    4. JavaScript
    5. Hilfe bei RSS-feed benötigt !
    • dslraser
      dslraser Forum Testing Most Active @Negalein last edited by
      @negalein
      @sigi234
      versucht mal so
       <variables>
         <variable id="L7A9(g?`LW}R/bMuZJZ+">alarm</variable>
         <variable id="LsczX0YIyn!68c?SjK*I">Ansage</variable>
       </variables>
       <block type="on" id="4Ag2o!M7(duPG[0Vl2Hd" x="238" y="-88">
         <field name="OID">alias.0.Steckdosen.Kaminlampe</field>
         <field name="CONDITION">gt</field>
           <block type="variables_set" id="%HtGMbM4;hXhq!W!Jl{p">
             <field name="VAR" id="L7A9(g?`LW}R/bMuZJZ+">alarm</field>
               <block type="get_value" id=")4aT*cgU|]x#C}|MNW[[">
                 <field name="OID">0_userdata.0.Test.Feuerwehr</field>
               <block type="variables_set" id="CMmMZwNmchG4F@fQN:C}">
                 <field name="VAR" id="LsczX0YIyn!68c?SjK*I">Ansage</field>
                   <block type="text_join" id="*h/@)bzlPIooxo1/j:Au">
                     <mutation items="8"></mutation>
                     <value name="ADD0">
                       <block type="text" id="Xu8o?(43(vn;Cg!T-f[1">
                         <field name="TEXT">30;Achtung </field>
                     <value name="ADD1">
                       <block type="get_attr" id="v~82#[cNH(ra2KPFbM4W">
                         <value name="PATH">
                           <shadow type="text" id="7;3ubSC@.Vh4B1@vTR%$">
                             <field name="TEXT">0.Titel</field>
                         <value name="OBJECT">
                           <block type="variables_get" id="+ui2E?c,Vjd@r+{OJD%%">
                     <value name="ADD2">
                       <block type="text" id="-mZ^h1(ueF^~78a{-,4z">
                         <field name="TEXT">, </field>
                     <value name="ADD3">
                       <block type="text" id="0}0|gG|9{6D#6[fzo9qB">
                         <field name="TEXT">Feuerwehreinsatz in </field>
                     <value name="ADD4">
                       <block type="get_attr" id="NH!)Y8=bLfRpPo2:WbjX">
                         <value name="PATH">
                           <shadow type="text" id="(Cy7yET/dEvN8A4b|-(w">
                             <field name="TEXT">0.Feuerwache</field>
                           <block type="variables_get" id="H6r!qQXG2k`,6ad^P8@L">
                     <value name="ADD5">
                       <block type="text" id="a$[LcG?`YqUEJ88yB|Nk">
                     <value name="ADD6">
                       <block type="text" id="H^eJylGZdDfB9@!`VW/M">
                         <field name="TEXT"> Alarmstufe </field>
                     <value name="ADD7">
                       <block type="get_attr" id="FgybMVKzEzhDO=?4Y9qZ">
                         <value name="PATH">
                           <shadow type="text" id="_sE$+E3j.T_fm~J)o.x2">
                             <field name="TEXT">0.Alarmstufe</field>
                           <block type="variables_get" id="|!-j*yWA38543V2I-Yo2">
                   <block type="control" id="aB@ja!KyrC^SDNh,s[3Y">
                     <field name="OID">alexa2.0.Echo-Devices.G0911B0592770T3W.Commands.speak</field>
                       <block type="variables_get" id="[,fek++O]qRkKOl/UM1.">
                       <block type="email" id="YM7NQxe=ea`Z6_6ny^5*">
                         <field name="IS_HTML">TRUE</field>
                         <field name="LOG"></field>
                         <value name="TO">
                           <shadow type="text" id="UJo2VuxhO4m1:PSA#Uo+">
                             <field name="TEXT">max.muster@freenet.de</field>
                         <value name="TEXT">
                           <shadow type="text" id="mqy9$BPrKj)wQHn~@pQD">
                             <field name="TEXT"></field>
                           <block type="text_join" id="U9ogXL1RVR*KTGlUN%[8">
                             <value name="ADD0">
                               <block type="text" id="u$+8h[#TvJNBlqO#DMNZ">
                                 <field name="TEXT">Achtung </field>
                             <value name="ADD1">
                               <block type="get_attr" id="K|I(f`CPY6_et1P+Ec{V">
                                 <value name="PATH">
                                   <shadow type="text" id="7~:zoG$5o5~/5[*]|hz-">
                                   <block type="variables_get" id="bg?[_%0?+|Lz]c?|Bjea">
                             <value name="ADD2">
                               <block type="text" id="iRW$8%(PQabo_TPC6pwT">
                             <value name="ADD3">
                               <block type="text" id="?-EkZF@.k~Zdiq,O#7;8">
                             <value name="ADD4">
                               <block type="get_attr" id="?+:bHdKlcpq61g|?zPmo">
                                 <value name="PATH">
                                   <shadow type="text" id="AM%5!JwtoKH/Kwm7#BRS">
                                   <block type="variables_get" id="f,~yx_lT.$!D7rtfIm3{">
                             <value name="ADD5">
                               <block type="text" id="U5s0[VLHA!HUN~Zb#2G*">
                             <value name="ADD6">
                               <block type="text" id="QyCi`-M$*N%b_2+Wa5u+">
                             <value name="ADD7">
                               <block type="get_attr" id="t=:=pQ}E)eKu}Cdo{R(3">
