    4. MQTT-FEHLER
    MQTT-FEHLER
      AndyUM61 last edited by
      Scheint leider noch nicht zu funktionieren.
      Ich habe an 4 verschiedenen Stellen die Datei writeToStream.js
      Habe alle vier mal ausgetauscht (mit Sicherung natürlich).
      SERVER	2017-02-03 14:00:32.835	info	host.ARGO-SERVER Restart adapter system.adapter.mqtt.0 because enabled
      ARGO-SERVER	2017-02-03 14:00:32.835	error	host.ARGO-SERVER instance system.adapter.mqtt.0 terminated with code 6 (uncaught exception)
      mqtt.0	2017-02-03 14:00:31.801	error	mqtt.0 Error: Cannot find module './constants' at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:17) a
      mqtt.0	2017-02-03 14:00:31.799	error	mqtt.0 uncaught exception: Cannot find module './constants'
      host.ARGO-SERVER	2017-02-03 14:00:29.249	info	instance system.adapter.mqtt.0 started with pid 6900
      host.ARGO-SERVER	2017-02-03 14:00:19.547	info	Restart adapter system.adapter.mqtt.0 because enabled
      host.ARGO-SERVER	2017-02-03 14:00:19.545	error	instance system.adapter.mqtt.0 terminated with code 6 (uncaught exception)
      mqtt.0	2017-02-03 14:00:18.501	error	at require (internal/module.js:12:17)
      mqtt.0	2017-02-03 14:00:18.501	error	at Module.require (module.js:353:17)
      mqtt.0	2017-02-03 14:00:18.501	error	at Function.Module._load (module.js:300:12)
      mqtt.0	2017-02-03 14:00:18.501	error	at Module.load (module.js:343:32)
      mqtt.0	2017-02-03 14:00:18.501	error	at Object.Module._extensions..js (module.js:416:10)
      mqtt.0	2017-02-03 14:00:18.501	error	at Module._compile (module.js:409:26)
      mqtt.0	2017-02-03 14:00:18.501	error	at Object. (C:\Program Files\ioBroker\node_modules\iobroker.mqtt\node_modules\mqtt-connection\lib\writeToStream.js:3:16)
      mqtt.0	2017-02-03 14:00:18.501	error	at Function.Module._load (module.js:276:25)
      mqtt.0	2017-02-03 14:00:18.501	error	at Function.Module._resolveFilename (module.js:325:15)
      mqtt.0	2017-02-03 14:00:18.501	error	Error: Cannot find module './constants'
      mqtt.0	2017-02-03 14:00:18.484	error	uncaught exception: Cannot find module './constants'
      P.S.:
      Ich habe die Dateien erst alle ausgetauscht, danach die Version 1.3.5. installiert.
      Das scheint nicht zu funktionieren.
      Mit der Version 1.2.5 scheint es zu funktionieren.
      Allerdings läuft die 1.2.5 ja sowieso irgendwie besser .
      • Bluefox
        Bluefox last edited by
        Alle Dateien auszutauschen ist falsch.
        Nur die, die ich benannt habe.
        Du hast komplett andere Datei mit überschrieben.
        Vergleich mal:
        https://github.com/mqttjs/mqtt-connecti … oStream.js
        und
        https://github.com/GermanBluefox/mqtt-p ... oStream.js
        Namen sind gleich, aber die sind komplett anders.
        gut dass, die Datei nicht index.js heißt. :lol:
          Leider scheint es aber diese Pfade in der Windows-Version von ioBroker nicht zu geben 😞
          Wo soll ich dann genau die Datei austauschen?
          • Bluefox
            @AndyUM61:
            Wo soll ich dann genau die Datei austauschen? `
            Das hängt davon ab, welche npm version du hast. ich vermute 2.15.xxx
            Dann solltest du hier eine Datei finden:
            C:\Program Files\ioBroker\node_modules\iobroker.mqtt\node_modules\mqtt-connection\node_modules\mqtt-packet\writeToStream.js
              Wie es aussieht, funktioniert das jetzt:).
              Ich habe die entsprechende Datei ausgetauscht.
