    4. Test Adapter Govee v0.0.x
      myssv @nbuenger last edited by myssv
      @nbuenger
      Ich bekomme diese Meldung:
      [Edit} Mein Fehler. Der Slash am Ende war zu viel ...
        A Former User @nbuenger last edited by
        @nbuenger Hi,
        super, vielen Dank für das Update.
        Da ich zwei H6104 habe, kann ich diese wie gehabt ein-aus schalten, mehr geht nicht.
        Der Status wieder wie erwartet nicht von der API heraus gegeben.
        Hier das Log: ( sehr gute Idee mit dem unkenntlichmachen!! )
        2021-07-06 18:41:19.140  - debug: govee.0 (8412) Function: get current device info by API
        2021-07-06 18:41:19.140  - debug: govee.0 (8412) Request send: get device list
        2021-07-06 18:41:19.140  - debug: govee.0 (8412) Server Response: 200 (OK)
        2021-07-06 18:41:19.434  - error: govee.0 (8412) Error: Request failed with status code 400
        2021-07-06 18:41:19.460  - error: govee.0 (8412) Error: Request failed with status code 400
        2021-07-06 18:41:20.981  - info: host.VMC123-iobroker stopInstance system.adapter.govee.0 (force=false, process=true)
        2021-07-06 18:41:20.983  - info: host.VMC123-iobroker stopInstance system.adapter.govee.0 send kill signal
        2021-07-06 18:41:20.983  - info: govee.0 (8412) Got terminate signal TERMINATE_YOURSELF
        2021-07-06 18:41:20.984  - info: govee.0 (8412) terminating
        2021-07-06 18:41:20.984  - info: govee.0 (8412) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2021-07-06 18:41:21.584  - info: synology.0 (998) State value to set for "synology.0.DiskStationManager.info.uptime" has to be type "string" but received type "number"
        2021-07-06 18:41:21.773  - info: host.VMC123-iobroker instance system.adapter.govee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2021-07-06 18:41:23.871  - info: linux-control.0 (1995) getting data from gymberry (192.168.4.19:22)
        2021-07-06 18:41:24.254  - info: host.VMC123-iobroker instance system.adapter.govee.0 started with pid 10132
        2021-07-06 18:41:24.318  - info: linux-control.0 (1995) State value to set for "linux-control.0.gymberry.info.is_online" has to be type "string" but received type "boolean"
        2021-07-06 18:41:24.656  - debug: govee.0 (10132) Redis Objects: Use Redis connection: 127.0.0.1:6379
        2021-07-06 18:41:24.686  - debug: govee.0 (10132) Objects client ready ... initialize now
        2021-07-06 18:41:24.688  - debug: govee.0 (10132) Objects create System PubSub Client
        2021-07-06 18:41:24.689  - debug: govee.0 (10132) Objects create User PubSub Client
        2021-07-06 18:41:24.690  - debug: govee.0 (10132) Objects client initialize lua scripts
        2021-07-06 18:41:24.696  - debug: govee.0 (10132) Objects connected to redis: 127.0.0.1:6379
        2021-07-06 18:41:24.700  - debug: govee.0 (10132) objectDB connected
        2021-07-06 18:41:24.701  - debug: govee.0 (10132) Redis States: Use Redis connection: 127.0.0.1:6379
        2021-07-06 18:41:24.705  - debug: govee.0 (10132) States create System PubSub Client
        2021-07-06 18:41:24.705  - debug: govee.0 (10132) States create User PubSub Client
        2021-07-06 18:41:24.709  - debug: govee.0 (10132) States connected to redis: 127.0.0.1:6379
        2021-07-06 18:41:24.709  - debug: govee.0 (10132) statesDB connected
        2021-07-06 18:41:24.816  - info: govee.0 (10132) starting. Version 0.0.5 in /opt/iobroker/node_modules/iobroker.govee, node: v14.17.2, js-controller: 3.3.14
        2021-07-06 18:41:24.835  - info: govee.0 (10132) Expert log enabled