                                 <value name="PATH">
                                   <shadow type="text" id="cMvw=ASRyt0tBHK2J#Oq">
                                   <block type="variables_get" id="00u2P-C=I?PGEYe3[1P,">
                         <value name="SUBJECT">
                           <shadow type="text" id="LCFI}F_YAI2`#AS~*Guw">
                             <field name="TEXT">Einsatzmeldung</field>
       <block type="on" id="YTUB}MoK,`c3}KE9L0UK" x="1087" y="38">
         <field name="CONDITION">lt</field>
           <block type="variables_set" id="Cc8.9pdG`HUph)@/}29Z">
               <block type="text" id="2CpPUD^;S4FApOa;J9fS">
                 <field name="TEXT">30;Feuerwehreinsatz beendet</field>
               <block type="control" id="kz}]{anpK9e;0v$@D2:r">
                   <block type="variables_get" id="i:=aoCY9Nn=K?in/(/q0">
                   <block type="email" id="*B.v-4+VD8X0LrJ43RZ[">
                     <value name="TO">
                       <shadow type="text" id=",#yxKZ_Eohz^4`aIoz|-">
                     <value name="TEXT">
                       <shadow type="text" id="Pb~lI+PPW?e0d~utS3L-">
                         <field name="TEXT">Feuerwehreinsatz beendet</field>
                       <shadow type="text" id="$mF~`]ectlcrGo}x8SH4">
                         <field name="TEXT">Einsatz beendet</field>
        sigi234 Forum Testing Most Active @dslraser last edited by
        @dslraser
        Hallo, kann man bei 0.Titel 5 Zeichen abnehmen?
        • dslraser
          dslraser Forum Testing Most Active @sigi234 last edited by
          @sigi234 sagte in Hilfe bei RSS-feed benötigt !:
          @dslraser
          sag mir bitte erstmal ob das jetzt so funktioniert, oder ob sich die Ansagen noch wiederholen ?
            sigi234 Forum Testing Most Active @dslraser last edited by sigi234
            @dslraser sagte in Hilfe bei RSS-feed benötigt !:
            @dslraser
            Teste gerade, Einsatz beendet kommt teilweise obwohl nicht beendet. Der letzte Einsatz wird nicht angesagt nur der 2.
            Denke es liegt am Skript.
            • dslraser
              dslraser Forum Testing Most Active @sigi234 last edited by dslraser
              @sigi234
              Dann baue mal einen debug Baustein unter den Trigger in dem Blockly und schau mal was passiert. Ich nutze ja das Script für den Trigger nicht....
                @sigi234
                Einsatz gerade reingekommen, das hat jetzt funktioniert.
                • dslraser
                  @dslraser
                   <variables>
                   </variables>
                                 <value name="ADD0">
                                 <value name="ADD1">
                                   <block type="text_getSubstring" id="}IpIsHTiUy+8B#?K/B%5">
                                     <mutation at1="true" at2="false"></mutation>
                                     <field name="WHERE1">FROM_START</field>
                                     <field name="WHERE2">LAST</field>
                                     <value name="STRING">
                                         <value name="PATH">
                                     <value name="AT1">
                                       <block type="math_number" id="uTA06l]H..Y:0_w;K7O7">
                                         <field name="NUM">6</field>
                                 <value name="ADD2">
                                 <value name="ADD3">
                                 <value name="ADD4">
                                     <value name="PATH">
                                 <value name="ADD5">
                                 <value name="ADD6">
                                 <value name="ADD7">
                                     <value name="PATH">
                                     <value name="TO">
                                     <value name="TEXT">
                                         <value name="ADD0">
                                         <value name="ADD1">
                                           <block type="text_getSubstring" id="zs%iN@J`LLFKDe[jGF%:">
                                               <block type="get_attr" id="t6|IbW_JAURBISg~m6?a">
                                                 <value name="PATH">
                                                   <shadow type="text" id="8W0+?rt=ODl:HWyh*1X.">
                                                   <block type="variables_get" id="V_g-q,=8v),Fn=bVEJN(">
                                             <value name="AT1">
                                               <block type="math_number" id="jXZ4Kbou^wBbJnph#njt">
                                         <value name="ADD2">
                                         <value name="ADD3">
                                         <value name="ADD4">
                                             <value name="PATH">
                                         <value name="ADD5">
                                         <value name="ADD6">
                                         <value name="ADD7">
                                             <value name="PATH">
                       <block type="on" id="YTUB}MoK,`c3}KE9L0UK">
                                     <value name="TO">
                                     <value name="TEXT">
                    @dslraser
                    Danke, derzeit läuft kein Einsatz mehr. Kann es bei einen neuen testen.
