    4. [gelöst] Stromausfall Web-Oberfläche öffnet sich nicht mehr
    • Berserker
      Berserker @Thomas Braun last edited by
      Okay werde ich machen
      Ausgabe ist folgendes:
      pi@pi:/opt/iobroker $ iobroker restart
      pi@pi:/opt/iobroker $ iobroker status
      Objects type: file
      States  type: file
      pi@pi:/opt/iobroker $ iobroker list instances
      + instance is alive
      Danke schonmal für die Hilfe!!
        Thomas Braun Most Active @Berserker last edited by
        @berserker
        iobroker list adapters
        Berserker 1 Reply Last reply Reply Quote 1
        • Berserker
          da kommt nichts
          pi@pi:/opt/iobroker $ iobroker list adapters
            @berserker Okay.
            iobroker add admin
              Homoran Global Moderator Administrators @Berserker last edited by
              @berserker sagte in Stromausfall Web-Oberfläche öffnet sich nicht mehr:
              Cannot read system.config: null (OK when migrating or restoring)
              Da gibt's Arbeit für das Mini HowTo
              • Berserker
                @thomas-braun said in Stromausfall Web-Oberfläche öffnet sich nicht mehr:
                iobroker add admin
                pi@pi:/opt/iobroker $ iobroker add admin
                host.pi install adapter admin
                upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
                upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
                upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
                upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                host.pi object system.adapter.admin created/updated
                host.pi create instance admin
                host.pi object admin.0.info.newsETag created
                host.pi object admin.0.info.newsfeed created
                host.pi object admin.0.connected created
                host.pi object admin.0 created
                host.pi object admin.0.info created
                host.pi object system.adapter.admin.upload created
                host.pi object system.adapter.admin.0.logLevel created
                host.pi object system.adapter.admin.0.sigKill created
                host.pi object system.adapter.admin.0.eventLoopLag created
                host.pi object system.adapter.admin.0.outputCount created
                host.pi object system.adapter.admin.0.inputCount created
                host.pi object system.adapter.admin.0.uptime created
                host.pi object system.adapter.admin.0.memRss created
                host.pi object system.adapter.admin.0.memHeapTotal created
                host.pi object system.adapter.admin.0.memHeapUsed created
                host.pi object system.adapter.admin.0.cputime created
                host.pi object system.adapter.admin.0.cpu created
                host.pi object system.adapter.admin.0.compactMode created
                host.pi object system.adapter.admin.0.connected created
                host.pi object system.adapter.admin.0.alive created
                host.pi object system.adapter.admin.0 created
                Thomas Braun Berserker 2 Replies Last reply Reply Quote 0
                  @berserker
                  Läuft der Admin jetzt?
                  Berserker 1 Reply Last reply Reply Quote 0
                  • Berserker
                    Berserker @Berserker last edited by
                    @berserker
                    Die Web Oberfläche ist wieder da.
                    Ich lass erstmal die Finger weg bis du etwas dazu sagst.
                    • Berserker
                      + system.adapter.admin.0                  : admin                 : pi                                       -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                      + instance is alive
                      Das kommt dabei raus
                        @berserker Dann solltest du jetzt die fehlenden Adapter ja nachinstallieren können.
                        Berserker 2 Replies Last reply Reply Quote 1
                        • Berserker
                          Wenn ich jetzt die fehlenden Adapter nachinstalliert, sind die Settings dann noch da ??
                          Vielen Dank erstmal
                          • Berserker
                            Wenn ich Adapter installieren möchte, dann steht bei den Adaptern die ich hatte, dass schon einer Installiert ist.
                            Kann ich zB. den Skripte Adapter irgendwie mit den alten Skripten herunterladen?
                            • Berserker
                              @berserker
                              So wie hier
                                @berserker Vermutlich so einfach nicht.
                                Du kannst jetzt Mal nach dem
                                https://forum.iobroker.net/topic/43325/mini-howto-cannot-find-view-system-for-search-host?_=1625594165671
                                versuchen die alten Einstellungen herbeizaubern.
                                  @berserker
                                  Und ein
                                  iobroker stop
                                  iobroker fix
                                  kann auch nicht Schaden.
                                  • Berserker
                                    Hab ich getan
                                    Eine frage:
                                    Der Post den du mir verlinkt hast ist doch nur um den Iobroker wieder an laufen zu bekommen oder?
                                    Ich wüsste nicht an welcher Stelle ich da jetzt einsteigen müsste.
                                    Wäre dankbar wenn du mir noch einmal helfen könntest.
                                    Und könnte es sein das die Daten noch da sind, da ja mir angezeigt wird das die Instanzen installiert sind. Ich kann sie im der Instanzen Liste und in den Objekten nur leider nicht sehen.
                                      @berserker
                                      Du kannst probieren per
                                      iobroker upload all
                                      Oder aus dem Mini-HowTo deine alten states und objects wieder herstellen.