              DANKESCHÖN:)!!
              Vielleicht kann das ja bei dem nächsten Update eingepflegt werden;).
              • Bluefox
                @AndyUM61:
                DANKESCHÖN:)!!
                Vielleicht kann das ja bei dem nächsten Update eingepflegt werden;). `
                Es wird eingepflegt, sonst gibt es kein nächsten Update 🙂
                • Alex1808
                  Alex1808 last edited by
                  Bei mir hat auch funktioniert!
                  Danke!
                  • Bluefox
                    Schaut mal, was ich machen muss nun eure "falsch implementierte" Clients zu unterstützen. 😄
                    https://github.com/mqttjs/mqtt-packet/i … -277351131
                    Das ist mühsam....
                    • Bluefox
                      Habe alles abgecheckt. Fazit: schmeißt eure MQTT clients in die Tonne. :lol:
                      • Alex1808
                        @Bluefox:
                        Habe alles abgecheckt. Fazit: schmeißt eure MQTT clients in die Tonne. :lol: `
                        Es gibt keine alternative..? 😞
                        Die alte version (1.2.5) vom MQTT server hat doch funktioniert :? Mit deinem Fix geht auch die neue. Ist klar, das ist nur Übergangs Lösung, aber die Tonne soll noch warten 🙂
                        • Bluefox
                          @Alex1808:
                          @Bluefox:
                          Die alte version (1.2.5) vom MQTT server hat doch funktioniert :? Mit deinem Fix geht auch die neue. Ist klar, das ist nur Übergangs Lösung, aber die Tonne soll noch warten 🙂 `
                          Fix beweist, dass meine Vermutung richtig ist.
                          1.2.5 hat nur zufällig funktioniert.
                          Andy was für einen Client hast du?
                          • Thisoft
                            Thisoft last edited by
                            Hmm - das würde mich auch mal interessieren was ihr für Clients habt.
                            Ich habe nämlich mit meinen 2 Arduinos die ich über MQTT angebunden habe den Fehler glücklicherweise noch nicht gehabt. Und ich habe vor, diese Schiene von Arduino über MQTT weiter auszubauen. Aber wenn da ein Systemfehler in MQTT ist?? Könnte der dann auch irgendwo mal zuschlagen? Ich habe jetzt leider nicht so wirklich verstanden was der Grund ist - dazu bin ich zu wenig Netzwerker, ich bin mehr in Datenbanken zu Hause…
                              Guten Morgen:).
                              Also ich habe 12 ESP8266-Clients in Nutzung.
                              Davon laufen einige als reine Sender und einige auch als Actoren.
                              Basis ist die PubClient-Library in der Arduino IDE.
                              Das funktioniert auch top.
                              Meine "Grundscripts" habe ich ja schon vor einiger Zeit unter "Praktische Anwendungen" veröffentlicht.
                              Ich denke, MQTT ist ein wirklich ziemlich zuverlässiges Verfahren.
                              • N
                                nop0 last edited by
                                Hallo Kollegen,
                                in die letzten Tagen habe ich auch Probleme mit dem MQTT-Adapter (s. log unten). Habe 4 ESP8266 im Einsatz, node.js 4.2.6. Weder der downgrade auf MQTT 1.2.5 noch den scriptaustaush haben geholfen.
