    5. Datenpunkt setzen mit "Heute" "Gestern" "Vorgestern"
    • dslraser
      dslraser Forum Testing Most Active @fastfoot last edited by dslraser
      @fastfoot
      Ich habe es jetzt so...
       <variables>
         <variable id="GfWhg11(gE@cDL}rT~qj">letzte_Bewaesserung</variable>
         <variable id="TN*b2s_.y_`^DJT6$cA3">Gestern</variable>
         <variable id="~!)I|B*)E+YCj^%Tm]k)">Vorgestern</variable>
       </variables>
       <block type="procedures_defcustomreturn" id="=_Xx7~PddFV+`HS|w}Ld" x="13" y="13">
         <mutation statements="false"></mutation>
         <field name="NAME">datum_gestern</field>
         <field name="SCRIPT">dmFyIHllc3RlcmRheSA9IChmdW5jdGlvbihkKXsgZC5zZXREYXRlKGQuZ2V0RGF0ZSgpLTEpOyByZXR1cm4gZH0pKG5ldyBEYXRlKQpyZXR1cm4geWVzdGVyZGF5IDs=</field>
       <block type="procedures_defcustomreturn" id="!Vf+c%_m)^5NUX6GBnue" x="13" y="63">
         <field name="NAME">datum_vorgestern</field>
         <field name="SCRIPT">dmFyIHRoZWRheWJlZm9yeWVzdGVyZGF5ID0gKGZ1bmN0aW9uKGQpeyBkLnNldERhdGUoZC5nZXREYXRlKCktMik7IHJldHVybiBkfSkobmV3IERhdGUpCnJldHVybiB0aGVkYXliZWZvcnllc3RlcmRheTs=</field>
       <block type="on_ext" id="PC{Q}G6V9t1ay|%ZQ6q:" x="13" y="113">
         <value name="OID0">
           <shadow type="field_oid" id="T/YG1KxJ@TY1WzPIi|Yk">
             <field name="oid">0_userdata.0.Test.Datum_letzte_Bewaesserung</field>
           <block type="variables_set" id="UIkcSE,9bu6,OtT-8D:D">
             <field name="VAR" id="GfWhg11(gE@cDL}rT~qj">letzte_Bewaesserung</field>
               <block type="on_source" id="Q}W|q^5#]C+#CafA+);H">
               <block type="variables_set" id="RymLVmrI_a|%C-),fVB-">
                 <field name="VAR" id="TN*b2s_.y_`^DJT6$cA3">Gestern</field>
                   <block type="convert_from_date" id="**9!|uKs(gBaLtF;IlBo">
                     <field name="OPTION">DD.MM.YYYY</field>
                       <block type="procedures_callcustomreturn" id="-=Y1*T].C]}%!~bGt)Rs">
                         <mutation name="datum_gestern"></mutation>
                   <block type="variables_set" id="?h2F*bUz_9QmbM?29wC)">
                     <field name="VAR" id="~!)I|B*)E+YCj^%Tm]k)">Vorgestern</field>
                       <block type="convert_from_date" id="{$vz@8,cW^$yrRgq~jw!">
                           <block type="procedures_callcustomreturn" id="~_20WVn-5)%Q88x_!zKi">
                             <mutation name="datum_vorgestern"></mutation>
                       <block type="controls_if" id="=a:o^eb_Ice3nnyJ{7o3">
                         <mutation elseif="2" else="1"></mutation>
                           <block type="logic_compare" id="ALQMq4Ht3Y3`5e;B(oA+">
                             <field name="OP">EQ</field>
                               <block type="variables_get" id="q4`E+VCJB@1B+t9hL|BF">
                               <block type="time_get" id="0*bmmc|b7VrGa%e{C($d">
                           <block type="update" id="jWgkwCIX^:_q_4,hZNeW">
                             <field name="OID">0_userdata.0.Test.heute_gestern_vorgestern</field>
                               <block type="text" id="-M;!i9$vWQ*.G18AUP:Y">
                                 <field name="TEXT">Heute</field>
                         <value name="IF1">
                           <block type="logic_compare" id=")R|MNW^j|X+4w4*1UTQx">
                               <block type="variables_get" id="^ywj6fUE{1i12FzBwBD@">
                               <block type="variables_get" id="-?#q|^5M;9Kp+glPOiM3">
                         <statement name="DO1">
                           <block type="update" id=":bDCMK{5z~rTH?3y:w$w">
                               <block type="text" id="$U~M|_quSrJaxubl((r.">
                                 <field name="TEXT">Gestern</field>
                         <value name="IF2">
                           <block type="logic_compare" id="yF~13~g[*p{Wf?WE}p/?">
                               <block type="variables_get" id="$k0erYX*.V6jS49*M_5o">