        2021-07-06 18:41:24.836  - info: govee.0 (10132) Private mode is enabled (senstive data will not shown in log output)
        2021-07-06 18:41:24.836  - info: govee.0 (10132) Refresh interval set to: 15 seceonds
        2021-07-06 18:41:24.837  - info: govee.0 (10132) Govee API Key: *******************************2125
        2021-07-06 18:41:25.192  - info: synology.0 (998) State value to set for "synology.0.DiskStationManager.info.uptime" has to be type "string" but received type "number"
        2021-07-06 18:41:25.192  - info: synology.0 (998) State value to set for "synology.0.DiskStationManager.vol_info.volume_1.used_size" has to be type "number" but received type "string"
        2021-07-06 18:41:25.228  - info: govee.0 (10132) check user admin pw iobroker: false,system.user.admin
        2021-07-06 18:41:25.231  - info: govee.0 (10132) check group user admin group admin: false
        2021-07-06 18:41:25.302  - info: govee.0 (10132) Request send: get device list
        2021-07-06 18:41:25.303  - info: govee.0 (10132) Server Response: 200 (OK)
        2021-07-06 18:41:25.303  - info: govee.0 (10132) Found (2) Devices
        2021-07-06 18:41:25.303  - info: govee.0 (10132) Select Device: ******************3:CD
        2021-07-06 18:41:25.304  - info: govee.0 (10132) Device: ******************3:CD is controllable
        2021-07-06 18:41:25.304  - info: govee.0 (10132) Device: ******************3:CD created
        2021-07-06 18:41:25.305  - info: govee.0 (10132) object "model" for: ******************3:CD created
        2021-07-06 18:41:25.306  - info: govee.0 (10132) object "retrievable" for: ******************3:CD created
        2021-07-06 18:41:25.306  - info: govee.0 (10132) Device: ******************3:CD supports cmd "powerState"
        2021-07-06 18:41:25.306  - info: govee.0 (10132) object "powerState" for: ******************3:CD created
        2021-07-06 18:41:25.306  - warn: govee.0 (10132) Device: ******************3:CD not supports cmd "brightness"
        2021-07-06 18:41:25.306  - warn: govee.0 (10132) Device: ******************3:CD not supports cmd "color"
        2021-07-06 18:41:25.307  - warn: govee.0 (10132) Device: ******************3:CD not supports cmd "colorTem"
        2021-07-06 18:41:25.307  - error: govee.0 (10132) H6104
        2021-07-06 18:41:25.307  - info: govee.0 (10132) Device "******************3:CD" was created.
        2021-07-06 18:41:25.307  - info: govee.0 (10132) Select Device: ******************D:74
        2021-07-06 18:41:25.307  - info: govee.0 (10132) Device: ******************D:74 is controllable
        2021-07-06 18:41:25.308  - info: govee.0 (10132) Device: ******************D:74 created
        2021-07-06 18:41:25.308  - info: govee.0 (10132) object "model" for: ******************D:74 created
        2021-07-06 18:41:25.308  - info: govee.0 (10132) object "retrievable" for: ******************D:74 created
        2021-07-06 18:41:25.308  - info: govee.0 (10132) Device: ******************D:74 supports cmd "powerState"
        2021-07-06 18:41:25.309  - info: govee.0 (10132) object "powerState" for: ******************D:74 created
        2021-07-06 18:41:25.309  - warn: govee.0 (10132) Device: ******************D:74 not supports cmd "brightness"
        2021-07-06 18:41:25.309  - warn: govee.0 (10132) Device: ******************D:74 not supports cmd "color"
        2021-07-06 18:41:25.309  - warn: govee.0 (10132) Device: ******************D:74 not supports cmd "colorTem"
        2021-07-06 18:41:25.310  - error: govee.0 (10132) H6104
        2021-07-06 18:41:25.310  - info: govee.0 (10132) Device "******************D:74" was created.