                                Ich habe die Datei writeToStream.js an 5 stellen:
                                osmc@osmc:~$ find /opt -name writeToStream.js
                                1 -/opt/iobroker/node_modules/iobroker.mqtt/node_modules/mqtt-connection/lib/writeToStream.js
                                2 -/opt/iobroker/node_modules/iobroker.mqtt/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js
                                3 -/opt/iobroker/node_modules/iobroker.mqtt/node_modules/mqtt-connection/node_modules/mqtt-packet/benchmarks/writeToStream.js
                                4 -/opt/iobroker/node_modules/iobroker.mqtt/node_modules/mqtt/node_modules/mqtt-packet/writeToStream.js
                                5 -/opt/iobroker/node_modules/iobroker.mqtt/node_modules/mqtt/node_modules/mqtt-packet/benchmarks/writeToStream.js
                                habe 2 und 4 (nacheinander) ausprobiert auszutauschen - leider mit Fehler:
                                beim 2:
                                osmc	2017-02-07 18:05:00.667	error	host.osmc instance system.adapter.mqtt.0 terminated with code 6 (uncaught exception)
                                mqtt.0	2017-02-07 18:04:59.662	error	mqtt.0 SyntaxError: Unexpected token ILLEGAL at exports.runInThisContext (vm.js:53:16) at Module._compile (module.js:374:25) at Object.Module._extensions..js (module.js:417:10) at Modu
                                mqtt.0	2017-02-07 18:04:59.655	error	mqtt.0 uncaught exception: Unexpected token ILLEGAL
                                beim 4 - gleichen Fehler wie im Log (uncaught exception: parts.trim is not a function).
                                Hat jemand Ideen?
                                LOG vom MQTT 1.2.5:
                                mqtt.0 2017-02-07 15:56:18.556 error mqtt.0 TypeError: parts.trim is not a function at receivedTopic (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:301:59) at Connection. (/opt/iobroker/node_modules/iobroker.m
                                mqtt.0 2017-02-07 15:56:18.555 error mqtt.0 uncaught exception: parts.trim is not a function
                                mqtt.0 2017-02-07 15:56:18.545 error mqtt.0 Closed because of error
                                mqtt.0 2017-02-07 15:55:25.956 error at Connection.Duplexify._forward (/opt/iobroker/node_modules/iobroker.mqtt/node_modules/mqtt-connection/node_modules/duplexify/index.js:163:26)
                                mqtt.0 2017-02-07 15:55:25.956 error at Connection.Readable.push (/opt/iobroker/node_modules/readable-stream/lib/_stream_readable.js:157:10)
                                mqtt.0 2017-02-07 15:55:25.956 error at readableAddChunk (/opt/iobroker/node_modules/readable-stream/lib/_stream_readable.js:198:18)
                                mqtt.0 2017-02-07 15:55:25.956 error at Connection.emit (events.js:169:7)
                                mqtt.0 2017-02-07 15:55:25.956 error at emitOne (events.js:77:13)
                                mqtt.0 2017-02-07 15:55:25.956 error at Connection.emitPacket (/opt/iobroker/node_modules/iobroker.mqtt/node_modules/mqtt-connection/connection.js:14:8)
                                mqtt.0 2017-02-07 15:55:25.956 error at Connection. (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:423:17)
                                mqtt.0 2017-02-07 15:55:25.956 error at receivedTopic (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:301:59)
                                mqtt.0 2017-02-07 15:55:25.956 error TypeError: parts.trim is not a function
                                mqtt.0 2017-02-07 15:55:25.930 error uncaught exception: parts.trim is not a function
                                mqtt.0 2017-02-07 15:50:06.552 error Closed because of error
                                mqtt.0 2017-02-07 15:49:14.597 error at Connection.Duplexify._forward (/opt/iobroker/node_modules/iobroker.mqtt/node_modules/mqtt-connection/node_modules/duplexify/index.js:163:26)
                                mqtt.0 2017-02-07 15:49:14.597 error at Connection.Readable.push (/opt/iobroker/node_modules/readable-stream/lib/_stream_readable.js:157:10)
                                mqtt.0 2017-02-07 15:49:14.597 error at readableAddChunk (/opt/iobroker/node_modules/readable-stream/lib/_stream_readable.js:198:18)
