    4. ADAPTER FÜR Bosch Indego Connect
      flocke112 @a1development last edited by flocke112
      @a1development
      Im Log stand so einiges. Frage mich nur warum der bot per App gut funktioniert (wenn ich sie mal benutze) und es mit der Version 0.9.10 wochenlang keine Probleme gab?
      Hier der LOG: ICH VERSTEHE DA ALLERDINGS NICHTS!!
      host.raspberrypi	2021-07-27 10:23:52.087	warn	Do not restart adapter system.adapter.boschindego.0 because restart loop detected
      host.raspberrypi	2021-07-27 10:23:52.087	info	Restart adapter system.adapter.boschindego.0 because enabled
      host.raspberrypi	2021-07-27 10:23:52.085	error	instance system.adapter.boschindego.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      boschindego.0	2021-07-27 10:23:51.818	error	(12449) DB closed
      boschindego.0	2021-07-27 10:23:51.817	error	at TCP.<anonymous> (net.js:675:12)
      boschindego.0	2021-07-27 10:23:51.817	error	at Socket.emit (events.js:314:20)
      boschindego.0	2021-07-27 10:23:51.817	error	at Object.onceWrapper (events.js:421:26)
      boschindego.0	2021-07-27 10:23:51.817	error	at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:146:20)
      boschindego.0	2021-07-27 10:23:51.817	error	at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:179:25)
      boschindego.0	2021-07-27 10:23:51.817	error	(12449) Error: DB closed
      boschindego.0	2021-07-27 10:23:51.816	error	(12449) unhandled promise rejection: DB closed
      boschindego.0	2021-07-27 10:23:51.815	error	(12449) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      boschindego.0	2021-07-27 10:23:51.729	info	(12449) bot stopped
      boschindego.0	2021-07-27 10:23:51.496	info	(12449) connect ok
      boschindego.0	2021-07-27 10:23:51.313	error	(12449) Request failed with status code 401
      boschindego.0	2021-07-27 10:23:51.312	error	at processTicksAndRejections (internal/process/task_queues.js:84:21)
      boschindego.0	2021-07-27 10:23:51.312	error	at endReadableNT (_stream_readable.js:1241:12)
      boschindego.0	2021-07-27 10:23:51.312	error	at IncomingMessage.emit (events.js:326:22)
      boschindego.0	2021-07-27 10:23:51.312	error	at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/axios/lib/adapters/http.js:260:11)
      boschindego.0	2021-07-27 10:23:51.312	error	at settle (/opt/iobroker/node_modules/axios/lib/core/settle.js:17:12)
      boschindego.0	2021-07-27 10:23:51.312	error	at createError (/opt/iobroker/node_modules/axios/lib/core/createError.js:16:15)
      boschindego.0	2021-07-27 10:23:51.312	error	(12449) Error: Request failed with status code 401
      boschindego.0	2021-07-27 10:23:51.312	error	(12449) unhandled promise rejection: Request failed with status code 401
      boschindego.0	2021-07-27 10:23:51.311	error	(12449) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      boschindego.0	2021-07-27 10:23:51.311	error	(12449) error in clear alerts request: Error: Request failed with status code 401
      boschindego.0	2021-07-27 10:23:51.310	error	(12449) error in alerts request: Error: Request failed with status code 401
      boschindego.0	2021-07-27 10:23:51.301	warn	(12449) Terminated (UNCAUGHT_EXCEPTION): Without reason
      boschindego.0	2021-07-27 10:23:51.300	info	(12449) terminating
      boschindego.0	2021-07-27 10:23:51.287	error	(12449) Request failed with status code 401
      boschindego.0	2021-07-27 10:23:51.287	error	at processTicksAndRejections (internal/process/task_queues.js:84:21)
      boschindego.0	2021-07-27 10:23:51.287	error	at endReadableNT (_stream_readable.js:1241:12)
      boschindego.0	2021-07-27 10:23:51.287	error	at IncomingMessage.emit (events.js:326:22)
      boschindego.0	2021-07-27 10:23:51.287	error	at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/axios/lib/adapters/http.js:260:11)