                               <block type="variables_get" id="OFahT5(Jd7v]=,2:o~f^">
                         <statement name="DO2">
                           <block type="update" id="|~iHb[aYUq)LC}*aFQ{B">
                               <block type="text" id="nw[M3T}TLrE),V:Rj0*,">
                                 <field name="TEXT">Vorgestern</field>
                         <statement name="ELSE">
                           <block type="update" id="Cs*/-=)--;+xa?8gvP-F">
                               <block type="on_source" id="OWz~)t$v$cF_fVD~[d:/">
      F P 2 Replies Last reply Reply Quote 0
        fastfoot @dslraser last edited by
        @dslraser einen haste noch. Deine Funktionen liefern auch die Uhrzeit, weshalb sie wohl fast nie der letzten Bewässerung entsprechen werden
        • dslraser
          @fastfoot sagte in Datenpunkt setzen mit "Heute" "Gestern" "Vorgestern":
          ? welche Uhrzeit meinst Du ?
            @dslraser upps, mea culpa, mea maxima culpa, habe die Funktion mit der Variablen verwechselt.
            • dslraser
              Und ich habe sie nun umbenannt und das Bild ausgetauscht 🤠
                paul53 @Peks200 last edited by paul53
                @peks-67
                Man kann als Datenpunkt eine Werteliste verwenden:
                  "_id": "0_userdata.0.Bewaesserung.Tag",
                  "type": "state",
                  "common": {
                    "name": "Tag letzte Bewässerung",
                    "role": "",
                    "type": "number",
                    "read": true,
                    "write": true,
                    "desc": "Manuell erzeugt",
                    "min": 0,
                    "max": 3,
                    "def": 0,
                    "states": {
                      "0": "heute",
                      "1": "gestern",
                      "2": "vorgestern",
                      "3": "länger her"
                  "native": {},
                  "user": "system.user.admin",
                  "ts": 1626938044757,
                  "acl": {
                    "object": 1636,
                    "state": 1636,
                    "owner": "system.user.admin",
                und die Tagesdifferenz berechnen:
                  Peks200 @paul53 last edited by
                  Danke für die vielen Vorschläge! Ich werde mich später oder morgen mal dran setzen und versuchen ob ich es so zum laufen bekomme. 👍 👍
                    Peks200 @dslraser last edited by
                    @dslraser said in Datenpunkt setzen mit "Heute" "Gestern" "Vorgestern":
                    @fastfoot
                     <variables>
                     </variables>
                       <value name="OID0">
                                       <value name="IF1">
                                       <value name="IF2">
                    Funktioniert im Testlauf schonmal astrein! Vielen Dank!
                    Was mir nur durch den Kopf geht ist der Trigger. Wenn heute gemäht wurde und ich schaue morgen vor dem Mähvorgang in die App steht da doch immernoch "Heute" oder?
                    Meine Idee wäre jetzt jeden Tag um 0:00 Uhr einen Trigger mit dem selben Script laufen zu lassen.
                    Oder gäbe es hier eine sehr viel kleinere Möglichkeit?
                    dslraser paul53 2 Replies Last reply Reply Quote 0
                    • dslraser
                      dslraser Forum Testing Most Active @Peks200 last edited by dslraser
                      @peks-67 sagte in Datenpunkt setzen mit "Heute" "Gestern" "Vorgestern":
                      Da hast Du natürlich recht. Ich nehme allerdings einen Cron dafür, weil Zeitpläne oft nicht richtig funktionieren (warum auch immer ? ) Ich habe es gerade probiert (mit einem Cron um 17:05 Uhr) da hat es funktioniert wie gewünscht. Ob es genau um 00:00 Uhr funktioniert weiß ich nicht, sonst vielleicht 00:01 Uhr nehmen....Ich probiere es heute Nacht auch mal mit 00:00 Uhr.