                                mqtt.0 2017-02-07 15:49:14.597 error at Connection.emit (events.js:169:7)
                                mqtt.0 2017-02-07 15:49:14.597 error at emitOne (events.js:77:13)
                                mqtt.0 2017-02-07 15:49:14.597 error at Connection.emitPacket (/opt/iobroker/node_modules/iobroker.mqtt/node_modules/mqtt-connection/connection.js:14:8)
                                mqtt.0 2017-02-07 15:49:14.597 error at Connection. (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:423:17)
                                mqtt.0 2017-02-07 15:49:14.597 error at receivedTopic (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:301:59)
                                mqtt.0 2017-02-07 15:49:14.597 error TypeError: parts.trim is not a function
                                mqtt.0 2017-02-07 15:49:14.539 error uncaught exception: parts.trim is not a function
                                mqtt.0 2017-02-07 15:48:24.443 error at Connection.Duplexify._forward (/opt/iobroker/node_modules/iobroker.mqtt/node_modules/mqtt-connection/node_modules/duplexify/index.js:163:26)
                                mqtt.0 2017-02-07 15:48:24.443 error at Connection.Readable.push (/opt/iobroker/node_modules/readable-stream/lib/_stream_readable.js:157:10)
                                mqtt.0 2017-02-07 15:48:24.443 error at readableAddChunk (/opt/iobroker/node_modules/readable-stream/lib/_stream_readable.js:198:18)
                                mqtt.0 2017-02-07 15:48:24.443 error at Connection.emit (events.js:169:7)
                                mqtt.0 2017-02-07 15:48:24.443 error at emitOne (events.js:77:13)
                                mqtt.0 2017-02-07 15:48:24.443 error at Connection.emitPacket (/opt/iobroker/node_modules/iobroker.mqtt/node_modules/mqtt-connection/connection.js:14:8)
                                mqtt.0 2017-02-07 15:48:24.443 error at Connection. (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:423:17)
                                mqtt.0 2017-02-07 15:48:24.443 error at receivedTopic (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:301:59)
                                mqtt.0 2017-02-07 15:48:24.443 error TypeError: parts.trim is not a function
                                mqtt.0 2017-02-07 15:48:24.392 error uncaught exception: parts.trim is not a function
                                mqtt.0 2017-02-07 15:47:36.787 error at Connection.Duplexify._forward (/opt/iobroker/node_modules/iobroker.mqtt/node_modules/mqtt-connection/node_modules/duplexify/index.js:163:26)
                                mqtt.0 2017-02-07 15:47:36.787 error at Connection.Readable.push (/opt/iobroker/node_modules/readable-stream/lib/_stream_readable.js:157:10)
                                mqtt.0 2017-02-07 15:47:36.787 error at readableAddChunk (/opt/iobroker/node_modules/readable-stream/lib/_stream_readable.js:198:18)
                                mqtt.0 2017-02-07 15:47:36.787 error at Connection.emit (events.js:169:7)
                                mqtt.0 2017-02-07 15:47:36.787 error at emitOne (events.js:77:13)
                                mqtt.0 2017-02-07 15:47:36.787 error at Connection.emitPacket (/opt/iobroker/node_modules/iobroker.mqtt/node_modules/mqtt-connection/connection.js:14:8)
                                mqtt.0 2017-02-07 15:47:36.787 error at Connection. (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:423:17)
                                mqtt.0 2017-02-07 15:47:36.787 error at receivedTopic (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:301:59)
                                mqtt.0 2017-02-07 15:47:36.787 error TypeError: parts.trim is not a function
                                mqtt.0 2017-02-07 15:47:36.733 error uncaught exception: parts.trim is not a function
                                mqtt.0 2017-02-07 15:46:50.613 error at Connection.Duplexify._forward (/opt/iobroker/node_modules/iobroker.mqtt/node_modules/mqtt-connection/node_modules/duplexify/index.js:163:26)
                                mqtt.0 2017-02-07 15:46:50.613 error at Connection.Readable.push (/opt/iobroker/node_modules/readable-stream/lib/_stream_readable.js:157:10)
                                mqtt.0 2017-02-07 15:46:50.613 error at readableAddChunk (/opt/iobroker/node_modules/readable-stream/lib/_stream_readable.js:198:18)
