    4. [gelöst] Stromausfall Web-Oberfläche öffnet sich nicht mehr
      Homoran Global Moderator Administrators @Berserker last edited by
      @berserker sagte in Stromausfall Web-Oberfläche öffnet sich nicht mehr:
      Cannot read system.config: null (OK when migrating or restoring)
      Da gibt's Arbeit für das Mini HowTo
      • Berserker
        Berserker @Thomas Braun last edited by
        @thomas-braun said in Stromausfall Web-Oberfläche öffnet sich nicht mehr:
        iobroker add admin
        pi@pi:/opt/iobroker $ iobroker add admin
        host.pi install adapter admin
        upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
        upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
        upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
        upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
        host.pi object system.adapter.admin created/updated
        host.pi create instance admin
        host.pi object admin.0.info.newsETag created
        host.pi object admin.0.info.newsfeed created
        host.pi object admin.0.connected created
        host.pi object admin.0 created
        host.pi object admin.0.info created
        host.pi object system.adapter.admin.upload created
        host.pi object system.adapter.admin.0.logLevel created
        host.pi object system.adapter.admin.0.sigKill created
        host.pi object system.adapter.admin.0.eventLoopLag created
        host.pi object system.adapter.admin.0.outputCount created
        host.pi object system.adapter.admin.0.inputCount created
        host.pi object system.adapter.admin.0.uptime created
        host.pi object system.adapter.admin.0.memRss created
        host.pi object system.adapter.admin.0.memHeapTotal created
        host.pi object system.adapter.admin.0.memHeapUsed created
        host.pi object system.adapter.admin.0.cputime created
        host.pi object system.adapter.admin.0.cpu created
        host.pi object system.adapter.admin.0.compactMode created
        host.pi object system.adapter.admin.0.connected created
        host.pi object system.adapter.admin.0.alive created
        host.pi object system.adapter.admin.0 created
        Thomas Braun Berserker 2 Replies Last reply Reply Quote 0
          Thomas Braun Most Active @Berserker last edited by
          @berserker
          Läuft der Admin jetzt?
          iobroker list instances
          Berserker 1 Reply Last reply Reply Quote 0
          • Berserker
            Berserker @Berserker last edited by
            @berserker
            Die Web Oberfläche ist wieder da.
            Ich lass erstmal die Finger weg bis du etwas dazu sagst.
            • Berserker
              pi@pi:/opt/iobroker $ iobroker list instances
              + system.adapter.admin.0                  : admin                 : pi                                       -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              + instance is alive
              Das kommt dabei raus
                @berserker Dann solltest du jetzt die fehlenden Adapter ja nachinstallieren können.
                Berserker 2 Replies Last reply Reply Quote 1
                • Berserker
                  Wenn ich jetzt die fehlenden Adapter nachinstalliert, sind die Settings dann noch da ??
                  Vielen Dank erstmal
                  • Berserker
                    Wenn ich Adapter installieren möchte, dann steht bei den Adaptern die ich hatte, dass schon einer Installiert ist.
                    Kann ich zB. den Skripte Adapter irgendwie mit den alten Skripten herunterladen?
                    • Berserker
                      @berserker
                      So wie hier
                        @berserker Vermutlich so einfach nicht.
                        Du kannst jetzt Mal nach dem
                        https://forum.iobroker.net/topic/43325/mini-howto-cannot-find-view-system-for-search-host?_=1625594165671
                        versuchen die alten Einstellungen herbeizaubern.
                          @berserker
                          Und ein
                          iobroker stop
                          iobroker fix
                          kann auch nicht Schaden.
                          • Berserker
                            Hab ich getan
                            Eine frage:
                            Der Post den du mir verlinkt hast ist doch nur um den Iobroker wieder an laufen zu bekommen oder?
                            Ich wüsste nicht an welcher Stelle ich da jetzt einsteigen müsste.
                            Wäre dankbar wenn du mir noch einmal helfen könntest.
                            Und könnte es sein das die Daten noch da sind, da ja mir angezeigt wird das die Instanzen installiert sind. Ich kann sie im der Instanzen Liste und in den Objekten nur leider nicht sehen.
                              @berserker
                              Du kannst probieren per
                              iobroker upload all
                              Oder aus dem Mini-HowTo deine alten states und objects wieder herstellen.
