    3. Entwicklung
    4. [gelöst] Hue Motion Sensor Daten auslesen und verarbeiten
    • BAG-STG -KFT
      BAG-STG -KFT @mickym last edited by
      @mickym öhmmmmm.........
      wie bitte?
      so 100% weiß nicht so ganz, was ich tue........
      vielleicht wenn ich noch in jedem einzelnen Raum solche Thermostate gemacht habe, vielleicht..... (mit Kellrräumen zusammen einiges, 10 minimum)
      Also was machen? Die Change, was ich gemacht habe, mit J.Son?
      • mickym
        mickym Most Active @BAG-STG -KFT last edited by mickym
        @bag-stg-kft
        Ich habe keine HUE Nodes deswegen ist die bei mir unbekannt. Aber so schreibst Du für jeden Sensor den Wert in MQTT.
        Kein JSON nichts. Hier der Flow insgesamt:
               "id": "6761429.ba3e7bc",
               "type": "debug",
               "z": "2f60357.916aeca",
               "name": "Draußentemperatur",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": true,
               "complete": "payload",
               "targetType": "msg",
               "statusVal": "payload",
               "statusType": "auto",
               "x": 810,
               "y": 480,
               "wires": []
               "id": "2e217949.2f68c6",
               "type": "hue-temperature",
               "name": "Hue outdoor temp. sensor 1",
               "bridge": "57dcfa9c.e1e824",
               "sensorid": "50",
               "skipevents": false,
               "universalevents": false,
               "x": 280,
               "y": 420,
               "wires": [
                       "4523ccfc.12cec4"
               "id": "4523ccfc.12cec4",
               "type": "change",
               "name": "extrahiere Celsius",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "to": "payload.celsius",
                       "tot": "msg"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 560,
               "y": 420,
               "wires": [
                       "6761429.ba3e7bc",
                       "57f4d279.bcff2c"
               "id": "57f4d279.bcff2c",
               "type": "mqtt out",
               "name": "",
               "topic": "/outdoorsensor/temperatur",
               "qos": "",
               "retain": "",
               "respTopic": "",
               "contentType": "",
               "userProps": "",
               "correl": "",
               "expiry": "",
               "broker": "88095ea7.00c13",
               "x": 820,
               "y": 420,
               "wires": []
               "id": "88095ea7.00c13",
               "type": "mqtt-broker",
               "name": "Outdoorsensor",
               "broker": "192.168.1.170",
               "port": "1883",
               "clientid": "",
               "usetls": false,
               "protocolVersion": "3",
               "keepalive": "60",
               "cleansession": true,
               "birthTopic": "/outdoorsensor/temperature",
               "birthQos": "1",
               "birthRetain": "true",
               "birthPayload": "/outdoorsensor/temperature",
               "birthMsg": {},
               "closeTopic": "",
               "closeQos": "0",
               "closePayload": "",
               "closeMsg": {},
               "willTopic": "",
               "willQos": "0",
               "willPayload": "",
               "willMsg": {},
               "sessionExpiry": ""
        • mickym
          @bag-stg-kft sagte in [gelöst] Hue Motion Sensor Daten auslesen und verarbeiten:
          wie bitte?
          Diese 3 Nodes (HUE, Change, MQTT Out) kopierst für jeden Sensor und lässt die in MQTT natürlich in verschiedene Datenpunkte schreiben.
          Du hast ja auch für jeden Sensor dann eine eigene HUE In Node.
          Nach der Change Node steht im MQTT nun der Temperaturwert und kein JSON mehr. Das siehst wenn Du die Debug Node vom vollständigen Nachrichtenobjekt wieder auf msg.payload stellst.
          und kompliziert ist das eigentlich gar nicht, Aber ich habe so das Gefühl, dass etwas das Verständnis für die Zusammenhänge fehlt.
          Leider hattest Du in der Debug Node - wieder nur die msg.payload und nicht das komplette Nachrichtenobjekt drin. Sonst hätte man sehen können ob in msg.topic Rückschlüsse auf den Sensor zu sehen waren.
          Es ist halt bissi schade - dass Du das nicht immer 1:1 umgesetzt hast .
          Meine Debug Node die ich gepostet habe:
          Deine Debug Node - 3 Posts später_
          Erkennst Du den Unterschied?
          BAG-STG -KFT 2 Replies Last reply Reply Quote 0
          • BAG-STG -KFT
            @mickym ja, in einem wird es weitergeleitet (payload was auch im MQTT publish benutzt wird) in anderem "verarbeitet" (komplette Nachricht)
            es zeigt zwar in Node Red an (in Debug) aber in ESP ist der Wert das Alte (im HASSIO habe noch nicht geschaut)
            [{"id":"f1822ff4.c63d2","type":"mqtt in","z":"865f2cf7.542ac","name":"/outdoorsensor/temperaturin","topic":"/outdoorsensor/temperatur","qos":"2","datatype":"auto","broker":"88095ea7.00c13","nl":false,"rap":true,"rh":0,"x":120,"y":220,"wires":[[]]},{"id":"88095ea7.00c13","type":"mqtt-broker","name":"Outdoorsensor","broker":"192.168.1.170","port":"1883","clientid":"","usetls":false,"protocolVersion":"3","keepalive":"60","cleansession":true,"birthTopic":"/outdoorsensor/temperature","birthQos":"1","birthRetain":"true","birthPayload":"/outdoorsensor/temperature","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"sessionExpiry":""}]
            • mickym
              @bag-stg-kft Wenn es in der Debug Node den Wert anzeigt, dann ist es doch das gleiche was wir mit der Inject Node manuell gemacht haben. Es steht 24.62 drin.
