    4. Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda
      rabru @Exile82 last edited by
      @exile82 @tombox
      I finally found the following Issue:
      https://github.com/TA2k/ioBroker.vw-connect/issues/119
      A lot of work for nothing. VW is definitely not automation minded.
      • bmueller77
        bmueller77 @tombox last edited by
        @tombox Welcher Wert steht denn für die Lenkradheizung? Ist für den ID über die App steuerbar aber ich finde in den Objects nicht den passenden Eintrag.
          TiDO @bmueller77 last edited by
          @tombox
          habe gerade auf 0.0.36 aktualsisiert.
          Nun kommt folgender Fehler:
          vw-connect.0	2021-06-18 09:01:56.504	error	(11256) status update Failed WVWZZZxxxxxx
          vw-connect.0	2021-06-18 09:01:56.503	debug	(11256) error while getting $homeregion/fs-car/bs/dwap/v1/$type/$country/vehicles/$vin/history
          vw-connect.0	2021-06-18 09:01:56.502	debug	(11256) error while getting $homeregion/fs-car/bs/rs/v1/$type/$country/vehicles/$vin/status
          vw-connect.0	2021-06-18 09:01:56.502	debug	(11256) error while getting $homeregion/fs-car/bs/batterycharge/v1/$type/$country/vehicles/$vin/charger
          vw-connect.0	2021-06-18 09:01:56.502	debug	(11256) error while getting $homeregion/fs-car/destinationfeedservice/mydestinations/v1/$type/$country/vehicles/$vin/destinations
          vw-connect.0	2021-06-18 09:01:56.501	debug	(11256) error while getting $homeregion/fs-car/bs/vsr/v1/$type/$country/vehicles/$vin/status
          vw-connect.0	2021-06-18 09:01:56.501	debug	(11256) error while getting $homeregion/fs-car/bs/cf/v1/$type/$country/vehicles/$vin/position
          vw-connect.0	2021-06-18 09:01:56.501	debug	(11256) error while getting $homeregion/fs-car/bs/climatisation/v1/$type/$country/vehicles/$vin/climater
          vw-connect.0	2021-06-18 09:01:56.500	debug	(11256) error while getting $homeregion/fs-car/bs/departuretimer/v1/$type/$country/vehicles/$vin/timer
          vw-connect.0	2021-06-18 09:01:56.500	error	(11256) Error: Invalid URI "undefined/fs-car/bs/dwap/v1/Wc/DE/vehicles/WVWZZZxxxxxx/history"
          vw-connect.0	2021-06-18 09:01:56.499	error	(11256) Error: Invalid URI "undefined/fs-car/bs/rs/v1/Wc/DE/vehicles/WVWZZZxxxxxx/status"
          vw-connect.0	2021-06-18 09:01:56.498	error	(11256) Error: Invalid URI "undefined/fs-car/bs/batterycharge/v1/Wc/DE/vehicles/WVWZZZxxxxxx/charger"
          vw-connect.0	2021-06-18 09:01:56.497	error	(11256) Error: Invalid URI "undefined/fs-car/destinationfeedservice/mydestinations/v1/Wc/DE/vehicles/WVWZZZxxxxxx/destinations"
          vw-connect.0	2021-06-18 09:01:56.496	error	(11256) Error: Invalid URI "undefined/fs-car/bs/vsr/v1/Wc/DE/vehicles/WVWZZZxxxxxx/status"
          vw-connect.0	2021-06-18 09:01:56.495	error	(11256) Error: Invalid URI "undefined/fs-car/bs/cf/v1/Wc/DE/vehicles/WVWZZZxxxxxx/position"
          vw-connect.0	2021-06-18 09:01:56.494	error	(11256) Error: Invalid URI "undefined/fs-car/bs/climatisation/v1/Wc/DE/vehicles/WVWZZZxxxxxx/climater"
          vw-connect.0	2021-06-18 09:01:56.493	error	(11256) Error: Invalid URI "undefined/fs-car/bs/departuretimer/v1/Wc/DE/vehicles/WVWZZZxxxxxx/timer"
          vw-connect.0	2021-06-18 09:01:56.489	error	(11256) get vehicle data Failed
          vw-connect.0	2021-06-18 09:01:56.489	error	(11256) Error: Invalid URI "undefined/fs-car/bs/vsr/v1/Wc/DE/vehicles/WVWZZZxxxxxx/requests"
          vw-connect.0	2021-06-18 09:01:56.488	error	(11256) WVWZZZxxxxxx
          vw-connect.0	2021-06-18 09:01:56.486	error	(11256) Error: Invalid URI "undefined/fs-car/vehicleMgmt/vehicledata/v2/Wc/DE/vehicles/WVWZZZxxxxxx/"
          vw-connect.0	2021-06-18 09:01:56.483	debug	(11256) get home region Failed WVWZZZxxxxxx
          vw-connect.0	2021-06-18 09:01:56.482	error	(11256) 400
          vw-connect.0	2021-06-18 09:01:56.266	debug	(11256) getHomeRegion
            tombox @TiDO last edited by
            @tido Der Fehler für ID Fahrzeuge ist mit 0.0.37 gefixt
              Sneak-L8 @tombox last edited by
              @tombox Adapter läuft mit 0.3.37. Bei mir kommen jetzt folgende Warnungen:
              vw-connect.0	2021-06-18 10:18:46.040	warn	(21140) This object will not be created in future versions. Please report this to the developer.
              vw-connect.0	2021-06-18 10:18:46.039	warn	(21140) Object vw-connect.0.WVWZZZE1ZMP035023.status.capabilityStatus.webRadio.status03 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
              vw-connect.0	2021-06-18 10:18:46.039	warn	(21140) This object will not be created in future versions. Please report this to the developer.
