    4. [gelöst] Stromausfall Web-Oberfläche öffnet sich nicht mehr
    • Berserker
      Berserker @Berserker last edited by
      @berserker
      Ich kann sogar Adapter, die vorher installiert waren Updaten.
      Dann ist doch noch nicht alles verloren oder?
      $ ./iobroker upgrade backitup
      Update backitup from @2.1.11 to @2.1.13
      NPM version: 6.14.12
      npm install iobroker.backitup@2.1.13 --loglevel error --prefix "/opt/iobroker" (System call)
      ../authenticate_pam.cc: In function ‘void after_doing_auth(uv_work_t*, int)’:
      ../authenticate_pam.cc:107:87: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]   Nan::MakeCallback(Nan::GetCurrentContext()->Global(), Nan::New(m->callback), 1, args);        ^In file included from ../authenticate_pam.cc:23:../../nan/nan.h:1026:46: note: declared here   NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(                                              ^~~~~~~~~~~~
      ../authenticate_pam.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE Authenticate(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../authenticate_pam.cc:147:83: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]   Local<Value> res = options->Get(Nan::New<String>("serviceName").ToLocalChecked());        ^In file included from /home/iobroker/.cache/node-gyp/12.22.1/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.22.1/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:3553:51: note: declared here
         V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));                                                   ^~~/home/iobroker/.cache/node-gyp/12.22.1/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../authenticate_pam.cc:150:69: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’    serviceName->WriteUtf8(m->serviceName, sizeof(m->serviceName) - 1);        ^In file included from /home/iobroker/.cache/node-gyp/12.22.1/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,       ^~~~~~~~~
      /home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’../authenticate_pam.cc:152:69: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         res = options->Get(Nan::New<String>("remoteHost").ToLocalChecked());        ^In file included from /home/iobroker/.cache/node-gyp/12.22.1/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.22.1/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:3553:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));                                                   ^~~/home/iobroker/.cache/node-gyp/12.22.1/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../authenticate_pam.cc:155:66: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’    remoteHost->WriteUtf8(m->remoteHost, sizeof(m->remoteHost) - 1);        ^
      In file included from /home/iobroker/.cache/node-gyp/12.22.1/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,       ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’
      ../authenticate_pam.cc:160:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’  username->WriteUtf8(m->username, sizeof(m->username) - 1);                                                          ^In file included from /home/iobroker/.cache/node-gyp/12.22.1/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,       ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.22.1/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’../authenticate_pam.cc:161:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’  password->WriteUtf8(m->password, sizeof(m->password) - 1);                                                          ^
      ../authenticate_pam.cc: At global scope:../authenticate_pam.cc:170:11: error: variable or field ‘init’ declared void void init(Handle<Object> exports) {           ^~~~~~
      ../authenticate_pam.cc:170:11: error: ‘Handle’ was not declared in this scope
      ../authenticate_pam.cc:170:11: note: suggested alternative: ‘rand_r’
       void init(Handle<Object> exports) {           ^~~~~~           rand_r../authenticate_pam.cc:170:24: error: expected primary-expression before ‘>’ token void init(Handle<Object> exports) {                        ^
      ../authenticate_pam.cc:170:26: error: ‘exports’ was not declared in this scope void init(Handle<Object> exports) {                          ^~~~~~~
      In file included from ../../nan/nan.h:56,
                       from ../authenticate_pam.cc:23:../authenticate_pam.cc:175:31: error: ‘init’ was not declared in this scope NODE_MODULE(authenticate_pam, init);                               ^~~~/home/iobroker/.cache/node-gyp/12.22.1/include/node/node.h:736:36: note: in definition of macro ‘NODE_MODULE_X’       (node::addon_register_func) (regfunc),                          \                                    ^~~~~~~../authenticate_pam.cc:175:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(authenticate_pam, init); ^~~~~~~~~~~
      ../authenticate_pam.cc:175:31: note: suggested alternative: ‘int’
      make: *** [authenticate_pam.target.mk:109: Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
      gyp ERR! build error
      gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
      gyp ERR! stack     at ChildProcess.emit (events.js:314:20)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)gyp ERR! System Linux 5.10.17-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pamgyp ERR! node -v v12.22.1gyp ERR! node-gyp -v v5.1.0
      gyp ERR! not ok
      upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
      upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
      upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
      upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
      upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
      upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
      upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
      upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
      upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
      upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
      Adapter "backitup" updated
      process exited with code 0
      Das ist jetzt aber eine Ausgabe aus diesem Fenster:
        Homoran Global Moderator Administrators @Berserker last edited by Homoran
        @berserker sagte in Stromausfall Web-Oberfläche öffnet sich nicht mehr:
        Ich habe außerdem über Backitup vor einer Woche ein Backup gemacht.
        ich denke du hast keins.
        da ich so Dumm war und kein Back-UP gemacht habe
        was gilt denn jetzt.
        wenn wir damit rumspielen existiert gar keine Chance mehr, das defekte zu retten!
        Weiß einer wie ich das vielleicht wiederherstellen könnte?
        natürlich über backitup, aber wie gesagt ist danach die alte Version auf gar keinen Fall mehr wiederherzustellen.
