    4. Test ViessmannAPI v2.0.0
      LaBamba @LaBamba last edited by
      @tombox
      Gibt es einen Datenpunkt der immer die letzte Aktualisierung als Zeitwert festhält?
        michis0806 @amgxda last edited by
        @amgxda Den Punkt hab ich gefunden. Dort ist bei mir nur daily befüllt. weekly, monthly und yearly sind leer.
        Im alten Adapter gab's eben noch den Punkt cumulative. Das war recht praktisch, da ich damit einfach in grafana die diff auslesen konnte...
          LaBamba @BlackTigga last edited by
          @tombox
          @blacktigga
          Ich habe ein 2 Minuten Intervall drin!
          viessmannapi.0
          31378 2021-08-09 22:59:27.182 error Error: Request failed with status code 429
          viessmannapi.0
          31378 2021-08-09 22:59:27.069 error {"viErrorId":"req-cadeadb09d854e70aa9d9b21ce9818e9","statusCode":429,"errorType":"RATE_LIMIT_EXCEEDED","message":"API calls rate limit has been exceeded. Please wait until your limit will renew.","extendedPayload":{"name":"development portal "3dc06fb9bcdb7cee328b85eec0231e8e" daily limit","requestCountLimit":1450,"clientId":"3dc06fb9bcdb7cee328b85eec0231e8e","userId":"70cd1a55-5bbf-4ab0-a7e0-8c3aa51e365b","limitReset":1628553604683}}
          viessmannapi.0
          31378 2021-08-09 22:59:27.068 error Error: Request failed with status code 429
          viessmannapi.0
          31378 2021-08-09 22:59:26.963 error {"viErrorId":"req-1cec73d226da40f1a181b282fd590073","statusCode":429,"errorType":"RATE_LIMIT_EXCEEDED","message":"API calls rate limit has been exceeded. Please wait until your limit will renew.","extendedPayload":{"name":"development portal "3dc06fb9bcdb7cee328b85eec0231e8e" daily limit","requestCountLimit":1450,"clientId":"3dc06fb9bcdb7cee328b85eec0231e8e","userId":"70cd1a55-5bbf-4ab0-a7e0-8c3aa51e365b","limitReset":1628553604683}}
          viessmannapi.0
          31378 2021-08-09 22:59:26.962 error Error: Request failed with status code 429
          viessmannapi.0
          22367 2021-08-09 22:58:30.541 error Error: Request failed with status code 429
          viessmannapi.0
          22367 2021-08-09 22:58:30.540 error https://api.viessmann.com/iot/v1/equipment/installations/1288346/gateways/7571381752940106/devices/$id/features
          viessmannapi.0
          22367 2021-08-09 22:58:30.536 error Error: Request failed with status code 429
          viessmannapi.0
          22367 2021-08-09 22:58:30.535 error https://api.viessmann.com/iot/v1/events-history/events?gatewaySerial=7571381752940106&installationId=1288346
          viessmannapi.0
          22367 2021-08-09 22:56:30.591 error Error: Request failed with status code 429
          viessmannapi.0
          22367 2021-08-09 22:56:30.589 error https://api.viessmann.com/iot/v1/events-history/events?gatewaySerial=7571381752940106&installationId=1288346
          viessmannapi.0
          22367 2021-08-09 22:56:30.582 error Error: Request failed with status code 429
          viessmannapi.0
          22367 2021-08-09 22:56:30.581 error https://api.viessmann.com/iot/v1/equipment/installations/1288346/gateways/7571381752940106/devices/$id/features
          viessmannapi.0
          22367 2021-08-09 22:56:15.848 error Error: Request failed with status code 429
          viessmannapi.0
          22367 2021-08-09 22:56:15.848 error https://api.viessmann.com/iot/v1/events-history/events?gatewaySerial=7571381752940106&installationId=1288346
          viessmannapi.0
          22367 2021-08-09 22:56:15.833 error Error: Request failed with status code 429
          T L 2 Replies Last reply Reply Quote 0
            tombox @LaBamba last edited by
            @labamba das sieht nicht danach aus als hättest du die letze version via github installiert
              @tombox sagte in Test ViessmannAPI v2.0.0:
              @blacktigga Sollte eigentlich nicht passieren....
