    4. Test Adapter homeconnect (BSH Home-Connect) v0.0.x
      dj_membrane @dj_membrane last edited by
      @dj_membrane Jetzt mit laufendem Skript und debug mode:
      homeconnect.3	2021-06-07 22:48:51.948	debug	(29202) 011030386960041183.programs.selected.options.BSH_Common_Option_ProgramProgress:100
      homeconnect.3	2021-06-07 22:48:51.946	debug	(29202) event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1623098931,\"handling\":\"none\",\"uri\":\"/api/homeappliances/011030386960041183/programs/selected/options/BSH.Common.Option.Program
      homeconnect.3	2021-06-07 22:48:51.928	debug	(29202) 011030386960041183.status.BSH_Common_Status_OperationState:BSH.Common.EnumType.OperationState.Inactive
      homeconnect.3	2021-06-07 22:48:51.927	debug	(29202) event: {"type":"STATUS","data":"{\"items\":[{\"timestamp\":1623098931,\"handling\":\"none\",\"uri\":\"/api/homeappliances/011030386960041183/status/BSH.Common.Status.OperationState\",\"key\":\
      homeconnect.3	2021-06-07 22:48:51.890	debug	(29202) 011030386960041183.programs.selected.options.BSH_Common_Option_ProgramProgress:0
      homeconnect.3	2021-06-07 22:48:51.889	debug	(29202) event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1623098931,\"handling\":\"none\",\"uri\":\"/api/homeappliances/011030386960041183/programs/selected/options/BSH.Common.Option.Program
      homeconnect.3	2021-06-07 22:48:51.797	debug	(29202) 011030386960041183.settings.BSH_Common_Setting_PowerState:BSH.Common.EnumType.PowerState.Off
      homeconnect.3	2021-06-07 22:48:51.793	debug	(29202) event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1623098931,\"handling\":\"none\",\"uri\":\"/api/homeappliances/011030386960041183/settings/BSH.Common.Setting.PowerState\",\"key\":\"
      homeconnect.3	2021-06-07 22:48:00.507	info	(29202) 011030386960041183: There is no program active
      homeconnect.3	2021-06-07 22:47:56.362	error	(29202) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":100}}
      homeconnect.3	2021-06-07 22:47:56.359	info	(29202) 409: Program option not supported
      homeconnect.3	2021-06-07 22:47:51.946	debug	(29202) Rate per min: 4
      homeconnect.3	2021-06-07 22:47:51.937	debug	(29202) Delete: 011030386960041183.programs.active.options
      homeconnect.3	2021-06-07 22:47:51.935	debug	(29202) active.options.
      homeconnect.3	2021-06-07 22:47:51.833	error	(29202) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":100}}
      homeconnect.3	2021-06-07 22:47:51.832	info	(29202) 409: Program option not supported
      homeconnect.3	2021-06-07 22:47:51.819	debug	(29202) 011030386960041183.status.BSH_Common_Status_OperationState:BSH.Common.EnumType.OperationState.Finished
      homeconnect.3	2021-06-07 22:47:51.817	debug	(29202) event: {"type":"STATUS","data":"{\"items\":[{\"timestamp\":1623098871,\"handling\":\"none\",\"uri\":\"/api/homeappliances/011030386960041183/status/BSH.Common.Status.OperationState\",\"key\":\
      homeconnect.3	2021-06-07 22:47:51.723	debug	(29202) Rate per min: 3
      homeconnect.3	2021-06-07 22:47:51.721	debug	(29202) {"data":{"key":"BSH.Common.Option.ProgramProgress","value":100}}
      homeconnect.3	2021-06-07 22:47:51.719	debug	(29202) 011030386960041183/programs/active/options/BSH.Common.Option.ProgramProgress
      homeconnect.3	2021-06-07 22:47:51.687	debug	(29202) 011030386960041183.programs.active.BSH_Common_Root_ActiveProgram:null
      homeconnect.3	2021-06-07 22:47:51.685	debug	(29202) event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1623098871,\"handling\":\"none\",\"uri\":\"/api/homeappliances/011030386960041183/programs/active\",\"key\":\"BSH.Common.Root.ActiveP
      homeconnect.3	2021-06-07 22:47:51.679	debug	(29202) Rate per min: 2
      homeconnect.3	2021-06-07 22:47:51.677	debug	(29202) {"data":{"key":"BSH.Common.Option.ProgramProgress","value":100}}
