      MCU last edited by MCU
      @ww1983 Als Beispiel Timer mit Umschaltung:
      alexa, starte timer eier kochen mit 4 Minuten (STARTEN)
      alexa, timer stopp (STOPPEN)
      Verzögerung von ca 3-4 Sekunden durch Amazon und Alexa2-Adapter.
      ! Nur ein Timer zur Zeit!
      // Alexa-Timer berücksichtigen
      // alexa2.0.Echo-Devices.G2AXXXXXXXX.Timer.nextTimerDate
      createState('0_userdata.0.jarvis.timerRestzeit','',false, {read: true, write: true, name: "Timer Restzeit", type: "string", role: "state", def: "" });
      createState('0_userdata.0.jarvis.timerStart','',false, {read: true, write: true, name: "Timer gestartet?", type: "boolean", role: "state", def: "" });
      createState('0_userdata.0.jarvis.timerText','',false, {read: true, write: true, name: "Timer Text", type: "string", role: "state", def: "" });
      let TAB_timer = "timer-11";
      let TAB_home  = "dateien-8";
      // alexa, starte timer Eier kochen mit 4 Minuten
      // alexa, timer stopp
      on({id: 'alexa2.0.Echo-Devices.G2AXXXXXXX.Timer.nextTimerDate', change: "any"}, function (obj) {
          let value = obj.state.val;
          //console.log(obj.state.val);
          setState('0_userdata.0.jarvis.timerText',getState('alexa2.0.History.answerText').val);
          timerX(value);
          setState('jarvis.0.addNotification','{ "title": "!", "display": "none","focusTab": "' + TAB_timer +'" }');
      function timerX(val) {
          if (val > 0){
              // Countdown starten
              let aktZeit = getDateObject(new Date()).getTime();
              //console.log(aktZeit);
              let diffZeitSec = Math.ceil((val - aktZeit)/1000);
              //console.log(diffZeitSec); // 3 Sekunden Verzögerung durch Alexa2 oder Amazon
              setState('0_userdata.0.jarvis.timerStart',true);
              CNTDOWN(diffZeitSec,'0_userdata.0.jarvis.timerStart',false,'0_userdata.0.jarvis.timerRestzeit',true);
          }else{
              // Countdown stoppen
              CNTDOWN(1,'0_userdata.0.jarvis.timerStart',false,'0_userdata.0.jarvis.timerRestzeit',true);
      function CNTDOWN(delay,Schaltwert,Zuweisung,Restwert,Schalten) {
        (function () {if (Intervall) {clearInterval(Intervall); Intervall = null;}})();
        START = delay;
        if(Schalten == null){Schalten =true};
        Intervall = setInterval(function () {
          //log(typeof delay);
          delay = (typeof delay == 'number' ? delay : 0) + -1;
          // String erstellen aus Sekunden
          // Std
          if (delay>0){
              if (delay>3600){
                  setState(Restwert, formatDate(delay*1000,'hh:mm:ss'));
              }else{
                  setState(Restwert, formatDate(delay*1000,'mm:ss'));
          }else{setState(Restwert, '00:00');}
          if (delay <= 0) {
            //log(START + ' Sekunden - Countdown beendet');
            if (Schalten){
              setStateDelayed(Schaltwert, Zuweisung, false, 0, false);
              setState('jarvis.0.addNotification','{ "title": "!", "display": "none","focusTab": "'+ TAB_home + '" }');
        }, 1000);
      Werte müssen entsprechend angepasst werden.
        WW1983 @MCU last edited by
        @mcu Cool. Danke dir. Genauso meinte ich das. Danke für den Lösungsvorschlag
          matzesutopia last edited by
          Habe irgendwie Probleme mit der JSON Tabelle. Würde mir gerne über den tr-064 Adapter meine Geräte anzeigen lassen, bzw. welche davon gerade online sind. Doch leider wird auf entsprechender Seite gar nichts angezeigt.
            MCU @matzesutopia last edited by
            @matzesutopia Zeig mal die Einstellungen.
              matzesutopia @MCU last edited by
              @mcu welche Einstellungen meinst du?
                MCU @matzesutopia last edited by MCU
                @matzesutopia In jarvis. Welches JSON wird denn benutzt?
