    4. Test Adapter homeconnect (BSH Home-Connect) v0.0.x
      tombox @dj_membrane last edited by
      @dj_membrane Das kann eigentlich nicht durch den Adapter entstehen.
      Ich habe in der github verison noch ein zusätzliches Log bitte mal installieren und instanz neustarten.
      Es scheint so als würde von extern der Program Progress geschrieben werden was natürlich nicht geht.
        dj_membrane @tombox last edited by
        @tombox Hab ich gemacht und den Log erneut mitlaufen lassen:
        homeconnect.3	2021-06-07 22:17:47.464	error	(28407) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":63}}
        homeconnect.3	2021-06-07 22:17:47.462	info	(28407) 409: Program option not supported
        homeconnect.3	2021-06-07 22:16:47.140	error	(28407) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":62}}
        homeconnect.3	2021-06-07 22:16:47.139	info	(28407) 409: Program option not supported
        homeconnect.3	2021-06-07 22:15:47.459	error	(28407) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":61}}
        homeconnect.3	2021-06-07 22:15:47.457	info	(28407) 409: Program option not supported
        homeconnect.3	2021-06-07 22:14:46.953	error	(28407) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":60}}
        homeconnect.3	2021-06-07 22:14:46.951	info	(28407) 409: Program option not supported
        homeconnect.3	2021-06-07 22:13:46.960	error	(28407) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":59}}
        homeconnect.3	2021-06-07 22:13:46.959	info	(28407) 409: Program option not supported
        homeconnect.3	2021-06-07 22:12:46.986	error	(28407) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":58}}
        homeconnect.3	2021-06-07 22:12:46.984	info	(28407) 409: Program option not supported
        homeconnect.3	2021-06-07 22:11:46.969	error	(28407) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":57}}
        homeconnect.3	2021-06-07 22:11:46.967	info	(28407) 409: Program option not supported
        homeconnect.3	2021-06-07 22:10:47.484	error	(28407) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":56}}
        homeconnect.3	2021-06-07 22:10:47.483	info	(28407) 409: Program option not supported
        homeconnect.3	2021-06-07 22:09:47.502	error	(28407) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":55}}
        homeconnect.3	2021-06-07 22:09:47.501	info	(28407) 429: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 7 seconds.
        homeconnect.3	2021-06-07 22:08:48.460	error	(28407) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":54}}
        homeconnect.3	2021-06-07 22:08:48.458	info	(28407) 409: Program option not supported
        homeconnect.3	2021-06-07 22:07:54.097	error	(28407) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":59}}
        homeconnect.3	2021-06-07 22:07:54.095	info	(28407) 409: Program option not supported
        homeconnect.3	2021-06-07 22:06:54.929	error	(28407) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":58}}
        homeconnect.3	2021-06-07 22:06:54.927	info	(28407) 409: Program option not supported
        homeconnect.3	2021-06-07 22:05:55.084	error	(28407) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":57}}
        homeconnect.3	2021-06-07 22:05:55.082	info	(28407) 409: Program option not supported
        homeconnect.3	2021-06-07 22:04:55.059	error	(28407) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":56}}
        homeconnect.3	2021-06-07 22:04:55.057	info	(28407) 409: Program option not supported
        homeconnect.3	2021-06-07 22:03:55.080	error	(28407) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":55}}
        homeconnect.3	2021-06-07 22:03:55.079	info	(28407) 409: Program option not supported
        homeconnect.3	2021-06-07 22:02:54.882	error	(28407) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":54}}
        homeconnect.3	2021-06-07 22:02:54.881	info	(28407) 409: Program option not supported
        homeconnect.3	2021-06-07 22:01:54.529	error	(28407) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":53}}
        homeconnect.3	2021-06-07 22:01:54.527	info	(28407) 409: Program option not supported
        homeconnect.3	2021-06-07 22:00:54.270	error	(28407) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":52}}
        homeconnect.3	2021-06-07 22:00:54.268	info	(28407) 409: Program option not supported
        homeconnect.3	2021-06-07 21:59:55.103	error	(28407) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":51}}
        homeconnect.3	2021-06-07 21:59:55.102	info	(28407) 409: Program option not supported
        homeconnect.3	2021-06-07 21:58:55.269	error	(28407) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":49}}
        homeconnect.3	2021-06-07 21:58:55.267	info	(28407) 409: Program option not supported
        homeconnect.3	2021-06-07 21:57:55.421	error	(28407) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":48}}
        homeconnect.3	2021-06-07 21:57:55.419	info	(28407) 409: Program option not supported
        homeconnect.3	2021-06-07 21:56:55.085	error	(28407) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":47}}
        homeconnect.3	2021-06-07 21:56:55.083	info	(28407) 409: Program option not supported
        homeconnect.3	2021-06-07 21:55:54.628	error	(28407) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":46}}
        homeconnect.3	2021-06-07 21:55:54.626	info	(28407) 409: Program option not supported
        homeconnect.3	2021-06-07 21:54:55.006	error	(28407) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":45}}
        homeconnect.3	2021-06-07 21:54:55.005	info	(28407) 409: Program option not supported
        homeconnect.3	2021-06-07 21:53:55.798	error	(28407) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":44}}
        homeconnect.3	2021-06-07 21:53:55.793	info	(28407) 409: Program option not supported
        homeconnect.3	2021-06-07 21:52:55.739	error	(28407) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":43}}
        homeconnect.3	2021-06-07 21:52:55.737	info	(28407) 409: Program option not supported
        homeconnect.3	2021-06-07 21:51:55.023	error	(28407) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":42}}
        homeconnect.3	2021-06-07 21:51:55.022	info	(28407) 409: Program option not supported
        homeconnect.3	2021-06-07 21:50:55.064	error	(28407) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":41}}
        homeconnect.3	2021-06-07 21:50:55.062	info	(28407) 409: Program option not supported
        homeconnect.3	2021-06-07 21:49:55.068	error	(28407) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":40}}
        homeconnect.3	2021-06-07 21:49:55.066	info	(28407) 409: Program option not supported
        homeconnect.3	2021-06-07 21:48:55.079	error	(28407) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":39}}
        homeconnect.3	2021-06-07 21:48:55.077	info	(28407) 429: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 26 seconds.
