    4. js-controller 3.3 jetzt im STABLE!
      apollon77 @OliverIO last edited by
      @oliverio Exakt. Ein Read only state kann per definition nicht kontrolliert werden weil er nur einen Wert bereitstellt 🙂 Daher die Meldung.
      Michael Schmitt 1 Reply Last reply Reply Quote 0
      • Michael Schmitt
        Michael Schmitt @apollon77 last edited by
        was bedeutet diese Meldung im Log ???
        State value to set for "tr-064.0.callmonitor.lastCall.callee" has to be type "number" but received type "string"
        Michael Schmitt mickym apollon77 3 Replies Last reply Reply Quote 0
        • Michael Schmitt
          Michael Schmitt @Michael Schmitt last edited by
          bzw
          fritzdect.0	2021-08-05 13:17:21.675	info	(2739) State value to set for "fritzdect.0.DECT_099950270252.endperiod" has to be type "number" but received type "string"
          fritzdect.0	2021-08-05 13:17:21.674	info	(2739) State value to set for "fritzdect.0.DECT_099950270252.boostactiveendtime" has to be type "number" but received type "string"
          fritzdect.0	2021-08-05 13:17:21.673	info	(2739) State value to set for "fritzdect.0.DECT_099950270252.windowopenactiveendtime" has to be type "number" but received type "string"
          fritzdect.0	2021-08-05 13:17:21.579	info	(2739) State value to set for "fritzdect.0.DECT_099950276783.endperiod" has to be type "number" but received type "string"
          fritzdect.0	2021-08-05 13:17:21.574	info	(2739) State value to set for "fritzdect.0.DECT_099950276783.boostactiveendtime" has to be type "number" but received type "string"
          fritzdect.0	2021-08-05 13:17:21.573	info	(2739) State value to set for "fritzdect.0.DECT_099950276783.windowopenactiveendtime" has to be type "number" but received type "string"
          fritzdect.0	2021-08-05 13:17:21.470	info	(2739) State value to set for "fritzdect.0.DECT_099950696353.endperiod" has to be type "number" but received type "string"
          fritzdect.0	2021-08-05 13:17:21.468	info	(2739) State value to set for "fritzdect.0.DECT_099950696353.boostactiveendtime" has to be type "number" but received type "string"
          fritzdect.0	2021-08-05 13:17:21.467	info	(2739) State value to set for "fritzdect.0.DECT_099950696353.windowopenactiveendtime" has to be type "number" but received type "string"
          fritzdect.0	2021-08-05 13:17:21.393	info	(2739) State value to set for "fritzdect.0.DECT_133560170728.endperiod" has to be type "number" but received type "string"
          fritzdect.0	2021-08-05 13:17:21.391	info	(2739) State value to set for "fritzdect.0.DECT_133560170728.boostactiveendtime" has to be type "number" but received type "string"
          fritzdect.0	2021-08-05 13:17:21.390	info	(2739) State value to set for "fritzdect.0.DECT_133560170728.windowopenactiveendtime" has to be type "number" but received type "string"
          fritzdect.0	2021-08-05 13:17:21.300	info	(2739) State value to set for "fritzdect.0.DECT_133560175984.endperiod" has to be type "number" but received type "string"
          fritzdect.0	2021-08-05 13:17:21.298	info	(2739) State value to set for "fritzdect.0.DECT_133560175984.boostactiveendtime" has to be type "number" but received type "string"
          fritzdect.0	2021-08-05 13:17:21.281	info	(2739) State value to set for "fritzdect.0.DECT_133560175984.windowopenactiveendtime" has to be type "number" but received type "string"
          fritzdect.0	2021-08-05 13:17:21.135	info	(2739) State value to set for "fritzdect.0.DECT_133560155800.endperiod" has to be type "number" but received type "string"
          fritzdect.0	2021-08-05 13:17:21.126	info	(2739) State value to set for "fritzdect.0.DECT_133560155800.boostactiveendtime" has to be type "number" but received type "string"
          fritzdect.0	2021-08-05 13:17:21.124	info	(2739) State value to set for "fritzdect.0.DECT_133560155800.windowopenactiveendtime" has to be type "number" but received type "string"
          • mickym
            mickym Most Active @Michael Schmitt last edited by mickym
            @michael-schmitt Ja das hatte ich auch. Ist aber wie in der Anleitung beschrieben.
            Ich habe die Datenpunkte alle gelöscht (des Callmonitors) und dann den Adapter neu gestartet und der Adapter hat die Objekte dann mit dem korrekten Typ angelegt.
            Also zum Beispiel den Callmonitor.
            Es geht Dir halt die Historie verloren. - Vielleicht auch nicht, aber ich habe nicht jeden Datenpunkt geprüft. 😉 Also vielleicht hätte es auch getan, wenn ich nur den monierten Punkt gelöscht hätte.
            apollon77 Michael Schmitt 2 Replies Last reply Reply Quote 0
              apollon77 @mickym last edited by
              @mickym sagte in js-controller 3.3 jetzt im STABLE!:
              Nur die Settings für History ... man kann es danach wieder aktivieren. Ja das ist leider blöd, aber aktuell leider so.