      boschindego.0	2021-07-27 10:23:51.287	error	at settle (/opt/iobroker/node_modules/axios/lib/core/settle.js:17:12)
      boschindego.0	2021-07-27 10:23:51.287	error	at createError (/opt/iobroker/node_modules/axios/lib/core/createError.js:16:15)
      boschindego.0	2021-07-27 10:23:51.287	error	(12449) Error: Request failed with status code 401
      boschindego.0	2021-07-27 10:23:51.285	error	(12449) unhandled promise rejection: Request failed with status code 401
      boschindego.0	2021-07-27 10:23:51.285	error	(12449) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      boschindego.0	2021-07-27 10:23:51.283	error	(12449) error in clear alerts request: Error: Request failed with status code 401
      boschindego.0	2021-07-27 10:23:51.283	error	(12449) error in alerts request: Error: Request failed with status code 401
      boschindego.0	2021-07-27 10:23:51.191	info	(12449) connect
      boschindego.0	2021-07-27 10:23:51.189	info	(12449) pause command sent
      boschindego.0	2021-07-27 10:23:51.188	info	(12449) state boschindego.0.commands.pause changed: false (ack = false)
      boschindego.0	2021-07-27 10:23:51.159	info	(12449) connect
      boschindego.0	2021-07-27 10:23:51.156	info	(12449) pause command sent
      boschindego.0	2021-07-27 10:23:51.155	info	(12449) state boschindego.0.commands.pause changed: false (ack = false)
      boschindego.0	2021-07-27 10:23:29.585	error	(12449) connection error - credentials wrong or no network?
      boschindego.0	2021-07-27 10:23:26.387	info	(12449) connect
      boschindego.0	2021-07-27 10:23:26.172	info	(12449) starting. Version 0.9.11 in /opt/iobroker/node_modules/iobroker.boschindego, node: v12.22.2, js-controller: 3.2.16
      host.raspberrypi	2021-07-27 10:23:24.304	info	instance system.adapter.boschindego.0 started with pid 12449
      host.raspberrypi	2021-07-27 10:23:23.202	info	Restart adapter system.adapter.boschindego.0 because enabled
      host.raspberrypi	2021-07-27 10:23:23.200	error	instance system.adapter.boschindego.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      boschindego.0	2021-07-27 10:23:22.033	error	(12290) connection error - credentials wrong or no network?
      boschindego.0	2021-07-27 10:23:22.030	error	(12290) connection error - credentials wrong or no network?
      boschindego.0	2021-07-27 10:23:22.028	error	(12290) error in mow request: Error: Request failed with status code 429
      boschindego.0	2021-07-27 10:23:22.025	error	(12290) Request failed with status code 429
      boschindego.0	2021-07-27 10:23:22.025	error	at processTicksAndRejections (internal/process/task_queues.js:84:21)
      boschindego.0	2021-07-27 10:23:22.025	error	at endReadableNT (_stream_readable.js:1241:12)
      boschindego.0	2021-07-27 10:23:22.025	error	at IncomingMessage.emit (events.js:326:22)
      boschindego.0	2021-07-27 10:23:22.025	error	at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/axios/lib/adapters/http.js:260:11)
      boschindego.0	2021-07-27 10:23:22.025	error	at settle (/opt/iobroker/node_modules/axios/lib/core/settle.js:17:12)
      boschindego.0	2021-07-27 10:23:22.025	error	at createError (/opt/iobroker/node_modules/axios/lib/core/createError.js:16:15)
      boschindego.0	2021-07-27 10:23:22.025	error	(12290) Error: Request failed with status code 429
      boschindego.0	2021-07-27 10:23:22.024	error	(12290) unhandled promise rejection: Request failed with status code 429
      boschindego.0	2021-07-27 10:23:22.023	error	(12290) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      boschindego.0	2021-07-27 10:23:22.023	error	(12290) error in clear alerts request: Error: Request failed with status code 429
      boschindego.0	2021-07-27 10:23:22.021	error	(12290) error in alerts request: Error: Request failed with status code 429
      boschindego.0	2021-07-27 10:23:21.998	warn	(12290) Terminated (UNCAUGHT_EXCEPTION): Without reason