              vw-connect.0	2021-06-18 10:18:46.038	warn	(21140) Object vw-connect.0.WVWZZZE1ZMP035023.status.capabilityStatus.webRadio.status02 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
              vw-connect.0	2021-06-18 10:18:46.037	warn	(21140) This object will not be created in future versions. Please report this to the developer.
              vw-connect.0	2021-06-18 10:18:46.036	warn	(21140) Object vw-connect.0.WVWZZZE1ZMP035023.status.capabilityStatus.webRadio.status01 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
              Das sind im Vergleich zu vorher relativ viele Status. Nix großes, aber zur Info...
                tombox @Sneak-L8 last edited by
                @sneak-l8 lösche mal die objekte und probiere mit der aktuellen github version nochmal ob der fehler kommt
                  @tombox War mein ersten Schritt, hab die WebRadio-State bzw. den Chanel gelöscht und neu gestartet. Gerade nochmal WebRadio gelöscht, von git installiert und neu gestartet. Leider gleiches Problem.
                    @sneak-l8 nochmal bitte
                      @tombox Jetzt past's, danke!
                        AndreasK last edited by AndreasK
                        Hallo.
                        Ich versuche aktuell den Adapter in Gang zu bekommen.
                        Es funktioniert leider nicht.
                        Ich bekomme im Log immer „No Token received“ ausgeben.
                        Ich habe die Zugangs-Daten der WeConnect App und auch den richtigen S-PIN eingetragen. Mehrfach geprüft.
                        VW ausgewählt, da ich einen Passat habe.
                        Was mache ich falsch?
                        Nutze die Version 0.0.39
                        Andreas
                        flkontakt T 2 Replies Last reply Reply Quote 0
                        • flkontakt
                          flkontakt @AndreasK last edited by
                          @andreask mal mit VWv2 testen, damit läuft es bei mir, ebenfalls passat01.JPG
                          A T 2 Replies Last reply Reply Quote 0
                            tombox @AndreasK last edited by
                            @andreask Du kannst entweder den Adapter in debug setzen und mit den log schicken oder Zugangsdaten damit ich es selber testen kann. Die App funktioniert ohne Probleme?
                              AndreasK @flkontakt last edited by
                              @flkontakt said in Test Adapter VW Connect v0.0.x für VW We Connect, ID:
                              Super. Funktioniert jetzt. Danke
                                tombox @flkontakt last edited by
                                @flkontakt welche Baujahre sind eure Autos
                                flkontakt 1 Reply Last reply Reply Quote 0
                                • flkontakt
                                  flkontakt @tombox last edited by
                                  @tombox 2021, CB531Z
                                    Backes last edited by Backes
                                    Hallo tombox,
                                    ich hatte auf Github (Github-Issue #86) schonmal als Issue aufgemacht, die Unterstützung für Skoda/Seat/Cupra Wallboxen nachzupflegen. Dabei erwähntest du, dass du Zugangsdaten bräuchtest oder man mit dir hier in Kontakt treten sollte. Da mir meine Zugangsdaten heilig sind, bin ich da doch zwiegespalten. Ansonsten würde ich aber auch selbst gern helfen an der Integration der Powerpass-Schnittstelle (ähnlich WeCharge, allerdings bei Skoda) zu entwickeln. Notfalls könnte man natürlich auch einen Test-Account bei Powerpass erstellen damit man dran kommt.
                                    Ich gehe davon aus, dass im ersten Schritt die Endpunkte zum Backend herausgefunden werden müssten. Wie würdest du dort vorgehen? Reverse-Proxy? MITM und dann mittels Wireshark mitsniffen? Sofern du natürlich noch eine einfachere Variante hast gerne her damit. Dann würde ich mit meiner Wallbox (iV Charger Connect+) und Account durchtesten und Infos liefern bzw. selbst einen Branch machen und einen Pull-Request erstellen.
                                    Beste Grüße
                                    Backes
                                      tombox @Backes last edited by
                                      @backes Die Github Version unterstützt cupra elli wallbox bitte installieren und testen
                                        @tombox
                                        2021-07-09 14:50:02.873 - error: vw-connect.0 (4769) Failed in first login step
                                        2021-07-09 14:50:02.877 - error: vw-connect.0 (4769) 500
                                        2021-07-09 14:50:02.879 - error: vw-connect.0 (4769) "\n\n\n\n \n \n \n \n\n\n
                                        \n
                                        \n
                                        Something went wrong
                                        \n
                                        \n Please try again.\n
                                        \n
                                        \n If the problem continues contact support.\n
                                        \n
                                        \n\n
                                        \n Error code: XYZ _PLATZHALTER_XYZ\n
                                        \n\n\n
                                        \n\n\n\n\n\n\n\n\n"
                                        2021-07-09 14:50:02.883 - error: vw-connect.0 (4769) Login Failed
                                        Eintrag im Log bei der Nutzung vom Elli-Cupra Adapter bei Nutzung einer Skoda Wallbox.
                                        Error-Code kann ich dir gern per PN schicken, falls benötigt.
                                        Ich denke jeder Hersteller hat da seine eigenen Anpassungen.
                                          @backes Skoda Wallbox wird noch nicht unterstützt. Dazu bräuchte ich Zugangsdaten
                                          • flkontakt
                                            flkontakt @flkontakt last edited by
                                            @flkontakt Hallo tombox, leider bekomme ich immer wieder Fehlermeldungen, siehe auch Bild. Hast du hier einen Tipp? Hier https://forum.iobroker.net/post/595171 schien es ähnlich zu sein, gab es hier eine Lösung? Vielen Dank!!!01.JPG
                                            81.1k
                                            audi id.3 myaudi seat skoda skoda connect volkswagen vw id we connect wecharge
                                            398
                                            3090
                                            1599664