      homeconnect.3	2021-06-07 22:47:51.673	debug	(29202) 011030386960041183/programs/active/options/BSH.Common.Option.ProgramProgress
      homeconnect.3	2021-06-07 22:47:51.637	debug	(29202) 011030386960041183.events.BSH_Common_Event_ProgramFinished:BSH.Common.EnumType.EventPresentState.Present
      homeconnect.3	2021-06-07 22:47:51.631	debug	(29202) event: {"type":"EVENT","data":"{\"items\":[{\"timestamp\":1623098871,\"handling\":\"none\",\"key\":\"BSH.Common.Event.ProgramFinished\",\"value\":\"BSH.Common.EnumType.EventPresentState.Presen
      homeconnect.3	2021-06-07 22:47:51.616	debug	(29202) 011030386960041183.programs.active.options.BSH_Common_Option_RemainingProgramTime:0
      homeconnect.3	2021-06-07 22:47:51.615	debug	(29202) 011030386960041183.programs.active.options.BSH_Common_Option_ProgramProgress:100
      homeconnect.3	2021-06-07 22:47:51.613	debug	(29202) event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1623098871,\"handling\":\"none\",\"uri\":\"/api/homeappliances/011030386960041183/programs/active/options/BSH.Common.Option.ProgramPr
      homeconnect.3	2021-06-07 22:46:57.969	error	(29202) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":99}}
      homeconnect.3	2021-06-07 22:46:57.967	info	(29202) 409: Program option not supported
      homeconnect.3	2021-06-07 22:46:57.791	debug	(29202) Rate per min: 1
      homeconnect.3	2021-06-07 22:46:57.790	debug	(29202) {"data":{"key":"BSH.Common.Option.ProgramProgress","value":99}}
      homeconnect.3	2021-06-07 22:46:57.788	debug	(29202) 011030386960041183/programs/active/options/BSH.Common.Option.ProgramProgress
      homeconnect.3	2021-06-07 22:46:56.952	error	(29202) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":99}}
      homeconnect.3	2021-06-07 22:46:56.950	info	(29202) 409: Program option not supported
      homeconnect.3	2021-06-07 22:46:56.775	debug	(29202) Rate per min: 1
      homeconnect.3	2021-06-07 22:46:56.774	debug	(29202) {"data":{"key":"BSH.Common.Option.ProgramProgress","value":99}}
      homeconnect.3	2021-06-07 22:46:56.773	debug	(29202) 011030386960041183/programs/active/options/BSH.Common.Option.ProgramProgress
      homeconnect.3	2021-06-07 22:46:56.725	debug	(29202) 011030386960041183.programs.active.options.BSH_Common_Option_RemainingProgramTime:60
      homeconnect.3	2021-06-07 22:46:56.723	debug	(29202) 011030386960041183.programs.active.options.BSH_Common_Option_ProgramProgress:99
      homeconnect.3	2021-06-07 22:46:56.722	debug	(29202) event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1623098816,\"handling\":\"none\",\"uri\":\"/api/homeappliances/011030386960041183/programs/active/options/BSH.Common.Option.ProgramPr
      homeconnect.3	2021-06-07 22:45:57.927	error	(29202) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":98}}
      homeconnect.3	2021-06-07 22:45:57.925	info	(29202) 409: Program option not supported
      homeconnect.3	2021-06-07 22:45:57.751	debug	(29202) Rate per min: 2
      homeconnect.3	2021-06-07 22:45:57.750	debug	(29202) {"data":{"key":"BSH.Common.Option.ProgramProgress","value":98}}
      homeconnect.3	2021-06-07 22:45:57.748	debug	(29202) 011030386960041183/programs/active/options/BSH.Common.Option.ProgramProgress
      homeconnect.3	2021-06-07 22:45:56.934	error	(29202) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":98}}
      homeconnect.3	2021-06-07 22:45:56.933	info	(29202) 409: Program option not supported
      homeconnect.3	2021-06-07 22:45:56.758	debug	(29202) Rate per min: 1
      homeconnect.3	2021-06-07 22:45:56.757	debug	(29202) {"data":{"key":"BSH.Common.Option.ProgramProgress","value":98}}
      homeconnect.3	2021-06-07 22:45:56.756	debug	(29202) 011030386960041183/programs/active/options/BSH.Common.Option.ProgramProgress
      homeconnect.3	2021-06-07 22:45:56.713	debug	(29202) 011030386960041183.programs.active.options.BSH_Common_Option_RemainingProgramTime:120