              Ich habe gestern Abend nichts weiter gemacht, in der Erwartung, dass ab 2:00 Uhr die Daten wieder automatisch in den Adapter reinlaufen. Das war heute morgen dann aber nicht der Fall. Ich musste den Adapter neustarten, seitdem holt er sich wieder die Daten.
              Zu Deinen Fragen:
              Wieviele Geräte hast du am Gateway
              1x Vitocaldens 222F
              Ist eine Hybrid-Anlage mit separater Kompressor- und Brennereinheit
              wie oft setzt du Werte an das Gerät
              Ich setzte keine Werte, ich lese nur Werte aus
              wie viele request da pro minute rausgehen
              Auszug aus Log-Datei (Wobei ich nach 180 Zeichen den restlichen Datensatz abgeschnitten habe):
              viessmannapi.0	10.08.2021 09:50:41	debug	"{""data"":[{""properties"":{},""commands"":{},""components"":[],""apiVersion"":1,""uri"":"https://api.viessmann-platform.io/iot/v1/equipment/installations/396344/gateways/7637415019518205/devi
              viessmannapi.1	10.08.2021 09:50:41	debug	"{""data"":[{""properties"":{},""commands"":{},""components"":[],""apiVersion"":1,""uri"":"https://api.viessmann-platform.io/iot/v1/equipment/installations/396344/gateways/7637415019518205/devi
              viessmannapi.3	10.08.2021 09:50:41	debug	"{""data"":[]}"
              viessmannapi.5	10.08.2021 09:49:42	debug	"{""data"":[{""properties"":{},""commands"":{},""components"":[],""apiVersion"":1,""uri"":"https://api.viessmann-platform.io/iot/v1/equipment/installations/396344/gateways/7637415019518205/devi
              viessmannapi.7	10.08.2021 09:49:41	debug	"{""data"":[{""properties"":{},""commands"":{},""components"":[],""apiVersion"":1,""uri"":"https://api.viessmann-platform.io/iot/v1/equipment/installations/396344/gateways/7637415019518205/devi
              viessmannapi.9	10.08.2021 09:49:40	debug	"{""data"":[]}"
              viessmannapi.11	10.08.2021 09:48:43	debug	"{""data"":[{""properties"":{},""commands"":{},""components"":[],""apiVersion"":1,""uri"":"https://api.viessmann-platform.io/iot/v1/equipment/installations/396344/gateways/7637415019518205/devi
              viessmannapi.13	10.08.2021 09:48:41	debug	"{""data"":[{""properties"":{},""commands"":{},""components"":[],""apiVersion"":1,""uri"":"https://api.viessmann-platform.io/iot/v1/equipment/installations/396344/gateways/7637415019518205/devi
              viessmannapi.15	10.08.2021 09:48:41	debug	"{""data"":[]}"
              viessmannapi.17	10.08.2021 09:47:42	debug	"{""data"":[{""properties"":{},""commands"":{},""components"":[],""apiVersion"":1,""uri"":"https://api.viessmann-platform.io/iot/v1/equipment/installations/396344/gateways/7637415019518205/devi
              viessmannapi.19	10.08.2021 09:47:41	debug	"{""data"":[{""properties"":{},""commands"":{},""components"":[],""apiVersion"":1,""uri"":"https://api.viessmann-platform.io/iot/v1/equipment/installations/396344/gateways/7637415019518205/devi
              viessmannapi.21	10.08.2021 09:47:40	debug	"{""data"":[]}"
              viessmannapi.23	10.08.2021 09:46:42	debug	"{""data"":[{""properties"":{},""commands"":{},""components"":[],""apiVersion"":1,""uri"":"https://api.viessmann-platform.io/iot/v1/equipment/installations/396344/gateways/7637415019518205/devi
              viessmannapi.25	10.08.2021 09:46:41	debug	"{""data"":[{""properties"":{},""commands"":{},""components"":[],""apiVersion"":1,""uri"":"https://api.viessmann-platform.io/iot/v1/equipment/installations/396344/gateways/7637415019518205/devi
              viessmannapi.27	10.08.2021 09:46:40	debug	"{""data"":[]}"
