    5. Spannungsgeführte Gerätesteuerung
      Medoc @Medoc last edited by
        paul53 @Medoc last edited by
        @medoc sagte: mit diesem script geht sie aber gar nicht aus, trotz unterspannung.
        Poste bitte den erzeugten Javascript-Code ohne die letzte Zeile in Code tags.
          Medoc @paul53 last edited by
            <variables>
              <variable id="QyU%NeehKu8B-(eUUWzJ">Spannung</variable>
              <variable id="#NjROm#D]q?~e5E)g.cx">Klopumpe</variable>
              <variable id="{;KYn9h|rc9~MuiJ,B1)">Ausschaltsperre</variable>
            </variables>
            <block type="comment" id="ssS0i7mkz[OJd.j+Zc[I" x="-463" y="113">
              <field name="COMMENT">Wemos</field>
                <block type="schedule" id="eeUAS=8PwkHaxCD(:R3Q">
                  <field name="SCHEDULE">*/15 * * * * *</field>
                    <block type="variables_set" id="p`zjoN.Y$dfrM3$_-TD=">
                      <field name="VAR" id="QyU%NeehKu8B-(eUUWzJ">Spannung</field>
                        <block type="math_arithmetic" id="@=c~HnpsOGPp%HE)??a,">
                            <shadow type="math_number" id="IpcqkKWeHfj+0kswZU,6">
                              <field name="NUM">1.035</field>
                            <shadow type="math_number" id="Ddgh17!!-mr3LzmX)5#$">
                              <field name="NUM">1</field>
                            <block type="get_value" id="/4#Mj^[%xux*kVeiQ@hn">
                              <field name="OID">shelly.0.SHUNI-1#C45BBE6012E4#1.ADC.Power</field>
                        <block type="controls_if" id="}i[YhGk3Ej3WitGAFARb">
                            <block type="logic_operation" id="f06jj}?C=9lpu$aeNOw/">
                              <field name="OP">AND</field>
                                <block type="logic_compare" id="zcL)}uuX|`u4)W}/C2Mv">
                                  <field name="OP">GTE</field>
                                    <block type="variables_get" id="67R^j}I!!WdvCk)_nYKS">
                                    <block type="math_number" id="W{5|7zNIx*]`yO`Xx(9c">
                                      <field name="NUM">26</field>
                                <block type="variables_get" id="QT`SNdX)B-s^j/CB.i_Q">
                                  <field name="VAR" id="#NjROm#D]q?~e5E)g.cx">Klopumpe</field>
                            <block type="variables_set" id="xUvP-(!Qw6fIB*1omyT+">
                                <block type="logic_boolean" id="=mGpGGf14F)fn+kJFJBc">
                                <block type="variables_set" id="2_XAmV8SZ_lso#XPZx+W">
                                  <field name="VAR" id="{;KYn9h|rc9~MuiJ,B1)">Ausschaltsperre</field>
                                    <block type="logic_boolean" id="ro|;zB~nYTD~J3|]FE*v">
                                    <block type="timeouts_settimeout" id="u=qreL=vkd4iCaHC{9e7">
                                      <field name="DELAY">1</field>
                                        <block type="variables_set" id="I0I$UU+ToIj/br)Zehze">
                                            <block type="logic_boolean" id="ft]85^%!=:UC5!#-fxXV">
                          <value name="IF1">
                            <block type="logic_operation" id="Swy-NSk.!/O~PTmL|]G3">
                                <block type="logic_compare" id="NZ/Om+d5]yf#JSw*+~8z">
                                  <field name="OP">LTE</field>
                                    <block type="variables_get" id="6a*~7GmR-:uhzLU_Y%M1">
                                    <block type="math_number" id="UY.gw+tm2z^]M=IPNE+D">
                                      <field name="NUM">24.5</field>
                                <block type="logic_negate" id="1bMmw_^uX;w#[W`}M,Jd">
                                  <value name="BOOL">
                                    <block type="variables_get" id="D{w$z%$V=PPl+TN5Rx)k">
                          <statement name="DO1">
                            <block type="variables_set" id="71#sghGovQ5_TvJM/dY%">
                                <block type="logic_boolean" id="2{HxH}qiWV#MT+@=]z97">
                            <block type="controls_if" id=",lL|hYeYfX@RMeP7FYEz">
                                <block type="logic_compare" id=";5*a;c}6)M%[z1ib07P`">
                                  <field name="OP">NEQ</field>
                                    <block type="variables_get" id="I?LFXdfrJm^^0qd#!Lh@">
                                    <block type="get_value" id="CwWf/DQ#*TI{Qp.@PZb@">
                                      <field name="OID">sonoff.0.DVES_53921A.POWER2</field>
                                <block type="control" id="tqUink=@Ra`$k:17SfeI">
                                    <block type="variables_get" id="GV7*!p8_;=Q7b=rGWM*b">
            sie schaltet auch nicht ein
              @medoc sagte: sie schaltet auch nicht ein
              Initialisiere mal die Variable Klopumpe bei Skriptstart:
                nichts
                  paul53 @Medoc last edited by paul53
                  @medoc sagte: nichts
                  Ich kann keinen Fehler entdecken. Erzeuge mal Log-Ausgaben:
                    nach ettlichen litern wasser das klo runter hatte ich eine spontanidee. iobroker neu starten. und siehe, er tut es.
                    wo finde ich den debug-text?
                      @medoc sagte: wo finde ich den debug-text?
                      Den "debug output" unter "System", "erstelle Text aus" unter "Text".
                        ich meine den text, der dann geschrieben wird.
                          Homoran Global Moderator Administrators @Medoc last edited by
                          @medoc im log als loglevel info
                            soll ich nochmal spülen und dir den log dann schicken?
                            oder hat sich das erledigt?
                              @medoc sagte: ich meine den text, der dann geschrieben wird.
                              Normalerweise im Fenster unter dem Blockly-Skript (Editor). Auf jeden Fall im Tab "Log".
                                @medoc sagte: soll ich nochmal spülen und dir den log dann schicken?
                                Wenn es jetzt funktioniert, hat es sich erledigt.
                                  Medoc @paul53 last edited by Medoc
                                  und zum abschluß vielen dank für die geduld.
                                  solltest du mal in der nähe von rudolstadt sein, gibt es argentinisches steak, bier und whisky
                                    es war ein schöner tag, wechselhaftes wetter, mal sonne und mal dichte wolken.
                                    die relais klappern wie sie sollen.
                                    grandios
                                    3497