      homeconnect.3	2021-06-07 22:45:56.712	debug	(29202) 011030386960041183.programs.active.options.BSH_Common_Option_ProgramProgress:98
      homeconnect.3	2021-06-07 22:45:56.710	debug	(29202) event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1623098756,\"handling\":\"none\",\"uri\":\"/api/homeappliances/011030386960041183/programs/active/options/BSH.Common.Option.ProgramPr
      homeconnect.3	2021-06-07 22:44:57.899	error	(29202) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":97}}
      homeconnect.3	2021-06-07 22:44:57.897	info	(29202) 409: Program option not supported
      homeconnect.3	2021-06-07 22:44:57.756	debug	(29202) Rate per min: 2
      homeconnect.3	2021-06-07 22:44:57.755	debug	(29202) {"data":{"key":"BSH.Common.Option.ProgramProgress","value":97}}
      homeconnect.3	2021-06-07 22:44:57.753	debug	(29202) 011030386960041183/programs/active/options/BSH.Common.Option.ProgramProgress
      homeconnect.3	2021-06-07 22:44:56.931	error	(29202) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":97}}
      homeconnect.3	2021-06-07 22:44:56.930	info	(29202) 429: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 0 seconds.
      homeconnect.3	2021-06-07 22:44:56.754	debug	(29202) Rate per min: 2
      homeconnect.3	2021-06-07 22:44:56.753	debug	(29202) {"data":{"key":"BSH.Common.Option.ProgramProgress","value":97}}
      homeconnect.3	2021-06-07 22:44:56.751	debug	(29202) 011030386960041183/programs/active/options/BSH.Common.Option.ProgramProgress
      homeconnect.3	2021-06-07 22:44:56.710	debug	(29202) 011030386960041183.programs.active.options.BSH_Common_Option_RemainingProgramTime:180
      homeconnect.3	2021-06-07 22:44:56.708	debug	(29202) 011030386960041183.programs.active.options.BSH_Common_Option_ProgramProgress:97
      homeconnect.3	2021-06-07 22:44:56.706	debug	(29202) event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1623098696,\"handling\":\"none\",\"uri\":\"/api/homeappliances/011030386960041183/programs/active/options/BSH.Common.Option.ProgramPr
      homeconnect.3	2021-06-07 22:43:57.960	error	(29202) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":96}}
      homeconnect.3	2021-06-07 22:43:57.958	info	(29202) 429: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 59 seconds.
      homeconnect.3	2021-06-07 22:43:57.772	debug	(29202) Rate per min: 2
      homeconnect.3	2021-06-07 22:43:57.771	debug	(29202) {"data":{"key":"BSH.Common.Option.ProgramProgress","value":96}}
      homeconnect.3	2021-06-07 22:43:57.769	debug	(29202) 011030386960041183/programs/active/options/BSH.Common.Option.ProgramProgress
      homeconnect.3	2021-06-07 22:43:56.946	error	(29202) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":96}}
      homeconnect.3	2021-06-07 22:43:56.945	info	(29202) 429: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 60 seconds.
      homeconnect.3	2021-06-07 22:43:56.800	debug	(29202) Rate per min: 2
      homeconnect.3	2021-06-07 22:43:56.779	debug	(29202) {"data":{"key":"BSH.Common.Option.ProgramProgress","value":96}}
      homeconnect.3	2021-06-07 22:43:56.777	debug	(29202) 011030386960041183/programs/active/options/BSH.Common.Option.ProgramProgress
      homeconnect.3	2021-06-07 22:43:56.732	debug	(29202) 011030386960041183.programs.active.options.BSH_Common_Option_RemainingProgramTime:240
      homeconnect.3	2021-06-07 22:43:56.731	debug	(29202) 011030386960041183.programs.active.options.BSH_Common_Option_ProgramProgress:96
      homeconnect.3	2021-06-07 22:43:56.729	debug	(29202) event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1623098636,\"handling\":\"none\",\"uri\":\"/api/homeappliances/011030386960041183/programs/active/options/BSH.Common.Option.ProgramPr
      homeconnect.3	2021-06-07 22:42:57.992	error	(29202) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":95}}
      homeconnect.3	2021-06-07 22:42:57.991	info	(29202) 429: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 119 seconds.