              viessmannapi.29	10.08.2021 09:45:43	debug	"{""data"":[{""properties"":{},""commands"":{},""components"":[],""apiVersion"":1,""uri"":"https://api.viessmann-platform.io/iot/v1/equipment/installations/396344/gateways/7637415019518205/devi
              viessmannapi.31	10.08.2021 09:45:41	debug	"{""data"":[{""properties"":{},""commands"":{},""components"":[],""apiVersion"":1,""uri"":"https://api.viessmann-platform.io/iot/v1/equipment/installations/396344/gateways/7637415019518205/devi
              viessmannapi.33	10.08.2021 09:45:41	debug	"{""data"":[]}"
              viessmannapi.35	10.08.2021 09:44:42	debug	"{""data"":[{""properties"":{},""commands"":{},""components"":[],""apiVersion"":1,""uri"":"https://api.viessmann-platform.io/iot/v1/equipment/installations/396344/gateways/7637415019518205/devi
              viessmannapi.37	10.08.2021 09:44:41	debug	"{""data"":[{""properties"":{},""commands"":{},""components"":[],""apiVersion"":1,""uri"":"https://api.viessmann-platform.io/iot/v1/equipment/installations/396344/gateways/7637415019518205/devi
              viessmannapi.39	10.08.2021 09:44:40	debug	"{""data"":[]}"
              viessmannapi.41	10.08.2021 09:43:43	debug	"{""data"":[{""properties"":{},""commands"":{},""components"":[],""apiVersion"":1,""uri"":"https://api.viessmann-platform.io/iot/v1/equipment/installations/396344/gateways/7637415019518205/devi
              viessmannapi.43	10.08.2021 09:43:41	debug	"{""data"":[{""properties"":{},""commands"":{},""components"":[],""apiVersion"":1,""uri"":"https://api.viessmann-platform.io/iot/v1/equipment/installations/396344/gateways/7637415019518205/devi
              viessmannapi.45	10.08.2021 09:43:41	debug	"{""data"":[]}"
              viessmannapi.47	10.08.2021 09:42:41	debug	"{""data"":[{""properties"":{},""commands"":{},""components"":[],""apiVersion"":1,""uri"":"https://api.viessmann-platform.io/iot/v1/equipment/installations/396344/gateways/7637415019518205/devi
              viessmannapi.49	10.08.2021 09:42:41	debug	"{""data"":[{""properties"":{},""commands"":{},""components"":[],""apiVersion"":1,""uri"":"https://api.viessmann-platform.io/iot/v1/equipment/installations/396344/gateways/7637415019518205/devi
              viessmannapi.51	10.08.2021 09:42:41	debug	"{""data"":[]}"
              viessmannapi.53	10.08.2021 09:41:42	debug	"{""data"":[]}"
              viessmannapi.55	10.08.2021 09:41:42	debug	"{""data"":[{""properties"":{},""commands"":{},""components"":[],""apiVersion"":1,""uri"":"https://api.viessmann-platform.io/iot/v1/equipment/installations/396344/gateways/7637415019518205/devi
              viessmannapi.57	10.08.2021 09:41:41	debug	"{""data"":[{""properties"":{},""commands"":{},""components"":[],""apiVersion"":1,""uri"":"https://api.viessmann-platform.io/iot/v1/equipment/installations/396344/gateways/7637415019518205/devi
              viessmannapi.59	10.08.2021 09:40:42	debug	"{""data"":[{""properties"":{},""commands"":{},""components"":[],""apiVersion"":1,""uri"":"https://api.viessmann-platform.io/iot/v1/equipment/installations/396344/gateways/7637415019518205/devi
              viessmannapi.61	10.08.2021 09:40:41	debug	"{""data"":[{""properties"":{},""commands"":{},""components"":[],""apiVersion"":1,""uri"":"https://api.viessmann-platform.io/iot/v1/equipment/installations/396344/gateways/7637415019518205/devi
              viessmannapi.63	10.08.2021 09:40:41	debug	"{""data"":[]}"
