    4. Z-wave2 mit iobroker verbinden (im Netzwerk)
      Thomas Braun Most Active @rhartmann76 last edited by Thomas Braun
      @rhartmann76 sagte in Z-wave2 mit iobroker verbinden (im Netzwerk):
      Somit würde ich es eigentlich ausschließen
      Deine Kernel-Ring-Meldungen sagen ganz eindeutig etwas anderes:
      [Mon Aug  2 14:25:38 2021] Voltage normalised (0x00000000)
      [Mon Aug  2 14:25:42 2021] Under-voltage detected! (0x00050005)
      [Mon Aug  2 14:25:48 2021] Voltage normalised (0x00000000)
      [Mon Aug  2 14:30:36 2021] rpi_firmware_get_throttled: 10 callbacks suppressed
      [Mon Aug  2 14:30:36 2021] Voltage normalised (0x00000000)
      [Mon Aug  2 14:30:42 2021] rpi_firmware_get_throttled: 11 callbacks suppressed
      [Mon Aug  2 14:30:42 2021] Under-voltage detected! (0x00050005)
      [Mon Aug  2 14:30:48 2021] Voltage normalised (0x00000000)
      [Mon Aug  2 14:31:19 2021] Under-voltage detected! (0x00050005)
      [Mon Aug  2 14:31:25 2021] Voltage normalised (0x00000000)
      [Mon Aug  2 14:31:30 2021] Under-voltage detected! (0x00050005)
      • AlCalzone
        AlCalzone Developer @rhartmann76 last edited by
        @rhartmann76 Was steht denn jetzt in der Logdatei?
        Siehe https://github.com/AlCalzone/ioBroker.zwave2/blob/master/docs/de/bei-problemen.md#notwendige-informationen-für-ein-issue
          rhartmann76 @AlCalzone last edited by rhartmann76
          @alcalzone
          pi@raspberrypi:/opt/iobroker/node_modules/iobroker.zwave2/build $ cat zwavejs_2021-08-02.log
          2021-08-02T12:37:21.254Z DRIVER   ███████╗ ██╗    ██╗  █████╗  ██╗   ██╗ ███████╗             ██╗ ███████╗
          2021-08-02T12:37:21.257Z DRIVER   version 7.12.1
          2021-08-02T12:37:21.258Z DRIVER
          2021-08-02T12:37:21.259Z DRIVER   starting driver...
          2021-08-02T12:37:21.305Z DRIVER   opening serial port /dev/ttyAMA0
          2021-08-02T12:37:21.344Z DRIVER   serial port opened
          2021-08-02T12:37:21.347Z SERIAL » [NAK]        (0x15)
          2021-08-02T12:42:56.953Z DRIVER   ███████╗ ██╗    ██╗  █████╗  ██╗   ██╗ ███████╗             ██╗ ███████╗
          2021-08-02T12:42:56.956Z DRIVER   version 7.12.1
          2021-08-02T12:42:56.957Z DRIVER
          2021-08-02T12:42:56.958Z DRIVER   starting driver...
          2021-08-02T12:42:57.004Z DRIVER   opening serial port /dev/ttyAMA0
          2021-08-02T12:42:57.041Z DRIVER   serial port opened
          2021-08-02T12:42:57.044Z SERIAL » [NAK]        (0x15)
          2021-08-02T12:49:04.410Z DRIVER   ███████╗ ██╗    ██╗  █████╗  ██╗   ██╗ ███████╗             ██╗ ███████╗
          2021-08-02T12:49:04.414Z DRIVER   version 7.12.1
          2021-08-02T12:49:04.415Z DRIVER
          2021-08-02T12:49:04.416Z DRIVER   starting driver...
          2021-08-02T12:49:04.461Z DRIVER   opening serial port /dev/ttyAMA0
          2021-08-02T12:49:04.497Z DRIVER   serial port opened
          2021-08-02T12:49:04.500Z SERIAL » [NAK]        (0x15)
          2021-08-02T12:54:41.665Z DRIVER   ███████╗ ██╗    ██╗  █████╗  ██╗   ██╗ ███████╗             ██╗ ███████╗
          2021-08-02T12:54:41.669Z DRIVER   version 7.12.1
          2021-08-02T12:54:41.670Z DRIVER
          2021-08-02T12:54:41.672Z DRIVER   starting driver...
          2021-08-02T12:54:41.737Z DRIVER   opening serial port /dev/ttyAMA0
          2021-08-02T12:54:41.793Z DRIVER   serial port opened
          2021-08-02T12:54:41.796Z SERIAL » [NAK]        (0x15)
          2021-08-02T12:57:32.676Z DRIVER   destroying driver instance...
          2021-08-02T12:57:39.712Z DRIVER   ███████╗ ██╗    ██╗  █████╗  ██╗   ██╗ ███████╗             ██╗ ███████╗
          2021-08-02T12:57:39.717Z DRIVER   version 7.12.1
          2021-08-02T12:57:39.719Z DRIVER
          2021-08-02T12:57:39.720Z DRIVER   starting driver...
          2021-08-02T12:57:39.806Z DRIVER   opening serial port /dev/ttyAMA0
          2021-08-02T12:57:39.863Z DRIVER   serial port opened
          2021-08-02T12:57:39.868Z SERIAL » [NAK]        (0x15)
          2021-08-02T13:03:18.444Z DRIVER   ███████╗ ██╗    ██╗  █████╗  ██╗   ██╗ ███████╗             ██╗ ███████╗
          2021-08-02T13:03:18.447Z DRIVER   version 7.12.1
          2021-08-02T13:03:18.448Z DRIVER
          2021-08-02T13:03:18.449Z DRIVER   starting driver...
          2021-08-02T13:03:18.495Z DRIVER   opening serial port /dev/ttyAMA0
          2021-08-02T13:03:18.534Z DRIVER   serial port opened
          2021-08-02T13:03:18.536Z SERIAL » [NAK]        (0x15)
          2021-08-02T13:09:05.481Z DRIVER   ███████╗ ██╗    ██╗  █████╗  ██╗   ██╗ ███████╗             ██╗ ███████╗
          2021-08-02T13:09:05.484Z DRIVER   version 7.12.1
          2021-08-02T13:09:05.485Z DRIVER
          2021-08-02T13:09:05.486Z DRIVER   starting driver...
          2021-08-02T13:09:05.532Z DRIVER   opening serial port /dev/ttyAMA0
          2021-08-02T13:09:05.567Z DRIVER   serial port opened
          2021-08-02T13:09:05.570Z SERIAL » [NAK]        (0x15)
          2021-08-02T13:14:32.512Z DRIVER   ███████╗ ██╗    ██╗  █████╗  ██╗   ██╗ ███████╗             ██╗ ███████╗
          2021-08-02T13:14:32.515Z DRIVER   version 7.12.1
          2021-08-02T13:14:32.516Z DRIVER
          2021-08-02T13:14:32.517Z DRIVER   starting driver...
          2021-08-02T13:14:32.564Z DRIVER   opening serial port /dev/ttyAMA0
          2021-08-02T13:14:32.599Z DRIVER   serial port opened
          2021-08-02T13:14:32.602Z SERIAL » [NAK]        (0x15)
          2021-08-02T13:20:12.946Z DRIVER   ███████╗ ██╗    ██╗  █████╗  ██╗   ██╗ ███████╗             ██╗ ███████╗
          2021-08-02T13:20:12.949Z DRIVER   version 7.12.1
          2021-08-02T13:20:12.951Z DRIVER
          2021-08-02T13:20:12.951Z DRIVER   starting driver...
          2021-08-02T13:20:12.997Z DRIVER   opening serial port /dev/ttyAMA0
          2021-08-02T13:20:13.032Z DRIVER   serial port opened
          2021-08-02T13:20:13.035Z SERIAL » [NAK]        (0x15)
          2021-08-02T13:25:23.559Z DRIVER   ███████╗ ██╗    ██╗  █████╗  ██╗   ██╗ ███████╗             ██╗ ███████╗
          2021-08-02T13:25:23.567Z DRIVER   version 7.12.1
          2021-08-02T13:25:23.569Z DRIVER
          2021-08-02T13:25:23.571Z DRIVER   starting driver...
          2021-08-02T13:25:23.671Z DRIVER   opening serial port /dev/ttyAMA0
          2021-08-02T13:25:23.740Z DRIVER   serial port opened
          2021-08-02T13:25:23.746Z SERIAL » [NAK]        (0x15)
          2021-08-02T13:31:22.995Z DRIVER   ███████╗ ██╗    ██╗  █████╗  ██╗   ██╗ ███████╗             ██╗ ███████╗
          2021-08-02T13:31:22.997Z DRIVER   version 7.12.1
          2021-08-02T13:31:22.999Z DRIVER
          2021-08-02T13:31:22.999Z DRIVER   starting driver...
          2021-08-02T13:31:23.044Z DRIVER   opening serial port /dev/ttyAMA0
          2021-08-02T13:31:23.080Z DRIVER   serial port opened
          2021-08-02T13:31:23.083Z SERIAL » [NAK]        (0x15)
          2021-08-02T13:36:46.842Z DRIVER   ███████╗ ██╗    ██╗  █████╗  ██╗   ██╗ ███████╗             ██╗ ███████╗
          2021-08-02T13:36:46.844Z DRIVER   version 7.12.1
          2021-08-02T13:36:46.846Z DRIVER
          2021-08-02T13:36:46.846Z DRIVER   starting driver...
          2021-08-02T13:36:46.892Z DRIVER   opening serial port /dev/ttyAMA0
          2021-08-02T13:36:46.928Z DRIVER   serial port opened
          2021-08-02T13:36:46.931Z SERIAL » [NAK]        (0x15)
          2021-08-02T13:40:45.374Z DRIVER   destroying driver instance...
          2021-08-02T13:41:41.268Z DRIVER   ███████╗ ██╗    ██╗  █████╗  ██╗   ██╗ ███████╗             ██╗ ███████╗
          2021-08-02T13:41:41.272Z DRIVER   version 7.12.1
          2021-08-02T13:41:41.274Z DRIVER
          2021-08-02T13:41:41.275Z DRIVER   starting driver...
          2021-08-02T13:41:41.347Z DRIVER   opening serial port /dev/ttyAMA0
          2021-08-02T13:41:41.396Z DRIVER   Serial port errored: Error: Permission denied, cannot open /dev/ttyAMA0
          2021-08-02T13:41:41.398Z DRIVER   destroying driver instance...
          2021-08-02T13:43:52.855Z DRIVER   ███████╗ ██╗    ██╗  █████╗  ██╗   ██╗ ███████╗             ██╗ ███████╗
          2021-08-02T13:43:52.858Z DRIVER   version 7.12.1
          2021-08-02T13:43:52.859Z DRIVER
          2021-08-02T13:43:52.860Z DRIVER   starting driver...
          2021-08-02T13:43:52.905Z DRIVER   opening serial port /dev/ttyAMA0
          2021-08-02T13:43:52.941Z DRIVER   Serial port errored: Error: Permission denied, cannot open /dev/ttyAMA0
          2021-08-02T13:43:52.942Z DRIVER   destroying driver instance...
          2021-08-02T13:54:14.856Z DRIVER   ███████╗ ██╗    ██╗  █████╗  ██╗   ██╗ ███████╗             ██╗ ███████╗
          2021-08-02T13:54:14.869Z DRIVER   version 7.12.1
          2021-08-02T13:54:14.871Z DRIVER
          2021-08-02T13:54:14.872Z DRIVER   starting driver...
          2021-08-02T13:54:14.939Z DRIVER   opening serial port /dev/ttyAMA0
          2021-08-02T13:54:14.986Z DRIVER   Serial port errored: Error: Permission denied, cannot open /dev/ttyAMA0
          2021-08-02T13:54:14.988Z DRIVER   destroying driver instance...
          2021-08-02T14:19:17.512Z DRIVER   ███████╗ ██╗    ██╗  █████╗  ██╗   ██╗ ███████╗             ██╗ ███████╗
          2021-08-02T14:19:17.516Z DRIVER   version 7.12.1
          2021-08-02T14:19:17.517Z DRIVER
          2021-08-02T14:19:17.518Z DRIVER   starting driver...
          2021-08-02T14:19:17.583Z DRIVER   opening serial port /dev/ttyAMA0
          2021-08-02T14:19:17.628Z DRIVER   Serial port errored: Error: Permission denied, cannot open /dev/ttyAMA0
          2021-08-02T14:19:17.630Z DRIVER   destroying driver instance...
          oh, kein Zugriff mehr auf den Port. Wie bekomme ic die Berechtingung wieder hin?
            @alcalzone
            2021-08-02T14:33:07.202Z DRIVER ███████╗ ██╗ ██╗ █████╗ ██╗ ██╗ ███████╗ ██╗ ███████╗
            2021-08-02T14:33:07.206Z DRIVER version 7.12.1
            2021-08-02T14:33:07.208Z DRIVER
            2021-08-02T14:33:07.209Z DRIVER starting driver...
            2021-08-02T14:33:07.271Z DRIVER opening serial port /dev/ttyAMA0
            2021-08-02T14:33:07.315Z DRIVER serial port opened
            2021-08-02T14:33:07.318Z SERIAL » [NAK] (0x15)
            2021-08-02T14:33:08.831Z DRIVER loading configuration...
            2021-08-02T14:33:08.837Z CONFIG version 7.12.1
            2021-08-02T14:33:39.212Z CONFIG Device index regenerated
            2021-08-02T14:33:39.338Z DRIVER beginning interview...
            2021-08-02T14:33:39.341Z DRIVER added request handler for AddNodeToNetwork (0x4a)...
            1 registered
            2021-08-02T14:33:39.342Z DRIVER added request handler for RemoveNodeFromNetwork (0x4b)...
            1 registered
            2021-08-02T14:33:39.342Z DRIVER added request handler for ReplaceFailedNode (0x63)...
            1 registered
            2021-08-02T14:33:39.346Z CNTRLR beginning interview...
            2021-08-02T14:33:39.347Z CNTRLR querying version info...
            2021-08-02T14:33:40.042Z SERIAL » 0x01030015e9 (5 bytes)
            2021-08-02T14:33:40.047Z DRIVER » [REQ] [GetControllerVersion]
            2021-08-02T14:33:40.069Z SERIAL « [ACK] (0x06)
            2021-08-02T14:33:40.079Z SERIAL « 0x011001155a2d5761766520342e3035000197 (18 bytes)
            2021-08-02T14:33:40.083Z SERIAL » [ACK] (0x06)
            2021-08-02T14:33:40.090Z DRIVER « [RES] [GetControllerVersion]
            payload: 0x5a2d5761766520342e30350001
            2021-08-02T14:33:40.120Z CNTRLR received version info:
            controller type: Static Controller
            library version: Z-Wave 4.05
            2021-08-02T14:33:40.121Z CNTRLR querying controller IDs...
            2021-08-02T14:33:40.154Z SERIAL » 0x01030020dc (5 bytes)
            2021-08-02T14:33:40.156Z DRIVER » [REQ] [GetControllerId]
            2021-08-02T14:33:40.162Z SERIAL « 0x010d000a0501010201045e9f6c5502 (15 bytes)
            2021-08-02T14:33:40.164Z SERIAL » [ACK] (0x06)
            2021-08-02T14:33:40.165Z SERIAL « [CAN] (0x18)
            2021-08-02T14:33:40.171Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
            n 100 ms.
            2021-08-02T14:33:40.176Z DRIVER « [REQ] [UNKNOWN_FUNC_UNKNOWN_0x0a]
            payload: 0x0501010201045e9f6c55
            2021-08-02T14:33:40.184Z DRIVER handling request UNKNOWN_FUNC_UNKNOWN_0x0a (10)
            2021-08-02T14:33:40.185Z DRIVER no handlers registered!
            2021-08-02T14:33:40.187Z SERIAL « 0x0115000400080f9f0378008fe38338860df0bf977d25d1 (23 bytes)
            2021-08-02T14:33:40.192Z DRIVER Dropping message because it could not be deserialized: The command class Secur
            ity 2 is not implemented
            2021-08-02T14:33:40.193Z SERIAL » [ACK] (0x06)
            2021-08-02T14:33:40.197Z SERIAL « 0x0114000400080e9f0379006b792e58d7b8ac056eae6e (22 bytes)
            2021-08-02T14:33:40.199Z DRIVER Dropping message because it could not be deserialized: The command class Secur
            2021-08-02T14:33:40.200Z SERIAL » [ACK] (0x06)
            2021-08-02T14:33:40.273Z SERIAL » 0x01030020dc (5 bytes)
            2021-08-02T14:33:40.275Z DRIVER » [REQ] [GetControllerId]
            2021-08-02T14:33:40.279Z SERIAL « [ACK] (0x06)
            2021-08-02T14:33:40.285Z SERIAL « 0x01080120cb35fd6b01bf (10 bytes)
            2021-08-02T14:33:40.287Z SERIAL » [ACK] (0x06)
            2021-08-02T14:33:40.289Z DRIVER « [RES] [GetControllerId]
            payload: 0xcb35fd6b01
            2021-08-02T14:33:40.301Z CNTRLR received controller IDs:
            home ID: 0xcb35fd6b
            own node ID: 1
            2021-08-02T14:33:40.302Z CNTRLR querying controller capabilities...
            2021-08-02T14:33:40.318Z SERIAL » 0x01030005f9 (5 bytes)
            2021-08-02T14:33:40.319Z DRIVER » [REQ] [GetControllerCapabilities]
            2021-08-02T14:33:40.324Z SERIAL « [ACK] (0x06)
            2021-08-02T14:33:40.328Z SERIAL « 0x010401051ce3 (6 bytes)
            2021-08-02T14:33:40.330Z SERIAL » [ACK] (0x06)
            2021-08-02T14:33:40.332Z DRIVER « [RES] [GetControllerCapabilities]
            payload: 0x1c
            2021-08-02T14:33:40.343Z CNTRLR received controller capabilities:
            controller role: primary
            is in other network: false
            is SIS present: true
            was real primary: true
            is a SUC: true
            2021-08-02T14:33:40.344Z CNTRLR querying API capabilities...