                              • Berserker
                                pi@pi:/opt/iobroker $ iobroker upload all
                                upload [80] info.admin /opt/iobroker/node_modules/iobroker.info/admin/words.js words.js application/javascript
                                upload [70] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/hostInfo.js lib/js/hostInfo.js application/javascript
                                upload [60] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/bootstrap.min.js lib/js/bootstrap.min.js application/javascript
                                upload [50] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/slackware.png lib/img/logos/slackware.png image/png
                                upload [40] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/manjaro.png lib/img/logos/manjaro.png image/png
                                upload [30] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/coreos.png lib/img/logos/coreos.png image/png
                                upload [20] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/disk.png lib/img/icons/disk.png image/png
                                upload [19] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/cpu.png lib/img/icons/cpu.png image/png
                                upload [18] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/battery.png lib/img/icons/battery.png image/png
                                upload [17] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/sechand.png lib/img/clock/sechand.png image/png
                                upload [16] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/minhand.png lib/img/clock/minhand.png image/png
                                upload [15] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/hourhand.png lib/img/clock/hourhand.png image/png
                                upload [14] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/clockface.png lib/img/clock/clockface.png image/png
                                upload [13] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.woff2 lib/fonts/fontawesome-webfont.woff2 font/woff2
                                upload [12] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.woff lib/fonts/fontawesome-webfont.woff font/woff
                                upload [11] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.ttf lib/fonts/fontawesome-webfont.ttf font/ttf
                                upload [10] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.svg lib/fonts/fontawesome-webfont.svg image/svg+xml
                                upload [9] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.eot lib/fonts/fontawesome-webfont.eot application/vnd.ms-fontobject
                                upload [8] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/FontAwesome.otf lib/fonts/FontAwesome.otf font/otf
                                upload [7] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/data/infoData.json lib/data/infoData.json application/json
                                upload [6] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/simplemde.min.css lib/css/simplemde.min.css text/css
                                upload [5] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/info.css lib/css/info.css text/css
                                upload [4] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/font-awesome.min.css lib/css/font-awesome.min.css text/css
                                upload [3] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/chartist.min.css lib/css/chartist.min.css text/css
                                upload [2] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
                                upload [1] info.admin /opt/iobroker/node_modules/iobroker.info/admin/info.png info.png image/png
                                upload [0] info.admin /opt/iobroker/node_modules/iobroker.info/admin/index_m.html index_m.html text/html
                                Update "system.adapter.info.0"
                                upload [4] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/words.js words.js application/javascript
                                upload [3] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/instruction.png instruction.png image/png
                                upload [2] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/index_m.html index_m.html text/html
                                upload [1] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/index.html index.html text/html
                                upload [0] hue.admin /opt/iobroker/node_modules/iobroker.hue/admin/hue.jpeg hue.jpeg image/jpeg
                                upload [13] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/words.js words.js application/javascript
                                upload [12] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/instruction.png instruction.png image/png
                                upload [11] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/index_m.html index_m.html text/html
                                upload [10] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                upload [9] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                upload [8] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                upload [7] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                upload [6] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                upload [5] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                upload [4] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                upload [3] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                upload [2] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                upload [1] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                upload [0] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/deconz.png deconz.png image/png
                                Update "system.adapter.deconz.0"
                                Update "system.adapter.admin.0"
                                Das kommt bei raus.
                                Ich finde irgendwie keinen Post indem etwas in dem Sinne zu finden ist
                                Abgesehen davon erstmal meinen Respekt und ein großes Danke für deine Hilfe!!
                                  am Anfang.
                                  weil es wahrsche7nlich die Datenbanken der Objekte ind States terschossen hat
                                  die stellst du mit der verlinkten Anleit6ng aus deren internen backups wieder her
                                  • Berserker
                                    Berserker @Homoran last edited by
                                    @homoran @homoran
                                    pi@pi:/opt/iobroker $ ls -la /opt/iobroker/iobroker-data/backup-objects/
                                    insgesamt 45036
                                    drwxrwxrwx+ 2 iobroker iobroker   4096 Jul  6 20:13 .
                                    drwxrwxrwx+ 8 iobroker iobroker   4096 Jul  6 20:22 ..