                  @mcu im tr adapter die jsonDeviceList. tr-064.0.devices.jsonDeviceList. Von den Einstellungen mache ich eben einen Screenshot
                    matzesutopia @matzesutopia last edited by matzesutopia
                      @matzesutopia Das Problem ist die jsondevicelist aus dem tr064. Dort ist active als boolean definiert. Dies kann jarvis in v2.2.2 nicht verarbeiten und stürzt ab. Du musst erst eine eigene jsonListe erstellen aus den Daten. Dort dürfen dann nur Strings drin sein. Dann kann man das JSON mit jarvis darstellen. Als Vorgeschmack für Deine Tabelle:
                      [{"label":"mac","align":"left"},{"label":"ip","align":"left"},{"label":"name","align":"left"}]
                      Trägst du dort active ein, stürzt jarvis ab.
                        @mcu schade, aber ok. wenigstens kann ich mit deiner Anweisung wenigstens schon mal etwas sehen. Den Rest werde ich dann irgendwie umbauen. Danke für die schnelle Hilfe
                          @matzesutopia
                          createState('0_userdata.0.jarvis.tr-064.jsonDeviceActive','',false, {read: true, write: true, name: "JSON Aktive tr-064 für Jarvis", type: "string", role: "state", def: "" });
                          on({id: 'tr-064.0.devices.jsonDeviceList', change: "any"}, function (obj) {
                             let jsonList = JSON.parse(value);
                             let newJson = [];
                             for (let i=0;i< jsonList.length;i++){
                                 if (jsonList[i].active){
                                     let newData = {};
                                     newData.mac = jsonList[i].mac;
                                     newData.ip = jsonList[i].ip;
                                     newData.name = jsonList[i].name;
                                     //console.log(newData);
                                     newJson.push(newData);
                             setState('0_userdata.0.jarvis.tr-064.jsonDeviceActive',JSON.stringify(newJson));
                          Ich musste bei mir gerade feststellen, daß die JSONListe nicht korrekt ist. Mag aber auch vielleicht an meiner Fritzbox 6591 Cable v7.27 liegen, wer weiß?. Geräte werden mit dem richtigen active-Zustand in der Verzeichnisliste angezeigt, aber nicht in der JSONListe, obwohl sie nach Zustandsänderung aktualisiert wurde.
                          • Zefau
                            Zefau @MCU last edited by
                            @mcu @matzesutopia sonst mit der v3 probieren, damit sollte es passen
                            stephan1827 1 Reply Last reply Reply Quote 0
                            • stephan1827
                              stephan1827 @Zefau last edited by
                              @zefau Ich bekomme die V3 immer noch nicht installiert. Die V3 wird bei der Installtion agezeigtBildschirmfoto 2021-07-24 um 08.22.34.png
                              aber im Programm steht immer noch V2.2.0Bildschirmfoto 2021-07-24 um 08.22.58.png
                              Ich habe auch schon mal Upload gemacht aber das ändert nichts
                              • Zefau
                                Zefau @stephan1827 last edited by
                                @stephan1827 die v3 ist noch Alpha und nur über GitHub erhältlich
                                  @stephan1827
                                  Upload über console schon versucht?
                                  iobroker upload jarvis
                                  Ansonsten nochmal:
                                  • stephan1827
                                    @zefau das ist schon klar, in dem ersten Screenshot sieht man auch die Alpha installiert ist aber die Instanz ist immer noch auf der alten Version. Ich habe jetzt auch mal die alte Version komplett gelöscht und die Beta neu installiert aber da steht immer noch V2.2.0
                                    Stephan
                                    • Zefau
                                      @stephan1827 ah ok. Puffer im Web ist aus? Sonst Web Adapter mal durchstarten.
                                        disaster123 last edited by
                                        Hallo seit heute morgen ist plötzlich meine Jarvis Config weg. Ich habe tägliche Backups meiner VM - unter welchem Pfad finde ich denn die Jarvis Config? Dann muss ich nicht alles restoren.
                                          MCU @disaster123 last edited by
                                          @disaster123 Auch die Sicherungen in der Instanz sind weg?
                                            disaster123 @MCU last edited by
                                            @mcu Nein die Sicherungen sind da ergeben nach einem restore aber irgendwie nicht das Bild von vorher
                                            316
                                            6126
                                            4104265