        homeconnect.3	2021-06-07 21:47:55.077	error	(28407) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":38}}
        homeconnect.3	2021-06-07 21:47:55.075	info	(28407) 409: Program option not supported
        homeconnect.3	2021-06-07 21:46:55.090	error	(28407) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":37}}
        homeconnect.3	2021-06-07 21:46:55.089	info	(28407) 409: Program option not supported
        homeconnect.3	2021-06-07 21:45:54.427	error	(28407) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":36}}
        homeconnect.3	2021-06-07 21:45:54.426	info	(28407) 409: Program option not supported
        homeconnect.3	2021-06-07 21:44:54.321	error	(28407) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":35}}
        homeconnect.3	2021-06-07 21:44:54.319	info	(28407) 409: Program option not supported
        homeconnect.3	2021-06-07 21:43:55.264	error	(28407) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":34}}
        homeconnect.3	2021-06-07 21:43:55.263	info	(28407) 409: Program option not supported
        homeconnect.3	2021-06-07 21:42:55.322	error	(28407) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":33}}
        homeconnect.3	2021-06-07 21:42:55.320	info	(28407) 409: Program option not supported
        homeconnect.3	2021-06-07 21:41:55.284	error	(28407) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":32}}
        homeconnect.3	2021-06-07 21:41:55.283	info	(28407) 409: Program option not supported
        homeconnect.3	2021-06-07 21:40:54.968	error	(28407) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":31}}
        homeconnect.3	2021-06-07 21:40:54.966	info	(28407) 409: Program option not supported
        homeconnect.3	2021-06-07 21:39:55.265	error	(28407) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":29}}
        homeconnect.3	2021-06-07 21:39:55.263	info	(28407) 409: Program option not supported
        homeconnect.3	2021-06-07 21:39:21.392	error	(28407) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":28}}
        homeconnect.3	2021-06-07 21:39:21.387	info	(28407) 409: Program option not supported
        homeconnect.3	2021-06-07 21:38:30.381	info	(28407) 011030386960041183: Program currently not available
        homeconnect.3	2021-06-07 21:38:27.375	info	(28407) 011030386960041183: Program currently not available
        homeconnect.3	2021-06-07 21:38:24.369	info	(28407) 011030386960041183: Program currently not available
        homeconnect.3	2021-06-07 21:38:22.873	info	(28407) 011030386960041183: Program currently not available
        homeconnect.3	2021-06-07 21:38:21.358	info	(28407) 011030386960041183: Program currently not available
        homeconnect.3	2021-06-07 21:38:19.865	info	(28407) 011030386960041183: Program currently not available
        homeconnect.3	2021-06-07 21:38:11.907	info	(28407) Accesstoken renewed...
        homeconnect.3	2021-06-07 21:38:10.961	info	(28407) starting. Version 0.0.36 in /opt/iobroker/node_modules/iobroker.homeconnect, node: v12.22.1, js-controller: 3.2.16
        homeconnect.3	2021-06-07 21:37:59.994	info	(28348) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        homeconnect.3	2021-06-07 21:37:59.989	info	(28348) terminating
        homeconnect.3	2021-06-07 21:37:59.977	info	(28348) cleaned everything up...
        homeconnect.3	2021-06-07 21:37:59.974	info	(28348) Got terminate signal TERMINATE_YOURSELF
        homeconnect.3	2021-06-07 21:37:55.280	error	(28348) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":27}}
        homeconnect.3	2021-06-07 21:37:55.278	info	(28348) 409: Program option not supported
        homeconnect.3	2021-06-07 21:36:55.285	error	(28348) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":26}}
        homeconnect.3	2021-06-07 21:36:55.284	info	(28348) 409: Program option not supported
        homeconnect.3	2021-06-07 21:36:22.231	error	(28348) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":25}}
        homeconnect.3	2021-06-07 21:36:22.228	info	(28348) 409: Program option not supported
        homeconnect.3	2021-06-07 21:36:07.447	info	(28348) 011030386960041183: Program currently not available
        homeconnect.3	2021-06-07 21:36:04.434	info	(28348) 011030386960041183: Program currently not available
        homeconnect.3	2021-06-07 21:36:02.940	info	(28348) 011030386960041183: Program currently not available
        homeconnect.3	2021-06-07 21:36:01.438	info	(28348) 011030386960041183: Program currently not available
        homeconnect.3	2021-06-07 21:35:59.938	info	(28348) 011030386960041183: Program currently not available
        homeconnect.3	2021-06-07 21:35:58.438	info	(28348) 011030386960041183: Program currently not available
        homeconnect.3	2021-06-07 21:35:56.957	info	(28348) 011030386960041183: Program currently not available
        homeconnect.3	2021-06-07 21:35:44.289	info	(28348) Accesstoken renewed...
        homeconnect.3	2021-06-07 21:35:43.323	info	(28348) starting. Version 0.0.36 in /opt/iobroker/node_modules/iobroker.homeconnect, node: v12.22.1, js-controller: 3.2.16
        homeconnect.3	2021-06-07 21:35:26.475	info	(9964) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        homeconnect.3	2021-06-07 21:35:26.471	info	(9964) terminating
        homeconnect.3	2021-06-07 21:35:26.459	info	(9964) cleaned everything up...
        homeconnect.3	2021-06-07 21:35:26.455	info	(9964) Got terminate signal TERMINATE_YOURSELF
        homeconnect.3	2021-06-07 21:34:55.286	error	(9964) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress[object Object]
        homeconnect.3	2021-06-07 21:34:55.285	info	(9964) 409: Program option not supported
        homeconnect.3	2021-06-07 21:33:55.305	error	(9964) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress[object Object]
        homeconnect.3	2021-06-07 21:33:55.304	info	(9964) 409: Program option not supported
        homeconnect.3	2021-06-07 21:32:55.271	error	(9964) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress[object Object]
        homeconnect.3	2021-06-07 21:32:55.270	info	(9964) 409: Program option not supported
        homeconnect.3	2021-06-07 21:31:55.276	error	(9964) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress[object Object]
        homeconnect.3	2021-06-07 21:31:55.275	info	(9964) 409: Program option not supported
        homeconnect.3	2021-06-07 21:30:55.265	error	(9964) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress[object Object]
        homeconnect.3	2021-06-07 21:30:55.264	info	(9964) 409: Program option not supported
        homeconnect.3	2021-06-07 21:29:55.301	error	(9964) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress[object Object]
        homeconnect.3	2021-06-07 21:29:55.300	info	(9964) 409: Program option not supported
        homeconnect.3	2021-06-07 21:28:55.275	error	(9964) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress[object Object]
        homeconnect.3	2021-06-07 21:28:55.274	info	(9964) 409: Program option not supported
        homeconnect.3	2021-06-07 21:27:55.281	error	(9964) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress[object Object]
        homeconnect.3	2021-06-07 21:27:55.279	info	(9964) 409: Program option not supported
        homeconnect.3	2021-06-07 21:26:55.258	error	(9964) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress[object Object]
        homeconnect.3	2021-06-07 21:26:55.257	info	(9964) 409: Program option not supported
        homeconnect.3	2021-06-07 21:25:55.329	error	(9964) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress[object Object]
        homeconnect.3	2021-06-07 21:25:55.328	info	(9964) 409: Program option not supported
        homeconnect.3	2021-06-07 21:24:54.473	error	(9964) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress[object Object]
