      MCU @MCU last edited by MCU
      @holzapfelauge
       <variables>
         <variable id="BW%9v~G}+|6BPI-mC^U~">X_completed</variable>
         <variable id="8SK,{_!3h?;v%0+=ZeUU">X_createdDateTime</variable>
         <variable id="rO9asU5s{Y2G@3IkL@g~">X_value</variable>
         <variable id="-gF.AQ8**.mG;]}U}aCI">NEW_JSON</variable>
         <variable id="MpCcK~ur_i5(;GNB}F?^">jsonitems</variable>
         <variable id="7huB30*E_mbam=Bi-D2z">select</variable>
         <variable id="W@MiB696qRDvf-aB*Cb1">i</variable>
         <variable id="dU=%0t3gDY!SaSObPx}I">ADD_select</variable>
       </variables>
       <block type="procedures_defcustomreturn" id="mxG_{B!Y/t/PJQkf4_^S" x="238" y="-663">
         <mutation statements="false">
           <arg name="X_completed" varid="BW%9v~G}+|6BPI-mC^U~"></arg>
           <arg name="X_createdDateTime" varid="8SK,{_!3h?;v%0+=ZeUU"></arg>
           <arg name="X_value" varid="rO9asU5s{Y2G@3IkL@g~"></arg>
         </mutation>
         <field name="NAME">JSON_ELEMENT</field>
         <field name="SCRIPT">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</field>
       <block type="create" id="G]R]no),5~HQ]rMcDMT(" x="237" y="-612">
         <field name="NAME">0_userdata.0.alexa.todo_json_jarvis</field>
           <block type="create" id="=)6?8)IqYQnQuesdU7UA">
             <field name="NAME">0_userdata.0.alexa.todo_select</field>
             <value name="COMMON">
               <block type="text_join" id="t%HpOTmWwv0}]!N=QK~2">
                 <mutation items="4"></mutation>
                 <value name="ADD0">
                   <block type="text" id="CQZ?#lk_wSG1Juk.E}!*">
                     <field name="TEXT">{"read": true,"write": true, </field>
                 <value name="ADD1">
                   <block type="text" id="@SE1f2TGhb)XwfKW1jAM">
                     <field name="TEXT">"type": "string","name": "Auswahl", </field>
                 <value name="ADD2">
                   <block type="text" id="/#-h~q~zfI|N_oXBwK,`">
                     <field name="TEXT"></field>
                 <value name="ADD3">
                   <block type="text" id="?:x8KxIyksC4;q*pMkSl">
                     <field name="TEXT">"states": {"all":"Alle","false":"Offene","true":"Erledigte"}}</field>
               <block type="on_ext" id="ZM4rstIXoN#mZ-2b2%iG">
                 <value name="OID0">
                   <shadow type="field_oid" id="!^G4~u8j[W6crS2yG6P`">
                     <field name="oid">alexa2.0.Lists.TO_DO.json</field>
                   <block type="procedures_callnoreturn" id="*8x-8sM$V;V1!qlyv#1s">
                     <mutation name="JSON_FÜR_JARVIS"></mutation>
                   <block type="on_ext" id="u:c:K(a.v=[lf5Y;.^gp">
                     <value name="OID0">
                       <shadow type="field_oid" id="EykUyR?a8C63eqTR@5%*">
                         <field name="oid">0_userdata.0.alexa.todo_select</field>
                       <block type="procedures_callnoreturn" id="LAP^y%R6t^IgBuhC$p#l">
       <block type="procedures_defnoreturn" id="}z{CqW-9zw2xWC*XwEPb" x="237" y="62">
         <field name="NAME">JSON_FÜR_JARVIS</field>
         <statement name="STACK">
           <block type="variables_set" id="]g$swJ*{2zi#DDIxG_*9">
             <field name="VAR" id="-gF.AQ8**.mG;]}U}aCI">NEW_JSON</field>
               <block type="lists_create_with" id="s=b/i.]d.{lIVezRf3G]">
               <block type="variables_set" id="B`W:^0^1rmhAz{G;3(=}">
                 <field name="VAR" id="MpCcK~ur_i5(;GNB}F?^">jsonitems</field>
                   <block type="convert_json2object" id="|Na{Lsyc[M~de-(U@Lo*">
                       <block type="get_value" id="^Qf/]g}*V1]-.;T/%AIY">
                         <field name="OID">alexa2.0.Lists.TO_DO.json</field>
                   <block type="variables_set" id="+{vBa^+a7]q#9p]?hMH7">
                     <field name="VAR" id="7huB30*E_mbam=Bi-D2z">select</field>
                       <block type="get_value" id="$tt:77/o}Y:xtjuJ6vZR">
                         <field name="OID">0_userdata.0.alexa.todo_select</field>