                    • Negalein
                      Negalein Global Moderator last edited by Negalein
                      @dslraser
                      Ich bekomme beim neuen Blockly Fehler.
                      11:35:35.750	error	javascript.0 (24023) script.js.Feuerwehr.Alarm-Alexa: TypeError: Cannot read property 'length' of null
                      11:35:35.750	error	javascript.0 (24023) at subsequenceFromStartLast (script.js.Feuerwehr.Alarm-Alexa:5:22)
                      11:35:35.750	error	javascript.0 (24023) at script.js.Feuerwehr.Alarm-Alexa:18:23
                      11:35:35.750	error	javascript.0 (24023) at script.js.Feuerwehr.Alarm-Alexa:35:3
                      sigi234 dslraser 2 Replies Last reply Reply Quote 0
                        sigi234 Forum Testing Most Active @Negalein last edited by
                        @negalein sagte in Hilfe bei RSS-feed benötigt !:
                        @dslraser
                        Denke weil keine Meldung da ist.
                        • dslraser
                          dslraser Forum Testing Most Active @Negalein last edited by dslraser
                          @negalein
                          Das geht auch nicht...Das E-Mail Dinges ist ausserhalb vom Trigger.
                          EDIT: und ändere die E-Mail in dem Blockly Export...
                          EDITT2: und da ist meine Lampe noch drinn.
                          Negalein sigi234 2 Replies Last reply Reply Quote 1
                          • Negalein
                            Negalein Global Moderator @dslraser last edited by
                            stimmt, war verrutscht.
                            Jetzt passts wieder.
                              @negalein
                              Hast du einen Bezirk bei Wache eingetragen? Geht das bei Dir?
                              • Negalein
                                Negalein Global Moderator @sigi234 last edited by
                                Ja, hab einfach Schärding eingetragen.
                                Sborg hat gesagt, dass er die Description absucht. Und wenn da das Wort enthalten ist, kommt was.
                                Hat gestern mit Schardenberg funktioniert.
                                In der Description stans "Schärding - Schardenberg"
                                • SBorg
                                  Das hieß auch Eingangs nicht "Wache" sondern "Filter", da wäre es wohl deutlicher geworden 😉
                                  btw:
                                  const Zeitplan = "*/10 * * * *";              //jede Minute bei 23 Sekunden
                                  Mit diesem Cron wird nur alle 10 Minuten abgefragt, also xx:10 Uhr, xx:20 Uhr ... xx:50 Uhr
                                  const Zeitplan = "*/10 * * * *";              //Abfrage alle 10 Minuten
                                    @dslraser
                                    Hallo, bei mir kommt immer die Einsatz Ende Meldung sobald ein Einsatz neu ist?
                                    • dslraser
                                      @dslraser
                                      Ja, wann/wie soll die Meldung denn kommen ?
                                      Die Einsatz Ende Meldung kommt sobald Der Datenpunkt auf false geht. Wahrscheinlich geht der Datenpunkt erst auf false, weil die Meldubg gelöscht / geleert wird, dann bei einer neuen Meldung wieder auf true.
                                      Macht denn die Ende Meldung überhaupt Sinn ?
                                      Ist dieser Einsatz dann überhaupt tatsächlich beendet ?
                                        Werde ich raus nehmen. DANKE jetzt läuft es Super ! 👍
                                        Das Skript wird ja bei mir alle 3 Minuten abgerufen, dadurch kommt dann jedes Mal die Alarmmeldung. Kann man das ändern?
                                        Ev. geht es mit "Einsatz":"E210801649"
                                        Diese Nummer wird nur einmal vergeben pro Einsatz.
                                        • Negalein
                                          Ja, kommt bei mir auch gerade wiederholend! Ich bekomm es alle 23 Sekunden, da ich schnell Infos benötige.
                                          Das hat auch nicht geholfen.
                                          • dslraser
                                            was kommt denn ? Neue Meldungen, oder wird immer die gleiche Meldung wiederholt ?
                                            426
                                            67222