              viessmannapi.65	10.08.2021 09:39:43	debug	"{""data"":[{""properties"":{},""commands"":{},""components"":[],""apiVersion"":1,""uri"":"https://api.viessmann-platform.io/iot/v1/equipment/installations/396344/gateways/7637415019518205/devi
              viessmannapi.67	10.08.2021 09:39:41	debug	"{""data"":[{""properties"":{},""commands"":{},""components"":[],""apiVersion"":1,""uri"":"https://api.viessmann-platform.io/iot/v1/equipment/installations/396344/gateways/7637415019518205/devi
              viessmannapi.69	10.08.2021 09:39:41	debug	"{""data"":[]}"
              viessmannapi.71	10.08.2021 09:38:43	debug	"{""data"":[{""properties"":{},""commands"":{},""components"":[],""apiVersion"":1,""uri"":"https://api.viessmann-platform.io/iot/v1/equipment/installations/396344/gateways/7637415019518205/devi
              viessmannapi.73	10.08.2021 09:38:41	debug	"{""data"":[{""properties"":{},""commands"":{},""components"":[],""apiVersion"":1,""uri"":"https://api.viessmann-platform.io/iot/v1/equipment/installations/396344/gateways/7637415019518205/devi
              viessmannapi.75	10.08.2021 09:38:40	debug	"{""data"":[]}"
              viessmannapi.77	10.08.2021 09:37:43	debug	"{""data"":[{""properties"":{},""commands"":{},""components"":[],""apiVersion"":1,""uri"":"https://api.viessmann-platform.io/iot/v1/equipment/installations/396344/gateways/7637415019518205/devi
              viessmannapi.79	10.08.2021 09:37:41	debug	"{""data"":[{""properties"":{},""commands"":{},""components"":[],""apiVersion"":1,""uri"":"https://api.viessmann-platform.io/iot/v1/equipment/installations/396344/gateways/7637415019518205/devi
              viessmannapi.81	10.08.2021 09:37:41	debug	"{""data"":[]}"
              viessmannapi.83	10.08.2021 09:36:41	debug	"{""data"":[{""properties"":{},""commands"":{},""components"":[],""apiVersion"":1,""uri"":"https://api.viessmann-platform.io/iot/v1/equipment/installations/396344/gateways/7637415019518205/devi
              viessmannapi.85	10.08.2021 09:36:41	debug	"{""data"":[{""properties"":{},""commands"":{},""components"":[],""apiVersion"":1,""uri"":"https://api.viessmann-platform.io/iot/v1/equipment/installations/396344/gateways/7637415019518205/devi
              viessmannapi.87	10.08.2021 09:36:40	debug	"{""data"":[]}"
              viessmannapi.89	10.08.2021 09:35:41	debug	"{""data"":[{""properties"":{},""commands"":{},""components"":[],""apiVersion"":1,""uri"":"https://api.viessmann-platform.io/iot/v1/equipment/installations/396344/gateways/7637415019518205/devi
              viessmannapi.91	10.08.2021 09:35:41	debug	"{""data"":[{""properties"":{},""commands"":{},""components"":[],""apiVersion"":1,""uri"":"https://api.viessmann-platform.io/iot/v1/equipment/installations/396344/gateways/7637415019518205/devi
              viessmannapi.93	10.08.2021 09:35:40	debug	"{""data"":[]}"
              viessmannapi.95	10.08.2021 09:34:43	debug	"{""data"":[{""properties"":{},""commands"":{},""components"":[],""apiVersion"":1,""uri"":"https://api.viessmann-platform.io/iot/v1/equipment/installations/396344/gateways/7637415019518205/devi
              viessmannapi.97	10.08.2021 09:34:41	debug	"{""data"":[{""properties"":{},""commands"":{},""components"":[],""apiVersion"":1,""uri"":"https://api.viessmann-platform.io/iot/v1/equipment/installations/396344/gateways/7637415019518205/devi
                tombox @BlackTigga last edited by
                @blacktigga Es werden leider noch zwei request rausgesendet. Bitte nochmal installieren und ein paar debug zeilen schicken
                  pfahlenbauer @tombox last edited by
                  @tombox
                  Super Adapter, vielen Dank!