            2021-08-02T14:33:40.357Z SERIAL » 0x01030007fb (5 bytes)
            2021-08-02T14:33:40.358Z DRIVER » [REQ] [GetSerialApiCapabilities]
            2021-08-02T14:33:40.363Z SERIAL « [ACK] (0x06)
            2021-08-02T14:33:40.368Z SERIAL « 0x012b01070504014704000002fe83ff88cf1f0000fb9f7da067008080008086000 (45 bytes)
            000e87300000e0000401a005e
            2021-08-02T14:33:40.371Z SERIAL » [ACK] (0x06)
            2021-08-02T14:33:40.374Z DRIVER « [RES] [GetSerialApiCapabilities]
            payload: 0x0504014704000002fe83ff88cf1f0000fb9f7da067008080008086000000e8730
            0000e0000401a00
            2021-08-02T14:33:40.389Z CNTRLR received API capabilities:
            serial API version: 5.4
            manufacturer ID: 0x0147
            product type: 0x0400
            product ID: 0x02
            supported functions:
            · GetSerialApiInitData (0x02)
            · FUNC_ID_SERIAL_API_APPL_NODE_INFORMATION (0x03)
            · ApplicationCommand (0x04)
            · GetControllerCapabilities (0x05)
            · SetSerialApiTimeouts (0x06)
            · GetSerialApiCapabilities (0x07)
            · FUNC_ID_SERIAL_API_SOFT_RESET (0x08)
            · UNKNOWN_FUNC_UNKNOWN_0x09 (0x09)
            · UNKNOWN_FUNC_UNKNOWN_0x0a (0x0a)
            · SetRFReceiveMode (0x10)
            · UNKNOWN_FUNC_SET_SLEEP_MODE (0x11)
            · FUNC_ID_ZW_SEND_NODE_INFORMATION (0x12)
            · SendData (0x13)
            · SendDataMulticast (0x14)
            · GetControllerVersion (0x15)
            · SendDataAbort (0x16)
            · FUNC_ID_ZW_R_F_POWER_LEVEL_SET (0x17)
            · UNKNOWN_FUNC_SEND_DATA_META (0x18)
            · FUNC_ID_ZW_GET_RANDOM (0x1c)
            · GetControllerId (0x20)
            · UNKNOWN_FUNC_MEMORY_GET_BYTE (0x21)
            · UNKNOWN_FUNC_MEMORY_PUT_BYTE (0x22)
            · UNKNOWN_FUNC_MEMORY_GET_BUFFER (0x23)
            · UNKNOWN_FUNC_MEMORY_PUT_BUFFER (0x24)
            · UNKNOWN_FUNC_FlashAutoProgSet (0x27)
            · UNKNOWN_FUNC_UNKNOWN_0x28 (0x28)
            · GetNVMId (0x29)
            · ExtNVMReadLongBuffer (0x2a)
            · ExtNVMWriteLongBuffer (0x2b)
            · ExtNVMReadLongByte (0x2c)
            · ExtExtWriteLongByte (0x2d)
            · GetNodeProtocolInfo (0x41)
            · HardReset (0x42)
            · FUNC_ID_ZW_REPLICATION_COMMAND_COMPLETE (0x44)
            · FUNC_ID_ZW_REPLICATION_SEND_DATA (0x45)
            · AssignReturnRoute (0x46)
            · DeleteReturnRoute (0x47)
            · RequestNodeNeighborUpdate (0x48)
            · ApplicationUpdateRequest (0x49)
            · AddNodeToNetwork (0x4a)
            · RemoveNodeFromNetwork (0x4b)
            · FUNC_ID_ZW_CREATE_NEW_PRIMARY (0x4c)
            · FUNC_ID_ZW_CONTROLLER_CHANGE (0x4d)
            · FUNC_ID_ZW_SET_LEARN_MODE (0x50)
            · AssignSUCReturnRoute (0x51)
            · FUNC_ID_ZW_REQUEST_NETWORK_UPDATE (0x53)
            · SetSUCNodeId (0x54)
            · DeleteSUCReturnRoute (0x55)
            · GetSUCNodeId (0x56)
            · UNKNOWN_FUNC_SEND_SUC_ID (0x57)
            · FUNC_ID_ZW_EXPLORE_REQUEST_INCLUSION (0x5e)
            · RequestNodeInfo (0x60)
            · RemoveFailedNode (0x61)
            · IsFailedNode (0x62)
            · ReplaceFailedNode (0x63)
            · UNKNOWN_FUNC_UNKNOWN_0x66 (0x66)
            · UNKNOWN_FUNC_UNKNOWN_0x67 (0x67)
            · UNKNOWN_FUNC_UNKNOWN_0x78 (0x78)
            · GetRoutingInfo (0x80)
            · UNKNOWN_FUNC_LOCK_ROUTE_RESPONSE (0x90)
            · UNKNOWN_FUNC_GET_PRIORITY_ROUTE (0x92)
            · UNKNOWN_FUNC_SET_PRIORITY_ROUTE (0x93)
            · UNKNOWN_FUNC_UNKNOWN_0x98 (0x98)
            · UNKNOWN_FUNC_UNKNOWN_0xB4 (0xb4)
            · UNKNOWN_FUNC_WATCH_DOG_ENABLE (0xb6)
            · UNKNOWN_FUNC_WATCH_DOG_DISABLE (0xb7)
            · UNKNOWN_FUNC_WATCH_DOG_KICK (0xb8)
            · UNKNOWN_FUNC_UNKNOWN_0xB9 (0xb9)
            · UNKNOWN_FUNC_RF_POWERLEVEL_GET (0xba)
            · UNKNOWN_FUNC_GET_LIBRARY_TYPE (0xbd)
            · UNKNOWN_FUNC_SEND_TEST_FRAME (0xbe)
            · UNKNOWN_FUNC_GET_PROTOCOL_STATUS (0xbf)
            · UNKNOWN_FUNC_UNKNOWN_0xD2 (0xd2)
            · UNKNOWN_FUNC_UNKNOWN_0xD3 (0xd3)
            · UNKNOWN_FUNC_UNKNOWN_0xD4 (0xd4)
            · UNKNOWN_FUNC_UNKNOWN_0xEF (0xef)
            · UNKNOWN_FUNC_ZMEFreqChange (0xf2)
            · UNKNOWN_FUNC_ZMEBootloaderFlash (0xf4)
            · UNKNOWN_FUNC_ZMECapabilities (0xf5)
            2021-08-02T14:33:40.391Z CNTRLR finding SUC...
            2021-08-02T14:33:40.408Z SERIAL » 0x01030056aa (5 bytes)
            2021-08-02T14:33:40.409Z DRIVER » [REQ] [GetSUCNodeId]
            2021-08-02T14:33:40.413Z SERIAL « [ACK] (0x06)
            2021-08-02T14:33:40.417Z SERIAL « 0x0104015601ad (6 bytes)
            2021-08-02T14:33:40.419Z SERIAL » [ACK] (0x06)
            2021-08-02T14:33:40.421Z DRIVER « [RES] [GetSUCNodeId]
            payload: 0x01
            2021-08-02T14:33:40.431Z CNTRLR This is the SUC
            2021-08-02T14:33:40.492Z CNTRLR querying node information...
            2021-08-02T14:33:40.505Z SERIAL » 0x01030002fe (5 bytes)
            2021-08-02T14:33:40.506Z DRIVER » [REQ] [GetSerialApiInitData]
            2021-08-02T14:33:40.509Z SERIAL « [ACK] (0x06)
            2021-08-02T14:33:40.567Z SERIAL « 0x0125010205081dbfea19000000000000000000000000000000000000000000000 (39 bytes)
            0000000050080
            2021-08-02T14:33:40.569Z SERIAL » [ACK] (0x06)
            2021-08-02T14:33:40.571Z DRIVER « [RES] [GetSerialApiInitData]
            payload: 0x05081dbfea1900000000000000000000000000000000000000000000000000000
            500
            2021-08-02T14:33:40.582Z CNTRLR received node information:
            controller is a SUC: true
            controller is a slave: false
            controller supports timers: false
            nodes in the network: 1, 2, 3, 4, 5, 6, 8, 10, 12, 14, 15, 16, 17, 20,
            21
            2021-08-02T14:33:40.701Z CNTRLR [Node 001] [Manufacturer Specific] manufacturerId: metadata updated
            2021-08-02T14:33:40.703Z CNTRLR [Node 001] [Manufacturer Specific] productType: metadata updated
            2021-08-02T14:33:40.705Z CNTRLR [Node 001] [Manufacturer Specific] productId: metadata updated
            2021-08-02T14:33:40.710Z CNTRLR [Node 001] [+] [Manufacturer Specific] manufacturerId: 327
            2021-08-02T14:33:40.711Z CNTRLR [Node 001] [+] [Manufacturer Specific] productType: 1024
            2021-08-02T14:33:40.713Z CNTRLR [Node 001] [+] [Manufacturer Specific] productId: 2
            2021-08-02T14:33:40.716Z CNTRLR [Node 001] [Version] firmwareVersions: metadata updated
            2021-08-02T14:33:40.718Z CNTRLR [Node 001] [+] [Version] firmwareVersions: 5.4
            2021-08-02T14:33:40.719Z CNTRLR setting serial API timeouts: ack = 1000 ms, byte = 150 ms
            2021-08-02T14:33:40.732Z SERIAL » 0x01050006640f97 (7 bytes)
            2021-08-02T14:33:40.734Z DRIVER » [REQ] [SetSerialApiTimeouts]
            payload: 0x640f
            2021-08-02T14:33:40.739Z SERIAL « [ACK] (0x06)
            2021-08-02T14:33:40.743Z SERIAL « 0x01050106960f64 (7 bytes)
            2021-08-02T14:33:40.745Z SERIAL » [ACK] (0x06)
            2021-08-02T14:33:40.747Z DRIVER « [RES] [SetSerialApiTimeouts]
            payload: 0x960f
            2021-08-02T14:33:40.755Z CNTRLR serial API timeouts overwritten. The old values were: ack = 1500 ms, byte = 15
            0 ms
            2021-08-02T14:33:40.756Z CNTRLR Interview completed
            2021-08-02T14:33:40.756Z DRIVER driver ready
            2021-08-02T14:33:40.767Z CNTRLR [Node 001] Beginning interview - last completed stage: None
            2021-08-02T14:33:40.768Z CNTRLR [Node 001] new node, doing a full interview...
            2021-08-02T14:33:40.770Z CNTRLR » [Node 001] querying protocol info...
            2021-08-02T14:33:40.993Z SERIAL » 0x0104004101bb (6 bytes)
            2021-08-02T14:33:40.994Z DRIVER » [REQ] [GetNodeProtocolInfo]
            payload: 0x01
            2021-08-02T14:33:41.001Z SERIAL « [ACK] (0x06)
            2021-08-02T14:33:41.005Z SERIAL « 0x0109014193160102020133 (11 bytes)
            2021-08-02T14:33:41.008Z SERIAL » [ACK] (0x06)
            2021-08-02T14:33:41.010Z DRIVER « [RES] [GetNodeProtocolInfo]
            payload: 0x931601020201
            2021-08-02T14:33:41.019Z CNTRLR « [Node 001] received response for protocol info:
            basic device class: Static Controller
            generic device class: Static Controller
            specific device class: PC Controller
            node type: Controller
            is always listening: true
            is frequent listening: false
            can route messages: false
            supports security: false
            supports beaming: true
            maximum data rate: 100000 kbps
            protocol version: 3
            2021-08-02T14:33:41.035Z CNTRLR [Node 001] Interview stage completed: ProtocolInfo
            2021-08-02T14:33:41.037Z CNTRLR [Node 001] not pinging the controller
            2021-08-02T14:33:41.038Z CNTRLR [Node 001] not querying node info from the controller
            2021-08-02T14:33:41.039Z CNTRLR [Node 001] Interview stage completed: NodeInfo
            2021-08-02T14:33:41.044Z CNTRLR [Node 001] Interview stage completed: CommandClasses
            2021-08-02T14:33:41.064Z CNTRLR [Node 001] Embedded device config loaded
            2021-08-02T14:33:41.065Z CNTRLR [Node 001] Interview stage completed: OverwriteConfig
            2021-08-02T14:33:41.066Z CNTRLR » [Node 001] requesting node neighbors...
            2021-08-02T14:33:41.080Z SERIAL » 0x010700800100000079 (9 bytes)
            2021-08-02T14:33:41.081Z DRIVER » [REQ] [GetRoutingInfo]
            remove non-repeaters: false
            remove bad links: false
            2021-08-02T14:33:41.095Z SERIAL « [ACK] (0x06)
            2021-08-02T14:33:41.101Z SERIAL « 0x01200180a00a01000000000000000000000000000000000000000000000000000 (34 bytes)
            0f5
            2021-08-02T14:33:41.104Z SERIAL » [ACK] (0x06)
            2021-08-02T14:33:41.111Z DRIVER « [RES] [GetRoutingInfo]
            node ids: 6, 8, 10, 12, 17
            2021-08-02T14:33:41.123Z CNTRLR « [Node 001] node neighbors received: 6, 8, 10, 12, 17
            2021-08-02T14:33:41.124Z CNTRLR [Node 001] Interview stage completed: Neighbors
            2021-08-02T14:33:41.125Z CNTRLR [Node 001] Interview completed
            2021-08-02T14:33:41.126Z CNTRLR [Node 001] The node is ready to be used
            2021-08-02T14:33:41.131Z CNTRLR [Node 001] The node is alive.
            2021-08-02T14:33:41.134Z CNTRLR [Node 002] Beginning interview - last completed stage: None
            2021-08-02T14:33:41.135Z CNTRLR [Node 002] new node, doing a full interview...
            2021-08-02T14:33:41.135Z CNTRLR » [Node 002] querying protocol info...
            2021-08-02T14:33:41.148Z SERIAL » 0x0104004102b8 (6 bytes)
            2021-08-02T14:33:41.149Z DRIVER » [REQ] [GetNodeProtocolInfo]
            payload: 0x02
            2021-08-02T14:33:41.152Z CNTRLR [Node 003] Beginning interview - last completed stage: None
            2021-08-02T14:33:41.153Z CNTRLR [Node 003] new node, doing a full interview...
            2021-08-02T14:33:41.153Z CNTRLR » [Node 003] querying protocol info...
            2021-08-02T14:33:41.158Z CNTRLR [Node 004] Beginning interview - last completed stage: None
            2021-08-02T14:33:41.159Z CNTRLR [Node 004] new node, doing a full interview...
            2021-08-02T14:33:41.160Z CNTRLR » [Node 004] querying protocol info...
            2021-08-02T14:33:41.166Z CNTRLR [Node 005] Beginning interview - last completed stage: None
            2021-08-02T14:33:41.167Z CNTRLR [Node 005] new node, doing a full interview...
            2021-08-02T14:33:41.167Z CNTRLR » [Node 005] querying protocol info...
            2021-08-02T14:33:41.172Z CNTRLR [Node 006] Beginning interview - last completed stage: None
            2021-08-02T14:33:41.173Z CNTRLR [Node 006] new node, doing a full interview...
            2021-08-02T14:33:41.174Z CNTRLR » [Node 006] querying protocol info...
            2021-08-02T14:33:41.179Z CNTRLR [Node 008] Beginning interview - last completed stage: None
            2021-08-02T14:33:41.179Z CNTRLR [Node 008] new node, doing a full interview...
            2021-08-02T14:33:41.180Z CNTRLR » [Node 008] querying protocol info...
            2021-08-02T14:33:41.185Z CNTRLR [Node 010] Beginning interview - last completed stage: None
            2021-08-02T14:33:41.186Z CNTRLR [Node 010] new node, doing a full interview...
            2021-08-02T14:33:41.186Z CNTRLR » [Node 010] querying protocol info...
            2021-08-02T14:33:41.191Z CNTRLR [Node 012] Beginning interview - last completed stage: None
            2021-08-02T14:33:41.192Z CNTRLR [Node 012] new node, doing a full interview...
            2021-08-02T14:33:41.192Z CNTRLR » [Node 012] querying protocol info...
            2021-08-02T14:33:41.197Z CNTRLR [Node 014] Beginning interview - last completed stage: None
            2021-08-02T14:33:41.198Z CNTRLR [Node 014] new node, doing a full interview...
            2021-08-02T14:33:41.199Z CNTRLR » [Node 014] querying protocol info...
            2021-08-02T14:33:41.204Z CNTRLR [Node 015] Beginning interview - last completed stage: None
            2021-08-02T14:33:41.204Z CNTRLR [Node 015] new node, doing a full interview...
            2021-08-02T14:33:41.205Z CNTRLR » [Node 015] querying protocol info...
            2021-08-02T14:33:41.210Z CNTRLR [Node 016] Beginning interview - last completed stage: None
            2021-08-02T14:33:41.211Z CNTRLR [Node 016] new node, doing a full interview...
            2021-08-02T14:33:41.211Z CNTRLR » [Node 016] querying protocol info...
            2021-08-02T14:33:41.216Z CNTRLR [Node 017] Beginning interview - last completed stage: None
            2021-08-02T14:33:41.217Z CNTRLR [Node 017] new node, doing a full interview...
            2021-08-02T14:33:41.217Z CNTRLR » [Node 017] querying protocol info...
            2021-08-02T14:33:41.222Z CNTRLR [Node 020] Beginning interview - last completed stage: None
            2021-08-02T14:33:41.223Z CNTRLR [Node 020] new node, doing a full interview...
            2021-08-02T14:33:41.223Z CNTRLR » [Node 020] querying protocol info...
            2021-08-02T14:33:41.228Z CNTRLR [Node 021] Beginning interview - last completed stage: None
            2021-08-02T14:33:41.229Z CNTRLR [Node 021] new node, doing a full interview...
            2021-08-02T14:33:41.230Z CNTRLR » [Node 021] querying protocol info...
            2021-08-02T14:33:41.243Z DRIVER Checking for configuration updates...
            2021-08-02T14:33:41.357Z SERIAL « [ACK] (0x06)
            2021-08-02T14:33:41.361Z SERIAL « 0x01090141d39c01041001ed (11 bytes)
            2021-08-02T14:33:41.362Z SERIAL » [ACK] (0x06)
            2021-08-02T14:33:41.364Z DRIVER « [RES] [GetNodeProtocolInfo]
            payload: 0xd39c01041001
            2021-08-02T14:33:41.378Z SERIAL » 0x0104004103b9 (6 bytes)
            2021-08-02T14:33:41.379Z DRIVER » [REQ] [GetNodeProtocolInfo]
            payload: 0x03
            2021-08-02T14:33:41.381Z CNTRLR « [Node 002] received response for protocol info:
            basic device class: Routing Slave
            generic device class: Binary Switch
            specific device class: Binary Power Switch
            node type: Routing End Node
            can route messages: true
            protocol version: 3
            2021-08-02T14:33:41.382Z CNTRLR [Node 002] Interview stage completed: ProtocolInfo
            2021-08-02T14:33:41.383Z CNTRLR » [Node 002] pinging the node...
            2021-08-02T14:33:41.404Z SERIAL « [ACK] (0x06)
            2021-08-02T14:33:41.407Z SERIAL « 0x01090141539c010407017a (11 bytes)
            2021-08-02T14:33:41.408Z SERIAL » [ACK] (0x06)
            2021-08-02T14:33:41.412Z DRIVER « [RES] [GetNodeProtocolInfo]
            payload: 0x539c01040701
            2021-08-02T14:33:41.426Z SERIAL » 0x0104004104be (6 bytes)
            2021-08-02T14:33:41.427Z DRIVER » [REQ] [GetNodeProtocolInfo]
            payload: 0x04
            2021-08-02T14:33:41.429Z CNTRLR « [Node 003] received response for protocol info:
            generic device class: Notification Sensor
            specific device class: Notification Sensor
            is always listening: false
            protocol version: 3
            2021-08-02T14:33:41.431Z CNTRLR [Node 003] The node is asleep.
            2021-08-02T14:33:41.434Z CNTRLR [Node 003] Interview stage completed: ProtocolInfo
            2021-08-02T14:33:41.435Z CNTRLR » [Node 003] querying node info...
            2021-08-02T14:33:41.468Z SERIAL « [ACK] (0x06)
            2021-08-02T14:33:41.471Z SERIAL « 0x01090141d39c00041000ed (11 bytes)
            2021-08-02T14:33:41.473Z SERIAL » [ACK] (0x06)
            2021-08-02T14:33:41.477Z DRIVER « [RES] [GetNodeProtocolInfo]
            payload: 0xd39c00041000
            2021-08-02T14:33:41.511Z SERIAL » 0x0104004105bf (6 bytes)
            2021-08-02T14:33:41.512Z DRIVER » [REQ] [GetNodeProtocolInfo]
            payload: 0x05
            2021-08-02T14:33:41.513Z CNTRLR « [Node 004] received response for protocol info:
            specific device class: Unused
            maximum data rate: 40000 kbps
            protocol version: 3
            2021-08-02T14:33:41.514Z CNTRLR [Node 004] Interview stage completed: ProtocolInfo
            2021-08-02T14:33:41.515Z CNTRLR » [Node 004] pinging the node...