              Die Alternative ist per Admin im Export-Modus das Objekt zu editierne und den Datentyp dort anzulassen. Für die mit History-Settings vllt schneller
              • mickym
                mickym Most Active @apollon77 last edited by
                @apollon77 sagte in js-controller 3.3 jetzt im STABLE!:
                Jain ... gibt auch genügend Fälle in Visus oder JavaScript wo User-Skripte komische und falsche Dinge tun.
                Jo so habe ich heute festgestellt, dass mein NodeRed Flow Strings in ein Zahlenobjekt geschrieben hat. Ich finde diese Meldungen auch als "Nicht-Adapter" Entwickler durchaus nützlich. 🙂
                  apollon77 @Michael Schmitt last edited by
                  @michael-schmitt Die Meldung bedeutet das das Objekt definiert hat das es eine Nummer/Zahl ist, aber der Adapter hat eine Zeichenkette reingeschrieben ... Das kann ein Fehler sein weil das Objekt falsch ist oder nur ein Fall von -- Adapter schreibt "22" anstelle 22 -- rein
                  • Michael Schmitt
                    Michael Schmitt @mickym last edited by
                    sind davon dann meine Blockly script betroffen ?
                      @michael-schmitt sagte in js-controller 3.3 jetzt im STABLE!:
                      Wenn Sie die richtigen Datentypen in die States schreiben nein ... falls die was falsch machen wirst Du auch Meldungen bekommen.
                      • mickym
                        Ja ich schrieb ja dass ich zu faul war, jetzt zu warten welche Datenpunkte alle moniert werden, da das ja auch nicht immer gleich funktioniert. Am Besten müsste das ja der Adapterentwickler wissen, aber keine Ahnung ob man als Adapterentwickler auch den Typ eines Objektes nachträglich ändern kann. Ich geh mal davon aus, dass das geht, aber ist halt zusätzliche Arbeit für die Entwickler.
                        • OliverIO
                          OliverIO @mickym last edited by
                          @mickym
                          schön wäre eine musterlösung für eine migration.
                          dann könnte man die genau so in den adapter einbauen
                          und es müsste sich nicht jeder eine eigene Funktion ausdenken.
                          idee für eine Funktionssignatur wäre:
                          function migrateStateType(id,fromType,toType)
                          oder müsste es eigentlich Object heißen?
                          • mickym
                            mickym Most Active @OliverIO last edited by
                            @oliverio So weit ich das System durchschaue - aber da bist Du schlauer, muss man den Typ glaub in dem Objekt ändern.
                              paul53 @mickym last edited by
                              @mickym sagte: muss man den Typ glaub in dem Objekt ändern.
                              Ja, common.type im Objekt vom Typ "state".
                              • mickym
                                mickym Most Active @paul53 last edited by mickym
                                @paul53 Das Objekt ist doch das, was unter "raw" steht, das war mein Verständnis:
                                EDIT: Ach so ich verstehe was Du meinst vom Typ state (letzte Zeile). 😉
                                  @mickym
                                  Genau dort erfolgt die Korrektur.
                                  • mickym
                                    So noch ein Info - zum Info Adapter 😉 - da gibt es auch wenn man sonst keine Systemdaten monitoren will noch 5 Objekte, die man auch löscht, damit der Adapter die korrekten Typen wieder anlegt:
                                    info.0	2021-08-05 13:29:38.945	info	(5272) State value to set for "info.0.sysinfo.cpu.info.cache-l3" has to be type "number" but received type "string"
                                    info.0	2021-08-05 13:29:38.941	info	(5272) State value to set for "info.0.sysinfo.cpu.info.cache-l2" has to be type "number" but received type "string"
                                    info.0	2021-08-05 13:29:38.936	info	(5272) State value to set for "info.0.sysinfo.cpu.info.cache-l1i" has to be type "number" but received type "string"
                                    info.0	2021-08-05 13:29:38.886	info	(5272) State value to set for "info.0.sysinfo.cpu.info.cache-l1d" has to be type "number" but received type "string"
                                    info.0	2021-08-05 13:29:38.849	info	(5272) State value to set for "info.0.sysinfo.cpu.info.speed" has to be type "string" but received type "number"
                                    Es langt aber wirklich nur diese 5 Punkte zu löschen!!!
                                    Selbst als ich dann das Laden der Systemdaten mal kurzzeitig aktiviert habe, wurden keine weiteren Inkonsistenzen festgestellt.
                                      @mickym Bei info hängt es davon ab welche Statistiken man alles so aktiviert hat, können auch mehr sein.
                                        apollon77 @paul53 last edited by
                                        @paul53 Vollkommen korrekt
                                          paul53 @apollon77 last edited by paul53
                                          @apollon77
                                          Wer merged eigentlich meinen PR im Deconz-Adapter?
                                            @paul53 Den kannte ich bisher nicht ... Kläre
                                            344
                                            90005
