    4. Easee Wallbox mit iobroker
      warp735 last edited by
      Ist wieder abgeschmiert (rot)
      Glaub ich mach das jetzt mal über die App und warte auf n Adapter Update. Zig mal am Tag das Ding reseten bringt ja auch nix.
      host.50a2896d0707	2021-07-28 14:36:01.618	warn	Do not restart adapter system.adapter.easee.0 because restart loop detected
      host.50a2896d0707	2021-07-28 14:36:01.618	info	Restart adapter system.adapter.easee.0 because enabled
      host.50a2896d0707	2021-07-28 14:36:01.617	error	instance system.adapter.easee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      easee.0	2021-07-28 14:36:01.015	warn	(22507) Terminated (UNCAUGHT_EXCEPTION): Without reason
      easee.0	2021-07-28 14:36:00.994	error	(22507) Request failed with status code 504
      easee.0	2021-07-28 14:36:00.994	error	at processTicksAndRejections (internal/process/task_queues.js:84:21)
      easee.0	2021-07-28 14:36:00.994	error	at endReadableNT (_stream_readable.js:1241:12)
      easee.0	2021-07-28 14:36:00.994	error	at IncomingMessage.emit (events.js:326:22)
      easee.0	2021-07-28 14:36:00.994	error	at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/axios/lib/adapters/http.js:260:11)
      easee.0	2021-07-28 14:36:00.994	error	at settle (/opt/iobroker/node_modules/axios/lib/core/settle.js:17:12)
      easee.0	2021-07-28 14:36:00.994	error	at createError (/opt/iobroker/node_modules/axios/lib/core/createError.js:16:15)
      easee.0	2021-07-28 14:36:00.994	error	(22507) Error: Request failed with status code 504
      easee.0	2021-07-28 14:36:00.992	error	(22507) unhandled promise rejection: Request failed with status code 504
      easee.0	2021-07-28 14:36:00.989	error	(22507) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      host.50a2896d0707	2021-07-28 14:35:49.145	info	instance system.adapter.easee.0 started with pid 22507
      host.50a2896d0707	2021-07-28 14:35:19.101	info	Restart adapter system.adapter.easee.0 because enabled
      host.50a2896d0707	2021-07-28 14:35:19.101	error	instance system.adapter.easee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      easee.0	2021-07-28 14:35:18.510	warn	(21865) Terminated (UNCAUGHT_EXCEPTION): Without reason
      easee.0	2021-07-28 14:35:18.496	error	(21865) Request failed with status code 503
      easee.0	2021-07-28 14:35:18.496	error	at processTicksAndRejections (internal/process/task_queues.js:84:21)
      easee.0	2021-07-28 14:35:18.496	error	at endReadableNT (_stream_readable.js:1241:12)
      easee.0	2021-07-28 14:35:18.496	error	at IncomingMessage.emit (events.js:326:22)
      easee.0	2021-07-28 14:35:18.496	error	at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/axios/lib/adapters/http.js:260:11)
      easee.0	2021-07-28 14:35:18.496	error	at settle (/opt/iobroker/node_modules/axios/lib/core/settle.js:17:12)
      easee.0	2021-07-28 14:35:18.496	error	at createError (/opt/iobroker/node_modules/axios/lib/core/createError.js:16:15)
      easee.0	2021-07-28 14:35:18.496	error	(21865) Error: Request failed with status code 503
      easee.0	2021-07-28 14:35:18.494	error	(21865) unhandled promise rejection: Request failed with status code 503
      easee.0	2021-07-28 14:35:18.492	error	(21865) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      host.50a2896d0707	2021-07-28 14:35:16.839	info	instance system.adapter.easee.0 started with pid 21865
      host.50a2896d0707	2021-07-28 14:34:46.789	info	Restart adapter system.adapter.easee.0 because enabled
      host.50a2896d0707	2021-07-28 14:34:46.784	error	instance system.adapter.easee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      easee.0	2021-07-28 14:34:46.173	warn	(8911) Terminated (UNCAUGHT_EXCEPTION): Without reason
      easee.0	2021-07-28 14:34:46.157	error	(8911) Cannot read property 'cableLocked' of undefined
      easee.0	2021-07-28 14:34:46.157	error	at async /opt/iobroker/node_modules/iobroker.easee/main.js:207:17
      easee.0	2021-07-28 14:34:46.157	error	at Easee.setNewStatusToCharger (/opt/iobroker/node_modules/iobroker.easee/main.js:316:85)
      easee.0	2021-07-28 14:34:46.157	error	(8911) TypeError: Cannot read property 'cableLocked' of undefined
      easee.0	2021-07-28 14:34:46.156	error	(8911) unhandled promise rejection: Cannot read property 'cableLocked' of undefined
      easee.0	2021-07-28 14:34:46.155	error	(8911) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      easee.0	2021-07-28 14:34:46.150	error	(8911) Error: Request failed with status code 503
      easee.0	2021-07-28 14:34:45.890	error	(8911) Error: Request failed with status code 502
      easee.0	2021-07-28 14:33:43.426	warn	(8911) No Chargers found!