                      Ich weiß keine...
                       <variables>
                         <variable type="cron" id="schedule1">schedule1</variable>
                       </variables>
                         <value name="OID0">
                                             <field name="OID">0_userdata.0.Test.letzte_Bewaesserung_Tag</field>
                                         <value name="IF1">
                                         <value name="IF2">
                           <block type="schedule_create" id="Ts/}Sgr+5Q}e53fCH]pH">
                             <field name="NAME">schedule1</field>
                             <value name="SCHEDULE">
                               <shadow type="field_cron" id="(e?VUV5O$=;M(qzb{o!3">
                                 <field name="CRON">0 0 * * *</field>
                               <block type="variables_set" id="abrv/M@%W(b+Rhw,wn:d">
                                   <block type="get_value" id="JRxo)x|aWP|Bfi3-^9@2">
                                     <field name="OID">0_userdata.0.Test.Datum_letzte_Bewaesserung</field>
                                   <block type="variables_set" id="W@o(K#T(=Fz#kJs@)d]x">
                                       <block type="convert_from_date" id="Le0;N,+cY|zn]x_:SVMY">
                                           <block type="procedures_callcustomreturn" id="+aAo(A?8Fec@1|!ZqKrF">
                                       <block type="variables_set" id="e%plMH`1zjs||?VJCSI]">
                                           <block type="convert_from_date" id="ij*6M]A0lxP~ol9:WaoL">
                                               <block type="procedures_callcustomreturn" id="J3u*AcmOr3DP^r?gTr}z">
                                           <block type="controls_if" id="f4k4F1oDz$BY-79X;zC,">
                                               <block type="logic_compare" id="Q?A?{3TNMt%Csym`$@,P">
                                                   <block type="variables_get" id="89v1,Nq{h}9+p#}(?u3^">
                                                   <block type="time_get" id="W|t)3lGMjn-m9TpJ_h~1">
                                               <block type="update" id="K_Y8z]6,uOH,I.){~dD/">
                                                   <block type="text" id="f_^+TMRI=u~uh|aW4OqO">
                                             <value name="IF1">
                                               <block type="logic_compare" id="%GVDT+;4GdLWK3J*]?Ja">
                                                   <block type="variables_get" id="+lRXB@O:Rsw8:nvsCTYe">
                                                   <block type="variables_get" id="i;)YWu`uxj3e@5Titag[">
                                               <block type="update" id="^PSTwN4}k-c:@Zq.sOSB">
                                                   <block type="text" id="@xf%UW]nG(IW?Jdx-/Lf">
                                             <value name="IF2">
                                               <block type="logic_compare" id="%jLWIlm:7.he01N;QIKR">
                                                   <block type="variables_get" id="H}y.*:7;%}wI,5fgNS77">
                                                   <block type="variables_get" id="Ud}b$w_2r)g5BEvPDUzg">
                                               <block type="update" id="JoPvu#lNpRpzV`^:lk:z">
                                                   <block type="text" id="2{IEjnE3{o:tV:S$)6k-">
                                               <block type="update" id="/CaOI)#RKk=}KY$BSPFN">
                                                   <block type="get_value" id="TVO@D,jX)[?H;+$COiU`">
                      Variante ala @paul53 mit gemeinsamer Funktion
                       <variables>
                       </variables>
                         <value name="OID0">
                           <block type="procedures_callnoreturn" id="`K4}[lJOEB7Ha%#8s%nT">
                             <mutation name="Bewaesserung_Tag"></mutation>
                           <block type="schedule" id="w8Q*X39N|^xlJz[xJ.NG">
                             <field name="SCHEDULE">0 0 * * *</field>
                               <block type="procedures_callnoreturn" id="=Q.Z9g1Tu+N0zMGX,{Ek">
                       <block type="procedures_defnoreturn" id="n0Y.,:A:u!dU#APKEp`Z" x="213" y="163">
                         <field name="NAME">Bewaesserung_Tag</field>
                         <statement name="STACK">
                                         <value name="IF1">
                                         <value name="IF2">
                        @peks-67 sagte: kleinere Möglichkeit?
                        Übersichtlicher ist die Verwendung einer gemeinsamen Funktion. Beispiel:
                        843
