    4. Zigbee-Stick cc2652P direkt über LAN anbinden
      crunchip Forum Testing Most Active @klassisch last edited by
      @klassisch habs heute mal versucht, hat alles geklappt mit der IP Umstellung des USR, allerdings bekomme ich die zigbee Instanz nicht zum laufen, beim starten/beenden der Instanz kommt folgendes
      zigbee.0	2021-07-01 12:04:19.830	error	(32102) Cannot read property 'getEntries' of null
      zigbee.0	2021-07-01 12:04:19.829	error	at processTicksAndRejections (internal/process/task_queues.js:95:5)
      zigbee.0	2021-07-01 12:04:19.829	error	at runMicrotasks (<anonymous>)
      zigbee.0	2021-07-01 12:04:19.829	error	at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:696:41)
      zigbee.0	2021-07-01 12:04:19.829	error	at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:385:20)
      zigbee.0	2021-07-01 12:04:19.829	error	at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:214:42)
      zigbee.0	2021-07-01 12:04:19.829	error	at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:43)
      zigbee.0	2021-07-01 12:04:19.829	error	at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:228:49)
      zigbee.0	2021-07-01 12:04:19.829	error	at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:303:31)
      zigbee.0	2021-07-01 12:04:19.829	error	at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:240:16)
      zigbee.0	2021-07-01 12:04:19.829	error	at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:55)
      zigbee.0	2021-07-01 12:04:19.829	error	(32102) TypeError: Cannot read property 'getEntries' of null
      zigbee.0	2021-07-01 12:04:19.825	error	(32102) unhandled promise rejection: Cannot read property 'getEntries' of null
      zigbee.0	2021-07-01 12:04:19.824	error	(32102) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      zigbee.0	2021-07-01 12:04:19.823	info	(32102) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      ansonsten kommt dann
      zigbee.0	2021-07-01 12:18:35.954	error	(11099) Error herdsman start
      zigbee.0	2021-07-01 12:18:35.953	error	(11099) Failed to start Zigbee
      zigbee.0	2021-07-01 12:18:35.952	error	(11099) Starting zigbee-herdsman problem : "Error while opening socket"
      zigbee.0	2021-07-01 12:18:35.944	info	(11099) Starting Zigbee npm ...
      zigbee.0	2021-07-01 12:18:35.942	info	(11099) Try to reconnect.
      zigbee.0	2021-07-01 12:18:25.955	info	(11099) Installed Version: ioBroker/ioBroker.zigbee#master
      zigbee.0	2021-07-01 12:18:25.940	error	(11099) Error herdsman start
      zigbee.0	2021-07-01 12:18:25.937	error	(11099) Failed to start Zigbee
      zigbee.0	2021-07-01 12:18:25.936	error	(11099) Starting zigbee-herdsman problem : "Error while opening socket"
      zigbee.0	2021-07-01 12:18:25.718	info	(11099) Starting Zigbee npm ...
      zigbee.0	2021-07-01 12:18:25.622	info	(11099) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.17.0, js-controller: 3.3.14
        klassisch Most Active @crunchip last edited by klassisch
        @crunchip Bin jetzt nicht der Adpater-Spezialist. Aber Error opening socket klingt schon nach tcp Problem.
        Hast Du RxD (converter) -> TxD (board) gekreuzt?
        Ich fahre noch eine ältere Versionskombi mit V1.5.5.
        Aber das sollte hoffentlich nicht stören.
