    4. [gelöst] Stromausfall Web-Oberfläche öffnet sich nicht mehr
    • Berserker
      Berserker @Thomas Braun last edited by
      da kommt nichts
      pi@pi:/opt/iobroker $ iobroker list adapters
        Thomas Braun Most Active @Berserker last edited by
        @berserker Okay.
        iobroker add admin
        Berserker 1 Reply Last reply Reply Quote 1
          Homoran Global Moderator Administrators @Berserker last edited by
          @berserker sagte in Stromausfall Web-Oberfläche öffnet sich nicht mehr:
          Cannot read system.config: null (OK when migrating or restoring)
          Da gibt's Arbeit für das Mini HowTo
          • Berserker
            @thomas-braun said in Stromausfall Web-Oberfläche öffnet sich nicht mehr:
            iobroker add admin
            pi@pi:/opt/iobroker $ iobroker add admin
            host.pi install adapter admin
            upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
            upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
            upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
            upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
            host.pi object system.adapter.admin created/updated
            host.pi create instance admin
            host.pi object admin.0.info.newsETag created
            host.pi object admin.0.info.newsfeed created
            host.pi object admin.0.connected created
            host.pi object admin.0 created
            host.pi object admin.0.info created
            host.pi object system.adapter.admin.upload created
            host.pi object system.adapter.admin.0.logLevel created
            host.pi object system.adapter.admin.0.sigKill created
            host.pi object system.adapter.admin.0.eventLoopLag created
            host.pi object system.adapter.admin.0.outputCount created
            host.pi object system.adapter.admin.0.inputCount created
            host.pi object system.adapter.admin.0.uptime created
            host.pi object system.adapter.admin.0.memRss created
            host.pi object system.adapter.admin.0.memHeapTotal created
            host.pi object system.adapter.admin.0.memHeapUsed created
            host.pi object system.adapter.admin.0.cputime created
            host.pi object system.adapter.admin.0.cpu created
            host.pi object system.adapter.admin.0.compactMode created
            host.pi object system.adapter.admin.0.connected created
            host.pi object system.adapter.admin.0.alive created
            host.pi object system.adapter.admin.0 created
            Thomas Braun Berserker 2 Replies Last reply Reply Quote 0
              @berserker
              Läuft der Admin jetzt?
              iobroker list instances
              Berserker 1 Reply Last reply Reply Quote 0
              • Berserker
                Berserker @Berserker last edited by
                @berserker
                Die Web Oberfläche ist wieder da.
                Ich lass erstmal die Finger weg bis du etwas dazu sagst.
                • Berserker
                  pi@pi:/opt/iobroker $ iobroker list instances
                  + system.adapter.admin.0                  : admin                 : pi                                       -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  + instance is alive
                  Das kommt dabei raus
                    @berserker Dann solltest du jetzt die fehlenden Adapter ja nachinstallieren können.
                    Berserker 2 Replies Last reply Reply Quote 1
                    • Berserker
                      Wenn ich jetzt die fehlenden Adapter nachinstalliert, sind die Settings dann noch da ??
                      Vielen Dank erstmal
                      • Berserker
                        Wenn ich Adapter installieren möchte, dann steht bei den Adaptern die ich hatte, dass schon einer Installiert ist.
                        Kann ich zB. den Skripte Adapter irgendwie mit den alten Skripten herunterladen?
                        • Berserker
                          @berserker
                          So wie hier
                            @berserker Vermutlich so einfach nicht.
                            Du kannst jetzt Mal nach dem
                            https://forum.iobroker.net/topic/43325/mini-howto-cannot-find-view-system-for-search-host?_=1625594165671
                            versuchen die alten Einstellungen herbeizaubern.
                              @berserker
                              Und ein
                              iobroker stop
                              iobroker fix
                              kann auch nicht Schaden.
                              • Berserker
                                Hab ich getan
                                Eine frage:
                                Der Post den du mir verlinkt hast ist doch nur um den Iobroker wieder an laufen zu bekommen oder?
                                Ich wüsste nicht an welcher Stelle ich da jetzt einsteigen müsste.
                                Wäre dankbar wenn du mir noch einmal helfen könntest.
                                Und könnte es sein das die Daten noch da sind, da ja mir angezeigt wird das die Instanzen installiert sind. Ich kann sie im der Instanzen Liste und in den Objekten nur leider nicht sehen.
                                  @berserker
                                  Du kannst probieren per
                                  iobroker upload all
                                  Oder aus dem Mini-HowTo deine alten states und objects wieder herstellen.
