    4. js-controller 3.3 jetzt im STABLE!
      apollon77 @Negalein last edited by
      @negalein Also mindestens bei weatherunderground ist das über "Objekte löschen " gelöst ... mihome denke auch ... also bitte versuche das vor Issues!
        apollon77 @exitus last edited by
        @exitus Naja ohne das Skript zu kennen eher schwierig zu sagen
        Bjoern77 1 Reply Last reply Reply Quote 0
        • Bjoern77
          Bjoern77 @apollon77 last edited by Bjoern77
          Moin
          Ich habe dann auch das Update gemacht. Leider läuft es noch nicht wieder rund.
          Ich bekomme alle 30s diesen LOG:
          host.raspberrypi	2021-08-06 11:13:24.434	info	Restart adapter system.adapter.javascript.0 because enabled
          host.raspberrypi	2021-08-06 11:13:24.434	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          host.raspberrypi	2021-08-06 11:13:24.433	error	Caught by controller[0]: }
          host.raspberrypi	2021-08-06 11:13:24.433	error	Caught by controller[0]: ]
          host.raspberrypi	2021-08-06 11:13:24.433	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
          host.raspberrypi	2021-08-06 11:13:24.433	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-tsc/build/index.js',
          host.raspberrypi	2021-08-06 11:13:24.433	error	Caught by controller[0]: '/opt/iobroker/node_modules/virtual-tsc/build/server.js',
          host.raspberrypi	2021-08-06 11:13:24.432	error	Caught by controller[0]: requireStack: [
          host.raspberrypi	2021-08-06 11:13:24.432	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
          host.raspberrypi	2021-08-06 11:13:24.432	error	Caught by controller[0]: {
          host.raspberrypi	2021-08-06 11:13:24.432	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
          host.raspberrypi	2021-08-06 11:13:24.432	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
          host.raspberrypi	2021-08-06 11:13:24.431	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
          host.raspberrypi	2021-08-06 11:13:24.431	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
          host.raspberrypi	2021-08-06 11:13:24.431	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
          host.raspberrypi	2021-08-06 11:13:24.431	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
          host.raspberrypi	2021-08-06 11:13:24.431	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:35:24)
          host.raspberrypi	2021-08-06 11:13:24.431	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
          host.raspberrypi	2021-08-06 11:13:24.430	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
          host.raspberrypi	2021-08-06 11:13:24.430	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
          host.raspberrypi	2021-08-06 11:13:24.430	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
          host.raspberrypi	2021-08-06 11:13:24.430	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
          host.raspberrypi	2021-08-06 11:13:24.429	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
          host.raspberrypi	2021-08-06 11:13:24.429	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-tsc/build/index.js:8:16)
          host.raspberrypi	2021-08-06 11:13:24.429	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
          host.raspberrypi	2021-08-06 11:13:24.429	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
          host.raspberrypi	2021-08-06 11:13:24.429	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
          host.raspberrypi	2021-08-06 11:13:24.429	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
          host.raspberrypi	2021-08-06 11:13:24.428	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
          host.raspberrypi	2021-08-06 11:13:24.428	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
          host.raspberrypi	2021-08-06 11:13:24.428	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-tsc/build/server.js:4:10)
          host.raspberrypi	2021-08-06 11:13:24.428	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
          host.raspberrypi	2021-08-06 11:13:24.427	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
          host.raspberrypi	2021-08-06 11:13:24.427	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:667:27)
          host.raspberrypi	2021-08-06 11:13:24.427	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
          host.raspberrypi	2021-08-06 11:13:24.426	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
          host.raspberrypi	2021-08-06 11:13:24.426	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-tsc/build/index.js
          host.raspberrypi	2021-08-06 11:13:24.426	error	Caught by controller[0]: - /opt/iobroker/node_modules/virtual-tsc/build/server.js
          host.raspberrypi	2021-08-06 11:13:24.426	error	Caught by controller[0]: Require stack:
          host.raspberrypi	2021-08-06 11:13:24.426	error	Caught by controller[0]: Error: Cannot find module 'typescript'
          host.raspberrypi	2021-08-06 11:13:24.425	error	Caught by controller[0]: ^
          host.raspberrypi	2021-08-06 11:13:24.425	error	Caught by controller[0]: throw err;
          host.raspberrypi	2021-08-06 11:13:24.424	error	Caught by controller[0]: internal/modules/cjs/loader.js:818
          host.raspberrypi	2021-08-06 11:13:23.898	info	instance system.adapter.javascript.0 started with pid 23893
          Es ist ein Master-Slave System. Ich habe erst den Master upgedated. Diese Meldungen kommen vom Master.