      boschindego.0	2021-07-27 10:23:21.997	info	(12290) terminating
      boschindego.0	2021-07-27 10:23:21.985	error	(12290) Request failed with status code 429
      boschindego.0	2021-07-27 10:23:21.985	error	at processTicksAndRejections (internal/process/task_queues.js:84:21)
      boschindego.0	2021-07-27 10:23:21.985	error	at endReadableNT (_stream_readable.js:1241:12)
      boschindego.0	2021-07-27 10:23:21.985	error	at IncomingMessage.emit (events.js:326:22)
      boschindego.0	2021-07-27 10:23:21.985	error	at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/axios/lib/adapters/http.js:260:11)
      boschindego.0	2021-07-27 10:23:21.985	error	at settle (/opt/iobroker/node_modules/axios/lib/core/settle.js:17:12)
      boschindego.0	2021-07-27 10:23:21.985	error	at createError (/opt/iobroker/node_modules/axios/lib/core/createError.js:16:15)
      boschindego.0	2021-07-27 10:23:21.985	error	(12290) Error: Request failed with status code 429
      boschindego.0	2021-07-27 10:23:21.983	error	(12290) unhandled promise rejection: Request failed with status code 429
      boschindego.0	2021-07-27 10:23:21.983	error	(12290) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      boschindego.0	2021-07-27 10:23:21.981	error	(12290) error in clear alerts request: Error: Request failed with status code 429
      boschindego.0	2021-07-27 10:23:21.979	error	(12290) error in alerts request: Error: Request failed with status code 429
      boschindego.0	2021-07-27 10:23:21.974	error	(12290) error in mow request: Error: Request failed with status code 429
      boschindego.0	2021-07-27 10:23:20.843	error	(12290) connection error - credentials wrong or no network?
      boschindego.0	2021-07-27 10:23:20.806	info	(12290) connect
      boschindego.0	2021-07-27 10:23:20.804	info	(12290) mow command sent
      boschindego.0	2021-07-27 10:23:20.803	info	(12290) state boschindego.0.commands.mow changed: true (ack = false)
      boschindego.0	2021-07-27 10:23:20.720	info	(12290) connect
      boschindego.0	2021-07-27 10:23:20.718	info	(12290) mow command sent
      boschindego.0	2021-07-27 10:23:20.717	info	(12290) state boschindego.0.commands.mow changed: true (ack = false)
      boschindego.0	2021-07-27 10:23:18.874	info	(12290) connect
      boschindego.0	2021-07-27 10:23:18.872	info	(12290) mow command sent
      boschindego.0	2021-07-27 10:23:18.871	info	(12290) state boschindego.0.commands.mow changed: true (ack = false)
      boschindego.0	2021-07-27 10:23:18.854	info	(12290) connect
      boschindego.0	2021-07-27 10:23:18.851	info	(12290) mow command sent
      boschindego.0	2021-07-27 10:23:18.850	info	(12290) state boschindego.0.commands.mow changed: true (ack = false)
      boschindego.0	2021-07-27 10:23:17.645	info	(12290) connect
      boschindego.0	2021-07-27 10:23:17.514	info	(12290) starting. Version 0.9.11 in /opt/iobroker/node_modules/iobroker.boschindego, node: v12.22.2, js-controller: 3.2.16
      host.raspberrypi	2021-07-27 10:23:15.778	info	instance system.adapter.boschindego.0 started with pid 12290
      host.raspberrypi	2021-07-27 10:23:14.682	info	Restart adapter system.adapter.boschindego.0 because enabled
      host.raspberrypi	2021-07-27 10:23:14.676	error	instance system.adapter.boschindego.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      boschindego.0	2021-07-27 10:23:14.131	error	(753) error in map request: Error: Request failed with status code 429
      boschindego.0	2021-07-27 10:23:13.990	warn	(753) Terminated (UNCAUGHT_EXCEPTION): Without reason
      boschindego.0	2021-07-27 10:23:13.988	info	(753) terminating
      boschindego.0	2021-07-27 10:23:13.968	error	(753) error in pause request: Error: Request failed with status code 429
      boschindego.0	2021-07-27 10:23:13.964	error	(753) Request failed with status code 429
