    4. Javascript und Web Adapter laufen nicht mehr
      Thomas Braun Most Active @matzesutopia last edited by
      @matzesutopia
      iobroker update && iobroker upgrade
      Bitte auch die Rückmeldungen posten, nicht nur 'Geht nicht'
      • wendy2702
        wendy2702 @matzesutopia last edited by
        @matzesutopia was kommt auf beiden System bei
        iobroker update
          matzesutopia @Thomas Braun last edited by
          tschuldige
          matze@iobroker-master:~$ iobroker update && iobroker upgrade
          Used repository: Stable (default)
          hash changed or no sources cached => force download of new sources
          update done
          Adapter    "admin"         : 5.1.23   , installed 5.1.23
          Adapter    "alexa2"        : 3.9.3    , installed 3.9.3
          Adapter    "backitup"      : 2.1.13   , installed 2.1.15
          Adapter    "cloud"         : 4.1.0    , installed 4.1.0
          Adapter    "coronavirus-statistics": 0.6.3   , installed 0.7.1
          Adapter    "daswetter"     : 3.0.7    , installed 3.0.7
          Adapter    "devices"       : 1.0.9    , installed 1.0.9
          Adapter    "discovery"     : 2.7.0    , installed 2.7.0
          Adapter    "dwd"           : 2.7.7    , installed 2.7.7
          Adapter    "echarts"       : 0.4.13   , installed 1.0.3
          Adapter    "feiertage"     : 1.0.17   , installed 1.0.23
          Adapter    "flot"          : 1.10.6   , installed 1.10.6
          Adapter    "ham"           : 4.0.2    , installed 4.0.2
          Adapter    "history"       : 1.9.13   , installed 1.9.13
          Adapter    "hm-rega"       : 3.0.29   , installed 3.0.30
          Adapter    "hm-rpc"        : 1.14.43  , installed 1.14.43
          Adapter    "influxdb"      : 1.9.5    , installed 1.9.5
          Adapter    "info"          : 1.9.8    , installed 1.9.8
          Adapter    "iot"           : 1.8.22   , installed 1.8.22
          Adapter    "jarvis"        : 2.2.1    , installed 2.2.2
          Adapter    "javascript"    : 5.2.8    , installed 5.2.8
          Controller "js-controller" : 3.3.15   , installed 3.3.15
          Adapter    "milight-smart-light": 1.2.0   , installed 1.2.1
          Adapter    "mobile"        : 1.0.1    , installed 1.0.1
          Adapter    "nina"          : 0.0.25   , installed 0.0.25
          Adapter    "octoprint"     : 1.1.1    , installed 1.1.1
          Adapter    "onvif"         : 0.4.4    , installed 0.4.4
          Adapter    "pi-hole"       : 1.3.2    , installed 1.3.2
          Adapter    "ping"          : 1.5.0    , installed 1.5.0
          Adapter    "rpi2"          : 1.3.1    , installed 1.3.1
          Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
          Adapter    "smartcontrol"  : 1.2.1    , installed 1.2.1
          Adapter    "socketio"      : 3.1.4    , installed 3.1.4
          Adapter    "sonoff"        : 2.4.5    , installed 2.4.5
          Adapter    "spotify-premium": 1.0.0   , installed 1.1.3
          Adapter    "statistics"    : 1.0.9    , installed 1.0.9
          Adapter    "tankerkoenig"  : 2.1.1    , installed 2.1.1
          Adapter    "telegram"      : 1.10.0   , installed 1.10.0
          Adapter    "text2command"  : 2.1.1    , installed 2.1.1
          Adapter    "tr-064"        : 4.2.14   , installed 4.2.14
          Adapter    "tuya"          : 3.6.5    , installed 3.6.9
          Adapter    "virtualpowermeter": 1.4.2   , installed 1.4.2
          Adapter    "vis"           : 1.4.3    , installed 1.4.3
          Adapter    "vis-history"   : 1.0.0    , installed 1.0.0
          Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.7
          Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
          Adapter    "vis-justgage"  : 1.0.2    , installed 1.0.2
          Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
          Adapter    "web"           : 3.4.7    , installed 3.4.7
          Adapter    "wled"          : 0.5.6    , installed 0.5.6
          Adapter    "yamaha"        : 0.4.0    , installed 0.4.0
          Adapter    "zigbee"        : 1.5.6    , installed 1.5.6
          All adapters are up to date
            @matzesutopia
            iobroker upload all
            • wendy2702
              wendy2702 last edited by
              Was kommt auf dem SLAVE ?
                hatte ich gerade schon mal gemacht, aber gab keine Besserung. Muss ich den Admin auf dem Slave vielleicht löschen? Aktiviert ist er nicht
                wendy2702 Thomas Braun 2 Replies Last reply Reply Quote 0
                • wendy2702
                  @matzesutopia auf einem Slave wird kein Admin benötigt.
                  Wenn doch vorhanden muss er auch aktualisiert werden.
                    @matzesutopia
                    Rückmeldungen in der Konsole...