      easee.0	2021-07-28 14:33:43.426	error	(8911) Error: Request failed with status code 504
      easee.0	2021-07-28 14:33:03.145	warn	(8911) No Chargers found!
      easee.0	2021-07-28 14:33:03.140	error	(8911) Error: Request failed with status code 504
      • Newan
        Newan last edited by
        Bitte testet einmal Version 1.0.3 ob der Adapter immer noch abstürzt!
          stonemaan @Newan last edited by
          @newan ist installiert.. wird gecheckt
            habs auch drauf
            Newan 1 Reply Last reply Reply Quote 0
            • Newan
              Newan @warp735 last edited by
              @warp735 Naja gestern hat er nicht 7 Stunden gehalten 😉
                @newan heute noch keine Ausfälle zu verzeichnen. Ich beobachte weiter 🙂
                  Hatte heute zweimal folgendes im Log. Adapter läuft aber noch 👍
                  easee.0	2021-07-30 05:33:17.336	warn	(31842) No Chargers found!
                  easee.0	2021-07-30 05:33:17.336	error	(31842) Error: Request failed with status code 504
                  • Newan
                    Gut wenn nichts mehr kommt würde ich die Version als stable einchecken?
                    Scotty89 1 Reply Last reply Reply Quote 0
                    • Scotty89
                      Scotty89 @Newan last edited by
                      Hey,
                      ich habe mir jetzt auch die version 1.0.3 drauf gemacht und logge es die tage mal mit ...
                      bisher sieht es aber ganz gut aus..
                      eine Frage an alle .. in welchen Intervall lasst ihr ihn laufen ? was habt ihr da eingestellt wenn ihr PV laden damit macht ?
                      • Newan
                        Newan @Scotty89 last edited by
                        @scotty89 Nutz doch SignalR das ist dann in echtzeit
                        • Scotty89
                          @newan sagte in Easee Wallbox mit iobroker:
                          das habe ich aktiv leider nicht wirklich rausbekommen was es macht 😉
                          was genau steht da hinter ? und in wie weit steht das damit dem Intervall im zusammenhang ?
                          ich schreibe ja den Parameter ....config.dynamicChargerCurrent bekomme ich ihn dann auch bestätigt oder erst nach einem erneuten lesen welches dann über das Interfall kommt ?
                          • Newan
                            @scotty89 Also Grundsätzlich ist das Intervall ja das die Daten in einem Bestimmten Zyklus abgeholt werden.
                            Den kannst du relativ hoch setzen und da über SignalR nicht alle Daten kommen wie Energieverbräuche etc. z.b 5 mal am Tag.
                            Dann wählst du SignalR aus und der Adapter registriert sich an der Cloud, die schickt dann bei einer Änderung das Event direkt zum Adapter, also quasi live.
                            Wie gut das ganze funktioniert weiß ich nicht, da das noch nie einer getestet hat 😧
                            • Scotty89
                              @newan
                              ok dann teste ich das doch einfach mal etwas...
