    3. Off Topic
    4. Bezahlte IOBroker Hilfe um Kerpen gesucht!
      Thomas Braun Most Active @sascha100 last edited by
      @sascha100 Ich dachte SSH funktioniert?
        sascha100 @Thomas Braun last edited by
        ja das schon aber ich sitze im Moment nicht im Wohnmobil! 🙂 und habe auch keinen Fernzugriff.
          sascha100 @Thomas Braun last edited by Homoran
          @thomas-braun said in Bezahlte IOBroker Hilfe um Kerpen gesucht!:
          iobroker status
          Guten Morgen Thomas,
          das ist die Ausgabe :
          pi@SmartWoMo:~ $ iobroker status
          internal/modules/cjs/loader.js:818
            throw err;
          Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
              at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
              at Function.Module._load (internal/modules/cjs/loader.js:667:27)
              at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
              at internal/main/run_main_module.js:17:47 {
            code: 'MODULE_NOT_FOUND',
            requireStack: []
          MOD-Edit: Code in code-tags gesetzt!
            Thomas Braun Most Active @sascha100 last edited by Thomas Braun
            @sascha100
            iobroker stop
            iobroker fix
            cd /opt/iobroker
            sudo -H -u iobroker npm install iobroker.js-controller
            iobroker start
              iobroker fix
              danke für die schnelle Antwort:
              Hier die Ausgabe im Terminal:
              pi@SmartWoMo:~ $ iobroker stop
              pi@SmartWoMo:~ $ iobroker fix
              library: loaded
              Library version=2021-04-07
              ioBroker is not installed in /opt/iobroker! Cannot fix anything...
              pi@SmartWoMo:~ $
              pi@SmartWoMo:~ $ cd /opt/iobroker
              pi@SmartWoMo:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
              npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
              npm WARN deprecated har-validator@5.1.5: this library is no longer supported
              npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/copy-props/node_modules/is-plain-object
              npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/ecc-jsbn
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
              npm ERR! code EACCES
              npm ERR! syscall access
              npm ERR! path /opt/iobroker/node_modules/iobroker.javascript/node_modules/copy-props/node_modules/is-plain-object
              npm ERR! errno -13
              npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.javascript/node_modules/copy-props/node_modules/is-plain-object'
              npm ERR!  [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.javascript/node_modules/copy-props/node_modules/is-plain-object'] {
              npm ERR!   errno: -13,
              npm ERR!   code: 'EACCES',
              npm ERR!   syscall: 'access',
              npm ERR!   path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/copy-props/node_modules/is-plain-object'
              npm ERR! }
              npm ERR!
              npm ERR! The operation was rejected by your operating system.
              npm ERR! It is likely you do not have the permissions to access this file as the current user
              npm ERR!
              npm ERR! If you believe this might be a permissions issue, please double-check the
              npm ERR! permissions of the file and its containing directories, or try running
              npm ERR! the command again as root/Administrator.
              npm ERR!     /home/iobroker/.npm/_logs/2021-07-29T10_05_22_993Z-debug.log
              Nach dem Start kann ich iobroker nicht aufrufen.
              mikeal created this issue in request/request
              open Request’s Past, Present and Future #3142
                ich hoffe ich habe jetzt nichts falsch gemacht. Da die Konsole sagte das nichts im Verzeichnis vorhanden ist habe ich iobroker erneut installiert.
                Jetzt bekomme ich bei der Statusabfrage folgendes:
                Objects type: file
                States  type: file
                pi@SmartWoMo:~ $
                Leider kann ich den iobroker immer noch nicht über das Webinterface erreichen. Ich benutze Chrome und habe es auch mit Edge getestet.
                  @sascha100
                  kann auf eine defekte SD-Karte hindeuten.
                  dmesg -T | grep -i ext4
                  macht dich schlauer.
                    wie immer danke für deine Antwort:
                    hier die Ausgabe:
                    pi@SmartWoMo:~ $ dmesg -T | grep -i ext4
                    [Do Jul 29 12:25:23 2021] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:640x480M@60 smsc95xx.macaddr=DC:A6:32:C5:C8:9D vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=7da69e20-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                    [Do Jul 29 12:25:24 2021] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                    [Do Jul 29 12:25:24 2021] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                    [Do Jul 29 12:25:27 2021] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                    pi@SmartWoMo:~ $
                    Mich macht es nicht schlauer aber eventuell kannst du mir sagen ob die Karte defekt ist. Das wäre für mich extrem unangenehm. Es hat eine Ewigkeit gedauert alles zu konfigurieren und ich weis nicht ob ich das so nochmal schaffe. Daher gleich noch eine Frage:
                    • ich habe immer noch vollen Zugriff per WinSCP. Ich benutze unter anderem 5 Modebus Adapter um Daten auszulesen. Kann man das irgendwie sichern? Das wäre mir extrem wichtig. Kann man die VIS sichern? Ich habe den Ordner der VIS unter VIS.0 gefunden. Reicht das um es wieder auf einen neuen aufzuspielen?
                    Danke dir für die Hilfe!
                      Darf ich gleich noch eine Frage stellen?
