    4. Test Adapter homeconnect (BSH Home-Connect) v0.0.x
      totti1171 @tombox last edited by totti1171
      @tombox Danke. inzwischen funktionieren diese Abfragen gut. Ich habe inzwischen 6 Homeconnect-Geräte (2 Geschirrspüler, Herd, Waschmaschine, Trockner, Kaffeeautomat) im Haus und trotz eingelegter 24h Pause nach kurzer Zeit wieder diese Meldung:
      homeconnect.0	2021-07-15 06:04:05.429	error	(19432) Error (401010522127001422)
      homeconnect.0	2021-07-15 06:04:05.429	error	(19432) 429 Too Many Requests
      homeconnect.0	2021-07-15 06:04:05.429	error	(19432) EventSource error: {"type":"error","status":429,"message":"Too Many Requests"}
      homeconnect.0	2021-07-15 06:04:05.380	warn	(19432) Too many requests. Adapter sends too many requests per minute. Please wait 1min before restart the instance.
      homeconnect.0	2021-07-15 06:04:05.380	error	(19432) Error (BOSCH-HNG6764S6-68A40E565336)
      homeconnect.0	2021-07-15 06:04:05.380	error	(19432) 429 Too Many Requests
      homeconnect.0	2021-07-15 06:04:05.380	error	(19432) EventSource error: {"type":"error","status":429,"message":"Too Many Requests"}
      homeconnect.0	2021-07-15 06:04:05.372	warn	(19432) Too many requests. Adapter sends too many requests per minute. Please wait 1min before restart the instance.
      homeconnect.0	2021-07-15 06:04:05.372	error	(19432) Error (SIEMENS-WT7YH701-68A40E02A511)
      homeconnect.0	2021-07-15 06:04:05.372	error	(19432) 429 Too Many Requests
      homeconnect.0	2021-07-15 06:04:05.372	error	(19432) EventSource error: {"type":"error","status":429,"message":"Too Many Requests"}
      homeconnect.0	2021-07-15 06:04:05.363	warn	(19432) Too many requests. Adapter sends too many requests per minute. Please wait 1min before restart the instance.
      homeconnect.0	2021-07-15 06:04:05.363	error	(19432) Error (SIEMENS-TI9555X1DE-68A40E2399A9)
      homeconnect.0	2021-07-15 06:04:05.363	error	(19432) 429 Too Many Requests
      homeconnect.0	2021-07-15 06:04:05.363	error	(19432) EventSource error: {"type":"error","status":429,"message":"Too Many Requests"}
      homeconnect.0	2021-07-15 06:04:05.355	warn	(19432) Too many requests. Adapter sends too many requests per minute. Please wait 1min before restart the instance.
      homeconnect.0	2021-07-15 06:04:05.355	error	(19432) Error (BOSCH-SMI88TS36E-68A40E029D20)
      homeconnect.0	2021-07-15 06:04:05.354	error	(19432) 429 Too Many Requests
      homeconnect.0	2021-07-15 06:04:05.354	error	(19432) EventSource error: {"type":"error","status":429,"message":"Too Many Requests"}
      homeconnect.0	2021-07-15 06:04:05.343	warn	(19432) Too many requests. Adapter sends too many requests per minute. Please wait 1min before restart the instance.
      homeconnect.0	2021-07-15 06:04:05.343	error	(19432) Error (SIEMENS-WM4YH741-68A40E02AF0A)
      homeconnect.0	2021-07-15 06:04:05.343	error	(19432) 429 Too Many Requests
      homeconnect.0	2021-07-15 06:04:05.343	error	(19432) EventSource error: {"type":"error","status":429,"message":"Too Many Requests"}
        tombox @totti1171 last edited by
        @totti1171 dann wurde der Adapter zu oft neugestartet oder er läuft doppelt
        T D 2 Replies Last reply Reply Quote 0
          @tombox Hab bei diesem Adapter keine Neustarts eingerichtet und es läuft auch nur eine Instanz 😠
          hatte ihn >24h vorgestern aus, da lief er dann wieder für ein paar Stunden - heute morgen dann wieder die Meldungen
            @totti1171 Dann muss irgend ein fehler oder neu verbinden statt finden. Schick mal das komplette log file nach dem 24h warten per pn an mich
              @tombox würde ich ja gern - habe aber keinen "PN-Button" 😠
                bob der 1. @tombox last edited by
                @tombox sagte in Test Adapter homeconnect (BSH Home-Connect) v0.0.x:
                @totti1171 Was ist genau das Problem du musst nur den states
                homeconnect.0.SIEMENS-XXXXX.status.BSH_Common_Status_OperationState
                mit den Möglichkeiten vergleichen
                BSH.Common.EnumType.OperationState.Inactive
                BSH.Common.EnumType.OperationState.Ready
                BSH.Common.EnumType.OperationState.Run
                BSH.Common.EnumType.OperationState.Finished
                Und wie müsste ein Blockly aussehen zn für die Tür ?