                  Kann man auch die Temperatursensoren der Heizkreise auslesen?
                  Ich hatte früher einen Datenpunkt heating.circuits.0.sensors.temperature.supply.value - den kann ich allerdings nicht mehr finden.
                    jrudolph @pfahlenbauer last edited by
                    @pfahlenbauer Das ist jetzt viessmannapi.0.xxxxxxx.0.features.heating.circuits.0.sensors.temperature.supply.properties.value.value
                      BlackTigga @tombox last edited by
                      Hab neu installiert.
                      Anbei der Auszug aus dem Log:
                      viessmannapi.0	10.08.2021 19:10	debug	"https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/RoomControl-1/features {""data"":[{""properties"":{},""commands"":{},""components"":[],""ap"
                      viessmannapi.0	10.08.2021 19:10	debug	"https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/0/features {""data"":[{""properties"":{},""commands"":{},""components"":[],""apiVersion"":1,"
                      viessmannapi.0	10.08.2021 19:10	debug	"https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/HeatDemandControl/features {""data"":[]}"
                      viessmannapi.0	10.08.2021 19:09	debug	"https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/RoomControl-1/features {""data"":[{""properties"":{},""commands"":{},""components"":[],""ap"
                      viessmannapi.0	10.08.2021 19:09	debug	"https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/0/features {""data"":[{""properties"":{},""commands"":{},""components"":[],""apiVersion"":1,"
                      viessmannapi.0	10.08.2021 19:09	debug	"https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/HeatDemandControl/features {""data"":[]}"
                      viessmannapi.0	10.08.2021 19:08	debug	"https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/RoomControl-1/features {""data"":[{""properties"":{},""commands"":{},""components"":[],""ap"
                      viessmannapi.0	10.08.2021 19:08	debug	"https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/0/features {""data"":[{""properties"":{},""commands"":{},""components"":[],""apiVersion"":1,"
                      viessmannapi.0	10.08.2021 19:08	debug	"https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/HeatDemandControl/features {""data"":[]}"
                      viessmannapi.0	10.08.2021 19:07	debug	"https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/0/features {""data"":[{""properties"":{},""commands"":{},""components"":[],""apiVersion"":1,"
                      viessmannapi.0	10.08.2021 19:07	debug	"https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/RoomControl-1/features {""data"":[{""properties"":{},""commands"":{},""components"":[],""ap"
                      viessmannapi.0	10.08.2021 19:07	debug	"https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/HeatDemandControl/features {""data"":[]}"
                      viessmannapi.0	10.08.2021 19:06	debug	"https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/0/features {""data"":[{""properties"":{},""commands"":{},""components"":[],""apiVersion"":1,"
                      viessmannapi.0	10.08.2021 19:06	debug	"https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/RoomControl-1/features {""data"":[{""properties"":{},""commands"":{},""components"":[],""ap"
                      viessmannapi.0	10.08.2021 19:06	debug	"https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/HeatDemandControl/features {""data"":[]}"
                      viessmannapi.0	10.08.2021 19:05	debug	"https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/RoomControl-1/features {""data"":[{""properties"":{},""commands"":{},""components"":[],""ap"
                      viessmannapi.0	10.08.2021 19:05	debug	"https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/0/features {""data"":[{""properties"":{},""commands"":{},""components"":[],""apiVersion"":1,"