                                  • Berserker
                                    pi@pi:/opt/iobroker $ iobroker upload all
                                    upload [80] info.admin /opt/iobroker/node_modules/iobroker.info/admin/words.js words.js application/javascript
                                    upload [70] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/hostInfo.js lib/js/hostInfo.js application/javascript
                                    upload [60] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/bootstrap.min.js lib/js/bootstrap.min.js application/javascript
                                    upload [50] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/slackware.png lib/img/logos/slackware.png image/png
                                    upload [40] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/manjaro.png lib/img/logos/manjaro.png image/png
                                    upload [30] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/coreos.png lib/img/logos/coreos.png image/png
                                    upload [20] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/disk.png lib/img/icons/disk.png image/png
                                    upload [19] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/cpu.png lib/img/icons/cpu.png image/png
                                    upload [18] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/battery.png lib/img/icons/battery.png image/png
                                    upload [17] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/sechand.png lib/img/clock/sechand.png image/png
                                    upload [16] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/minhand.png lib/img/clock/minhand.png image/png
                                    upload [15] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/hourhand.png lib/img/clock/hourhand.png image/png
                                    upload [14] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/clockface.png lib/img/clock/clockface.png image/png
                                    upload [13] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.woff2 lib/fonts/fontawesome-webfont.woff2 font/woff2
                                    upload [12] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.woff lib/fonts/fontawesome-webfont.woff font/woff
                                    upload [11] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.ttf lib/fonts/fontawesome-webfont.ttf font/ttf
                                    upload [10] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.svg lib/fonts/fontawesome-webfont.svg image/svg+xml
                                    upload [9] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.eot lib/fonts/fontawesome-webfont.eot application/vnd.ms-fontobject
                                    upload [8] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/FontAwesome.otf lib/fonts/FontAwesome.otf font/otf
                                    upload [7] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/data/infoData.json lib/data/infoData.json application/json
                                    upload [6] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/simplemde.min.css lib/css/simplemde.min.css text/css
                                    upload [5] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/info.css lib/css/info.css text/css
                                    upload [4] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/font-awesome.min.css lib/css/font-awesome.min.css text/css
                                    upload [3] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/chartist.min.css lib/css/chartist.min.css text/css
                                    upload [2] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
                                    upload [1] info.admin /opt/iobroker/node_modules/iobroker.info/admin/info.png info.png image/png
                                    upload [0] info.admin /opt/iobroker/node_modules/iobroker.info/admin/index_m.html index_m.html text/html
                                    Update "system.adapter.info.0"
                                    upload [4] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/words.js words.js application/javascript
                                    upload [3] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/instruction.png instruction.png image/png
                                    upload [2] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/index_m.html index_m.html text/html
                                    upload [1] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/index.html index.html text/html
                                    upload [0] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/hue.jpeg hue.jpeg image/jpeg
                                    upload [13] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/words.js words.js application/javascript
                                    upload [12] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/instruction.png instruction.png image/png
                                    upload [11] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/index_m.html index_m.html text/html
                                    upload [10] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                    upload [9] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                    upload [8] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                    upload [7] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                    upload [6] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                    upload [5] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                    upload [4] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                    upload [3] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                    upload [2] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                    upload [1] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                    upload [0] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/deconz.png deconz.png image/png
                                    Update "system.adapter.deconz.0"
                                    Update "system.adapter.admin.0"
                                    Das kommt bei raus.
                                    Ich finde irgendwie keinen Post indem etwas in dem Sinne zu finden ist
                                    Abgesehen davon erstmal meinen Respekt und ein großes Danke für deine Hilfe!!
                                      am Anfang.
                                      weil es wahrsche7nlich die Datenbanken der Objekte ind States terschossen hat
                                      die stellst du mit der verlinkten Anleit6ng aus deren internen backups wieder her
                                      • Berserker
                                        Berserker @Homoran last edited by
                                        @homoran @homoran
                                        pi@pi:/opt/iobroker $ ls -la /opt/iobroker/iobroker-data/backup-objects/
                                        insgesamt 45036
                                        drwxrwxrwx+ 2 iobroker iobroker   4096 Jul  6 20:13 .
                                        drwxrwxrwx+ 8 iobroker iobroker   4096 Jul  6 20:22 ..