        homeconnect.3	2021-06-07 21:24:54.472	info	(9964) 409: Program option not supported
        homeconnect.3	2021-06-07 21:23:54.511	error	(9964) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress[object Object]
        homeconnect.3	2021-06-07 21:23:54.510	info	(9964) 409: Program option not supported
        homeconnect.3	2021-06-07 21:22:55.262	error	(9964) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress[object Object]
        homeconnect.3	2021-06-07 21:22:55.261	info	(9964) 409: Program option not supported
        homeconnect.3	2021-06-07 21:21:55.254	error	(9964) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress[object Object]
        homeconnect.3	2021-06-07 21:21:55.253	info	(9964) 409: Program option not supported
        homeconnect.3	2021-06-07 21:20:55.274	error	(9964) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress[object Object]
        homeconnect.3	2021-06-07 21:20:55.273	info	(9964) 409: Program option not supported
        homeconnect.3	2021-06-07 21:19:55.301	error	(9964) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress[object Object]
        homeconnect.3	2021-06-07 21:19:55.300	info	(9964) 409: Program option not supported
        homeconnect.3	2021-06-07 21:18:55.256	error	(9964) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress[object Object]
        homeconnect.3	2021-06-07 21:18:55.255	info	(9964) 409: Program option not supported
        homeconnect.3	2021-06-07 21:17:55.284	error	(9964) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress[object Object]
        homeconnect.3	2021-06-07 21:17:55.283	info	(9964) 409: Program option not supported
        homeconnect.3	2021-06-07 21:16:55.262	error	(9964) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress[object Object]
        homeconnect.3	2021-06-07 21:16:55.261	info	(9964) 409: Program option not supported
        homeconnect.3	2021-06-07 21:15:55.354	error	(9964) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress[object Object]
        homeconnect.3	2021-06-07 21:15:55.353	info	(9964) 409: Program option not supported
        homeconnect.3	2021-06-07 21:14:54.454	error	(9964) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress[object Object]
        homeconnect.3	2021-06-07 21:14:54.453	info	(9964) 409: Program option not supported
        homeconnect.3	2021-06-07 21:13:55.276	error	(9964) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress[object Object]
        homeconnect.3	2021-06-07 21:13:55.275	info	(9964) 409: Program option not supported
        homeconnect.3	2021-06-07 21:12:55.305	error	(9964) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress[object Object]
        homeconnect.3	2021-06-07 21:12:55.304	info	(9964) 409: Program option not supported
        homeconnect.3	2021-06-07 21:11:35.664	error	(9964) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress[object Object]
        homeconnect.3	2021-06-07 21:11:35.663	info	(9964) 409: Program option not supported
          @dj_membrane Wird der program progress irgendwo weiter verarbeitet oder angezeigt? Kannst du das deaktivieren es. Bzw wenn das passiert den Adapter in debug mode setzen
            @tombox Es wird nur in IOBROKER Vis angezeigt und in einem Skript weiter bearbeitet
            Habe das Skript nun deaktiviert und den debug mitlaufen
              dj_membrane @dj_membrane last edited by
              @dj_membrane Mit deaktiviertem Skript:
              homeconnect.3	2021-06-07 22:27:57.535	error	(29202) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":79}}
              homeconnect.3	2021-06-07 22:27:57.533	info	(29202) 409: Program option not supported
              homeconnect.3	2021-06-07 22:27:57.354	debug	(29202) Rate per min: 2
              homeconnect.3	2021-06-07 22:27:57.353	debug	(29202) {"data":{"key":"BSH.Common.Option.ProgramProgress","value":79}}
              homeconnect.3	2021-06-07 22:27:57.351	debug	(29202) 011030386960041183/programs/active/options/BSH.Common.Option.ProgramProgress
              homeconnect.3	2021-06-07 22:27:56.975	error	(29202) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":79}}
              homeconnect.3	2021-06-07 22:27:56.973	info	(29202) 409: Program option not supported
              homeconnect.3	2021-06-07 22:27:56.828	debug	(29202) Rate per min: 2
              homeconnect.3	2021-06-07 22:27:56.827	debug	(29202) {"data":{"key":"BSH.Common.Option.ProgramProgress","value":79}}
              homeconnect.3	2021-06-07 22:27:56.825	debug	(29202) 011030386960041183/programs/active/options/BSH.Common.Option.ProgramProgress
              homeconnect.3	2021-06-07 22:27:56.761	debug	(29202) 011030386960041183.programs.active.options.BSH_Common_Option_RemainingProgramTime:1200
              homeconnect.3	2021-06-07 22:27:56.760	debug	(29202) 011030386960041183.programs.active.options.BSH_Common_Option_ProgramProgress:79
              homeconnect.3	2021-06-07 22:27:56.757	debug	(29202) event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1623097676,\"handling\":\"none\",\"uri\":\"/api/homeappliances/011030386960041183/programs/active/options/BSH.Common.Option.ProgramPr
              homeconnect.3	2021-06-07 22:27:12.636	error	(29202) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":78}}
              homeconnect.3	2021-06-07 22:27:12.634	info	(29202) 409: Program option not supported
              homeconnect.3	2021-06-07 22:27:12.441	debug	(29202) Rate per min: 1
              homeconnect.3	2021-06-07 22:27:12.440	debug	(29202) {"data":{"key":"BSH.Common.Option.ProgramProgress","value":78}}
              homeconnect.3	2021-06-07 22:27:12.438	debug	(29202) 011030386960041183/programs/active/options/BSH.Common.Option.ProgramProgress
              homeconnect.3	2021-06-07 22:26:57.470	error	(29202) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":78}}
              homeconnect.3	2021-06-07 22:26:57.468	info	(29202) 409: Program option not supported
              homeconnect.3	2021-06-07 22:26:57.237	debug	(29202) Rate per min: 0
              homeconnect.3	2021-06-07 22:26:57.236	debug	(29202) {"data":{"key":"BSH.Common.Option.ProgramProgress","value":78}}
              homeconnect.3	2021-06-07 22:26:57.234	debug	(29202) 011030386960041183/programs/active/options/BSH.Common.Option.ProgramProgress
              homeconnect.3	2021-06-07 22:26:56.864	debug	(29202) 011030386960041183.programs.active.options.BSH_Common_Option_RemainingProgramTime:1260
              homeconnect.3	2021-06-07 22:26:56.862	debug	(29202) 011030386960041183.programs.active.options.BSH_Common_Option_ProgramProgress:78
              homeconnect.3	2021-06-07 22:26:56.860	debug	(29202) event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1623097616,\"handling\":\"none\",\"uri\":\"/api/homeappliances/011030386960041183/programs/active/options/BSH.Common.Option.ProgramPr
              homeconnect.3	2021-06-07 22:25:57.311	error	(29202) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":77}}
              homeconnect.3	2021-06-07 22:25:57.309	info	(29202) 409: Program option not supported
              homeconnect.3	2021-06-07 22:25:57.135	debug	(29202) Rate per min: 1
              homeconnect.3	2021-06-07 22:25:57.134	debug	(29202) {"data":{"key":"BSH.Common.Option.ProgramProgress","value":77}}
              homeconnect.3	2021-06-07 22:25:57.132	debug	(29202) 011030386960041183/programs/active/options/BSH.Common.Option.ProgramProgress
              homeconnect.3	2021-06-07 22:25:57.114	error	(29202) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":77}}
              homeconnect.3	2021-06-07 22:25:57.113	info	(29202) 409: Program option not supported
              homeconnect.3	2021-06-07 22:25:56.833	debug	(29202) Rate per min: 1
