    3. Entwicklung
    4. [gelöst] Hue Motion Sensor Daten auslesen und verarbeiten
    • BAG-STG -KFT
      BAG-STG -KFT @mickym last edited by BAG-STG -KFT
      @mickym und unten:
      • BAG-STG -KFT
        @mickym Ah!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
        Verstehe............. "in dem du schreibst".......
        • BAG-STG -KFT
          @mickym also das schnalle mal, wo dieser Spoiler ist, aber wie bringe ich den code her?
          Soll ich exportieren aus node red?
          • mickym
            mickym Most Active @BAG-STG -KFT last edited by
            @bag-stg-kft
            Hier zeige ich Dir, wie man Node Red Nodes exportiert und hier postet.
            Erst mal der Spoiler:
            Darin kommt dann der Text in Code Tags
                    "id": "1c91eb2a.6924b5",
                    "type": "change",
                    "z": "6442fb39.022744",
                    "name": "extrahiere Celsius",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "payload.celsius",
                            "tot": "msg"
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "$number(payload)\t",
                            "tot": "jsonata"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 810,
                    "y": 1120,
                    "wires": [
                    "id": "6004d3b4.3bff3c",
                    "type": "json",
                    "name": "",
                    "property": "payload",
                    "action": "",
                    "pretty": false,
                    "x": 630,
                    "y": 1140,
                    "wires": [
                            "1c91eb2a.6924b5",
                            "1b30a759.0bdcb9"
                    "id": "1b30a759.0bdcb9",
                    "type": "debug",
                    "name": "",
                    "active": true,
                    "tosidebar": true,
                    "console": false,
                    "tostatus": false,
                    "complete": "false",
                    "statusVal": "",
                    "statusType": "auto",
                    "x": 790,
                    "y": 1200,
                    "wires": []
            Nun sind die Nodes exportiert.
            Zum Importieren ....
            BAG-STG -KFT 3 Replies Last reply Reply Quote 0
            • BAG-STG -KFT
              • mickym
                mickym Most Active @BAG-STG -KFT last edited by mickym
                gelöscht
                • BAG-STG -KFT
                  @mickym ich kann von Node Red exportieren/importieren....... aber hier? muss noch lesen.........
                  das ist von Node Red:
                  [{"id":"89554c5d.fc87d","type":"inject","z":"b66a6350.12eee","name":"Outdoor","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"Outdoor","payloadType":"str","x":90,"y":80,"wires":[["6ea3eb57.5cc664"]]}]
                  • BAG-STG -KFT
                    wie und von wo hierher importieren? bzw. von wo exportieren?
                    • mickym
                      @bag-stg-kft Hast Du das Video geschaut?
                      Das was Du hier von Node Red gepostet hast in den Spoiler und in Code Tags.
                      BAG-STG -KFT 2 Replies Last reply Reply Quote 0
                      • BAG-STG -KFT
                        @mickym
                        • mickym
                          @bag-stg-kft
                          Klasse:
                          Du siehst ich konnte die Node erfolgreich exportieren.
                          • BAG-STG -KFT
                            @mickym
                            ich hoffe, habe richtig gemacht........
                            1. Auge
                            2. Code
                            3. Einfügen (vorher export in Zwischenablage in Node Red)
                            4. Spoiler klicken
                            5. senden
                            • BAG-STG -KFT
                              @mickym
                              [{"id":"89554c5d.fc87d","type":"inject","z":"b66a6350.12eee","name":"Outdoor","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"Outdoor","payloadType":"str","x":90,"y":80,"wires":[["6ea3eb57.5cc664"]]},{"id":"6ea3eb57.5cc664","type":"mqtt out","z":"b66a6350.12eee","name":"/outdoorsensor/temperature","topic":"/outdoorsensor/temperature","qos":"","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"88095ea7.00c13","x":320,"y":80,"wires":[]},{"id":"88095ea7.00c13","type":"mqtt-broker","name":"Outdoorsensor","broker":"192.168.1.170","port":"1883","clientid":"","usetls":false,"protocolVersion":"3","keepalive":"60","cleansession":true,"birthTopic":"/outdoorsensor/temperature","birthQos":"1","birthRetain":"true","birthPayload":"/outdoorsensor/temperature","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"sessionExpiry":""}]
                              • BAG-STG -KFT
                                @mickym nur, was bringt dir das, wenn es je nicht funktioniert?