      homeconnect.3	2021-06-07 22:42:57.816	debug	(29202) Rate per min: 1
      homeconnect.3	2021-06-07 22:42:57.815	debug	(29202) {"data":{"key":"BSH.Common.Option.ProgramProgress","value":95}}
      homeconnect.3	2021-06-07 22:42:57.813	debug	(29202) 011030386960041183/programs/active/options/BSH.Common.Option.ProgramProgress
      homeconnect.3	2021-06-07 22:42:56.992	error	(29202) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":95}}
      homeconnect.3	2021-06-07 22:42:56.990	info	(29202) 429: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 120 seconds.
      homeconnect.3	2021-06-07 22:42:56.810	debug	(29202) Rate per min: 1
      homeconnect.3	2021-06-07 22:42:56.809	debug	(29202) {"data":{"key":"BSH.Common.Option.ProgramProgress","value":95}}
      homeconnect.3	2021-06-07 22:42:56.808	debug	(29202) 011030386960041183/programs/active/options/BSH.Common.Option.ProgramProgress
      homeconnect.3	2021-06-07 22:42:56.762	debug	(29202) 011030386960041183.programs.active.options.BSH_Common_Option_RemainingProgramTime:300
      homeconnect.3	2021-06-07 22:42:56.760	debug	(29202) 011030386960041183.programs.active.options.BSH_Common_Option_ProgramProgress:95
      homeconnect.3	2021-06-07 22:42:56.758	debug	(29202) event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1623098576,\"handling\":\"none\",\"uri\":\"/api/homeappliances/011030386960041183/programs/active/options/BSH.Common.Option.ProgramPr
      homeconnect.3	2021-06-07 22:41:57.949	error	(29202) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":94}}
      homeconnect.3	2021-06-07 22:41:57.947	info	(29202) 429: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 179 seconds.
      homeconnect.3	2021-06-07 22:41:57.777	debug	(29202) Rate per min: 1
      homeconnect.3	2021-06-07 22:41:57.776	debug	(29202) {"data":{"key":"BSH.Common.Option.ProgramProgress","value":94}}
      homeconnect.3	2021-06-07 22:41:57.774	debug	(29202) 011030386960041183/programs/active/options/BSH.Common.Option.ProgramProgress
      homeconnect.3	2021-06-07 22:41:57.001	error	(29202) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":94}}
      homeconnect.3	2021-06-07 22:41:56.999	info	(29202) 429: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 180 seconds.
      homeconnect.3	2021-06-07 22:41:56.777	debug	(29202) Rate per min: 1
      homeconnect.3	2021-06-07 22:41:56.776	debug	(29202) {"data":{"key":"BSH.Common.Option.ProgramProgress","value":94}}
      homeconnect.3	2021-06-07 22:41:56.775	debug	(29202) 011030386960041183/programs/active/options/BSH.Common.Option.ProgramProgress
      homeconnect.3	2021-06-07 22:41:56.725	debug	(29202) 011030386960041183.programs.active.options.BSH_Common_Option_RemainingProgramTime:360
      homeconnect.3	2021-06-07 22:41:56.724	debug	(29202) 011030386960041183.programs.active.options.BSH_Common_Option_ProgramProgress:94
      homeconnect.3	2021-06-07 22:41:56.722	debug	(29202) event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1623098516,\"handling\":\"none\",\"uri\":\"/api/homeappliances/011030386960041183/programs/active/options/BSH.Common.Option.ProgramPr
      homeconnect.3	2021-06-07 22:40:57.938	error	(29202) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":93}}
      homeconnect.3	2021-06-07 22:40:57.934	info	(29202) 429: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 239 seconds.
      homeconnect.3	2021-06-07 22:40:57.763	debug	(29202) Rate per min: 2
      homeconnect.3	2021-06-07 22:40:57.762	debug	(29202) {"data":{"key":"BSH.Common.Option.ProgramProgress","value":93}}
      homeconnect.3	2021-06-07 22:40:57.760	debug	(29202) 011030386960041183/programs/active/options/BSH.Common.Option.ProgramProgress
      homeconnect.3	2021-06-07 22:40:56.947	error	(29202) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":93}}
      homeconnect.3	2021-06-07 22:40:56.945	info	(29202) 429: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 240 seconds.
