    4. JavaScript
    5. Hilfe bei RSS-feed benötigt !
    • dslraser
      dslraser Forum Testing Most Active @Negalein last edited by
      @negalein
       <variables>
         <variable id="L7A9(g?`LW}R/bMuZJZ+">alarm</variable>
         <variable id="LsczX0YIyn!68c?SjK*I">Ansage</variable>
       </variables>
       <block type="on" id="+@7%D7W8?OQL#7sG9${H" x="62" y="12">
         <field name="OID">alias.0.Steckdosen.Kaminlampe</field>
           <block type="variables_set" id="%HtGMbM4;hXhq!W!Jl{p">
             <field name="VAR" id="L7A9(g?`LW}R/bMuZJZ+">alarm</field>
               <block type="get_value" id=")4aT*cgU|]x#C}|MNW[[">
                 <field name="OID">0_userdata.0.Test.Feuerwehr</field>
               <block type="variables_set" id="?;!h8=JjxBHUrvS?Y!;_">
                 <field name="VAR" id="LsczX0YIyn!68c?SjK*I">Ansage</field>
                   <block type="logic_ternary" id="L)4b8*{+md/}v?{/C9.:">
                     <value name="IF">
                       <block type="get_value" id="S;xg!`v.v]~mPQ:E%HgF">
                     <value name="THEN">
                       <block type="text_join" id="*h/@)bzlPIooxo1/j:Au">
                         <mutation items="5"></mutation>
                         <value name="ADD0">
                           <block type="text" id="Xu8o?(43(vn;Cg!T-f[1">
                             <field name="TEXT">80;Feuerwehreinsatz in </field>
                         <value name="ADD1">
                           <block type="get_attr" id="NH!)Y8=bLfRpPo2:WbjX">
                             <value name="PATH">
                               <shadow type="text" id="(Cy7yET/dEvN8A4b|-(w">
                                 <field name="TEXT">0.Feuerwache</field>
                             <value name="OBJECT">
                               <block type="variables_get" id="H6r!qQXG2k`,6ad^P8@L">
                         <value name="ADD2">
                           <block type="text" id="a$[LcG?`YqUEJ88yB|Nk">
                             <field name="TEXT">, </field>
                         <value name="ADD3">
                           <block type="text" id="H^eJylGZdDfB9@!`VW/M">
                             <field name="TEXT"> Alarmstufe </field>
                         <value name="ADD4">
                           <block type="get_attr" id="FgybMVKzEzhDO=?4Y9qZ">
                             <value name="PATH">
                               <shadow type="text" id="_sE$+E3j.T_fm~J)o.x2">
                                 <field name="TEXT">0.Alarmstufe</field>
                               <block type="variables_get" id="|!-j*yWA38543V2I-Yo2">
                     <value name="ELSE">
                       <block type="text" id="2CpPUD^;S4FApOa;J9fS">
                         <field name="TEXT">80;Feuerwehreinsatz beendet</field>
                   <block type="control" id="qQ9[Z8iQklaMF+xh,a10">
                     <field name="OID">alexa2.0.Echo-Devices.G0911B0592770T3W.Commands.speak</field>
                       <block type="variables_get" id="*0=u_Ai?c:6|1T8FKUV[">
      Negalein 1 Reply Last reply Reply Quote 2
      • Negalein
        Negalein Global Moderator @dslraser last edited by
        @dslraser sagte in Hilfe bei RSS-feed benötigt !:
        @negalein
        • dslraser
          @negalein
          bei Wert von Feuerwehr müßte dann Dein DP mit dem json hin
          Probiere mal aus
           <variables>
           </variables>
           <block type="on" id="4Ag2o!M7(duPG[0Vl2Hd" x="238" y="-88">
             <field name="OID">javascript.0.Feuerwehr.neuer_Alarm</field>
                   <block type="variables_set" id="CMmMZwNmchG4F@fQN:C}">
                       <block type="text_join" id="Vyi+e2{];XoHNaU6g^V8">
                         <value name="ADD0">
                           <block type="logic_ternary" id="i5.8F@(VdWhDGf$#*z*/">
                             <value name="IF">
                               <block type="get_value" id="JDX!Y$H%-r1]ZyBPgeHQ">
                             <value name="THEN">
                                 <value name="ADD0">
                                 <value name="ADD1">
                                     <value name="PATH">
                                 <value name="ADD2">
                                 <value name="ADD3">
                                 <value name="ADD4">
                                     <value name="PATH">
                             <value name="ELSE">
                       <block type="control" id="aB@ja!KyrC^SDNh,s[3Y">
                         <field name="OID">alexa2.0.Echo-Devices.G090LF1182231CD6.Commands.speak</field>
                           <block type="variables_get" id="[,fek++O]qRkKOl/UM1.">
          • Negalein
            @dslraser
            funktioniert soweit.