        Sagt das was aus?
        wann war der Stromausfall?
        ich tippe mal 17:36
        Berserker 1 Reply Last reply Reply Quote 0
          lass doch endlich das rumspielen, oder willst du alles endgültig überschreiben?
            Fabian1 @Berserker last edited by
            @berserker said in Stromausfall Web-Oberfläche öffnet sich nicht mehr:
            @homoran @homoran
            pi@pi:/opt/iobroker $ ls -la /opt/iobroker/iobroker-data/backup-objects/
            insgesamt 45036
            drwxrwxrwx+ 2 iobroker iobroker   4096 Jul  6 20:13 .
            drwxrwxrwx+ 8 iobroker iobroker   4096 Jul  6 20:22 ..
            -rwxrwxrwx+ 1 iobroker iobroker 978138 Jul  4 20:37 2021-07-04_20-37_objects.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker 585862 Jul  4 21:32 2021-07-04_21-32_states.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker 978121 Jul  4 22:37 2021-07-04_22-37_objects.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker 677255 Jul  4 23:32 2021-07-04_23-32_states.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker 978113 Jul  5 00:44 2021-07-05_00-44_objects.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker 667109 Jul  5 01:32 2021-07-05_01-32_states.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker 978111 Jul  5 02:44 2021-07-05_02-44_objects.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker 667112 Jul  5 03:32 2021-07-05_03-32_states.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker 978125 Jul  5 04:46 2021-07-05_04-46_objects.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker 718539 Jul  5 05:32 2021-07-05_05-32_states.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker 978141 Jul  5 06:54 2021-07-05_06-54_objects.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker 762710 Jul  5 07:33 2021-07-05_07-33_states.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker 978086 Jul  5 09:02 2021-07-05_09-02_objects.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker 762745 Jul  5 09:33 2021-07-05_09-33_states.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker 978115 Jul  5 11:02 2021-07-05_11-02_objects.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker 843746 Jul  5 11:33 2021-07-05_11-33_states.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker 978111 Jul  5 13:02 2021-07-05_13-02_objects.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker 675898 Jul  5 13:33 2021-07-05_13-33_states.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker 978111 Jul  5 15:03 2021-07-05_15-03_objects.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker 735153 Jul  5 15:34 2021-07-05_15-34_states.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker 978339 Jul  5 17:04 2021-07-05_17-04_objects.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker 760527 Jul  5 17:34 2021-07-05_17-34_states.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker 985171 Jul  5 19:04 2021-07-05_19-04_objects.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker 750921 Jul  5 19:34 2021-07-05_19-34_states.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker 985169 Jul  5 21:05 2021-07-05_21-05_objects.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker 749874 Jul  5 21:34 2021-07-05_21-34_states.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker 985157 Jul  5 23:05 2021-07-05_23-05_objects.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker 876184 Jul  5 23:34 2021-07-05_23-34_states.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker 985178 Jul  6 01:05 2021-07-06_01-05_objects.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker 876145 Jul  6 01:34 2021-07-06_01-34_states.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker 984256 Jul  6 03:15 2021-07-06_03-15_objects.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker 876278 Jul  6 03:34 2021-07-06_03-34_states.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker 984275 Jul  6 05:15 2021-07-06_05-15_objects.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker 876270 Jul  6 05:34 2021-07-06_05-34_states.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker 984292 Jul  6 07:16 2021-07-06_07-16_objects.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker 805282 Jul  6 07:34 2021-07-06_07-34_states.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker 984302 Jul  6 09:16 2021-07-06_09-16_objects.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker 810170 Jul  6 09:35 2021-07-06_09-35_states.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker 984304 Jul  6 11:16 2021-07-06_11-16_objects.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker 796188 Jul  6 11:35 2021-07-06_11-35_states.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker 984288 Jul  6 13:16 2021-07-06_13-16_objects.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker 650163 Jul  6 13:36 2021-07-06_13-36_states.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker 984294 Jul  6 15:16 2021-07-06_15-16_objects.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker 652989 Jul  6 15:36 2021-07-06_15-36_states.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker 984240 Jul  6 17:21 2021-07-06_17-21_objects.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker 681146 Jul  6 17:36 2021-07-06_17-36_states.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker   3487 Jul  6 18:41 2021-07-06_18-41_objects.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker 681758 Jul  6 19:01 2021-07-06_19-01_states.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker   3491 Jul  6 19:03 2021-07-06_19-03_objects.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker 681483 Jul  6 19:04 2021-07-06_19-04_states.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker   3491 Jul  6 19:05 2021-07-06_19-05_objects.json.gz
            -rwxrwxrwx+ 1 iobroker iobroker 681482 Jul  6 19:06 2021-07-06_19-06_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker   6790 Jul  6 19:37 2021-07-06_19-37_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 681474 Jul  6 19:37 2021-07-06_19-37_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker   6790 Jul  6 19:42 2021-07-06_19-42_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 681484 Jul  6 19:43 2021-07-06_19-43_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 684488 Jul  6 20:06 2021-07-06_20-06_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 682204 Jul  6 20:06 2021-07-06_20-06_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 684596 Jul  6 20:13 2021-07-06_20-13_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 682357 Jul  6 20:13 2021-07-06_20-13_states.json.gz
            Sagt das was aus?