              homeconnect.3	2021-06-07 22:25:56.832	debug	(29202) {"data":{"key":"BSH.Common.Option.ProgramProgress","value":77}}
              homeconnect.3	2021-06-07 22:25:56.831	debug	(29202) 011030386960041183/programs/active/options/BSH.Common.Option.ProgramProgress
              homeconnect.3	2021-06-07 22:25:56.777	debug	(29202) 011030386960041183.programs.active.options.BSH_Common_Option_RemainingProgramTime:1320
              homeconnect.3	2021-06-07 22:25:56.776	debug	(29202) 011030386960041183.programs.active.options.BSH_Common_Option_ProgramProgress:77
              homeconnect.3	2021-06-07 22:25:56.773	debug	(29202) event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1623097556,\"handling\":\"none\",\"uri\":\"/api/homeappliances/011030386960041183/programs/active/options/BSH.Common.Option.ProgramPr
              homeconnect.3	2021-06-07 22:24:57.150	error	(29202) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":76}}
              homeconnect.3	2021-06-07 22:24:57.149	info	(29202) 409: Program option not supported
              homeconnect.3	2021-06-07 22:24:57.012	debug	(29202) Rate per min: 1
              homeconnect.3	2021-06-07 22:24:57.010	debug	(29202) {"data":{"key":"BSH.Common.Option.ProgramProgress","value":76}}
              homeconnect.3	2021-06-07 22:24:57.009	debug	(29202) 011030386960041183/programs/active/options/BSH.Common.Option.ProgramProgress
              homeconnect.3	2021-06-07 22:24:56.772	debug	(29202) 011030386960041183.programs.active.options.BSH_Common_Option_RemainingProgramTime:1380
              homeconnect.3	2021-06-07 22:24:56.770	debug	(29202) 011030386960041183.programs.active.options.BSH_Common_Option_ProgramProgress:76
              homeconnect.3	2021-06-07 22:24:56.768	debug	(29202) event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1623097496,\"handling\":\"none\",\"uri\":\"/api/homeappliances/011030386960041183/programs/active/options/BSH.Common.Option.ProgramPr
              homeconnect.3	2021-06-07 22:24:24.368	error	(29202) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":75}}
              homeconnect.3	2021-06-07 22:24:24.366	info	(29202) 409: Program option not supported
              homeconnect.3	2021-06-07 22:24:12.604	debug	(29202) Create State: 011030386960041183.programs.selected.options.Kurz60.Dishcare_Dishwasher_Option_SilenceOnDemand
              homeconnect.3	2021-06-07 22:24:12.602	debug	(29202) Create State: 011030386960041183.programs.selected.options.Kurz60.Dishcare_Dishwasher_Option_BrillianceDry
              homeconnect.3	2021-06-07 22:24:12.596	debug	(29202) Create State: 011030386960041183.programs.selected.options.Kurz60.Dishcare_Dishwasher_Option_VarioSpeedPlus
              homeconnect.3	2021-06-07 22:24:12.594	debug	(29202) Create State: 011030386960041183.programs.selected.options.Kurz60.Dishcare_Dishwasher_Option_IntensivZone
              homeconnect.3	2021-06-07 22:24:12.592	debug	(29202) Create State: 011030386960041183.programs.selected.options.Kurz60.BSH_Common_Option_StartInRelative
              homeconnect.3	2021-06-07 22:24:12.581	debug	(29202) {"data":{"options":[{"key":"BSH.Common.Option.StartInRelative","value":0,"unit":"seconds","name":"Startzeit"},{"key":"Dishcare.Dishwasher.Option.IntensivZone","value":false,"name":"IntensivZon
              homeconnect.3	2021-06-07 22:24:12.579	debug	(29202) /programs/selected/options
              homeconnect.3	2021-06-07 22:24:09.651	debug	(29202) Create State: 011030386960041183.programs.active.options.BSH_Common_Option_WaterForecast
              homeconnect.3	2021-06-07 22:24:09.649	debug	(29202) Create State: 011030386960041183.programs.active.options.BSH_Common_Option_EnergyForecast
              homeconnect.3	2021-06-07 22:24:09.648	debug	(29202) Create State: 011030386960041183.programs.active.options.BSH_Common_Option_RemainingProgramTimeIsEstimated
              homeconnect.3	2021-06-07 22:24:09.647	debug	(29202) Create State: 011030386960041183.programs.active.options.BSH_Common_Option_RemainingProgramTime
              homeconnect.3	2021-06-07 22:24:09.645	debug	(29202) Create State: 011030386960041183.programs.active.options.BSH_Common_Option_ProgramProgress
              homeconnect.3	2021-06-07 22:24:09.644	debug	(29202) Create State: 011030386960041183.programs.active.options.Dishcare_Dishwasher_Option_SilenceOnDemand
              homeconnect.3	2021-06-07 22:24:09.643	debug	(29202) Create State: 011030386960041183.programs.active.options.Dishcare_Dishwasher_Option_BrillianceDry
              homeconnect.3	2021-06-07 22:24:09.642	debug	(29202) Create State: 011030386960041183.programs.active.options.Dishcare_Dishwasher_Option_VarioSpeedPlus
              homeconnect.3	2021-06-07 22:24:09.641	debug	(29202) Create State: 011030386960041183.programs.active.options.Dishcare_Dishwasher_Option_IntensivZone
              homeconnect.3	2021-06-07 22:24:09.639	debug	(29202) Create State: 011030386960041183.programs.active.options.BSH_Common_Option_StartInRelative
              homeconnect.3	2021-06-07 22:24:09.638	debug	(29202) {"data":{"options":[{"key":"BSH.Common.Option.StartInRelative","value":0,"unit":"seconds","name":"Startzeit"},{"key":"Dishcare.Dishwasher.Option.IntensivZone","value":false,"name":"IntensivZon
              homeconnect.3	2021-06-07 22:24:09.636	debug	(29202) /programs/active/options
              Schalte nun das Skript nochmal ein und schicke dir dann den log nochmal
                @dj_membrane Jetzt mit laufendem Skript und debug mode:
                homeconnect.3	2021-06-07 22:48:51.948	debug	(29202) 011030386960041183.programs.selected.options.BSH_Common_Option_ProgramProgress:100
                homeconnect.3	2021-06-07 22:48:51.946	debug	(29202) event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1623098931,\"handling\":\"none\",\"uri\":\"/api/homeappliances/011030386960041183/programs/selected/options/BSH.Common.Option.Program
                homeconnect.3	2021-06-07 22:48:51.928	debug	(29202) 011030386960041183.status.BSH_Common_Status_OperationState:BSH.Common.EnumType.OperationState.Inactive
                homeconnect.3	2021-06-07 22:48:51.927	debug	(29202) event: {"type":"STATUS","data":"{\"items\":[{\"timestamp\":1623098931,\"handling\":\"none\",\"uri\":\"/api/homeappliances/011030386960041183/status/BSH.Common.Status.OperationState\",\"key\":\
                homeconnect.3	2021-06-07 22:48:51.890	debug	(29202) 011030386960041183.programs.selected.options.BSH_Common_Option_ProgramProgress:0
                homeconnect.3	2021-06-07 22:48:51.889	debug	(29202) event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1623098931,\"handling\":\"none\",\"uri\":\"/api/homeappliances/011030386960041183/programs/selected/options/BSH.Common.Option.Program
                homeconnect.3	2021-06-07 22:48:51.797	debug	(29202) 011030386960041183.settings.BSH_Common_Setting_PowerState:BSH.Common.EnumType.PowerState.Off
                homeconnect.3	2021-06-07 22:48:51.793	debug	(29202) event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1623098931,\"handling\":\"none\",\"uri\":\"/api/homeappliances/011030386960041183/settings/BSH.Common.Setting.PowerState\",\"key\":\"
                homeconnect.3	2021-06-07 22:48:00.507	info	(29202) 011030386960041183: There is no program active
                homeconnect.3	2021-06-07 22:47:56.362	error	(29202) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":100}}
                homeconnect.3	2021-06-07 22:47:56.359	info	(29202) 409: Program option not supported
                homeconnect.3	2021-06-07 22:47:51.946	debug	(29202) Rate per min: 4
                homeconnect.3	2021-06-07 22:47:51.937	debug	(29202) Delete: 011030386960041183.programs.active.options
                homeconnect.3	2021-06-07 22:47:51.935	debug	(29202) active.options.