                                mqtt.0 2017-02-07 15:46:50.613 error at Connection.emit (events.js:169:7)
                                mqtt.0 2017-02-07 15:46:50.613 error at emitOne (events.js:77:13)
                                mqtt.0 2017-02-07 15:46:50.613 error at Connection.emitPacket (/opt/iobroker/node_modules/iobroker.mqtt/node_modules/mqtt-connection/connection.js:14:8)
                                mqtt.0 2017-02-07 15:46:50.613 error at Connection. (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:423:17)
                                mqtt.0 2017-02-07 15:46:50.613 error at receivedTopic (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:301:59)
                                mqtt.0 2017-02-07 15:46:50.613 error TypeError: parts.trim is not a function
                                mqtt.0 2017-02-07 15:46:50.550 error uncaught exception: parts.trim is not a function
                                mqtt.0 2017-02-07 15:46:06.202 error at Connection.Duplexify._forward (/opt/iobroker/node_modules/iobroker.mqtt/node_modules/mqtt-connection/node_modules/duplexify/index.js:163:26)
                                mqtt.0 2017-02-07 15:46:06.202 error at Connection.Readable.push (/opt/iobroker/node_modules/readable-stream/lib/_stream_readable.js:157:10)
                                mqtt.0 2017-02-07 15:46:06.202 error at readableAddChunk (/opt/iobroker/node_modules/readable-stream/lib/_stream_readable.js:198:18)
                                mqtt.0 2017-02-07 15:46:06.202 error at Connection.emit (events.js:169:7)
                                mqtt.0 2017-02-07 15:46:06.202 error at emitOne (events.js:77:13)
                                mqtt.0 2017-02-07 15:46:06.202 error at Connection.emitPacket (/opt/iobroker/node_modules/iobroker.mqtt/node_modules/mqtt-connection/connection.js:14:8)
                                mqtt.0 2017-02-07 15:46:06.202 error at Connection. (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:423:17)
                                mqtt.0 2017-02-07 15:46:06.202 error at receivedTopic (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:301:59)
                                mqtt.0 2017-02-07 15:46:06.202 error TypeError: parts.trim is not a function
                                mqtt.0 2017-02-07 15:46:06.180 error uncaught exception: parts.trim is not a function
                                mqtt.0 2017-02-07 15:45:41.257 error Closed because of error
                                mqtt.0 2017-02-07 15:44:52.747 error at Connection.Duplexify._forward (/opt/iobroker/node_modules/iobroker.mqtt/node_modules/mqtt-connection/node_modules/duplexify/index.js:163:26)
                                mqtt.0 2017-02-07 15:44:52.747 error at Connection.Readable.push (/opt/iobroker/node_modules/readable-stream/lib/_stream_readable.js:157:10)
                                mqtt.0 2017-02-07 15:44:52.747 error at readableAddChunk (/opt/iobroker/node_modules/readable-stream/lib/_stream_readable.js:198:18)
                                mqtt.0 2017-02-07 15:44:52.747 error at Connection.emit (events.js:169:7)
                                mqtt.0 2017-02-07 15:44:52.747 error at emitOne (events.js:77:13)
                                mqtt.0 2017-02-07 15:44:52.747 error at Connection.emitPacket (/opt/iobroker/node_modules/iobroker.mqtt/node_modules/mqtt-connection/connection.js:14:8)
                                mqtt.0 2017-02-07 15:44:52.747 error at Connection. (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:423:17)
                                mqtt.0 2017-02-07 15:44:52.747 error at receivedTopic (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:301:59)
                                mqtt.0 2017-02-07 15:44:52.747 error TypeError: parts.trim is not a function
                                mqtt.0 2017-02-07 15:44:52.717 error uncaught exception: parts.trim is not a function
                                mqtt.0 2017-02-07 15:37:31.217 error Closed because of error
                                mqtt.0 2017-02-07 15:36:42.850 error at Connection.Duplexify._forward (/opt/iobroker/node_modules/iobroker.mqtt/node_modules/mqtt-connection/node_modules/duplexify/index.js:163:26)