            2021-08-02T14:33:41.557Z SERIAL « [ACK] (0x06)
            2021-08-02T14:33:41.560Z SERIAL « 0x01090141539c010407017a (11 bytes)
            2021-08-02T14:33:41.562Z SERIAL » [ACK] (0x06)
            2021-08-02T14:33:41.566Z DRIVER « [RES] [GetNodeProtocolInfo]
            2021-08-02T14:33:41.579Z SERIAL » 0x0104004106bc (6 bytes)
            2021-08-02T14:33:41.581Z DRIVER » [REQ] [GetNodeProtocolInfo]
            payload: 0x06
            2021-08-02T14:33:41.582Z CNTRLR « [Node 005] received response for protocol info:
            protocol version: 3
            2021-08-02T14:33:41.584Z CNTRLR [Node 005] The node is asleep.
            2021-08-02T14:33:41.595Z SERIAL « [ACK] (0x06)
            2021-08-02T14:33:41.598Z SERIAL « 0x01090141539c010407017a (11 bytes)
            2021-08-02T14:33:41.600Z SERIAL » [ACK] (0x06)
            2021-08-02T14:33:41.604Z DRIVER « [RES] [GetNodeProtocolInfo]
            2021-08-02T14:33:41.619Z SERIAL » 0x0104004108b2 (6 bytes)
            2021-08-02T14:33:41.620Z DRIVER » [REQ] [GetNodeProtocolInfo]
            payload: 0x08
            2021-08-02T14:33:41.622Z CNTRLR « [Node 006] received response for protocol info:
            protocol version: 3
            2021-08-02T14:33:41.624Z CNTRLR [Node 006] The node is asleep.
            2021-08-02T14:33:41.626Z CNTRLR [Node 006] Interview stage completed: ProtocolInfo
            2021-08-02T14:33:41.627Z CNTRLR » [Node 006] querying node info...
            2021-08-02T14:33:41.636Z CNTRLR [Node 005] Interview stage completed: ProtocolInfo
            2021-08-02T14:33:41.637Z CNTRLR » [Node 005] querying node info...
            2021-08-02T14:33:41.643Z SERIAL « [ACK] (0x06)
            2021-08-02T14:33:41.646Z SERIAL « 0x01090141539c010407017a (11 bytes)
            2021-08-02T14:33:41.647Z SERIAL » [ACK] (0x06)
            2021-08-02T14:33:41.651Z DRIVER « [RES] [GetNodeProtocolInfo]
            2021-08-02T14:33:41.667Z SERIAL » 0x010400410ab0 (6 bytes)
            2021-08-02T14:33:41.673Z DRIVER » [REQ] [GetNodeProtocolInfo]
            payload: 0x0a
            2021-08-02T14:33:41.675Z CNTRLR « [Node 008] received response for protocol info:
            protocol version: 3
            2021-08-02T14:33:41.677Z CNTRLR [Node 008] The node is asleep.
            2021-08-02T14:33:41.680Z CNTRLR [Node 008] Interview stage completed: ProtocolInfo
            2021-08-02T14:33:41.680Z CNTRLR » [Node 008] querying node info...
            2021-08-02T14:33:41.689Z SERIAL « [ACK] (0x06)
            2021-08-02T14:33:41.693Z SERIAL « 0x01090141539c010407017a (11 bytes)
            2021-08-02T14:33:41.695Z SERIAL » [ACK] (0x06)
            2021-08-02T14:33:41.697Z DRIVER « [RES] [GetNodeProtocolInfo]
            2021-08-02T14:33:41.712Z SERIAL » 0x010400410cb6 (6 bytes)
            2021-08-02T14:33:41.713Z DRIVER » [REQ] [GetNodeProtocolInfo]
            payload: 0x0c
            2021-08-02T14:33:41.715Z CNTRLR « [Node 010] received response for protocol info:
            protocol version: 3
            2021-08-02T14:33:41.717Z CNTRLR [Node 010] The node is asleep.
            2021-08-02T14:33:41.719Z CNTRLR [Node 010] Interview stage completed: ProtocolInfo
            2021-08-02T14:33:41.720Z CNTRLR » [Node 010] querying node info...
            2021-08-02T14:33:41.733Z SERIAL « [ACK] (0x06)
            2021-08-02T14:33:41.737Z SERIAL « 0x01090141539c010407017a (11 bytes)
            2021-08-02T14:33:41.738Z SERIAL » [ACK] (0x06)
            2021-08-02T14:33:41.740Z DRIVER « [RES] [GetNodeProtocolInfo]
            2021-08-02T14:33:41.755Z SERIAL » 0x010400410eb4 (6 bytes)
            2021-08-02T14:33:41.756Z DRIVER » [REQ] [GetNodeProtocolInfo]
            payload: 0x0e
            2021-08-02T14:33:41.757Z CNTRLR « [Node 012] received response for protocol info:
            protocol version: 3
            2021-08-02T14:33:41.759Z CNTRLR [Node 012] The node is asleep.
            2021-08-02T14:33:41.761Z CNTRLR [Node 012] Interview stage completed: ProtocolInfo
            2021-08-02T14:33:41.762Z CNTRLR » [Node 012] querying node info...
            2021-08-02T14:33:41.773Z SERIAL « [ACK] (0x06)
            2021-08-02T14:33:41.776Z SERIAL « 0x01090141539c010407017a (11 bytes)
            2021-08-02T14:33:41.777Z SERIAL » [ACK] (0x06)
            2021-08-02T14:33:41.779Z DRIVER « [RES] [GetNodeProtocolInfo]
            2021-08-02T14:33:41.794Z SERIAL » 0x010400410fb5 (6 bytes)
            2021-08-02T14:33:41.795Z DRIVER » [REQ] [GetNodeProtocolInfo]
            payload: 0x0f
            2021-08-02T14:33:41.796Z CNTRLR « [Node 014] received response for protocol info:
            protocol version: 3
            2021-08-02T14:33:41.798Z CNTRLR [Node 014] The node is asleep.
            2021-08-02T14:33:41.811Z SERIAL « [ACK] (0x06)
            2021-08-02T14:33:41.814Z SERIAL « 0x01090141539c010407017a (11 bytes)
            2021-08-02T14:33:41.816Z SERIAL » [ACK] (0x06)
            2021-08-02T14:33:41.818Z DRIVER « [RES] [GetNodeProtocolInfo]
            2021-08-02T14:33:41.834Z SERIAL » 0x0104004110aa (6 bytes)
            2021-08-02T14:33:41.835Z DRIVER » [REQ] [GetNodeProtocolInfo]
            payload: 0x10
            2021-08-02T14:33:41.836Z CNTRLR « [Node 015] received response for protocol info:
            protocol version: 3
            2021-08-02T14:33:41.838Z CNTRLR [Node 015] The node is asleep.
            2021-08-02T14:33:41.840Z CNTRLR [Node 015] Interview stage completed: ProtocolInfo
            2021-08-02T14:33:41.841Z CNTRLR » [Node 015] querying node info...
            2021-08-02T14:33:41.869Z CNTRLR [Node 014] Interview stage completed: ProtocolInfo
            2021-08-02T14:33:41.870Z CNTRLR » [Node 014] querying node info...
            2021-08-02T14:33:41.875Z SERIAL « [ACK] (0x06)
            2021-08-02T14:33:41.878Z SERIAL « 0x01090141539c010407017a (11 bytes)
            2021-08-02T14:33:41.880Z SERIAL » [ACK] (0x06)
            2021-08-02T14:33:41.890Z DRIVER « [RES] [GetNodeProtocolInfo]
            2021-08-02T14:33:41.905Z SERIAL » 0x0104004111ab (6 bytes)
            2021-08-02T14:33:41.907Z DRIVER » [REQ] [GetNodeProtocolInfo]
            payload: 0x11
            2021-08-02T14:33:41.908Z CNTRLR « [Node 016] received response for protocol info:
            protocol version: 3
            2021-08-02T14:33:41.910Z CNTRLR [Node 016] The node is asleep.
            2021-08-02T14:33:41.912Z CNTRLR [Node 016] Interview stage completed: ProtocolInfo
            2021-08-02T14:33:41.913Z CNTRLR » [Node 016] querying node info...
            2021-08-02T14:33:41.942Z SERIAL « [ACK] (0x06)
            2021-08-02T14:33:41.949Z SERIAL « 0x01090141539c010407017a (11 bytes)
            2021-08-02T14:33:41.950Z SERIAL » [ACK] (0x06)
            2021-08-02T14:33:42.010Z DRIVER No configuration update available...
            2021-08-02T14:33:42.015Z DRIVER « [RES] [GetNodeProtocolInfo]
            2021-08-02T14:33:42.029Z SERIAL » 0x0104004114ae (6 bytes)
            2021-08-02T14:33:42.030Z DRIVER » [REQ] [GetNodeProtocolInfo]
            payload: 0x14
            2021-08-02T14:33:42.031Z CNTRLR « [Node 017] received response for protocol info:
            protocol version: 3
            2021-08-02T14:33:42.032Z CNTRLR [Node 017] The node is asleep.
            2021-08-02T14:33:42.045Z SERIAL « [ACK] (0x06)
            2021-08-02T14:33:42.048Z SERIAL « 0x01090141539c010407017a (11 bytes)
            2021-08-02T14:33:42.050Z SERIAL » [ACK] (0x06)
            2021-08-02T14:33:42.052Z DRIVER « [RES] [GetNodeProtocolInfo]
            2021-08-02T14:33:42.065Z SERIAL » 0x0104004115af (6 bytes)
            2021-08-02T14:33:42.066Z DRIVER » [REQ] [GetNodeProtocolInfo]
            payload: 0x15
            2021-08-02T14:33:42.067Z CNTRLR « [Node 020] received response for protocol info:
            protocol version: 3
            2021-08-02T14:33:42.069Z CNTRLR [Node 020] The node is asleep.
            2021-08-02T14:33:42.085Z CNTRLR [Node 020] Interview stage completed: ProtocolInfo
            2021-08-02T14:33:42.086Z CNTRLR » [Node 020] querying node info...
            2021-08-02T14:33:42.101Z CNTRLR [Node 017] Interview stage completed: ProtocolInfo
            2021-08-02T14:33:42.101Z CNTRLR » [Node 017] querying node info...
            2021-08-02T14:33:42.107Z SERIAL « [ACK] (0x06)
            2021-08-02T14:33:42.110Z SERIAL « 0x01090141539c010407017a (11 bytes)
            2021-08-02T14:33:42.111Z SERIAL » [ACK] (0x06)
            2021-08-02T14:33:42.114Z DRIVER « [RES] [GetNodeProtocolInfo]
            2021-08-02T14:33:42.141Z SERIAL » 0x010800130201002501c3 (10 bytes)
            2021-08-02T14:33:42.143Z DRIVER » [Node 002] [REQ] [SendData]
            │ transmit options: 0x25
            │ callback id: 1
            └─[NoOperationCC]
            2021-08-02T14:33:42.145Z CNTRLR « [Node 021] received response for protocol info:
            protocol version: 3
            2021-08-02T14:33:42.147Z CNTRLR [Node 021] The node is asleep.
            2021-08-02T14:33:42.149Z CNTRLR [Node 021] Interview stage completed: ProtocolInfo
            2021-08-02T14:33:42.150Z CNTRLR » [Node 021] querying node info...
            2021-08-02T14:33:42.160Z SERIAL « [ACK] (0x06)
            2021-08-02T14:33:42.166Z SERIAL « 0x0104011301e8 (6 bytes)
            2021-08-02T14:33:42.168Z SERIAL » [ACK] (0x06)
            2021-08-02T14:33:42.171Z DRIVER « [RES] [SendData]
            was sent: true
            2021-08-02T14:33:46.287Z SERIAL « 0x010700130101019d77 (9 bytes)
            2021-08-02T14:33:46.290Z SERIAL » [ACK] (0x06)
            2021-08-02T14:33:46.293Z DRIVER « [REQ] [SendData]
            callback id: 1
            transmit status: NoAck
            2021-08-02T14:33:46.347Z CNTRLR [Node 002] Node 2 did not respond after 1 attempts, it is presumed dead
            2021-08-02T14:33:46.351Z CNTRLR [Node 002] The node is dead.
            2021-08-02T14:33:46.369Z SERIAL » 0x010800130401002502c6 (10 bytes)
            2021-08-02T14:33:46.371Z DRIVER » [Node 004] [REQ] [SendData]
            │ callback id: 2
            └─[NoOperationCC]
            2021-08-02T14:33:46.374Z CNTRLR [Node 002] ping failed: Failed to send the command after 1 attempts (Status No
            Ack)
            2021-08-02T14:33:46.375Z CNTRLR » [Node 002] querying node info...
            2021-08-02T14:33:46.375Z CNTRLR » [Node 002] pinging the node...
            2021-08-02T14:33:46.384Z SERIAL « [ACK] (0x06)
            2021-08-02T14:33:46.388Z SERIAL « 0x0104011301e8 (6 bytes)
            2021-08-02T14:33:46.390Z SERIAL » [ACK] (0x06)
            2021-08-02T14:33:46.391Z DRIVER « [RES] [SendData]
            was sent: true
            2021-08-02T14:33:50.488Z SERIAL « 0x010700130201019b72 (9 bytes)
            2021-08-02T14:33:50.490Z SERIAL » [ACK] (0x06)
            2021-08-02T14:33:50.492Z DRIVER « [REQ] [SendData]
            callback id: 2
            2021-08-02T14:33:50.504Z CNTRLR [Node 004] Node 4 did not respond after 1 attempts, it is presumed dead
            2021-08-02T14:33:50.506Z CNTRLR [Node 004] The node is dead.
            2021-08-02T14:33:50.521Z SERIAL » 0x010800130201002503c1 (10 bytes)
            2021-08-02T14:33:50.523Z DRIVER » [Node 002] [REQ] [SendData]
            │ callback id: 3
            └─[NoOperationCC]
            2021-08-02T14:33:50.526Z CNTRLR [Node 004] ping failed: Failed to send the command after 1 attempts (Status No
            Ack)
            2021-08-02T14:33:50.527Z CNTRLR » [Node 004] querying node info...
            2021-08-02T14:33:50.528Z CNTRLR » [Node 004] pinging the node...
            2021-08-02T14:33:50.541Z SERIAL « [ACK] (0x06)
            2021-08-02T14:33:50.547Z SERIAL « 0x0104011301e8 (6 bytes)
            2021-08-02T14:33:50.549Z SERIAL » [ACK] (0x06)
            2021-08-02T14:33:50.552Z DRIVER « [RES] [SendData]
            was sent: true
            2021-08-02T14:33:54.668Z SERIAL « 0x010700130301019d75 (9 bytes)
            2021-08-02T14:33:54.670Z SERIAL » [ACK] (0x06)
            2021-08-02T14:33:54.672Z DRIVER « [REQ] [SendData]
            callback id: 3
            2021-08-02T14:33:54.684Z CNTRLR [Node 002] Node 2 did not respond after 1 attempts, it is presumed dead
            2021-08-02T14:33:54.698Z SERIAL » 0x010800130401002504c0 (10 bytes)
            2021-08-02T14:33:54.700Z DRIVER » [Node 004] [REQ] [SendData]
            │ callback id: 4
            └─[NoOperationCC]
            2021-08-02T14:33:54.703Z CNTRLR [Node 002] ping failed: Failed to send the command after 1 attempts (Status No
            Ack)
            2021-08-02T14:33:54.705Z CNTRLR [Node 002] Interview attempt (1/5) failed, node is dead.
            2021-08-02T14:33:54.712Z SERIAL « [ACK] (0x06)
            2021-08-02T14:33:54.717Z SERIAL « 0x0104011301e8 (6 bytes)
            2021-08-02T14:33:54.719Z SERIAL » [ACK] (0x06)
            2021-08-02T14:33:54.721Z DRIVER « [RES] [SendData]
            was sent: true
            2021-08-02T14:33:58.848Z SERIAL « 0x010700130401019e71 (9 bytes)
            2021-08-02T14:33:58.850Z SERIAL » [ACK] (0x06)
            2021-08-02T14:33:58.852Z DRIVER « [REQ] [SendData]
            callback id: 4
            2021-08-02T14:33:58.864Z CNTRLR [Node 004] Node 4 did not respond after 1 attempts, it is presumed dead
            2021-08-02T14:33:58.871Z CNTRLR [Node 004] ping failed: Failed to send the command after 1 attempts (Status No
            Ack)
            2021-08-02T14:33:58.872Z CNTRLR [Node 004] Interview attempt (1/5) failed, node is dead.
              rhartmann76 @rhartmann76 last edited by
              nun läuft es. Post nochmal aktiviert. Nun mal schauen, wie ich die Geräte anlerne.
              Danke Euch
              • AlCalzone
                AlCalzone Developer @rhartmann76 last edited by AlCalzone
                Da sind schon Geräte angelernt. In Z-Wave werden die in Hardware gespeichert. Dauert nur ein bisschen bis alle Infos da sind - Batteriebetriebene Geräte kannst du manuell aufwecken, um das zu beschleunigen.
                  @AlCalzone Danke. Die Rauchmelder von Abus werden erkannt.
                  Gibt es eine Iobroker Anleitung, wie man Rauchmelder richtig einbindet? Bisher war meine Suche erfolglos.
                  Außerdem die Frage, wie erkenne ich, welche Node zu welchen Gerät gehört?
                  Danke!
                  • AlCalzone
                    @rhartmann76 Die sind alle noch nicht fertig interviewt (ready: false), daher ist noch gar keine Info da.
                    Ohne Log kann ich nicht sagen warum genau - hast du die Melder mal aufgeweckt? Aktuell schlafen alle (status: asleep).
                      @alcalzone Danke. Ich dachte, sleep ist bei Feuermelder normal - nur wenn er auslöst.....
                      Wie kann ich die aktivieren?
                      Hier ein Auszug aus dem log. Wenn Du mehr sehen willst, fange ich weiter oben an
                      2021-08-03T08:50:17.862Z DRIVER   destroying driver instance...
                      2021-08-03T08:50:33.883Z DRIVER   ███████╗ ██╗    ██╗  █████╗  ██╗   ██╗ ███████╗             ██╗ ███████╗
                      2021-08-03T08:50:33.886Z DRIVER   version 7.12.1
                      2021-08-03T08:50:33.887Z DRIVER
                      2021-08-03T08:50:33.888Z DRIVER   starting driver...
                      2021-08-03T08:50:33.934Z DRIVER   opening serial port /dev/ttyAMA0
                      2021-08-03T08:50:33.980Z DRIVER   serial port opened
                      2021-08-03T08:50:33.982Z SERIAL » [NAK]        (0x15)
                      2021-08-03T08:50:35.494Z DRIVER   loading configuration...
                      2021-08-03T08:50:35.502Z CONFIG   version 7.12.1
                      2021-08-03T08:50:37.836Z DRIVER   beginning interview...
                      2021-08-03T08:50:37.840Z DRIVER   added request handler for AddNodeToNetwork (0x4a)...
                                                        1 registered
                      2021-08-03T08:50:37.841Z DRIVER   added request handler for RemoveNodeFromNetwork (0x4b)...
                                                        1 registered
                      2021-08-03T08:50:37.841Z DRIVER   added request handler for ReplaceFailedNode (0x63)...
                                                        1 registered
                      2021-08-03T08:50:37.845Z CNTRLR   beginning interview...
                      2021-08-03T08:50:37.846Z CNTRLR   querying version info...
                      2021-08-03T08:50:38.289Z SERIAL » 0x01030015e9                                                         (5 bytes)
                      2021-08-03T08:50:38.294Z DRIVER » [REQ] [GetControllerVersion]
                      2021-08-03T08:50:38.303Z SERIAL « [ACK]        (0x06)
                      2021-08-03T08:50:38.311Z SERIAL « 0x011001155a2d5761766520342e3035000197                              (18 bytes)
                      2021-08-03T08:50:38.315Z SERIAL » [ACK]        (0x06)
                      2021-08-03T08:50:38.319Z DRIVER « [RES] [GetControllerVersion]
                      2021-08-03T08:50:38.340Z CNTRLR   received version info:
                      2021-08-03T08:50:38.341Z CNTRLR   querying controller IDs...