                       <block type="debug" id=")#p1xctd[CKaOi}fUfW)" disabled="true">
                         <value name="TEXT">
                           <shadow type="text" id="t-2b_e#0STem%wB/vwMS">
                           <block type="variables_get" id="q%U/3q~`p=5uyPE-eaAk">
                           <block type="controls_forEach" id="Jr]rCwGV4+ZJW|.JDFoh">
                             <field name="VAR" id="W@MiB696qRDvf-aB*Cb1">i</field>
                             <value name="LIST">
                               <block type="variables_get" id=",~mWGy{FpQD5@ncHG9uq">
                             <statement name="DO">
                               <block type="debug" id="|}P0#g}U6HB({/,$])lw" disabled="true">
                                 <value name="TEXT">
                                   <shadow type="text" id="+?}@}ZxJAsZN5TtPs{av">
                                   <block type="convert_jsonata" id="*8%E3s_lo)vJX{xu(5MF">
                                     <value name="EXPRESSION">
                                       <shadow type="text" id="(m+8t{gx1Kk@3Hzq8,jB">
                                         <field name="TEXT">completed</field>
                                     <value name="TARGET">
                                       <block type="variables_get" id="IDyoQxR)dt9M*[n3ShUo">
                                   <block type="variables_set" id="MMmJ=$3Av~;=8?:CLJ/?">
                                     <field name="VAR" id="dU=%0t3gDY!SaSObPx}I">ADD_select</field>
                                       <block type="logic_boolean" id="=hyUVhSs!A%-9jI+{DUM">
                                       <block type="controls_if" id="Kwi^{w?v/g=KmUzfK3o$">
                                         <mutation elseif="2"></mutation>
                                           <block type="logic_compare" id="paFV3UpfROlwbseECIW8">
                                             <field name="OP">EQ</field>
                                               <block type="variables_get" id="ms1-N4Hh4HwO3[vO,8qJ">
                                               <block type="text" id="dl=n:TaVE;zn,lo_dDU:">
                                                 <field name="TEXT">all</field>
                                           <block type="variables_set" id="`#`6u*=P1Op#.AV?i?cD">
                                               <block type="logic_boolean" id="H_pQE1d|D~fo2]E3yfdx">
                                         <value name="IF1">
                                           <block type="logic_compare" id="6iE*0Atm^B]yoUHj~e90">
                                               <block type="variables_get" id="fH~RkEanrpluVyhdQVd^">
                                               <block type="text" id="LYe@tI5;CI@eX?#Fb`tx">
                                                 <field name="TEXT">false</field>
                                         <statement name="DO1">
                                           <block type="controls_if" id="Skx)dhe*t;i%zFH9#HDe">
                                               <block type="logic_compare" id="N0mP%Y@nJII)FUkV(|ot">
                                                   <block type="convert_tostring" id="%lxfjvw/;}838}H#v-wA">
                                                       <block type="convert_jsonata" id="2=/{cS9wTG-j`^Z%!580">
                                                           <shadow type="text" id="}@K=JL!N,dddRT/*N0DF">
                                                           <block type="variables_get" id="`DcTGvtRHbcsq2i=ytZS">
                                                   <block type="text" id="~L(vpPkIy;VPicYNW]yS">
                                               <block type="variables_set" id="WMsqF_mnxx|zP$?YUArJ">
                                                   <block type="logic_boolean" id="#I[kEn`t=3Ft4CTu!WNV">
                                         <value name="IF2">
                                           <block type="logic_compare" id="U=F7PQoX8|APZ]Sz17K2">
                                               <block type="variables_get" id="o2Vh2IGtY-3]c8QQa!@B">
