    4. Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda
      Backes @tombox last edited by
      @tombox Läuft! Daten von Wallbox und Ladevorgänge werden angezeigt!
        mguenther @tombox last edited by
        @tombox
        taucht bei mir aktuell auf:
        vw-connect.0	2021-07-16 19:01:45.166	error	(17911) "502 Bad Gateway: Registered endpoint failed to handle the request.\n"
        vw-connect.0	2021-07-16 19:01:45.166	error	(17911) 502
        vw-connect.0	2021-07-16 19:01:45.159	error	(17911) Failed to get token
        und dann
        vw-connect.0	2021-07-16 19:06:46.787	error	(17911) Failed to get records
        vw-connect.0	2021-07-16 19:06:46.786	error	(17911) {"tracing_id":"703540aaf50d09729156148cf72c1ab1","errors":[{"message":"Signin failed","code":"AUTHZ_SIGNIN_WITH_TOKEN"}]}
        vw-connect.0	2021-07-16 19:06:46.785	error	(17911) 401
        vw-connect.0	2021-07-16 19:06:46.754	error	(17911) Failed to get stations
        vw-connect.0	2021-07-16 19:06:46.754	error	(17911) {"tracing_id":"8109df1aa5f10e27494c8de9b32f72ed","errors":[{"message":"Signin failed","code":"AUTHZ_SIGNIN_WITH_TOKEN"}]}
        vw-connect.0	2021-07-16 19:06:46.752	error	(17911) 401
        vw-connect.0	2021-07-16 19:06:46.376	error	(17911) Failed to get chargeandpay records
        vw-connect.0	2021-07-16 19:06:46.375	error	(17911) {"tracing_id":"804a8efc6cb6f4efe1f33c0e06727984","errors":[{"message":"The request could not be authenticated","code":"UNAUTHORIZED"}]}
        vw-connect.0	2021-07-16 19:06:46.375	error	(17911) 401
        vw-connect.0	2021-07-16 19:06:46.372	error	(17911) Failed to get subscription
        vw-connect.0	2021-07-16 19:06:46.371	error	(17911) {"tracing_id":"18e581eb9382e50967aa44e9dac6fd3e","errors":[{"message":"The request could not be authenticated","code":"UNAUTHORIZED"}]}
        vw-connect.0	2021-07-16 19:06:46.370	error	(17911) 401
        usw...
        Der Adapter selber bleibt aber grün...
        T J 2 Replies Last reply Reply Quote 0
          tombox @mguenther last edited by tombox
          @mguenther geht denn wecharge über die app?
            @tombox
            generell geht es, ja. Ob es vorhin ging, weiß ich nicht.
              Backes last edited by
              Option "skodae" scheint noch Fehler zu erzeugen.
              siehe Log:
              Müsste diese Stelle hier sein Zeile 2518:
                tombox @Backes last edited by tombox
                @backes Habe ich übersehen gibt es denn sowas wie ein force reload bei skoda e autos.
                Habs in der github version rausgenommen bitte mal testen
                  jhg @mguenther last edited by
                  @mguenther Diesen Fehler habe ich aktuell auch seit einigen Tagen.
                  Konnte zwar nicht sehen ob das eine Auswirkung hat, aber die Fehlermeldung ist da.
                    SiKo last edited by SiKo
                    grundsätzlich läuft bei mir der Adapter. ich kann z.B. auch "Hupen & Blicken" Allerdings ist immer alles sehr zeitversetzt. Hab das Auto in der Garage entriegelt und Fenster teilweise geöffnet. bis ich das in ioBroker sehe vergehen oft Stunden. Mach ich hier etwas falsch?
                      MrLee last edited by
                      Moin!
                      Auch von mir einen herzlichen Dank für den Adapter. Spiele mich gerade etwas rein, gerade bez. Akku und Ladestand.
                      Da mein Fahrzeug (Audi) über die Standklimatisierung verfügt würde ich diese auch gerne steuern können (so wie aus der unsagbar schlechten Audi App...)