      boschindego.0	2021-07-27 10:23:13.962	error	at processTicksAndRejections (internal/process/task_queues.js:84:21)
      boschindego.0	2021-07-27 10:23:13.962	error	at endReadableNT (_stream_readable.js:1241:12)
      boschindego.0	2021-07-27 10:23:13.962	error	at IncomingMessage.emit (events.js:326:22)
      boschindego.0	2021-07-27 10:23:13.962	error	at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/axios/lib/adapters/http.js:260:11)
      boschindego.0	2021-07-27 10:23:13.962	error	at settle (/opt/iobroker/node_modules/axios/lib/core/settle.js:17:12)
      boschindego.0	2021-07-27 10:23:13.962	error	at createError (/opt/iobroker/node_modules/axios/lib/core/createError.js:16:15)
      boschindego.0	2021-07-27 10:23:13.962	error	(753) Error: Request failed with status code 429
      boschindego.0	2021-07-27 10:23:13.961	error	(753) unhandled promise rejection: Request failed with status code 429
      boschindego.0	2021-07-27 10:23:13.961	error	(753) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      boschindego.0	2021-07-27 10:23:13.960	error	(753) error in alerts request: Error: Request failed with status code 429
      boschindego.0	2021-07-27 10:23:13.954	error	(753) Request failed with status code 429
      boschindego.0	2021-07-27 10:23:13.953	error	at processTicksAndRejections (internal/process/task_queues.js:84:21)
      boschindego.0	2021-07-27 10:23:13.953	error	at endReadableNT (_stream_readable.js:1241:12)
      boschindego.0	2021-07-27 10:23:13.953	error	at IncomingMessage.emit (events.js:326:22)
      boschindego.0	2021-07-27 10:23:13.953	error	at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/axios/lib/adapters/http.js:260:11)
      boschindego.0	2021-07-27 10:23:13.953	error	at settle (/opt/iobroker/node_modules/axios/lib/core/settle.js:17:12)
      boschindego.0	2021-07-27 10:23:13.953	error	at createError (/opt/iobroker/node_modules/axios/lib/core/createError.js:16:15)
      boschindego.0	2021-07-27 10:23:13.953	error	(753) Error: Request failed with status code 429
      boschindego.0	2021-07-27 10:23:13.951	error	(753) unhandled promise rejection: Request failed with status code 429
      boschindego.0	2021-07-27 10:23:13.950	error	(753) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      boschindego.0	2021-07-27 10:23:13.948	error	(753) error in clear alerts request: Error: Request failed with status code 429
      boschindego.0	2021-07-27 10:23:13.946	error	(753) error in alerts request: Error: Request failed with status code 429
      boschindego.0	2021-07-27 10:23:13.861	info	(753) connect
      boschindego.0	2021-07-27 10:23:13.860	error	(753) connection error
      boschindego.0	2021-07-27 10:23:13.849	error	(753) error in operatingData request: Error: Request failed with status code 429
      boschindego.0	2021-07-27 10:23:13.838	error	(753) error in pause request: Error: Request failed with status code 429
      boschindego.0	2021-07-27 10:23:12.444	error	(753) error in map request: Error: Request failed with status code 429
      boschindego.0	2021-07-27 10:23:12.327	error	(753) error in map request: Error: Request failed with status code 429
      boschindego.0	2021-07-27 10:23:12.042	error	(753) error in operatingData request: Error: Request failed with status code 429
      boschindego.0	2021-07-27 10:23:11.934	error	(753) error in operatingData request: Error: Request failed with status code 504
      boschindego.0	2021-07-27 10:23:10.828	info	(753) pause command sent
      boschindego.0	2021-07-27 10:23:10.827	info	(753) state boschindego.0.commands.pause changed: false (ack = false)
      boschindego.0	2021-07-27 10:23:10.737	error	(753) error in map request: Error: Request failed with status code 500
      boschindego.0	2021-07-27 10:23:10.719	info	(753) pause command sent