                    Nicht 'Hat nicht geklappt'. Da kann keiner was mit anfangen.
                      matzesutopia @wendy2702 last edited by
                      @wendy2702
                      pi@iobroker-aquarium:~ $ iobroker update && iobroker upgrade
                      hash unchanged, use cached sources
                      update done
                      Adapter    "admin"         : 5.1.23   , installed 4.2.1 [Updateable]
                      Adapter    "coronavirus-statistics": 0.6.3   , installed 0.6.3
                      Adapter    "devices"       : 1.0.9    , installed 0.3.16 [Updateable]
                      Adapter    "ds18b20"       : 1.4.1    , installed 1.4.1
                      Adapter    "fb-checkpresence": 1.1.7   , installed 1.1.7
                      Adapter    "i2c"           : 1.2.0    , installed 1.2.0
                      Adapter    "owfs"          : 0.6.4    , installed 0.6.4
                      Adapter    "vis"           : 1.4.3    , installed 1.3.6 [Updateable]
                      Required dependency "web" not found on this host.
                      This upgrade of "admin" will at least introduce the following changes:
                      -> 5.1.23:
                      Corrected some errors reported via sentry
                      -> 5.1.22:
                      -> 5.1.21:
                      -> 5.1.20:
                      -> 5.1.19:
                      Corrected some GUI errors
                      -> 5.1.18:
                      Corrected some GUI errors: theme switching, system settings
                      -> 5.1.17:
                      Corrected the error on the adapter's tab
                      BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                      Would you like to upgrade admin from @4.2.1 to @5.1.23 now? [(y)es, (n)o]:
                      wenn ich mit yes bestätige, kommt danach eine Fehlermeldung. Kleinen moment, reiche ich sofort nach
                        @matzesutopia
                          brauchst du den kompletten log davon?
                          • wendy2702
                            wendy2702 @matzesutopia last edited by wendy2702
                            @matzesutopia kurze Frage.
                            Der Aquarium war mal ein Master?
                            Benötigst du die ganzen Instanzen auf dem Slave bzw. Sind die dort überhaupt aktiv?
                            Sonst lösche alle Instanzen vom Slave die du dort nicht benötigst inklusive Admin.
                              @wendy2702
                              Would you like to upgrade admin from @4.2.1 to @5.1.23 now? [(y)es, (n)o]: y
                              Update admin from @4.2.1 to @5.1.23
                              NPM version: 6.14.12
                              npm install iobroker.admin@5.1.23 --loglevel error --prefix "/opt/iobroker" (System call)
                              npm ERR! code EINTEGRITY
                              npm ERR! errno EINTEGRITY
                              npm ERR! Invalid response body while trying to fetch https://registry.npmjs.org/depd: Integrity verification failed for sha512-4LnpbjdJ7Aia2yIhzsT7YFDSNUEVWhe/86Ht3cEAtvX2HpV81Cy1rWTq0sU9ujYWVGoahyyL4FoJZZCjs7CzJg== (/home/iobroker/.npm/_cacache/content-v2/sha512/e0/b9/e96e3749ec089adb2221cec4fb6050d23541155a17bff3a1edddc100b6f5f61e957cd42cb5ad64ead2c53dba3616546a1a872c8be05a096590a3b3b0b326)
                              npm ERR!     /home/iobroker/.npm/_logs/2021-08-06T21_15_31_482Z-debug.log
                              upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
                              upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
                              upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
                              upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                              Adapter "admin" updated
                              Invalid version of "admin". Installed "4.2.1", required ">=5.1.0
                                @matzesutopia
                                Bitte auch die Eingabezeile nicht verheimlichen.
                                cd /opt/iobroker
                                npm cache verify
                                  @wendy2702
                                  nein er war kein Master.
                                  Dort läuft auch nur I2C und der DS18B2 Adapter
                                    matze@iobroker-master:~$ cd /opt/iobroker
                                    matze@iobroker-master:/opt/iobroker$ npm cache verify
                                    Cache verified and compressed (~/.npm/_cacache):
                                    Content verified: 0 (0 bytes)
                                    Index entries: 0
                                    Finished in 0.013s
                                    pi@iobroker-aquarium:~ $ cd /opt/iobroker
                                    pi@iobroker-aquarium:/opt/iobroker $ npm cache verify
                                    Content verified: 1352 (296466020 bytes)
                                    Corrupted content removed: 10
                                    Content garbage-collected: 160 (13662853 bytes)
                                    Missing content: 10
                                    Index entries: 2137
                                    Finished in 26.679s
                                    • wendy2702
                                      @matzesutopia warum sind dann soviel installiert?
                                      Aber eigentlich egal, dein System.
                                      Aber entweder Admin Updaten oder löschen.
                                        @matzesutopia
                                        Jetzt nochmal
                                        iobroker update
                                        iobroker upgrade
                                          kommt die gleiche Fehlermeldung
                                          pi@iobroker-aquarium:~ $ iobroker upgrade
                                          -> 5.1.23:
                                          -> 5.1.22:
                                          -> 5.1.21:
                                          -> 5.1.20:
                                          -> 5.1.19:
                                          -> 5.1.18:
                                          -> 5.1.17:
                                          Bekomme den Admin Adapter auch nicht gelöscht
                                            @matzesutopia
                                            iobroker add web
                                            admin javascript update web
                                            2395
