    4. Admin v5.1.23 Fehler
      MatthiaB @Thomas Braun last edited by
      host.raspberrypi
      2021-08-08 15:20:26.084 info Restart adapter system.adapter.shelly.0 because enabled
      host.raspberrypi
      2021-08-08 15:20:26.084 info instance system.adapter.shelly.0 terminated with code 0 (NO_ERROR)
      shelly.0
      2021-08-08 15:20:25.857 info Starting Shelly adapter in CoAP modus.
      shelly.0
      2021-08-08 15:20:25.815 info Starting Adapter shelly.0 in version 4.0.7
      shelly.0
      2021-08-08 15:20:25.777 info starting. Version 4.0.7 in /opt/iobroker/node_modules/iobroker.shelly, node: v12.22.1, js-controller: 3.3.15
        admin.0
        2021-08-08 15:22:05.746 warn State "admin.0.info.connection" has no existing object, this might lead to an error in future versions
          Thomas Braun Most Active @MatthiaB last edited by
          @matthiab
          Das ist a) nicht die komplette Ein- und Ausgabe und b) fehlen die CodeTags um den Text.
            pi@raspberrypi:~ $ iob list adapters
            system.adapter.admin                   : admin          - v4.2.2
            system.adapter.backitup                : backitup       - v2.1.13
            system.adapter.discovery               : discovery      - v2.7.0
            system.adapter.flot                    : flot           - v1.10.6
            system.adapter.fritzdect               : fritzdect      - v2.1.15
            system.adapter.habpanel                : habpanel       - v0.4.3
            system.adapter.history                 : history        - v1.9.13
            system.adapter.icons-icons8            : icons-icons8   - v0.0.1
            system.adapter.icons-mfd-png           : icons-mfd-png  - v1.0.2
            system.adapter.icons-open-icon-library-png: icons-open-icon-library-png - v0.1.2
            system.adapter.influxdb                : influxdb       - v1.9.5
            system.adapter.info                    : info           - v1.7.14
            system.adapter.javascript              : javascript     - v5.1.3
            system.adapter.logparser               : logparser      - v1.1.0
            system.adapter.mqtt                    : mqtt           - v2.4.0
            system.adapter.shelly                  : shelly         - v4.0.7
            system.adapter.simple-api              : simple-api     - v2.6.1
            system.adapter.socketio                : socketio       - v3.1.4
            system.adapter.sonoff                  : sonoff         - v2.4.0
            system.adapter.sourceanalytix          : sourceanalytix - v0.4.8
            system.adapter.sql                     : sql            - v1.15.7
            system.adapter.statistics              : statistics     - v1.0.4
            system.adapter.telegram                : telegram       - v1.9.0
            system.adapter.text2command            : text2command   - v2.1.1
            system.adapter.tr-064                  : tr-064         - v4.2.12
            system.adapter.vis                     : vis            - v1.4.3
            system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.1.7
            system.adapter.vis-inventwo            : vis-inventwo   - v3.0.11
            system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
            system.adapter.vis-map                 : vis-map        - v1.0.4
            system.adapter.vis-materialdesign      : vis-materialdesign - v0.4.2
            system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
            system.adapter.vw-connect              : vw-connect     - v0.0.39
            system.adapter.web                     : web            - v3.4.1
            system.adapter.worx                    : worx           - v1.3.6
            pi@raspberrypi:~ $ iob list instances
            + system.adapter.admin.0                  : admin                 : raspberrypi        -  enabled, port: 8081, bind: 0.0.0.0, run as: admi                                               n
            + system.adapter.backitup.0               : backitup              : raspberrypi        -  enabled
            + system.adapter.discovery.0              : discovery             : raspberrypi        -  enabled
              system.adapter.flot.0                   : flot                  : raspberrypi        - disabled
            + system.adapter.fritzdect.0              : fritzdect             : raspberrypi        -  enabled
              system.adapter.habpanel.0               : habpanel              : raspberrypi        - disabled
            + system.adapter.history.0                : history               : raspberrypi        -  enabled
              system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi        - disabled
              system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi        - disabled
              system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ras                                               pberrypi                              - disabled
            + system.adapter.influxdb.0               : influxdb              : raspberrypi        -  enabled, port: 8086
            + system.adapter.info.0                   : info                  : raspberrypi        -  enabled
            + system.adapter.javascript.0             : javascript            : raspberrypi        -  enabled
            + system.adapter.logparser.0              : logparser             : raspberrypi        -  enabled
            + system.adapter.mqtt.0                   : mqtt                  : raspberrypi        -  enabled, port: 1886, bind: 0.0.0.0