                      2021-08-03T08:50:38.363Z SERIAL » 0x01030020dc                                                         (5 bytes)
                      2021-08-03T08:50:38.364Z DRIVER » [REQ] [GetControllerId]
                      2021-08-03T08:50:38.369Z SERIAL « [ACK]        (0x06)
                      2021-08-03T08:50:38.373Z SERIAL « 0x01080120cb35fd6b01bf                                              (10 bytes)
                      2021-08-03T08:50:38.376Z SERIAL » [ACK]        (0x06)
                      2021-08-03T08:50:38.379Z DRIVER « [RES] [GetControllerId]
                      2021-08-03T08:50:38.391Z CNTRLR   received controller IDs:
                                                          home ID:     0xcb35fd6b
                                                          own node ID: 1
                      2021-08-03T08:50:38.392Z CNTRLR   querying controller capabilities...
                      2021-08-03T08:50:38.405Z SERIAL » 0x01030005f9                                                         (5 bytes)
                      2021-08-03T08:50:38.407Z DRIVER » [REQ] [GetControllerCapabilities]
                      2021-08-03T08:50:38.411Z SERIAL « [ACK]        (0x06)
                      2021-08-03T08:50:38.415Z SERIAL « 0x010401051ce3                                                       (6 bytes)
                      2021-08-03T08:50:38.417Z SERIAL » [ACK]        (0x06)
                      2021-08-03T08:50:38.420Z DRIVER « [RES] [GetControllerCapabilities]
                                                          payload: 0x1c
                      2021-08-03T08:50:38.432Z CNTRLR   received controller capabilities:
                                                          is a SUC:            true
                      2021-08-03T08:50:38.433Z CNTRLR   querying API capabilities...
                      2021-08-03T08:50:38.446Z SERIAL » 0x01030007fb                                                         (5 bytes)
                      2021-08-03T08:50:38.447Z DRIVER » [REQ] [GetSerialApiCapabilities]
                      2021-08-03T08:50:38.452Z SERIAL « [ACK]        (0x06)
                      2021-08-03T08:50:38.460Z SERIAL « 0x012b01070504014704000002fe83ff88cf1f0000fb9f7da067008080008086000 (45 bytes)
                      2021-08-03T08:50:38.466Z SERIAL » [ACK]        (0x06)
                      2021-08-03T08:50:38.468Z DRIVER « [RES] [GetSerialApiCapabilities]
                                                        0000e0000401a00
                      2021-08-03T08:50:38.483Z CNTRLR   received API capabilities:
                                                          product ID:          0x02
                                                          · SendData (0x13)
                                                          · GetNVMId (0x29)
                                                          · HardReset (0x42)
                      2021-08-03T08:50:38.485Z CNTRLR   finding SUC...
                      2021-08-03T08:50:38.518Z SERIAL » 0x01030056aa                                                         (5 bytes)
                      2021-08-03T08:50:38.519Z DRIVER » [REQ] [GetSUCNodeId]
                      2021-08-03T08:50:38.524Z SERIAL « [ACK]        (0x06)
                      2021-08-03T08:50:38.528Z SERIAL « 0x0104015601ad                                                       (6 bytes)
                      2021-08-03T08:50:38.531Z SERIAL » [ACK]        (0x06)
                      2021-08-03T08:50:38.534Z DRIVER « [RES] [GetSUCNodeId]
                                                          payload: 0x01
                      2021-08-03T08:50:38.546Z CNTRLR   This is the SUC
                      2021-08-03T08:50:38.585Z CNTRLR   querying node information...
                      2021-08-03T08:50:38.598Z SERIAL » 0x01030002fe                                                         (5 bytes)
                      2021-08-03T08:50:38.599Z DRIVER » [REQ] [GetSerialApiInitData]
                      2021-08-03T08:50:38.605Z SERIAL « [ACK]        (0x06)
                      2021-08-03T08:50:38.661Z SERIAL « 0x0125010205081dbfea19000000000000000000000000000000000000000000000 (39 bytes)
                                                        0000000050080
                      2021-08-03T08:50:38.664Z SERIAL » [ACK]        (0x06)
                      2021-08-03T08:50:38.667Z DRIVER « [RES] [GetSerialApiInitData]
                                                        500
                      2021-08-03T08:50:38.680Z CNTRLR   received node information:
                                                         21
                      2021-08-03T08:50:38.792Z CNTRLR   [Node 001] [Manufacturer Specific] manufacturerId: metadata updated
                      2021-08-03T08:50:38.794Z CNTRLR   [Node 001] [Manufacturer Specific] productType: metadata updated
                      2021-08-03T08:50:38.796Z CNTRLR   [Node 001] [Manufacturer Specific] productId: metadata updated
                      2021-08-03T08:50:38.799Z CNTRLR   [Node 001] [+] [Manufacturer Specific] manufacturerId: 327
                      2021-08-03T08:50:38.801Z CNTRLR   [Node 001] [+] [Manufacturer Specific] productType: 1024
                      2021-08-03T08:50:38.802Z CNTRLR   [Node 001] [+] [Manufacturer Specific] productId: 2
                      2021-08-03T08:50:38.805Z CNTRLR   [Node 001] [Version] firmwareVersions: metadata updated
                      2021-08-03T08:50:38.806Z CNTRLR   [Node 001] [+] [Version] firmwareVersions: 5.4
                      2021-08-03T08:50:38.807Z CNTRLR   setting serial API timeouts: ack = 1000 ms, byte = 150 ms
                      2021-08-03T08:50:38.820Z SERIAL » 0x01050006640f97                                                     (7 bytes)
                      2021-08-03T08:50:38.822Z DRIVER » [REQ] [SetSerialApiTimeouts]
                                                          payload: 0x640f
                      2021-08-03T08:50:38.827Z SERIAL « [ACK]        (0x06)
                      2021-08-03T08:50:38.831Z SERIAL « 0x01050106640f96                                                     (7 bytes)
                      2021-08-03T08:50:38.833Z SERIAL » [ACK]        (0x06)
                      2021-08-03T08:50:38.835Z DRIVER « [RES] [SetSerialApiTimeouts]
                                                          payload: 0x640f
                      2021-08-03T08:50:38.849Z CNTRLR   serial API timeouts overwritten. The old values were: ack = 1000 ms, byte = 15
                                                        0 ms
                      2021-08-03T08:50:38.850Z CNTRLR   Interview completed
                      2021-08-03T08:50:38.850Z DRIVER   driver ready
                      2021-08-03T08:50:38.862Z CNTRLR   [Node 001] Beginning interview - last completed stage: None
                      2021-08-03T08:50:38.864Z CNTRLR   [Node 001] new node, doing a full interview...
                      2021-08-03T08:50:38.866Z CNTRLR » [Node 001] querying protocol info...
                      2021-08-03T08:50:39.013Z SERIAL » 0x0104004101bb                                                       (6 bytes)
                      2021-08-03T08:50:39.023Z DRIVER » [REQ] [GetNodeProtocolInfo]
                                                          payload: 0x01
                      2021-08-03T08:50:39.051Z SERIAL « [ACK]        (0x06)
                      2021-08-03T08:50:39.056Z SERIAL « 0x0109014193160102020133                                            (11 bytes)
                      2021-08-03T08:50:39.059Z SERIAL » [ACK]        (0x06)
                      2021-08-03T08:50:39.076Z DRIVER « [RES] [GetNodeProtocolInfo]
                      2021-08-03T08:50:39.091Z CNTRLR « [Node 001] received response for protocol info:
                                                        protocol version:      3
                      2021-08-03T08:50:39.137Z CNTRLR   [Node 001] Interview stage completed: ProtocolInfo
                      2021-08-03T08:50:39.139Z CNTRLR   [Node 001] not pinging the controller
                      2021-08-03T08:50:39.141Z CNTRLR   [Node 001] not querying node info from the controller
                      2021-08-03T08:50:39.143Z CNTRLR   [Node 001] Interview stage completed: NodeInfo
                      2021-08-03T08:50:39.148Z CNTRLR   [Node 001] Interview stage completed: CommandClasses
                      2021-08-03T08:50:39.172Z CNTRLR » [Node 001] requesting node neighbors...
                      2021-08-03T08:50:39.235Z SERIAL » 0x010700800100000079                                                 (9 bytes)
                      2021-08-03T08:50:39.237Z DRIVER » [REQ] [GetRoutingInfo]
                      2021-08-03T08:50:39.238Z CNTRLR » [Node 002] requesting node neighbors...
                      2021-08-03T08:50:39.243Z CNTRLR » [Node 003] requesting node neighbors...
                      2021-08-03T08:50:39.249Z CNTRLR » [Node 004] requesting node neighbors...
                      2021-08-03T08:50:39.254Z CNTRLR » [Node 005] requesting node neighbors...
                      2021-08-03T08:50:39.259Z CNTRLR » [Node 006] requesting node neighbors...
                      2021-08-03T08:50:39.264Z CNTRLR » [Node 008] requesting node neighbors...
                      2021-08-03T08:50:39.269Z CNTRLR » [Node 010] requesting node neighbors...
                      2021-08-03T08:50:39.274Z CNTRLR » [Node 012] requesting node neighbors...
                      2021-08-03T08:50:39.279Z CNTRLR » [Node 014] requesting node neighbors...
                      2021-08-03T08:50:39.284Z CNTRLR » [Node 015] requesting node neighbors...
                      2021-08-03T08:50:39.289Z CNTRLR » [Node 016] requesting node neighbors...
                      2021-08-03T08:50:39.294Z CNTRLR » [Node 017] requesting node neighbors...
                      2021-08-03T08:50:39.303Z CNTRLR » [Node 020] requesting node neighbors...
                      2021-08-03T08:50:39.308Z CNTRLR » [Node 021] requesting node neighbors...
                      2021-08-03T08:50:39.321Z SERIAL « [ACK]        (0x06)
                      2021-08-03T08:50:39.325Z SERIAL « 0x01200180a00a01000000000000000000000000000000000000000000000000000 (34 bytes)
                                                        0f5
                      2021-08-03T08:50:39.327Z SERIAL » [ACK]        (0x06)
                      2021-08-03T08:50:39.329Z DRIVER « [RES] [GetRoutingInfo]
                      2021-08-03T08:50:39.344Z SERIAL » 0x01070080020000007a                                                 (9 bytes)
                      2021-08-03T08:50:39.345Z DRIVER » [REQ] [GetRoutingInfo]
                      2021-08-03T08:50:39.347Z CNTRLR « [Node 001] node neighbors received: 6, 8, 10, 12, 17
                      2021-08-03T08:50:39.357Z CNTRLR   [Node 001] Embedded device config loaded
                      2021-08-03T08:50:39.357Z CNTRLR   [Node 001] Interview stage completed: OverwriteConfig
                      2021-08-03T08:50:39.358Z CNTRLR » [Node 001] requesting node neighbors...
                      2021-08-03T08:50:39.365Z SERIAL « [ACK]        (0x06)
                      2021-08-03T08:50:39.369Z SERIAL « 0x01200180080000000000000000000000000000000000000000000000000000000 (34 bytes)
                                                        056
                      2021-08-03T08:50:39.370Z SERIAL » [ACK]        (0x06)
                      2021-08-03T08:50:39.373Z DRIVER « [RES] [GetRoutingInfo]
                                                          node ids: 4
                      2021-08-03T08:50:39.389Z SERIAL » 0x01070080030000007b                                                 (9 bytes)
                      2021-08-03T08:50:39.390Z DRIVER » [REQ] [GetRoutingInfo]
                      2021-08-03T08:50:39.392Z CNTRLR « [Node 002] node neighbors received: 4
                      2021-08-03T08:50:39.401Z SERIAL « [ACK]        (0x06)
                      2021-08-03T08:50:39.405Z SERIAL « 0x01200180080000000000000000000000000000000000000000000000000000000 (34 bytes)
                                                        056
                      2021-08-03T08:50:39.407Z SERIAL » [ACK]        (0x06)
                      2021-08-03T08:50:39.410Z DRIVER   Checking for configuration updates...
                      2021-08-03T08:50:39.515Z DRIVER « [RES] [GetRoutingInfo]
                                                          node ids: 4
                      2021-08-03T08:50:39.532Z SERIAL » 0x01070080040000007c                                                 (9 bytes)
                      2021-08-03T08:50:39.533Z DRIVER » [REQ] [GetRoutingInfo]
                      2021-08-03T08:50:39.534Z CNTRLR « [Node 003] node neighbors received: 4
                      2021-08-03T08:50:39.540Z SERIAL « [ACK]        (0x06)
                      2021-08-03T08:50:39.544Z SERIAL « 0x01200180060000000000000000000000000000000000000000000000000000000 (34 bytes)
                                                        058
                      2021-08-03T08:50:39.546Z SERIAL » [ACK]        (0x06)
                      2021-08-03T08:50:39.549Z DRIVER « [RES] [GetRoutingInfo]
                                                          node ids: 2, 3
                      2021-08-03T08:50:39.563Z SERIAL » 0x01070080050000007d                                                 (9 bytes)
                      2021-08-03T08:50:39.564Z DRIVER » [REQ] [GetRoutingInfo]
                      2021-08-03T08:50:39.565Z CNTRLR « [Node 004] node neighbors received: 2, 3
                      2021-08-03T08:50:39.578Z SERIAL « [ACK]        (0x06)
                      2021-08-03T08:50:39.581Z SERIAL « 0x01200180000000000000000000000000000000000000000000000000000000000 (34 bytes)
                                                        05e
                      2021-08-03T08:50:39.582Z SERIAL » [ACK]        (0x06)
                      2021-08-03T08:50:39.588Z DRIVER « [RES] [GetRoutingInfo]
                                                          node ids:
                      2021-08-03T08:50:39.602Z SERIAL » 0x01070080060000007e                                                 (9 bytes)
                      2021-08-03T08:50:39.603Z DRIVER » [REQ] [GetRoutingInfo]
                      2021-08-03T08:50:39.605Z CNTRLR « [Node 005] node neighbors received:
                      2021-08-03T08:50:39.633Z SERIAL « [ACK]        (0x06)
                      2021-08-03T08:50:39.636Z SERIAL « 0x01200180010000000000000000000000000000000000000000000000000000000 (34 bytes)
                                                        05f
                      2021-08-03T08:50:39.638Z SERIAL » [ACK]        (0x06)
                      2021-08-03T08:50:39.640Z DRIVER « [RES] [GetRoutingInfo]
                                                          node ids: 1
                      2021-08-03T08:50:39.658Z SERIAL » 0x010700800800000070                                                 (9 bytes)
                      2021-08-03T08:50:39.660Z DRIVER » [REQ] [GetRoutingInfo]
                      2021-08-03T08:50:39.661Z CNTRLR « [Node 006] node neighbors received: 1
                      2021-08-03T08:50:39.676Z SERIAL « [ACK]        (0x06)
                      2021-08-03T08:50:39.684Z SERIAL « 0x01200180010000000000000000000000000000000000000000000000000000000 (34 bytes)
                                                        05f
                      2021-08-03T08:50:39.686Z SERIAL » [ACK]        (0x06)
                      2021-08-03T08:50:39.688Z DRIVER « [RES] [GetRoutingInfo]
                                                          node ids: 1
                      2021-08-03T08:50:39.701Z SERIAL » 0x010700800a00000072                                                 (9 bytes)
                      2021-08-03T08:50:39.703Z DRIVER » [REQ] [GetRoutingInfo]
                      2021-08-03T08:50:39.704Z CNTRLR « [Node 008] node neighbors received: 1
                      2021-08-03T08:50:39.708Z SERIAL « [ACK]        (0x06)
                      2021-08-03T08:50:39.713Z SERIAL « 0x01200180010000000000000000000000000000000000000000000000000000000 (34 bytes)
                                                        05f
                      2021-08-03T08:50:39.715Z SERIAL » [ACK]        (0x06)
                      2021-08-03T08:50:39.717Z DRIVER « [RES] [GetRoutingInfo]
                                                          node ids: 1
                      2021-08-03T08:50:39.744Z SERIAL » 0x010700800c00000074                                                 (9 bytes)
                      2021-08-03T08:50:39.745Z DRIVER » [REQ] [GetRoutingInfo]
                      2021-08-03T08:50:39.747Z CNTRLR « [Node 010] node neighbors received: 1
                      2021-08-03T08:50:39.759Z SERIAL « [ACK]        (0x06)
                      2021-08-03T08:50:39.762Z SERIAL « 0x01200180010000000000000000000000000000000000000000000000000000000 (34 bytes)
                                                        05f
                      2021-08-03T08:50:39.764Z SERIAL » [ACK]        (0x06)
                      2021-08-03T08:50:39.781Z DRIVER « [RES] [GetRoutingInfo]
                                                          node ids: 1
                      2021-08-03T08:50:39.797Z SERIAL » 0x010700800e00000076                                                 (9 bytes)
                      2021-08-03T08:50:39.798Z DRIVER » [REQ] [GetRoutingInfo]
                      2021-08-03T08:50:39.799Z CNTRLR « [Node 012] node neighbors received: 1
                      2021-08-03T08:50:39.808Z SERIAL « [ACK]        (0x06)
                      2021-08-03T08:50:39.811Z SERIAL « 0x01200180000000000000000000000000000000000000000000000000000000000 (34 bytes)
                                                        05e
                      2021-08-03T08:50:39.813Z SERIAL » [ACK]        (0x06)
                      2021-08-03T08:50:39.816Z DRIVER « [RES] [GetRoutingInfo]
                                                          node ids:
                      2021-08-03T08:50:39.834Z SERIAL » 0x010700800f00000077                                                 (9 bytes)
                      2021-08-03T08:50:39.836Z DRIVER » [REQ] [GetRoutingInfo]
                      2021-08-03T08:50:39.838Z CNTRLR « [Node 014] node neighbors received:
                      2021-08-03T08:50:39.930Z DRIVER   No configuration update available...