                Wenn offen dann Lampe an oder wie binde ich sowas ein mit den Operatonns States.Finished.
                Das komme ich nicht klar.
                Kann.mit da einer mal nur zeigen wie ich den Finished dazu bekomme irgendwas zu schalten
                  tombox @bob der 1. last edited by
                  @bob-der-1
                  Tür ist dann der Zustand:
                  homeconnect.0.SIEMENS-XXXXXXX.status.BSH_Common_Status_DoorState
                  die beiden Zustände
                  BSH.Common.EnumType.DoorState.Closed
                  BSH.Common.EnumType.DoorState.Open
                    @tombox
                    Ich muss das morgen mal testen,ich sehe da noch nicht meinen Weg....
                      JohnnyBahama last edited by
                      Hi, ich bekomme in meinen Log folgende Errors. Weiß einer was das bedeutet und wie man diese beseitigt.
                      homeconnect.0	2021-07-24 15:01:20.042	error	(23410) {"data":{"programs":[]}}
                      homeconnect.0	2021-07-24 15:01:20.042	error	(23410) /programs
                      homeconnect.0	2021-07-24 15:01:20.041	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
                      homeconnect.0	2021-07-24 15:01:20.041	error	at runMicrotasks (<anonymous>)
                      homeconnect.0	2021-07-24 15:01:20.041	error	at /opt/iobroker/node_modules/iobroker.homeconnect/main.js:1032:39
                      homeconnect.0	2021-07-24 15:01:20.041	error	at Array.forEach (<anonymous>)
                      homeconnect.0	2021-07-24 15:01:20.041	error	at /opt/iobroker/node_modules/iobroker.homeconnect/main.js:1041:57
                      homeconnect.0	2021-07-24 15:01:20.041	error	(23410) TypeError: Cannot read property 'forEach' of undefined
                      homeconnect.0	2021-07-24 15:01:20.039	error	(23410) TypeError: Cannot read property 'forEach' of undefined
                        tombox @JohnnyBahama last edited by
                        @johnnybahama installier mal über GitHub ob es dann weg ist
                          JohnnyBahama @tombox last edited by
                          @tombox Selbes Ergebniss
                            @johnnybahama Eigentlich müsste es gefixt sein wenn du via github installierst und neustartest welchen fehler bekommst du dann genau
                              @tombox Also ich habe jetzt folgendes probiert:
                              Adapter deinstalliert, über Adapter Page neu installiert v0.0.36
                              Adapter wieder deinstalliert, über GitHub installiert v0.0.30 wird angezeigt.
                              Adapter upgedated über Adapterpage auf v0.0.36
                              Alle drei Schritte werfen den oben genannten Error aus.
                              Am Ende kann ich auch damit leben, wenn es keine Auswirkungen hat.
                                @johnnybahama Hat keine Auswirkung github sollte eigentlich kein Update anbieten ich werde mal eine neue version hochladen
                                  @johnnybahama Du hast das falsche github installiert
                                  https://github.com/iobroker-community-adapters/ioBroker.homeconnect
                                    @tombox Ah ok. Ist natürlich blöd, wenn der nicht korrekte Adapter in der Liste erscheint. Danke. Momentan keine Meldungen.
                                      hab da noch was gefunden (ps.. ich komm zu nix)
                                      gerade das system neu gestartet.. der adapter läuft auf dem master.. nicht irritieren lassen von dem slave LOg...
                                      aber.. da ich den gerade neu gestartet habe wie kommt der zu der Meldung
                                      ich würde vermuten ohne in den source zu schauen dass der refresh token da mist macht
                                      wie gesagt vor dem systemneu start lief der adapter durch
                                        tombox @arteck last edited by
                                        @arteck Wäre interessant zu wissen was passiert ist bevor der erste 429 aufgetaucht ist
                                          arteck Developer Most Active @tombox last edited by arteck
                                          @tombox ja...
                                          um 3 uhr wurder der adapter neu gestartet
                                          und ab da gings los
                                          weiter um 6 hab ich die GIT Version gezogen
                                            tombox @arteck last edited by tombox
                                            @arteck Es sieht so aus als wäre er 1Uhr auch neugestartet. Je nach anzahl an devices sind nur begrenzte Neustarts möglich durch die hohe anzahl von requests
                                            Das ist doch normales Verhalten. Ist es denn trotzdem der einzige Neustart in den letzten 24h gewesen?
                                            bsh bsh home connect home connect homeconnect adapter
                                            195
                                            1373
                                            499572