        2021-07-06 18:41:25.310  - info: govee.0 (10132) Govee Startup Routine finished
        2021-07-06 18:41:25.319  - info: govee.0 (10132) State value to set for "govee.0.9B:18:78:9C:E7:08:13:CD.retrievable" has to be type "string" but received type "boolean"
        2021-07-06 18:41:25.320  - info: govee.0 (10132) State value to set for "govee.0.99:63:78:9C:E7:0D:1D:74.retrievable" has to be type "string" but received type "boolean"
        2021-07-06 18:41:25.611  - error: govee.0 (10132) Error: Request failed with status code 400
        2021-07-06 18:41:25.621  - error: govee.0 (10132) Error: Request failed with status code 400
        2021-07-06 18:41:28.342  - info: synology.0 (998) State value to set for "synology.0.DiskStationManager.info.uptime" has to be type "string" but received type "number"
        2021-07-06 18:41:31.536  - info: synology.0 (998) State value to set for "synology.0.DiskStationManager.info.uptime" has to be type "string" but received type "number"
        2021-07-06 18:41:34.754  - info: synology.0 (998) State value to set for "synology.0.DiskStationManager.info.uptime" has to be type "string" but received type "number"
        2021-07-06 18:41:37.454  - info: fullybrowser.0 (10339) State value to set for "fullybrowser.0.192_168_4_50.Info.sensorInfo" has to be stringified but received type "object"
        2021-07-06 18:41:38.591  - info: synology.0 (998) State value to set for "synology.0.DiskStationManager.info.uptime" has to be type "string" but received type "number"
        2021-07-06 18:41:38.592  - info: synology.0 (998) State value to set for "synology.0.DiskStationManager.vol_info.volume_1.used_size" has to be type "number" but received type "string"
        2021-07-06 18:41:40.308  - info: govee.0 (10132) Function: get current device info by API
        2021-07-06 18:41:40.308  - info: govee.0 (10132) Request send: get device list
        2021-07-06 18:41:40.309  - info: govee.0 (10132) Server Response: 200 (OK)
        2021-07-06 18:41:40.611  - error: govee.0 (10132) Error: Request failed with status code 400
        2021-07-06 18:41:40.612  - error: govee.0 (10132) Error: Request failed with status code 400
        nbuenger 1 Reply Last reply Reply Quote 0
        • nbuenger
          nbuenger Developer @Guest last edited by
          @ilovegym Moin,
          ich weiß bei dir ist das mit den H6104 ein spezieller Fall. Ich habe alle Commands bis auf "turn" bei dem Gerät entfernt. Damit das Gerät aber nicht komplett ignoriert wird fragt er immer noch nach dem Status. Dies werde ich beheben sobald ich die H6104 da habe damit ich direkt sehe was diese macht. Denn ich habe herausgefunden das das Modell H6104 nicht vollständig von der API unterstützt wird. Man kann zwar alles über die API steuern nur gibt diese nichts zurück und das ist ein Problem. Denn eine Steuerung ohne Feedback zu bekommen ist ein wenig sinnfrei.
            @nbuenger
            Danke, alles gut, soweit nicht mehr von der API unterstützt wird, lass es. Mir reicht, wenn ich das Teil an/aus schalten kann, da der H6104 ja nur zur Ambiente genutzt wird.
              myssv @Guest last edited by myssv
              Ich habe heute auf den Admin 5.1.10 upgedated und bekomme nun neue Meldungen:
              govee.0 2021-07-10 12:43:57.838	info	State value to set for "govee.0.17:5D:A4:C1:38:9D:6A:59.online" has to be type "boolean" but received type "string"
              govee.0 2021-07-10 12:43:52.704	info	State value to set for "govee.0.17:5D:A4:C1:38:9D:6A:59.online" has to be type "boolean" but received type "string"
              govee.0 2021-07-10 12:43:47.340	info	State value to set for "govee.0.17:5D:A4:C1:38:9D:6A:59.online" has to be type "boolean" but received type "string"
              govee.0 2021-07-10 12:43:42.324	info	State value to set for "govee.0.17:5D:A4:C1:38:9D:6A:59.online" has to be type "boolean" but received type "string"
              govee.0 2021-07-10 12:43:37.509	info	State value to set for "govee.0.17:5D:A4:C1:38:9D:6A:59.online" has to be type "boolean" but received type "string"
              govee.0 2021-07-10 12:43:32.368	info	State value to set for "govee.0.17:5D:A4:C1:38:9D:6A:59.online" has to be type "boolean" but received type "string"
              govee.0 2021-07-10 12:43:27.614	info	State value to set for "govee.0.17:5D:A4:C1:38:9D:6A:59.online" has to be type "boolean" but received type "string"