                              das Intervall werde ich mal 30 Sekunden hoch setzen und schauen wie sich meine Regelung verhält die Tage wenn das Wetter besser ist 😉
                              Danke.
                              andere frage gleich noch .. läuft der Adapter eigentlich auf Offline ? oder rein über die Cloud von denen ?
                              • Newan
                                @scotty89 Nur cloud
                                  @newan ich habe heute morgen signalR angeschaltet. leider ist der adapter nach einiger Zeit wieder auf gelb gesprungen. Ich habe heute allerdings auch den JS controller geupdated und NodeJS auch..
                                  2021-08-06 11:34:42.697 - error: easee.0 (1381) Error: Request failed with status code 503
                                  2021-08-06 11:34:42.698 - error: easee.0 (1381) Error: Easee API error on charger state - stop refresh
                                  2021-08-06 11:34:42.704 - error: easee.0 (1381) Error: Request failed with status code 503
                                  2021-08-06 11:34:42.705 - error: easee.0 (1381) Error: Easee API error on charger state - stop refresh
                                  2021-08-06 11:34:53.251 - error: easee.0 (1381) SignalR Verbindung beendet!!!- restart
                                  2021-08-06 11:34:53.379 - error: easee.0 (1381) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  2021-08-06 11:34:53.380 - error: easee.0 (1381) unhandled promise rejection: Service Temporarily Unavailable
                                  2021-08-06 11:34:53.381 - error: easee.0 (1381) Error: Service Temporarily Unavailable
                                  at new HttpError (/opt/iobroker/node_modules/@microsoft/signalr/dist/cjs/Errors.js:27:24)
                                  at FetchHttpClient. (/opt/iobroker/node_modules/@microsoft/signalr/dist/cjs/FetchHttpClient.js:154:35)
                                  at step (/opt/iobroker/node_modules/@microsoft/signalr/dist/cjs/FetchHttpClient.js:52:23)
                                  at Object.next (/opt/iobroker/node_modules/@microsoft/signalr/dist/cjs/FetchHttpClient.js:33:53)
                                  at fulfilled (/opt/iobroker/node_modules/@microsoft/signalr/dist/cjs/FetchHttpClient.js:24:58)
                                  at runMicrotasks ()
                                  at processTicksAndRejections (internal/process/task_queues.js:97:5)
                                  2021-08-06 11:34:53.381 - error: easee.0 (1381) Service Temporarily Unavailable
                                  2021-08-06 11:34:53.384 - info: easee.0 (1381) Adaptor easee cleaned up everything...
                                  2021-08-06 11:34:53.384 - info: easee.0 (1381) terminating
                                  2021-08-06 11:34:53.385 - warn: easee.0 (1381) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                  2021-08-06 11:35:02.486 - info: easee.0 (7331) starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.easee, node: v12.22.4, js-controller: 3.3.15
                                  2021-08-06 11:35:02.742 - error: easee.0 (7331) Api login error - check Username and password
                                  Ich beobachte mal weiter
                                  • Newan
                                    Newan @stonemaan last edited by
                                    @stonemaan ok ist aber 1.0.3?
                                    Schau mir das nochmal an
                                      @newan jo... 1.0.3
                                        Aiouh @stonemaan last edited by
                                        @Newan
                                        Ich bekomme seit Heute mit der 1.0.3 folg. Fehler
                                        easee.0	2021-08-06 23:14:23.569	error	(8630) Api login error - check Username and password
                                        Es wurde aber an user & passwort nichts geändert 😞
                                        • Newan
                                          Newan @Aiouh last edited by
                                          @aiouh mal aus der App abmelden und versuchen da wieder anzumelden. Die erros kommen ja direkt von der api
                                            Aiouh @Newan last edited by
                                            @newan said in Easee Wallbox mit iobroker:
                                            abmelden aus der App hat leider nichts gebracht, nach Neustart des ioBroker ist aber wieder alles im Lot.
                                            Ist 1.0.3 eigentlich die aktuelle?
                                            adapter easee wallbox
                                            60
                                            510
                                            96193
