    4. Javascript und Web Adapter laufen nicht mehr
    • wendy2702
      wendy2702 @matzesutopia last edited by
      @matzesutopia auf einem Slave wird kein Admin benötigt.
      Wenn doch vorhanden muss er auch aktualisiert werden.
        Thomas Braun Most Active @matzesutopia last edited by
        @matzesutopia
        Rückmeldungen in der Konsole...
        Nicht 'Hat nicht geklappt'. Da kann keiner was mit anfangen.
          matzesutopia @wendy2702 last edited by
          @wendy2702
          pi@iobroker-aquarium:~ $ iobroker update && iobroker upgrade
          Used repository: Stable (default)
          hash unchanged, use cached sources
          update done
          Adapter    "admin"         : 5.1.23   , installed 4.2.1 [Updateable]
          Adapter    "alexa2"        : 3.9.3    , installed 3.9.3
          Adapter    "backitup"      : 2.1.13   , installed 2.1.15
          Adapter    "cloud"         : 4.1.0    , installed 4.1.0
          Adapter    "coronavirus-statistics": 0.6.3   , installed 0.6.3
          Adapter    "daswetter"     : 3.0.7    , installed 3.0.7
          Adapter    "devices"       : 1.0.9    , installed 0.3.16 [Updateable]
          Adapter    "discovery"     : 2.7.0    , installed 2.7.0
          Adapter    "ds18b20"       : 1.4.1    , installed 1.4.1
          Adapter    "dwd"           : 2.7.7    , installed 2.7.7
          Adapter    "echarts"       : 0.4.13   , installed 1.0.3
          Adapter    "fb-checkpresence": 1.1.7   , installed 1.1.7
          Adapter    "feiertage"     : 1.0.17   , installed 1.0.23
          Adapter    "flot"          : 1.10.6   , installed 1.10.6
          Adapter    "history"       : 1.9.13   , installed 1.9.13
          Adapter    "i2c"           : 1.2.0    , installed 1.2.0
          Adapter    "influxdb"      : 1.9.5    , installed 1.9.5
          Adapter    "info"          : 1.9.8    , installed 1.9.8
          Controller "js-controller" : 3.3.15   , installed 3.3.15
          Adapter    "mobile"        : 1.0.1    , installed 1.0.1
          Adapter    "nina"          : 0.0.25   , installed 0.0.25
          Adapter    "octoprint"     : 1.1.1    , installed 1.1.1
          Adapter    "owfs"          : 0.6.4    , installed 0.6.4
          Adapter    "ping"          : 1.5.0    , installed 1.5.0
          Adapter    "rpi2"          : 1.3.1    , installed 1.3.1
          Adapter    "smartcontrol"  : 1.2.1    , installed 1.2.1
          Adapter    "spotify-premium": 1.0.0   , installed 1.1.3
          Adapter    "statistics"    : 1.0.9    , installed 1.0.9
          Adapter    "tankerkoenig"  : 2.1.1    , installed 2.1.1
          Adapter    "text2command"  : 2.1.1    , installed 2.1.1
          Adapter    "tuya"          : 3.6.5    , installed 3.6.9
          Adapter    "virtualpowermeter": 1.4.2   , installed 1.4.2
          Adapter    "vis"           : 1.4.3    , installed 1.3.6 [Updateable]
          Adapter    "vis-history"   : 1.0.0    , installed 1.0.0
          Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.7
          Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
          Adapter    "vis-justgage"  : 1.0.2    , installed 1.0.2
          Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
          Adapter    "wled"          : 0.5.6    , installed 0.5.6
          Required dependency "web" not found on this host.
