    4. Test Adapter powerfox v0.0.2-x
      Thomas Braun Most Active @mp3junkie last edited by
      @mp3junkie
      Im Log File passiert dann was?
        mp3junkie @Thomas Braun last edited by mp3junkie
        (10855) Password error: Please re-enter the password in Admin.
          @mp3junkie
          Bitte mehr zeigen. Z. B. einen Adapter-Neustart. Und bitte in </> CodeTags das ganze.
            mp3junkie last edited by mp3junkie
            2021-07-02 18:54:00.060 - info: host.raspberrypi instance system.adapter.powerfox.0 started with pid 11561
            2021-07-02 18:54:01.828 - info: powerfox.0 (11561) starting. Version 0.0.2-4 in /opt/iobroker/node_modules/iobroker.powerfox, node: v12.22.1, js-controller: 3.2.16
            2021-07-02 18:54:01.900 - error: powerfox.0 (11561) Password error: Please re-enter the password in Admin.
            2021-07-02 18:54:01.963 - info: powerfox.0 (11561) Terminated (NO_ERROR): Without reason
            2021-07-02 18:54:02.502 - info: host.raspberrypi instance system.adapter.powerfox.0 terminated with code 0 (NO_ERROR)
            2021-07-02 18:54:30.777 - info: connector-local-control.0 (3381) Heartbeat
            2021-07-02 18:55:00.134 - info: host.raspberrypi instance system.adapter.powerfox.0 started with pid 12239
            2021-07-02 18:55:01.941 - info: powerfox.0 (12239) starting. Version 0.0.2-4 in /opt/iobroker/node_modules/iobroker.powerfox, node: v12.22.1, js-controller: 3.2.16
            2021-07-02 18:55:02.014 - error: powerfox.0 (12239) Password error: Please re-enter the password in Admin.
            2021-07-02 18:55:02.028 - info: powerfox.0 (12239) Terminated (NO_ERROR): Without reason
            2021-07-02 18:55:02.559 - info: host.raspberrypi instance system.adapter.powerfox.0 terminated with code 0 (NO_ERROR)
            2021-07-02 18:55:04.177 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 12278
            Das versuch ich gerade. Bin Newbee. 😞
              Bekomme es nicht hin. Sorry.
                @mp3junkie
                Was?
                Text markieren, Icon anklicken:
                Fertig.
                  host.raspberrypi	2021-07-02 19:33:02.520	info	instance system.adapter.powerfox.0 terminated with code 0 (NO_ERROR)
                  powerfox.0	2021-07-02 19:33:01.982	info	(7160) Terminated (NO_ERROR): Without reason
                  powerfox.0	2021-07-02 19:33:01.974	error	(7160) Password error: Please re-enter the password in Admin.
                  powerfox.0	2021-07-02 19:33:01.909	info	(7160) starting. Version 0.0.2-4 in /opt/iobroker/node_modules/iobroker.powerfox, node: v12.22.1, js-controller: 3.2.16
                  host.raspberrypi	2021-07-02 19:33:00.079	info	instance system.adapter.powerfox.0 started with pid 7160
                  connector-local-control.0	2021-07-02 19:32:30.794	info	(3381) Heartbeat
                  host.raspberrypi	2021-07-02 19:32:02.427	info	instance system.adapter.powerfox.0 terminated with code 0 (NO_ERROR)
                  powerfox.0	2021-07-02 19:32:01.888	info	(6417) Terminated (NO_ERROR): Without reason
                  powerfox.0	2021-07-02 19:32:01.880	error	(6417) Password error: Please re-enter the password in Admin.