                      2021-08-03T08:50:39.935Z SERIAL « [ACK]        (0x06)
                      2021-08-03T08:50:39.940Z SERIAL « 0x01200180000000000000000000000000000000000000000000000000000000000 (34 bytes)
                                                        05e
                      2021-08-03T08:50:39.942Z SERIAL » [ACK]        (0x06)
                      2021-08-03T08:50:39.949Z DRIVER « [RES] [GetRoutingInfo]
                                                          node ids:
                      2021-08-03T08:50:39.963Z SERIAL » 0x010700801000000068                                                 (9 bytes)
                      2021-08-03T08:50:39.964Z DRIVER » [REQ] [GetRoutingInfo]
                      2021-08-03T08:50:39.965Z CNTRLR « [Node 015] node neighbors received:
                      2021-08-03T08:50:39.972Z SERIAL « [ACK]        (0x06)
                      2021-08-03T08:50:39.975Z SERIAL « 0x01200180000000000000000000000000000000000000000000000000000000000 (34 bytes)
                                                        05e
                      2021-08-03T08:50:39.977Z SERIAL » [ACK]        (0x06)
                      2021-08-03T08:50:39.979Z DRIVER « [RES] [GetRoutingInfo]
                                                          node ids:
                      2021-08-03T08:50:40.008Z SERIAL » 0x010700801100000069                                                 (9 bytes)
                      2021-08-03T08:50:40.010Z DRIVER » [REQ] [GetRoutingInfo]
                      2021-08-03T08:50:40.011Z CNTRLR « [Node 016] node neighbors received:
                      2021-08-03T08:50:40.016Z SERIAL « [ACK]        (0x06)
                      2021-08-03T08:50:40.020Z SERIAL « 0x01200180010000000000000000000000000000000000000000000000000000000 (34 bytes)
                                                        05f
                      2021-08-03T08:50:40.022Z SERIAL » [ACK]        (0x06)
                      2021-08-03T08:50:40.025Z DRIVER « [RES] [GetRoutingInfo]
                                                          node ids: 1
                      2021-08-03T08:50:40.046Z SERIAL » 0x01070080140000006c                                                 (9 bytes)
                      2021-08-03T08:50:40.047Z DRIVER » [REQ] [GetRoutingInfo]
                      2021-08-03T08:50:40.048Z CNTRLR « [Node 017] node neighbors received: 1
                      2021-08-03T08:50:40.053Z SERIAL « [ACK]        (0x06)
                      2021-08-03T08:50:40.058Z SERIAL « 0x01200180000000000000000000000000000000000000000000000000000000000 (34 bytes)
                                                        05e
                      2021-08-03T08:50:40.060Z SERIAL » [ACK]        (0x06)
                      2021-08-03T08:50:40.064Z DRIVER « [RES] [GetRoutingInfo]
                                                          node ids:
                      2021-08-03T08:50:40.079Z SERIAL » 0x01070080150000006d                                                 (9 bytes)
                      2021-08-03T08:50:40.080Z DRIVER » [REQ] [GetRoutingInfo]
                      2021-08-03T08:50:40.082Z CNTRLR « [Node 020] node neighbors received:
                      2021-08-03T08:50:40.090Z SERIAL « [ACK]        (0x06)
                      2021-08-03T08:50:40.094Z SERIAL « 0x01200180000000000000000000000000000000000000000000000000000000000 (34 bytes)
                                                        05e
                      2021-08-03T08:50:40.096Z SERIAL » [ACK]        (0x06)
                      2021-08-03T08:50:40.098Z DRIVER « [RES] [GetRoutingInfo]
                                                          node ids:
                      2021-08-03T08:50:40.114Z SERIAL » 0x010700800100000079                                                 (9 bytes)
                      2021-08-03T08:50:40.115Z DRIVER » [REQ] [GetRoutingInfo]
                      2021-08-03T08:50:40.117Z CNTRLR « [Node 021] node neighbors received:
                      2021-08-03T08:50:40.125Z SERIAL « [ACK]        (0x06)
                      2021-08-03T08:50:40.129Z SERIAL « 0x01200180a00a01000000000000000000000000000000000000000000000000000 (34 bytes)
                                                        0f5
                      2021-08-03T08:50:40.131Z SERIAL » [ACK]        (0x06)
                      2021-08-03T08:50:40.133Z DRIVER « [RES] [GetRoutingInfo]
                      2021-08-03T08:50:40.142Z CNTRLR « [Node 001] node neighbors received: 6, 8, 10, 12, 17
                      2021-08-03T08:50:40.143Z CNTRLR   [Node 001] Interview stage completed: Neighbors
                      2021-08-03T08:50:40.155Z CNTRLR   [Node 001] Interview completed
                      2021-08-03T08:50:40.157Z CNTRLR   [Node 001] The node is ready to be used
                      2021-08-03T08:50:40.165Z CNTRLR   [Node 001] The node is alive.
                      2021-08-03T08:50:40.175Z CNTRLR   [Node 002] Beginning interview - last completed stage: None
                      2021-08-03T08:50:40.175Z CNTRLR   [Node 002] new node, doing a full interview...
                      2021-08-03T08:50:40.176Z CNTRLR » [Node 002] querying protocol info...
                      2021-08-03T08:50:40.187Z SERIAL » 0x0104004102b8                                                       (6 bytes)
                      2021-08-03T08:50:40.189Z DRIVER » [REQ] [GetNodeProtocolInfo]
                                                          payload: 0x02
                      2021-08-03T08:50:40.192Z CNTRLR   [Node 003] Beginning interview - last completed stage: None
                      2021-08-03T08:50:40.194Z CNTRLR   [Node 003] new node, doing a full interview...
                      2021-08-03T08:50:40.195Z CNTRLR » [Node 003] querying protocol info...
                      2021-08-03T08:50:40.200Z CNTRLR   [Node 004] Beginning interview - last completed stage: None
                      2021-08-03T08:50:40.201Z CNTRLR   [Node 004] new node, doing a full interview...
                      2021-08-03T08:50:40.201Z CNTRLR » [Node 004] querying protocol info...
                      2021-08-03T08:50:40.207Z CNTRLR   [Node 005] Beginning interview - last completed stage: None
                      2021-08-03T08:50:40.207Z CNTRLR   [Node 005] new node, doing a full interview...
                      2021-08-03T08:50:40.208Z CNTRLR » [Node 005] querying protocol info...
                      2021-08-03T08:50:40.213Z CNTRLR   [Node 006] Beginning interview - last completed stage: None
                      2021-08-03T08:50:40.214Z CNTRLR   [Node 006] new node, doing a full interview...
                      2021-08-03T08:50:40.215Z CNTRLR » [Node 006] querying protocol info...
                      2021-08-03T08:50:40.220Z CNTRLR   [Node 008] Beginning interview - last completed stage: None
                      2021-08-03T08:50:40.221Z CNTRLR   [Node 008] new node, doing a full interview...
                      2021-08-03T08:50:40.221Z CNTRLR » [Node 008] querying protocol info...
                      2021-08-03T08:50:40.226Z CNTRLR   [Node 010] Beginning interview - last completed stage: None
                      2021-08-03T08:50:40.227Z CNTRLR   [Node 010] new node, doing a full interview...
                      2021-08-03T08:50:40.227Z CNTRLR » [Node 010] querying protocol info...
                      2021-08-03T08:50:40.232Z CNTRLR   [Node 012] Beginning interview - last completed stage: None
                      2021-08-03T08:50:40.233Z CNTRLR   [Node 012] new node, doing a full interview...
                      2021-08-03T08:50:40.233Z CNTRLR » [Node 012] querying protocol info...
                      2021-08-03T08:50:40.238Z CNTRLR   [Node 014] Beginning interview - last completed stage: None
                      2021-08-03T08:50:40.239Z CNTRLR   [Node 014] new node, doing a full interview...
                      2021-08-03T08:50:40.239Z CNTRLR » [Node 014] querying protocol info...
                      2021-08-03T08:50:40.244Z CNTRLR   [Node 015] Beginning interview - last completed stage: None
                      2021-08-03T08:50:40.245Z CNTRLR   [Node 015] new node, doing a full interview...
                      2021-08-03T08:50:40.246Z CNTRLR » [Node 015] querying protocol info...
                      2021-08-03T08:50:40.251Z CNTRLR   [Node 016] Beginning interview - last completed stage: None
                      2021-08-03T08:50:40.252Z CNTRLR   [Node 016] new node, doing a full interview...
                      2021-08-03T08:50:40.252Z CNTRLR » [Node 016] querying protocol info...
                      2021-08-03T08:50:40.257Z CNTRLR   [Node 017] Beginning interview - last completed stage: None
                      2021-08-03T08:50:40.258Z CNTRLR   [Node 017] new node, doing a full interview...
                      2021-08-03T08:50:40.258Z CNTRLR » [Node 017] querying protocol info...
                      2021-08-03T08:50:40.265Z CNTRLR   [Node 020] Beginning interview - last completed stage: None
                      2021-08-03T08:50:40.271Z CNTRLR   [Node 020] new node, doing a full interview...
                      2021-08-03T08:50:40.272Z CNTRLR » [Node 020] querying protocol info...
                      2021-08-03T08:50:40.277Z CNTRLR   [Node 021] Beginning interview - last completed stage: None
                      2021-08-03T08:50:40.278Z CNTRLR   [Node 021] new node, doing a full interview...
                      2021-08-03T08:50:40.278Z CNTRLR » [Node 021] querying protocol info...
                      2021-08-03T08:50:40.289Z SERIAL « [ACK]        (0x06)
                      2021-08-03T08:50:40.293Z SERIAL « 0x01090141d39c01041001ed                                            (11 bytes)
                      2021-08-03T08:50:40.294Z SERIAL » [ACK]        (0x06)
                      2021-08-03T08:50:40.296Z DRIVER « [RES] [GetNodeProtocolInfo]
                      2021-08-03T08:50:40.316Z SERIAL » 0x0104004103b9                                                       (6 bytes)
                      2021-08-03T08:50:40.317Z DRIVER » [REQ] [GetNodeProtocolInfo]
                                                          payload: 0x03
                      2021-08-03T08:50:40.319Z CNTRLR « [Node 002] received response for protocol info:
                                                        protocol version:      3
                      2021-08-03T08:50:40.327Z SERIAL « [ACK]        (0x06)
                      2021-08-03T08:50:40.330Z SERIAL « 0x01090141539c010407017a                                            (11 bytes)
                      2021-08-03T08:50:40.332Z SERIAL » [ACK]        (0x06)
                      2021-08-03T08:50:40.335Z DRIVER « [RES] [GetNodeProtocolInfo]
                      2021-08-03T08:50:40.372Z SERIAL » 0x0104004104be                                                       (6 bytes)
                      2021-08-03T08:50:40.373Z DRIVER » [REQ] [GetNodeProtocolInfo]
                                                          payload: 0x04
                      2021-08-03T08:50:40.375Z CNTRLR « [Node 003] received response for protocol info:
                                                        protocol version:      3
                      2021-08-03T08:50:40.378Z CNTRLR   [Node 003] The node is asleep.
                      2021-08-03T08:50:40.381Z CNTRLR   [Node 003] Interview stage completed: ProtocolInfo
                      2021-08-03T08:50:40.382Z CNTRLR » [Node 003] querying node info...
                      2021-08-03T08:50:40.396Z CNTRLR   [Node 002] Interview stage completed: ProtocolInfo
                      2021-08-03T08:50:40.398Z CNTRLR » [Node 002] pinging the node...
                      2021-08-03T08:50:40.411Z SERIAL « [ACK]        (0x06)
                      2021-08-03T08:50:40.414Z SERIAL « 0x01090141d39c00041000ed                                            (11 bytes)
                      2021-08-03T08:50:40.416Z SERIAL » [ACK]        (0x06)
                      2021-08-03T08:50:40.419Z DRIVER « [RES] [GetNodeProtocolInfo]
                      2021-08-03T08:50:40.433Z SERIAL » 0x0104004105bf                                                       (6 bytes)
                      2021-08-03T08:50:40.434Z DRIVER » [REQ] [GetNodeProtocolInfo]
                                                          payload: 0x05
                      2021-08-03T08:50:40.436Z CNTRLR « [Node 004] received response for protocol info:
                                                        protocol version:      3
                      2021-08-03T08:50:40.436Z CNTRLR   [Node 004] Interview stage completed: ProtocolInfo
                      2021-08-03T08:50:40.437Z CNTRLR » [Node 004] pinging the node...
                      2021-08-03T08:50:40.447Z SERIAL « [ACK]        (0x06)
                      2021-08-03T08:50:40.450Z SERIAL « 0x01090141539c010407017a                                            (11 bytes)
                      2021-08-03T08:50:40.452Z SERIAL » [ACK]        (0x06)
                      2021-08-03T08:50:40.454Z DRIVER « [RES] [GetNodeProtocolInfo]
                      2021-08-03T08:50:40.475Z SERIAL » 0x0104004106bc                                                       (6 bytes)
                      2021-08-03T08:50:40.476Z DRIVER » [REQ] [GetNodeProtocolInfo]
                                                          payload: 0x06
                      2021-08-03T08:50:40.477Z CNTRLR « [Node 005] received response for protocol info:
                                                        protocol version:      3
                      2021-08-03T08:50:40.479Z CNTRLR   [Node 005] The node is asleep.
                      2021-08-03T08:50:40.481Z CNTRLR   [Node 005] Interview stage completed: ProtocolInfo
                      2021-08-03T08:50:40.482Z CNTRLR » [Node 005] querying node info...
                      2021-08-03T08:50:40.491Z SERIAL « [ACK]        (0x06)
                      2021-08-03T08:50:40.494Z SERIAL « 0x01090141539c010407017a                                            (11 bytes)
                      2021-08-03T08:50:40.496Z SERIAL » [ACK]        (0x06)
                      2021-08-03T08:50:40.498Z DRIVER « [RES] [GetNodeProtocolInfo]
                      2021-08-03T08:50:40.513Z SERIAL » 0x0104004108b2                                                       (6 bytes)
                      2021-08-03T08:50:40.514Z DRIVER » [REQ] [GetNodeProtocolInfo]
                                                          payload: 0x08
                      2021-08-03T08:50:40.516Z CNTRLR « [Node 006] received response for protocol info:
                                                        protocol version:      3
                      2021-08-03T08:50:40.517Z CNTRLR   [Node 006] The node is asleep.
                      2021-08-03T08:50:40.520Z CNTRLR   [Node 006] Interview stage completed: ProtocolInfo
                      2021-08-03T08:50:40.521Z CNTRLR » [Node 006] querying node info...
                      2021-08-03T08:50:40.530Z SERIAL « [ACK]        (0x06)
                      2021-08-03T08:50:40.533Z SERIAL « 0x01090141539c010407017a                                            (11 bytes)
                      2021-08-03T08:50:40.535Z SERIAL » [ACK]        (0x06)
                      2021-08-03T08:50:40.538Z DRIVER « [RES] [GetNodeProtocolInfo]
                      2021-08-03T08:50:40.574Z SERIAL » 0x010400410ab0                                                       (6 bytes)
                      2021-08-03T08:50:40.575Z DRIVER » [REQ] [GetNodeProtocolInfo]
                                                          payload: 0x0a
                      2021-08-03T08:50:40.577Z CNTRLR « [Node 008] received response for protocol info:
                                                        protocol version:      3
                      2021-08-03T08:50:40.579Z CNTRLR   [Node 008] The node is asleep.
                      2021-08-03T08:50:40.594Z SERIAL « [ACK]        (0x06)
                      2021-08-03T08:50:40.599Z SERIAL « 0x01090141539c010407017a                                            (11 bytes)
                      2021-08-03T08:50:40.601Z SERIAL » [ACK]        (0x06)
                      2021-08-03T08:50:40.606Z DRIVER « [RES] [GetNodeProtocolInfo]
                      2021-08-03T08:50:40.626Z SERIAL » 0x010400410cb6                                                       (6 bytes)
                      2021-08-03T08:50:40.628Z DRIVER » [REQ] [GetNodeProtocolInfo]
                                                          payload: 0x0c
                      2021-08-03T08:50:40.631Z CNTRLR « [Node 010] received response for protocol info:
                                                        protocol version:      3
                      2021-08-03T08:50:40.633Z CNTRLR   [Node 010] The node is asleep.
                      2021-08-03T08:50:40.635Z CNTRLR   [Node 010] Interview stage completed: ProtocolInfo
                      2021-08-03T08:50:40.636Z CNTRLR » [Node 010] querying node info...
                      2021-08-03T08:50:40.651Z CNTRLR   [Node 008] Interview stage completed: ProtocolInfo
                      2021-08-03T08:50:40.651Z CNTRLR » [Node 008] querying node info...
                      2021-08-03T08:50:40.658Z SERIAL « [ACK]        (0x06)
                      2021-08-03T08:50:40.661Z SERIAL « 0x01090141539c010407017a                                            (11 bytes)
                      2021-08-03T08:50:40.662Z SERIAL » [ACK]        (0x06)
                      2021-08-03T08:50:40.665Z DRIVER « [RES] [GetNodeProtocolInfo]
                      2021-08-03T08:50:40.681Z SERIAL » 0x010400410eb4                                                       (6 bytes)
                      2021-08-03T08:50:40.682Z DRIVER » [REQ] [GetNodeProtocolInfo]
                                                          payload: 0x0e
                      2021-08-03T08:50:40.683Z CNTRLR « [Node 012] received response for protocol info:
                                                        protocol version:      3
                      2021-08-03T08:50:40.685Z CNTRLR   [Node 012] The node is asleep.
                      2021-08-03T08:50:40.688Z CNTRLR   [Node 012] Interview stage completed: ProtocolInfo
                      2021-08-03T08:50:40.689Z CNTRLR » [Node 012] querying node info...
                      2021-08-03T08:50:40.700Z SERIAL « [ACK]        (0x06)
                      2021-08-03T08:50:40.704Z SERIAL « 0x01090141539c010407017a                                            (11 bytes)
                      2021-08-03T08:50:40.706Z SERIAL » [ACK]        (0x06)
                      2021-08-03T08:50:40.707Z DRIVER « [RES] [GetNodeProtocolInfo]
                      2021-08-03T08:50:40.737Z SERIAL » 0x010400410fb5                                                       (6 bytes)
                      2021-08-03T08:50:40.738Z DRIVER » [REQ] [GetNodeProtocolInfo]
                                                          payload: 0x0f
                      2021-08-03T08:50:40.740Z CNTRLR « [Node 014] received response for protocol info:
                                                        protocol version:      3
                      2021-08-03T08:50:40.743Z CNTRLR   [Node 014] The node is asleep.
                      2021-08-03T08:50:40.746Z CNTRLR   [Node 014] Interview stage completed: ProtocolInfo
                      2021-08-03T08:50:40.746Z CNTRLR » [Node 014] querying node info...
                      2021-08-03T08:50:40.755Z SERIAL « [ACK]        (0x06)
                      2021-08-03T08:50:40.758Z SERIAL « 0x01090141539c010407017a                                            (11 bytes)
                      2021-08-03T08:50:40.760Z SERIAL » [ACK]        (0x06)
                      2021-08-03T08:50:40.762Z DRIVER « [RES] [GetNodeProtocolInfo]
                      2021-08-03T08:50:40.809Z SERIAL » 0x0104004110aa                                                       (6 bytes)
                      2021-08-03T08:50:40.810Z DRIVER » [REQ] [GetNodeProtocolInfo]
                                                          payload: 0x10
                      2021-08-03T08:50:40.812Z CNTRLR « [Node 015] received response for protocol info:
                                                        protocol version:      3
                      2021-08-03T08:50:40.813Z CNTRLR   [Node 015] The node is asleep.
                      2021-08-03T08:50:40.823Z SERIAL « [ACK]        (0x06)
                      2021-08-03T08:50:40.827Z SERIAL « 0x01090141539c010407017a                                            (11 bytes)
                      2021-08-03T08:50:40.828Z SERIAL » [ACK]        (0x06)
                      2021-08-03T08:50:40.831Z DRIVER « [RES] [GetNodeProtocolInfo]
                      2021-08-03T08:50:40.852Z SERIAL » 0x0104004111ab                                                       (6 bytes)
                      2021-08-03T08:50:40.853Z DRIVER » [REQ] [GetNodeProtocolInfo]
                                                          payload: 0x11
                      2021-08-03T08:50:40.855Z CNTRLR « [Node 016] received response for protocol info:
                                                        protocol version:      3
                      2021-08-03T08:50:40.858Z CNTRLR   [Node 016] The node is asleep.
                      2021-08-03T08:50:40.861Z CNTRLR   [Node 016] Interview stage completed: ProtocolInfo
                      2021-08-03T08:50:40.863Z CNTRLR » [Node 016] querying node info...
                      2021-08-03T08:50:40.871Z CNTRLR   [Node 015] Interview stage completed: ProtocolInfo
                      2021-08-03T08:50:40.872Z CNTRLR » [Node 015] querying node info...
                      2021-08-03T08:50:40.876Z SERIAL « [ACK]        (0x06)
                      2021-08-03T08:50:40.885Z SERIAL « 0x01090141539c010407017a                                            (11 bytes)
                      2021-08-03T08:50:40.886Z SERIAL » [ACK]        (0x06)
                      2021-08-03T08:50:40.888Z DRIVER « [RES] [GetNodeProtocolInfo]
                      2021-08-03T08:50:40.903Z SERIAL » 0x0104004114ae                                                       (6 bytes)
                      2021-08-03T08:50:40.904Z DRIVER » [REQ] [GetNodeProtocolInfo]
                                                          payload: 0x14
                      2021-08-03T08:50:40.906Z CNTRLR « [Node 017] received response for protocol info:
                                                        protocol version:      3
                      2021-08-03T08:50:40.908Z CNTRLR   [Node 017] The node is asleep.