                                               <block type="text" id="e@cS%G1a[N-`qPV.A7EE">
                                                 <field name="TEXT">true</field>
                                         <statement name="DO2">
                                           <block type="controls_if" id=",,7q^;^ykjHZUFLC1s%{">
                                               <block type="logic_compare" id="zqC,-gE?urRyxEfdZAfu">
                                                   <block type="convert_tostring" id="LeRW,6c8xyUh;*wIL)MQ">
                                                       <block type="convert_jsonata" id="Q-MMm$fHe4io_vHjSY_.">
                                                           <shadow type="text" id="jJ+~bp;!d$*`m%Ctj6D$">
                                                           <block type="variables_get" id=";)I@*nH{bp=_]=}znxgN">
                                                   <block type="text" id="zMJ,hoF}E)tES9{q$Z(h">
                                               <block type="variables_set" id="8(T:~McP8TfZbWDftG*k">
                                                   <block type="logic_boolean" id="2ND5y7W@V^HEzfL~^uzk">
                                           <block type="controls_if" id="49^HV302$#}aPx~PH5Tg">
                                               <block type="variables_get" id="IX|.A-#iMIj(T^]4DSEO">
                                               <block type="lists_setIndex" id="@:3ZNJZ:55#tL}E7vu^T">
                                                 <mutation at="false"></mutation>
                                                 <field name="WHERE">LAST</field>
                                                 <value name="LIST">
                                                   <block type="variables_get" id="af%%PgQ7fWx!_GIzW-u;">
                                                 <value name="TO">
                                                   <block type="procedures_callcustomreturn" id="DK/42*f_58--ovA;lXv)">
                                                     <mutation name="JSON_ELEMENT">
                                                       <arg name="X_completed"></arg>
                                                       <arg name="X_createdDateTime"></arg>
                                                       <arg name="X_value"></arg>
                                                     </mutation>
                                                     <value name="ARG0">
                                                       <block type="convert_jsonata" id="p~t%WLYkQmU]]h8l+Cs7">
                                                           <shadow type="text" id=";b2/pyI3v@1,eX5G?8PQ">
                                                           <block type="variables_get" id="!PMW.%,?n$]kNTW~!p8J">
                                                     <value name="ARG1">
                                                       <block type="convert_from_date" id="zZ%~t]{DcMF2oM,p{Hup">
                                                         <mutation xmlns="http://www.w3.org/1999/xhtml" format="true" language="false"></mutation>
                                                         <field name="OPTION">custom</field>
                                                         <field name="FORMAT">JJJJ.MM.TT SS:mm:ss.sss</field>
                                                           <block type="convert_jsonata" id="C$2e~IAW]hx`*V~X[)D#">
                                                               <shadow type="text" id="[e:fFe+C8.d5_Q-Jzmwe">
        <field name="TEXT">createdDateTime</field>
                                                               <block type="variables_get" id="`-z1(J9v}MJR?I=(_K[v">
                                                     <value name="ARG2">
                                                       <block type="convert_jsonata" id="OnDoF_MTz~7s^|kTVg$B">
                                                           <shadow type="text" id="Be.Qa)$#T7.Qy[SAl+fw">