                                mqtt.0 2017-02-07 15:36:42.850 error at Connection.Readable.push (/opt/iobroker/node_modules/readable-stream/lib/_stream_readable.js:157:10)
                                mqtt.0 2017-02-07 15:36:42.850 error at readableAddChunk (/opt/iobroker/node_modules/readable-stream/lib/_stream_readable.js:198:18)
                                mqtt.0 2017-02-07 15:36:42.850 error at Connection.emit (events.js:169:7)
                                mqtt.0 2017-02-07 15:36:42.850 error at emitOne (events.js:77:13)
                                mqtt.0 2017-02-07 15:36:42.850 error at Connection.emitPacket (/opt/iobroker/node_modules/iobroker.mqtt/node_modules/mqtt-connection/connection.js:14:8)
                                mqtt.0 2017-02-07 15:36:42.850 error at Connection. (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:423:17)
                                mqtt.0 2017-02-07 15:36:42.850 error at receivedTopic (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:301:59)
                                mqtt.0 2017-02-07 15:36:42.850 error TypeError: parts.trim is not a function
                                mqtt.0 2017-02-07 15:36:42.827 error uncaught exception: parts.trim is not a function
                                mqtt.0 2017-02-07 15:32:53.630 error Closed because of error
                                mqtt.0 2017-02-07 15:32:05.886 error at Connection.Duplexify._forward (/opt/iobroker/node_modules/iobroker.mqtt/node_modules/mqtt-connection/node_modules/duplexify/index.js:163:26)
                                mqtt.0 2017-02-07 15:32:05.886 error at Connection.Readable.push (/opt/iobroker/node_modules/readable-stream/lib/_stream_readable.js:157:10)
                                mqtt.0 2017-02-07 15:32:05.886 error at readableAddChunk (/opt/iobroker/node_modules/readable-stream/lib/_stream_readable.js:198:18)
                                mqtt.0 2017-02-07 15:32:05.886 error at Connection.emit (events.js:169:7)
                                mqtt.0 2017-02-07 15:32:05.886 error at emitOne (events.js:77:13)
                                mqtt.0 2017-02-07 15:32:05.886 error at Connection.emitPacket (/opt/iobroker/node_modules/iobroker.mqtt/node_modules/mqtt-connection/connection.js:14:8)
                                mqtt.0 2017-02-07 15:32:05.886 error at Connection. (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:423:17)
                                mqtt.0 2017-02-07 15:32:05.886 error at receivedTopic (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:301:59)
                                mqtt.0 2017-02-07 15:32:05.886 error TypeError: parts.trim is not a function
                                mqtt.0 2017-02-07 15:32:05.864 error uncaught exception: parts.trim is not a function
                                mqtt.0 2017-02-07 15:32:05.757 error Closed because of error
                                mqtt.0 2017-02-07 15:31:15.578 error at Connection.Duplexify._forward (/opt/iobroker/node_modules/iobroker.mqtt/node_modules/mqtt-connection/node_modules/duplexify/index.js:163:26)
                                mqtt.0 2017-02-07 15:31:15.578 error at Connection.Readable.push (/opt/iobroker/node_modules/readable-stream/lib/_stream_readable.js:157:10)
                                mqtt.0 2017-02-07 15:31:15.578 error at readableAddChunk (/opt/iobroker/node_modules/readable-stream/lib/_stream_readable.js:198:18)
                                mqtt.0 2017-02-07 15:31:15.578 error at Connection.emit (events.js:169:7)
                                mqtt.0 2017-02-07 15:31:15.578 error at emitOne (events.js:77:13)
                                mqtt.0 2017-02-07 15:31:15.578 error at Connection.emitPacket (/opt/iobroker/node_modules/iobroker.mqtt/node_modules/mqtt-connection/connection.js:14:8)
                                mqtt.0 2017-02-07 15:31:15.578 error at Connection. (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:423:17)
                                mqtt.0 2017-02-07 15:31:15.578 error at receivedTopic (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:301:59)
                                mqtt.0 2017-02-07 15:31:15.578 error TypeError: parts.trim is not a function
                                mqtt.0 2017-02-07 15:31:15.550 error uncaught exception: parts.trim is not a function