                                    -rwxrwxrwx+ 1 iobroker iobroker 978138 Jul  4 20:37 2021-07-04_20-37_objects.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker 585862 Jul  4 21:32 2021-07-04_21-32_states.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker 978121 Jul  4 22:37 2021-07-04_22-37_objects.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker 677255 Jul  4 23:32 2021-07-04_23-32_states.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker 978113 Jul  5 00:44 2021-07-05_00-44_objects.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker 667109 Jul  5 01:32 2021-07-05_01-32_states.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker 978111 Jul  5 02:44 2021-07-05_02-44_objects.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker 667112 Jul  5 03:32 2021-07-05_03-32_states.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker 978125 Jul  5 04:46 2021-07-05_04-46_objects.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker 718539 Jul  5 05:32 2021-07-05_05-32_states.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker 978141 Jul  5 06:54 2021-07-05_06-54_objects.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker 762710 Jul  5 07:33 2021-07-05_07-33_states.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker 978086 Jul  5 09:02 2021-07-05_09-02_objects.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker 762745 Jul  5 09:33 2021-07-05_09-33_states.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker 978115 Jul  5 11:02 2021-07-05_11-02_objects.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker 843746 Jul  5 11:33 2021-07-05_11-33_states.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker 978111 Jul  5 13:02 2021-07-05_13-02_objects.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker 675898 Jul  5 13:33 2021-07-05_13-33_states.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker 978111 Jul  5 15:03 2021-07-05_15-03_objects.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker 735153 Jul  5 15:34 2021-07-05_15-34_states.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker 978339 Jul  5 17:04 2021-07-05_17-04_objects.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker 760527 Jul  5 17:34 2021-07-05_17-34_states.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker 985171 Jul  5 19:04 2021-07-05_19-04_objects.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker 750921 Jul  5 19:34 2021-07-05_19-34_states.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker 985169 Jul  5 21:05 2021-07-05_21-05_objects.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker 749874 Jul  5 21:34 2021-07-05_21-34_states.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker 985157 Jul  5 23:05 2021-07-05_23-05_objects.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker 876184 Jul  5 23:34 2021-07-05_23-34_states.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker 985178 Jul  6 01:05 2021-07-06_01-05_objects.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker 876145 Jul  6 01:34 2021-07-06_01-34_states.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker 984256 Jul  6 03:15 2021-07-06_03-15_objects.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker 876278 Jul  6 03:34 2021-07-06_03-34_states.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker 984275 Jul  6 05:15 2021-07-06_05-15_objects.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker 876270 Jul  6 05:34 2021-07-06_05-34_states.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker 984292 Jul  6 07:16 2021-07-06_07-16_objects.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker 805282 Jul  6 07:34 2021-07-06_07-34_states.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker 984302 Jul  6 09:16 2021-07-06_09-16_objects.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker 810170 Jul  6 09:35 2021-07-06_09-35_states.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker 984304 Jul  6 11:16 2021-07-06_11-16_objects.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker 796188 Jul  6 11:35 2021-07-06_11-35_states.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker 984288 Jul  6 13:16 2021-07-06_13-16_objects.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker 650163 Jul  6 13:36 2021-07-06_13-36_states.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker 984294 Jul  6 15:16 2021-07-06_15-16_objects.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker 652989 Jul  6 15:36 2021-07-06_15-36_states.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker 984240 Jul  6 17:21 2021-07-06_17-21_objects.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker 681146 Jul  6 17:36 2021-07-06_17-36_states.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker   3487 Jul  6 18:41 2021-07-06_18-41_objects.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker 681758 Jul  6 19:01 2021-07-06_19-01_states.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker   3491 Jul  6 19:03 2021-07-06_19-03_objects.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker 681483 Jul  6 19:04 2021-07-06_19-04_states.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker   3491 Jul  6 19:05 2021-07-06_19-05_objects.json.gz
                                    -rwxrwxrwx+ 1 iobroker iobroker 681482 Jul  6 19:06 2021-07-06_19-06_states.json.gz
                                    -rw-rwxr--+ 1 iobroker iobroker   6790 Jul  6 19:37 2021-07-06_19-37_objects.json.gz
                                    -rw-rwxr--+ 1 iobroker iobroker 681474 Jul  6 19:37 2021-07-06_19-37_states.json.gz
                                    -rw-rwxr--+ 1 iobroker iobroker   6790 Jul  6 19:42 2021-07-06_19-42_objects.json.gz
                                    -rw-rwxr--+ 1 iobroker iobroker 681484 Jul  6 19:43 2021-07-06_19-43_states.json.gz
                                    -rw-rw-r--+ 1 iobroker iobroker 684488 Jul  6 20:06 2021-07-06_20-06_objects.json.gz
                                    -rw-rw-r--+ 1 iobroker iobroker 682204 Jul  6 20:06 2021-07-06_20-06_states.json.gz
                                    -rw-rw-r--+ 1 iobroker iobroker 684596 Jul  6 20:13 2021-07-06_20-13_objects.json.gz
                                    -rw-rw-r--+ 1 iobroker iobroker 682357 Jul  6 20:13 2021-07-06_20-13_states.json.gz
                                    Sagt das was aus?
                                    Ich habe außerdem über Backitup vor einer Woche ein Backup gemacht.
                                    Weiß einer wie ich das vielleicht wiederherstellen könnte?
                                    Thomas Braun Berserker Homoran F 4 Replies Last reply Reply Quote 0
                                      @berserker
                                      ist die letzte intakte Datei. Die nächste ist kaputt.
                                      • Berserker
                                        @berserker
                                        Ich kann sogar Adapter, die vorher installiert waren Updaten.
                                        Dann ist doch noch nicht alles verloren oder?