            Allerdings lässt er zB bei diesem JSON was aus.
            [{"Titel":"SD - BRANDMELDEALARM","Feuerwache":"Schärding - SCHARDENBERG","Einsatz":"E210800560","Alarmstufe":"1","Feuerwehren":"1","Zeit":"06.08.2021 14:02 Uhr06.08.2021 14:47","Bezirk":"FF Schardenberg"}]
            im Blockly bei 0.Feuerwache spricht er nur Schärding. Sollte aber Schärding - Schardenberg sein.
            Wenn ich den Titel SD - BRANDMELDEALARM noch möchte, reicht hier dann ein 0.Titel einzufügen?
            • dslraser
              dslraser Forum Testing Most Active @Negalein last edited by dslraser
              @negalein sagte in Hilfe bei RSS-feed benötigt !:
              Ich weiß gerade nicht wie sich Bindestriche bei speak auswirken...?
              Ja, wobei ich nicht weiß wie SD ausgesprochen wird ?
              (ich bin jetzt nur am Handy, habe den Rechner schon aus)
              • Negalein
                hab gerade 40;SD - BRANDMELDEALARM direkt im Speak DP getestet. Da wird es als SD BRANDMELDEALARM vorgelesen.
                  sigi234 Forum Testing Most Active @Negalein last edited by sigi234
                  Ja, man müsste 5(?) Zeichen abnehmen, weil SD braucht man nicht
                  Negalein 2 Replies Last reply Reply Quote 0
                  • Negalein
                    Negalein Global Moderator @sigi234 last edited by
                    @sigi234 sagte in Hilfe bei RSS-feed benötigt !:
                    Ich würde eher den ganzen Text nehmen. Gestern beim Sturm ist mir aufgefallen, dass der Titel oft variiert.
                    BR - Sturm, Braunau - Sturm, usw.
                    • Negalein
                      Ok, ich hab jetzt nochmal die Titel der letzten 2 Tage kontrolliert.
                      Da würde es mit den 5 Zeichen passen.
                      http://cf-intranet.ooelfv.at/webext2/rss/rss_2tage.xml
                        @negalein
                        Wenn kein Einsatz ist kommt ein Fehler, weil der DP leer ist.
                        Negalein dslraser 2 Replies Last reply Reply Quote 0
                        • Negalein
                          bei mir passts
                          • dslraser
                            dslraser Forum Testing Most Active @sigi234 last edited by dslraser
                            @sigi234
                            Du musst unten für die E-Mail auch den prüfe Baustein einbauen, nur ohne die Lautstärke am Anfang.
                            Oben kann der Baustein mit dem Kreuz weg.
                            • Negalein
                              @dslraser
                              Hab gerade eine Einsatzmeldung.
                              Aber die Meldung wird jetzt solange wiederholt, bis der Einsatz beendet ist.
                              Kann man das Blockly so ändern, dass 1x die Einsatzmeldung kommt, dann Meldung bei Einsatz Ende (das passt schon so)?
                              Script fragt jede 23. Sekunde die Einsätze ab. Schreibt dadurch den DP jedes mal neu.
                              Und gerade ist mir aufgefallen, dass das Einsatzende auch wiederholt wird.
                              Müsste da @SBorg das Script anpassen?
                              dslraser 3 Replies Last reply Reply Quote 0
                              • dslraser
                                @negalein
                                Dann stelle mal den Trigger auf größer als letztes , vielleicht reicht das schon.