                      Das habe ich auf meinem Raspi gefunden. Ist das zufällig ein komplett Backup? Dann wäre ich sehr happy.
                      J Homoran 2 Replies Last reply Reply Quote 0
                        Jan1 @sascha100 last edited by
                        @sascha100
                        Von der Größe sieht es danach aus 😉
                          @sascha100 sagte in Bezahlte IOBroker Hilfe um Kerpen gesucht!:
                          Nein, das sind die normalen Meldungen beim Systemstart. Eine defekte Karte würde sich anders melden.
                          Die fehlenden Rechte kommen mir immer noch komisch vor.
                          groups
                          sudo -u iobroker groups
                          liefert?
                            Homoran Global Moderator Administrators @sascha100 last edited by Homoran
                            Erst einmal solltest du diese Dateien auf einem PC sichern!
                            Kommt darauf an, was du unter komplett verstehst.
                            Das sieht schon mal nach ordentlich angelegten regelmäßigen BackitUp Backups aus.
                            Diese enthalten alle Konfigurationen deiner Adapter, alle Scripte und alle Views.
                            was meinst du denn hiermit:
                              sascha100 @Jan1 last edited by
                              @jan1
                              ohhh danke das lässt hoffen.
                                @sascha100
                                normal weiß man aber wo die Backups herkommen und homoran schreibt ja auch nach was das aussieht
                                  Hier die Ausgabe:
                                  pi@SmartWoMo:~ $ sudo -u iobroker groups
                                  iobroker tty dialout audio video bluetooth gpio i2c
                                  pi@SmartWoMo:~ $
                                    sascha100 @Homoran last edited by
                                    ich meinte damit die Einstellungen der Adapter und der VIS. So wie du schreibst könnte es das ja sein. Das gibt mir Hoffnung.
                                    Ich habe den Modbus Adapter 5 mal angelegt da ich eine Victron Cerbo GX auslese. es hat nur funktioniert wenn ich für jedes an die Cerbo angeschlossen Gerät einen eigenen Modbusadapter angelegt habe. Das war für mich viel Arbeit und Einstellungen bis das lief darum möchte / muss ich das unbedingt sichern.
                                    Ich hoffe ich konnte erklären was ich meine.
                                      @sascha100
                                      Da fehlt die Ausgabe von
                                      groups
                                      Wem gehören denn die Dateien?
                                      ls -la /opt/iobroker/node_modules/iobroker.javascript/node_modules/copy-props/node_modules/is-plain-object
                                      bzw.
                                      getfacl /opt/iobroker/node_modules/iobroker.javascript/node_modules/copy-props/node_modules/is-plain-object
                                        im WoMo??
                                        ist das nicht Kanonen auf Spatzen?
                                        was hast du denn da alles dran?
                                        ein SmartSolar MPPT 100/50 über ve-direct plane ich ja auch, ggf. noch ein BMV, aber mehr fällt mir gar nicht ein
                                          🙂 ja das kann man so nennen. Da wir auch Strandurlaube machen brauche ich Beschäftigung. 😑 Das ist nicht so meins aber happy wife happe life. Zum anderen hatte ich überlegt meine Hausautomation über die VIS schöner zu gestalten. Somit kann ich es damit eventuell lernen.
                                          An der Cerbo hängt ein MPPT, ein Charger, ein Shunt sowie Tanksensoren und Temperatursensoren. Einen BMV habe ich nicht. Des weiteren möchte ich meinen BMS von der LifePoe4 auslesen und anzeigen. Ich hatte mir eine VIS gebaut wo alle Daten angezeigt werden. Diese rufe ich über das Tablet auf. Alles ein bisschen mit Grafana auswerten, einfach nur weil ich es lernen möchte.
                                          Weiterhin möchte ich dann gewisse Dingen (Ich weis es auch noch nicht genau) per Telegram mitgeteilt bekommen.
                                          Zigbee ist zum Beispiel auch installiert und die Fenster und Klappen werden / sind mit Aquara Sensoren ausgestattet.
                                          Tankentleerung über Ventil über die VIS. Geht auch einfacher aber warum nicht.
                                          Das mal als grobe Umschreibung.
                                            sascha100 @Thomas Braun last edited by sascha100
                                            hier die Ausgabe: Da fehlt was würde ich sagen.
                                            pi@SmartWoMo:~ $ ls -la /opt/iobroker/node_modules/iobroker.javascript/node_modules/copy-props/node_modules/is-plain-object
                                            ls: Zugriff auf '/opt/iobroker/node_modules/iobroker.javascript/node_modules/copy-props/node_modules/is-plain-object' nicht möglich: Datei oder Verzeichnis nicht gefunden
                                            pi@SmartWoMo:~ $ getfacl /opt/iobroker/node_modules/iobroker.javascript/node_modules/copy-props/node_modules/is-plain-object
                                            getfacl: /opt/iobroker/node_modules/iobroker.javascript/node_modules/copy-props/node_modules/is-plain-object: Datei oder Verzeichnis nicht gefunden
                                            pi@SmartWoMo:~ $
                                            2081