          Was kann ich versuchen?
          Danke für eure Arbeit únd Gruß
          Björn
          • OliverIO
            OliverIO @exitus last edited by
            @exitus sagte in js-controller 3.3 jetzt im STABLE!:
            nach dem update funktionieren bei die Blocky scripte nicht mehr woran kann es liegen.
            raspberrypi
            Plattform
            linux
            Betriebssystem
            linux
            Architektur
            arm
            CPUs
            Geschwindigkeit
            1500 MHz
            Modell
            ARMv7 Processor rev 3 (v7l)
            RAM
            3.74 GB
            System-Betriebszeit
            06:25:21
            Node.js
            v12.22.4
            NPM
            6.14.14
            Datenträgergröße
            28.98 GB
            freier Festplattenspeicher
            23.35 GB
            Anzahl der Adapter
            338
            Betriebszeit
            00:06:25
            Aktive Instanzen
            38
            01:29:57.404	error	javascript.0 (5232) script.js.Flur.Flur_Automatik: TypeError: Cannot read property 'indexOf' of undefined
            01:29:57.404	error	javascript.0 (5232) at iCalToHTMLTable (script.js.Flur.Flur_Automatik:337:24)
            01:29:57.405	error	javascript.0 (5232) at script.js.Flur.Flur_Automatik:130:1
            01:29:57.405	error	javascript.0 (5232) at script.js.Flur.Flur_Automatik:15:3
            javascript.0	2021-08-06 01:31:13.193	error	(5232) at Script.runInContext (vm.js:130:18)
            javascript.0	2021-08-06 01:31:13.192	error	(5232) at script.js.Heizung_Steuerung.Jale_Heizung:14:3
            javascript.0	2021-08-06 01:31:13.192	error	(5232) at script.js.Heizung_Steuerung.Jale_Heizung:130:1
            javascript.0	2021-08-06 01:31:13.192	error	(5232) at iCalToHTMLTable (script.js.Heizung_Steuerung.Jale_Heizung:337:24)
            javascript.0	2021-08-06 01:31:13.192	error	(5232) script.js.Heizung_Steuerung.Jale_Heizung: TypeError: Cannot read property 'indexOf' of undefined
            Das hat alles mit dem Kalender adapter zu tun, da war doch hier schon ein weiterer Fehler, der relativ einfach behoben werden konnte.
            Jemand erwähnte, das im Kalender -Adapter etwas angepasst wurde, wo nutzende ebenfalls tätig werden müssen. Also dort nachlesen und ggfs. nachfragen.
              apollon77 @Bjoern77 last edited by
              @bjoern77 Instslliere mal javascript adapte rneu ... aus irgendeinem grund fehlt da ein paket?
              Bjoern77 1 Reply Last reply Reply Quote -1
              • Bjoern77
                @apollon77
                @apollon77
                Moin
                Habe ich auf verschiedenste Wege versucht.
                Der letzte Versuch war dieser:
                cd /opt/iobroker/node_modules/iobroker.javascript
                npm install --production
                Wie würdest du es versuchen?