      homeconnect.3	2021-06-07 22:40:56.771	debug	(29202) Rate per min: 1
      homeconnect.3	2021-06-07 22:40:56.770	debug	(29202) {"data":{"key":"BSH.Common.Option.ProgramProgress","value":93}}
      homeconnect.3	2021-06-07 22:40:56.769	debug	(29202) 011030386960041183/programs/active/options/BSH.Common.Option.ProgramProgress
      homeconnect.3	2021-06-07 22:40:56.725	debug	(29202) 011030386960041183.programs.active.options.BSH_Common_Option_RemainingProgramTime:420
      homeconnect.3	2021-06-07 22:40:56.724	debug	(29202) 011030386960041183.programs.active.options.BSH_Common_Option_ProgramProgress:93
      homeconnect.3	2021-06-07 22:40:56.722	debug	(29202) event: {"type":"NOTIFY","data":"{\"items\":[{\"timestamp\":1623098456,\"handling\":\"none\",\"uri\":\"/api/homeappliances/011030386960041183/programs/active/options/BSH.Common.Option.ProgramPr
      homeconnect.3	2021-06-07 22:39:57.909	error	(29202) Put folder failed 011030386960041183/commands/BSH.Common.Option.ProgramProgress{"data":{"key":"BSH.Common.Option.ProgramProgress","value":92}}
      homeconnect.3	2021-06-07 22:39:57.907	info	(29202) 429: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 299 seconds.
      homeconnect.3	2021-06-07 22:39:57.774	debug	(29202) Rate per min: 1
      homeconnect.3	2021-06-07 22:39:57.773	debug	(29202) {"data":{"key":"BSH.Common.Option.ProgramProgress","value":92}}
      homeconnect.3	2021-06-07 22:39:57.772	debug	(29202) 011030386960041183/programs/active/options/BSH.Common.Option.ProgramProgress
        bob der 1. @dj_membrane last edited by
        Hey ich suche bei meinem Spüler einen State der mir sagt das der Spüler fertig ist....
        Ich komme mit der Rolle indicator nicht so klar.
        Wie muss ich das sehen mit true und false im Blockly....hänge da voll.
          sigi234 Forum Testing Most Active @bob der 1. last edited by
          @bob-der-1 sagte in Test Adapter homeconnect (BSH Home-Connect) v0.0.x:
            bob der 1. @sigi234 last edited by bob der 1.
            @sigi234
            Heist im Blockly das dann....
            wenn Wert von ObjektID BSH_Common_Status_OperationState ( = ) ......
            Ab da weis ich nicht was ich nehmen soll...einen Textbaustein mit dem Wort "RUN"?
              sigi234 Forum Testing Most Active @bob der 1. last edited by sigi234
              @bob-der-1
              Warte mal, da hat mir @dslraser mal was gemacht. Ich suche.....
              https://forum.iobroker.net/topic/44096/erledigt-ansage-geschirrspüler/5?_=1625230221839
                @sigi234
                Ich glaube ich muss mich anders erklären.
                Da mein Geschirrspüler eine StatusLED hat die auf den Boden scheinen soll sobald er läuft, aber der Spüler über einer Schublade steht und so die StatusLED verdeckt ist, wollte ich wie folgt vorgehen.
                Spülvorgang ist in Betrieb, eine Led die am meinem WEMOS D1 Mini hängt anschalten, ist der Spüler fertig = LED aus.
                Vorerst habe ich das über den Stromverbrauch geregelt, was auch funktioniert aber ich wollte da noch ein skript wenn der Spüler zb Klarspüler mangel hat oder sonst was ...eben die LED rot oder grün leuchtet.
                Aber vorerst muss ich mal den Datenpunkt verstehen.
                Bzw müsste ich wissen wie ich States mit der Rolle indikator verwenden kann , als Wert wäre zb Aus/An aber wie sage ich in einem Blockly,wenn der Datenpunkt AUS als Wert hat???? True oder false kenne ich ja aber bilde ich aus an ab oder aktiv/bereit etc oder geht das überhaupt.
