    4. Hilfe für Sonoff Zigbee Bridge in ioBroker
    • nukleuz
      nukleuz @Asgothian last edited by
      @asgothian
      Hi zusammen,
      ich habe eben auch versucht meine Sonoff Zigbee-Bridge über den Zigbee Adapter ans Laufen zu bekommen.
      Ich bin nach deiner Anleitung vorgegangen: https://forum.iobroker.net/topic/43446/zigbee-adapter-mit-sonoff-zigbee-bridge/8?_=1624362828057
      MQTT ist aus und TCP-Server läuft auf Port 8888.
      Diese Meldung kommt schon beim Öffnen des Zigbee-Adapters:
      Das Log schreibt:
      zigbee.0	2021-06-22 14:20:21.314	info	(32096) Starting Zigbee npm ...
      zigbee.0	2021-06-22 14:20:21.313	info	(32096) Try to reconnect.
      zigbee.0	2021-06-22 14:20:11.311	error	(32096) Error herdsman start
      zigbee.0	2021-06-22 14:20:11.311	error	(32096) Failed to start Zigbee
      zigbee.0	2021-06-22 14:20:11.310	error	(32096) Starting zigbee-herdsman problem : "debNetworkParam.extendedPanID.replace is not a function"
      zigbee.0	2021-06-22 14:20:11.309	info	(32096) Coordinator firmware version: {"type":"EZSP v8","meta":{"product":8,"majorrel":"6","minorrel":"7","maintrel":"8 ","revision":"6.7.8.0 build 373"}}
      zigbee.0	2021-06-22 14:20:05.270	info	(32096) Installed Version: iobroker.zigbee@1.5.6
      zigbee.0	2021-06-22 14:20:05.210	info	(32096) Starting Zigbee npm ...
      zigbee.0	2021-06-22 14:20:05.208	info	(32096) Try to reconnect.
      zigbee.0	2021-06-22 14:19:55.208	error	(32096) Error herdsman start
      zigbee.0	2021-06-22 14:19:55.208	error	(32096) Failed to start Zigbee
      zigbee.0	2021-06-22 14:19:55.207	error	(32096) Starting zigbee-herdsman problem : "debNetworkParam.extendedPanID.replace is not a function"
      zigbee.0	2021-06-22 14:19:55.205	info	(32096) Coordinator firmware version: {"type":"EZSP v8","meta":{"product":8,"majorrel":"6","minorrel":"7","maintrel":"8 ","revision":"6.7.8.0 build 373"}}
      zigbee.0	2021-06-22 14:19:49.290	info	(32096) Installed Version: iobroker.zigbee@1.5.6
      zigbee.0	2021-06-22 14:19:49.266	info	(32096) Starting Zigbee npm ...
      zigbee.0	2021-06-22 14:19:49.265	info	(32096) Try to reconnect.
      zigbee.0	2021-06-22 14:19:42.807	error	(32096) getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefined
      zigbee.0	2021-06-22 14:19:39.263	error	(32096) Error herdsman start
      zigbee.0	2021-06-22 14:19:39.263	error	(32096) Failed to start Zigbee
      zigbee.0	2021-06-22 14:19:39.261	error	(32096) Starting zigbee-herdsman problem : "debNetworkParam.extendedPanID.replace is not a function"
      zigbee.0	2021-06-22 14:19:39.260	info	(32096) Coordinator firmware version: {"type":"EZSP v8","meta":{"product":8,"majorrel":"6","minorrel":"7","maintrel":"8 ","revision":"6.7.8.0 build 373"}}
      zigbee.0	2021-06-22 14:19:33.279	info	(32096) Installed Version: iobroker.zigbee@1.5.6
      zigbee.0	2021-06-22 14:19:33.237	info	(32096) Starting Zigbee npm ...
      Das sind meine Einstellungen im Adapter:
      Danke für Hilfe...
        Andreas.S @Asgothian last edited by Andreas.S
        @asgothian
        Das ist ein super Angebot. Heute schaffe ich das leider nicht.
        Passt bei dir einer der nächsten Tage. 18 Uhr ist an sich perfekt.
        • Asgothian
          Asgothian Developer @Andreas.S last edited by
          @andreas-s Dann erst wieder kommenden Dienstag - ich hab den rest der Woche Besuch und werd mich da nicht dran setzen können.
          A.
            @asgothian
            Dann plane ich mir mal den nächsten Dienstag ein.
            Vielen Dank schon mal.
              @asgothian
              Ich bin dem iobroker Discord beigetreten. (Andreas.W.S)
              Gib mir eine Info wenn es bei dir passt.
              • Asgothian
                @andreas-s Moin.. jetzt wäre ich zu hause.
                A.
                  @asgothian
                  Besten Dank für die absolut tolle Unterstützung und den genialen Fix 👷 👍
                    Malte O. @Andreas.S last edited by
                    @andreas-s
                    Ich glaube ich stehe vor dem gleichen Problem - was war denn der geniale fix?
                    Asgothian A 2 Replies Last reply Reply Quote 0
                    • Asgothian
                      Asgothian Developer @Malte O. last edited by
                      @malte-o sagte in Hilfe für Sonoff Zigbee Bridge in ioBroker:
                      @andreas-s
                      das ist ein anderer Fehler. Bitte versuch mal die Testversion von
                      https://github.com/asgothian/ioBroker.zigbee/tarball/LatestHerdsman
                      das sollte den Fehler beheben.
                      A.
                        Andreas.S @Malte O. last edited by
                        @malte-o
                        Der Fix bezog sich nicht auf mein ursprüngliches Ansinnen, die Sonoff Zigbee-Bridge zum laufen zu bekommen.
                        Bei mir ging gar keine Zigbee-Instanz mehr. Nicht nur die neue Instanz.
                        Ich habe eben mal einen neuen Docker eingerichtet mit buanet/iobroker latest (Node.js v12.22.1 & NPM 6.14.12)
                        In den "komplett leeren" iobroker habe ich nur den Zigbee- Adapter (V 1.5.6) installiert. Sonst ist nichts in diesem iobroker.
                        Das ist das Ergebnis…
                        zigbee.0	2021-07-01 19:50:37.982	error	(2141) Error herdsman start
                        zigbee.0	2021-07-01 19:50:37.981	error	(2141) Failed to start Zigbee
                        zigbee.0	2021-07-01 19:50:37.981	error	(2141) Starting zigbee-herdsman problem : "debNetworkParam.extendedPanID.replace is not a function"
                        zigbee.0	2021-07-01 19:50:37.981	info	(2141) Coordinator firmware version: {"type":"EZSP v8","meta":{"product":8,"majorrel":"6","minorrel":"7","maintrel":"9 ","revision":"6.7.9.0 build 405"}}
                        zigbee.0	2021-07-01 19:50:32.262	info	(2141) Installed Version: iobroker.zigbee@1.5.6
                        zigbee.0	2021-07-01 19:50:32.257	info	(2141) Starting Zigbee npm ...```
                        Leider kann ich nicht sagen, ob es event. an einem Fehler bei der Prozedur mit dem Sonoff liegt.
                          Andreas.S @Andreas.S last edited by
                          Und nun noch die Testversion von
                          in den Docker und.....
                          2389
