    3. Entwicklung
    4. [Neuer Adapter] Proxmox VM
    • Negalein
      Hallo
      Kann mir jemand weiterhelfen?
      Ich hab den Adapter in 1.3.4 laufen.
      Admin ist 5.1.9
      JS-Controller ist 3.3.14
      Ich kann mich nicht verbinden.
      IP passt, User & Passwort vom Server passt.
      Egal ob PAM oder PVE ausgewählt ist, geht der Adapter gleich wieder auf Rot.
      host.ioBroker 2021-07-09 17:06:06.128	info	Do not restart adapter system.adapter.proxmox.0 because desired by instance
      host.ioBroker 2021-07-09 17:06:06.128	error	instance system.adapter.proxmox.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
      proxmox.0 2021-07-09 17:06:06.062	info	cleaned everything up...
      proxmox.0 2021-07-09 17:06:05.556	error	401: wrong User data, could not log in, please try again with correct user and pw
      proxmox.0 2021-07-09 17:06:05.556	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      proxmox.0 2021-07-09 17:06:05.555	error	Unable to authenticate with Proxmox host. Please check your credentials
      proxmox.0 2021-07-09 17:06:02.521	debug	Use Proxmox API: https://10.0.1.201:8006/api2/json
      proxmox.0 2021-07-09 17:06:02.479	info	starting. Version 1.3.4 in /opt/iobroker/node_modules/iobroker.proxmox, node: v14.17.1, js-controller: 3.3.14
      proxmox.0 2021-07-09 17:06:02.151	debug	statesDB connected
      proxmox.0 2021-07-09 17:06:02.150	debug	States connected to redis: 0.0.0.0:9000
      proxmox.0 2021-07-09 17:06:02.105	debug	States create User PubSub Client
      proxmox.0 2021-07-09 17:06:02.104	debug	States create System PubSub Client
      proxmox.0 2021-07-09 17:06:02.058	debug	Redis States: Use Redis connection: 0.0.0.0:9000
      proxmox.0 2021-07-09 17:06:02.057	debug	objectDB connected
      proxmox.0 2021-07-09 17:06:02.054	debug	Objects connected to redis: 0.0.0.0:9001
      proxmox.0 2021-07-09 17:06:02.038	debug	Objects client initialize lua scripts
      proxmox.0 2021-07-09 17:06:02.038	debug	Objects create User PubSub Client
      proxmox.0 2021-07-09 17:06:02.038	debug	Objects create System PubSub Client
      proxmox.0 2021-07-09 17:06:01.958	debug	Objects client ready ... initialize now
      proxmox.0 2021-07-09 17:06:01.886	debug	Redis Objects: Use Redis connection: 0.0.0.0:9001
      crunchip K 2 Replies Last reply Reply Quote 0
        crunchip Forum Testing Most Active @Negalein last edited by crunchip
        @negalein sagte in [Neuer Adapter] Proxmox VM:
        eventuelle API-Änderung ( proxmox Update?)
          Kueppert @Negalein last edited by Kueppert
          @negalein oder Sonderzeichen im PW? Ich hab 6.4-12 drauf (gestern Update gemacht) und bei mir rennt der Adapter
          • Negalein
            Negalein Global Moderator @crunchip last edited by
            @crunchip sagte in [Neuer Adapter] Proxmox VM:
            @kueppert sagte in [Neuer Adapter] Proxmox VM:
            Hab 6.4-9 drauf.
            Passwort ist ohne Sonderzeichen.
            Hab gerade gesehn, dass unter Rechenzentrum ---> Übersicht ---> Knoten eine andere IP steht.
            Zugriff auf Proxmox = 10.0.1.201
            Knoten = 192.168.11.200
            Was ist das für eine IP? Wo kommt die her?
              hast du scheinbar eingetragen oder vllt versehentlich copy/past
              • Negalein
                hat dann @Dutchman gemacht! 😉
                Hat diese IP eine Bedeutung?
                  @negalein mach mal nen Screen davon...bei mir steht nur 1 IP (nutze LXC und VMs):
                  • Negalein
                    Negalein Global Moderator @Kueppert last edited by
                    da steht die 192.
                    mein Netz ist jedoch ein 10.0.1.
                    greife auch mit 10.0.1.201 drauf zu.
                    • Meister Mopper
                      Meister Mopper @Negalein last edited by
                      @negalein Ich vermute mal, dass das Zertifikat nicht stimmt. Da muss wahrscheinlich ein neues her.
                      Negalein 2 Replies Last reply Reply Quote 0
                      • Negalein
                        Negalein Global Moderator @Meister Mopper last edited by
                        @meister-mopper sagte in [Neuer Adapter] Proxmox VM:
                        Hmmm, muss mal schaun, wo ich das neu anfordere.
                        Bin noch ganz frisch in Proxmox.
                        K Meister Mopper 2 Replies Last reply Reply Quote 0
                          @negalein ich habs mir selbst installiert...so lang noch nicht so viel drauf läuft, kann man das ja ganz easy selbst neu draufzimmern. LXC/VMs gesichert auf der Syno oder separaten Festplatte....sind RuckZuck wieder da, wenn Proxmox neu aufgesetzt ist.
                          Aber frag doch erst mal den Kollegen Dutch, ob da nicht einfach ne Config vom Proxmox anpassen musst. Ich vermute, die 192er IP steht irgendwo als fixe IP drin.
                          • Meister Mopper
                            @negalein
                            Ich mache das so:
                            Zertifikate erneuern
                            Private and public key are both stored in
                            cd /etc/pve/nodes/<your node>
                            • private key : pve-ssl.key
                            • public key : pve-ssl.pem
                            Double-check that in /etc/hosts and /etc/hostname and /etc/pve/nodes both IP address and hostname is updated.
                            Use the pvecm command line to update your certificate :
                            pvecm updatecerts --force
                            restart the pveproxy
                            service pveproxy restart
                            • Negalein
                              hab ihn markiert. 🙂
                              Ich mache das so:
                              ok, schau ich mir an. Hatte gehofft, dass es auf der GUI einen Menüpunkt zum erneuern gibt.
                              • Negalein
                                hab gerade das gefunden.
                                Läuft bis 2031
                                  @negalein laut google, wenn die Ip geändert wird/nicht übereinstimmt, dann mal nachsehen in /etc/hosts gegebenenfalls dort die Ip anpassen, danach
                                  pvecm updatecerts -f
                                  • Negalein
                                    die hosts schaut so aus
                                    127.0.0.1 localhost.localdomain localhost
                                    192.168.11.200 proxmox.local proxmox
                                    # The following lines are desirable for IPv6 capable hosts
                                    ::1     ip6-localhost ip6-loopback
                                    fe00::0 ip6-localnet
                                    ff00::0 ip6-mcastprefix
                                    ff02::1 ip6-allnodes
                                    ff02::2 ip6-allrouters
                                    ff02::3 ip6-allhosts
                                    192.168.11.200 ändere ich dann einfach auf 10.0.1.201 und mach dann pvecm updatecerts -f?
                                      @negalein ja
                                      • Negalein
                                        @Kueppert @crunchip @Meister-Mopper
                                        Es ist verhext.
                                        Hab gerade mit @Dutchman geschrieben. Nichts verändert.
                                        Plötzlich läuft das Teil! 😁
                                        crunchip Dutchman 2 Replies Last reply Reply Quote 0
                                          @negalein Selbstheilung🤔 😉
                                          • Dutchman
                                            Dutchman Developer Most Active Administrators @Negalein last edited by
                                            Es ist verhext.
                                            proxmox
                                            75
                                            486
                                            109730