                      2021-08-03T08:50:40.910Z CNTRLR   [Node 017] Interview stage completed: ProtocolInfo
                      2021-08-03T08:50:40.911Z CNTRLR » [Node 017] querying node info...
                      2021-08-03T08:50:40.920Z SERIAL « [ACK]        (0x06)
                      2021-08-03T08:50:40.924Z SERIAL « 0x01090141539c010407017a                                            (11 bytes)
                      2021-08-03T08:50:40.926Z SERIAL » [ACK]        (0x06)
                      2021-08-03T08:50:40.928Z DRIVER « [RES] [GetNodeProtocolInfo]
                      2021-08-03T08:50:40.944Z SERIAL » 0x0104004115af                                                       (6 bytes)
                      2021-08-03T08:50:40.952Z DRIVER » [REQ] [GetNodeProtocolInfo]
                                                          payload: 0x15
                      2021-08-03T08:50:40.954Z CNTRLR « [Node 020] received response for protocol info:
                                                        protocol version:      3
                      2021-08-03T08:50:40.955Z CNTRLR   [Node 020] The node is asleep.
                      2021-08-03T08:50:40.958Z CNTRLR   [Node 020] Interview stage completed: ProtocolInfo
                      2021-08-03T08:50:40.959Z CNTRLR » [Node 020] querying node info...
                      2021-08-03T08:50:40.967Z SERIAL « [ACK]        (0x06)
                      2021-08-03T08:50:40.971Z SERIAL « 0x01090141539c010407017a                                            (11 bytes)
                      2021-08-03T08:50:40.972Z SERIAL » [ACK]        (0x06)
                      2021-08-03T08:50:40.974Z DRIVER « [RES] [GetNodeProtocolInfo]
                      2021-08-03T08:50:40.991Z SERIAL » 0x010800130201002501c3                                              (10 bytes)
                      2021-08-03T08:50:40.993Z DRIVER » [Node 002] [REQ] [SendData]
                                                        │ callback id:      1
                                                        └─[NoOperationCC]
                      2021-08-03T08:50:40.995Z CNTRLR « [Node 021] received response for protocol info:
                                                        protocol version:      3
                      2021-08-03T08:50:40.997Z CNTRLR   [Node 021] The node is asleep.
                      2021-08-03T08:50:40.999Z CNTRLR   [Node 021] Interview stage completed: ProtocolInfo
                      2021-08-03T08:50:41.000Z CNTRLR » [Node 021] querying node info...
                      2021-08-03T08:50:41.023Z SERIAL « [ACK]        (0x06)
                      2021-08-03T08:50:41.028Z SERIAL « 0x0104011301e8                                                       (6 bytes)
                      2021-08-03T08:50:41.029Z SERIAL » [ACK]        (0x06)
                      2021-08-03T08:50:41.033Z DRIVER « [RES] [SendData]
                                                          was sent: true
                      2021-08-03T08:50:45.106Z SERIAL « 0x010700130101019b71                                                 (9 bytes)
                      2021-08-03T08:50:45.109Z SERIAL » [ACK]        (0x06)
                      2021-08-03T08:50:45.112Z DRIVER « [REQ] [SendData]
                                                          callback id:     1
                      2021-08-03T08:50:45.130Z CNTRLR   [Node 002] Node 2 did not respond after 1 attempts, it is presumed dead
                      2021-08-03T08:50:45.133Z CNTRLR   [Node 002] The node is dead.
                      2021-08-03T08:50:45.166Z SERIAL » 0x010800130401002502c6                                              (10 bytes)
                      2021-08-03T08:50:45.168Z DRIVER » [Node 004] [REQ] [SendData]
                                                        │ callback id:      2
                                                        └─[NoOperationCC]
                      2021-08-03T08:50:45.172Z CNTRLR   [Node 002] ping failed: Failed to send the command after 1 attempts (Status No
                                                        Ack)
                      2021-08-03T08:50:45.174Z CNTRLR » [Node 002] querying node info...
                      2021-08-03T08:50:45.175Z CNTRLR » [Node 002] pinging the node...
                      2021-08-03T08:50:45.189Z SERIAL « [ACK]        (0x06)
                      2021-08-03T08:50:45.195Z SERIAL « 0x0104011301e8                                                       (6 bytes)
                      2021-08-03T08:50:45.196Z SERIAL » [ACK]        (0x06)
                      2021-08-03T08:50:45.200Z DRIVER « [RES] [SendData]
                                                          was sent: true
                      2021-08-03T08:50:49.301Z SERIAL « 0x010700130201019c75                                                 (9 bytes)
                      2021-08-03T08:50:49.303Z SERIAL » [ACK]        (0x06)
                      2021-08-03T08:50:49.305Z DRIVER « [REQ] [SendData]
                                                          callback id:     2
                      2021-08-03T08:50:49.316Z CNTRLR   [Node 004] Node 4 did not respond after 1 attempts, it is presumed dead
                      2021-08-03T08:50:49.318Z CNTRLR   [Node 004] The node is dead.
                      2021-08-03T08:50:49.334Z SERIAL » 0x010800130201002503c1                                              (10 bytes)
                      2021-08-03T08:50:49.336Z DRIVER » [Node 002] [REQ] [SendData]
                                                        │ callback id:      3
                                                        └─[NoOperationCC]
                      2021-08-03T08:50:49.339Z CNTRLR   [Node 004] ping failed: Failed to send the command after 1 attempts (Status No
                                                        Ack)
                      2021-08-03T08:50:49.341Z CNTRLR » [Node 004] querying node info...
                      2021-08-03T08:50:49.342Z CNTRLR » [Node 004] pinging the node...
                      2021-08-03T08:50:49.353Z SERIAL « [ACK]        (0x06)
                      2021-08-03T08:50:49.358Z SERIAL « 0x0104011301e8                                                       (6 bytes)
                      2021-08-03T08:50:49.359Z SERIAL » [ACK]        (0x06)
                      2021-08-03T08:50:49.362Z DRIVER « [RES] [SendData]
                                                          was sent: true
                      2021-08-03T08:50:53.437Z SERIAL « 0x010700130301019971                                                 (9 bytes)
                      2021-08-03T08:50:53.439Z SERIAL » [ACK]        (0x06)
                      2021-08-03T08:50:53.441Z DRIVER « [REQ] [SendData]
                                                          callback id:     3
                      2021-08-03T08:50:53.453Z CNTRLR   [Node 002] Node 2 did not respond after 1 attempts, it is presumed dead
                      2021-08-03T08:50:53.494Z SERIAL » 0x010800130401002504c0                                              (10 bytes)
                      2021-08-03T08:50:53.497Z DRIVER » [Node 004] [REQ] [SendData]
                                                        │ callback id:      4
                                                        └─[NoOperationCC]
                      2021-08-03T08:50:53.501Z CNTRLR   [Node 002] ping failed: Failed to send the command after 1 attempts (Status No
                                                        Ack)
                      2021-08-03T08:50:53.503Z CNTRLR   [Node 002] Interview attempt (1/5) failed, node is dead.
                      2021-08-03T08:50:53.509Z SERIAL « [ACK]        (0x06)
                      2021-08-03T08:50:53.515Z SERIAL « 0x0104011301e8                                                       (6 bytes)
                      2021-08-03T08:50:53.516Z SERIAL » [ACK]        (0x06)
                      2021-08-03T08:50:53.518Z DRIVER « [RES] [SendData]
                                                          was sent: true
                      2021-08-03T08:50:57.630Z SERIAL « 0x010700130401019c73                                                 (9 bytes)
                      2021-08-03T08:50:57.632Z SERIAL » [ACK]        (0x06)
                      2021-08-03T08:50:57.633Z DRIVER « [REQ] [SendData]
                                                          callback id:     4
                      2021-08-03T08:50:57.640Z CNTRLR   [Node 004] Node 4 did not respond after 1 attempts, it is presumed dead
                      2021-08-03T08:50:57.646Z CNTRLR   [Node 004] ping failed: Failed to send the command after 1 attempts (Status No
                                                        Ack)
                      2021-08-03T08:50:57.647Z CNTRLR   [Node 004] Interview attempt (1/5) failed, node is dead.
                      2021-08-03T09:01:07.727Z SERIAL « 0x0115000400140f9f03a30064afffa8eecfcccb29c3dc46                    (23 bytes)
                      2021-08-03T09:01:07.735Z DRIVER   Dropping message because it could not be deserialized: The command class Secur
                                                        ity 2 is not implemented
                      2021-08-03T09:01:07.737Z SERIAL » [ACK]        (0x06)
                      2021-08-03T09:01:08.603Z SERIAL « 0x0114000400140e9f03a400a8f00877dd329fbaa37dfe                      (22 bytes)
                      2021-08-03T09:01:08.605Z DRIVER   Dropping message because it could not be deserialized: The command class Secur
                      2021-08-03T09:01:08.606Z SERIAL » [ACK]        (0x06)
                      2021-08-03T09:21:02.428Z SERIAL « 0x0115000400080f9f039e003afacca10eef96b7ad1fba8e                    (23 bytes)
                      2021-08-03T09:21:02.431Z DRIVER   Dropping message because it could not be deserialized: The command class Secur
                      2021-08-03T09:21:02.432Z SERIAL » [ACK]        (0x06)
                      2021-08-03T09:21:03.221Z SERIAL « 0x0114000400080e9f039f0066718bd95598571b8bf653                      (22 bytes)
                      2021-08-03T09:21:03.223Z DRIVER   Dropping message because it could not be deserialized: The command class Secur
                      2021-08-03T09:21:03.225Z SERIAL » [ACK]        (0x06)
                      2021-08-03T09:30:19.720Z SERIAL « 0x0115000400100f9f034f00e6115ff5df4138097890675f                    (23 bytes)
                      2021-08-03T09:30:19.722Z DRIVER   Dropping message because it could not be deserialized: The command class Secur
                      2021-08-03T09:30:19.723Z SERIAL » [ACK]        (0x06)
                      2021-08-03T09:30:20.569Z SERIAL « 0x0114000400100e9f035000f3634da0aaac816498e3d8                      (22 bytes)
                      2021-08-03T09:30:20.572Z DRIVER   Dropping message because it could not be deserialized: The command class Secur
                      2021-08-03T09:30:20.573Z SERIAL » [ACK]        (0x06)
                      pi@raspberrypi:/opt/iobroker/node_modules/iobroker.zwave2/build $
                      • AlCalzone
                        @rhartmann76 sagte in Z-wave2 mit iobroker verbinden (im Netzwerk):
                        Ja, aber damit der Adapter weiß, was die Dinger sind und können (außer dass sie existieren), muss er mal mit ihnen kommunizieren. Das geht nicht solange sie schlafen.
                        Und das ist das Problem:
                        Dropping message because it could not be deserialized: The command class Security 2 is not implemented
                        Die Geräte sind mit Security S2 verschlüsselt eingebunden, das kann der Adapter noch nicht. Ich bin in letzter Zeit ziemlich weit gekommen, fertig ist die Unterstützung hierfür aber noch nicht. Ich sehe 2 Optionen für dich:
                        1. Entweder du geduldest dich noch ein paar Wochen und gehst so lange zurück auf die Software, die du vorher genutzt hast.
                        2. Oder du setzt alle Geräte zurück und bindest sie über den Adapter nochmal ohne S2 ein.
                          rhartmann76 last edited by rhartmann76
                          @alcalzone Danke, alle geräte löschen und dann auf neu einbinden?
                            ich hatte nun alle Geräte (ausser PC Controller und Binary Power Switch) gelöscht und 3 von den Geräter zurückgesetzt. Leider findet er das Gerät dann aber nicht, obwohl es auf pairing ist.
                            Hilfe bitte
                              rhartmann76 @AlCalzone last edited by rhartmann76
                              @alcalzone ich glaube jetzt habe ich es. Die Base war zum anlernen etwas weit weg.
                               │ callback id:      119
        └─[VersionCCCommandClassGet]
        CC: Association
                              2021-08-03T12:29:05.463Z SERIAL « [ACK]        (0x06)
                              2021-08-03T12:29:05.467Z SERIAL « 0x0104011301e8                                                       (6 bytes)
                              2021-08-03T12:29:05.468Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:05.469Z DRIVER « [RES] [SendData]
        was sent: true
                              2021-08-03T12:29:05.481Z SERIAL « 0x01070013770000029e                                                 (9 bytes)
                              2021-08-03T12:29:05.482Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:05.483Z DRIVER « [REQ] [SendData]
        callback id:     119
        transmit status: OK
                              2021-08-03T12:29:05.496Z SERIAL « 0x010a000400210486148502c1                                          (12 bytes)
                              2021-08-03T12:29:05.497Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:05.498Z DRIVER « [Node 033] [REQ] [ApplicationCommand]
        └─[VersionCCCommandClassReport]
        CC:      Association
        version: 2
                              2021-08-03T12:29:05.501Z CNTRLR   [Node 033]   supports CC Association (0x85) in version 2
                              2021-08-03T12:29:05.502Z CNTRLR » [Node 033]   querying the CC version for Multi Channel Association...
                              2021-08-03T12:29:05.512Z SERIAL » 0x010a0013210386138e257882                                          (12 bytes)
                              2021-08-03T12:29:05.513Z DRIVER » [Node 033] [REQ] [SendData]
        │ callback id:      120
        CC: Multi Channel Association
                              2021-08-03T12:29:05.516Z SERIAL « [ACK]        (0x06)
                              2021-08-03T12:29:05.520Z SERIAL « 0x0104011301e8                                                       (6 bytes)
                              2021-08-03T12:29:05.521Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:05.522Z DRIVER « [RES] [SendData]
        was sent: true
                              2021-08-03T12:29:05.534Z SERIAL « 0x010700137800000291                                                 (9 bytes)
                              2021-08-03T12:29:05.535Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:05.536Z DRIVER « [REQ] [SendData]
        callback id:     120
        transmit status: OK
                              2021-08-03T12:29:05.549Z SERIAL « 0x010a000400210486148e03cb                                          (12 bytes)
                              2021-08-03T12:29:05.550Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:05.551Z DRIVER « [Node 033] [REQ] [ApplicationCommand]
        version: 3
                              2021-08-03T12:29:05.554Z CNTRLR   [Node 033]   supports CC Multi Channel Association (0x8e) in version 3
                              2021-08-03T12:29:05.555Z CNTRLR » [Node 033]   querying the CC version for Association Group Information...
                              2021-08-03T12:29:05.562Z SERIAL » 0x010a00132103861359257954                                          (12 bytes)
                              2021-08-03T12:29:05.563Z DRIVER » [Node 033] [REQ] [SendData]
        │ callback id:      121
        CC: Association Group Information
                              2021-08-03T12:29:05.565Z SERIAL « [ACK]        (0x06)
                              2021-08-03T12:29:05.569Z SERIAL « 0x0104011301e8                                                       (6 bytes)
                              2021-08-03T12:29:05.570Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:05.571Z DRIVER « [RES] [SendData]
        was sent: true
                              2021-08-03T12:29:05.584Z SERIAL « 0x010700137900000290                                                 (9 bytes)
                              2021-08-03T12:29:05.585Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:05.586Z DRIVER « [REQ] [SendData]
        callback id:     121
        transmit status: OK
                              2021-08-03T12:29:05.599Z SERIAL « 0x010a0004002104861459011e                                          (12 bytes)
                              2021-08-03T12:29:05.600Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:05.601Z DRIVER « [Node 033] [REQ] [ApplicationCommand]
        version: 1
                              2021-08-03T12:29:05.607Z CNTRLR   [Node 033]   supports CC Association Group Information (0x59) in version 1
                              2021-08-03T12:29:05.608Z CNTRLR   [Node 033]   skipping query for Transport Service (0x55) because max implement
        ed version is 0
                              2021-08-03T12:29:05.608Z CNTRLR » [Node 033]   querying the CC version for Manufacturer Specific...
                              2021-08-03T12:29:05.615Z SERIAL » 0x010a00132103861372257a7c                                          (12 bytes)
                              2021-08-03T12:29:05.616Z DRIVER » [Node 033] [REQ] [SendData]
        │ callback id:      122
        CC: Manufacturer Specific
                              2021-08-03T12:29:05.619Z SERIAL « [ACK]        (0x06)
                              2021-08-03T12:29:05.623Z SERIAL « 0x0104011301e8                                                       (6 bytes)
                              2021-08-03T12:29:05.624Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:05.625Z DRIVER « [RES] [SendData]
        was sent: true
                              2021-08-03T12:29:05.638Z SERIAL « 0x010700137a00000190                                                 (9 bytes)
                              2021-08-03T12:29:05.639Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:05.640Z DRIVER « [REQ] [SendData]
        callback id:     122
        transmit status: OK
                              2021-08-03T12:29:05.652Z SERIAL « 0x010a00040021048614720236                                          (12 bytes)
                              2021-08-03T12:29:05.653Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:05.654Z DRIVER « [Node 033] [REQ] [ApplicationCommand]
        version: 2
                              2021-08-03T12:29:05.658Z CNTRLR   [Node 033]   supports CC Manufacturer Specific (0x72) in version 2
                              2021-08-03T12:29:05.658Z CNTRLR   [Node 033]   skipping query for Device Reset Locally (0x5a) because max implem
        ented version is 1
                              2021-08-03T12:29:05.658Z CNTRLR   [Node 033]   skipping query for Powerlevel (0x73) because max implemented vers
        ion is 0
                              2021-08-03T12:29:05.658Z CNTRLR » [Node 033]   querying the CC version for Battery...
                              2021-08-03T12:29:05.669Z SERIAL » 0x010a00132103861380257b8f                                          (12 bytes)
                              2021-08-03T12:29:05.670Z DRIVER » [Node 033] [REQ] [SendData]
        │ callback id:      123
        CC: Battery
                              2021-08-03T12:29:05.672Z SERIAL « [ACK]        (0x06)
                              2021-08-03T12:29:05.677Z SERIAL « 0x0104011301e8                                                       (6 bytes)
                              2021-08-03T12:29:05.677Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:05.678Z DRIVER « [RES] [SendData]
        was sent: true
                              2021-08-03T12:29:05.691Z SERIAL « 0x010700137b00000292                                                 (9 bytes)
                              2021-08-03T12:29:05.692Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:05.694Z DRIVER « [REQ] [SendData]
        callback id:     123
        transmit status: OK
                              2021-08-03T12:29:05.706Z SERIAL « 0x010a000400210486148001c7                                          (12 bytes)
                              2021-08-03T12:29:05.707Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:05.709Z DRIVER « [Node 033] [REQ] [ApplicationCommand]
        CC:      Battery
        version: 1
                              2021-08-03T12:29:05.712Z CNTRLR   [Node 033]   supports CC Battery (0x80) in version 1
                              2021-08-03T12:29:05.713Z CNTRLR   [Node 033]   skipping query for Security 2 (0x9f) because max implemented vers
        ion is 0
                              2021-08-03T12:29:05.713Z CNTRLR » [Node 033]   querying the CC version for Notification...