                                mqtt.0 2017-02-07 15:30:37.441 error Closed because of error
                                mqtt.0 2017-02-07 15:29:48.190 error at Connection.Duplexify._forward (/opt/iobroker/node_modules/iobroker.mqtt/node_modules/mqtt-connection/node_modules/duplexify/index.js:163:26)
                                mqtt.0 2017-02-07 15:29:48.190 error at Connection.Readable.push (/opt/iobroker/node_modules/readable-stream/lib/_stream_readable.js:157:10)
                                mqtt.0 2017-02-07 15:29:48.190 error at readableAddChunk (/opt/iobroker/node_modules/readable-stream/lib/_stream_readable.js:198:18)
                                mqtt.0 2017-02-07 15:29:48.190 error at Connection.emit (events.js:169:7)
                                mqtt.0 2017-02-07 15:29:48.190 error at emitOne (events.js:77:13)
                                mqtt.0 2017-02-07 15:29:48.190 error at Connection.emitPacket (/opt/iobroker/node_modules/iobroker.mqtt/node_modules/mqtt-connection/connection.js:14:8)
                                mqtt.0 2017-02-07 15:29:48.190 error at Connection. (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:423:17)
                                mqtt.0 2017-02-07 15:29:48.190 error at receivedTopic (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:301:59)
                                mqtt.0 2017-02-07 15:29:48.190 error TypeError: parts.trim is not a function
                                mqtt.0 2017-02-07 15:29:48.156 error uncaught exception: parts.trim is not a function
                                mqtt.0 2017-02-07 15:29:38.893 error Closed because of error
                                • Bluefox
                                  Lösche mal das Verzeichnis
                                  und installiere
                                  cd /opt/iobroker
                                  npm i iobroker.mqtt@1.2.5
                                  Aber das Problem ist in dem Client. Am besten das benutzen: https://github.com/knolleary/pubsubclient
                                  • N
                                    nop0 last edited by
                                    Hallo Bluefox,
                                    danke für den Tipp, habe ich gemacht. Ich benutze schon die PubSubClient in ESP8266 (s. Screenschot). Habe mittlerweile mein Fehler gefunden (parts.trim is not a function). Ich habe versucht Daten über MQTT zu übergeben, formatiert in eckige klammern [] und Komma. Das hat der MQTT-Brocker böse geärgert.
                                    Der downgrade auf MQTT 1.2.5 hat leider nicht geholfen (habe ich früher auch probiert) - bekomme immer noch eine einzige Meldung - "Closed because of error" (MQTT Adapter).
                                    Ich frage mich wieso hat das MQTT monatelang funktioniert und jetzt plötzlich nicht?
                                    • Bluefox
                                      Prüfe bitte, was für eine Version von mqtt-packet du hast?
                                      Hast du an dieser Stelle den Fehler?
                                      https://github.com/ioBroker/ioBroker.mq … in.js#L148
                                      • N
                                        nop0 last edited by
                                        Hallo nochmal Bluefox,
                                        wie meinst du, welche Version von MQTT-Packet?
                                        Das ESP-Programm wird mit PubSubClient Library v.2.6.0 kompiliert (s. Screenshot oben).
                                        Der MQTT-Brocker hat die Version 1.2.5 (wie oben empfohlen - npm i iobroker.mqtt@1.2.5). Es lässt sich auch nicht mehr per web-interface hochrüsten (weder auf 1.3.0, noch auf 1.3.1 vom Github) - stirbt mit Fehler 25. Per ssh nicht probiert. Erstmals die 1.2.5 gelassen, obwohl das Problem mit dem reset noch besteht ("Closed because of error").
                                        Die Fehler mit trim wurde nicht vom ioBroker, sonder vom ESP-Seite verursacht (und schon beseitigt - s. unten), deine Frage betrifft aber die ioBroker-Seite. Wenn ich zuhause bin, werde versuchen die "Bekanntgeben eigene States beim Verbinden" auszuschalten - wenn ich dein Vorschlag richtig verstehe (Zeile 148 vom main.js).