                      viessmannapi.0	10.08.2021 19:05	debug	"https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/HeatDemandControl/features {""data"":[]}"
                      viessmannapi.0	10.08.2021 19:04	debug	"https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/RoomControl-1/features {""data"":[{""properties"":{},""commands"":{},""components"":[],""ap"
                      viessmannapi.0	10.08.2021 19:04	debug	"https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/0/features {""data"":[{""properties"":{},""commands"":{},""components"":[],""apiVersion"":1,"
                      viessmannapi.0	10.08.2021 19:04	debug	"https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/HeatDemandControl/features {""data"":[]}"
                      viessmannapi.0	10.08.2021 19:03	debug	"https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/7637415019518205/devices/RoomControl-1/features {""data"":[{""properties"":{},""commands"":{},""components"":[],""ap"
                        pfahlenbauer @jrudolph last edited by
                        @jrudolph said in Test ViessmannAPI v2.0.0:
                        .properties.value
                        Bei mir gibt es den "value" offenbar nicht mehr. Der "properties" ordner ist leer:
                          Hansi1234 @pfahlenbauer last edited by
                          @pfahlenbauer welche Sensoren hast du jeweils für die Räume?
                            pfahlenbauer @Hansi1234 last edited by
                            @hansi1234
                            Für die Räume habe ich keine Sensoren.
                            Ich habe eine Vitodens 300 B3HF mit 2 Heizkreisen. Ich würde gerne die Vorlauftemperaturen der Heizkreise auslesen. Da gibt mir der Adapater aber leider keine Temperatur values. Vielleicht hilft es den Adapter zu löschen und neu zu installieren - da scheue ich mich aber davor, weil ich dann evtl. meine alten Daten verliere - die brauche ich noch zur Argumentation mit meinem HB, der noch ein paar Fehler korrigieren muss.
                              BlackTigga @BlackTigga last edited by BlackTigga
                              Anbei meine weiteren Beobachtungen:
                              Nachdem gestern im Laufe des Tages das Request-Limit erreicht wurde, erschien bis kurz vor 02:00 Uhr folgende Meldung:
                              2021-08-11 01:59:38.751 - info: viessmannapi.0 (19325) Rate limit reached. Will be reseted next day 02:00
                              2021-08-11 01:59:38.752 - error: viessmannapi.0 (19325) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/76374150xxxxxxxx//devices/$id/features
                              2021-08-11 01:59:38.752 - error: viessmannapi.0 (19325) Error: Request failed with status code 429
                              Der nächste (und einzige) Logeintrag war dann um 02:40 Uhr:
                              2021-08-11 02:40:38.929 - info: viessmannapi.0 (19325) {"viErrorId":"req-a8064f7bb16d4e2997deb18e4d760b82","statusCode":502,"errorType":"DEVICE_COMMUNICATION_ERROR","message":"DEVICE_COMMUNICATION_ERROR","extendedPayload":{"code":"404","reason":"GATEWAY_OFFLINE"}}
                              2021-08-11 02:40:38.940 - info: viessmannapi.0 (19325) Please check the connection of your gateway
                              2021-08-11 02:40:38.941 - error: viessmannapi.0 (19325) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/76374150xxxxxxxx//devices/$id/features
                              2021-08-11 02:40:38.942 - error: viessmannapi.0 (19325) Error: Request failed with status code 502
                              2021-08-11 02:40:38.954 - info: viessmannapi.0 (19325) {"viErrorId":"req-2ee6cfab343b4c3a9d175fc79c7af20a","statusCode":502,"errorType":"DEVICE_COMMUNICATION_ERROR","message":"DEVICE_COMMUNICATION_ERROR","extendedPayload":{"code":"404","reason":"GATEWAY_OFFLINE"}}
                              2021-08-11 02:40:38.955 - info: viessmannapi.0 (19325) Please check the connection of your gateway