      boschindego.0	2021-07-27 10:23:10.719	info	(753) state boschindego.0.commands.pause changed: false (ack = false)
      boschindego.0	2021-07-27 10:23:08.903	info	(753) pause command sent
      boschindego.0	2021-07-27 10:23:08.902	info	(753) state boschindego.0.commands.pause changed: false (ack = false)
      boschindego.0	2021-07-27 10:23:08.779	info	(753) pause command sent
      boschindego.0	2021-07-27 10:23:08.778	info	(753) state boschindego.0.commands.pause changed: false (ack = false)
      boschindego.0	2021-07-27 10:23:07.999	error	(753) error in map request: Error: Request failed with status code 500
      boschindego.0	2021-07-27 10:23:07.843	error	(753) error in map request: Error: Request failed with status code 500
      boschindego.0	2021-07-27 10:23:05.884	info	(753) mow command sent
      boschindego.0	2021-07-27 10:23:05.884	info	(753) state boschindego.0.commands.mow changed: true (ack = false)
      boschindego.0	2021-07-27 10:23:05.750	info	(753) mow command sent
      boschindego.0	2021-07-27 10:23:05.749	info	(753) state boschindego.0.commands.mow changed: true (ack = false)
      boschindego.0	2021-07-27 10:23:03.942	info	(753) mow command sent
      boschindego.0	2021-07-27 10:23:03.941	info	(753) state boschindego.0.commands.mow changed: true (ack = false)
      boschindego.0	2021-07-27 10:23:03.864	info	(753) mow command sent
      boschindego.0	2021-07-27 10:23:03.863	info	(753) state boschindego.0.commands.mow changed: true (ack = false)
      boschindego.0	2021-07-27 10:22:57.703	error	(753) error in map request: Error: Request failed with status code 500
      boschindego.0	2021-07-27 10:22:56.147	info	(753) bot stopped
      boschindego.0	2021-07-27 10:22:56.064	error	(753) error in map request: Error: Request failed with status code 500
      boschindego.0	2021-07-27 10:22:55.883	info	(753) pause command sent
      boschindego.0	2021-07-27 10:22:55.883	info	(753) state boschindego.0.commands.pause changed: false (ack = false)
      boschindego.0	2021-07-27 10:22:55.844	error	(753) error in map request: Error: Request failed with status code 500
      boschindego.0	2021-07-27 10:22:55.803	info	(753) pause command sent
      boschindego.0	2021-07-27 10:22:55.803	info	(753) state boschindego.0.commands.pause changed: false (ack = false)
      boschindego.0	2021-07-27 10:22:53.942	info	(753) pause command sent
      boschindego.0	2021-07-27 10:22:53.941	info	(753) state boschindego.0.commands.pause changed: false (ack = false)
      boschindego.0	2021-07-27 10:22:53.867	info	(753) pause command sent
      boschindego.0	2021-07-27 10:22:53.866	info	(753) state boschindego.0.commands.pause changed: false (ack = false)
      boschindego.0	2021-07-27 10:22:26.890	error	(753) error in map request: Error: Request failed with status code 500
      boschindego.0	2021-07-27 10:22:26.462	error	(753) error in operatingData request: Error: Request failed with status code 504
      boschindego.0	2021-07-27 10:21:41.963	error	(753) error in map request: Error: Request failed with status code 500
      boschindego.0	2021-07-27 10:21:40.314	error	(753) error in operatingData request: Error: Request failed with status code 504
      boschindego.0	2021-07-27 10:20:57.896	error	(753) error in operatingData request: Error: Request failed with status code 504
      boschindego.0	2021-07-27 10:20:55.440	error	(753) error in map request: Error: Request failed with status code 500
      boschindego.0	2021-07-27 10:20:15.855	error	(753) error in operatingData request: Error: Request failed with status code 504
      boschindego.0	2021-07-27 10:20:10.117	error	(753) error in map request: Error: Request failed with status code 500
        Thomas Braun Most Active @flocke112 last edited by
        @flocke112 sagte in ADAPTER FÜR Bosch Indego Connect:
        In CodeTags gesetzt wäre das auch einfacher für andere.