              system.adapter.shelly.0                 : shelly                : raspberrypi        -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.socketio.0               : socketio              : raspberrypi        -  enabled, port: 8084, bind: 192.168.178.30, run a                                               s: admin
            + system.adapter.sonoff.0                 : sonoff                : raspberrypi        -  enabled, port: 1883, bind: 0.0.0.0
            + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi        -  enabled
            + system.adapter.sql.0                    : sql                   : raspberrypi        -  enabled, port: 0
            + system.adapter.sql.1                    : sql                   : raspberrypi        -  enabled, port: 0
            + system.adapter.statistics.0             : statistics            : raspberrypi        -  enabled
            + system.adapter.telegram.0               : telegram              : raspberrypi        -  enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.text2command.0           : text2command          : raspberrypi        -  enabled
            + system.adapter.tr-064.0                 : tr-064                : raspberrypi        -  enabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi        - disabled
              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi        - disabled
              system.adapter.vis-map.0                : vis-map               : raspberrypi        - disabled
              system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi        - disabled
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi        - disabled
              system.adapter.vis.0                    : vis                   : raspberrypi        -  enabled
            + system.adapter.vw-connect.0             : vw-connect            : raspberrypi        -  enabled
            + system.adapter.web.0                    : web                   : raspberrypi        -  enabled, port: 8082, bind: 0.0.0.0, run as: admi                                               n
            + system.adapter.worx.0                   : worx                  : raspberrypi        -  enabled
            + instance is alive
            pi@raspberrypi:~ $ iob update
            Used repository: Stable (default)
            hash changed or no sources cached => force download of new sources
            update done
            Adapter    "admin"         : 5.1.23   , installed 5.1.23
            Adapter    "backitup"      : 2.1.13   , installed 2.1.13
            Adapter    "discovery"     : 2.7.0    , installed 2.7.0
            Adapter    "flot"          : 1.10.6   , installed 1.10.6
            Adapter    "fritzdect"     : 2.1.15   , installed 2.1.15
            Adapter    "habpanel"      : 0.4.3    , installed 0.4.3
            Adapter    "history"       : 1.9.13   , installed 1.9.13
            Adapter    "icons-icons8"  : 0.0.1    , installed 0.0.1
            Adapter    "icons-mfd-png" : 1.0.2    , installed 1.0.2
            Adapter    "icons-open-icon-library-png": 0.1.2   , installed 0.1.2
            Adapter    "influxdb"      : 1.9.5    , installed 1.9.5
            Adapter    "info"          : 1.9.8    , installed 1.9.8
            Adapter    "javascript"    : 5.2.8    , installed 5.2.8
            Controller "js-controller" : 3.3.15   , installed 3.3.15
            Adapter    "logparser"     : 1.1.0    , installed 1.1.0
            Adapter    "mqtt"          : 2.4.0    , installed 2.4.0
            Adapter    "shelly"        : 4.0.7    , installed 4.0.7
            Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
            Adapter    "socketio"      : 3.1.4    , installed 3.1.4
            Adapter    "sonoff"        : 2.4.5    , installed 2.4.5
            Adapter    "sql"           : 1.15.7   , installed 1.15.7
            Adapter    "statistics"    : 1.0.9    , installed 1.0.9
            Adapter    "telegram"      : 1.10.0   , installed 1.10.0
            Adapter    "text2command"  : 2.1.1    , installed 2.1.1
            Adapter    "tr-064"        : 4.2.14   , installed 4.2.14
            Adapter    "vis"           : 1.4.3    , installed 1.4.3
            Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.7
            Adapter    "vis-inventwo"  : 3.0.11   , installed 3.0.11
            Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
            Adapter    "vis-map"       : 1.0.4    , installed 1.0.4
            Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
            Adapter    "vw-connect"    : 0.0.39   , installed 0.0.39
            Adapter    "web"           : 3.4.7    , installed 3.4.7
            Adapter    "worx"          : 1.4.3    , installed 1.4.3
              @matthiab
              iobroker upload all
                habe ich durchgeführt, nun stimmt zumindest die Version des Admin-Adapters.
                Shelly geht weiterhin nicht, SourceAnalytics geht soweit, kann aber nicht mehr konfigurtiert werden
                Cannot load jsonConfig of sourceanalytix: Not exists
                  @matthiab
                  Und was steht im LogFile, wenn man den jeweiligen Adapter neustartet?
                    host.raspberrypi
                    	2021-08-08 21:50:20.483	info	Restart adapter system.adapter.shelly.0 because enabled
                    host.raspberrypi
                    	2021-08-08 21:50:20.480	info	instance system.adapter.shelly.0 terminated with code 0 (NO_ERROR)
                    shelly.0
                    	2021-08-08 21:50:20.219	info	Starting Shelly adapter in CoAP modus.