                              2021-08-11 02:40:38.956 - error: viessmannapi.0 (19325) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/76374150xxxxxxxx//devices/$id/features
                              2021-08-11 02:40:38.957 - error: viessmannapi.0 (19325) Error: Request failed with status code 502
                              2021-08-11 02:40:39.004 - info: viessmannapi.0 (19325) {"viErrorId":"req-9534206120014dc5a58a3f6809c10b10","statusCode":502,"errorType":"DEVICE_COMMUNICATION_ERROR","message":"DEVICE_COMMUNICATION_ERROR","extendedPayload":{"code":"404","reason":"GATEWAY_OFFLINE"}}
                              2021-08-11 02:40:39.005 - info: viessmannapi.0 (19325) Please check the connection of your gateway
                              2021-08-11 02:40:39.006 - error: viessmannapi.0 (19325) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/76374150xxxxxxxx//devices/$id/features
                              2021-08-11 02:40:39.007 - error: viessmannapi.0 (19325) Error: Request failed with status code 502
                              Um 07:19 habe ich den Adapter neu gestartet, seitdem laufen die Daten wieder rein:
                              2021-08-11 07:20:57.024 - debug: viessmannapi.0 (22168) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/76374150xxxxxxxx/devices/HeatDemandControl/features {"data":[]}
                              2021-08-11 07:20:57.408 - debug: viessmannapi.0 (22168) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/76374150xxxxxxxx/devices/RoomControl-1/features {"data":[{"properties":{},"commands":{},"components":[],"apiVersion":1,"uri":"https://api.viessmann-platform.io/iot/v1/equipment/installations/396344/gateways/76374150xxxxxxxx/devices/RoomControl-1/features/device","gatewayId":"76374150xxxxxxxx","feature":"device","timestamp":"2021-08-11T00:40:56.097Z","isEnabled":true,"isReady":true,"deviceId":"RoomControl-1"}]}
                              2021-08-11 07:20:58.558 - debug: viessmannapi.0 (22168) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/76374150xxxxxxxx/devices/0/features {"data"...
                              2021-08-11 07:21:59.559 - debug: viessmannapi.0 (22168) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/76374150xxxxxxxx/devices/RoomControl-1/features {"data":[{"properties":{},"commands":{},"components":[],"apiVersion":1,"uri":"https://api.viessmann-platform.io/iot/v1/equipment/installations/396344/gateways/76374150xxxxxxxx/devices/RoomControl-1/features/device","gatewayId":"76374150xxxxxxxx","feature":"device","timestamp":"2021-08-11T00:40:56.097Z","isEnabled":true,"isReady":true,"deviceId":"RoomControl-1"}]}
                              2021-08-11 07:22:57.085 - debug: viessmannapi.0 (22168) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/76374150xxxxxxxx/devices/HeatDemandControl/features {"data":[]}
                              2021-08-11 07:22:57.351 - debug: viessmannapi.0 (22168) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/76374150xxxxxxxx/devices/0/features {"data"...
                              2021-08-11 07:22:59.194 - debug: viessmannapi.0 (22168) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/76374150xxxxxxxx/devices/RoomControl-1/features {"data":[{"properties":{},"commands":{},"components":[],"apiVersion":1,"uri":"https://api.viessmann-platform.io/iot/v1/equipment/installations/396344/gateways/76374150xxxxxxxx/devices/RoomControl-1/features/device","gatewayId":"76374150xxxxxxxx","feature":"device","timestamp":"2021-08-11T00:40:56.097Z","isEnabled":true,"isReady":true,"deviceId":"RoomControl-1"}]}
                              2021-08-11 07:23:56.993 - debug: viessmannapi.0 (22168) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/76374150xxxxxxxx/devices/HeatDemandControl/features {"data":[]}
                              2021-08-11 07:23:57.181 - debug: viessmannapi.0 (22168) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/76374150xxxxxxxx/devices/0/features {"data"...