                                                             <field name="TEXT">value</field>
                                                           <block type="variables_get" id="ZdrDTX/aEU]9Q!=Cey5,">
                               <block type="controls_if" id="w9hDJs7nyR2z[DBTv!rF">
                                   <block type="lists_isEmpty" id="W*NG``#wpfb[V(?1nNHL">
                                       <block type="variables_get" id="0%Yg#Juc=;)l@d3-#F7d">
                                   <block type="lists_setIndex" id="Qo=m1Wp$57Zy(l6yE,Z(">
                                     <value name="LIST">
                                       <block type="variables_get" id="5W5CKh5liv6FuatsK/?Z">
                                     <value name="TO">
                                       <block type="procedures_callcustomreturn" id="@HOvj(IHOLe56frxw!@l">
                                         </mutation>
                                         <value name="ARG0">
                                           <block type="logic_boolean" id="99FS2N/.0wC;4WBiN3KV">
                                         <value name="ARG1">
                                           <block type="time_get" id="uT3s!cz2Cd4XE|j3#{9.">
                                         <value name="ARG2">
                                           <block type="text" id="W_Am_?MWaDu4^J,j!TWX">
                                             <field name="TEXT">KEINE DATEN</field>
                                   <block type="control" id="{W3|J:c#[2b{b:Xu]A{n">
                                     <field name="OID">0_userdata.0.alexa.todo_json_jarvis</field>
                                       <block type="convert_object2json" id="168#s}4?dNMkYXfgV!R:">
                                         <field name="PRETTIFY">FALSE</field>
                                           <block type="variables_get" id="pMM{?xO2~8WGxNgT$-UI">
                                       <block type="debug" id="N/EOUd~/!~AJc29vuAh7" disabled="true">
                                         <value name="TEXT">
                                           <shadow type="text" id="~j3T*-ZtFWuLI/`wpea=">
                                           <block type="convert_object2json" id="vJ}n)j)ESFbL)v`qcOFU">
                                               <block type="variables_get" id="0lspr~*WijzCwXkZYN_!">
      JSONTABLE dann umstellen auf:
      [{"label":"Aufgabe","align":"left"},{"label":"Datum","align":"left"}]
      holzapfelauge 1 Reply Last reply Reply Quote 1
      • holzapfelauge
        holzapfelauge @MCU last edited by holzapfelauge
        @mcu Vielen Dank! Jetzt wird zwar Aufgabe und Datum angezeigt, allerdings steht bei den offenen Aufgaben, wenn kein Eintrag vorhanden ist, immer noch "Keine Daten" in der Liste. 🤔
        EDIT: Habs hinbekommen. Einfach nur die Einträge, welche bei einem leeren Datenpunkt angezeigt werden sollen, deaktiviert.
          handy80 @Zefau last edited by
          @zefau Hallo, versuche gerade einen 0/1 Wert in jarvis darzustellen und per switchaction schaltbar zu machen. (nutze den Wolf-Adapter der Daten über das Wolf-Portal zieht) und möchte "Warmwasser 1x" schaltbar machen. Normale ON/OFF Button funktionieren aber mit den Werten 0/1 (Zahl) kommend aus ioBroker funktioniert es nicht. Der SwitchAction zeigt immer "eingeschaltet" an. Ich habe schon mit JSON auf Datenpunkt Eigenschaften
            "0": "Aus",
            "1": "Ein"
          versucht, hilft aber auch nichts. Habt ihr eine Idee für mich. bitte 🙂
            MCU @handy80 last edited by
            @handy80
            {"off":"0","on":"1"}
              handy80 @MCU last edited by
              @mcu supervielen Dank! hat sofort funktioniert. Danke auch für die Screenshots, hatte dabei festgestellt, dass ich auch den Datenpunkt fürAnzeige noch pflegen musste. naja, immerhin, jetzt gibt's einen "blutigen" Anfänger weniger. Jarvis-Aufstieg zum Anfänger check! 😉
                MarcoPescado last edited by
                seitdem ich den Kalender benutze bekomme ich minütlich Warnungen.