                homeconnect.3	2021-06-07 22:47:51.833	error	(29202) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":100}}
                homeconnect.3	2021-06-07 22:47:51.832	info	(29202) 409: Program option not supported
                homeconnect.3	2021-06-07 22:47:51.819	debug	(29202) 011030386960041183.status.BSH_Common_Status_OperationState:BSH.Common.EnumType.OperationState.Finished
                homeconnect.3	2021-06-07 22:47:51.817	debug	(29202) event: {"type":"STATUS","data":"{\"items\":[{\"timestamp\":1623098871,\"handling\":\"none\",\"uri\":\"/api/homeappliances/011030386960041183/status/BSH.Common.Status.OperationState\",\"key\":\
                homeconnect.3	2021-06-07 22:47:51.723	debug	(29202) Rate per min: 3
                homeconnect.3	2021-06-07 22:47:51.721	debug	(29202) {"data":{"key":"BSH.Common.Option.ProgramProgress","value":100}}
                homeconnect.3	2021-06-07 22:47:51.719	debug	(29202) 011030386960041183/programs/active/options/BSH.Common.Option.ProgramProgress
                homeconnect.3	2021-06-07 22:47:51.687	debug	(29202) 011030386960041183.programs.active.BSH_Common_Root_ActiveProgram:null
                homeconnect.3	2021-06-07 22:47:51.685	debug	(29202) event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1623098871,\"handling\":\"none\",\"uri\":\"/api/homeappliances/011030386960041183/programs/active\",\"key\":\"BSH.Common.Root.ActiveP
                homeconnect.3	2021-06-07 22:47:51.679	debug	(29202) Rate per min: 2
                homeconnect.3	2021-06-07 22:47:51.677	debug	(29202) {"data":{"key":"BSH.Common.Option.ProgramProgress","value":100}}
                homeconnect.3	2021-06-07 22:47:51.673	debug	(29202) 011030386960041183/programs/active/options/BSH.Common.Option.ProgramProgress
                homeconnect.3	2021-06-07 22:47:51.637	debug	(29202) 011030386960041183.events.BSH_Common_Event_ProgramFinished:BSH.Common.EnumType.EventPresentState.Present
                homeconnect.3	2021-06-07 22:47:51.631	debug	(29202) event: {"type":"EVENT","data":"{\"items\":[{\"timestamp\":1623098871,\"handling\":\"none\",\"key\":\"BSH.Common.Event.ProgramFinished\",\"value\":\"BSH.Common.EnumType.EventPresentState.Presen
                homeconnect.3	2021-06-07 22:47:51.616	debug	(29202) 011030386960041183.programs.active.options.BSH_Common_Option_RemainingProgramTime:0
                homeconnect.3	2021-06-07 22:47:51.615	debug	(29202) 011030386960041183.programs.active.options.BSH_Common_Option_ProgramProgress:100
                homeconnect.3	2021-06-07 22:47:51.613	debug	(29202) event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1623098871,\"handling\":\"none\",\"uri\":\"/api/homeappliances/011030386960041183/programs/active/options/BSH.Common.Option.ProgramPr
                homeconnect.3	2021-06-07 22:46:57.969	error	(29202) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":99}}
                homeconnect.3	2021-06-07 22:46:57.967	info	(29202) 409: Program option not supported
                homeconnect.3	2021-06-07 22:46:57.791	debug	(29202) Rate per min: 1
                homeconnect.3	2021-06-07 22:46:57.790	debug	(29202) {"data":{"key":"BSH.Common.Option.ProgramProgress","value":99}}
                homeconnect.3	2021-06-07 22:46:57.788	debug	(29202) 011030386960041183/programs/active/options/BSH.Common.Option.ProgramProgress
                homeconnect.3	2021-06-07 22:46:56.952	error	(29202) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":99}}
                homeconnect.3	2021-06-07 22:46:56.950	info	(29202) 409: Program option not supported
                homeconnect.3	2021-06-07 22:46:56.775	debug	(29202) Rate per min: 1
                homeconnect.3	2021-06-07 22:46:56.774	debug	(29202) {"data":{"key":"BSH.Common.Option.ProgramProgress","value":99}}
                homeconnect.3	2021-06-07 22:46:56.773	debug	(29202) 011030386960041183/programs/active/options/BSH.Common.Option.ProgramProgress
                homeconnect.3	2021-06-07 22:46:56.725	debug	(29202) 011030386960041183.programs.active.options.BSH_Common_Option_RemainingProgramTime:60
                homeconnect.3	2021-06-07 22:46:56.723	debug	(29202) 011030386960041183.programs.active.options.BSH_Common_Option_ProgramProgress:99
                homeconnect.3	2021-06-07 22:46:56.722	debug	(29202) event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1623098816,\"handling\":\"none\",\"uri\":\"/api/homeappliances/011030386960041183/programs/active/options/BSH.Common.Option.ProgramPr
                homeconnect.3	2021-06-07 22:45:57.927	error	(29202) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":98}}
                homeconnect.3	2021-06-07 22:45:57.925	info	(29202) 409: Program option not supported
                homeconnect.3	2021-06-07 22:45:57.751	debug	(29202) Rate per min: 2
                homeconnect.3	2021-06-07 22:45:57.750	debug	(29202) {"data":{"key":"BSH.Common.Option.ProgramProgress","value":98}}
                homeconnect.3	2021-06-07 22:45:57.748	debug	(29202) 011030386960041183/programs/active/options/BSH.Common.Option.ProgramProgress
                homeconnect.3	2021-06-07 22:45:56.934	error	(29202) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":98}}
                homeconnect.3	2021-06-07 22:45:56.933	info	(29202) 409: Program option not supported
                homeconnect.3	2021-06-07 22:45:56.758	debug	(29202) Rate per min: 1
                homeconnect.3	2021-06-07 22:45:56.757	debug	(29202) {"data":{"key":"BSH.Common.Option.ProgramProgress","value":98}}
                homeconnect.3	2021-06-07 22:45:56.756	debug	(29202) 011030386960041183/programs/active/options/BSH.Common.Option.ProgramProgress
                homeconnect.3	2021-06-07 22:45:56.713	debug	(29202) 011030386960041183.programs.active.options.BSH_Common_Option_RemainingProgramTime:120
                homeconnect.3	2021-06-07 22:45:56.712	debug	(29202) 011030386960041183.programs.active.options.BSH_Common_Option_ProgramProgress:98