              govee.0 2021-07-10 12:43:22.295	info	State value to set for "govee.0.17:5D:A4:C1:38:9D:6A:59.online" has to be type "boolean" but received type "string"
              govee.0 2021-07-10 12:43:18.031	info	State value to set for "govee.0.17:5D:A4:C1:38:9D:6A:59.online" has to be type "boolean" but received type "string"
              govee.0 2021-07-10 12:43:12.402	info	State value to set for "govee.0.17:5D:A4:C1:38:9D:6A:59.online" has to be type "boolean" but received type "string"
              govee.0 2021-07-10 12:43:07.321	info	State value to set for "govee.0.17:5D:A4:C1:38:9D:6A:59.online" has to be type "boolean" but received type "string"
              govee.0 2021-07-10 12:43:02.364	info	State value to set for "govee.0.17:5D:A4:C1:38:9D:6A:59.online" has to be type "boolean" but received type "string"
              govee.0 2021-07-10 12:42:57.614	info	State value to set for "govee.0.17:5D:A4:C1:38:9D:6A:59.online" has to be type "boolean" but received type "string"
              govee.0 2021-07-10 12:42:52.672	info	State value to set for "govee.0.17:5D:A4:C1:38:9D:6A:59.online" has to be type "boolean" but received type "string"
              govee.0 2021-07-10 12:42:48.152	info	State value to set for "govee.0.17:5D:A4:C1:38:9D:6A:59.online" has to be type "boolean" but received type "string"
              govee.0 2021-07-10 12:42:42.580	info	State value to set for "govee.0.17:5D:A4:C1:38:9D:6A:59.online" has to be type "boolean" but received type "string"
              govee.0 2021-07-10 12:42:38.432	info	State value to set for "govee.0.17:5D:A4:C1:38:9D:6A:59.online" has to be type "boolean" but received type "string"
              govee.0 2021-07-10 12:42:32.312	info	State value to set for "govee.0.17:5D:A4:C1:38:9D:6A:59.online" has to be type "boolean" but received type "string"
              govee.0 2021-07-10 12:42:27.573	info	State value to set for "govee.0.17:5D:A4:C1:38:9D:6A:59.online" has to be type "boolean" but received type "string"
              govee.0 2021-07-10 12:42:22.610	info	State value to set for "govee.0.17:5D:A4:C1:38:9D:6A:59.online" has to be type "boolean" but received type "string"
              govee.0 2021-07-10 12:42:17.975	info	State value to set for "govee.0.17:5D:A4:C1:38:9D:6A:59.online" has to be type "boolean" but received type "string"
              govee.0 2021-07-10 12:42:12.610	info	State value to set for "govee.0.17:5D:A4:C1:38:9D:6A:59.online" has to be type "boolean" but received type "string"
              govee.0 2021-07-10 12:42:07.749	info	State value to set for "govee.0.17:5D:A4:C1:38:9D:6A:59.online" has to be type "boolean" but received type "string"
              govee.0 2021-07-10 12:42:02.299	info	State value to set for "govee.0.17:5D:A4:C1:38:9D:6A:59.online" has to be type "boolean" but received type "string"
              govee.0 2021-07-10 12:41:57.633	info	State value to set for "govee.0.17:5D:A4:C1:38:9D:6A:59.online" has to be type "boolean" but received type "string"
              govee.0 2021-07-10 12:41:53.421	info	State value to set for "govee.0.17:5D:A4:C1:38:9D:6A:59.online" has to be type "boolean" but received type "string"
              govee.0 2021-07-10 12:41:52.228	info	Govee Startup Routine finished
              govee.0 2021-07-10 12:41:51.692	info	check group user admin group admin: false
              govee.0 2021-07-10 12:41:51.688	info	check user admin pw iobroker: true,system.user.admin
              govee.0 2021-07-10 12:41:51.544	info	Govee API Key:
              govee.0 2021-07-10 12:41:51.543	warn	Expert log disabled
              govee.0 2021-07-10 12:41:51.523	info	starting. Version 0.0.4 in /opt/iobroker/node_modules/iobroker.govee, node: v12.22.2, js-controller: 3.3.14
                A Former User last edited by
                @myssv
                das kommt wie du weisst nicht vom Admin 5 sondern vom js-controller 3.3.x und da du auf dem Beta Repo unterwegs bist, auch, was man da macht :-), oder?? 🙂
                ( Vorausgesetzt, man hat die dazu gehörigen Threads im Forum gelesen, was man tunlichst machen sollte bei Beta... )
                  @ilovegym Moin Bernd,
                  wie Du sicher weißt, weiß ich nicht, was man da macht! Aber Du kannst mich gerne aufklären.