        F integer63 2 Replies Last reply Reply Quote 0
          flocke112 @Thomas Braun last edited by
          @thomas-braun "in was" gesetzt? 😑 sorry! 🤷‍♂️
          überfordere mich nicht.
          Meine Kompetenz ist in diesem Fall stark eingeschränkt 😊
          • integer63
            integer63 @Thomas Braun last edited by
            Ich habe, seit dem ich auf die 0.9.11 gegangen bin, hin und wieder diese Meldungen im Log:
            boschindego.0	2021-07-27 10:21:46.602	info	(17119) Terminated (NO_ERROR): Without reason
            boschindego.0	2021-07-27 10:21:46.602	info	(17119) terminating
            boschindego.0	2021-07-27 10:21:46.601	info	(17119) connect
            boschindego.0	2021-07-27 10:21:46.601	error	(17119) connection error
            boschindego.0	2021-07-27 10:21:46.600	error	(17119) error in operatingData request: Error: Request failed with status code 401
            boschindego.0	2021-07-27 10:21:46.599	error	at process._tickCallback (internal/process/next_tick.js:63:19)
            boschindego.0	2021-07-27 10:21:46.599	error	at endReadableNT (_stream_readable.js:1145:12)
            boschindego.0	2021-07-27 10:21:46.599	error	at IncomingMessage.emit (events.js:203:15)
            boschindego.0	2021-07-27 10:21:46.599	error	at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/axios/lib/adapters/http.js:260:11)
            boschindego.0	2021-07-27 10:21:46.599	error	at settle (/opt/iobroker/node_modules/axios/lib/core/settle.js:17:12)
            boschindego.0	2021-07-27 10:21:46.599	error	at createError (/opt/iobroker/node_modules/axios/lib/core/createError.js:16:15)
            boschindego.0	2021-07-27 10:21:46.599	error	(17119) Error: Request failed with status code 401
            boschindego.0	2021-07-27 10:21:46.599	error	(17119) unhandled promise rejection: Request failed with status code 401
            boschindego.0	2021-07-27 10:21:46.598	error	(17119) error in alerts request: Error: Request failed with status code 401
            Soweit scheint aber alles zu funktionieren, nur dass diese Meldungen vorher nicht kamen.
              @flocke112
              Text der in CodeTags gesetzt werden soll markieren,
              </> anklicken, absenden.
              Sieht dann so aus wie bei @integer63
              Viel besser lesbar.
                withstu @Thomas Braun last edited by
                @thomas-braun Folgender PR sollte die Fehlermeldung beheben: https://github.com/a1development/ioBroker.boschindego/pull/25
                Die Fehler waren übrigens vorher auch schon da. Ich hatte lediglich das Logging für die Nachrichten hinzugefügt. Hintergrund ist hier, dass der User nach einer gewissen Zeit nicht mehr angemeldet ist. Der Adapter meldet sich nach einem solchen Fehler neu an. Man könnte jetzt vor jede API Abfrage die checkAuth Methode packen, aber das macht glaub ich auch nicht so viel Sinn.
                withstu created this issue in a1development/ioBroker.boschindego
                closed fix 401 errors #25
                  Der Adapter steigt immer wieder aus! Würde gerne mal die alte 0.9.10 Version wieder installieren, das funktioniert allerdings nicht im Expertenmodus bei den Adaptern. Kann man das irgendwie downgraden?