                Was hat das zu bedeuten? Ich verwende 2.2.0
                Read-only state "jarvis.0.info.data" has been written without ack-flag with value "{"data":"BEGIN:VCALENDAR\r\nVERSION:2.0\r\nX-WR-CALNAME:XXXXXXXX\r\nX-APPLE-CALENDAR-COLOR:#CC73E1\r\nBEGIN:VEVENT\r\nCREATED:20210629T193019Z\r\nDTEND;TZID=Europe/Berlin:20210809T091500\r\nDTSTAMP:20210629T193020Z\r\nDTSTART;TZID=Europe/Berlin:20210809T083000\r\nLAST-
                  karstent last edited by
                  nach dem ich den Adapter upgedatet habe erscheint nun die Meldung:
                  File index.html not found: {}
                  Die Backups aus dem Adapter haben das Problem leider nicht behoben.
                  Was kann ich tun?
                  • Zefau
                    Zefau @karstent last edited by
                    @karstent Adapter nochmal hochladen
                      karstent @Zefau last edited by
                      @zefau also noch mal deinstallieren und dann installieren?
                      • Zefau
                        @karstent das geht auch. Gibt aber zum hochladen extra einen Button. Sonst per cli iobroker upload jarvis
                        K H 2 Replies Last reply Reply Quote -1
                          @zefau Danke, das hat geklappt. Habe es über die cli gemacht. 👍
                            lustig29 @MCU last edited by lustig29
                            @mcu Gab es denn schon eine Antwort? Oder wie kann man denn das mit einem Script lösen? Es geht um den Homepilot Adapter für den Rollotron Gurtwickler, da dort keine Datenpunkte für auf und zu vorhanden sind. Man kann das Rollo nur mit Prozentangabe steuern.
                              MCU @lustig29 last edited by
                              @lustig29 Nein, es gab leider noch keine Antwort. Vielleicht solltest du dann erstmal eine andere Variante zur Steuerung nutzen: DropdownAction. Damit kannst du die Werte dann vorgeben und das Rollo fährt dann ja an die entsprechende Position.
                              {"0":"ZU","25":"25","45":"45","65":"65","100":"OFFEN"}
                              Siehe oben im gif die Änderung vom Wert:
                              stephan1827 1 Reply Last reply Reply Quote 0
                              • stephan1827
                                stephan1827 @MCU last edited by
                                @Zefau gibt es eine Anleitung, um die V3 zu installieren? Ich habe den Adapter installiert und dort zeigt er auch die Version V3 an aber meine Instanz ist immer noch V2. Gibt es einen eigenen Thread für V3? Ich konnte keinen finden.
                                Stephan
                                  WW1983 @stephan1827 last edited by
                                  @stephan1827
                                  Probiere mal den Upload Button zu drücken:
                                  Würde die V3 aber nur auf einer Testinstanz nutzen. Es handelt sich aktuell um eine Alpha die für den Altag noch nicht nutzbar ist.
                                    derAndy @neunteufels last edited by
                                    @neunteufels
                                    hier gab es ja einige mit fehlenden Wetter Icons: Seit einigen Tagen ist die 2.2.2 verfügbar. Die funktioniert bei mir problemlos und zeigt die Wetter Icons wieder an.
                                    holzapfelauge 1 Reply Last reply Reply Quote 0
                                    • holzapfelauge
                                      holzapfelauge @derAndy last edited by
                                      @derandy Wo wurde dir denn die 2.2.2 angeboten? Bei mir wird keine neue verfügbare Version angezeigt. Ist immer noch die 2.2.1!
                                        luie @holzapfelauge last edited by luie
                                        @holzapfelauge
                                        die gibt es im GitHub
                                        https://github.com/Zefau/ioBroker.jarvis/tree/v2.2.x
                                          Robbi12 last edited by
                                          Hallo. Wollte auf 2.2.0 updaten. Nun hat er mir einfach die Version 3 installiert. Per Github link gehts auf 3.
                                          Wie bekomme ich die alte Version 2 drauf. Ich habe ein Backitup. Aber das funktioniert nicht so einfach
                                            luie @Robbi12 last edited by
                                            @robbi12
                                            Du kannst versuchen den Adapter zu löschen, über die benutzerdefinierte URL neu installieren und dann dein backup wieder einspielen.
                                            316
                                            6126
                                            4108754