                      Welchen Datenpunkt muß ich denn dafür nehmen? Remote/climatisation** erzeugen keine Reaktion bei mir.
                      Des weiteren: Hat jemand erfahrung mit den möglichen polling zyklen bei Audi? Die Servererreichbarkeit ist ja eh nicht "optimal"
                      Wer schön wenn jemand schon etwas Erfahrungen mit Audi gemacht hat...
                      Liebe Grüße
                      Mr.Lee
                        tombox @MrLee last edited by
                        @mrlee Standheizung geht auch nicht?
                          MrLee @tombox last edited by
                          @tombox gerade probiert..nein, zumindest nix in der Audi App sichtbar
                            Generelle Frage...
                            Gibt es einen Datenpunkt der ein Datenupdate erzwingt?
                            bis denne
                            Mr.Lee
                              @mrlee in der app geht klima?
                              nicht man kann nur den interval in den optionen angeben
                              aktualisiert sich denn alles wenn du in der audi app nach unten ziehst
                                @tombox Jo, in der App geht klima, sofortstart, etc.
                                Im Adapter geht auch Abschließen und aufschließen, kontakt habe ich also 🙂
                                Da ich die App gerne ganz und gar und in alle Ewigkeit ablösen würde...könnte man ein force-update noch in den Adapter einbauen oder geht das Systembedingt nicht?
                                  Lattenleger 0 last edited by
                                  Hallo, ich habe hier so gut wie alles durch gelesen, leider hilft es nicht bei meinem Problem. Ich habe 2 DATA Plugs in verschiedenen Autos. Beide liefern Daten an die Cloud in der GO App. Einer der Autos ist auch in der We Connect App mit Car-Net verknüpft. Dieses Auto ist auch im Adapter im io Brocker zu sehen. Leider sind beide über die DATA Plugs nicht zusehen. Was mache ich falsch?
                                    tombox @Lattenleger 0 last edited by
                                    @lattenleger-0 Dann musst du zwei instancen verwenden eine für we-connect und eine für go
                                      Magnus 1 Developer last edited by
                                      versuche mich gerade mit der v0.0.39 und bekomme in paar Daten geliefert, aber noch nicht die Dinge die mich wirklich interessieren (SOC, Trip history etc).
                                      Im Protokoll findet sich folgender Fehler:
                                      The service: statusreport_v1 for VIN:
                                      vw-connect.0
                                      2021-08-16 15:12:19.939	error	status update Failed WVW….
                                      vw-connect.0
                                      2021-08-16 15:12:19.927	error	{"error":{"errorCode":"VSR.security.9007","description":"The service: statusreport_v1 for VIN: WVW…. could not be found."}}
                                      vw-connect.0
                                      2021-08-16 15:12:19.926	error	502
                                      vw-connect.0
                                      2021-08-16 15:12:19.925	error	WVW….
                                      Die VIN habe ich hier im Beitrag gekürzt.
                                      Kann mir jemand helfen was hier schief läuft?
                                      Es ist ein ID3 und da ja einige Daten geliefert werden zu meinem Fahrzeug gehe ich davon aus, dass die con mir eingegeben Zugangsdaten wohl stimmen.
                                      Viele Grüße,
                                      Magnus
                                        tombox @Magnus 1 last edited by
                                        @magnus-1 Bitte bei typ ID auswählen
                                          Magnus 1 Developer @tombox last edited by
                                          @tombox Super, dass war schnell und leicht zu fixen. jetzt kommt deutlich mehr.
                                          Noch nicht entdecken konnte ich die Trip infos. Gucke ich nur dran vorbei, oder gibt es die bei den ID nicht?
                                          Viele Grüße
                                          Magnus
                                            @magnus-1 nur das was es in der App gibt
                                            RaspiUser 1 Reply Last reply Reply Quote 0
                                            81.1k
                                            audi id.3 myaudi seat skoda skoda connect volkswagen vw id we connect wecharge
                                            398
                                            3090
                                            1600119