                                      • Berserker
                                        pi@pi:/opt/iobroker $ iobroker upload all
                                        upload [80] info.admin /opt/iobroker/node_modules/iobroker.info/admin/words.js words.js application/javascript
                                        upload [70] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/hostInfo.js lib/js/hostInfo.js application/javascript
                                        upload [60] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/bootstrap.min.js lib/js/bootstrap.min.js application/javascript
                                        upload [50] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/slackware.png lib/img/logos/slackware.png image/png
                                        upload [40] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/manjaro.png lib/img/logos/manjaro.png image/png
                                        upload [30] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/coreos.png lib/img/logos/coreos.png image/png
                                        upload [20] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/disk.png lib/img/icons/disk.png image/png
                                        upload [19] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/cpu.png lib/img/icons/cpu.png image/png
                                        upload [18] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/battery.png lib/img/icons/battery.png image/png
                                        upload [17] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/sechand.png lib/img/clock/sechand.png image/png
                                        upload [16] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/minhand.png lib/img/clock/minhand.png image/png
                                        upload [15] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/hourhand.png lib/img/clock/hourhand.png image/png
                                        upload [14] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/clockface.png lib/img/clock/clockface.png image/png
                                        upload [13] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.woff2 lib/fonts/fontawesome-webfont.woff2 font/woff2
                                        upload [12] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.woff lib/fonts/fontawesome-webfont.woff font/woff
                                        upload [11] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.ttf lib/fonts/fontawesome-webfont.ttf font/ttf
                                        upload [10] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.svg lib/fonts/fontawesome-webfont.svg image/svg+xml
                                        upload [9] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.eot lib/fonts/fontawesome-webfont.eot application/vnd.ms-fontobject
                                        upload [8] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/FontAwesome.otf lib/fonts/FontAwesome.otf font/otf
                                        upload [7] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/data/infoData.json lib/data/infoData.json application/json
                                        upload [6] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/simplemde.min.css lib/css/simplemde.min.css text/css
                                        upload [5] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/info.css lib/css/info.css text/css
                                        upload [4] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/font-awesome.min.css lib/css/font-awesome.min.css text/css
                                        upload [3] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/chartist.min.css lib/css/chartist.min.css text/css
                                        upload [2] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
                                        upload [1] info.admin /opt/iobroker/node_modules/iobroker.info/admin/info.png info.png image/png
                                        upload [0] info.admin /opt/iobroker/node_modules/iobroker.info/admin/index_m.html index_m.html text/html
                                        Update "system.adapter.info.0"
                                        upload [4] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/words.js words.js application/javascript
                                        upload [3] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/instruction.png instruction.png image/png
                                        upload [2] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/index_m.html index_m.html text/html
                                        upload [1] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/index.html index.html text/html
                                        upload [0] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/hue.jpeg hue.jpeg image/jpeg
                                        upload [13] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/words.js words.js application/javascript
                                        upload [12] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/instruction.png instruction.png image/png
                                        upload [11] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/index_m.html index_m.html text/html
                                        upload [10] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                        upload [9] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                        upload [8] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                        upload [7] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                        upload [6] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                        upload [5] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                        upload [4] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                        upload [3] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                        upload [2] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                        upload [1] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                        upload [0] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/deconz.png deconz.png image/png
                                        Update "system.adapter.deconz.0"
                                        Update "system.adapter.admin.0"
                                        Das kommt bei raus.
                                        Ich finde irgendwie keinen Post indem etwas in dem Sinne zu finden ist
                                        Abgesehen davon erstmal meinen Respekt und ein großes Danke für deine Hilfe!!
                                          am Anfang.
                                          weil es wahrsche7nlich die Datenbanken der Objekte ind States terschossen hat
                                          die stellst du mit der verlinkten Anleit6ng aus deren internen backups wieder her
                                          • Berserker
                                            Berserker @Homoran last edited by
                                            @homoran @homoran
                                            pi@pi:/opt/iobroker $ ls -la /opt/iobroker/iobroker-data/backup-objects/
                                            insgesamt 45036
                                            drwxrwxrwx+ 2 iobroker iobroker   4096 Jul  6 20:13 .
                                            drwxrwxrwx+ 8 iobroker iobroker   4096 Jul  6 20:22 ..
