    4. Javascript und Web Adapter laufen nicht mehr
      matzesutopia @Thomas Braun last edited by
      tschuldige
      matze@iobroker-master:~$ iobroker update && iobroker upgrade
      Used repository: Stable (default)
      hash changed or no sources cached => force download of new sources
      update done
      Adapter    "admin"         : 5.1.23   , installed 5.1.23
      Adapter    "alexa2"        : 3.9.3    , installed 3.9.3
      Adapter    "backitup"      : 2.1.13   , installed 2.1.15
      Adapter    "cloud"         : 4.1.0    , installed 4.1.0
      Adapter    "coronavirus-statistics": 0.6.3   , installed 0.7.1
      Adapter    "daswetter"     : 3.0.7    , installed 3.0.7
      Adapter    "devices"       : 1.0.9    , installed 1.0.9
      Adapter    "discovery"     : 2.7.0    , installed 2.7.0
      Adapter    "dwd"           : 2.7.7    , installed 2.7.7
      Adapter    "echarts"       : 0.4.13   , installed 1.0.3
      Adapter    "feiertage"     : 1.0.17   , installed 1.0.23
      Adapter    "flot"          : 1.10.6   , installed 1.10.6
      Adapter    "ham"           : 4.0.2    , installed 4.0.2
      Adapter    "history"       : 1.9.13   , installed 1.9.13
      Adapter    "hm-rega"       : 3.0.29   , installed 3.0.30
      Adapter    "hm-rpc"        : 1.14.43  , installed 1.14.43
      Adapter    "influxdb"      : 1.9.5    , installed 1.9.5
      Adapter    "info"          : 1.9.8    , installed 1.9.8
      Adapter    "iot"           : 1.8.22   , installed 1.8.22
      Adapter    "jarvis"        : 2.2.1    , installed 2.2.2
      Adapter    "javascript"    : 5.2.8    , installed 5.2.8
      Controller "js-controller" : 3.3.15   , installed 3.3.15
      Adapter    "milight-smart-light": 1.2.0   , installed 1.2.1
      Adapter    "mobile"        : 1.0.1    , installed 1.0.1
      Adapter    "nina"          : 0.0.25   , installed 0.0.25
      Adapter    "octoprint"     : 1.1.1    , installed 1.1.1
      Adapter    "onvif"         : 0.4.4    , installed 0.4.4
      Adapter    "pi-hole"       : 1.3.2    , installed 1.3.2
      Adapter    "ping"          : 1.5.0    , installed 1.5.0
      Adapter    "rpi2"          : 1.3.1    , installed 1.3.1
      Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
      Adapter    "smartcontrol"  : 1.2.1    , installed 1.2.1
      Adapter    "socketio"      : 3.1.4    , installed 3.1.4
      Adapter    "sonoff"        : 2.4.5    , installed 2.4.5
      Adapter    "spotify-premium": 1.0.0   , installed 1.1.3
      Adapter    "statistics"    : 1.0.9    , installed 1.0.9
      Adapter    "tankerkoenig"  : 2.1.1    , installed 2.1.1
      Adapter    "telegram"      : 1.10.0   , installed 1.10.0
      Adapter    "text2command"  : 2.1.1    , installed 2.1.1
      Adapter    "tr-064"        : 4.2.14   , installed 4.2.14
      Adapter    "tuya"          : 3.6.5    , installed 3.6.9
      Adapter    "virtualpowermeter": 1.4.2   , installed 1.4.2
      Adapter    "vis"           : 1.4.3    , installed 1.4.3
      Adapter    "vis-history"   : 1.0.0    , installed 1.0.0
      Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.7
      Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
      Adapter    "vis-justgage"  : 1.0.2    , installed 1.0.2
      Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
      Adapter    "web"           : 3.4.7    , installed 3.4.7
      Adapter    "wled"          : 0.5.6    , installed 0.5.6
      Adapter    "yamaha"        : 0.4.0    , installed 0.4.0
      Adapter    "zigbee"        : 1.5.6    , installed 1.5.6
      All adapters are up to date
        Thomas Braun Most Active @matzesutopia last edited by
        @matzesutopia
        iobroker upload all
        • wendy2702
          wendy2702 last edited by
          Was kommt auf dem SLAVE ?
            hatte ich gerade schon mal gemacht, aber gab keine Besserung. Muss ich den Admin auf dem Slave vielleicht löschen? Aktiviert ist er nicht
            wendy2702 Thomas Braun 2 Replies Last reply Reply Quote 0
            • wendy2702
              wendy2702 @matzesutopia last edited by
              @matzesutopia auf einem Slave wird kein Admin benötigt.
              Wenn doch vorhanden muss er auch aktualisiert werden.
                @matzesutopia
                Rückmeldungen in der Konsole...