                                Bei mir ist es gar nicht, wie bei dir, mit "laufender Linie"
                                • mickym
                                  @bag-stg-kft
                                  Auch das funktioniert hervorragend:
                                  Das liegt aber nicht an den Nodes.
                                  Hast Du irgendeinen Fehler oder die Nodes ggf. deaktiviert?
                                  • BAG-STG -KFT
                                    @mickym Ich weiß schon!!!!!!!!!!!!!!!!!!!!!!
                                    Ich habe herum experementiert und flow2 deaktiviert....... nun jetzt muss suchen, wo ich es wieder aktiviere....... 🙂
                                    • BAG-STG -KFT
                                      @mickym jetzt funkzt, nur keine Werte.....
                                      • BAG-STG -KFT
                                        @mickym
                                        [{"id":"89554c5d.fc87d","type":"inject","z":"b66a6350.12eee","name":"Outdoor","props":[{"p":"payload"}],"repeat":"5","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"Outdoor","payloadType":"str","x":90,"y":80,"wires":[["6ea3eb57.5cc664"]]},{"id":"6ea3eb57.5cc664","type":"mqtt out","z":"b66a6350.12eee","name":"/outdoorsensor/temperature","topic":"/outdoorsensor/temperature","qos":"","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"88095ea7.00c13","x":320,"y":80,"wires":[]},{"id":"88095ea7.00c13","type":"mqtt-broker","name":"Outdoorsensor","broker":"192.168.1.170","port":"1883","clientid":"","usetls":false,"protocolVersion":"3","keepalive":"60","cleansession":true,"birthTopic":"/outdoorsensor/temperature","birthQos":"1","birthRetain":"true","birthPayload":"/outdoorsensor/temperature","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"sessionExpiry":""}]
                                        • mickym
                                          @bag-stg-kft
                                          Du sollst doch erst mal schauen, ob nun Outdoor als String so in Deinem ESP angezeigt wird, wie Du es da reingeschrieben hast und mach das bitte wieder aus, das automatisch Injected wird - das soll doch nur funktionieren indem Du auf die Schaltfläche klickst.
                                          Dann sollte in Deinem ESP jetzt Outdoor stehen.
                                          Da sollte ja jetzt nicht mehr der JSON String sondern einfach nur Outdoor drin stehen.
                                          BAG-STG -KFT mickym 2 Replies Last reply Reply Quote 0
                                          • BAG-STG -KFT
                                            @mickym Also im ESP (und allgemein) ist der Name "Draußentemperatur"
                                            Der Sensorname (von HUE) automatisch als "outdoorsensor" und das wollte nie umschreiben, wegen HUE-Bridge und sonstige APPS, bevor nicht alle fix ist, weil ich Angst hatte, dass es nicht mehr gefunden wird.......
                                            Selbst in HASSIO habe ich in Konfigurationsdatei als Sensor "Draußentemperatur" hingefügt gehabt, nur bekam keine Werte angezeigt. Deshalb habe ich angefangen nach Lösungen zu suchen, und so kam ich eigentlich zu Node Red, was für mich ziemlich kompliziert ist, obwohl es mit grafisches Zeichen relative einfach scheint, nur diese JSON, Value, Topic etc habe 0 Ahnung........ Ich habe die Plex und Kodi (xmbc) auch auf Windows installiert, weil ich 0 Ahnung zu "Elek" und "Himbeer" habe
                                            so ist die Einstellung in ESP als MQTT import:
                                            287
                                            59915