                  Ich war mal auf Beta gewechselt, da ich sonst einige Adapter nicht bekommen hatte. Das habe ich aber gerade wieder aus Stable geändert. Danke für den Hinweis!
                    @ilovegym
                    wäre ich nicht im Beta Status, könnte ich z.B. die Neue Vis-Offline Lizenz nicht nutzen.
                    Zitat: Zur Nutzung dieser Offline Lizenz ist der Vis Adapter in Version v1.4.3 nötig.
                    Im Stable ist noch 1.3.10
                      Wildbill @myssv last edited by
                      @myssv Mittlerweile ist die VIS 1.4.3 auch im stable.
                      Wenn man, warum auch immer, einen Adapter aus dem BETA-Zweig braucht, so installiert man ihn entweder direkt via Github (die "Katze" oben), oder man stellt das Repo auf BETA/Latest, installiert genau diesen einen Adapter und stellt danach wieder auf stable zurück. Macht man Letzteres nicht, so bleibt man im BETA-Zweig, bekommt für alle installierten Aapter die Beta-Versionen zum Update angeboten und wird somit (ungewollt?) Beta-Tester mit allen Rechten und Pflichten (Issues melden) und natürlich Problemen (mögliche Fehler in Adaptern, Wegfall von Funktionen, Abstürze, viele Warnings und Errors im Log, usw.) Der Sinn von BETA ist eben, Fehler zu finden, bevor eine neue Version ausgerollt wird. Stable=Produktivsystem, BETA=Testsystem, wo es egal ist, wenn man was nicht funktioniert.
                      @nbuenger Ich habe auch die H6104 (Ambilight). Gibt es schon was Neues dazu? Ich bekomme auch laufend
                      im Log und würde das gerne weghaben. Ich weiss ja, dass nichts zurück kommt... Ich habe mal das Intervall auf 3600 (eine Stunde) gesetzt, aber der Weisheit letzter Schluss ist das nicht. 😊
                      Ansonsten dickes Danke, dass Du Dich hier ran gemacht hast.
                      Gruss, Jürgen
                      • nbuenger
                        nbuenger Developer @Wildbill last edited by
                        @wildbill Moin Jürgen, freut mich das du auch dabei bist und vielen dank.
                        Also die Sache sieht so aus ich werde diese Woche diesen Fehler beheben und ein Update ausrollen. Wenn das denn getestet wurde und keine großen Fehler mehr auftreten dann stelle ich den Antrag das der Adapter in die Offizielle Liste mit aufgenommen wird. Außerdem arbeite ich gerade an Version 2 von meinem GOVEE API TESTING TOOL.
                        Ich habe da mehr den Wert auf GUI gelegt und ein paar neue Funktionen kommen auch dazu. Das erleichtert uns die Fehlersuche.
                        Beste Grüße zurück, Nick
                          Michi_Pi last edited by
                          @nbuenger Mir ist gerade aufgefallen dass in der Übersicht diese Kachel ist
                          Der Port der hier dafür angegeben ist, wird bei mir, für eine andere Anwendung bereits verwendet.
                          Kann man hier den Port ändern?
                          W nbuenger 2 Replies Last reply Reply Quote 0
                            Wildbill @Michi_Pi last edited by
                            @michi_pi Port 8082 ist doch standardmäßig eh für die VIS belegt. Bei mir zeigt der Govee auch den 8082 an. Was läuft da bei Dir ansonsten?
                            Gruss, Jürgen
                            • nbuenger
                              nbuenger Developer @Michi_Pi last edited by
                              @michi_pi Moin, ja ich weiß diese Kachel ist mir auch aufgefallen aber leider erst nachdem ich den Patch gemacht hatte. Das werde ich im nächsten Update auch entfernen es gibt bisher keine Webschnittstelle die ich implementiert habe daher ist diese Kachel unwichtig. Ich werde es aber wohl leider nicht mehr diese Woche schaffen, mein Job beansprucht mich derzeit etwas😁 .
