    4. Unifi Protect Adapter
    • peterbaumert
      peterbaumert Developer @Frank579 last edited by
      @frank579 ja am besten nach dem starten mal dein intervall abwarten was du eingestellt hast und dann das log danach posten 👍
        Frank579 @peterbaumert last edited by Frank579
        @peterbaumert
        Beim Start
        2021-07-06 20:50:38.086 - info: unifi-protect.0 (43941) Got terminate signal TERMINATE_YOURSELF
        2021-07-06 20:50:38.086 - info: unifi-protect.0 (43941) cleaned everything up...
        2021-07-06 20:50:38.087 - info: unifi-protect.0 (43941) terminating
        2021-07-06 20:50:38.087 - info: unifi-protect.0 (43941) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2021-07-06 20:50:54.577 - debug: unifi-protect.0 (44263) Redis Objects: Use Redis connection: 127.0.0.1:9001
        2021-07-06 20:50:54.599 - debug: unifi-protect.0 (44263) Objects client ready ... initialize now
        2021-07-06 20:50:54.599 - debug: unifi-protect.0 (44263) Objects create System PubSub Client
        2021-07-06 20:50:54.600 - debug: unifi-protect.0 (44263) Objects create User PubSub Client
        2021-07-06 20:50:54.600 - debug: unifi-protect.0 (44263) Objects client initialize lua scripts
        2021-07-06 20:50:54.607 - debug: unifi-protect.0 (44263) Objects connected to redis: 127.0.0.1:9001
        2021-07-06 20:50:54.609 - debug: unifi-protect.0 (44263) objectDB connected
        2021-07-06 20:50:54.610 - debug: unifi-protect.0 (44263) Redis States: Use Redis connection: 127.0.0.1:9000
        2021-07-06 20:50:54.614 - debug: unifi-protect.0 (44263) States create System PubSub Client
        2021-07-06 20:50:54.614 - debug: unifi-protect.0 (44263) States create User PubSub Client
        2021-07-06 20:50:54.619 - debug: unifi-protect.0 (44263) States connected to redis: 127.0.0.1:9000
        2021-07-06 20:50:54.620 - debug: unifi-protect.0 (44263) statesDB connected
        2021-07-06 20:50:54.783 - debug: unifi-protect.0 (44263) Plugin sentry Initialize Plugin (enabled=true)
        2021-07-06 20:50:54.857 - info: unifi-protect.0 (44263) starting. Version 0.0.12 in /opt/iobroker/node_modules/iobroker.unifi-protect, node: v12.22.2, js-controller: 3.3.14
        Danach kam nichts mehr Intervall steht auf 60 sek... gehe jetzt mal grad der cam winken 🙂 und pack den Log noch dran
        Beim auslösen der Cam kam auch nichts im Log
        Edit Jetzt kam nochmal was ... Bewegung war laut Unifi OS um 20:56:35 , Bild passt aber noch nicht
        2021-07-06 21:01:55.473 - debug: unifi-protect.0 (44263) update lastMotion thumbnail for cam 5eb1b8b7038a8c03e7002492
        2021-07-06 21:01:55.607 - debug: unifi-protect.0 (44263) [getThumbnail] thumb stored successfully -> /vis.0/unifi-protect/lastMotion/5eb1b8b7038a8c03e7002492.jpg
        peterbaumert 1 Reply Last reply Reply Quote 0
        • peterbaumert
          @frank579 hm ok komisch da hätte mehr kommen müssen. Ich bin bis nächsten Mittwoch im Urlaub. Aber wenn es dir passt können wir dann Do oder Fr einfach mal zusammen drüber schauen im Discord oder Teamviewer oder so?
            @peterbaumert
            Ja können wir Gerne machen, AnyDesk hätte ich zur verfügung 🙂
            Schönen Urlaub 🙂 👍
            peterbaumert 1 Reply Last reply Reply Quote 1
            • peterbaumert
              @frank579 perfekt. Meld mich dann. Danke 🙂
              L T 2 Replies Last reply Reply Quote 1
                pietro @peterbaumert last edited by
                @peterbaumert said in Unifi Protect Adapter:
                @pietro Hatt leider echt viel um die Ohren die letzte Zeit. Werde nun aber versuchen mich da wieder ranzumachen und halte euch auf dem laufenden.
                Das wäre echt super !!!
                • X
                  x.Oli last edited by
                  Hallo zusammen
                  Ich verfolge seit einiger Zeit sehr interessiert diesen Beitrag hier, da ich, wie alle hier, auch sehr interessiert an Unifi Protect bin. Leider bin ich nicht so firm mit den Adaptern. Ist dieser hier noch nicht "offiziell" ? Wie kann ich diesen denn installieren, um testen zu können, ob das Gewünschte funktioniert ?
                  Vielen Dank und liebe Grüße
                  x.Oli
                    Christian_L 0 last edited by
                    Ich bin noch ganz neu hier aber versuche Dir trotzdem mal zu helfen:
                    nein, der Adapter scheint noch nicht im "offiziellen" Repo zu sein.