                  <block type="on" id="QG~H_+mc!MMghSuyE$6s" x="-37" y="-687">
                    <field name="OID">homeconnect.0.0110XXXXXXX4004514.status.BSH_Common_Status_OperationState</field>
                      <block type="controls_if" id="W41!S?TX}n/?eG@p6%-Y">
                          <block type="logic_compare" id="G~Bn]@r08c!9DaLMQ17z">
                            <field name="OP">EQ</field>
                              <block type="get_value" id="_-^2Qv;pWu+`61u{{1}6">
                                <field name="OID">homeconnect.0.01104XXXXXX514.status.BSH_Common_Status_OperationState</field>
                              <block type="text" id="#J23()ok4G$5z3yO3i::">
                                <field name="TEXT">WAS MUSS HIER STEHEN???</field>
                          <block type="control" id="[1SD..Y)z/{CR8F*wy9Y">
                            <field name="OID">wled.0.c45bbe549f2a.on</field>
                              <block type="logic_boolean" id="..^/{+8xCfdla[lT.Jf)">
                              <block type="control" id="RFx_yv6|MD?Ew61VARBY">
                                <field name="OID">wled.0.c45bbe549f2a.bri</field>
                                  <block type="math_number" id="bQB0UTzYbQEtRDsJ_r)b">
                                    <field name="NUM">255</field>
                        <value name="IF1">
                          <block type="logic_compare" id="^e/rgexxWCLzba/V{PkN">
                              <block type="get_value" id="{6)n;w-Ih}qP1N^oCH5C">
                                <field name="OID">homeconnect.0.011040XXXXX4514.status.BSH_Common_Status_OperationState</field>
                              <block type="text" id="3#u(iSzzuoSB$CtR!A~+">
                        <statement name="DO1">
                          <block type="control" id=")qNNnu)#I#?~K3]HTf,B">
                              <block type="logic_boolean" id="yp-j-0alBYM|n.BK?1{2">
                  @bob-der-1
                  Teste das mal:
                  Importiere dir mal diese View:
                  VIEW_ok_Geschirrspüler_Inventwo_sigi234.txt
                    @sigi234
                    Sobald ich wieder daheim bin......
                    Aber danke und ich bleibe dran
                      @sigi234
                      Ich hab die beiden Vorschläge von dir probiert,leider ohne Erfolg.
                      Das View ist wie immer mega,werde es sicherlich in kleinen Teilen behalten und in einem eigenen View verwurschteln
                        totti1171 @oberfragger last edited by
                        @oberfragger gibt es eine Lösung? hab seit einigen Tagen das gleiche Problem.
                        B T 2 Replies Last reply Reply Quote 0
                          bob der 1. @totti1171 last edited by bob der 1.
                          @totti1171
                          Bisher hatte ich kaum Zeit und habe es ja über den Umweg mit der Steckdose gelöst.
                          Muss aber auf dauer mit dem Adapter zu lösen sein
                            tombox @totti1171 last edited by
                            @totti1171 Was ist genau das Problem du musst nur den states
                            homeconnect.0.SIEMENS-XXXXX.status.BSH_Common_Status_OperationState
                            mit den Möglichkeiten vergleichen
                            BSH.Common.EnumType.OperationState.Ready
                            BSH.Common.EnumType.OperationState.Run
                            T B 2 Replies Last reply Reply Quote 0
                              totti1171 @tombox last edited by totti1171
                              @tombox Danke. inzwischen funktionieren diese Abfragen gut. Ich habe inzwischen 6 Homeconnect-Geräte (2 Geschirrspüler, Herd, Waschmaschine, Trockner, Kaffeeautomat) im Haus und trotz eingelegter 24h Pause nach kurzer Zeit wieder diese Meldung:
                              homeconnect.0	2021-07-15 06:04:05.429	error	(19432) Error (401010522127001422)
                              homeconnect.0	2021-07-15 06:04:05.429	error	(19432) 429 Too Many Requests
                              homeconnect.0	2021-07-15 06:04:05.429	error	(19432) EventSource error: {"type":"error","status":429,"message":"Too Many Requests"}
                              homeconnect.0	2021-07-15 06:04:05.380	warn	(19432) Too many requests. Adapter sends too many requests per minute. Please wait 1min before restart the instance.