          This upgrade of "admin" will at least introduce the following changes:
          -> 5.1.23:
          Corrected some errors reported via sentry
          -> 5.1.22:
          -> 5.1.21:
          -> 5.1.20:
          -> 5.1.19:
          Corrected some GUI errors
          -> 5.1.18:
          Corrected some GUI errors: theme switching, system settings
          -> 5.1.17:
          Corrected the error on the adapter's tab
          BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
          Would you like to upgrade admin from @4.2.1 to @5.1.23 now? [(y)es, (n)o]:
          wenn ich mit yes bestätige, kommt danach eine Fehlermeldung. Kleinen moment, reiche ich sofort nach
            @matzesutopia
              matzesutopia @Thomas Braun last edited by
              brauchst du den kompletten log davon?
              • wendy2702
                wendy2702 @matzesutopia last edited by wendy2702
                @matzesutopia kurze Frage.
                Der Aquarium war mal ein Master?
                Benötigst du die ganzen Instanzen auf dem Slave bzw. Sind die dort überhaupt aktiv?
                Sonst lösche alle Instanzen vom Slave die du dort nicht benötigst inklusive Admin.
                  @wendy2702
                  Would you like to upgrade admin from @4.2.1 to @5.1.23 now? [(y)es, (n)o]: y
                  Update admin from @4.2.1 to @5.1.23
                  NPM version: 6.14.12
                  npm install iobroker.admin@5.1.23 --loglevel error --prefix "/opt/iobroker" (System call)
                  npm ERR! code EINTEGRITY
                  npm ERR! errno EINTEGRITY
                  npm ERR! Invalid response body while trying to fetch https://registry.npmjs.org/depd: Integrity verification failed for sha512-4LnpbjdJ7Aia2yIhzsT7YFDSNUEVWhe/86Ht3cEAtvX2HpV81Cy1rWTq0sU9ujYWVGoahyyL4FoJZZCjs7CzJg== (/home/iobroker/.npm/_cacache/content-v2/sha512/e0/b9/e96e3749ec089adb2221cec4fb6050d23541155a17bff3a1edddc100b6f5f61e957cd42cb5ad64ead2c53dba3616546a1a872c8be05a096590a3b3b0b326)
                  npm ERR!     /home/iobroker/.npm/_logs/2021-08-06T21_15_31_482Z-debug.log
                  upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
                  upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
                  upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
                  upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                  Adapter "admin" updated
                  Invalid version of "admin". Installed "4.2.1", required ">=5.1.0
                    @matzesutopia
                    Bitte auch die Eingabezeile nicht verheimlichen.
                    cd /opt/iobroker
                    npm cache verify
                      @wendy2702
                      nein er war kein Master.
                      Dort läuft auch nur I2C und der DS18B2 Adapter
                        matze@iobroker-master:~$ cd /opt/iobroker
                        matze@iobroker-master:/opt/iobroker$ npm cache verify
                        Cache verified and compressed (~/.npm/_cacache):
                        Content verified: 0 (0 bytes)
                        Index entries: 0
                        Finished in 0.013s
                        pi@iobroker-aquarium:~ $ cd /opt/iobroker
                        pi@iobroker-aquarium:/opt/iobroker $ npm cache verify
                        Content verified: 1352 (296466020 bytes)
                        Corrupted content removed: 10
                        Content garbage-collected: 160 (13662853 bytes)
                        Missing content: 10
                        Index entries: 2137
                        Finished in 26.679s
                        • wendy2702
                          @matzesutopia warum sind dann soviel installiert?
                          Aber eigentlich egal, dein System.
                          Aber entweder Admin Updaten oder löschen.
                            @matzesutopia
                            Jetzt nochmal
                            iobroker update
                            iobroker upgrade
                              kommt die gleiche Fehlermeldung
                              pi@iobroker-aquarium:~ $ iobroker upgrade
                              -> 5.1.23:
                              -> 5.1.22:
                              -> 5.1.21:
                              -> 5.1.20:
                              -> 5.1.19:
                              -> 5.1.18:
                              -> 5.1.17:
                              Bekomme den Admin Adapter auch nicht gelöscht
                                @matzesutopia
                                iobroker add web
                                  @thomas-braun und @wendy2702
                                  vielen Dank euch beiden. es funktioniert nun endlich wieder 🙂
                                  admin javascript update web
                                  2395