              Und wie gesagt mit den Formaten haben wir lange genug durchgekaut.
              • BAG-STG -KFT
                @mickym habe geändert..........
                [{"id":"6761429.ba3e7bc","type":"debug","z":"865f2cf7.542ac","name":"Draußentemperatur","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"true","targetType":"full","statusVal":"payload","statusType":"auto","x":410,"y":200,"wires":[]}]
                • BAG-STG -KFT
                  @mickym ja, eben deshalb kapiere es nicht, wenn der Zahl 23.3 eingegeben wurde, warum erscheint es im ESP und jetzt aber der Wert nicht mehr?
                  Was mache ich falsch?
                  • BAG-STG -KFT
                    @mickym etwas ist wieder schief gegangen......
                    "Draußentemperatur" ist verschwunden........ (oder "outdoor")
                    • mickym
                      @bag-stg-kft Vielleicht weil er doch einen anderen Wert als Zahl erwartet. Das ist genau das warum wir vorher die Übung gemacht haben.
                      Wie gesagt dann ändere es als String und schau ob das geht.
                      Aber wie gesagt - ich habe Dir mit der Inject Node alle Möglichkeiten gezeigt, was in die MQTT Node zu schreiben und was anderes passiert hier auch nicht, nur dass hier der Wert halt über die Change Node reinkommt.
                      • mickym
                        Die ist nicht verschwunden sondern wird vom JSON über schrieben. Zeig das Debug Fenster mit dem aktuellen Output.
                        • BAG-STG -KFT
                          • mickym
                            @bag-stg-kft Die payload bitte aufklappen - alle Pfeile nach unten
                            • BAG-STG -KFT
                              • mickym
                                @bag-stg-kft Na dann hängt doch die Change Node nicht dazwischen sonst würde die payload doch nicht mehr das Objekt enthalten.
                                BAG-STG -KFT 1 Reply Last reply Reply Quote 0
                                • BAG-STG -KFT
                                  @mickym o.k. ich trenne es, aber mal Frage, weil vielleicht da steckt MQTT.......
                                  Es gibt ja MQTT aus und ein. Da gbt es auch Einstellungen unter der Reiter "Nachrichten", wo ebenfalls diese "msg/payload/etc" ein zu tragen ist.......
                                  Habe ich nicht da etwas vergessen richtig zu stellen?
                                  • mickym
                                    Ehrlich gesagt verstehe ich nicht mehr was Du meinst.
                                    Wie haben es mit der Inject Node hinbekommen.
                                    Mit der Change Node machst Du identisch das gleiche indem Du einen Zahlwert in den gleichen MQTT Punkt schreibst.
                                    Wenn Du alles so gemacht hast, muss es sich identisch wie zu Inject NOde.
                                    Ehrlich gesagt verstehe ich nicht wovon Du sprichst mti dem Reiter:
                                    • BAG-STG -KFT
                                      BAG-STG -KFT @mickym last edited by BAG-STG -KFT
                                      Oben hast empfohlen, nachdem HUE-temp den MQTT-aus zu schalten......
                                      • mickym
                                        @bag-stg-kft Das was Du zeigst ist die MQTT Konfiguration von NodeRed um sich mit dem Broker NodeRed Server zu verbinden.
                                        Das konfiguriert man einmal und nie wieder.
                                        Und nein nichts MQTT ausschalten. Wie gesagt in der broker Konfig in dem Nachrichtenreiter machst Du nachdem er einmal konfiguriert wurde nie wieder was.
                                        Da gibts 2 Datenpunkte die man angibt, die gefüllt werden können, damit Du überprüfen kannst ob NodeREd sich mit Deinem MQTT Broker verbunden hat.
                                        Der eine was beim Verbindungsaufbau und der andere was beim Verbindungsabbau reingeschrieben wird.
                                        Hat mit Deinen Topics 0,0 zu tun.
                                        Ich habe bei mir reingeschrieben, dass er einmal connected in den Verbindungsaufbau und einmal disconnected beim Verbindungsabbau da reinschreiben soll.
                                        Das hat alles mit Deinen Datenpunkten gar nichts zu tun.
                                        Also vergiss die Broker Konfiguration einfach.
                                        Schreib mit der Change NOde den Wert in Deinen Topic und gut ist. 😉
                                        • BAG-STG -KFT
                                          @mickym also habe getrennt, wie du empfohlen hast......
                                          es zeigt im HASSIO aber dasselbe, wie mit und in ESP hat sich nichts geändert, dort setht immer noch 23.30, was wir manuell eingegeben haben.....
                                          in meiner MQTT Nachrichten habe ich ganz andere Dinge stehen...... die ist mit dem Sensor verbunden.....
                                          Fehlt weiterhin "Draußentemperatur"
                                          • mickym
                                            @bag-stg-kft Zeig bitte das Debug Fenster - wie gesagt - das letzte Mal stand immer noch ein Objekt drin.
                                            287
                                            59900