                                • dslraser
                                  Ja, steht hier im Script
                                  const Zeitplan = "*/10 * * * *";              //jede Minute bei 23 Sekunden
                                  • dslraser
                                    @negalein
                                    @sigi234
                                    versucht mal so
                                     <variables>
                                     </variables>
                                       <field name="CONDITION">gt</field>
                                                   <mutation items="8"></mutation>
                                                   <value name="ADD0">
                                                       <field name="TEXT">30;Achtung </field>
                                                   <value name="ADD1">
                                                     <block type="get_attr" id="v~82#[cNH(ra2KPFbM4W">
                                                       <value name="PATH">
                                                         <shadow type="text" id="7;3ubSC@.Vh4B1@vTR%$">
                                                           <field name="TEXT">0.Titel</field>
                                                         <block type="variables_get" id="+ui2E?c,Vjd@r+{OJD%%">
                                                   <value name="ADD2">
                                                     <block type="text" id="-mZ^h1(ueF^~78a{-,4z">
                                                   <value name="ADD3">
                                                     <block type="text" id="0}0|gG|9{6D#6[fzo9qB">
                                                       <field name="TEXT">Feuerwehreinsatz in </field>
                                                   <value name="ADD4">
                                                       <value name="PATH">
                                                   <value name="ADD5">
                                                   <value name="ADD6">
                                                   <value name="ADD7">
                                                       <value name="PATH">
                                                     <block type="email" id="YM7NQxe=ea`Z6_6ny^5*">
                                                       <field name="IS_HTML">TRUE</field>
                                                       <field name="LOG"></field>
                                                       <value name="TO">
                                                         <shadow type="text" id="UJo2VuxhO4m1:PSA#Uo+">
                                                           <field name="TEXT">max.muster@freenet.de</field>
                                                       <value name="TEXT">
                                                         <shadow type="text" id="mqy9$BPrKj)wQHn~@pQD">
                                                           <field name="TEXT"></field>
                                                         <block type="text_join" id="U9ogXL1RVR*KTGlUN%[8">
                                                           <value name="ADD0">
                                                             <block type="text" id="u$+8h[#TvJNBlqO#DMNZ">
                                                               <field name="TEXT">Achtung </field>
                                                           <value name="ADD1">
                                                             <block type="get_attr" id="K|I(f`CPY6_et1P+Ec{V">
                                                               <value name="PATH">
        <shadow type="text" id="7~:zoG$5o5~/5[*]|hz-">
        <block type="variables_get" id="bg?[_%0?+|Lz]c?|Bjea">
                                                           <value name="ADD2">
                                                             <block type="text" id="iRW$8%(PQabo_TPC6pwT">
                                                           <value name="ADD3">
                                                             <block type="text" id="?-EkZF@.k~Zdiq,O#7;8">
                                                           <value name="ADD4">
                                                             <block type="get_attr" id="?+:bHdKlcpq61g|?zPmo">
                                                               <value name="PATH">
        <shadow type="text" id="AM%5!JwtoKH/Kwm7#BRS">
        <block type="variables_get" id="f,~yx_lT.$!D7rtfIm3{">
                                                           <value name="ADD5">
                                                             <block type="text" id="U5s0[VLHA!HUN~Zb#2G*">
                                                           <value name="ADD6">
                                                             <block type="text" id="QyCi`-M$*N%b_2+Wa5u+">
                                                           <value name="ADD7">
                                                             <block type="get_attr" id="t=:=pQ}E)eKu}Cdo{R(3">
                                                               <value name="PATH">
        <shadow type="text" id="cMvw=ASRyt0tBHK2J#Oq">
        <block type="variables_get" id="00u2P-C=I?PGEYe3[1P,">
                                                       <value name="SUBJECT">
                                                         <shadow type="text" id="LCFI}F_YAI2`#AS~*Guw">
                                                           <field name="TEXT">Einsatzmeldung</field>
                                     <block type="on" id="YTUB}MoK,`c3}KE9L0UK" x="1087" y="38">
                                       <field name="CONDITION">lt</field>
                                         <block type="variables_set" id="Cc8.9pdG`HUph)@/}29Z">
                                               <field name="TEXT">30;Feuerwehreinsatz beendet</field>
                                             <block type="control" id="kz}]{anpK9e;0v$@D2:r">
                                                 <block type="variables_get" id="i:=aoCY9Nn=K?in/(/q0">
                                                 <block type="email" id="*B.v-4+VD8X0LrJ43RZ[">
                                                   <value name="TO">
                                                     <shadow type="text" id=",#yxKZ_Eohz^4`aIoz|-">
                                                   <value name="TEXT">
                                                     <shadow type="text" id="Pb~lI+PPW?e0d~utS3L-">
                                                       <field name="TEXT">Feuerwehreinsatz beendet</field>
                                                     <shadow type="text" id="$mF~`]ectlcrGo}x8SH4">
                                                       <field name="TEXT">Einsatz beendet</field>
                                      sigi234 Forum Testing Most Active @dslraser last edited by
                                      @dslraser
                                      Hallo, kann man bei 0.Titel 5 Zeichen abnehmen?
                                      • dslraser
                                        @dslraser
                                        sag mir bitte erstmal ob das jetzt so funktioniert, oder ob sich die Ansagen noch wiederholen ?
                                          sigi234 Forum Testing Most Active @dslraser last edited by sigi234
                                          @dslraser
                                          Teste gerade, Einsatz beendet kommt teilweise obwohl nicht beendet. Der letzte Einsatz wird nicht angesagt nur der 2.
                                          Denke es liegt am Skript.
                                          • dslraser
                                            @sigi234
                                            Dann baue mal einen debug Baustein unter den Trigger in dem Blockly und schau mal was passiert. Ich nutze ja das Script für den Trigger nicht....
                                            426
                                            67183