                              Ich gebe euch bescheid wenn neue Infos parat sind bis dahin wünsche ich euch allen ein angenehmes Wochenende und für die die noch Arbeiten müssen frohes schaffen.
                              ? 1 Reply Last reply Reply Quote 1
                                @nbuenger sagte in Test Adapter Govee v0.0.x:
                                Könnte man die Kachel vielleicht als Link für deinen API Tester nutzen?
                                  Michi_Pi @Wildbill last edited by
                                  @wildbill ja genau, bei mir läuft auf dem Port auch VIS. War nur ein wenig verwirrt, warum hier govee steht und wollte nur mitteilen, nicht das sich da was in quere kommt.
                                  Hab zudem aber noch mit der HM-Kachel ein Problem, dort wird der Port 0 angezeigt. Diese lässt sich dann so nicht öffnen. erst wenn ich die 0 entferne. Weiß nicht ob das vorher schon war oder auch erst mit dem Update gekommen ist.
                                  • Z
                                    zgadgeter last edited by
                                    Hallo, ich habe den Adapter installiert, API key drin, und er startet kurz und geht auf Gruen, ca 1 sek, dann wieder Rot. Hat da jemand einen Tipp fuer mich? danke.
                                      @zgadgeter
                                      was steht denn im Log ( stells auf debug bitte ) ??
                                      • Z
                                        zgadgeter last edited by zgadgeter
                                        Hi, anbei der Log, aber ich werde daraus nicht schlau...
                                        govee.0
                                        2021-07-25 13:15:10.004	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                        govee.0
                                        2021-07-25 13:15:10.004	info	terminating
                                        govee.0
                                        2021-07-25 13:15:10.002	error	Cannot read property 'status' of undefined
                                        govee.0
                                        2021-07-25 13:15:10.002	error	TypeError: Cannot read property 'status' of undefined at /opt/iobroker/node_modules/iobroker.govee/main.js:135:27 at processTicksAndRejections (internal/process/task_queues.js:97:5)
                                        govee.0
                                        2021-07-25 13:15:10.002	error	unhandled promise rejection: Cannot read property 'status' of undefined
                                        govee.0
                                        2021-07-25 13:15:10.001	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                        host.IOBDebian104
                                        2021-07-25 13:15:10.099	debug	Incoming Host message getLogs
                                        host.IOBDebian104
                                        2021-07-25 13:15:10.092	debug	Incoming Host message getLogFiles
                                        govee.0
                                        govee.0
                                        govee.0
                                        govee.0
                                        govee.0
                                        govee.0
                                        govee.0
                                        2021-07-25 13:15:09.653	info	check group user admin group admin: false
                                        govee.0
                                        2021-07-25 13:15:09.651	info	check user admin pw iobroker: true,system.user.admin
                                        govee.0
                                        2021-07-25 13:15:09.541	info	Govee API Key:
                                        govee.0
                                        2021-07-25 13:15:09.540	warn	Private mode is disabled (senstive data will shown in log output)
                                        govee.0
                                        2021-07-25 13:15:09.540	warn	Expert log disabled
                                        govee.0
                                        2021-07-25 13:15:09.530	info	starting. Version 0.0.5 in /opt/iobroker/node_modules/iobroker.govee, node: v12.22.2, js-controller: 3.3.14```
                                        ? nbuenger 2 Replies Last reply Reply Quote 0
                                          A Former User @zgadgeter last edited by
                                          @zgadgeter expert log und private log bitte einschalten und dann nochmals posten.
                                          • nbuenger
                                            nbuenger Developer @zgadgeter last edited by
                                            @zgadgeter Moin, freut mich das du dabei bist. Wie @ilovegym bereits geschrieben hat brauchen wir den expert log und in deine Privaten Infos zu schützen aktiviere doch auch bitte den private mode. Und noch eine kleine Info von dir. Welches Gerät von Govee hast du denn im Einsatz? Dein Problem bekommen wir auf jeden Fall gelöst. Außerdem hoffe ich das ich morgen das Update fertig bekomme.
                                            Beste Grüße Nick
                                            312
                                            68162