                              2021-08-03T12:29:05.722Z SERIAL » 0x010a00132103861371257c79                                          (12 bytes)
                              2021-08-03T12:29:05.723Z DRIVER » [Node 033] [REQ] [SendData]
        │ callback id:      124
        CC: Notification
                              2021-08-03T12:29:05.726Z SERIAL « [ACK]        (0x06)
                              2021-08-03T12:29:05.730Z SERIAL « 0x0104011301e8                                                       (6 bytes)
                              2021-08-03T12:29:05.731Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:05.732Z DRIVER « [RES] [SendData]
        was sent: true
                              2021-08-03T12:29:05.748Z SERIAL « 0x010700137c00000295                                                 (9 bytes)
                              2021-08-03T12:29:05.754Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:05.755Z DRIVER « [REQ] [SendData]
        callback id:     124
        transmit status: OK
                              2021-08-03T12:29:05.760Z SERIAL « 0x010a0004002104861471083f                                          (12 bytes)
                              2021-08-03T12:29:05.761Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:05.763Z DRIVER « [Node 033] [REQ] [ApplicationCommand]
        CC:      Notification
        version: 8
                              2021-08-03T12:29:05.766Z CNTRLR   [Node 033]   supports CC Notification (0x71) in version 8
                              2021-08-03T12:29:05.767Z CNTRLR » [Node 033]   querying the CC version for Wake Up...
                              2021-08-03T12:29:05.776Z SERIAL » 0x010a00132103861384257d8d                                          (12 bytes)
                              2021-08-03T12:29:05.777Z DRIVER » [Node 033] [REQ] [SendData]
        │ callback id:      125
        CC: Wake Up
                              2021-08-03T12:29:05.780Z SERIAL « [ACK]        (0x06)
                              2021-08-03T12:29:05.784Z SERIAL « 0x0104011301e8                                                       (6 bytes)
                              2021-08-03T12:29:05.785Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:05.786Z DRIVER « [RES] [SendData]
        was sent: true
                              2021-08-03T12:29:05.799Z SERIAL « 0x010700137d00000294                                                 (9 bytes)
                              2021-08-03T12:29:05.800Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:05.801Z DRIVER « [REQ] [SendData]
        callback id:     125
        transmit status: OK
                              2021-08-03T12:29:05.813Z SERIAL « 0x010a000400210486148402c0                                          (12 bytes)
                              2021-08-03T12:29:05.814Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:05.815Z DRIVER « [Node 033] [REQ] [ApplicationCommand]
        CC:      Wake Up
        version: 2
                              2021-08-03T12:29:05.822Z CNTRLR   [Node 033]   supports CC Wake Up (0x84) in version 2
                              2021-08-03T12:29:05.822Z CNTRLR   [Node 033]   skipping query for Supervision (0x6c) because max implemented ver
        sion is 1
                              2021-08-03T12:29:05.822Z CNTRLR » [Node 033] querying if Z-Wave Software Get is supported...
                              2021-08-03T12:29:05.830Z SERIAL » 0x0109001321028615257e0e                                            (11 bytes)
                              2021-08-03T12:29:05.831Z DRIVER » [Node 033] [REQ] [SendData]
        │ callback id:      126
        └─[VersionCCCapabilitiesGet]
                              2021-08-03T12:29:05.833Z SERIAL « [ACK]        (0x06)
                              2021-08-03T12:29:05.837Z SERIAL « 0x0104011301e8                                                       (6 bytes)
                              2021-08-03T12:29:05.838Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:05.839Z DRIVER « [RES] [SendData]
        was sent: true
                              2021-08-03T12:29:05.852Z SERIAL « 0x010700137e00000297                                                 (9 bytes)
                              2021-08-03T12:29:05.853Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:05.854Z DRIVER « [REQ] [SendData]
        callback id:     126
        transmit status: OK
                              2021-08-03T12:29:05.866Z SERIAL « 0x0109000400210386160747                                            (11 bytes)
                              2021-08-03T12:29:05.868Z CNTRLR   [Node 033] [+] [Version] supportsZWaveSoftwareGet: tru [Endpoint 0] [internal]
        e
                              2021-08-03T12:29:05.869Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:05.870Z DRIVER « [Node 033] [REQ] [ApplicationCommand]
        └─[VersionCCCapabilitiesReport]
        supports Z-Wave Software Get command: true
                              2021-08-03T12:29:05.874Z CNTRLR « [Node 033] Z-Wave Software Get is supported
                              2021-08-03T12:29:05.874Z CNTRLR » [Node 033] querying Z-Wave software versions...
                              2021-08-03T12:29:05.882Z SERIAL » 0x0109001321028617257f0d                                            (11 bytes)
                              2021-08-03T12:29:05.882Z DRIVER » [Node 033] [REQ] [SendData]
        │ callback id:      127
        └─[VersionCCZWaveSoftwareGet]
                              2021-08-03T12:29:05.888Z SERIAL « [ACK]        (0x06)
                              2021-08-03T12:29:05.891Z SERIAL « 0x0104011301e8                                                       (6 bytes)
                              2021-08-03T12:29:05.892Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:05.893Z DRIVER « [RES] [SendData]
        was sent: true
                              2021-08-03T12:29:05.904Z SERIAL « 0x010700137f00000296                                                 (9 bytes)
                              2021-08-03T12:29:05.905Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:05.906Z DRIVER « [REQ] [SendData]
        callback id:     127
        transmit status: OK
                              2021-08-03T12:29:05.923Z SERIAL « 0x011f00040021198618064703030101ccdd0000000000050300002b030101ccdd2 (33 bytes)
        d
                              2021-08-03T12:29:05.925Z CNTRLR   [Node 033] [+] [Version] sdkVersion: "6.71.3"                     [Endpoint 0]
                              2021-08-03T12:29:05.926Z CNTRLR   [Node 033] [+] [Version] applicationFrameworkAPIVersion: "3.1.1"  [Endpoint 0]
                              2021-08-03T12:29:05.928Z CNTRLR   [Node 033] [+] [Version] applicationFrameworkBuildNumber: 52445   [Endpoint 0]
                              2021-08-03T12:29:05.929Z CNTRLR   [Node 033] [+] [Version] hostInterfaceVersion: "unused"           [Endpoint 0]
                              2021-08-03T12:29:05.931Z CNTRLR   [Node 033] [+] [Version] hostInterfaceBuildNumber: 0              [Endpoint 0]
                              2021-08-03T12:29:05.932Z CNTRLR   [Node 033] [+] [Version] zWaveProtocolVersion: "5.3.0"            [Endpoint 0]
                              2021-08-03T12:29:05.933Z CNTRLR   [Node 033] [+] [Version] zWaveProtocolBuildNumber: 43             [Endpoint 0]
                              2021-08-03T12:29:05.935Z CNTRLR   [Node 033] [+] [Version] applicationVersion: "3.1.1"              [Endpoint 0]
                              2021-08-03T12:29:05.936Z CNTRLR   [Node 033] [+] [Version] applicationBuildNumber: 52445            [Endpoint 0]
                              2021-08-03T12:29:05.937Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:05.941Z DRIVER « [Node 033] [REQ] [ApplicationCommand]
        └─[VersionCCZWaveSoftwareReport]
        SDK version:                  6.71.3
        appl. framework API version:  3.1.1
        appl. framework build number: 52445
        host interface version:       unused
        Z-Wave protocol version:      5.3.0
        Z-Wave protocol build number: 43
        application version:          3.1.1
        application build number:     52445
                              2021-08-03T12:29:05.944Z CNTRLR « [Node 033] received Z-Wave software versions
                              2021-08-03T12:29:05.945Z CNTRLR   [Node 033] [+] [Version] interviewComplete: true       [Endpoint 0] [internal]
                              2021-08-03T12:29:06.007Z CNTRLR   [Node 033] Embedded device config loaded
                              2021-08-03T12:29:06.010Z CNTRLR   [Node 033] Interviewing Z-Wave Plus Info...
                              2021-08-03T12:29:06.011Z CNTRLR » [Node 033] querying Z-Wave+ information...
                              2021-08-03T12:29:06.019Z SERIAL » 0x0109001321025e0125803c                                            (11 bytes)
                              2021-08-03T12:29:06.020Z DRIVER » [Node 033] [REQ] [SendData]
        │ callback id:      128
        └─[ZWavePlusCCGet]
                              2021-08-03T12:29:06.028Z SERIAL « [ACK]        (0x06)
                              2021-08-03T12:29:06.033Z SERIAL « 0x0104011301e8                                                       (6 bytes)
                              2021-08-03T12:29:06.034Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:06.038Z DRIVER « [RES] [SendData]
        was sent: true
                              2021-08-03T12:29:06.046Z SERIAL « 0x010700138000000269                                                 (9 bytes)
                              2021-08-03T12:29:06.047Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:06.048Z DRIVER « [REQ] [SendData]
        callback id:     128
        transmit status: OK
                              2021-08-03T12:29:06.057Z SERIAL « 0x010f00040021095e020106000c010c0187                                (17 bytes)
                              2021-08-03T12:29:06.059Z CNTRLR   [Node 033] [+] [Z-Wave Plus Info] zwavePlusVersion: 1  [Endpoint 0] [internal]
                              2021-08-03T12:29:06.060Z CNTRLR   [Node 033] [+] [Z-Wave Plus Info] nodeType: 0          [Endpoint 0] [internal]
                              2021-08-03T12:29:06.061Z CNTRLR   [Node 033] [+] [Z-Wave Plus Info] roleType: 6          [Endpoint 0] [internal]
                              2021-08-03T12:29:06.061Z CNTRLR   [Node 033] [+] [Z-Wave Plus Info] installerIcon: 3073  [Endpoint 0] [internal]
                              2021-08-03T12:29:06.062Z CNTRLR   [Node 033] [+] [Z-Wave Plus Info] userIcon: 3073       [Endpoint 0] [internal]
                              2021-08-03T12:29:06.062Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:06.064Z DRIVER « [Node 033] [REQ] [ApplicationCommand]
        └─[ZWavePlusCCReport]
        version:      1
        node type:    Node
        role type:    SleepingReportingSlave
        icon (mgmt.): 0x0c01
        icon (user):  0x0c01
                              2021-08-03T12:29:06.071Z CNTRLR « [Node 033] received response for Z-Wave+ information:
        Z-Wave+ version: 1
        node type:       Node
        installer icon:  0x0c01
        user icon:       0x0c01
                              2021-08-03T12:29:06.072Z CNTRLR   [Node 033] [+] [Z-Wave Plus Info] interviewComplete: t [Endpoint 0] [internal]
        rue
                              2021-08-03T12:29:06.073Z CNTRLR   [Node 033] Interviewing Battery...
                              2021-08-03T12:29:06.073Z CNTRLR » [Node 033] querying battery status...
                              2021-08-03T12:29:06.080Z SERIAL » 0x01090013210280022581e0                                            (11 bytes)
                              2021-08-03T12:29:06.081Z DRIVER » [Node 033] [REQ] [SendData]
        │ callback id:      129
        └─[BatteryCCGet]
                              2021-08-03T12:29:06.084Z SERIAL « [ACK]        (0x06)
                              2021-08-03T12:29:06.088Z SERIAL « 0x0104011301e8                                                       (6 bytes)
                              2021-08-03T12:29:06.089Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:06.090Z DRIVER « [RES] [SendData]
        was sent: true
                              2021-08-03T12:29:06.103Z SERIAL « 0x010700138100000268                                                 (9 bytes)
                              2021-08-03T12:29:06.104Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:06.105Z DRIVER « [REQ] [SendData]
        callback id:     129
        transmit status: OK
                              2021-08-03T12:29:06.117Z SERIAL « 0x0109000400210380036437                                            (11 bytes)
                              2021-08-03T12:29:06.119Z CNTRLR   [Node 033] [+] [Battery] level: 100                               [Endpoint 0]
                              2021-08-03T12:29:06.125Z CNTRLR   [Node 033] [+] [Battery] isLow: false                             [Endpoint 0]
                              2021-08-03T12:29:06.126Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:06.129Z DRIVER « [Node 033] [REQ] [ApplicationCommand]
        └─[BatteryCCReport]
        level:  100
        is low: false
                              2021-08-03T12:29:06.133Z CNTRLR « [Node 033] received response for battery information:
        level:                           100
                              2021-08-03T12:29:06.134Z CNTRLR   [Node 033] [+] [Battery] interviewComplete: true       [Endpoint 0] [internal]
                              2021-08-03T12:29:06.149Z CNTRLR   [Node 033] Interviewing Association...
                              2021-08-03T12:29:06.150Z CNTRLR » [Node 033] querying number of association groups...
                              2021-08-03T12:29:06.158Z SERIAL » 0x01090013210285052582e1                                            (11 bytes)
                              2021-08-03T12:29:06.159Z DRIVER » [Node 033] [REQ] [SendData]
        │ callback id:      130
        └─[AssociationCCSupportedGroupingsGet]
                              2021-08-03T12:29:06.163Z SERIAL « [ACK]        (0x06)
                              2021-08-03T12:29:06.166Z SERIAL « 0x0104011301e8                                                       (6 bytes)
                              2021-08-03T12:29:06.167Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:06.168Z DRIVER « [RES] [SendData]
        was sent: true
                              2021-08-03T12:29:06.180Z SERIAL « 0x01070013820000026b                                                 (9 bytes)
                              2021-08-03T12:29:06.181Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:06.182Z DRIVER « [REQ] [SendData]
        callback id:     130
        transmit status: OK
                              2021-08-03T12:29:06.194Z SERIAL « 0x0109000400210385060251                                            (11 bytes)
                              2021-08-03T12:29:06.196Z CNTRLR   [Node 033] [+] [Association] groupCount: 2             [Endpoint 0] [internal]
                              2021-08-03T12:29:06.197Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:06.198Z DRIVER « [Node 033] [REQ] [ApplicationCommand]
        └─[AssociationCCSupportedGroupingsReport]
        group count: 2
                              2021-08-03T12:29:06.202Z CNTRLR « [Node 033] supports 2 association groups
                              2021-08-03T12:29:06.202Z CNTRLR   [Node 033] AssociationCC: skipping remaining interview because Multi Channel A
        ssociation is supported...
                              2021-08-03T12:29:06.203Z CNTRLR   [Node 033] [+] [Association] interviewComplete: true   [Endpoint 0] [internal]
                              2021-08-03T12:29:06.204Z CNTRLR   [Node 033] Interviewing Multi Channel Association...
                              2021-08-03T12:29:06.204Z CNTRLR » [Node 033] querying number of multi channel association groups...
                              2021-08-03T12:29:06.216Z SERIAL » 0x0109001321028e052583eb                                            (11 bytes)
                              2021-08-03T12:29:06.217Z DRIVER » [Node 033] [REQ] [SendData]
        │ callback id:      131
        └─[MultiChannelAssociationCCSupportedGroupingsGet]
                              2021-08-03T12:29:06.220Z SERIAL « [ACK]        (0x06)
                              2021-08-03T12:29:06.224Z SERIAL « 0x0104011301e8                                                       (6 bytes)
                              2021-08-03T12:29:06.225Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:06.226Z DRIVER « [RES] [SendData]
        was sent: true
                              2021-08-03T12:29:06.239Z SERIAL « 0x010700138300000169                                                 (9 bytes)
                              2021-08-03T12:29:06.240Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:06.241Z DRIVER « [REQ] [SendData]
        callback id:     131
        transmit status: OK
                              2021-08-03T12:29:06.253Z SERIAL « 0x010900040021038e06025a                                            (11 bytes)
                              2021-08-03T12:29:06.255Z CNTRLR   [Node 033] [+] [Multi Channel Association] groupCount: [Endpoint 0] [internal]
                              2021-08-03T12:29:06.255Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:06.256Z DRIVER « [Node 033] [REQ] [ApplicationCommand]
        └─[MultiChannelAssociationCCSupportedGroupingsReport]
        group count: 2
                              2021-08-03T12:29:06.260Z CNTRLR « [Node 033] supports 2 multi channel association groups
                              2021-08-03T12:29:06.260Z CNTRLR » [Node 033] querying multi channel association group #1...
                              2021-08-03T12:29:06.268Z SERIAL » 0x010a001321038e02012584e8                                          (12 bytes)
                              2021-08-03T12:29:06.269Z DRIVER » [Node 033] [REQ] [SendData]
        │ callback id:      132
        └─[MultiChannelAssociationCCGet]
        group id: 1
                              2021-08-03T12:29:06.271Z SERIAL « [ACK]        (0x06)
                              2021-08-03T12:29:06.276Z SERIAL « 0x0104011301e8                                                       (6 bytes)
                              2021-08-03T12:29:06.277Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:06.282Z DRIVER « [RES] [SendData]
        was sent: true
                              2021-08-03T12:29:06.291Z SERIAL « 0x01070013840000026d                                                 (9 bytes)
                              2021-08-03T12:29:06.292Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:06.293Z DRIVER « [REQ] [SendData]
        callback id:     132
        transmit status: OK
                              2021-08-03T12:29:06.309Z SERIAL « 0x010c00040021068e030105000158                                      (14 bytes)
                              2021-08-03T12:29:06.311Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:06.312Z CNTRLR   [Node 033] [+] [Multi Channel Association] maxNodes[1] [Endpoint 0] [internal]
        : 5
                              2021-08-03T12:29:06.313Z CNTRLR   [Node 033] [+] [Multi Channel Association] nodeIds[1]: [Endpoint 0] [internal]
                              2021-08-03T12:29:06.314Z CNTRLR   [Node 033] [+] [Multi Channel Association] endpoints[1 [Endpoint 0] [internal]
                              2021-08-03T12:29:06.315Z DRIVER « [Node 033] [REQ] [ApplicationCommand]
        └─[MultiChannelAssociationCCReport]
        group id:           1
        maximum # of nodes: 5
        node ids:           1
        endpoints:
                              2021-08-03T12:29:06.318Z CNTRLR « [Node 033] received information for multi channel association group #1:
        currently assigned nodes:     1
        currently assigned endpoints:
                              2021-08-03T12:29:06.318Z CNTRLR » [Node 033] querying multi channel association group #2...
                              2021-08-03T12:29:06.326Z SERIAL » 0x010a001321038e02022585ea                                          (12 bytes)
                              2021-08-03T12:29:06.326Z DRIVER » [Node 033] [REQ] [SendData]
        │ callback id:      133
        group id: 2
                              2021-08-03T12:29:06.329Z SERIAL « [ACK]        (0x06)
                              2021-08-03T12:29:06.333Z SERIAL « 0x0104011301e8                                                       (6 bytes)
                              2021-08-03T12:29:06.334Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:06.335Z DRIVER « [RES] [SendData]
        was sent: true
                              2021-08-03T12:29:06.348Z SERIAL « 0x01070013850000016f                                                 (9 bytes)
                              2021-08-03T12:29:06.349Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:06.357Z DRIVER « [REQ] [SendData]
        callback id:     133
        transmit status: OK
                              2021-08-03T12:29:06.363Z SERIAL « 0x010b00040021058e030205005e                                        (13 bytes)
                              2021-08-03T12:29:06.364Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:06.366Z CNTRLR   [Node 033] [+] [Multi Channel Association] maxNodes[2] [Endpoint 0] [internal]
        : 5
                              2021-08-03T12:29:06.367Z CNTRLR   [Node 033] [+] [Multi Channel Association] nodeIds[2]: [Endpoint 0] [internal]
                              2021-08-03T12:29:06.367Z CNTRLR   [Node 033] [+] [Multi Channel Association] endpoints[2 [Endpoint 0] [internal]
                              2021-08-03T12:29:06.368Z DRIVER « [Node 033] [REQ] [ApplicationCommand]
        group id:           2
        node ids:
        endpoints:
                              2021-08-03T12:29:06.371Z CNTRLR « [Node 033] received information for multi channel association group #2:
                              2021-08-03T12:29:06.372Z CNTRLR   [Node 033] [+] [Association] hasLifeline: true         [Endpoint 0] [internal]
                              2021-08-03T12:29:06.373Z CNTRLR   [Node 033] [+] [Multi Channel Association] interviewCo [Endpoint 0] [internal]
        mplete: true
                              2021-08-03T12:29:06.373Z CNTRLR   [Node 033] Interviewing Association Group Information...
                              2021-08-03T12:29:06.374Z CNTRLR » [Node 033] Association group #1: Querying name...