                                        $ ./iobroker upgrade backitup
                                        Update backitup from @2.1.11 to @2.1.13
                                        NPM version: 6.14.12
                                        npm install iobroker.backitup@2.1.13 --loglevel error --prefix "/opt/iobroker" (System call)
                                        ../authenticate_pam.cc: In function ‘void after_doing_auth(uv_work_t*, int)’:
                                        ../authenticate_pam.cc:107:87: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]   Nan::MakeCallback(Nan::GetCurrentContext()->Global(), Nan::New(m->callback), 1, args);        ^In file included from ../authenticate_pam.cc:23:../../nan/nan.h:1026:46: note: declared here   NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(                                              ^~~~~~~~~~~~
                                        ../authenticate_pam.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE Authenticate(Nan::NAN_METHOD_ARGS_TYPE)’:
                                        ../authenticate_pam.cc:147:83: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]   Local<Value> res = options->Get(Nan::New<String>("serviceName").ToLocalChecked());        ^In file included from /home/iobroker/.cache/node-gyp/12.22.1/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.22.1/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:3553:51: note: declared here
                                           V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));                                                   ^~~/home/iobroker/.cache/node-gyp/12.22.1/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../authenticate_pam.cc:150:69: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’    serviceName->WriteUtf8(m->serviceName, sizeof(m->serviceName) - 1);        ^In file included from /home/iobroker/.cache/node-gyp/12.22.1/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,       ^~~~~~~~~
                                        /home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’../authenticate_pam.cc:152:69: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                                           res = options->Get(Nan::New<String>("remoteHost").ToLocalChecked());        ^In file included from /home/iobroker/.cache/node-gyp/12.22.1/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.22.1/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:3553:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));                                                   ^~~/home/iobroker/.cache/node-gyp/12.22.1/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../authenticate_pam.cc:155:66: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’    remoteHost->WriteUtf8(m->remoteHost, sizeof(m->remoteHost) - 1);        ^
                                        In file included from /home/iobroker/.cache/node-gyp/12.22.1/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,       ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’
                                        ../authenticate_pam.cc:160:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’  username->WriteUtf8(m->username, sizeof(m->username) - 1);                                                          ^In file included from /home/iobroker/.cache/node-gyp/12.22.1/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,       ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’../authenticate_pam.cc:161:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’  password->WriteUtf8(m->password, sizeof(m->password) - 1);                                                          ^
                                        ../authenticate_pam.cc: At global scope:../authenticate_pam.cc:170:11: error: variable or field ‘init’ declared void void init(Handle<Object> exports) {           ^~~~~~
                                        ../authenticate_pam.cc:170:11: error: ‘Handle’ was not declared in this scope
                                        ../authenticate_pam.cc:170:11: note: suggested alternative: ‘rand_r’
                                         void init(Handle<Object> exports) {           ^~~~~~           rand_r../authenticate_pam.cc:170:24: error: expected primary-expression before ‘>’ token void init(Handle<Object> exports) {                        ^
                                        ../authenticate_pam.cc:170:26: error: ‘exports’ was not declared in this scope void init(Handle<Object> exports) {                          ^~~~~~~
                                        In file included from ../../nan/nan.h:56,
                                                         from ../authenticate_pam.cc:23:../authenticate_pam.cc:175:31: error: ‘init’ was not declared in this scope NODE_MODULE(authenticate_pam, init);                               ^~~~/home/iobroker/.cache/node-gyp/12.22.1/include/node/node.h:736:36: note: in definition of macro ‘NODE_MODULE_X’       (node::addon_register_func) (regfunc),                          \                                    ^~~~~~~../authenticate_pam.cc:175:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(authenticate_pam, init); ^~~~~~~~~~~
                                        ../authenticate_pam.cc:175:31: note: suggested alternative: ‘int’
                                        make: *** [authenticate_pam.target.mk:109: Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
                                        gyp ERR! build error
                                        gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
                                        gyp ERR! stack     at ChildProcess.emit (events.js:314:20)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)gyp ERR! System Linux 5.10.17-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pamgyp ERR! node -v v12.22.1gyp ERR! node-gyp -v v5.1.0
                                        gyp ERR! not ok
                                        upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                                        upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                                        upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                                        upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                                        upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                                        upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                                        upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                                        upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                                        upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                                        upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                                        Adapter "backitup" updated
                                        process exited with code 0
                                        Das ist jetzt aber eine Ausgabe aus diesem Fenster:
                                          Homoran Global Moderator Administrators @Berserker last edited by Homoran
                                          ich denke du hast keins.
                                          da ich so Dumm war und kein Back-UP gemacht habe
                                          was gilt denn jetzt.
                                          wenn wir damit rumspielen existiert gar keine Chance mehr, das defekte zu retten!
                                          natürlich über backitup, aber wie gesagt ist danach die alte Version auf gar keinen Fall mehr wiederherzustellen.
                                          Sagt das was aus?
                                          wann war der Stromausfall?
                                          ich tippe mal 17:36
                                            lass doch endlich das rumspielen, oder willst du alles endgültig überschreiben?
                                            3339
