    4. Backup / Restore von Raspberry Pi auf Synology [gelöst]
    • Z
      ZoXx @ZoXx last edited by
      @da_Woody backup ist durchgelaufen, kann jedoch den Container nicht mehr auflösen.
      Folgende Fehlermeldung in Chrome: ERR_EMPTY_RESPONSE
      Ich kopiere mal den Log:
      2021-07-07 20:07:29.311  - info: host.IoBroker received SIGTERM
      2021-07-07 20:07:29.318  - info: admin.0 (110) terminating http server on port 8081
      2021-07-07 20:07:29.319  - info: info.0 (152) cleaned everything up...
      2021-07-07 20:07:29.332  - info: backitup.0 (629) cleaned everything up...
      2021-07-07 20:07:29.331  - info: host.IoBroker stopInstance system.adapter.admin.0 (force=false, process=true)
      2021-07-07 20:07:29.332  - info: host.IoBroker stopInstance system.adapter.discovery.0 (force=false, process=true)
      2021-07-07 20:07:29.334  - info: host.IoBroker stopInstance system.adapter.info.0 (force=false, process=true)
      2021-07-07 20:07:29.336  - info: host.IoBroker stopInstance system.adapter.backitup.0 (force=false, process=true)
      2021-07-07 20:07:29.352  - info: admin.0 (110) Got terminate signal TERMINATE_YOURSELF
      2021-07-07 20:07:29.355  - info: info.0 (152) Got terminate signal TERMINATE_YOURSELF
      2021-07-07 20:07:29.354  - info: discovery.0 (125) Got terminate signal TERMINATE_YOURSELF
      2021-07-07 20:07:29.356  - info: backitup.0 (629) Got terminate signal TERMINATE_YOURSELF
      2021-07-07 20:07:29.362  - info: discovery.0 (125) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-07-07 20:07:29.363  - info: host.IoBroker stopInstance system.adapter.admin.0 send kill signal
      2021-07-07 20:07:29.364  - info: info.0 (152) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-07-07 20:07:29.365  - info: admin.0 (110) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-07-07 20:07:29.366  - debug: backitup.0 (629) Plugin sentry destroyed
      2021-07-07 20:07:29.367  - info: backitup.0 (629) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-07-07 20:07:29.401  - info: host.IoBroker stopInstance system.adapter.discovery.0 send kill signal
      2021-07-07 20:07:29.402  - info: host.IoBroker stopInstance system.adapter.info.0 send kill signal
      2021-07-07 20:07:29.403  - info: host.IoBroker stopInstance system.adapter.backitup.0 send kill signal
      2021-07-07 20:07:30.224  - info: host.IoBroker instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2021-07-07 20:07:30.275  - info: host.IoBroker instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2021-07-07 20:07:30.278  - info: host.IoBroker instance system.adapter.info.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2021-07-07 20:07:30.279  - info: host.IoBroker instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2021-07-07 20:07:30.280  - info: host.IoBroker All instances are stopped.
      2021-07-07 20:07:30.374  - info: host.IoBroker terminated
      2021-07-07 20:35:29.873  - info: host.98f3f68508a4 iobroker.js-controller version 3.2.16 js-controller starting
      2021-07-07 20:35:29.883  - info: host.98f3f68508a4 Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
      2021-07-07 20:35:29.884  - info: host.98f3f68508a4 hostname: 98f3f68508a4, node: v12.22.1
      2021-07-07 20:35:29.886  - info: host.98f3f68508a4 ip addresses: 172.17.0.6
      2021-07-07 20:35:30.785  - info: host.98f3f68508a4 connected to Objects and States
      2021-07-07 20:35:30.901  - info: host.98f3f68508a4 added notifications configuration of host
      2021-07-07 20:35:31.880  - info: host.98f3f68508a4 Delete host system.host.IoBroker
      2021-07-07 20:35:31.981  - info: host.98f3f68508a4 28 instances found
      2021-07-07 20:35:32.016  - warn: host.98f3f68508a4 does not start any instances on this host
      • Glasfaser
        Glasfaser @ZoXx last edited by Glasfaser
        @zoxx sagte in Backup / Restore von Raspberry Pi auf Synology:
        Mach nochmal :
        pkill -u iobroker
        iobroker host this
        und danach den Container neu starten .
        EDIT :
        was ist das denn , hast du so ein Netzwerk :
        Thomas Braun Z 2 Replies Last reply Reply Quote 0
          Thomas Braun Most Active @Glasfaser last edited by
          @glasfaser Extravagant, aber ein zugelassener Private IP-Bereich.
          • Z
            ZoXx @Glasfaser last edited by
            @glasfaser said in Backup / Restore von Raspberry Pi auf Synology:
        pkill -u iobroker        iobroker host this
            Anbei der Log als Screenhot.
            EDIT :
            Negativ, stammt evtl. vom Docker selbst?
            • Glasfaser
              Was negativ ?
              Keine Ahnung was du da hast ,
              Welche IP hat denn deine Syn , hast du die gleiche dann für ioBroker , oder hast du was anderes eingestellt .
              Nutzt du Host oder Bridge-Modus .
              Funktioniert jetzt ioBroker ?
              • Z
                Was negativ ?
                Nein, die IP-Adresse nutze ich nicht und kenne ich auch nicht.
                Meine IP-Adresse fängt mit 192.168. ... an.
                Die anderen Container lösen diese auch sauber auf. IoBroker lief bis zum Restore damit ja selbst auch.
                Ich nutze den bridge Modus mit festen zugeordneten Ports.
                Nein, gleicher Fehler wie oben.
                Glasfaser 2 Replies Last reply Reply Quote 0
                • Glasfaser
                  @zoxx
                  Zeige mal :
                  which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                  iobroker update -i
                  iobroker list instances
                  iobroker list adapters
                  iobroker version
                  • Z
                    which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs iobroker update -i iobroker list instances iobroker list adapters iobroker version
                    Guten Morgen zusammen,
                    sind ein paar Screenshots mehr.
                    Was mich wundert, dass einigen Instanzen als "disabled" stehen?
                    Hier die Bilder:
                    Viele Grüße
                    • Glasfaser
                      Die aktuelle wäre Interessant .
                      Das heißt du , bekommst kein zugriff auf Admin 8081 .
                      Mache mal :
                      iobroker upload all
                      INFO:
                      Bitte keine Screenshot , Ausgabe in </> code-tags
                      was sagt
                      iobroker status
                      • Z
                        iobroker upload all
                        Stop!!!!
                        Habe es gerade noch einmal probiert, es läuft nun!!! 🙂
                        Kann man sagen, woran es nun gescheitert ist vorher?
                        Vielen vielen Dank erst einmal!!!
                        • Glasfaser
                          Ich denke mal du warst zu ungeduldig , denn das Backup ist minimal ist auch gut so , denn alle Adapter werden dann nachinstalliert und das dauert nun mal mit der Restore .
                          da_Woody Z 2 Replies Last reply Reply Quote 0
                          • da_Woody
                            da_Woody @Glasfaser last edited by
                            @glasfaser sagte in Backup / Restore von Raspberry Pi auf Synology:
                            und das kann stunden dauern... kommt halt auf die menge der adapter an.
                            • Z
                              Okay. Heißt einfach der restore dauert in der Regel sehr lang und ich habe es zu "früh" probiert?
                              • da_Woody
                                da_Woody @ZoXx last edited by
                                @zoxx sieht so aus... 🙂
                                • Glasfaser
                                  , es läuft nun!!!
                                  Dann setzte den Thread auf [gelöst]
                                  2192
