    4. Test Adapter enigma2 v1.2.x
    • Meister Mopper
      Meister Mopper @Negalein last edited by
      @negalein
      Wird denn der Adapter überhaupt noch betreut?
      Matten Matten 1 Reply Last reply Reply Quote 0
      • Matten Matten
        Matten Matten @Negalein last edited by
        @negalein sagte in Test Adapter enigma2 v1.2.x:
        Ich bekomm seit JS-Controller 3.3.14 laufend solche Meldungen.
        enigma2.0 | 2021-07-08 16:04:56.849 | info | State value to set for "enigma2.0.enigma2.EVENTREMAINING" has to be type "number" but received type "string"
        enigma2.0 | 2021-07-08 16:04:56.848 | info | State value to set for "enigma2.0.enigma2.EVENTDURATION" has to be type "number" but received type "string"
        enigma2.0 | 2021-07-08 16:04:56.844 | info | State value to set for "enigma2.0.enigma2.MESSAGE_ANSWER" has to be type "integer" but received type "string"
        Bitte den Adapter neu installieren.
        • Matten Matten
          Matten Matten @Meister Mopper last edited by
          Nicht aktiv, nein
          • Negalein
            Negalein Global Moderator @Matten Matten last edited by Negalein
            @matten-matten sagte in Test Adapter enigma2 v1.2.x:
            Das wars.
            Nun kommt aber was neues.
            enigma2.0 2021-07-08 16:58:08.319	warn	State "enigma2.0.enigma2.HDD_FREE" has no existing object, this might lead to an error in future versions
            enigma2.0 2021-07-08 16:58:08.319	warn	State "enigma2.0.enigma2.HDD_CAPACITY" has no existing object, this might lead to an error in future versions
            enigma2.0 2021-07-08 16:57:47.334	warn	State "enigma2.0.enigma2.MOVIE_LIST" has no existing object, this might lead to an error in future versions
            enigma2.0 2021-07-08 16:57:43.350	info	enigma2 Verbunden!
            enigma2.0 2021-07-08 16:57:38.304	warn	State "enigma2.0.enigma2-CONNECTION" has no existing object, this might lead to an error in future versions
            enigma2.0 2021-07-08 16:57:38.303	warn	State "enigma2.0.Message.Timeout" has no existing object, this might lead to an error in future versions
            enigma2.0 2021-07-08 16:57:38.303	warn	State "enigma2.0.Message.Type" has no existing object, this might lead to an error in future versions
            enigma2.0 2021-07-08 16:57:38.284	info	starting Polling every 5000 ms
            enigma2.0 2021-07-08 16:57:38.261	info	starting. Version 1.3.3 in /opt/iobroker/node_modules/iobroker.enigma2, node: v14.17.1, js-controller: 3.3.14
            Matten Matten J 2 Replies Last reply Reply Quote 0
            • Matten Matten
              Das wars.
              Hast du die Instanzen vorher einmal gelöscht. Dann den Adapter neu installieren dann am besten ein Upload und die Instanzen neu anlegen.
              Gruß.
              Negalein oberfragger 2 Replies Last reply Reply Quote 1
                Jan1 @Negalein last edited by Jan1
                @negalein
                Greif mal auf die HDD zu, wenn die schläft bekommt der Adapter keine Daten 😉
                • Negalein
                  Nein.
                  Hab den Adapter gelöscht, installiert und Instanz erzeugt.
                  Hab nochmal einen Upload gemacht. Funktioniert! 🙂
                  Wo kommt der leere Admin Ordner her? Ist der eventuell noch von vorher?
                  Kann ich den löschen oder hat er eine Funktion?
                    @negalein
                    Einen leeren Admin Ordner habe ich bei jedem Adapter in den Objekten.
                    • Negalein
                      Negalein Global Moderator @Jan1 last edited by
                      @jan1 sagte in Test Adapter enigma2 v1.2.x:
                      stimmt. Hab gerade nachgeschaut.
                      Wird wohl mit Admin 5 zusammenhängen.
                        @negalein
                        Seit dem Umstieg sind die zumindest mal da. Was das soll frage ich mich aber auch. Da es nicht wirklich stört, wird es aber auch ein Sinn haben.
                        Hatte übrigens die selben Meldungen wie Du im Log wegen der HDD und erst nach dem ich die aus dem Sleep geholt hatte und der Adapter die Werte lesen konnte war Ruhe.