                                        -rwxrwxrwx+ 1 iobroker iobroker 978138 Jul  4 20:37 2021-07-04_20-37_objects.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker 585862 Jul  4 21:32 2021-07-04_21-32_states.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker 978121 Jul  4 22:37 2021-07-04_22-37_objects.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker 677255 Jul  4 23:32 2021-07-04_23-32_states.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker 978113 Jul  5 00:44 2021-07-05_00-44_objects.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker 667109 Jul  5 01:32 2021-07-05_01-32_states.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker 978111 Jul  5 02:44 2021-07-05_02-44_objects.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker 667112 Jul  5 03:32 2021-07-05_03-32_states.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker 978125 Jul  5 04:46 2021-07-05_04-46_objects.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker 718539 Jul  5 05:32 2021-07-05_05-32_states.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker 978141 Jul  5 06:54 2021-07-05_06-54_objects.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker 762710 Jul  5 07:33 2021-07-05_07-33_states.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker 978086 Jul  5 09:02 2021-07-05_09-02_objects.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker 762745 Jul  5 09:33 2021-07-05_09-33_states.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker 978115 Jul  5 11:02 2021-07-05_11-02_objects.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker 843746 Jul  5 11:33 2021-07-05_11-33_states.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker 978111 Jul  5 13:02 2021-07-05_13-02_objects.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker 675898 Jul  5 13:33 2021-07-05_13-33_states.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker 978111 Jul  5 15:03 2021-07-05_15-03_objects.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker 735153 Jul  5 15:34 2021-07-05_15-34_states.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker 978339 Jul  5 17:04 2021-07-05_17-04_objects.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker 760527 Jul  5 17:34 2021-07-05_17-34_states.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker 985171 Jul  5 19:04 2021-07-05_19-04_objects.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker 750921 Jul  5 19:34 2021-07-05_19-34_states.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker 985169 Jul  5 21:05 2021-07-05_21-05_objects.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker 749874 Jul  5 21:34 2021-07-05_21-34_states.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker 985157 Jul  5 23:05 2021-07-05_23-05_objects.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker 876184 Jul  5 23:34 2021-07-05_23-34_states.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker 985178 Jul  6 01:05 2021-07-06_01-05_objects.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker 876145 Jul  6 01:34 2021-07-06_01-34_states.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker 984256 Jul  6 03:15 2021-07-06_03-15_objects.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker 876278 Jul  6 03:34 2021-07-06_03-34_states.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker 984275 Jul  6 05:15 2021-07-06_05-15_objects.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker 876270 Jul  6 05:34 2021-07-06_05-34_states.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker 984292 Jul  6 07:16 2021-07-06_07-16_objects.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker 805282 Jul  6 07:34 2021-07-06_07-34_states.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker 984302 Jul  6 09:16 2021-07-06_09-16_objects.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker 810170 Jul  6 09:35 2021-07-06_09-35_states.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker 984304 Jul  6 11:16 2021-07-06_11-16_objects.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker 796188 Jul  6 11:35 2021-07-06_11-35_states.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker 984288 Jul  6 13:16 2021-07-06_13-16_objects.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker 650163 Jul  6 13:36 2021-07-06_13-36_states.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker 984294 Jul  6 15:16 2021-07-06_15-16_objects.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker 652989 Jul  6 15:36 2021-07-06_15-36_states.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker 984240 Jul  6 17:21 2021-07-06_17-21_objects.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker 681146 Jul  6 17:36 2021-07-06_17-36_states.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker   3487 Jul  6 18:41 2021-07-06_18-41_objects.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker 681758 Jul  6 19:01 2021-07-06_19-01_states.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker   3491 Jul  6 19:03 2021-07-06_19-03_objects.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker 681483 Jul  6 19:04 2021-07-06_19-04_states.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker   3491 Jul  6 19:05 2021-07-06_19-05_objects.json.gz
                                        -rwxrwxrwx+ 1 iobroker iobroker 681482 Jul  6 19:06 2021-07-06_19-06_states.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker   6790 Jul  6 19:37 2021-07-06_19-37_objects.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker 681474 Jul  6 19:37 2021-07-06_19-37_states.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker   6790 Jul  6 19:42 2021-07-06_19-42_objects.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker 681484 Jul  6 19:43 2021-07-06_19-43_states.json.gz
                                        -rw-rw-r--+ 1 iobroker iobroker 684488 Jul  6 20:06 2021-07-06_20-06_objects.json.gz
                                        -rw-rw-r--+ 1 iobroker iobroker 682204 Jul  6 20:06 2021-07-06_20-06_states.json.gz
                                        -rw-rw-r--+ 1 iobroker iobroker 684596 Jul  6 20:13 2021-07-06_20-13_objects.json.gz
                                        -rw-rw-r--+ 1 iobroker iobroker 682357 Jul  6 20:13 2021-07-06_20-13_states.json.gz
                                        Sagt das was aus?
                                        Ich habe außerdem über Backitup vor einer Woche ein Backup gemacht.
                                        Weiß einer wie ich das vielleicht wiederherstellen könnte?
                                        Thomas Braun Berserker Homoran F 4 Replies Last reply Reply Quote 0
                                          @berserker
                                          ist die letzte intakte Datei. Die nächste ist kaputt.