                homeconnect.3	2021-06-07 22:45:56.710	debug	(29202) event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1623098756,\"handling\":\"none\",\"uri\":\"/api/homeappliances/011030386960041183/programs/active/options/BSH.Common.Option.ProgramPr
                homeconnect.3	2021-06-07 22:44:57.899	error	(29202) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":97}}
                homeconnect.3	2021-06-07 22:44:57.897	info	(29202) 409: Program option not supported
                homeconnect.3	2021-06-07 22:44:57.756	debug	(29202) Rate per min: 2
                homeconnect.3	2021-06-07 22:44:57.755	debug	(29202) {"data":{"key":"BSH.Common.Option.ProgramProgress","value":97}}
                homeconnect.3	2021-06-07 22:44:57.753	debug	(29202) 011030386960041183/programs/active/options/BSH.Common.Option.ProgramProgress
                homeconnect.3	2021-06-07 22:44:56.931	error	(29202) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":97}}
                homeconnect.3	2021-06-07 22:44:56.930	info	(29202) 429: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 0 seconds.
                homeconnect.3	2021-06-07 22:44:56.754	debug	(29202) Rate per min: 2
                homeconnect.3	2021-06-07 22:44:56.753	debug	(29202) {"data":{"key":"BSH.Common.Option.ProgramProgress","value":97}}
                homeconnect.3	2021-06-07 22:44:56.751	debug	(29202) 011030386960041183/programs/active/options/BSH.Common.Option.ProgramProgress
                homeconnect.3	2021-06-07 22:44:56.710	debug	(29202) 011030386960041183.programs.active.options.BSH_Common_Option_RemainingProgramTime:180
                homeconnect.3	2021-06-07 22:44:56.708	debug	(29202) 011030386960041183.programs.active.options.BSH_Common_Option_ProgramProgress:97
                homeconnect.3	2021-06-07 22:44:56.706	debug	(29202) event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1623098696,\"handling\":\"none\",\"uri\":\"/api/homeappliances/011030386960041183/programs/active/options/BSH.Common.Option.ProgramPr
                homeconnect.3	2021-06-07 22:43:57.960	error	(29202) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":96}}
                homeconnect.3	2021-06-07 22:43:57.958	info	(29202) 429: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 59 seconds.
                homeconnect.3	2021-06-07 22:43:57.772	debug	(29202) Rate per min: 2
                homeconnect.3	2021-06-07 22:43:57.771	debug	(29202) {"data":{"key":"BSH.Common.Option.ProgramProgress","value":96}}
                homeconnect.3	2021-06-07 22:43:57.769	debug	(29202) 011030386960041183/programs/active/options/BSH.Common.Option.ProgramProgress
                homeconnect.3	2021-06-07 22:43:56.946	error	(29202) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":96}}
                homeconnect.3	2021-06-07 22:43:56.945	info	(29202) 429: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 60 seconds.
                homeconnect.3	2021-06-07 22:43:56.800	debug	(29202) Rate per min: 2
                homeconnect.3	2021-06-07 22:43:56.779	debug	(29202) {"data":{"key":"BSH.Common.Option.ProgramProgress","value":96}}
                homeconnect.3	2021-06-07 22:43:56.777	debug	(29202) 011030386960041183/programs/active/options/BSH.Common.Option.ProgramProgress
                homeconnect.3	2021-06-07 22:43:56.732	debug	(29202) 011030386960041183.programs.active.options.BSH_Common_Option_RemainingProgramTime:240
                homeconnect.3	2021-06-07 22:43:56.731	debug	(29202) 011030386960041183.programs.active.options.BSH_Common_Option_ProgramProgress:96
                homeconnect.3	2021-06-07 22:43:56.729	debug	(29202) event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1623098636,\"handling\":\"none\",\"uri\":\"/api/homeappliances/011030386960041183/programs/active/options/BSH.Common.Option.ProgramPr
                homeconnect.3	2021-06-07 22:42:57.992	error	(29202) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":95}}
                homeconnect.3	2021-06-07 22:42:57.991	info	(29202) 429: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 119 seconds.
                homeconnect.3	2021-06-07 22:42:57.816	debug	(29202) Rate per min: 1
                homeconnect.3	2021-06-07 22:42:57.815	debug	(29202) {"data":{"key":"BSH.Common.Option.ProgramProgress","value":95}}
                homeconnect.3	2021-06-07 22:42:57.813	debug	(29202) 011030386960041183/programs/active/options/BSH.Common.Option.ProgramProgress
                homeconnect.3	2021-06-07 22:42:56.992	error	(29202) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":95}}
                homeconnect.3	2021-06-07 22:42:56.990	info	(29202) 429: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 120 seconds.
                homeconnect.3	2021-06-07 22:42:56.810	debug	(29202) Rate per min: 1
                homeconnect.3	2021-06-07 22:42:56.809	debug	(29202) {"data":{"key":"BSH.Common.Option.ProgramProgress","value":95}}
                homeconnect.3	2021-06-07 22:42:56.808	debug	(29202) 011030386960041183/programs/active/options/BSH.Common.Option.ProgramProgress
                homeconnect.3	2021-06-07 22:42:56.762	debug	(29202) 011030386960041183.programs.active.options.BSH_Common_Option_RemainingProgramTime:300
                homeconnect.3	2021-06-07 22:42:56.760	debug	(29202) 011030386960041183.programs.active.options.BSH_Common_Option_ProgramProgress:95
                homeconnect.3	2021-06-07 22:42:56.758	debug	(29202) event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1623098576,\"handling\":\"none\",\"uri\":\"/api/homeappliances/011030386960041183/programs/active/options/BSH.Common.Option.ProgramPr
                homeconnect.3	2021-06-07 22:41:57.949	error	(29202) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":94}}
                homeconnect.3	2021-06-07 22:41:57.947	info	(29202) 429: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 179 seconds.