                              2021-08-03T12:29:06.390Z SERIAL » 0x010a0013210359010125863e                                          (12 bytes)
                              2021-08-03T12:29:06.391Z DRIVER » [Node 033] [REQ] [SendData]
        │ transmit options: 0x25
        │ callback id:      134
        └─[AssociationGroupInfoCCNameGet]
        group id: 1
                              2021-08-03T12:29:06.394Z SERIAL « [ACK]        (0x06)
                              2021-08-03T12:29:06.398Z SERIAL « 0x0104011301e8                                                       (6 bytes)
                              2021-08-03T12:29:06.398Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:06.400Z DRIVER « [RES] [SendData]
        was sent: true
                              2021-08-03T12:29:06.413Z SERIAL « 0x01070013860000026f                                                 (9 bytes)
                              2021-08-03T12:29:06.413Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:06.415Z DRIVER « [REQ] [SendData]
        callback id:     134
        transmit status: OK
                              2021-08-03T12:29:06.429Z SERIAL « 0x0112000400210c590201084c6966656c696e65be                          (20 bytes)
                              2021-08-03T12:29:06.431Z CNTRLR   [Node 033] [+] [Association Group Information] name[1] [Endpoint 0] [internal]
        : "Lifeline"
                              2021-08-03T12:29:06.435Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:06.437Z DRIVER « [Node 033] [REQ] [ApplicationCommand]
        └─[AssociationGroupInfoCCNameReport]
        group id: 1
                              2021-08-03T12:29:06.441Z CNTRLR « [Node 033] Association group #1 has name "Lifeline"
                              2021-08-03T12:29:06.441Z CNTRLR » [Node 033] Association group #1: Querying command list...
                              2021-08-03T12:29:06.450Z SERIAL » 0x010b00132104590580012587bd                                        (13 bytes)
                              2021-08-03T12:29:06.451Z DRIVER » [Node 033] [REQ] [SendData]
        │ callback id:      135
        └─[AssociationGroupInfoCCCommandListGet]
        group id:    1
        allow cache: true
                              2021-08-03T12:29:06.454Z SERIAL « [ACK]        (0x06)
                              2021-08-03T12:29:06.458Z SERIAL « 0x0104011301e8                                                       (6 bytes)
                              2021-08-03T12:29:06.459Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:06.460Z DRIVER « [RES] [SendData]
        was sent: true
                              2021-08-03T12:29:06.473Z SERIAL « 0x01070013870000026e                                                 (9 bytes)
                              2021-08-03T12:29:06.474Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:06.475Z DRIVER « [REQ] [SendData]
        callback id:     135
        transmit status: OK
                              2021-08-03T12:29:06.489Z SERIAL « 0x0110000400210a59060106800371055a0134                              (18 bytes)
                              2021-08-03T12:29:06.491Z CNTRLR   [Node 033] [+] [Association Group Information] issuedC [Endpoint 0] [internal]
        ommands[1]: [object Map]
                              2021-08-03T12:29:06.491Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:06.493Z DRIVER « [Node 033] [REQ] [ApplicationCommand]
        └─[AssociationGroupInfoCCCommandListReport]
        group id: 1
        commands:
        · Battery: 0x03
        · Notification: 0x05
        · Device Reset Locally: 0x01
                              2021-08-03T12:29:06.496Z CNTRLR » [Node 033] Association group #2: Querying name...
                              2021-08-03T12:29:06.503Z SERIAL » 0x010a00132103590102258833                                          (12 bytes)
                              2021-08-03T12:29:06.512Z DRIVER » [Node 033] [REQ] [SendData]
        │ callback id:      136
        group id: 2
                              2021-08-03T12:29:06.515Z SERIAL « [ACK]        (0x06)
                              2021-08-03T12:29:06.519Z SERIAL « 0x0104011301e8                                                       (6 bytes)
                              2021-08-03T12:29:06.520Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:06.521Z DRIVER « [RES] [SendData]
        was sent: true
                              2021-08-03T12:29:06.536Z SERIAL « 0x010700138800000261                                                 (9 bytes)
                              2021-08-03T12:29:06.537Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:06.538Z DRIVER « [REQ] [SendData]
        callback id:     136
        transmit status: OK
                              2021-08-03T12:29:06.551Z SERIAL « 0x0113000400210d590202094261736963207365748c                        (21 bytes)
                              2021-08-03T12:29:06.552Z CNTRLR   [Node 033] [+] [Association Group Information] name[2] [Endpoint 0] [internal]
        : "Basic set"
                              2021-08-03T12:29:06.553Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:06.554Z DRIVER « [Node 033] [REQ] [ApplicationCommand]
        group id: 2
                              2021-08-03T12:29:06.558Z CNTRLR « [Node 033] Association group #2 has name "Basic set"
                              2021-08-03T12:29:06.558Z CNTRLR » [Node 033] Association group #2: Querying command list...
                              2021-08-03T12:29:06.566Z SERIAL » 0x010b00132104590580022589b0                                        (13 bytes)
                              2021-08-03T12:29:06.567Z DRIVER » [Node 033] [REQ] [SendData]
        │ callback id:      137
        group id:    2
        allow cache: true
                              2021-08-03T12:29:06.570Z SERIAL « [ACK]        (0x06)
                              2021-08-03T12:29:06.574Z SERIAL « 0x0104011301e8                                                       (6 bytes)
                              2021-08-03T12:29:06.576Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:06.577Z DRIVER « [RES] [SendData]
        was sent: true
                              2021-08-03T12:29:06.590Z SERIAL « 0x010700138900000260                                                 (9 bytes)
                              2021-08-03T12:29:06.591Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:06.592Z DRIVER « [REQ] [SendData]
        callback id:     137
        transmit status: OK
                              2021-08-03T12:29:06.604Z SERIAL « 0x010c0004002106590602022001ae                                      (14 bytes)
                              2021-08-03T12:29:06.606Z CNTRLR   [Node 033] [+] [Association Group Information] issuedC [Endpoint 0] [internal]
        ommands[2]: [object Map]
                              2021-08-03T12:29:06.606Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:06.608Z DRIVER « [Node 033] [REQ] [ApplicationCommand]
        group id: 2
        commands:
        · Basic: 0x01
                              2021-08-03T12:29:06.611Z CNTRLR » [Node 033] Association group #1: Querying info...
                              2021-08-03T12:29:06.619Z SERIAL » 0x010b0013210459030001258a36                                        (13 bytes)
                              2021-08-03T12:29:06.620Z DRIVER » [Node 033] [REQ] [SendData]
        │ callback id:      138
        └─[AssociationGroupInfoCCInfoGet]
        group id:      1
        refresh cache: false
                              2021-08-03T12:29:06.622Z SERIAL « [ACK]        (0x06)
                              2021-08-03T12:29:06.627Z SERIAL « 0x0104011301e8                                                       (6 bytes)
                              2021-08-03T12:29:06.628Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:06.629Z DRIVER « [RES] [SendData]
        was sent: true
                              2021-08-03T12:29:06.642Z SERIAL « 0x010700138a00000263                                                 (9 bytes)
                              2021-08-03T12:29:06.642Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:06.643Z DRIVER « [REQ] [SendData]
        callback id:     138
        transmit status: OK
                              2021-08-03T12:29:06.657Z SERIAL « 0x0110000400210a590401010000010000009c                              (18 bytes)
                              2021-08-03T12:29:06.659Z CNTRLR   [Node 033] [+] [Association Group Information] hasDyna [Endpoint 0] [internal]
        micInfo: false
                              2021-08-03T12:29:06.660Z CNTRLR   [Node 033] [+] [Association Group Information] info[1] [Endpoint 0] [internal]
        : {"mode":0,"profile":1,"eventCode":0}
                              2021-08-03T12:29:06.660Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:06.662Z DRIVER « [Node 033] [REQ] [ApplicationCommand]
        └─[AssociationGroupInfoCCInfoReport]
        is list mode:     false
        has dynamic info: false
        groups:
        · Group #1
        mode:       0
        profile:    1
        event code: 0
                              2021-08-03T12:29:06.665Z CNTRLR « [Node 033] Received info for association group #1:
        info is dynamic: false
        profile:         General: Lifeline
                              2021-08-03T12:29:06.665Z CNTRLR » [Node 033] Association group #2: Querying info...
                              2021-08-03T12:29:06.673Z SERIAL » 0x010b0013210459030002258b34                                        (13 bytes)
                              2021-08-03T12:29:06.674Z DRIVER » [Node 033] [REQ] [SendData]
        │ callback id:      139
        group id:      2
                              2021-08-03T12:29:06.676Z SERIAL « [ACK]        (0x06)
                              2021-08-03T12:29:06.680Z SERIAL « 0x0104011301e8                                                       (6 bytes)
                              2021-08-03T12:29:06.681Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:06.682Z DRIVER « [RES] [SendData]
        was sent: true
                              2021-08-03T12:29:06.695Z SERIAL « 0x010700138b00000262                                                 (9 bytes)
                              2021-08-03T12:29:06.696Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:06.697Z DRIVER « [REQ] [SendData]
        callback id:     139
        transmit status: OK
                              2021-08-03T12:29:06.711Z SERIAL « 0x0110000400210a59040102007101000000ee                              (18 bytes)
                              2021-08-03T12:29:06.712Z CNTRLR   [Node 033] [~] [Association Group Information] hasDyna [Endpoint 0] [internal]
        micInfo: false => false
                              2021-08-03T12:29:06.713Z CNTRLR   [Node 033] [+] [Association Group Information] info[2] [Endpoint 0] [internal]
        : {"mode":0,"profile":28929,"eventCode":0}
                              2021-08-03T12:29:06.714Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:06.715Z DRIVER « [Node 033] [REQ] [ApplicationCommand]
        is list mode:     false
        groups:
        · Group #2
        mode:       0
        profile:    28929
        event code: 0
                              2021-08-03T12:29:06.718Z CNTRLR « [Node 033] Received info for association group #2:
        profile:         Notification: Smoke Alarm
                              2021-08-03T12:29:06.719Z CNTRLR   [Node 033] [+] [Association Group Information] intervi [Endpoint 0] [internal]
        ewComplete: true
                              2021-08-03T12:29:06.730Z CNTRLR   [Node 033] Interviewing Notification...
                              2021-08-03T12:29:06.730Z CNTRLR » [Node 033] querying supported notification types...
                              2021-08-03T12:29:06.738Z SERIAL » 0x0109001321027107258c19                                            (11 bytes)
                              2021-08-03T12:29:06.739Z DRIVER » [Node 033] [REQ] [SendData]
        │ callback id:      140
        └─[NotificationCCSupportedGet]
                              2021-08-03T12:29:06.741Z SERIAL « [ACK]        (0x06)
                              2021-08-03T12:29:06.745Z SERIAL « 0x0104011301e8                                                       (6 bytes)
                              2021-08-03T12:29:06.746Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:06.747Z DRIVER « [RES] [SendData]
        was sent: true
                              2021-08-03T12:29:06.760Z SERIAL « 0x010700138c00000265                                                 (9 bytes)
                              2021-08-03T12:29:06.761Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:06.762Z DRIVER « [REQ] [SendData]
        callback id:     140
        transmit status: OK
                              2021-08-03T12:29:06.775Z SERIAL « 0x010a000400210471080102ae                                          (12 bytes)
                              2021-08-03T12:29:06.776Z CNTRLR   [Node 033] [+] [Notification] supportedNotificationTyp [Endpoint 0] [internal]
        es: 1
                              2021-08-03T12:29:06.777Z CNTRLR   [Node 033] [+] [Notification] supportsV1Alarm: false   [Endpoint 0] [internal]
                              2021-08-03T12:29:06.778Z CNTRLR   [Node 033] [~] [Notification] supportedNotificationTyp [Endpoint 0] [internal]
        es: 1 => 1
                              2021-08-03T12:29:06.778Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:06.780Z DRIVER « [Node 033] [REQ] [ApplicationCommand]
        └─[NotificationCCSupportedReport]
        supports V1 alarm:            false
        supported notification types:
        · Smoke Alarm
                              2021-08-03T12:29:06.787Z CNTRLR « [Node 033] received supported notification types:
        · Smoke Alarm
                              2021-08-03T12:29:06.788Z CNTRLR » [Node 033] querying supported notification events for Smoke Alarm...
                              2021-08-03T12:29:06.795Z SERIAL » 0x010a00132103710101258d1d                                          (12 bytes)
                              2021-08-03T12:29:06.796Z DRIVER » [Node 033] [REQ] [SendData]
        │ callback id:      141
        └─[NotificationCCEventSupportedGet]
        notification type: Smoke Alarm
                              2021-08-03T12:29:06.799Z SERIAL « [ACK]        (0x06)
                              2021-08-03T12:29:06.803Z SERIAL « 0x0104011301e8                                                       (6 bytes)
                              2021-08-03T12:29:06.804Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:06.805Z DRIVER « [RES] [SendData]
        was sent: true
                              2021-08-03T12:29:06.818Z SERIAL « 0x010700138d00000167                                                 (9 bytes)
                              2021-08-03T12:29:06.819Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:06.820Z DRIVER « [REQ] [SendData]
        callback id:     141
        transmit status: OK
                              2021-08-03T12:29:06.833Z SERIAL « 0x010b00040021057102010104a3                                        (13 bytes)
                              2021-08-03T12:29:06.835Z CNTRLR   [Node 033] [+] [Notification] supportedNotificationEvents[1]: 2     [internal]
                              2021-08-03T12:29:06.836Z CNTRLR   [Node 033] [Notification] Smoke Alarm[Sensor status]: metadata up [Endpoint 0]
        dated
                              2021-08-03T12:29:06.838Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:06.839Z DRIVER « [Node 033] [REQ] [ApplicationCommand]
        └─[NotificationCCEventSupportedReport]
        supported events:
        · Smoke detected
                              2021-08-03T12:29:06.843Z CNTRLR « [Node 033] received supported notification events for Smoke Alarm: 2
                              2021-08-03T12:29:06.844Z CNTRLR   [Node 033] [+] [Notification] notificationMode: "push"              [internal]
                              2021-08-03T12:29:06.845Z CNTRLR » [Node 033] enabling notifications for Smoke Alarm...
                              2021-08-03T12:29:06.852Z SERIAL » 0x010b00132104710601ff258ee0                                        (13 bytes)
                              2021-08-03T12:29:06.853Z DRIVER » [Node 033] [REQ] [SendData]
        │ callback id:      142
        └─[NotificationCCSet]
        status:            true
                              2021-08-03T12:29:06.856Z SERIAL « [ACK]        (0x06)
                              2021-08-03T12:29:06.861Z SERIAL « 0x0104011301e8                                                       (6 bytes)
                              2021-08-03T12:29:06.862Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:06.863Z DRIVER « [RES] [SendData]
        was sent: true
                              2021-08-03T12:29:06.875Z SERIAL « 0x010700138e00000267                                                 (9 bytes)
                              2021-08-03T12:29:06.876Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:06.877Z DRIVER « [REQ] [SendData]
        callback id:     142
        transmit status: OK
                              2021-08-03T12:29:06.882Z CNTRLR   [Node 033] [+] [Notification] Smoke Alarm[Sensor status]: 0       [Endpoint 0]
                              2021-08-03T12:29:06.883Z CNTRLR   [Node 033] [+] [Notification] interviewComplete: true  [Endpoint 0] [internal]
                              2021-08-03T12:29:06.895Z CNTRLR   [Node 033] Interview stage completed: CommandClasses
                              2021-08-03T12:29:06.895Z CNTRLR   [Node 033] Interview stage completed: OverwriteConfig
                              2021-08-03T12:29:06.896Z CNTRLR » [Node 033] requesting node neighbors...
                              2021-08-03T12:29:06.909Z SERIAL » 0x010700802100000059                                                 (9 bytes)
                              2021-08-03T12:29:06.909Z DRIVER » [REQ] [GetRoutingInfo]
        remove non-repeaters: false
        remove bad links:     false
                              2021-08-03T12:29:06.913Z SERIAL « [ACK]        (0x06)
                              2021-08-03T12:29:06.915Z SERIAL « 0x01200180000000000000000000000000000000000000000000000000000000000 (34 bytes)
        05e
                              2021-08-03T12:29:06.917Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:06.918Z DRIVER « [RES] [GetRoutingInfo]
        node ids:
                              2021-08-03T12:29:06.922Z CNTRLR « [Node 033] node neighbors received:
                              2021-08-03T12:29:06.922Z CNTRLR   [Node 033] Interview stage completed: Neighbors
                              2021-08-03T12:29:06.923Z CNTRLR   [Node 033] Interview completed
                              2021-08-03T12:29:06.923Z CNTRLR   [Node 033] The node is ready to be used
                              2021-08-03T12:29:07.925Z CNTRLR » [Node 033] Sending node back to sleep...
                              2021-08-03T12:29:07.938Z SERIAL » 0x0109001321028408258fe0                                            (11 bytes)
                              2021-08-03T12:29:07.940Z DRIVER » [Node 033] [REQ] [SendData]
        │ callback id:      143
        └─[WakeUpCCNoMoreInformation]
                              2021-08-03T12:29:07.943Z SERIAL « [ACK]        (0x06)
                              2021-08-03T12:29:07.947Z SERIAL « 0x0104011301e8                                                       (6 bytes)
                              2021-08-03T12:29:07.948Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:07.950Z DRIVER « [RES] [SendData]
        was sent: true
                              2021-08-03T12:29:07.962Z SERIAL « 0x010700138f00000266                                                 (9 bytes)
                              2021-08-03T12:29:07.963Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:07.965Z DRIVER « [REQ] [SendData]
        callback id:     143
        transmit status: OK
                              2021-08-03T12:29:07.979Z CNTRLR   [Node 033] The node is now asleep.
                              2021-08-03T12:29:42.192Z SERIAL « 0x0109000400210380036437                                            (11 bytes)
                              2021-08-03T12:29:42.195Z CNTRLR   [Node 033] [~] [Battery] level: 100 => 100                        [Endpoint 0]
                              2021-08-03T12:29:42.197Z CNTRLR   [Node 033] [~] [Battery] isLow: false => false                    [Endpoint 0]
                              2021-08-03T12:29:42.199Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:42.203Z DRIVER « [Node 033] [REQ] [ApplicationCommand]
        └─[BatteryCCReport]
        level:  100
        is low: false
                              2021-08-03T12:29:53.279Z SERIAL « 0x01080004002102840753                                              (10 bytes)
                              2021-08-03T12:29:53.281Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:53.283Z DRIVER « [Node 033] [REQ] [ApplicationCommand]
        └─[WakeUpCCWakeUpNotification]
                              2021-08-03T12:29:53.287Z CNTRLR « [Node 033] received wakeup notification
                              2021-08-03T12:29:53.288Z CNTRLR   [Node 033] The node is now awake.
                              2021-08-03T12:29:54.291Z CNTRLR » [Node 033] Sending node back to sleep...
                              2021-08-03T12:29:54.298Z SERIAL » 0x01090013210284082590ff                                            (11 bytes)
                              2021-08-03T12:29:54.299Z DRIVER » [Node 033] [REQ] [SendData]
        │ callback id:      144
                              2021-08-03T12:29:54.302Z SERIAL « [ACK]        (0x06)
                              2021-08-03T12:29:54.306Z SERIAL « 0x0104011301e8                                                       (6 bytes)
                              2021-08-03T12:29:54.307Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:54.308Z DRIVER « [RES] [SendData]
        was sent: true
                              2021-08-03T12:29:54.320Z SERIAL « 0x010700139000000279                                                 (9 bytes)
                              2021-08-03T12:29:54.321Z SERIAL » [ACK]        (0x06)
                              2021-08-03T12:29:54.322Z DRIVER « [REQ] [SendData]
        callback id:     144
        transmit status: OK
                              2021-08-03T12:29:54.327Z CNTRLR   [Node 033] The node is now asleep.
                              2041