                    Um den Adapter zu installieren musst Du auf die "Adapter" Seite, dann auf das
                    zweite runde Symbol von rechts (schaut aus wie eine Katze und heisst im Tooltip
                    "Installieren aus eigener URL")
                    Dort kopierst Du folgende URL rein: https://github.com/peterbaumert/ioBroker.unifi-protect
                    Die Konfiguration findest Du weiter oben.
                    @peterbaumert: Machst Du zur Zeit noch am Adapter weiter?
                    Gruß, Christian
                    • X
                      wenn ich da die URL eingebe und anschließend auf "Installieren" klicke geht das Fenster zu und es passiert nichts mehr weiter. Hier mal ein Screenshot:
                      Screenshot - Adapterinstallation
                      x.Oli
                        Christian_L 0 @x.Oli last edited by Christian_L 0
                        @x-oli Entschuldige, ich war gestern ein wenig neben mir, Du musst natürlich noch oben den Reiter
                        "Beliebig" auswählen.
                        Ich habs hier mal mit einem andere Github Adapter probiert. Anders als bei den Adaptern aus dem
                        Repo muss Du dann noch den neuen Adapter und der Reiter "Adapters" suchen und durch das kleine
                        "+" eine Instanz davon installieren - das geht in diesem Fall nicht automatisch.
                        Gruß, Christian
                          lessthanmore @peterbaumert last edited by lessthanmore
                          @peterbaumert Hi, seit einigen Tagen habe ich das Problem dass die Instanz immer mehr RAM beansprucht. Zum Teil weit über 250 MB und gleichzeitig geht mein System bzw. ioBroker immer langsamer.
                          Sobald ich die Instanz von unifi protect beende ist alles wieder flüssig und läuft normal.
                          Im Log habe ich folgendes unzählige Male hintereinander:
                          unifi-protect.0	2021-07-19 14:34:33.128	error	(15210) Cannot find view "system" for search "device" : Connection is closed.
                          Ca. 100-150 Mal der gleiche Eintrag zur exakt gleichen Zeit (Stunde, Minute und Sekunde).
                          Habe ich hier evtl. etwas falsch konfiguriert?
                            der-eine last edited by
                            wie verschickt ihr die Bilder aktuell mit Telegram? Steh grad etwas auf dem Schlauch wie das geht wenn isMotion und lastMotion keine aktuellen Daten liefern. 🙂 Ich hoffe mir kann hier jemand auf die Sprünge helfen. 😁
                              Marcel85 @der-eine last edited by
                              @der-eine sagte in Unifi Protect Adapter:
                              Ich kann dir damit leider nicht weiterhelfen, ich würde mich deiner Frage aber gerne anschließen.
                                tyson0941 @peterbaumert last edited by
                                Hi @peterbaumert , sorry for my of topic question ,
                                I use unifi protect with UCK Gen2+ and a G4 doorbell , it is possible to see in the iobroker adapter when the ring button it is pressed?
                                Regards
                                Xenon 1 Reply Last reply Reply Quote 0
                                • Xenon
                                  Xenon Forum Testing Developer last edited by
                                  @peterbaumert @Scrounger
                                  gibts denn nicht die Möglichkeit per websocket zu arbeiten anstatt per http request? Ich habe es jetzt noch nicht getestet, meine es aber gelesen zu haben bei einer homekit Integration
                                  • Xenon
                                    Xenon Forum Testing Developer @tyson0941 last edited by
                                    @tyson0941 sagte in Unifi Protect Adapter:
                                    Regards
                                    yes, "last ring"
                                    But you have to set the refresh interval to 1-2 seconds. This in turn represents a higher system load. That's why I asked the developer if you can really only work via "HTTP request" or if you can connect live via websocket.
                                      tyson0941 @Xenon last edited by
                                      @xenon thanks
                                        Adrian-01 @tyson0941 last edited by
                                        bei mir lässt sich der Adapter leider nicht Installieren.
                                        Die Installation startet immer mit "npm install peterbaumert/ioBroker.unifi-protect#bd978d82b64a328f8d12245f93314d32a2e312b0 --loglevel error --prefix "/opt/iobroker" (System call)"
                                        Dann läufts weiter durch, der Adapter wird kurz erkannt sprich die Adapteranzahl der Installierten erhöht sich um 1 und nach kurzer Zeit reduziert es sich wieder um 1.
                                        Kann mir hierbei jemand weiterhelfen?
                                        Gruß,
                                        • Xenon
                                          Xenon Forum Testing Developer @Adrian-01 last edited by
                                          @adrian-01 welche npm Version? Installierst du über github oder offiziell?
                                            Adrian-01 @Xenon last edited by
                                            @xenon
                                            Danke für die schnelle Rückmeldung, hier die Infos:
                                            NPM: 6.14.15
                                            Ich Installiere über "Benutzerdefiniert" und dann die URL
                                            Wenn ich unter Adapter Unifi eingebe kommt nur der Adapter für den Unifi Controller.
                                            31.7k
                                            79.8k
                                            unifi unifi protect
                                            60
                                            221
                                            30308