                              homeconnect.0	2021-07-15 06:04:05.380	error	(19432) Error (BOSCH-HNG6764S6-68A40E565336)
                              homeconnect.0	2021-07-15 06:04:05.380	error	(19432) 429 Too Many Requests
                              homeconnect.0	2021-07-15 06:04:05.380	error	(19432) EventSource error: {"type":"error","status":429,"message":"Too Many Requests"}
                              homeconnect.0	2021-07-15 06:04:05.372	warn	(19432) Too many requests. Adapter sends too many requests per minute. Please wait 1min before restart the instance.
                              homeconnect.0	2021-07-15 06:04:05.372	error	(19432) Error (SIEMENS-WT7YH701-68A40E02A511)
                              homeconnect.0	2021-07-15 06:04:05.372	error	(19432) 429 Too Many Requests
                              homeconnect.0	2021-07-15 06:04:05.372	error	(19432) EventSource error: {"type":"error","status":429,"message":"Too Many Requests"}
                              homeconnect.0	2021-07-15 06:04:05.363	warn	(19432) Too many requests. Adapter sends too many requests per minute. Please wait 1min before restart the instance.
                              homeconnect.0	2021-07-15 06:04:05.363	error	(19432) Error (SIEMENS-TI9555X1DE-68A40E2399A9)
                              homeconnect.0	2021-07-15 06:04:05.363	error	(19432) 429 Too Many Requests
                              homeconnect.0	2021-07-15 06:04:05.363	error	(19432) EventSource error: {"type":"error","status":429,"message":"Too Many Requests"}
                              homeconnect.0	2021-07-15 06:04:05.355	warn	(19432) Too many requests. Adapter sends too many requests per minute. Please wait 1min before restart the instance.
                              homeconnect.0	2021-07-15 06:04:05.355	error	(19432) Error (BOSCH-SMI88TS36E-68A40E029D20)
                              homeconnect.0	2021-07-15 06:04:05.354	error	(19432) 429 Too Many Requests
                              homeconnect.0	2021-07-15 06:04:05.354	error	(19432) EventSource error: {"type":"error","status":429,"message":"Too Many Requests"}
                              homeconnect.0	2021-07-15 06:04:05.343	warn	(19432) Too many requests. Adapter sends too many requests per minute. Please wait 1min before restart the instance.
                              homeconnect.0	2021-07-15 06:04:05.343	error	(19432) Error (SIEMENS-WM4YH741-68A40E02AF0A)
                              homeconnect.0	2021-07-15 06:04:05.343	error	(19432) 429 Too Many Requests
                              homeconnect.0	2021-07-15 06:04:05.343	error	(19432) EventSource error: {"type":"error","status":429,"message":"Too Many Requests"}
                                @totti1171 dann wurde der Adapter zu oft neugestartet oder er läuft doppelt
                                T D 2 Replies Last reply Reply Quote 0
                                  @tombox Hab bei diesem Adapter keine Neustarts eingerichtet und es läuft auch nur eine Instanz 😠
                                  hatte ihn >24h vorgestern aus, da lief er dann wieder für ein paar Stunden - heute morgen dann wieder die Meldungen
                                    @totti1171 Dann muss irgend ein fehler oder neu verbinden statt finden. Schick mal das komplette log file nach dem 24h warten per pn an mich
                                      @tombox würde ich ja gern - habe aber keinen "PN-Button" 😠
                                        bob der 1. @tombox last edited by
                                        @tombox sagte in Test Adapter homeconnect (BSH Home-Connect) v0.0.x:
                                        Und wie müsste ein Blockly aussehen zn für die Tür ?
                                        Wenn offen dann Lampe an oder wie binde ich sowas ein mit den Operatonns States.Finished.
                                        Das komme ich nicht klar.
                                        Kann.mit da einer mal nur zeigen wie ich den Finished dazu bekomme irgendwas zu schalten
                                          tombox @bob der 1. last edited by
                                          @bob-der-1
                                          Tür ist dann der Zustand:
                                          homeconnect.0.SIEMENS-XXXXXXX.status.BSH_Common_Status_DoorState
                                          die beiden Zustände
                                          BSH.Common.EnumType.DoorState.Closed
                                          BSH.Common.EnumType.DoorState.Open
                                            @tombox
                                            Ich muss das morgen mal testen,ich sehe da noch nicht meinen Weg....
                                            bsh bsh home connect home connect homeconnect adapter
                                            195
                                            1373
                                            518292