                Nicht 'Hat nicht geklappt'. Da kann keiner was mit anfangen.
                  matzesutopia @wendy2702 last edited by
                  @wendy2702
                  pi@iobroker-aquarium:~ $ iobroker update && iobroker upgrade
                  hash unchanged, use cached sources
                  update done
                  Adapter    "admin"         : 5.1.23   , installed 4.2.1 [Updateable]
                  Adapter    "coronavirus-statistics": 0.6.3   , installed 0.6.3
                  Adapter    "devices"       : 1.0.9    , installed 0.3.16 [Updateable]
                  Adapter    "ds18b20"       : 1.4.1    , installed 1.4.1
                  Adapter    "fb-checkpresence": 1.1.7   , installed 1.1.7
                  Adapter    "i2c"           : 1.2.0    , installed 1.2.0
                  Adapter    "owfs"          : 0.6.4    , installed 0.6.4
                  Adapter    "vis"           : 1.4.3    , installed 1.3.6 [Updateable]
                  Required dependency "web" not found on this host.
                  This upgrade of "admin" will at least introduce the following changes:
                  -> 5.1.23:
                  Corrected some errors reported via sentry
                  -> 5.1.22:
                  -> 5.1.21:
                  -> 5.1.20:
                  -> 5.1.19:
                  Corrected some GUI errors
                  -> 5.1.18:
                  Corrected some GUI errors: theme switching, system settings
                  -> 5.1.17:
                  Corrected the error on the adapter's tab
                  BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                  Would you like to upgrade admin from @4.2.1 to @5.1.23 now? [(y)es, (n)o]:
                  wenn ich mit yes bestätige, kommt danach eine Fehlermeldung. Kleinen moment, reiche ich sofort nach
                    @matzesutopia
                      brauchst du den kompletten log davon?
                      • wendy2702
                        wendy2702 @matzesutopia last edited by wendy2702
                        @matzesutopia kurze Frage.
                        Der Aquarium war mal ein Master?
                        Benötigst du die ganzen Instanzen auf dem Slave bzw. Sind die dort überhaupt aktiv?
                        Sonst lösche alle Instanzen vom Slave die du dort nicht benötigst inklusive Admin.
                          @wendy2702
                          Would you like to upgrade admin from @4.2.1 to @5.1.23 now? [(y)es, (n)o]: y
                          Update admin from @4.2.1 to @5.1.23
                          NPM version: 6.14.12
                          npm install iobroker.admin@5.1.23 --loglevel error --prefix "/opt/iobroker" (System call)
                          npm ERR! code EINTEGRITY
                          npm ERR! errno EINTEGRITY
                          npm ERR! Invalid response body while trying to fetch https://registry.npmjs.org/depd: Integrity verification failed for sha512-4LnpbjdJ7Aia2yIhzsT7YFDSNUEVWhe/86Ht3cEAtvX2HpV81Cy1rWTq0sU9ujYWVGoahyyL4FoJZZCjs7CzJg== (/home/iobroker/.npm/_cacache/content-v2/sha512/e0/b9/e96e3749ec089adb2221cec4fb6050d23541155a17bff3a1edddc100b6f5f61e957cd42cb5ad64ead2c53dba3616546a1a872c8be05a096590a3b3b0b326)
                          npm ERR!     /home/iobroker/.npm/_logs/2021-08-06T21_15_31_482Z-debug.log
                          upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
                          upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
                          upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
                          upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                          Adapter "admin" updated
                          Invalid version of "admin". Installed "4.2.1", required ">=5.1.0
                            @matzesutopia
                            Bitte auch die Eingabezeile nicht verheimlichen.
                            cd /opt/iobroker
                            npm cache verify
                              @wendy2702
                              nein er war kein Master.
                              Dort läuft auch nur I2C und der DS18B2 Adapter
                                matze@iobroker-master:~$ cd /opt/iobroker
                                matze@iobroker-master:/opt/iobroker$ npm cache verify
                                Cache verified and compressed (~/.npm/_cacache):
                                Content verified: 0 (0 bytes)
                                Index entries: 0
                                Finished in 0.013s
                                pi@iobroker-aquarium:~ $ cd /opt/iobroker
                                pi@iobroker-aquarium:/opt/iobroker $ npm cache verify
                                Content verified: 1352 (296466020 bytes)
                                Corrupted content removed: 10
                                Content garbage-collected: 160 (13662853 bytes)
                                Missing content: 10
                                Index entries: 2137
                                Finished in 26.679s
                                • wendy2702
                                  @matzesutopia warum sind dann soviel installiert?
                                  Aber eigentlich egal, dein System.
                                  Aber entweder Admin Updaten oder löschen.
                                    @matzesutopia
                                    Jetzt nochmal
                                    iobroker update
                                    iobroker upgrade
                                      kommt die gleiche Fehlermeldung
                                      pi@iobroker-aquarium:~ $ iobroker upgrade
                                      -> 5.1.23:
                                      -> 5.1.22:
                                      -> 5.1.21:
                                      -> 5.1.20:
                                      -> 5.1.19:
                                      -> 5.1.18:
                                      -> 5.1.17:
                                      Bekomme den Admin Adapter auch nicht gelöscht
                                        @matzesutopia
                                        iobroker add web
                                          @thomas-braun und @wendy2702
                                          vielen Dank euch beiden. es funktioniert nun endlich wieder 🙂
                                          admin javascript update web
                                          2394
