    4. Admin v5 jetzt im STABLE!
      Michael 3 @Thomas Braun last edited by Negalein
      Objects type: file
      States  type: file
      pi@raspberrypi:~ $ iobroker list instances
        system.adapter.admin.0                  : admin                 : raspberrypi                              - disabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
        system.adapter.coronavirus-statistics.0 : coronavirus-statistics: raspberrypi                              - disabled
      + system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled, port: 80
      + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
        system.adapter.email.0                  : email                 : raspberrypi                              - disabled
      + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
      + system.adapter.hs100.0                  : hs100                 : raspberrypi                              -  enabled
      + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
      + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
      + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
        system.adapter.mobile.0                 : mobile                : raspberrypi                              - disabled
      + system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.node-red.0               : node-red              : raspberrypi                              - disabled, port: 1880, bind: 0.0.0.0
      + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
      + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1884, bind: 0.0.0.0
        system.adapter.web.0                    : web                   : raspberrypi                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
      + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
      + instance is alive
      pi@raspberrypi:~ $
        Thomas Braun Most Active @Michael 3 last edited by
        @michael-3
        So ähnlich...
        iobroker start admin
          das war easy! geht wieder....
          jetzt läuft die alte Version admin 4.2.2.
          muss ich da was besonderes beachten, beim upgrade auf admin 5.1.23 ?
            @michael-3
            iobroker update
            iobroker upgrade
            Rest sollte selbsterklärend sein.
              Vielen DANK!!
              läuft jetzt auch bei mir enabled und STABLE.
                womi @Homoran last edited by
                Hm. Das ist schon eine Weile her und ich möchte es daher nicht ausschliessen.
                Ausserdem hat sich der Slave mal abgekoppelt und ich musste ihn neu verbinden. Spätestens dann kann ich ja die Adapter nicht wieder runterwerfen.
                Finale Frage: Und wie bekomme ich das jetzt wieder geradegezogen?
                Alle Adapter auf den Host zurückstellen, abkoppeln, Adapter löschen und alles wieder zurück? Oder geht es einfacher?
                  Homoran Global Moderator Administrators @womi last edited by
                  @womi sagte in Admin v5 jetzt im STABLE!:
                  so hätte ich es jetzt gemacht, wobei ich den Slave komplett neu aufgesetzt hätte, die initialen Adapter gelöscht und dann die Verbindung zum Master hergestellt.
                  Aber so etwas habe ich ewig nicht mehr gemacht. Vielleicht kann dir jemand, der das vir kurzer Zeit praktiziert hat bestätigen
                  • Fabio
                    Fabio @crunchip last edited by
                    @crunchip ich weiß noch nicht mal was Github ist. Mal sehen, ich schau mir das mal an. Es geht ja auch ums verstehen und es wird im Alter und auch mit English immer schwieriger.🙃 😉
                    cash 1 Reply Last reply Reply Quote 0
                    • cash
                      cash Most Active @Fabio last edited by
                      @fa-bio github ist eine Entwicklerplattform wo der Quellcode der Adaper liegt. Für den Entwander ist dort der Bereich „Issue“ beim jeweiligen Adapter interessant. Dort kann man Fehler melden bzw Wünsche äußern. Andere User können dann den Fehler kommentieren. Der jeweilige Adapterentwickler sieht dort die Fehler und kann sich kümmern. Manchmal hat der Enwickler noch Fragen falls er den Fehler nicht reproduzieren kann.
                      Er meldet sich auch dort wenn der Fehler gefixt ist und Du dann ggf testen sollst…
                      Gute Palttform. Macht es den Entwicklern einfacher alles im Blick zu behalten. Also anmelden schadet nicht.
                      Fabio 1 Reply Last reply Reply Quote 1
                        apollon77 @Fabio last edited by
                        @fa-bio github -> github.com eine Web-Platform für die Entwicklung. Dort ein "Ticket" auf machen , auch Issue genannt und dann so einen Feature-Request erstellen.
                        Fabio 2 Replies Last reply Reply Quote 1
                          apollon77 @biker1602 last edited by
                          @biker1602 Es ist korrekt, der wurde bisher nicht angezeigt weil Admin4 bestimmte Objekttypen ignoriert hat. Admin5 zeigt da mehr an
                            apollon77 @Andersmacher last edited by
                            @andersmacher alias wird automatisch vom js-controller angelegt
                              apollon77 @womi last edited by
                              @womi Ja ich denke da gibt es dann noch ein issue im js-controller. An sich sollte - wenn man einen Adapter auf einem Host löscht - auch nur dort die Instanzen verschwinden. Machst Du bitte ein js.controlelr Issue auf dazu? Können wir künftig fixen
                              Die "kleine" Lösung inzwischen ist das Du manuell auf den Host gehst wo der Adapter nicht mehr nötig ist per SSH und dann in /opt/iobroker und dort "npm uninstall ioborker.adaptername" machst. Danach ist der da weg
                                A Former User last edited by
                                Wir bei einem Clean install von.
                                https://www.iobroker.net/#de/download
                                auch bereits die neue Version installiert?
                                  apollon77 @Guest last edited by
                                  @paul-ol Seit heute Abend ja. Das machen wir immer erst ein paar Tage verzögert
                                    A Former User @apollon77 last edited by
                                    @apollon77 sicher?
                                    • Fabio
                                      Fabio @cash last edited by
                                      @cash vielen Dank Cash für die Erklärung. Dann wird der alte Mann sich da mal da umschauen.👍
                                      • Fabio
                                        Fabio @apollon77 last edited by
                                        @apollon77 Danke appollon77, dann werde ich mich mal anmelden oder? Da bleibt einem ja nix anders übrig.😊
                                        • Fabio
                                          @apollon77 so ich hoffe es ist richtig so: https://github.com/ioBroker/ioBroker.admin/issues/1085
                                          sansonifabio created this issue in ioBroker/ioBroker.admin
                                          closed User Einstellungen speichern #1085
                                            @paul-ol Also wenn Du >23 Uhr oder so installiert hast dann ja ... Weiss geade nicht was der Screenshot zeigen soll?
                                            563
                                            121685