                                          • Berserker
                                            @berserker
                                            Ich kann sogar Adapter, die vorher installiert waren Updaten.
                                            Dann ist doch noch nicht alles verloren oder?
                                            $ ./iobroker upgrade backitup
                                            Update backitup from @2.1.11 to @2.1.13
                                            NPM version: 6.14.12
                                            npm install iobroker.backitup@2.1.13 --loglevel error --prefix "/opt/iobroker" (System call)
                                            ../authenticate_pam.cc: In function ‘void after_doing_auth(uv_work_t*, int)’:
                                            ../authenticate_pam.cc:107:87: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]   Nan::MakeCallback(Nan::GetCurrentContext()->Global(), Nan::New(m->callback), 1, args);        ^In file included from ../authenticate_pam.cc:23:../../nan/nan.h:1026:46: note: declared here   NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(                                              ^~~~~~~~~~~~
                                            ../authenticate_pam.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE Authenticate(Nan::NAN_METHOD_ARGS_TYPE)’:
                                            ../authenticate_pam.cc:147:83: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]   Local<Value> res = options->Get(Nan::New<String>("serviceName").ToLocalChecked());        ^In file included from /home/iobroker/.cache/node-gyp/12.22.1/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.22.1/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:3553:51: note: declared here
                                               V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));                                                   ^~~/home/iobroker/.cache/node-gyp/12.22.1/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../authenticate_pam.cc:150:69: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’    serviceName->WriteUtf8(m->serviceName, sizeof(m->serviceName) - 1);        ^In file included from /home/iobroker/.cache/node-gyp/12.22.1/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,       ^~~~~~~~~
                                            /home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’../authenticate_pam.cc:152:69: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                               res = options->Get(Nan::New<String>("remoteHost").ToLocalChecked());        ^In file included from /home/iobroker/.cache/node-gyp/12.22.1/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.22.1/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:3553:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));                                                   ^~~/home/iobroker/.cache/node-gyp/12.22.1/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../authenticate_pam.cc:155:66: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’    remoteHost->WriteUtf8(m->remoteHost, sizeof(m->remoteHost) - 1);        ^
                                            In file included from /home/iobroker/.cache/node-gyp/12.22.1/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,       ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’
                                            ../authenticate_pam.cc:160:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’  username->WriteUtf8(m->username, sizeof(m->username) - 1);                                                          ^In file included from /home/iobroker/.cache/node-gyp/12.22.1/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,       ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’../authenticate_pam.cc:161:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’  password->WriteUtf8(m->password, sizeof(m->password) - 1);                                                          ^
                                            ../authenticate_pam.cc: At global scope:../authenticate_pam.cc:170:11: error: variable or field ‘init’ declared void void init(Handle<Object> exports) {           ^~~~~~
                                            ../authenticate_pam.cc:170:11: error: ‘Handle’ was not declared in this scope
                                            ../authenticate_pam.cc:170:11: note: suggested alternative: ‘rand_r’
                                             void init(Handle<Object> exports) {           ^~~~~~           rand_r../authenticate_pam.cc:170:24: error: expected primary-expression before ‘>’ token void init(Handle<Object> exports) {                        ^
                                            ../authenticate_pam.cc:170:26: error: ‘exports’ was not declared in this scope void init(Handle<Object> exports) {                          ^~~~~~~
                                            In file included from ../../nan/nan.h:56,
                                                             from ../authenticate_pam.cc:23:../authenticate_pam.cc:175:31: error: ‘init’ was not declared in this scope NODE_MODULE(authenticate_pam, init);                               ^~~~/home/iobroker/.cache/node-gyp/12.22.1/include/node/node.h:736:36: note: in definition of macro ‘NODE_MODULE_X’       (node::addon_register_func) (regfunc),                          \                                    ^~~~~~~../authenticate_pam.cc:175:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(authenticate_pam, init); ^~~~~~~~~~~
                                            ../authenticate_pam.cc:175:31: note: suggested alternative: ‘int’
                                            make: *** [authenticate_pam.target.mk:109: Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
                                            gyp ERR! build error
                                            gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
                                            gyp ERR! stack     at ChildProcess.emit (events.js:314:20)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)gyp ERR! System Linux 5.10.17-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pamgyp ERR! node -v v12.22.1gyp ERR! node-gyp -v v5.1.0
                                            gyp ERR! not ok
                                            upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                                            upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                                            upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                                            upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                                            upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                                            upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                                            upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                                            upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                                            upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                                            upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                                            Adapter "backitup" updated
                                            process exited with code 0
                                            Das ist jetzt aber eine Ausgabe aus diesem Fenster:
                                            3337
