gelernt, durch dieses VIS, und du hast sicher etliches anzupassen. Den zu 99% passen die Adapter nicht zu deinen, der Aufbau nicht mit deinen vorhandenen Gegebenheiten überein. Mit "etwas" Einarbeitung wird das, aber wenn du so wie ich Neuland betrittst, stelle dich darauf ein, dass hier etliche Zeit reinfließt.
                                    Ich habe die Scripte nach Bedarf eingeschaltet und angepasst, da man sonst Zuviel Müll im Log produziert.
                                    Nach 2 Monaten habe ich das schon unter anderem im Schlafzimmer umgesetzt (ich arbeite aber nur zeitweise an der Umsetzung):
                                    Man muss auch die IP nicht zwingend wissen, bzw. war das noch nie notwendig.
                                    Ich liefere mal Beispiele:
                                    • Wetter: /adapter/daswetter/icons/tiempo-weather/galeria1/1.png
                                    • Flot:
                                    /flot/index.html?l%5B0%5D%5Bid%5D=tado.0.122768.Weather.outsideTemperature.celsius&l%5B0%5D%5Boffset%5D=0&l%5B0%5D%5Baggregate%5D=minmax&l%5B0%5D%5Bcolor%5D=%23FF0000&l%5B0%5D%5Bmin%5D=-20&l%5B0%5D%5Bmax%5D=40&l%5B0%5D%5Bthickness%5D=3&l%5B0%5D%5Bshadowsize%5D=3&l%5B0%5D%5Bunit%5D=%C2%B0C&l%5B0%5D%5Byaxe%5D=right&l%5B0%5D%5Bxaxe%5D=bottom&l%5B0%5D%5BignoreNull%5D=true&l%5B0%5D%5BafterComma%5D=0&l%5B0%5D%5Bdashes%5D=false&l%5B0%5D%5BdashLength%5D=10&l%5B0%5D%5BspaceLength%5D=10&l%5B0%5D%5Bfill%5D=0&l%5B0%5D%5Bmultiplicator%5D=1&timeType=relative&relativeEnd=now&range=10080&live=300&aggregateType=step&aggregateSpan=300&window_bg=%23212121&bg=2&barLabels=topover&hoverDetail=true&timeFormat=%25H%3A%25M+%25a&useComma=false&zoom=false&noedit=true&animation=0&m%5B0%5D%5Bl%5D=0&m%5B0%5D%5Bv%5D=0&m%5B0%5D%5Bf%5D=0&m%5B0%5D%5Bc%5D=black&m%5B0%5D%5Bt%5D=3&m%5B0%5D%5Bs%5D=3&m%5B0%5D%5Bd%5D=&m%5B0%5D%5Bp%5D=l&m%5B0%5D%5Bpy%5D=0&m%5B0%5D%5Bfc%5D=%23FF0000&m%5B0%5D%5Bfs%5D=&m%5B0%5D%5Bvl%5D=0&start=2019-02-09&start_time=15%3A48&end=2019-02-09&end_time=16%3A00&noBorder=noborder&x_labels_color=ffffff&y_labels_color=ffffff&barFontColor=white&titlePos=top%3A35%3Bleft%3A50&titleSize=40px&legColumns=0&legBgOpacity=0&legBg=black&width=380&height=230&border_width=1&titleColor=%23ffffff
                                      HoTi @Kuddel last edited by HoTi
                                      @kuddel
                                      Hallo Kuddel,
                                      ich versuche gerade dein VIS "voranzupassen" also im Texteditor.
                                      Kannst du mir sagen was bei dir hinter deinen IP Adressen steckt? Dann kann ich das bei mir passend anpassen, wenn ich das Gerät auch habe.
                                      Folgende IP Adressen habe ich in deinem Code gefunden
                                      192.168.4.1
                                      192.168.4.10
                                      192.168.4.11
                                      192.168.4.12
                                      192.168.4.17
                                      192.168.4.20
                                      192.168.4.24
                                      192.168.4.25
                                      192.168.4.34
                                      192.168.4.35
                                      192.168.4.37
                                      192.168.4.39
                                      192.168.4.41
                                      192.168.4.42
                                      192.168.4.45
                                      192.168.4.5
                                      192.168.4.60
                                      192.168.4.61
                                      192.168.4.62
                                      192.168.4.64
                                      192.168.4.65
                                      192.168.4.66
                                      192.168.4.67
                                      192.168.4.71
                                      192.168.4.72
                                        @HoTi
                                        192.168.4.1 FritzBox
                                        192.168.4.10 WinNAS (WindowsNAS)
                                        192.168.4.11 Xpenology (virtuelles Synology NAS)
                                        192.168.4.12 SynologyNAS
                                        192.168.4.17 Tablet
                                        192.168.4.20 QNAP-NAS
                                        192.168.4.24 VU+_TV_Recever
                                        192.168.4.25 Logitech_Harmony_Hub
                                        192.168.4.34
                                        192.168.4.35
                                        192.168.4.37
                                        192.168.4.39
                                        192.168.4.41 ESX-Test-1
                                        192.168.4.42 ESX-Test-2
                                        192.168.4.45 ESX-NUC
                                        192.168.4.5 CCU
                                        192.168.4.60
                                        192.168.4.61
                                        192.168.4.62 Unifi-Switch-Rack
                                        192.168.4.64 Unifi-Switch-Wohnzimmer
                                        192.168.4.65 Unifi-AP-OG
                                        192.168.4.66 Unifi-AP-EG
                                        192.168.4.67 Unifi-AP-Pavillon
                                        192.168.4.71 Kamera-Balkon
                                        192.168.4.72 Kamera-Haustuer
                                        Die IPs ohne Beschreibung habe ich aktuell nicht mehr in Verwendung und weiß daher nicht mehr, weclhes Geräte sie zum Zeitpunkt des Hochladens der VIS verwendet haben.
                                          @kuddel
                                          Super vielen Dank!
                                            @kuddel
                                            Kannst du mir den Blockly code vom Tablet nochmal extrahieren.
                                            den kann ich bei mir nicht ändern.
                                            1.0k
                                            vis vis projekte
                                            83
                                            640
                                            172229