                  powerfox.0	2021-07-02 19:32:01.818	info	(6417) starting. Version 0.0.2-4 in /opt/iobroker/node_modules/iobroker.powerfox, node: v12.22.1, js-controller: 3.2.16
                  host.raspberrypi	2021-07-02 19:32:00.061	info	instance system.adapter.powerfox.0 started with pid 6417
                    host.raspberrypi	2021-07-02 19:35:08.101	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    host.raspberrypi	2021-07-02 19:35:08.072	info	instance scheduled system.adapter.powerfox.0 * * * * *
                    dwd.0	2021-07-02 19:35:07.530	info	(8737) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    dwd.0	2021-07-02 19:35:06.270	info	(8737) starting. Version 2.7.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.22.1, js-controller: 3.2.16
                    host.raspberrypi	2021-07-02 19:35:04.940	info	stopInstance canceled schedule system.adapter.powerfox.0
                    host.raspberrypi	2021-07-02 19:35:04.939	info	stopInstance system.adapter.powerfox.0 (force=false, process=false)
                    host.raspberrypi	2021-07-02 19:35:04.143	info	instance system.adapter.dwd.0 started with pid 8737
                    host.raspberrypi	2021-07-02 19:35:02.523	info	instance system.adapter.powerfox.0 terminated with code 0 (NO_ERROR)
                    powerfox.0	2021-07-02 19:35:01.981	info	(8678) Terminated (NO_ERROR): Without reason
                    powerfox.0	2021-07-02 19:35:01.975	error	(8678) Password error: Please re-enter the password in Admin.
                    powerfox.0	2021-07-02 19:35:01.902	info	(8678) starting. Version 0.0.2-4 in /opt/iobroker/node_modules/iobroker.powerfox, node: v12.22.1, js-controller: 3.2.16
                    host.raspberrypi	2021-07-02 19:35:00.071	info	instance system.adapter.powerfox.0 started with pid 8678
                      Thomas Braun Most Active @mp3junkie last edited by Thomas Braun
                      @mp3junkie
                      Wie oft läuft der Cron?
                      Irgendwelche Sonderzeichen im Passwort? Änder das ggf. mal auf was 'einfaches'.
                        Den Cron habe ich noch nicht konfiguriert. Wie sollte er sein?
                        Ja, Passwort hat Sonderzeichen und Umlaute. Werde ich ändern.
                          @mp3junkie sagte in Test Adapter powerfox v0.0.2-x:
                          Keine Ahnung. Aber nicht zu häufig, sonst kann es sein das du ausgesperrt wirst.
                            Der Login ohne Sonderzeichen funktioniert nun.
                            Habe den Cron testweise auf 1 min gesetzt.
                              cTech last edited by
                              Wird der Adapter noch weiterentwickelt? Also ich habe auch Unmengen von Fehlern im Log. Funktion ist zwar gegeben aber vielleicht kann man ja doch was machen. Auch die Verbesserungen aus den Post könnte man vielleicht mit einfließen lassen. Würden sich sicher viele freuen 😉
                                Thomas Braun Most Active @cTech last edited by
                                @ctech Issue angelegt?
                                  ckuratle @Thomas Braun last edited by
                                  Der Adapter hat zZ 8 Issues, aber keine Aktivitäten.
                                  Benutzt überhaupt jemand diesen Adapter?
                                  Bei mir ist das Log zugemüllt mit powerfox Meldungen und ich möchte eine andere, bessere Lösung
                                  Ich weiss nicht ob er tot ist und man umstellen müsste, zB auf HTTP-request
                                  Ideen?
                                  Christian
                                  Thomas Braun T 2 Replies Last reply Reply Quote 0
                                    Thomas Braun Most Active @ckuratle last edited by
                                    @ckuratle Keine Ahnung...
                                    Ich setze den Adapter jedenfalls nicht ein...
                                      TiDO @ckuratle last edited by
                                      @ckuratle
                                      ich nutze den adapter.
                                      habe aber genau wie du sehr viele fehlermeldungen.
                                      das übermitteln der werte funktioniert aber bei mir.
                                      wäre schön, wenn jemand die fehler beseitigen könnte.
                                        Christian74 @Thomas Braun last edited by
                                        @thomas-braun Ich versuche mich auch am Auslesen des Powerfox. Gibt es eine Alternative zum Adapter? Sorry bin noch recht neu in dem Thema. Ich scheine immer nach dem falschen Stichwort zu suchen...
                                        Gruß Christian
                                          Thomas Braun Most Active @Christian74 last edited by
                                          @christian74
                                          Keine Ahnung. Ich setze weder die Hardware(?) noch den Adapter ein.
                                            @thomas-braun Okay...ich suche nach einer möglichkeit eine API vom Herstell abzufragen. Ich muss aber ein Benutzer und ein Kennwort angeben können....da komme ich zur Zeit nicht weiter...
                                            79.9k
                                            energy energy meter energy monitor powerfox
                                            28
                                            147
                                            16561