        Läuft der Stick/das board über USB?
        crunchip 2 Replies Last reply Reply Quote 1
          crunchip Forum Testing Most Active @klassisch last edited by crunchip
          @klassisch sagte in Zigbee-Stick cc2652P direkt über LAN anbinden:
          na so wie es in der Anleitung steht "DIO12 (RX) und DIO13 (TX)"
          oder ich tausche die mal
          edit: jetzt komm ich mit, nein nicht gekreuzt, versuche ich gleich nochmal
          ja, das läuft
            @klassisch also ich hab jetzt beides probiert, 1zu1 und gekreuzt angeschlossen, beides der gleiche Fehler.
            hier sieht man irgendwie auch nichts arbeiten
            Edit:
            jetzt tut sich was, hab im Menü den Work Mode noch geändert auf TCP Server
            63ccb15f-ad51-4bf4-aa40-11c4d945b6d1-grafik.png 95709343-b1b7-4b5c-827c-af6ce9d0802a-grafik.png
            zigbee.0	2021-07-01 19:15:30.646	error	(16349) Error herdsman start
            zigbee.0	2021-07-01 19:15:30.645	error	(16349) Failed to start Zigbee
            zigbee.0	2021-07-01 19:15:30.643	error	(16349) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
            zigbee.0	2021-07-01 19:15:11.660	info	(16349) Installed Version: ioBroker/ioBroker.zigbee#master
            zigbee.0	2021-07-01 19:15:11.632	info	(16349) Starting Zigbee npm ...
            zigbee.0	2021-07-01 19:15:11.631	info	(16349) Try to reconnect.
            zigbee.0	2021-07-01 19:15:01.630	error	(16349) Error herdsman start
            zigbee.0	2021-07-01 19:15:01.628	error	(16349) Failed to start Zigbee
            zigbee.0	2021-07-01 19:15:01.627	error	(16349) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
            zigbee.0	2021-07-01 19:14:42.668	info	(16349) Installed Version: ioBroker/ioBroker.zigbee#master
            EEEEEEEEEEEEEEEDDDDDDDDDDIIIIITTTT: Instanz ist GRÜN 👍
              @crunchip Glückwunsch, sehr schön, daß es jetzt funktioniert.
              ja TCP Server. der anfragende Rechner ist der Client.
              Sorry, daß ich derzeit so langsam reagiere. Bekomme irgendwie keine Updateinfos zu den abonnierten Themen mehr. Edit: Das war der Spamfilter des email-hosters.
                @klassisch kein Problem, wir sind hier ja auch nicht im 1zu1 Chat.
                nachdem die Instanz endlich lief, musste ich nen tradfri repeater und zwei xiaomi Sensoren neu anlernen, die wollten nicht mehr.
                Jetzt brauch ich nur noch ein passendes Gehäuse.
                  @crunchip Ja, bei Zigbee gibt es so viele credentials....
                  Wollte gestern testweise den Koordinator von einer zweiten Instanz aus parallel ansteuern. Das war nicht gut. Da ist die laufende Haupt-Instanz gleich ausgestiegen und das Netz hat nachher wieder Zeit gebraucht, um sich zu "erholen". Wenn man solche Spiele macht, sollte man besser wissen was man tut. Ich habe mich da noch nicht tief genug eingearbeitet. Nur an der Oberfläche und nur aktuell auftretende Themen behandelt.
                  Als Gehäuse nehme ich gerne die Donau-Elektronik Gehäuse KGB11 bzw. 15. Wenn man mehr Platz braucht auch KGB21 oder 31, weiß jetzt nicht, wie groß das TI Launchboard ist.
                  Die sind schlicht, einfach zu handhaben und billig. Gibt es schon Jahrzehnte, derzeit bei Pollin oder Voelkner.
                  Wer die alten Pop-Farben liebt, wird mit KGB10,12,13,14 fündig 🙂
                  Den USR T2 habe über seine Eth Buchse befestigt. Einfach an die Buchse Kabelschuhe anlöten, notfalls auch Ösen aus 1.5mm² Cu Installationsdraht selbst gebogen und mit Schrauben dann an die "Frontplatte" geschraubt.
                  Oder bei der Montageart "Eth-Buchse senkrecht orientiert" die Kabelschuhe nicht gebogen und eine Schraube durch die Ösen geführt (vorletzes + drittletztes Bild). Die Schraube Stützt sich dann an entsprechendne Domen in den Gehäusehalbschalen ab
                  crunchip 1 Reply Last reply Reply Quote 1
                    Danke für den Tipp, hatte ja ein selbst gedrucktes Gehäuse(Vorlage), aber eben genau passend fürs Board.