                homeconnect.3	2021-06-07 22:41:57.777	debug	(29202) Rate per min: 1
                homeconnect.3	2021-06-07 22:41:57.776	debug	(29202) {"data":{"key":"BSH.Common.Option.ProgramProgress","value":94}}
                homeconnect.3	2021-06-07 22:41:57.774	debug	(29202) 011030386960041183/programs/active/options/BSH.Common.Option.ProgramProgress
                homeconnect.3	2021-06-07 22:41:57.001	error	(29202) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":94}}
                homeconnect.3	2021-06-07 22:41:56.999	info	(29202) 429: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 180 seconds.
                homeconnect.3	2021-06-07 22:41:56.777	debug	(29202) Rate per min: 1
                homeconnect.3	2021-06-07 22:41:56.776	debug	(29202) {"data":{"key":"BSH.Common.Option.ProgramProgress","value":94}}
                homeconnect.3	2021-06-07 22:41:56.775	debug	(29202) 011030386960041183/programs/active/options/BSH.Common.Option.ProgramProgress
                homeconnect.3	2021-06-07 22:41:56.725	debug	(29202) 011030386960041183.programs.active.options.BSH_Common_Option_RemainingProgramTime:360
                homeconnect.3	2021-06-07 22:41:56.724	debug	(29202) 011030386960041183.programs.active.options.BSH_Common_Option_ProgramProgress:94
                homeconnect.3	2021-06-07 22:41:56.722	debug	(29202) event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1623098516,\"handling\":\"none\",\"uri\":\"/api/homeappliances/011030386960041183/programs/active/options/BSH.Common.Option.ProgramPr
                homeconnect.3	2021-06-07 22:40:57.938	error	(29202) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":93}}
                homeconnect.3	2021-06-07 22:40:57.934	info	(29202) 429: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 239 seconds.
                homeconnect.3	2021-06-07 22:40:57.763	debug	(29202) Rate per min: 2
                homeconnect.3	2021-06-07 22:40:57.762	debug	(29202) {"data":{"key":"BSH.Common.Option.ProgramProgress","value":93}}
                homeconnect.3	2021-06-07 22:40:57.760	debug	(29202) 011030386960041183/programs/active/options/BSH.Common.Option.ProgramProgress
                homeconnect.3	2021-06-07 22:40:56.947	error	(29202) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":93}}
                homeconnect.3	2021-06-07 22:40:56.945	info	(29202) 429: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 240 seconds.
                homeconnect.3	2021-06-07 22:40:56.771	debug	(29202) Rate per min: 1
                homeconnect.3	2021-06-07 22:40:56.770	debug	(29202) {"data":{"key":"BSH.Common.Option.ProgramProgress","value":93}}
                homeconnect.3	2021-06-07 22:40:56.769	debug	(29202) 011030386960041183/programs/active/options/BSH.Common.Option.ProgramProgress
                homeconnect.3	2021-06-07 22:40:56.725	debug	(29202) 011030386960041183.programs.active.options.BSH_Common_Option_RemainingProgramTime:420
                homeconnect.3	2021-06-07 22:40:56.724	debug	(29202) 011030386960041183.programs.active.options.BSH_Common_Option_ProgramProgress:93
                homeconnect.3	2021-06-07 22:40:56.722	debug	(29202) event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1623098456,\"handling\":\"none\",\"uri\":\"/api/homeappliances/011030386960041183/programs/active/options/BSH.Common.Option.ProgramPr
                homeconnect.3	2021-06-07 22:39:57.909	error	(29202) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":92}}
                homeconnect.3	2021-06-07 22:39:57.907	info	(29202) 429: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 299 seconds.
                homeconnect.3	2021-06-07 22:39:57.774	debug	(29202) Rate per min: 1
                homeconnect.3	2021-06-07 22:39:57.773	debug	(29202) {"data":{"key":"BSH.Common.Option.ProgramProgress","value":92}}
                homeconnect.3	2021-06-07 22:39:57.772	debug	(29202) 011030386960041183/programs/active/options/BSH.Common.Option.ProgramProgress
                  bob der 1. @dj_membrane last edited by
                  Hey ich suche bei meinem Spüler einen State der mir sagt das der Spüler fertig ist....
                  Ich komme mit der Rolle indicator nicht so klar.
                  Wie muss ich das sehen mit true und false im Blockly....hänge da voll.
                    sigi234 Forum Testing Most Active @bob der 1. last edited by
                    @bob-der-1 sagte in Test Adapter homeconnect (BSH Home-Connect) v0.0.x:
                      bob der 1. @sigi234 last edited by bob der 1.
                      @sigi234
                      Heist im Blockly das dann....
                      wenn Wert von ObjektID BSH_Common_Status_OperationState ( = ) ......
                      Ab da weis ich nicht was ich nehmen soll...einen Textbaustein mit dem Wort "RUN"?
                        sigi234 Forum Testing Most Active @bob der 1. last edited by sigi234
                        @bob-der-1
                        Warte mal, da hat mir @dslraser mal was gemacht. Ich suche.....
                        https://forum.iobroker.net/topic/44096/erledigt-ansage-geschirrspüler/5?_=1625230221839
                          @sigi234
                          Ich glaube ich muss mich anders erklären.
                          Da mein Geschirrspüler eine StatusLED hat die auf den Boden scheinen soll sobald er läuft, aber der Spüler über einer Schublade steht und so die StatusLED verdeckt ist, wollte ich wie folgt vorgehen.
                          Spülvorgang ist in Betrieb, eine Led die am meinem WEMOS D1 Mini hängt anschalten, ist der Spüler fertig = LED aus.
                          Vorerst habe ich das über den Stromverbrauch geregelt, was auch funktioniert aber ich wollte da noch ein skript wenn der Spüler zb Klarspüler mangel hat oder sonst was ...eben die LED rot oder grün leuchtet.
                          Aber vorerst muss ich mal den Datenpunkt verstehen.
                          Bzw müsste ich wissen wie ich States mit der Rolle indikator verwenden kann , als Wert wäre zb Aus/An aber wie sage ich in einem Blockly,wenn der Datenpunkt AUS als Wert hat???? True oder false kenne ich ja aber bilde ich aus an ab oder aktiv/bereit etc oder geht das überhaupt.