                        • oberfragger
                          oberfragger @Matten Matten last edited by
                          @matten-matten said in Test Adapter enigma2 v1.2.x:
                          Moin,
                          ich habe das so gemacht wie beschrieben. Vor der Neuinstallation der Instanzen noch die Objekte gelöscht. Leider bekomme ich noch folgendes:
                          enigma2.0
                          2021-08-10 22:20:22.561	warn	State "enigma2.0.enigma2.MOVIE_LIST" has no existing object, this might lead to an error in future versions
                          enigma2.0
                          2021-08-10 22:20:15.151	warn	State "enigma2.0.enigma2-CONNECTION" has no existing object, this might lead to an error in future versions
                          enigma2.0
                          2021-08-10 22:20:15.150	warn	State "enigma2.0.Message.Timeout" has no existing object, this might lead to an error in future versions
                          enigma2.0
                          2021-08-10 22:20:15.150	warn	State "enigma2.0.Message.Type" has no existing object, this might lead to an error in future versions
                            Hat sich eigentlich inzwischen ein Maintainer für den enigma2 Adapter gefunden?
                            Für admin 5 müsste da was angepasst werden
                            T 1 Reply Last reply Reply Quote 3
                              TiDO @Homoran last edited by
                              bekomme aktuell folgende Fehler:
                              enigma2.0
                              	2021-09-02 21:52:58.817	info	State value to set for "enigma2.0.enigma2.MESSAGE_ANSWER" has to be type "integer" but received type "string"
                              enigma2.0
                              	2021-09-02 21:52:53.832	info	State value to set for "enigma2.0.enigma2.EVENTREMAINING" has to be type "number" but received type "string"
                              enigma2.0
                              	2021-09-02 21:52:53.829	info	State value to set for "enigma2.0.enigma2.EVENTDURATION" has to be type "number" but received type "string"
                              enigma2.0
                              	2021-09-02 21:52:53.813	info	State value to set for "enigma2.0.enigma2.MESSAGE_ANSWER" has to be type "integer" but received type "string"
                              jemand eine Idee?
                              liegt das am js-controller 3.3.15?
                              • Glasfaser
                                Glasfaser @TiDO last edited by
                                @tido
                                Alle Datenpunkte vom enigma löschen und den Adapter neu installieren
                                https://forum.iobroker.net/topic/25112/test-adapter-enigma2-v1-2-x/441
                                  biker1602 @Glasfaser last edited by
                                  Ich habe mich jetzt auch mal, mit dem Adapter beschäftigt um mit einem Blockly zu arbeiten.
                                  Ich habe eine VU+Duo2 mit Open ATV Image, und es wird mir unter Objekte alles angezeigt, aber mein Problem ist, zum einen, dass ich die Box zwar in den DeepStandby versetzen kann, aber nicht wieder eingeschaltet bekomme. Es stehen ja auch nur die Werte true und false zur Verfügung, die sich automatisch auch nicht ändern.
                                  Das macht mich irgendwie stutzig. Kann mir da jemand helfen?
                                  E B SBorg 3 Replies Last reply Reply Quote 0
                                    el_malto @biker1602 last edited by
                                    @biker1602 beim DeepStandby wird der Receiver komplett heruntergefahren. Sprich, es ist auch kein Netzwerk mehr verfügbar und somit kannst du den Receiver darüber nicht aus dem DeppStandby holen. Das geht dann nur noch mit der Fernbedienung. Wenn du den Receiver immer über ioBroker steuern willst, musst du den nur in den normalen Standby schicken.
                                    Als abhilfe könnte hier vielleicht so eine Logitech Harmony sein? Weiß nicht ob man die quasi als "Brücke" nehmen kann.
                                      bombaman @biker1602 last edited by
                                      @biker1602 Du kannst über eine schaltbare Steckdose den Strom wegnehmen. Wenn du die dann wieder einschaltest dann startet der Receiver.
                                      • SBorg
                                        SBorg Forum Testing Most Active @biker1602 last edited by
                                        Hat die VU+Duo2 nicht WoL (was noch immer selbst bei der aktuellen DreamBox fehlt... 😞 ) ?
                                        @biker1602
                                        Hast du irgendwo was im Menü mit "Wake on LAN" (sorry, DreamBox-Nutzer 😉 ) ? Dann kannst du sie darüber aufwecken (bspw. "Magic Paket" per Blockly oä.).
                                        Atifan 1 Reply Last reply Reply Quote 0
                                        • Atifan
                                          Atifan @SBorg last edited by
                                          Duo2 weiß ich nicht, ich hab ne UNO 4K SE, die hat kein WOL.
                                          Man kann den Receiver entweder wie schon geschrieben über ne schaltbare Steckdose Wecken über Strom aus/an, oder über HDMI-CEC wenn man das TV ansteuern kann und das angeht, dass dann der Receiver angeschaltet wird. Oder über nen IR-Sender.
                                          • SBorg
                                            SBorg Forum Testing Most Active @Atifan last edited by
                                            @atifan ...und ich dachte schon nur die "Dreamer" schauen da in die Röhre... 😉
                                            Hier ist aber sogar eine Anleitung zur Einrichtung.
                                            adapter enigma2
                                            71
                                            640
                                            141841