                Gruß Björn
                  @bjoern77 Hm ... komisch .... versuch mal npm install in /opt/iobroker/node_modules/virtual-tsc/
                  A Bjoern77 2 Replies Last reply Reply Quote 0
                    Ahnungsbefreit @apollon77 last edited by
                    @apollon77 Bitte im 2.Post noch "LaMetric" ergänzen. Github Issue habe ich aufgemacht: https://github.com/klein0r/ioBroker.lametric/issues/45
                    ahnungsbefreit created this issue in klein0r/ioBroker.lametric
                    closed Type issue with js-controller 3.3 #45
                    • Bjoern77
                      @apollon77
                      Das hat geholfen. Vielen Dank. Läuft wieder auf grün und durch 🙂
                      Björn
                        @bjoern77 Dennoch sehr komisch und ungewöhnlich
                          exitus @paul53 last edited by exitus
                          @paul53 java script ist auf 5.1.3 es ist nicht >5.2
                          ical kalender ist auf 1.11.2
                            paul53 @exitus last edited by
                            @exitus sagte: java script ist auf 5.1.3 es ist nicht >5.2
                            Dann ist iCal schon auf die Änderungen im js-controller (JSON statt Objekt) umgestellt, Javascript aber noch nicht. Passen also nicht zueinander, was zu dem Fehler führt.
                            OliverIO E 2 Replies Last reply Reply Quote 0
                            • OliverIO
                              OliverIO @paul53 last edited by
                              Da Testsystem und nicht so oft benutzt habe ich nun nach Aktualisierung den folgenden Fehler:
                              Redis error:Error: Invalid Chunk: parse failed
                              obwohl dort redis für iobroker nicht konfiguriert ist.
                              Mehr Details hier:
                              https://forum.iobroker.net/topic/46803/redis-error-error-invalid-chunk-parse-failed?_=1628246890838
                                apollon77 @OliverIO last edited by
                                @oliverio Schaue dort, AUch die iobroker eigene DB nutzt seit controller 2.0 das Redis Protokoll unter der Haube
                                  @paul53 danke paul ich habe unter einstellung auf Beta gestellt und dann musste ich Admin Adapter Updaten damit ich Java script updaten konnte.
                                  Habe Admin Adapter auf 5.1.23 und java auf 5.2.6 danach lief es .
                                    @exitus Admin5 und die ganzen Deps kommen heute Abend
                                      A Former User @apollon77 last edited by
                                      @apollon77
                                      Vielen Dank für die stetige Aktualisierung und Weiterentwicklung!
                                      Mir juckt es etwas in den Fingern, aber da doch auf einige Meldungen verwiesen wird, würde ich gerne vorab das Fallback-Szenario erfragen (Linux)?
                                      Falls Die Fehlermeldungen/Probleme doch zu massiv werden, gibt es eine empfohlene und erprobte Methode außer ggf. eine komplette Neuinstallation mit dem Restore eines Backups?
                                      Besten Dank!
                                      apollon77 J 2 Replies Last reply Reply Quote 0
                                        apollon77 @Guest last edited by
                                        @pete0815 Steht zwar im ersten Post drin aber ich kopiere es gern nochmal hierher 🙂
                                        Die alte Version des js-controller kann im Notfall einfach wieder per npm install iobroker.js-controller@version (ausgeführt im ioBroker-Verzeichnis, z.B. /opt/iobroker) installiert werden und sollte alles wieder herstellen.
                                          Jan1 @Guest last edited by Jan1
                                          @pete0815
                                          Ein Restor eines Backup empfiehlt sich auch so ab und an mal zu tätigen, weil es das System sauber hält. Somit ist das die schnellste, einfachste und beste Art. Hier sollte dann auch der IOBroker Ordner sauber gelöscht werden und außer ner IOBroker Neuinstallation samt dem Backitup Adapter nichts drauf sein 😉
                                          Also alles andere als ne gefährliche Aktion bei der man ein Linux Nerd sein muss.
                                          Edit:
                                          Oder man machts wie apollon schon geschrieben hat, wie es im ersten Post dazu schon steht, was natürlich auch geht, aber das eventuell unsaubere System eben auch unsauber lässt.
                                            Fabian1 last edited by
                                            Dass der Admin5 und der Javascript Adapter nicht gleichzeitig mit dem js-controller ins stable gegangen sind war natürlich etwas unglücklich. 🙂
                                            Aber ich muss jetzt echt mal sagen, nachdem ich jetzt alle Fehler bei mir im System ausgebügelt habe läuft mein System mit dem js-controller 3.3 1000 mal stabiler als vorher! Wirklich super arbeit!
                                            344
                                            80974