                            <block type="on" id="QG~H_+mc!MMghSuyE$6s" x="-37" y="-687">
                              <field name="OID">homeconnect.0.0110XXXXXXX4004514.status.BSH_Common_Status_OperationState</field>
                                <block type="controls_if" id="W41!S?TX}n/?eG@p6%-Y">
                                    <block type="logic_compare" id="G~Bn]@r08c!9DaLMQ17z">
                                      <field name="OP">EQ</field>
                                        <block type="get_value" id="_-^2Qv;pWu+`61u{{1}6">
                                          <field name="OID">homeconnect.0.01104XXXXXX514.status.BSH_Common_Status_OperationState</field>
                                        <block type="text" id="#J23()ok4G$5z3yO3i::">
                                          <field name="TEXT">WAS MUSS HIER STEHEN???</field>
                                    <block type="control" id="[1SD..Y)z/{CR8F*wy9Y">
                                      <field name="OID">wled.0.c45bbe549f2a.on</field>
                                        <block type="logic_boolean" id="..^/{+8xCfdla[lT.Jf)">
                                        <block type="control" id="RFx_yv6|MD?Ew61VARBY">
                                          <field name="OID">wled.0.c45bbe549f2a.bri</field>
                                            <block type="math_number" id="bQB0UTzYbQEtRDsJ_r)b">
                                              <field name="NUM">255</field>
                                  <value name="IF1">
                                    <block type="logic_compare" id="^e/rgexxWCLzba/V{PkN">
                                        <block type="get_value" id="{6)n;w-Ih}qP1N^oCH5C">
                                          <field name="OID">homeconnect.0.011040XXXXX4514.status.BSH_Common_Status_OperationState</field>
                                        <block type="text" id="3#u(iSzzuoSB$CtR!A~+">
                                  <statement name="DO1">
                                    <block type="control" id=")qNNnu)#I#?~K3]HTf,B">
                                        <block type="logic_boolean" id="yp-j-0alBYM|n.BK?1{2">
                            @bob-der-1
                            Teste das mal:
                            Importiere dir mal diese View:
                            VIEW_ok_Geschirrspüler_Inventwo_sigi234.txt
                              @sigi234
                              Sobald ich wieder daheim bin......
                              Aber danke und ich bleibe dran
                                @sigi234
                                Ich hab die beiden Vorschläge von dir probiert,leider ohne Erfolg.
                                Das View ist wie immer mega,werde es sicherlich in kleinen Teilen behalten und in einem eigenen View verwurschteln
                                  totti1171 @oberfragger last edited by
                                  @oberfragger gibt es eine Lösung? hab seit einigen Tagen das gleiche Problem.
                                  B T 2 Replies Last reply Reply Quote 0
                                    bob der 1. @totti1171 last edited by bob der 1.
                                    @totti1171
                                    Bisher hatte ich kaum Zeit und habe es ja über den Umweg mit der Steckdose gelöst.
                                    Muss aber auf dauer mit dem Adapter zu lösen sein
                                      tombox @totti1171 last edited by
                                      @totti1171 Was ist genau das Problem du musst nur den states
                                      homeconnect.0.SIEMENS-XXXXX.status.BSH_Common_Status_OperationState
                                      mit den Möglichkeiten vergleichen
                                      BSH.Common.EnumType.OperationState.Ready
                                      BSH.Common.EnumType.OperationState.Run
                                      T B 2 Replies Last reply Reply Quote 0
                                        totti1171 @tombox last edited by totti1171
                                        @tombox Danke. inzwischen funktionieren diese Abfragen gut. Ich habe inzwischen 6 Homeconnect-Geräte (2 Geschirrspüler, Herd, Waschmaschine, Trockner, Kaffeeautomat) im Haus und trotz eingelegter 24h Pause nach kurzer Zeit wieder diese Meldung:
                                        homeconnect.0	2021-07-15 06:04:05.429	error	(19432) Error (401010522127001422)
                                        homeconnect.0	2021-07-15 06:04:05.429	error	(19432) 429 Too Many Requests
                                        homeconnect.0	2021-07-15 06:04:05.429	error	(19432) EventSource error: {"type":"error","status":429,"message":"Too Many Requests"}
                                        homeconnect.0	2021-07-15 06:04:05.380	warn	(19432) Too many requests. Adapter sends too many requests per minute. Please wait 1min before restart the instance.
                                        homeconnect.0	2021-07-15 06:04:05.380	error	(19432) Error (BOSCH-HNG6764S6-68A40E565336)
                                        homeconnect.0	2021-07-15 06:04:05.380	error	(19432) 429 Too Many Requests
                                        homeconnect.0	2021-07-15 06:04:05.380	error	(19432) EventSource error: {"type":"error","status":429,"message":"Too Many Requests"}
                                        homeconnect.0	2021-07-15 06:04:05.372	warn	(19432) Too many requests. Adapter sends too many requests per minute. Please wait 1min before restart the instance.
                                        homeconnect.0	2021-07-15 06:04:05.372	error	(19432) Error (SIEMENS-WT7YH701-68A40E02A511)
                                        homeconnect.0	2021-07-15 06:04:05.372	error	(19432) 429 Too Many Requests
                                        homeconnect.0	2021-07-15 06:04:05.372	error	(19432) EventSource error: {"type":"error","status":429,"message":"Too Many Requests"}
                                        homeconnect.0	2021-07-15 06:04:05.363	warn	(19432) Too many requests. Adapter sends too many requests per minute. Please wait 1min before restart the instance.
                                        homeconnect.0	2021-07-15 06:04:05.363	error	(19432) Error (SIEMENS-TI9555X1DE-68A40E2399A9)
                                        homeconnect.0	2021-07-15 06:04:05.363	error	(19432) 429 Too Many Requests
                                        homeconnect.0	2021-07-15 06:04:05.363	error	(19432) EventSource error: {"type":"error","status":429,"message":"Too Many Requests"}
                                        homeconnect.0	2021-07-15 06:04:05.355	warn	(19432) Too many requests. Adapter sends too many requests per minute. Please wait 1min before restart the instance.
                                        homeconnect.0	2021-07-15 06:04:05.355	error	(19432) Error (BOSCH-SMI88TS36E-68A40E029D20)
                                        homeconnect.0	2021-07-15 06:04:05.354	error	(19432) 429 Too Many Requests
                                        homeconnect.0	2021-07-15 06:04:05.354	error	(19432) EventSource error: {"type":"error","status":429,"message":"Too Many Requests"}
                                        homeconnect.0	2021-07-15 06:04:05.343	warn	(19432) Too many requests. Adapter sends too many requests per minute. Please wait 1min before restart the instance.
                                        homeconnect.0	2021-07-15 06:04:05.343	error	(19432) Error (SIEMENS-WM4YH741-68A40E02AF0A)
                                        homeconnect.0	2021-07-15 06:04:05.343	error	(19432) 429 Too Many Requests
                                        homeconnect.0	2021-07-15 06:04:05.343	error	(19432) EventSource error: {"type":"error","status":429,"message":"Too Many Requests"}
                                          @totti1171 dann wurde der Adapter zu oft neugestartet oder er läuft doppelt
                                          T D 2 Replies Last reply Reply Quote 0
                                            @tombox Hab bei diesem Adapter keine Neustarts eingerichtet und es läuft auch nur eine Instanz 😠
                                            hatte ihn >24h vorgestern aus, da lief er dann wieder für ein paar Stunden - heute morgen dann wieder die Meldungen
                                            bsh bsh home connect home connect homeconnect adapter
                                            195
                                            1373
                                            518092