                              2021-08-11 07:23:58.024 - debug: viessmannapi.0 (22168) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/76374150xxxxxxxx/devices/RoomControl-1/features {"data":[{"properties":{},"commands":{},"components":[],"apiVersion":1,"uri":"https://api.viessmann-platform.io/iot/v1/equipment/installations/396344/gateways/76374150xxxxxxxx/devices/RoomControl-1/features/device","gatewayId":"76374150xxxxxxxx","feature":"device","timestamp":"2021-08-11T00:40:56.097Z","isEnabled":true,"isReady":true,"deviceId":"RoomControl-1"}]}
                              2021-08-11 07:24:56.996 - debug: viessmannapi.0 (22168) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/76374150xxxxxxxx/devices/HeatDemandControl/features {"data":[]}
                              2021-08-11 07:24:57.460 - debug: viessmannapi.0 (22168) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/76374150xxxxxxxx/devices/0/features {"data"...
                                @tombox
                                Danke, ich hatte sie zwar installiert aber anscheinend wurde die installation abgebrochen. Nach der Neuinstallation funktioniert es wieder.
                                  tombox @BlackTigga last edited by tombox
                                  @blacktigga DAs ist sehr hilfreich
                                  was sind die Geräte
                                  RoomControl-1 und HeatDemandControl
                                  Haben die irgendwelche Sensoren oder braucht man davon Informationen?
                                    Ich sehe in beiden Datensätzen im Log keinerlei Informationen die ich benötigen würde und ich habe auch keine gesonderten Sensoren verbaut.
                                    Und die Logeinträge zu HeatDemandControl sehen ja auch immer so aus (ungekürzt):
                                    2021-08-11 07:20:57.024 - debug: viessmannapi.0 (22168) https://api.viessmann.com/iot/v1/equipment/installations/396344/gateways/763741501xxxxxxxx/devices/HeatDemandControl/features {"data":[]}
                                    Sieht für mich als Laie so aus, als wenn da sowieso gar keinerlei Daten abgeholt werden?!
                                      @blacktigga Ich habe dir dazu eine PN geschrieben
                                        amgxda @tombox last edited by
                                        Der Viessmann Developer Portal Changelog-Eintrag vom Juli 2021 ist auch bezeichnend. Da wird schon angekündigt, dass Datenpunkte und Funktionen hinter der Paywall verschwinden sollen. Warmwasser starten, nur gegen Gebühr, toll ausgedacht, Viessmann!
                                        "Hinweis: Die Funktionen der Basis (freien) Variante der API sind ein temporäres Angebot und der Umfang kann sich mit der Zeit gegenenfalls ändern."
                                          A Former User last edited by
                                          @amgxda Das war klar, denn die Entwicklungs- und Betriebskosten der Server kann man kaum mit dem einmaligen Kauf einer Anlage abdecken, denke ich ...
                                          Wenn's n paar Euro sind im Jahr.. wir werden sehen..
                                          Wenn's zu teuer wird, ist VControlD dann die Alternative.
                                            @ilovegym
                                            Ja, sollte Viessmann hier zu restriktiv vorgehen, werde ich die vcontrold-Lösung nutzen. Die Cloud-Lösung nutze ich hauptsächlich wegen der versprochenen 5-Jahre-Garantie. Wenn ich es richtig sehe, muss bei vcontrold nur das USB-Kabel an den RPi, der vcontrold laufen und mit iobroker.viessmann bekommt man auch noch die Datenpunkte. Das komplizierteste scheint die Erstellung der Konfigurationsdateien zu sein.
                                            Aber bis zum Garantie-Ende bin ich froh, dass es den viessmannapi-Adapter gibt 🙂
                                            795
                                            211118
