    2. English
    3. ioBroker general
    4. ioBroker does not respond SOLVED
      ap2017 last edited by ap2017
      Recently my Linux based ioBroker server stopped responding, giving message "This site can’t be reached 192.168.1.74 refused to connect". I can login to Linux using PuTTY with no problem. I suspect low SSD available memory, here is my df -h log:
      ap@AP-Tiny:/opt/iobroker$ df -h
      Filesystem      Size  Used Avail Use% Mounted on
      udev            1.9G     0  1.9G   0% /dev
      tmpfs           377M  1.2M  376M   1% /run
      /dev/sda1       110G  105G     0 100% /
      tmpfs           1.9G     0  1.9G   0% /dev/shm
      tmpfs           5.0M  4.0K  5.0M   1% /run/lock
      tmpfs           1.9G     0  1.9G   0% /sys/fs/cgroup
      tmpfs           377M  4.0K  377M   1% /run/user/111
      tmpfs           377M     0  377M   0% /run/user/1000
      MOD-Edit: added code-tags
      If I am low on memory, where I can delete Linux / ioBorker temporarily files or history logs over PuTTY?
        Homoran Global Moderator Administrators @ap2017 last edited by
        @ap2017 sagte in ioBroker does not respond:
        there is low memory but not no space left.
        what is zhe output of iobroker list instances
        A 2 Replies Last reply Reply Quote 0
          ap2017 @Homoran last edited by Homoran
          ap@AP-Tiny:~$ iobroker list instances
          + system.adapter.accuweather.0            : accuweather           : AP-Tiny                                  -  enabled
          + system.adapter.admin.0                  : admin                 : AP-Tiny                                  -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.backitup.0               : backitup              : AP-Tiny                                  -  enabled
            system.adapter.cloud.0                  : cloud                 : AP-Tiny                                  - disabled
            system.adapter.deconz.0                 : deconz                : AP-Tiny                                  - disabled, port: 8080
          + system.adapter.discovery.0              : discovery             : AP-Tiny                                  -  enabled
            system.adapter.echarts.0                : echarts               : AP-Tiny                                  -  enabled
            system.adapter.flot.0                   : flot                  : AP-Tiny                                  -  enabled
          + system.adapter.history.0                : history               : AP-Tiny                                  -  enabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : AP-Tiny                                  -  enabled
          + system.adapter.info.0                   : info                  : AP-Tiny                                  -  enabled
          + system.adapter.javascript.0             : javascript            : AP-Tiny                                  -  enabled
          + system.adapter.mysensors.0              : mysensors             : AP-Tiny                                  -  enabled, port: 5003, bind: 0.0.0.0
          + system.adapter.simple-api.0             : simple-api            : AP-Tiny                                  -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          + system.adapter.socketio.0               : socketio              : AP-Tiny                                  -  enabled, port: 8084, bind: 192.168.1.74, run as: admin
            system.adapter.sonoff.0                 : sonoff                : AP-Tiny                                  - disabled, port: 1883, bind: 0.0.0.0
          + system.adapter.telegram.0               : telegram              : AP-Tiny                                  -  enabled, port: 8443, bind: 0.0.0.0
            system.adapter.vis-google-fonts.0       : vis-google-fonts      : AP-Tiny                                  -  enabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : AP-Tiny                                  -  enabled
            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : AP-Tiny                                  -  enabled
            system.adapter.vis-material-advanced.0  : vis-material-advanced : AP-Tiny                                  -  enabled
            system.adapter.vis-material-webfont.0   : vis-material-webfont  : AP-Tiny                                  -  enabled
            system.adapter.vis-material.0           : vis-material          : AP-Tiny                                  -  enabled
            system.adapter.vis-materialdesign.0     : vis-materialdesign    : AP-Tiny                                  -  enabled
            system.adapter.vis-metro.0              : vis-metro             : AP-Tiny                                  -  enabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : AP-Tiny                                  -  enabled
            system.adapter.vis.0                    : vis                   : AP-Tiny                                  -  enabled
          + system.adapter.web.0                    : web                   : AP-Tiny                                  -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.zigbee.0                 : zigbee                : AP-Tiny                                  -  enabled, port: /dev/ttyACM1
          + system.adapter.zwave2.0                 : zwave2                : AP-Tiny                                  -  enabled
          + instance is alive
          Server Cannot save Dataset to /opt/iobroker/iobroker-data/states.json.new: ENOSPC: no space left on device, write
          Server Cannot save /opt/iobroker/iobroker-data/states.json: Error: ENOSPC: no space left on device, write
          ap@AP-Tiny:~$
            Homoran Global Moderator Administrators @ap2017 last edited by Homoran
            @ap2017 thanks - looks good
            iobroker status
            EDIT- it doesn't 😞
              ap@AP-Tiny:~$ iobroker status
              Objects type: file
              States  type: file
              A K 2 Replies Last reply Reply Quote 0
                ap2017 @ap2017 last edited by
                @ap2017 What if I clone existing drive onto larger drive using Acronis, will it work? It should, right?
                  @ap2017 You had been right ENOSPC!
                  you should delete some data
                  possible data can be logs or history.
                  I'm not sure how to do it with puTTY, I prefer filezilla for file-operations.
                  There you can save the history data to your pc before you delete them.
                  the data will be found in /opt/iobroker/iobroker-data/history or /opt/iobroker/log
                  if you have made some backups, stired locally, they will be in /opt/iobroker/backups
                    It should, right?
                    yes
                      @homoran Thank you. I will try to clone drive first, if it does not help will start deleting
                      history files.
                        @homoran Worked smooth, thank you!
                        Homoran 1 Reply Last reply Reply Quote 2
                          Congrats
                          Thanks for your feedback
                            Karabas @ap2017 last edited by
                            @ap2017
                            Hi see this link
                            https://www.youtube.com/watch?v=FZeWNwXC7rk&t=48s
                            this work
                            1281