                    Mit selbst konstruieren hab ichs nicht so, da ist dann so ein fertiges Gehäuse zum kaufen, doch die beste Alternative.
                    Werd mich mal umsehen, was es so an passende Größen gibt.
                      @crunchip Versuche schon seit Jahren vergeblich eine eventuelle Anschaffung eines 3D Druckers zu rechtfertigen. Aber Gehäusebau hat dazu noch nicht getaugt.
                      Neben den Donau-Gehäusen verwende ich viele Aufputz-Verteilerdosen von einfach bis edel und Kabelkanäle in verschiedenen Abmessungen. Mein erster Zigbee-Stick, der leider nur USB direkt hat, sonst aber sehr gut funktionierte, wohnt in einem Kabelkanal. Mit einer Pucksäge und einem Heißluftföhn ist da schnell ein einfaches Gehäuse gezimmert. Und Kabelkanäle gibt es in vielen Größen und einige Farben. Die kleineren, gängigen Größen braucht man eh im Vorrat.
                        @klassisch ja das mit dem Kabelkanal hatte ich schon gesehen. Man muss halt nur erfinderisch sein, dann geht alles mögliche. Nachteil, wie willst du dann argumentieren, das ein 3d Drucker her muss, wenn es auch ohne geht.😜
                          @crunchip sagte in Zigbee-Stick cc2652P direkt über LAN anbinden:
                          Ja, deshalb schleiche ich schon seit Jahren um das Thema rum und habe noch keinen. 3EUR für ein KGB, <1 EUR für einfache AP Dosen, ein paar Löcher gebohrt/gefeilt, Befestigungen gebaut und man ist letztlich billiger als gedruckt und schneller als konstruiert und gedruckt. Es sei denn man hat beim CAD genügend tägliche Praxis und ist da flott. Bei mir nicht der Fall. Und Figürchen drucken ist nicht so meins.
                          Oft können auch Verpackungen als Gehäuse bzw. Befestigungsmaterial dienen.
                            Abruni @klassisch last edited by
                            @klassisch Bevor ich davon ausgehen einen defekten, oder gefakten USR TCP232-T2 vom Alimann bekommen zu haben, frag ich doch einfach nochmal: Mein Netz ist sowieso in dieser IP Range (Fritzbox hat 192.168.0.1), da sollte ich doch direkt Zugriff haben mit dem Aufruf von 192.168.0.7, oder hab ich es falsch verstanden? Sämtliche Versuche scheitern, selbst bei Direktverkabelung mit Ausschalten von Firewall und Defender und fixer IP 192.168.0.201 kein Zugriff (5V/VDD-GND und 3,3V/VCC-GND versucht). Über Web und über die USR Test Tools nix. Übersehe ich was?
                              klassisch Most Active @Abruni last edited by
                              @abruni Zeig mal die ali-Bestellnummer. Ich hatte mal einen Fake USR gekauft. Der war zwar anpingbar hatte aber keinen Webserver.
                              Was sagt Dein Router? Sieht er das Teil? Kannst Du den USR anpingen? Ist jener IP-Bereich evtl in Deinem Router gesperrt oder reserviert?
                              Ich hatte bei den ersten ein oder zwei USRs einfach eine alte (Reserve-) Fritte genommen, die "platt gemacht" auf 192.168.0.1 konfiguriert und daran meinen Rechner (WLAN natürlich aus) und den USR angestöpselt. Das ging dann problemlos.
                              Mittlerweile mache ich es wie in der USR-Anleitung angegeben.