                                        Zu der Fehler mit "parts.trim is not a function". Ich habe auf meinem ESP8266 ein String erzeugt, im Form von:
                                        "text=[Zahl,Zahl,Zahl,Zahl,Zahl,Zahl]text=01101010...u.s.w. 01 sequenz"
                                        mit länge nicht mehr als 50-60 Zeichen. Dieses String wollte ich im einen Topic publischen (und die Topic wie immer bis jetzt im ioBroker automatisch erzeugen lassen). Dieses String hat aber den ioBroker MQTT Adapter zum absturz gebracht mit dem Meldung "parts.trim is not a function". Ich habe im ESP-Programm die eckige klammer mit dem String "start" und "end" und die kommaseparator mit dem Buchstabe "t" ausgetauscht und dann siehe da - die Variable (Topic) wurde automatisch im ioBrocker eingelegt und den gewünschten Inhalt wird übertragen. Kein Fehlermeldung wegen trim mehr.
                                        "text=startZahltZahltZahltZahltZahltZahlendtext=01101010...u.s.w. 01 sequenz"
                                        Ob die kommaseparator oder die "[]" der Brocker zum abstürz brachten weis ich nicht (habe auf einmahl kompiliert und per OTA eingespielt). Experimentierereien mit genau diesen node will ich nicht wirklich, weil schwer zugänglich, und wenn die node nicht mit MQTT verbunden ist (z.B. MQTT-Brocker abgestürzt), das laden des Programms via OTA funktioniert nicht wirklich (die Seite zum laden des Firmwares öffnet sich nicht, weil das ESP-Programm beschäftigt ist die MQTT-Verbindung aufzubauen - ein Teufelskreis, meine Programmierung ist nicht sauber an diese Stelle).
                                        • Bluefox
                                          @nop0:
                                          Ob die kommaseparator oder die "[]" der Brocker zum abstürz brachten weis ich nicht (habe auf einmahl kompiliert und per OTA eingespielt). Experimentierereien mit genau diesen node will ich nicht wirklich, weil schwer zugänglich, und wenn die node nicht mit MQTT verbunden ist (z.B. MQTT-Brocker abgestürzt), das laden des Programms via OTA funktioniert nicht wirklich (die Seite zum laden des Firmwares öffnet sich nicht, weil das ESP-Programm beschäftigt ist die MQTT-Verbindung aufzubauen - ein Teufelskreis, meine Programmierung ist nicht sauber an diese Stelle). `
                                          Ich habe natürlich ioBroker Seite gemeint und auch "mqtt-packet" als npm packet. Sollte irgendwo in node_modules drin sein.
                                          Dein Payload passt zu folgende Regelung an:
                                          https://github.com/ioBroker/ioBroker.mq … er.js#L297
                                          Es wird versucht die falsch encoded Strings zu decoden.
                                          Gerade jetzt ich empfehle dir so ein Code da zu benutzen. Zeile von 298 bis 308 (In deiner Version es können andere Zeilen sein)
                                          if (typeof message === 'string' && message.match(/^(\d)+,\s?(\d)+,\s?(\d)+/)) {
                                                      //adapter.log.info('Try to convert ' + message);
                                                      var parts = message.split(',');
                                                      try {
                                                          var str = '';
                                                          for (var p = 0; p < parts.length; p++) {
                                                              str += String.fromCharCode(parseInt(parts[p].trim(), 10));
                                                          message = str;
                                                      } catch (e) {
                                                          // cannot convert and ignore it
                                                      //adapter.log.info('Converted ' + message);
                                          • N
                                            nop0 last edited by
                                            Hallo Bluefox,
                                            danke für den Tipps. Ich habe gestern die MQTT Adapter v. 1.3.2 installiert und meine alte Programmierung vom letzte Woche auf die problematische ESP-Node zurückgespielt. Bis jetzt (über 20h) nur 1 Verbindungsabbruch, aber was git ist - ohne reset der MQTT-Adapter.
                                            Ich vermute Probleme mit zu lange Programmzyklen - der Watchdog vom ESP gefehlt das nicht und der loop wird reseted. Unklar war nur warum hat er den Adapter gleich ins Tod mitgerissen? Das ist aber Problem mit meine Programmierung - der MQTT-Adapter läuft stabil. Danke für deine Bemühungen!
                                            5776