                  Wäre mal interessant ob das Problem dann weiter besteht.
                  LG
                    @flocke112
                    Ich würde ja eher in dieser Richtung schauen:
                      a1development @withstu last edited by a1development
                      @withstu Das hat sich etwas überschnitten.
                      Ich habe zeitgleich mit einer etwas umfangreicheren Änderung an dem Adapter angefangen die ein paar Punkte optimieren sollen.
                      • Bot soll nicht ständig aufgeweckt werden ( "Display leuchtet" )
                      • Kommunikation zum Service soll wesentlich effizienter gehandelt werden.
                      Ich bin gerade noch bei Tests, die ich bis morgen beobachten möchte, bevor ich eine neue Version online stelle.
                      Daher wird der PR vermutlich nicht mehr ganz passen. Ich habe ihn mir aber angeschaut und die Punkte werden durch die Änderungen eh etwas anders gehandelt.
                        So, hab jetzt die Ladestation vom Indego näher ans Haus gesetzt. Siehe da, der Adapter schmiert nicht mehr ab und im LOG sind auch keine Fehlermeldungen mehr. Scheint wohl alles nur ein Problem der mangelhaften W-LAN Verbindung gewesen zu sein. Gartenumgestaltung und neue Adapterversion in kurzem Abstand, war für mein Fachverstand wohl etwas zu viel.
                        Entschuldigung, dass ich hier alle mit meinen persönlichen Unzulänglichkeiten genervt habe.
                        LG
                          Stand ja auch so sinngemäß im Log drin.
                            NEUE VERSION 0.9.12
                            In der aktuellen Version habe ich mich um das Problem des "leuchtenden Displays" gekümmert,
                            das dadurch entstanden ist weil der Bot bei Anfragen immer wieder aufgeweckt werden musste.
                            Wenn der Bot nicht fährt und nicht geladen wird, sollten diese Anfragen nicht mehr laufen. Generell verwendet der Adapter eine etwas andere Herangehensweise die Daten abzufragen, die wesentlich Akku / Datenschonender sein sollte.
                            Ich habe es soweit bei mir jetzt 2 Tage getestet und konnte in der Art wie ich den Bot einsetzte eine Verbesserung feststellen.
                            Einzige bekannte und geplante Einschränkung ist das Update des Batteriestatus.
                            Dieser wird beim mähen und beim laden weiterhin kontinuierlich aktualisiert, außerhalb dieser Aktionen allerdings nur, wenn sich auch der Status des Bots ändert.
                            Hintergrund: Das abfragen des Akkustands hat den mäher immer aufgeweckt ( display an + mehr stromverbrauch + Mobilfunkverbindung ). Ich denke das die Akkuinformationen beim mähen / laden sicherlich spannend sind, aber im Dock ohne Veränderung des Zustands eher nicht permanent geupdated werden müssen ( was ja zu einem höheren Verbrauch / Verschleiß führen würde )
                            T B 3 Replies Last reply Reply Quote 0
                              Tontechniker @a1development last edited by
                              @a1development
                              Danke für die neue Version! Habe sie gestern installiert und sie funktioniert!
