    4. Test Adapter TrashSchedule
      Speedy012 @haus-automatisierung last edited by
      Poste es eben hier, mache mir gleich einen Account beit Git..
      trashschedule.0	2021-08-03 15:39:11.171	debug	(19119) system.adapter.admin.0: logging true
      trashschedule.0	2021-08-03 15:39:09.988	error	(19119) no events found in iCal instance - check configuration and restart adapter
      trashschedule.0	2021-08-03 15:39:09.988	debug	(19119) updating data
      trashschedule.0	2021-08-03 15:39:09.986	debug	(19119) re-creating refresh timeout in 1255014ms (00:20:55)
      trashschedule.0	2021-08-03 15:39:09.936	debug	(19119) Trash type found: "Mülltonne"
      trashschedule.0	2021-08-03 15:39:09.888	debug	(19119) Trash type found: "Papiertonne"
      trashschedule.0	2021-08-03 15:39:09.841	debug	(19119) Trash type found: "Biotonne"
      trashschedule.0	2021-08-03 15:39:09.793	debug	(19119) Trash type found: "Gelbetonne"
      trashschedule.0	2021-08-03 15:39:09.769	info	(19119) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.trashschedule, node: v14.17.3, js-controller: 3.2.16
      trashschedule.0	2021-08-03 15:39:09.700	debug	(19119) Plugin sentry Initialize Plugin (enabled=true)
      trashschedule.0	2021-08-03 15:39:09.476	debug	(19119) statesDB connected
      trashschedule.0	2021-08-03 15:39:09.475	debug	(19119) States connected to redis: 127.0.0.1:9000
      trashschedule.0	2021-08-03 15:39:09.425	debug	(19119) States create User PubSub Client
      trashschedule.0	2021-08-03 15:39:09.424	debug	(19119) States create System PubSub Client
      trashschedule.0	2021-08-03 15:39:09.420	debug	(19119) Redis States: Use Redis connection: 127.0.0.1:9000
      trashschedule.0	2021-08-03 15:39:09.418	debug	(19119) objectDB connected
      trashschedule.0	2021-08-03 15:39:09.412	debug	(19119) Objects connected to redis: 127.0.0.1:9001
      trashschedule.0	2021-08-03 15:39:09.402	debug	(19119) Objects client initialize lua scripts
      trashschedule.0	2021-08-03 15:39:09.401	debug	(19119) Objects create User PubSub Client
      trashschedule.0	2021-08-03 15:39:09.401	debug	(19119) Objects create System PubSub Client
      trashschedule.0	2021-08-03 15:39:09.400	debug	(19119) Objects client ready ... initialize now
      trashschedule.0	2021-08-03 15:39:09.382	debug	(19119) Redis Objects: Use Redis connection: 127.0.0.1:9001
      trashschedule.0	2021-08-03 15:39:05.999	info	(16784) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      trashschedule.0	2021-08-03 15:39:05.998	info	(16784) terminating
      trashschedule.0	2021-08-03 15:39:05.998	info	(16784) cleaned everything up...
      trashschedule.0	2021-08-03 15:39:05.997	info	(16784) Got terminate signal TERMINATE_YOURSELF
      • haus-automatisierung
        haus-automatisierung Developer Most Active @Speedy012 last edited by
        @speedy012 Was steht denn in ical.0.data.table ?
          da sind nur "[]" drinne
          Glasfaser haus-automatisierung 2 Replies Last reply Reply Quote 0
          • Glasfaser
            Glasfaser @Speedy012 last edited by
            @speedy012
            https://forum.iobroker.net/topic/27050/test-adapter-trashschedule-v1-1-x/273
              Speedy012 @Glasfaser last edited by
              @glasfaser
              habs hinbekommen..... hab ical.0 ersetzt durch ical.2 hab einen neuen geöfnet und da geht es.
                @speedy012 Guck, liegt nicht an diesem Adapter. Wo nichts ist, kann auch nichts gelesen werden. Falls Du die Funktion „Ereignisse“ von iCal nutzt, dann musst Du beim jeweiligen Ereignis einen Haken bei „anzeigen“ setzen. Ansonsten werden die Termine gefiltert und sind nicht mehr in der Termin-Liste enthalten
                • Boronsbruder
                  Boronsbruder last edited by
                  Der js_controller 3.3.15 meckert:
                  trashschedule.0	2021-08-06 19:00:05.014	info	(1453) State value to set for "trashschedule.0.type.papier.nextWeekday" has to be type "string" but received type "number"
                  trashschedule.0	2021-08-06 19:00:05.013	info	(1453) State value to set for "trashschedule.0.type.gelberSack.nextWeekday" has to be type "string" but received type "number"
                  trashschedule.0	2021-08-06 19:00:05.012	info	(1453) State value to set for "trashschedule.0.type.muell.nextWeekday" has to be type "string" but received type "number"
                  Boronsbruder 1 Reply Last reply Reply Quote 0
                    Homoran Global Moderator Administrators @haus-automatisierung last edited by
                    @boronsbruder sagte in Test Adapter TrashSchedule v1.1.x:
                    Welche Versionen hast du?