                                @klassisch Das war dieser:
                                https://www.aliexpress.com/item/4001229906566.html?spm=a2g0s.9042311.0.0.2a554c4daTCLZZ
                                Fritzbox sieht ihn weder unter 192.168.0.7, noch unter einer anderen Adresse. In der Fritzbox ist diese IP weder vergeben, noch gesperrt. Anpingen geht ebenfalls nicht, weder über das normale LAN, noch bei Direktverbindung.
                                  @abruni sagte in Zigbee-Stick cc2652P direkt über LAN anbinden:
                                  da würde ich sagen Fake. Das ist ein FS100P, der unter USR verkauft wurde.
                                  Schau Dir mal das an ali 32329316229 bei JMTTOP
                                  oder bei SOS-Elektronik oder das Bild beim Hersteller USRIOT
                                  Der FS100P wird auch von anderen verkauft , ali 32963270624
                                  Ein Reviewer: "Default IP is 192.168.1.7 (not 192.168.0.7 as stated on product page), login admin, pwd admin, not yet tested with serial device connected but the ethernet works. "
                                  Vielleicht findest Du die Original-Anleitung. Oder Händler anschreiben, ihn auf das falsche Angebot aufmerksam machen und ihn um eine zugehörige Anleitung bitten. Hatte bei mir allerdings nichts gefruchtet.
                                    @klassisch
                                    Danke, der Tip mit 192.168.1.7 war Gold Wert. Direkt Verkabelung am PC, auf DHCP umgestellt, ins LAN gehängt, geguckt was die Fritzbox für eine IP vergeben hat und siehe da: Lüppt. Nochmals Danke.
                                      @abruni danke für die Rückmeldung. Die Bilder der Konfig-Webseite auf der Händlerseite sehen ähnlich aus wie USRIOT aber ohne deren Logo.
                                      Ich hoffe jetzt, daß Dein Clone auch so stabil und problemlos läuft, wie meine USRIOT Teile. Kostengünstig wäre er ja.
                                      opossum 1 Reply Last reply Reply Quote 0
                                      • opossum
                                        opossum @klassisch last edited by opossum
                                        Hallo, @klassisch,
                                        ich habe ein Modul, das hat den CH340E verbaut. Sollte ja eigentlich kein Problem darstellen. Bin noch am Problem klären, wo RX und TX vom CH340E an den 2656P2 gehen. Meiner Meinung nach ist da die Abbildung des neuen Sticks mit 2652P2 nicht korrekt, was die Anschlüsse für RX und TX angeht. Aber das Problem kläre ich mit @dimaiv . Meine Frage: Wie hast Du die Spannungsversorgung realisiert? Hast Du für das LAN-Modul eine extra 5V-Versorgung am Laufen oder holst Du Dir die 5V aus einem USB-Anschluss? Das ist für mich leider nicht so ersichtlich. Würdest Du da vielleicht noch ein paar Worte sagen? Ich denke, beide Module können mit 5V umgehen? Danke vielmals.
                                          klassisch Most Active @opossum last edited by
                                          @opossum Mit dem USB-Anschluß mache ich im Regelbetrieb gar nichts, auch keine Spannungsversorgung. Der kommt nur bei einem etwaigen FW-Upgrade zum Einsatz. Vielleicht.
                                          Ich bekomme 5V von einem 5V Netzteil 1.2A aus einem Pollin Abverkauf.
                                          Diese 5V gehen zum USR Modul.
                                          Ich nutze den dortigen AMS1117 3.3V Spannungsregler auch für die Versorgung des Zigbee-Sticks.
                                          Das kann man aus diesen Bildern erahnen
                                          Das war so einfacher zu verkabeln, alles über einen Stecker, an dem auf Zigbee Seite auch die 3.3V, nicht aber die 5V anliegen.
                                          Man kann natürlich auch die 5V auf beide Module bringen. Aber dann muß man beim Zigbee-Stick noch mehr rumfummeln.
                                          • opossum
                                            Hallo, @klassisch,
                                            die Lösung ist gut, werde ich dann auch so machen. Danke Dir.
                                            81
                                            17457