                              ? 1 Reply Last reply Reply Quote 1
                                Tontechniker @a1development last edited by Tontechniker
                                @a1development
                                Ich bekomme noch folgende Info/Fehlermeldung im Log, nachdem der Bot in "Docked - Waking up" steht und ich "Refresh Status" ausführe (5 = erste Meldung. 1 = letzte Meldung):
                                boschindego.0	2021-07-30 10:20:13.497	info	(1863) connect ok
                                boschindego.0	2021-07-30 10:20:12.974	info	(1863) connect
                                boschindego.0	2021-07-30 10:20:12.972	error	(1863) connection error{"message":"Request failed with status code 401","name":"Error","stack":"Error: Request failed with status code 401\n at createError (/opt/iobroker/node_modules/axios/lib/co
                                boschindego.0	2021-07-30 10:20:12.947	error	(1863) error in operatingData request: Error: Request failed with status code 401
                                boschindego.0	2021-07-30 10:20:12.822	info	(1863) state boschindego.0.commands.refresh_state changed: (ack = false)
                                Beim nächsten Ausführen von "Refresh Status" kommt
                                boschindego.0	2021-07-30 10:21:50.938	info	(1863) state boschindego.0.commands.refresh_state changed: (ack = false)
                                Mache ich noch etwas falsch?
                                  BiboX @a1development last edited by BiboX
                                  @a1development said in ADAPTER FÜR Bosch Indego Connect:
                                  Moin. Zuerst auch herzlichen Dank für die neue Version. Läuft bisher super.
                                  Was der Batteriestatus angeht, so scheint der Wert bei mir schlicht nicht korrekt zu sein.
                                  Er ist immer die Voltzahl * 10 ...
                                  Während die App einen niedrigen Batteriestand anzeigt, ist der Adapter der Meinung es wären noch über 50% Ladung vorhanden.
                                  Ist das ein generelles Problem (Bug) oder nur bei mir so?
                                  Danke und Grüße,
                                  Bibo
                                  EDIT: Ich muss das relativieren... Die Ladeanzeige der App scheint irgendwie grütze zu sein. Kann nicht sicher sagen, ob die App falsch anzeigt, oder der o.g. Batteriestatus falsch ist. Würde das bei Gelegenheit am Gerät noch mal prüfen.
                                    flocke112 @BiboX last edited by flocke112
                                    @bibox
                                    ... also bei mir werden die Werte "voltage" und "percent" in (vermutlich) Echtzeit aktualisiert. Wenn die App VOLL anzeigt, sind es auch 100% im Adapter.
                                    LG
                                      kassmann @flocke112 last edited by
                                      @flocke112 bei mir passen die Anzeigen auch zum tatsächlichen Wert! 👍 😊
                                        a1development @Tontechniker last edited by
                                        @tontechniker
                                        Nein da machst du nichts falsch. Ich sollte da an der Stelle noch das Error logging rausnehmen. Da es tatsächlich ein eingeplanter "Fehler" ist. Die Authentifizierung ist in dem Moment bei dir abgelaufen und muss erneuert werden, das sollte natürlich einfach im Hintergrund gehandelt werden, ohne das du darüber informiert wirst. In der nächsten Version ist es raus. Ich würde dafür nur ungerne jetzt eine neue Version online nehmen, da sich sonst nichts geändert hat.
                                        Wie oft kommt das bei dir vor?
                                        W T 2 Replies Last reply Reply Quote 0
                                          withstu @a1development last edited by
                                          @a1development Genau das Verhalten hatte ich mit meinem PR gelöst. Das Problem ist, dass im Refresh State das getOperationData außerhalb des try catch ausgeführt wird. In dem catch block werden nämlich Anmeldefehler korrekt verarbeitet und sich neu verbunden. Es gibt also zwei Möglichkeiten (Fehler Logging auskommentieren ist für mich keine, da damit der Fehler ja nicht behoben ist):
                                          1. getOperationData in den Catch Block
                                          2. eine Funktion schreiben handleConnectError(err), die in jeden axios catch Block eingefügt wird
                                            @a1development
                                            Es wäre schön, wenn Du es bei einer der nächsten Versionen ändern würdest. Über die Anzahl der Meldungen kann ich noch keine Auskunft geben. Bei dem derzeitigen Wetter lasse ich den ROBBY nur fahren, wenn es sicher nicht regnet.
                                            Danke und Gruß
                                            Hans
                                            232
                                            41918