                                            -rwxrwxrwx+ 1 iobroker iobroker 978138 Jul  4 20:37 2021-07-04_20-37_objects.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker 585862 Jul  4 21:32 2021-07-04_21-32_states.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker 978121 Jul  4 22:37 2021-07-04_22-37_objects.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker 677255 Jul  4 23:32 2021-07-04_23-32_states.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker 978113 Jul  5 00:44 2021-07-05_00-44_objects.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker 667109 Jul  5 01:32 2021-07-05_01-32_states.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker 978111 Jul  5 02:44 2021-07-05_02-44_objects.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker 667112 Jul  5 03:32 2021-07-05_03-32_states.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker 978125 Jul  5 04:46 2021-07-05_04-46_objects.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker 718539 Jul  5 05:32 2021-07-05_05-32_states.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker 978141 Jul  5 06:54 2021-07-05_06-54_objects.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker 762710 Jul  5 07:33 2021-07-05_07-33_states.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker 978086 Jul  5 09:02 2021-07-05_09-02_objects.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker 762745 Jul  5 09:33 2021-07-05_09-33_states.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker 978115 Jul  5 11:02 2021-07-05_11-02_objects.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker 843746 Jul  5 11:33 2021-07-05_11-33_states.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker 978111 Jul  5 13:02 2021-07-05_13-02_objects.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker 675898 Jul  5 13:33 2021-07-05_13-33_states.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker 978111 Jul  5 15:03 2021-07-05_15-03_objects.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker 735153 Jul  5 15:34 2021-07-05_15-34_states.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker 978339 Jul  5 17:04 2021-07-05_17-04_objects.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker 760527 Jul  5 17:34 2021-07-05_17-34_states.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker 985171 Jul  5 19:04 2021-07-05_19-04_objects.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker 750921 Jul  5 19:34 2021-07-05_19-34_states.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker 985169 Jul  5 21:05 2021-07-05_21-05_objects.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker 749874 Jul  5 21:34 2021-07-05_21-34_states.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker 985157 Jul  5 23:05 2021-07-05_23-05_objects.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker 876184 Jul  5 23:34 2021-07-05_23-34_states.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker 985178 Jul  6 01:05 2021-07-06_01-05_objects.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker 876145 Jul  6 01:34 2021-07-06_01-34_states.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker 984256 Jul  6 03:15 2021-07-06_03-15_objects.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker 876278 Jul  6 03:34 2021-07-06_03-34_states.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker 984275 Jul  6 05:15 2021-07-06_05-15_objects.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker 876270 Jul  6 05:34 2021-07-06_05-34_states.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker 984292 Jul  6 07:16 2021-07-06_07-16_objects.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker 805282 Jul  6 07:34 2021-07-06_07-34_states.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker 984302 Jul  6 09:16 2021-07-06_09-16_objects.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker 810170 Jul  6 09:35 2021-07-06_09-35_states.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker 984304 Jul  6 11:16 2021-07-06_11-16_objects.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker 796188 Jul  6 11:35 2021-07-06_11-35_states.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker 984288 Jul  6 13:16 2021-07-06_13-16_objects.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker 650163 Jul  6 13:36 2021-07-06_13-36_states.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker 984294 Jul  6 15:16 2021-07-06_15-16_objects.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker 652989 Jul  6 15:36 2021-07-06_15-36_states.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker 984240 Jul  6 17:21 2021-07-06_17-21_objects.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker 681146 Jul  6 17:36 2021-07-06_17-36_states.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker   3487 Jul  6 18:41 2021-07-06_18-41_objects.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker 681758 Jul  6 19:01 2021-07-06_19-01_states.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker   3491 Jul  6 19:03 2021-07-06_19-03_objects.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker 681483 Jul  6 19:04 2021-07-06_19-04_states.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker   3491 Jul  6 19:05 2021-07-06_19-05_objects.json.gz
                                            -rwxrwxrwx+ 1 iobroker iobroker 681482 Jul  6 19:06 2021-07-06_19-06_states.json.gz
                                            -rw-rwxr--+ 1 iobroker iobroker   6790 Jul  6 19:37 2021-07-06_19-37_objects.json.gz
                                            -rw-rwxr--+ 1 iobroker iobroker 681474 Jul  6 19:37 2021-07-06_19-37_states.json.gz
                                            -rw-rwxr--+ 1 iobroker iobroker   6790 Jul  6 19:42 2021-07-06_19-42_objects.json.gz
                                            -rw-rwxr--+ 1 iobroker iobroker 681484 Jul  6 19:43 2021-07-06_19-43_states.json.gz
                                            -rw-rw-r--+ 1 iobroker iobroker 684488 Jul  6 20:06 2021-07-06_20-06_objects.json.gz
                                            -rw-rw-r--+ 1 iobroker iobroker 682204 Jul  6 20:06 2021-07-06_20-06_states.json.gz
                                            -rw-rw-r--+ 1 iobroker iobroker 684596 Jul  6 20:13 2021-07-06_20-13_objects.json.gz
                                            -rw-rw-r--+ 1 iobroker iobroker 682357 Jul  6 20:13 2021-07-06_20-13_states.json.gz
                                            Sagt das was aus?
                                            Ich habe außerdem über Backitup vor einer Woche ein Backup gemacht.
                                            Weiß einer wie ich das vielleicht wiederherstellen könnte?
                                            Thomas Braun Berserker Homoran F 4 Replies Last reply Reply Quote 0
                                            3347