                    @haus-automatisierung sagte in Test Adapter TrashSchedule v1.1.x:
                    Eigentlich ist es relativ einfach:
                    Für alle iCal Versionen >= 1.10.0 braucht man Trashschedule Version >= 1.2.0
                    • Boronsbruder
                      Boronsbruder @Homoran last edited by
                      v1.2.0
                      Erst letztens upgedatet, wegen ical
                        Homoran Global Moderator Administrators @Boronsbruder last edited by
                        @boronsbruder OK!
                        mal bei Github nach issues gesucht?
                        Da ist keins mehr offen, aber eins geschlossen:
                        https://github.com/klein0r/ioBroker.trashschedule/issues/70#issuecomment-859474276
                        Bitte keine Issues mischen. Falls das Problem noch auftritt, einmal alle Datenpunkte unter trashshschedule.0 löschen und den Adapter neu starten.
                        Pocky2507 created this issue in klein0r/ioBroker.trashschedule
                        closed has to be type "string" but received type "object" #70
                        • Boronsbruder
                          Boronsbruder @Boronsbruder last edited by
                          @boronsbruder said in Test Adapter TrashSchedule v1.1.x:
                          Hat sich erledigt:
                          Das wurde in 57eedef schon behoben (siehe #65). Bitte keine Issues mischen. Falls das Problem noch auftritt, einmal alle Datenpunkte unter trashshschedule.0 löschen und den Adapter neu starten.
                            DragonDope last edited by
                            @haus-automatisierung Ist es möglich, dass bei next und nextAfter der Datenpunkt "Color" mit der entsprechenden Farbe hinzugefügt wird?
                              haus-automatisierung Developer Most Active @DragonDope last edited by
                              @dragondope Wenn Du mir sagst, was da drin steht, wenn zum Beispiel 2 oder 3 Typen gleichzeitig in "next" dran sind 😄
                              Beispiel: Papier (blau) und Bio (grün). Farbe von next?
                                DragonDope @haus-automatisierung last edited by
                                @haus-automatisierung Das ist eine berechtigte und schwierge Frage. Ich hätte mir eben ein entsprechendes Skript gespart, in dem ich die Farbe für die nächste Leerung herausfinde.
                                Ich würde entweder nur eine Farbe angeben. Welche das ist, sollte dann über die Reihenfolge in der Tabelle der Abfall-Typen entschieden werden.
                                Oder es wird ein zusätzlicher Datenpunkt mit den weiteren Farben erstellt.
                                Hintergrund der Frage:
                                Ich lasse mir den Abfallkalender in der VIS iQontrol anzeigen. Dort gibt es eine schöne Option, Kacheln mit einer Farbe zu umrahmen. Jetzt hätte ich gerne für die Kachel "nächste Leerung" dynamisch die entsprechende Farbe.
                                • Meister Mopper
                                  Meister Mopper @DragonDope last edited by
                                  @dragondope Dein Geschmack ist sophisticated 😊
                                  • SBorg
                                    ...oder man nimmt ein Binding in der Farbwahl:
                                    {v:_hier_Datenpunkt_; v.includes("Rest") ? #000000 : v.includes("Bio") ? #00ff00 : v.includes("Papier") ? #0000ff : #ffff00}
                                      StefanW @SBorg last edited by
                                      ich habe das Update auf die Admin Oberfläche 5.1.23 und seither startet Trash Schedule nicht mehr.
                                      Hat noch jemand das Problem, oder vielleicht sogar eine Lösung (außer Update)?
                                      Gruß & Danke
                                      Stefan
                                      Glasfaser Negalein haus-automatisierung 3 Replies Last reply Reply Quote 0
                                      • Glasfaser
                                        Glasfaser @StefanW last edited by
                                        @stefanw
                                        .... schau mal in der Meldung was da steht , deine Node ist falsch ... muß >12 sein
                                          StefanW @Glasfaser last edited by
                                          @glasfaser
                                          hab ich gelesen, deshalb ja die Frage ob es ne Möglichkeit ohne das Update gibt.Mir ist nicht klar was das Update der Admin Oberfläche damit zu tun hat.
                                          Wenn ich jetzt Node.js update mache habe ich bestimmt mehr Adapter wo nicht mehr laufen, so zu mindestens mein Gefühl.
                                          Stefan
                                          Thomas Braun Glasfaser 2 Replies Last reply Reply Quote 0
                                            Thomas Braun Most Active @StefanW last edited by Thomas Braun
                                            @stefanw
                                            NodeJS sauber updaten, fertig.
                                            Wo liegt genau das Problem?
                                            Node10 ist eh abgekündigt.
                                            adapter calendar ical kalender müll trash
                                            185
                                            1434
                                            503880
