    4. Adapter Hyundai (Bluelink) oder KIA (UVO)
      Morgennebel @Michaelnorge last edited by
      @michaelnorge Bei mir ebenfalls:
      (28109) ManagedBluelinkyError: @EuropeController.login: [400] Bad Request on [POST] https://prd.eu-ccapi.kia.com:8080/api/v1/user/signin - {"errId":"40e2388d-b91b-43cb-b4a8-b24bcbfaabcf","errCode":"4
      (28109) Login to api
      (28109) starting. Version 1.0.5 in /opt/iobroker/node_modules/iobroker.bluelink, node: v14.16.1, js-controller: 3.2.16
      instance system.adapter.bluelink.0 started with pid 28109
      Ich bin bereits auf einem migrierten Account und die UVO-App auf dem Handy läuft normal.
      Danke, -MN
      Newan 1 Reply Last reply Reply Quote 0
      • Newan
        Newan @Morgennebel last edited by
        @morgennebel testet nochmal reinstall. Wenn erfolgreich bau ich morgen ne stable
        M M 2 Replies Last reply Reply Quote 0
          Michaelnorge @Newan last edited by
          @newan Neuinstallation hat was gebracht, der Adapter funktioniert jetzt wieder.
          Vielleicht könntest Du auch noch die ganzen Warnungen elimieren? 😉
          bluelink.0
          2021-07-06 14:49:03.422	warn	Read-only state "bluelink.0.odometer.unit" has been written without ack-flag with value "1"
          bluelink.0
          2021-07-06 14:49:03.415	warn	Read-only state "bluelink.0.odometer.value" has been written without ack-flag with value "17099.5"
          bluelink.0
          2021-07-06 14:49:03.407	warn	Read-only state "bluelink.0.vehicleLocation.speed" has been written without ack-flag with value "0"
          bluelink.0
          2021-07-06 14:49:03.399	warn	Read-only state "bluelink.0.vehicleLocation.lon" has been written without ack-flag with value "11.716155"
          bluelink.0
          2021-07-06 14:49:03.391	warn	Read-only state "bluelink.0.vehicleLocation.lat" has been written without ack-flag with value "60.238214"
          bluelink.0
          2021-07-06 14:49:03.374	warn	Read-only state "bluelink.0.vehicleStatus.battery.state-12V" has been written without ack-flag with value "0"
          bluelink.0
          2021-07-06 14:49:03.361	warn	Read-only state "bluelink.0.vehicleStatus.battery.soc-12V" has been written without ack-flag with value "89"
          bluelink.0
          2021-07-06 14:49:03.347	info	State value to set for "bluelink.0.vehicleStatus.battery.plugin" has to be type "boolean" but received type "number"
          bluelink.0
          2021-07-06 14:49:03.346	warn	Read-only state "bluelink.0.vehicleStatus.battery.plugin" has been written without ack-flag with value "0"
          bluelink.0
          2021-07-06 14:49:03.338	warn	Read-only state "bluelink.0.vehicleStatus.battery.charge" has been written without ack-flag with value "false"
          bluelink.0
          2021-07-06 14:49:03.331	warn	Read-only state "bluelink.0.vehicleStatus.battery.soc" has been written without ack-flag with value "37"
          bluelink.0
          2021-07-06 14:49:03.282	warn	Read-only state "bluelink.0.vehicleStatus.evModeRange" has been written without ack-flag with value "125"
          bluelink.0
          2021-07-06 14:49:03.274	warn	Read-only state "bluelink.0.vehicleStatus.dte" has been written without ack-flag with value "125"
          bluelink.0
          2021-07-06 14:49:03.251	warn	Read-only state "bluelink.0.vehicleStatus.airCtrlOn" has been written without ack-flag with value "false"
          bluelink.0
          2021-07-06 14:49:03.202	warn	Read-only state "bluelink.0.vehicleStatus.hoodOpen" has been written without ack-flag with value "false"
          bluelink.0
          2021-07-06 14:49:03.193	warn	Read-only state "bluelink.0.vehicleStatus.trunkOpen" has been written without ack-flag with value "false"
          bluelink.0
          2021-07-06 14:49:03.182	warn	Read-only state "bluelink.0.vehicleStatus.doorLock" has been written without ack-flag with value "true"
          • Newan
            Newan @Michaelnorge last edited by
            @michaelnorge Version 1.0.6 bitte testen!
            docadams 1 Reply Last reply Reply Quote 0
            • docadams
              docadams @Newan last edited by
              @newan
              der Regen hat mir die Zeit verschafft, die neue Version zu testen.
              Seit ca. 8 Stunden läufts. Die Zukunft wird es zeigen.
              Allerdings hatte ich 2 mal (für mich scheinbar anlasslos) diese Meldungen:
              Mal was Anderes. Ist nicht schlimm und vielleicht sowieso zu spät.
              Für mich, der nicht ständig am ioBrocker sitzen kann, ist es leicht verwirrend, wenn der Adapter unter Hyundai firmiert, die Daten, mit denen ich meist zu tun habe, aber unter Bluelink zu finden sind.