                    shelly.0
                    	2021-08-08 21:50:20.177	info	Starting Adapter shelly.0 in version 4.0.7
                    shelly.0
                    	2021-08-08 21:50:20.136	info	starting. Version 4.0.7 in /opt/iobroker/node_modules/iobroker.shelly, node: v12.22.1, js-controller: 3.3.15
                    Der SourceAnalytixs Adapter läuft ganz normal zeigt beim Neustart nur Feher bei einem Objekt an.
                    sourceanalytix.0
                    	2021-08-08 21:51:38.701	error	Cannot handle initialisation for javascript.0.Eigene.Bewässerung.Verbrauch.WasseruhrAktuell
                    sourceanalytix.0
                    	2021-08-08 21:51:27.979	error	Please choose unit manually in state configuration
                    sourceanalytix.0
                    	2021-08-08 21:51:27.979	error	No unit defined for javascript.0.Eigene.fb_kmStand2, cannot execute calculations !
                    sourceanalytix.0
                    	2021-08-08 21:51:27.958	error	Please choose unit manually in state configuration
                    sourceanalytix.0
                    	2021-08-08 21:51:27.956	error	No unit defined for javascript.0.Eigene.Bewässerung.Verbrauch.WasseruhrAktuell, cannot execute calculations !
                    Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
                      @matthiab
                      Fällt mir zu beiden nix ein, habe ich nicht im Einsatz.
                        okay danke,
                        wenigstens lässt sich der Aktor über einen HTTP-Befehl noch steuern.
                          crunchip Forum Testing Most Active @MatthiaB last edited by
                          @matthiab sagte in Admin v5.1.23 Fehler:
                          bei 2 Objekte, einmal hast du SA zweckenfremdet "Eigene.fb_kmStand2" dafür gibt es keine Unit, daher auch die Meldung "cannot execute calculations"
                          und zum anderen hast du scheinbar die unit nicht angegeben, bei "Eigene.Bewässerung.Verbrauch.WasseruhrAktuell"
                            MatthiaB @crunchip last edited by
                            @crunchip
                            Moin.
                            Der Adapter lässt sich nicht mehr für Objekte konfigurieren. Es fehlt einfach in der Auswahl.
                              crunchip Forum Testing Most Active @MatthiaB last edited by crunchip
                              @matthiab ja, du hattest ja geschrieben
                              wie man das behebt, weiss ich leider nicht
                              Edit: welche version ist installiert?
                              siehe https://github.com/ioBroker/ioBroker.admin/issues/965
                              und wenn wir schon dabei sind, dein shelly Adapter auch updaten, aktuell ist v4.0.8, du hast 4.0.7
                              tugsi created this issue in ioBroker/ioBroker.admin
                              closed Benutzerdefinierte Einstellungen bei Objekten; Cannot load jsonConfig of sourceanalytix: Not exists #965
                                @crunchip
                                sourceAnalytix ist mit demUpdate wieder da, beim Shelly ist plötzlich eine Version 4.0.9. Beta drauf, aber auch hier keine Verbindung zum Host, kein Lebenszeichen.
                                Verbunden mit Geräte oder Dienst ist grün.
                                Daten werden aber nicht aktualisiert 😞
                                da_Woody crunchip 2 Replies Last reply Reply Quote 0
                                • da_Woody
                                  da_Woody @MatthiaB last edited by
                                  @matthiab hast du aktuelle FW auf den shellys? vom mcast auf unicast umgestellt?
                                  die 4.0.9beta ist die 4.0.8.
                                    @matthiab dann weiter im shelly thread oder einen eigenen aufmachen, denn das hat eigentlich nicht mit Admin Fehler zu tun
                                      MatthiaB @crunchip last edited by MatthiaB
                                      @crunchip
                                      die Probleme fingen ja damit an, zumindestens glaube ich das. Ich habe den Adapter auf mqtt umgestellt, zumindestens ist die instance grün. Schauen wir ob es Daten gibt.
                                      ein Shelly funkt auf mqtt, bei den anderen ist das nicht eingestellt, aber die Datenpunkte sind sehr rar
                                        MatthiaB @da_Woody last edited by
                                        @da_woody
                                        soll ich suf unicast umstellen oder war das eine Frage ob ich das gemacht haben?
                                        Bei mir steht mcast, ich habe an den Einstellungen nichts verändert.
                                          das shelly Problem gab es schon vorher, daher
                                          auf unicast umstellen
                                          • da_Woody
                                            @matthiab sorry, hab das jetzt schon so oft erklärt in diversen shelly beiträgen.
                                            wie gesagt, hat nichts mit dem admin zu tun, also suchen, oder neuen beitrag aufmachen.
                                            2061