            Warum machst du dir dann überhaupt die ganze Arbeit?!?! 😂
            Sag das doch gleich! Wo hast du das backup denn gespeichert? Mach die Karte einfach Platt, installier den IOBroker komplett neu und spiel das Backup ein! Das dauert keine 30 Minuten und geht meist deutlich schneller als stundenlang Fehler zu suchen. Selbst wenn du es jetzt wieder zum laufen kriegst, da scheint einiges im Argen zu liegen. Nimm ein frisches System, backup rein, fertig!
            Berserker Homoran 2 Replies Last reply Reply Quote 0
            • Berserker
              Berserker @Homoran last edited by
              tut mir Leid
              Back Up wurde auf jedenfall erstellt, nachdem ich das letzte mal das selbe problem hatte
              Stromausfall war heute gegen 18:00
              • Berserker
                Berserker @Fabian1 last edited by
                @fabian1
                Ich habe das Backup auf Backitup einfach auf Lokal gespeichert. Ich weiß nicht wo der das dann abspeichert??
                  ich tippe gegen 17:36
                  die Daten davor müsstest du nach HowTo wieder herstellen
                  • Berserker
                    Okay werde ich gleich mal versuchen
                    Ich melde mich dann wenn etwas bei rausgekommen ist
                      Homoran Global Moderator Administrators @Fabian1 last edited by
                      @fabian1 sagte in Stromausfall Web-Oberfläche öffnet sich nicht mehr:
                      ich befürchte nach all den Fragen, dass er backitup ggf. nicht vollständig konfiguriert hat.
                      und wenn es auf der Karte liegt kann es auch einen Schuss haben.
                      das sollten wir als letzte Möglichkeit zur Reserve haben.
                      so ein Restore der Datenbankbackups ist in 5-10 Minuten etledigt, dann wissen wir mehr
                        nimm die backups von
                          Thomas Braun Most Active @Berserker last edited by
                          Was dann eigentlich gleichbedeutend mit 'Ich hab keins' ist. Backups auf dem gleichen Speichermedium sind nur äußerst begrenzt sinnvoll. Ein Backup sichert man nach extern weg.
                          • Berserker
                            Berserker @Thomas Braun last edited by
                            Ich habe jetzt das Mini-HowTo befolgt und es hat echt geklappt.
                            Ich danke allen die mir hier geholfen haben, vor allem dir Thomas!!!!!!
                            Kann mir vlt. einer einen Tipp geben wie ich am besten ein back-Up erstellen kann für die Zukunft?
                            DANKE DANKE DANKE
                            Thomas Braun F Homoran 3 Replies Last reply Reply Quote 0
                              @berserker Am besten mit dem Backitup-Adapter. Der schaufelt bei mir jede Nacht ein Backup auf ein NAS (FritzBox) und bei Google Drive rauf.
                                @berserker Super dass es geklappt hat!
                                Und für die Zukunft mach es wie @Thomas-Braun schon gesagt hat! Backitup Adapter jede Nacht auf Dropbox oder Google Drive und wenn sowas dann das nächste Mal passiert. Zack Karte Platt machen, IObroker neu aufspielen, Backup auf der Dropbox drauf, fertig! Das spart jede menge Zeit und Nerven. 🙂
                                Berserker 1 Reply Last reply Reply Quote 1
                                • Berserker
                                  @fabian1 Dankeschön !!!
                                  So wird es gemacht!!!
                                    @berserker sagte in [gelöst] Stromausfall Web-Oberfläche öffnet sich nicht mehr:
                                    ach was!?
                                    sonst hätte ichdas nicht direkt zu Beginn gesagt
                                    @homoran sagte in [gelöst] Stromausfall Web-Oberfläche öffnet sich nicht mehr:
                                    Cannot read system.config: null (OK when migrating or restoring)
                                    Da gibt's Arbeit für das Mini HowTo
                                    • Berserker
                                      Eine kleine Frage habe ich noch
                                      Und zwar habe ich jetzt ein Back up in Google drive erstellt und ich finde irgendwie komisch das außer dem eufy Adapter und den Standard Adaptern (Info, Admin) keine weiteren Auftauchen
                                      Muss man in den Einstellungen irgendetwas spezielles beachten ?
                                      • Berserker
                                        @berserker 03D6CE09-A0BF-48D7-877A-4A5B7C34B354.png A2A03684-2741-4F67-86B0-E2306AF8908B.png
                                        Da sind halt keine Objekte drin teilweise
                                          @berserker
                                          Keine Ahnung wo du da bist. Das Backup nennt sich iobroker-Zeitstempel-backup.tar.gz oder ähnlich.
                                            du bist ja auch nicht im eigentlichen Backup sondern nur in den zusätzlichen Files
                                            3340