              Nur mal so, ansonsten TOP Arbeit, Danke.
                Morgennebel @Newan last edited by
                @newan Vielen Dank für die tolle Unterstützung. Läuft jetzt prima.
                Nebenbei gefragt, wie kann ich denn die Werte aus
                mit dee LOVELACE Karte nutzen? Meine bisherige Konfiguration ist:
                type: map
                entities: []
                hours_to_show: 0
                was mir die leere Karte meines Heimatortes aus der global Konfig anzeigt...
                Danke, -MN
                C Newan 2 Replies Last reply Reply Quote 0
                  ChristianF @Morgennebel last edited by
                  Hallo, ich wollte mich auch mal für den Adapter bedanken, toll dass er jetzt wieder funktioniert 🙂
                  Trotzdem habe ich noch einen kleinen Bug zu melden: wenn mehrere VINs in einem Account gepflegt sind, zum Beispiel weil jemand wie wir zwei Konas hat, wird nur ein Auto ausgelesen und in die Datenpunkte geschrieben, obwohl in den Instanzen unterschiedliche VINs gepflegt sind. Das zweite Auto können wir also nicht auslesen 😞
                  In der Bluelink App sind beide Autos sichtbar und man kann zwischen beiden hin und her switchen.
                  • Newan
                    Newan @ChristianF last edited by
                    @christianf ok danke fürs Feedback. Bräuchte dann zum Testen mal 2 vins in einem Account zum testen. Könnte mir einer was entsprechend bereitstellen? Habe kein Fahrzeug von dem Typ
                    • Newan
                      @morgennebel sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                      LOVELACE Karte
                      Hallo die Karte kenn ich nicht, aber die Werte aus dem Adapter funktionieren super in Google Maps
                      • Newan
                        Version 1.0.8 mit der Option laden zu starten und zu stoppen, könnte das einer testen, habe kein Fahrzeug und kein Account derzeit!
                          klauswu @Newan last edited by
                          @newan Hallo und einen schönen Tag.
                          Habe einen Kia E-Niro und würde das gerne testen, weiss aber nicht was ich bei PIN eingeben muss! VIN hab ich.
                          Das ist wahrscheinlich eine ziemlich blöde Frage, stehe aber momentan komplett am Schlauch. Sorry.
                          Klaus
                          Jackl1st 1 Reply Last reply Reply Quote 0
                            MichaelWit last edited by
                            @newan Hallo, habe seit heute das Problem das ich keine Daten mehr vom Adapter zurück bekomme.
                            Hier die Meldung aus dem Log:
                            (13504) @EuropeVehicle.fullStatus: [408] Request Timeout on [GET] https://prd.eu-ccapi.kia.com:8080/api/v2/spa/vehicles/a9bd4b32-ae03-4776-90b3-fc9cc48f716a/status - {"retCode":"F","resCode":"4081","
                            bluelink.0
                            Update auf 1.0.8 habe ich gemacht..Die App funktioniert.
                            Irgendeine Idee woran es liegt?
                            Michael
                            • Jackl1st
                              Jackl1st @klauswu last edited by
                              @klauswu ,Hallo bei Pin die Pin der App.
                              • Newan
                                Newan @MichaelWit last edited by
                                @michaelwit sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                                Request Timeout
                                Timeout ist was für Api Probleme oder deine Internetleitung.
                                  MichaelWit @Newan last edited by
                                  @newan
                                  Danke…hat sich jetzt erledigt. Funktioniert wieder…Selbstheilung…Keine Ahnung woran es lag.
                                    klauswu @Jackl1st last edited by
                                    @jackl1st Danke schon mal!
                                      Hallo, hat eigentlich schon mal jemand versucht die Werte in "A better Route Planer" zu übernehmen? Das wäre möglicherweise interessant.
                                      docadams M 2 Replies Last reply Reply Quote 0
                                      • docadams
                                        docadams @klauswu last edited by
                                        @klauswu Meinst du im ioBroker?
                                        Das wäre mir echt zu unsicher, da von unterwegs praktisch live Daten zu übertragen. Dann wäre die tägliche maximale Abrufmenge schnell erschöpft.
                                        Ich nutze ABRP, aber die Livedaten kommen von evNotify. Das funktionierte zu unserer Urlaubsfahrt (rund 1000km) sehr zuverlässig.
                                        • docadams
                                          docadams @docadams last edited by
                                          seit ein paar Tagen klappt es wieder nicht mehr.
                                          Ich habe heute den Adapter deinstalliert und die neueste Versiongeladen.
                                          Das Log meint Folgendes:
                                          Ich habe die Anzahl der Zugriffe begrenzt, darum vielleicht der Error. Aber auch bei den vorherigen Versuchen kam er nicht über "Read New status from API" hinaus.
                                          Klappt es bei euch noch?
                                            Michaelnorge @docadams last edited by
                                            @docadams Gerade probiert, bei mir läuft der Adapter ohne Probleme.
                                            2296
                                            858189
